[GRASS-SVN] r50242 - grass/branches/develbranch_6/scripts/v.report
svn_grass at osgeo.org
Tue Jan 17 14:33:13 EST 2012
Author: hamish
Date: 2012-01-17 11:33:13 -0800 (Tue, 17 Jan 2012)
New Revision: 50242
grass/branches/develbranch_6/scripts/v.report/v.report
quote some variables (probably not really needed)
Modified: grass/branches/develbranch_6/scripts/v.report/v.report
--- grass/branches/develbranch_6/scripts/v.report/v.report 2012-01-17 19:26:55 UTC (rev 50241)
+++ grass/branches/develbranch_6/scripts/v.report/v.report 2012-01-17 19:33:13 UTC (rev 50242)
@@ -99,14 +99,14 @@
LAYER="$GIS_OPT_LAYER"
# does the input vector map exist?
-eval `g.findfile element=vector file=$GIS_OPT_MAP`
+eval `g.findfile element=vector file="$GIS_OPT_MAP"`
if [ ! "$file" ] ; then
g.message -e "Vector map '$MAP' not found in mapset search path."
exit 1
fi
#test if the input vector has a table attached in the given layer
-v.info -c map=$MAP layer=$LAYER >/dev/null 2>&1
+v.info -c map="$MAP" layer="$LAYER" >/dev/null 2>&1
if [ $? -eq 0 ] ; then
TABLEEXISTS=1
else
@@ -114,7 +114,7 @@
fi
#fetch column names
-if [ $TABLEEXISTS -eq 1 ] ; then
+if [ "$TABLEEXISTS" -eq 1 ] ; then
COLNAMES="`v.info -c map=$MAP layer=$LAYER | grep -v '^Displaying column type' | cut -d '|' -f2 | tr '\n' '|'`" >/dev/null 2>&1
else
COLNAMES="cat|"
@@ -140,7 +140,7 @@
## NOTE: we suppress -1 cat and 0 cat
v.db.select -c map="$MAP" layer="$LAYER" | sort -n -t'|' -k 1 | grep -v '^0' > "$TMP1"
if [ `wc -l "$TMP1" | awk '{print $1}'` -eq 0 ] ; then
KEY=`v.db.connect -gl map="$GIS_OPT_MAP" fs="|" layer="$LAYER" | cut -f3 -d'|'`
