[GRASS-SVN] r50208 - grass/branches/develbranch_6/vector/v.proj
svn_grass at osgeo.org
Mon Jan 16 03:09:05 EST 2012
Author: hamish
Date: 2012-01-16 00:09:04 -0800 (Mon, 16 Jan 2012)
New Revision: 50208
grass/branches/develbranch_6/vector/v.proj/description.html
fix parameter names
Modified: grass/branches/develbranch_6/vector/v.proj/description.html
--- grass/branches/develbranch_6/vector/v.proj/description.html 2012-01-15 19:02:20 UTC (rev 50207)
+++ grass/branches/develbranch_6/vector/v.proj/description.html 2012-01-16 08:09:04 UTC (rev 50208)
@@ -9,16 +9,17 @@
<h2>NOTES</h2>
-If <b>out</b> is not specified it is set to be the same as input map name.
+If <b>output</b> is not specified it is set to be the same as input map
+name.
<br>
-If <b>dbase</b> is not specified it is assumed to be the current database.
-The user only has to specify <b>dbase</b> if the source location is stored
-in another separate GRASS database.
+If <b>mapset</b> is not specified, its name is assumed to be the same
+as the current mapset's name.
<br>
-If <b>set</b> is not specified, its name is assumed to be the same as the current
- mapset's name.
+If <b>dbase</b> is not specified it is assumed to be the current
+database. The user only has to specify <b>dbase</b> if the source
+location is stored in another separate GRASS database.
<p>
<em>v.proj</em> supports general datum transformations, making use of the
