[GRASS-SVN] r50284 - in grass/trunk/lib/temporal: . SQL src
Wed Jan 18 19:11:22 EST 2012
Author: huhabla
Date: 2012-01-18 16:11:22 -0800 (Wed, 18 Jan 2012)
New Revision: 50284
Added:
   grass/trunk/lib/temporal/SQL/
   grass/trunk/lib/temporal/SQL/map_stds_register_table_template.sql
   grass/trunk/lib/temporal/SQL/map_tables_template.sql
   grass/trunk/lib/temporal/SQL/raster3d_metadata_table.sql
   grass/trunk/lib/temporal/SQL/raster_metadata_table.sql
   grass/trunk/lib/temporal/SQL/sqlite3_delete_trigger.sql
   grass/trunk/lib/temporal/SQL/stds_map_register_table_template.sql
   grass/trunk/lib/temporal/SQL/stds_raster3d_register_trigger_template.sql
   grass/trunk/lib/temporal/SQL/stds_raster_register_trigger_template.sql
   grass/trunk/lib/temporal/SQL/stds_tables_template.sql
   grass/trunk/lib/temporal/SQL/stds_vector_register_trigger_template.sql
   grass/trunk/lib/temporal/SQL/str3ds_metadata_table.sql
   grass/trunk/lib/temporal/SQL/strds_metadata_table.sql
   grass/trunk/lib/temporal/SQL/stvds_metadata_table.sql
   grass/trunk/lib/temporal/SQL/test.temporal.py
   grass/trunk/lib/temporal/SQL/update_stds_spatial_temporal_extent_template.sql
   grass/trunk/lib/temporal/SQL/update_str3ds_metadata_template.sql
   grass/trunk/lib/temporal/SQL/update_strds_metadata_template.sql
   grass/trunk/lib/temporal/SQL/update_stvds_metadata_template.sql
   grass/trunk/lib/temporal/SQL/vector_metadata_table.sql
   grass/trunk/lib/temporal/src/
   grass/trunk/lib/temporal/src/Makefile
   grass/trunk/lib/temporal/src/connect.c
   grass/trunk/lib/temporal/src/default_name.c
Removed:
   grass/trunk/lib/temporal/map_stds_register_table_template.sql
   grass/trunk/lib/temporal/map_tables_template.sql
   grass/trunk/lib/temporal/raster3d_metadata_table.sql
   grass/trunk/lib/temporal/raster_metadata_table.sql
   grass/trunk/lib/temporal/sqlite3_delete_trigger.sql
   grass/trunk/lib/temporal/stds_map_register_table_template.sql
   grass/trunk/lib/temporal/stds_raster3d_register_trigger_template.sql
   grass/trunk/lib/temporal/stds_raster_register_trigger_template.sql
   grass/trunk/lib/temporal/stds_tables_template.sql
   grass/trunk/lib/temporal/stds_vector_register_trigger_template.sql
   grass/trunk/lib/temporal/str3ds_metadata_table.sql
   grass/trunk/lib/temporal/strds_metadata_table.sql
   grass/trunk/lib/temporal/stvds_metadata_table.sql
   grass/trunk/lib/temporal/test.temporal.py
   grass/trunk/lib/temporal/update_stds_spatial_temporal_extent_template.sql
   grass/trunk/lib/temporal/update_str3ds_metadata_template.sql
   grass/trunk/lib/temporal/update_strds_metadata_template.sql
   grass/trunk/lib/temporal/update_stvds_metadata_template.sql
   grass/trunk/lib/temporal/vector_metadata_table.sql
   grass/trunk/lib/temporal/Makefile
New directory structure. Added temporal C-library with temporal database init functions.
Modified: grass/trunk/lib/temporal/Makefile
--- grass/trunk/lib/temporal/Makefile	2012-01-18 22:33:23 UTC (rev 50283)
+++ grass/trunk/lib/temporal/Makefile	2012-01-19 00:11:22 UTC (rev 50284)
@@ -1,17 +1,13 @@
 MODULE_TOPDIR = ../..
-include $(MODULE_TOPDIR)/include/Make/Other.make
+include $(MODULE_TOPDIR)/include/Make/Vars.make
-SQLDIR = $(ETC)/sql
+#order is relevant:
+SUBDIRS = \
+	SQL \
+	src
-SQLFILES:= $(wildcard *.sql)
+include $(MODULE_TOPDIR)/include/Make/Dir.make
-DSTFILES := $(patsubst %.sql,$(SQLDIR)/%.sql,$(SQLFILES))
+default: subdirs
-default: $(DSTFILES)
-$(SQLDIR):
-	$(MKDIR) $@
-$(SQLDIR)/%.sql: %.sql | $(SQLDIR)
-	$(INSTALL_DATA) $< $@
Copied: grass/trunk/lib/temporal/SQL/map_stds_register_table_template.sql (from rev 50164, grass/trunk/lib/temporal/map_stds_register_table_template.sql)
--- grass/trunk/lib/temporal/SQL/map_stds_register_table_template.sql	                        (rev 0)
+++ grass/trunk/lib/temporal/SQL/map_stds_register_table_template.sql	2012-01-19 00:11:22 UTC (rev 50284)
@@ -0,0 +1,38 @@
+-- This SQL script generates the table listing all STDS in
+-- which the GRASS_MAP map is registered
+-- This table is map specific and created for each GRASS_MAP map which is registered
+-- in a STDS. TABLE_NAME is a placeholder for the table name which must be unique.
+-- A uuid is used as unique identifier across mapsets.
+-- Author: Soeren Gebbert soerengebbert <at> googlemail <dot> com
+--PRAGMA foreign_keys = ON;
+-- TABLE_NAME is a placeholder for specific table name (SQL compliant)
+-- MAP_ID is a placeholder for specific map id: name at mapset
+-- GRASS_MAP is a placeholder for specific map type: raster, raster3d or vector
+-- STDS is a placeholder for specific space-time dataset type: strds, str3ds, stvds
+-- This table stores the names of the space-time datasets in which this map is registered
+CREATE TABLE  TABLE_NAME_STDS_register (
+  id VARCHAR NOT NULL, -- This column is a primary foreign key storing the STDS names
+  PRIMARY KEY (id),
+  FOREIGN KEY (id) REFERENCES  STDS_base (id) ON DELETE CASCADE
+--CREATE TRIGGER TABLE_NAME_STDS_register_insert AFTER INSERT ON TABLE_NAME_STDS_register
+--  BEGIN
+--    UPDATE GRASS_MAP_base SET modification_time = datetime("NOW") WHERE GRASS_MAP_base.id = 'MAP_ID';
+--    UPDATE GRASS_MAP_base SET revision = (revision + 1) WHERE GRASS_MAP_base.id = 'MAP_ID';
+--  END;
+--CREATE TRIGGER TABLE_NAME_STDS_register_delete AFTER DELETE ON TABLE_NAME_STDS_register
+--  BEGIN
+--  END;
Copied: grass/trunk/lib/temporal/SQL/map_tables_template.sql (from rev 50164, grass/trunk/lib/temporal/map_tables_template.sql)
--- grass/trunk/lib/temporal/SQL/map_tables_template.sql	                        (rev 0)
+++ grass/trunk/lib/temporal/SQL/map_tables_template.sql	2012-01-19 00:11:22 UTC (rev 50284)
@@ -0,0 +1,83 @@
+-- This SQL script generates the grass map tables to store time stamps, revision
+-- and spatial extent for SQL queries and temporal GIS support.
+-- Additionally several triggers are created for convenient functions
+-- The grass map metadata is map specific (raster, raster3d and vector maps are
+-- supported)
+-- The placeholder GRASS_MAP will be replaced by raster, raster3d and vector
+CREATE TABLE  GRASS_MAP_base (
+  id VARCHAR NOT NULL,                  -- The id (PK) is the unique identifier for all tables, it is based on name and mapset (name at mapset) and is used as primary key
+  name VARCHAR NOT NULL,                -- name of the grass map
+  mapset VARCHAR NOT NULL,              -- mapset of the grass map
+  creator VARCHAR NOT NULL,
+  temporal_type VARCHAR,                -- The temporal type of the grass map "absolute" or "relative" or NULL in case no time stamp is available
+  creation_time TIMESTAMP NOT NULL,      -- The time of creation of the grass map
+-- Uncommented due to performance issues
+--  modification_time TIMESTAMP NOT NULL,  -- The time of the last modification of the grass map
+--  revision SMALLINT NOT NULL,           -- The revision number
+  PRIMARY KEY (id)
+-- Relative valid time interval with start and end time
+CREATE TABLE  GRASS_MAP_relative_time (
+  id VARCHAR NOT NULL,          -- The id (PFK) is the unique identifier for all tables, it is based on name and mapset (name at mapset) and is used as primary foreign key
+  start_time DOUBLE PRECISION,  -- The relative valid start time in [days]
+  end_time DOUBLE PRECISION,    -- The relative valid end time in [days]
+  PRIMARY KEY (id),
+  FOREIGN KEY (id) REFERENCES  GRASS_MAP_base (id) ON DELETE CASCADE
+CREATE TABLE  GRASS_MAP_absolute_time (
+  start_time TIMESTAMP,  --  Start of the valid time, can be NULL if no time information is available
+  end_time TIMESTAMP,    --  End of the valid time, can be NULL if no time information is available or valid time is a single point in time
+  timezone SMALLINT,     -- The timezone of the valid time
+  PRIMARY KEY (id),
+-- The spatial extent of a raster map
+CREATE TABLE  GRASS_MAP_spatial_extent (
+  id VARCHAR NOT NULL,                  -- The id (PFK) is the unique identifier for all tables, it is based on name and mapset (name at mapset) and is used as primary foreigen key
+  -- below is the spatial extent of the map
+  north DOUBLE PRECISION NOT NULL,
+  south DOUBLE PRECISION NOT NULL,
+  east DOUBLE PRECISION NOT NULL,
+  west DOUBLE PRECISION NOT NULL,
+  top DOUBLE PRECISION NOT NULL,
+  bottom DOUBLE PRECISION NOT NULL,
+  proj VARCHAR,
+  PRIMARY KEY (id),
+-- Create a trigger to update the modification time and revision number in case the metadata or timestanps have been updated
+--CREATE TRIGGER update_GRASS_MAP_absolute_time AFTER UPDATE ON GRASS_MAP_absolute_time
+--  BEGIN
+--    UPDATE GRASS_MAP_base SET modification_time = datetime("NOW") WHERE id = old.id;
+--    UPDATE GRASS_MAP_base SET revision = (revision + 1) WHERE id = old.id;
+-- END;
+--CREATE TRIGGER update_GRASS_MAP_relative_time AFTER UPDATE ON GRASS_MAP_relative_time
+--  BEGIN
+--  END;
+--CREATE TRIGGER update_GRASS_MAP_spatial_extent AFTER UPDATE ON GRASS_MAP_spatial_extent
+--  BEGIN
+--  END;
Copied: grass/trunk/lib/temporal/SQL/raster3d_metadata_table.sql (from rev 50164, grass/trunk/lib/temporal/raster3d_metadata_table.sql)
--- grass/trunk/lib/temporal/SQL/raster3d_metadata_table.sql	                        (rev 0)
+++ grass/trunk/lib/temporal/SQL/raster3d_metadata_table.sql	2012-01-19 00:11:22 UTC (rev 50284)
@@ -0,0 +1,74 @@
+-- This SQL script generates the raster3d metadata table to store
+-- and metadata for SQL queries and temporal GIS support. Additionally two views
+-- are created to access all map specific tables
+-- The metadata table reflects most of the raster3d metadata available in grass
+CREATE TABLE  raster3d_metadata (
+  str3ds_register VARCHAR, -- The name of the table storing all space-time raster3d datasets in which this map is registered
+  datatype VARCHAR NOT NULL,
+  cols INTEGER NOT NULL,
+  rows INTEGER NOT NULL,
+  depths INTEGER NOT NULL,
+  number_of_cells INTEGER NOT NULL,
+  nsres DOUBLE PRECISION NOT NULL,
+  ewres DOUBLE PRECISION NOT NULL,
+  tbres DOUBLE PRECISION NOT NULL,
+  min DOUBLE PRECISION,
+  max DOUBLE PRECISION,
+  PRIMARY KEY (id),
+  FOREIGN KEY (id) REFERENCES  raster3d_base (id) ON DELETE CASCADE
+-- Create the views to access all cols for the absolute and relative time
+CREATE VIEW raster3d_view_abs_time AS SELECT
+            A1.id, A1.mapset,
+            A1.name, A1.temporal_type,
+            A1.creation_time,
+--            A1.modification_time, A1.revision,
+            A1.creator,
+	    A2.start_time, A2.end_time, A2.timezone,
+            A3.north, A3.south, A3.east, A3.west, A3.proj,
+	    A4.datatype, A4.cols, A4.rows, A4.depths,
+            A4.nsres, A4.ewres, A4.tbres,
+            A4.min, A4.max,
+	    A4.str3ds_register,
+            A4.number_of_cells
+	    FROM raster3d_base A1, raster3d_absolute_time A2,
+            raster3d_spatial_extent A3, raster3d_metadata A4
+	    WHERE A1.id = A2.id AND A1.id = A3.id AND A1.id = A4.id;
+CREATE VIEW raster3d_view_rel_time AS SELECT
+            A1.id, A1.mapset,
+            A1.creation_time,
+            A1.creator,
+            A4.min, A4.max,
+	    FROM raster3d_base A1, raster3d_relative_time A2,
+-- Create a trigger to update the modification time and revision number in case the metadata have been updated
+--CREATE TRIGGER update_raster3d_metadata AFTER UPDATE ON raster3d_metadata
+--  BEGIN
+--    UPDATE raster3d_base SET modification_time = datetime("NOW") WHERE id = old.id;
+--    UPDATE raster3d_base SET revision = (revision + 1) WHERE id = old.id;
+--  END;
Copied: grass/trunk/lib/temporal/SQL/raster_metadata_table.sql (from rev 50164, grass/trunk/lib/temporal/raster_metadata_table.sql)
--- grass/trunk/lib/temporal/SQL/raster_metadata_table.sql	                        (rev 0)
+++ grass/trunk/lib/temporal/SQL/raster_metadata_table.sql	2012-01-19 00:11:22 UTC (rev 50284)
@@ -0,0 +1,71 @@
+-- This SQL script generates the raster metadata table to store
+-- The metadata table reflects most of the raster metadata available in grass
+CREATE TABLE  raster_metadata (
+  strds_register VARCHAR,            -- The name of the table storing all space-time raster datasets in which this map is registered
+  PRIMARY KEY (id),
+  FOREIGN KEY (id) REFERENCES  raster_base (id) ON DELETE CASCADE
+CREATE VIEW raster_view_abs_time AS SELECT
+            A1.id, A1.mapset,
+            A1.creation_time,
+            A1.creator,
+            A4.nsres, A4.ewres, A4.min, A4.max,
+	    A4.strds_register,
+	    FROM raster_base A1, raster_absolute_time A2,
+            raster_spatial_extent A3, raster_metadata A4
+CREATE VIEW raster_view_rel_time AS SELECT
+            A1.id, A1.mapset,
+            A1.creation_time,
+            A1.creator,
+	    FROM raster_base A1, raster_relative_time A2,
+--CREATE TRIGGER update_raster_metadata AFTER UPDATE ON raster_metadata
+--  BEGIN
+--    UPDATE raster_base SET modification_time = datetime("NOW") WHERE id = old.id;
+--    UPDATE raster_base SET revision = (revision + 1) WHERE id = old.id;
+--  END;
Copied: grass/trunk/lib/temporal/SQL/sqlite3_delete_trigger.sql (from rev 50164, grass/trunk/lib/temporal/sqlite3_delete_trigger.sql)
--- grass/trunk/lib/temporal/SQL/sqlite3_delete_trigger.sql	                        (rev 0)
+++ grass/trunk/lib/temporal/SQL/sqlite3_delete_trigger.sql	2012-01-19 00:11:22 UTC (rev 50284)
@@ -0,0 +1,51 @@
+-- Create trigger for automated deletion of dependent rows, this should normally be done using foreign keys
+CREATE TRIGGER delete_strds_base AFTER DELETE ON strds_base
+  BEGIN
+    DELETE FROM strds_absolute_time WHERE id = old.id;
+    DELETE FROM strds_relative_time WHERE id = old.id;
+    DELETE FROM strds_spatial_extent WHERE id = old.id;
+    DELETE FROM strds_metadata WHERE id = old.id;
+  END;
+CREATE TRIGGER delete_raster_base AFTER DELETE ON raster_base
+  BEGIN
+    DELETE FROM raster_absolute_time WHERE id = old.id;
+    DELETE FROM raster_relative_time WHERE id = old.id;
+    DELETE FROM raster_spatial_extent WHERE id = old.id;
+    DELETE FROM raster_metadata WHERE id = old.id;
+  END;
+CREATE TRIGGER delete_str3ds_base AFTER DELETE ON str3ds_base
+  BEGIN
+    DELETE FROM str3ds_absolute_time WHERE id = old.id;
+    DELETE FROM str3ds_relative_time WHERE id = old.id;
+    DELETE FROM str3ds_spatial_extent WHERE id = old.id;
+    DELETE FROM str3ds_metadata WHERE id = old.id;
+  END;
+CREATE TRIGGER delete_raster3d_base AFTER DELETE ON raster3d_base
+  BEGIN
+    DELETE FROM raster3d_absolute_time WHERE id = old.id;
+    DELETE FROM raster3d_relative_time WHERE id = old.id;
+    DELETE FROM raster3d_spatial_extent WHERE id = old.id;
+    DELETE FROM raster3d_metadata WHERE id = old.id;
+  END;
+CREATE TRIGGER delete_stvds_base AFTER DELETE ON stvds_base
+  BEGIN
+    DELETE FROM stvds_absolute_time WHERE id = old.id;
+    DELETE FROM stvds_relative_time WHERE id = old.id;
+    DELETE FROM stvds_spatial_extent WHERE id = old.id;
+    DELETE FROM stvds_metadata WHERE id = old.id;
+  END;
+CREATE TRIGGER delete_vector_base AFTER DELETE ON vector_base
+  BEGIN
+    DELETE FROM vector_absolute_time WHERE id = old.id;
+    DELETE FROM vector_relative_time WHERE id = old.id;
+    DELETE FROM vector_spatial_extent WHERE id = old.id;
+    DELETE FROM vector_metadata WHERE id = old.id;
+  END;
Copied: grass/trunk/lib/temporal/SQL/stds_map_register_table_template.sql (from rev 50164, grass/trunk/lib/temporal/stds_map_register_table_template.sql)
--- grass/trunk/lib/temporal/SQL/stds_map_register_table_template.sql	                        (rev 0)
+++ grass/trunk/lib/temporal/SQL/stds_map_register_table_template.sql	2012-01-19 00:11:22 UTC (rev 50284)
@@ -0,0 +1,129 @@
+-- This SQL script generates the table in which all registered GRASS_MAP maps
+-- are listed in.
+-- This table will be created for each STDS.
+-- SPACETIME_NAME is a placeholder for specific stds name (SQL compliant): name_mapset
+-- SPACETIME_ID is a placeholder for specific stds id: name at mapset
+-- This table stores the.ids of the GRASS_MAP maps registered in the current spacetime GRASS_MAP table
+CREATE TABLE  SPACETIME_NAME_GRASS_MAP_register (
+  id VARCHAR NOT NULL, -- This colum is a primary foreign key storing the registered GRASS_MAP map.ids
+  PRIMARY KEY (id),
+-- Triggers are disabled due to huge performance issues
+--CREATE TRIGGER SPACETIME_NAME_GRASS_MAP_register_insert_trigger AFTER INSERT ON SPACETIME_NAME_GRASS_MAP_register
+--  BEGIN
+--    UPDATE STDS_base SET modification_time = datetime("NOW") WHERE id = 'SPACETIME_ID';
+--    UPDATE STDS_base SET revision = (revision + 1) WHERE id = 'SPACETIME_ID';
+--    -- Number of registered maps
+--    UPDATE STDS_metadata SET number_of_maps =
+--           (SELECT count(id) FROM SPACETIME_NAME_GRASS_MAP_register)
+--           WHERE id = 'SPACETIME_ID';
+--    -- Update the temporal extent
+--    UPDATE STDS_absolute_time SET start_time =
+--           (SELECT min(start_time) FROM GRASS_MAP_absolute_time WHERE GRASS_MAP_absolute_time.id IN
+--			(SELECT id FROM SPACETIME_NAME_GRASS_MAP_register)
+--           ) WHERE id = 'SPACETIME_ID';
+--    UPDATE STDS_absolute_time SET end_time =
+--           (SELECT max(end_time) FROM GRASS_MAP_absolute_time WHERE GRASS_MAP_absolute_time.id IN
+--    UPDATE STDS_relative_time SET start_time =
+--           (SELECT min(start_time) FROM GRASS_MAP_relative_time WHERE GRASS_MAP_relative_time.id IN
+--    UPDATE STDS_relative_time SET end_time =
+--           (SELECT max(end_time) FROM GRASS_MAP_relative_time WHERE GRASS_MAP_relative_time.id IN
+--    -- Update the spatial extent
+--    UPDATE STDS_spatial_extent SET north =
+--           (SELECT max(north) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
+--    UPDATE STDS_spatial_extent SET south =
+--           (SELECT min(south) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
+--    UPDATE STDS_spatial_extent SET east =
+--           (SELECT max(east) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
+--    UPDATE STDS_spatial_extent SET west =
+--           (SELECT min(west) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
+--    UPDATE STDS_spatial_extent SET top =
+--           (SELECT max(top) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
+--    UPDATE STDS_spatial_extent SET bottom =
+--           (SELECT min(bottom) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
+--    UPDATE STDS_spatial_extent SET proj =
+--           (SELECT min(proj) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
+--  END;
+--CREATE TRIGGER SPACETIME_NAME_GRASS_MAP_register_delete_trigger AFTER DELETE ON SPACETIME_NAME_GRASS_MAP_register
+-- BEGIN
+--  END;
Copied: grass/trunk/lib/temporal/SQL/stds_raster3d_register_trigger_template.sql (from rev 50164, grass/trunk/lib/temporal/stds_raster3d_register_trigger_template.sql)
--- grass/trunk/lib/temporal/SQL/stds_raster3d_register_trigger_template.sql	                        (rev 0)
+++ grass/trunk/lib/temporal/SQL/stds_raster3d_register_trigger_template.sql	2012-01-19 00:11:22 UTC (rev 50284)
@@ -0,0 +1,113 @@
+-- This SQL script creates a trigger to update a space-time raster3d dataset
+-- metadata
+--CREATE TRIGGER SPACETIME_NAME_raster3d_metadata_register_insert_trigger AFTER INSERT ON SPACETIME_NAME_raster3d_register
+--  BEGIN
+--    -- Update the min and max values
+--    UPDATE str3ds_metadata SET min_min =
+--           (SELECT min(min) FROM raster3d_metadata WHERE raster3d_metadata.id IN
+--			(SELECT id FROM SPACETIME_NAME_raster3d_register)
+--    UPDATE str3ds_metadata SET min_max =
+--           (SELECT max(min) FROM raster3d_metadata WHERE raster3d_metadata.id IN
+--    UPDATE str3ds_metadata SET max_min =
+--           (SELECT min(max) FROM raster3d_metadata WHERE raster3d_metadata.id IN
+--    UPDATE str3ds_metadata SET max_max =
+--           (SELECT max(max) FROM raster3d_metadata WHERE raster3d_metadata.id IN
+--    -- Update the resolution
+--    UPDATE str3ds_metadata SET nsres_min =
+--           (SELECT min(nsres) FROM raster3d_metadata WHERE raster3d_metadata.id IN
+--    UPDATE str3ds_metadata SET nsres_max =
+--           (SELECT max(nsres) FROM raster3d_metadata WHERE raster3d_metadata.id IN
+--    UPDATE str3ds_metadata SET ewres_min =
+--           (SELECT min(ewres) FROM raster3d_metadata WHERE raster3d_metadata.id IN
+--    UPDATE str3ds_metadata SET ewres_max =
+--           (SELECT max(ewres) FROM raster3d_metadata WHERE raster3d_metadata.id IN
+--    UPDATE str3ds_metadata SET tbres_min =
+--           (SELECT min(tbres) FROM raster3d_metadata WHERE raster3d_metadata.id IN
+--    UPDATE str3ds_metadata SET tbres_max =
+--           (SELECT max(tbres) FROM raster3d_metadata WHERE raster3d_metadata.id IN
+--  END;
+--CREATE TRIGGER SPACETIME_NAME_raster3d_metadata_register_delete_trigger AFTER DELETE ON SPACETIME_NAME_raster3d_register
+--  BEGIN
+--  END;
Copied: grass/trunk/lib/temporal/SQL/stds_raster_register_trigger_template.sql (from rev 50164, grass/trunk/lib/temporal/stds_raster_register_trigger_template.sql)
--- grass/trunk/lib/temporal/SQL/stds_raster_register_trigger_template.sql	                        (rev 0)
+++ grass/trunk/lib/temporal/SQL/stds_raster_register_trigger_template.sql	2012-01-19 00:11:22 UTC (rev 50284)
@@ -0,0 +1,113 @@
+-- This SQL script creates a trigger to update a space-time raster dataset
+-- metadata
+--CREATE TRIGGER SPACETIME_NAME_raster_metadata_register_insert_trigger AFTER INSERT ON SPACETIME_NAME_raster_register
+--  BEGIN
+--    UPDATE strds_metadata SET min_min =
+--           (SELECT min(min) FROM raster_metadata WHERE raster_metadata.id IN
+--			(SELECT id FROM SPACETIME_NAME_raster_register)
+--    UPDATE strds_metadata SET min_max =
+--           (SELECT max(min) FROM raster_metadata WHERE raster_metadata.id IN
+--    UPDATE strds_metadata SET max_min =
+--           (SELECT min(max) FROM raster_metadata WHERE raster_metadata.id IN
+--    UPDATE strds_metadata SET max_max =
+--           (SELECT max(max) FROM raster_metadata WHERE raster_metadata.id IN
+--    UPDATE strds_metadata SET nsres_min =
+--           (SELECT min(nsres) FROM raster_metadata WHERE raster_metadata.id IN
+--    UPDATE strds_metadata SET nsres_max =
+--           (SELECT max(nsres) FROM raster_metadata WHERE raster_metadata.id IN
+--    UPDATE strds_metadata SET ewres_min =
+--           (SELECT min(ewres) FROM raster_metadata WHERE raster_metadata.id IN
+--    UPDATE strds_metadata SET ewres_max =
+--           (SELECT max(ewres) FROM raster_metadata WHERE raster_metadata.id IN
+--  END;
+--CREATE TRIGGER SPACETIME_NAME_raster_metadata_register_delete_trigger AFTER DELETE ON SPACETIME_NAME_raster_register
+--  BEGIN
+--  END;
Copied: grass/trunk/lib/temporal/SQL/stds_tables_template.sql (from rev 50164, grass/trunk/lib/temporal/stds_tables_template.sql)
--- grass/trunk/lib/temporal/SQL/stds_tables_template.sql	                        (rev 0)
+++ grass/trunk/lib/temporal/SQL/stds_tables_template.sql	2012-01-19 00:11:22 UTC (rev 50284)
@@ -0,0 +1,79 @@
+-- This SQL script generates the space time dataset tables to store time
+-- stamps and revision for SQL queries and temporal GIS support.
+CREATE TABLE  STDS_base (
+  id VARCHAR NOT NULL,                 -- Id of the space-time dataset, name at mapset this is the primary key
+  name VARCHAR NOT NULL,               -- name of the space-time dataset
+  mapset VARCHAR NOT NULL,             -- mapset of the space-time dataset
+  creator VARCHAR NOT NULL,            -- Name of the creator
+  temporal_type VARCHAR NOT NULL,      -- The temporal type of the dataset "absolute" or "relative"
+  semantic_type VARCHAR NOT NULL,      -- The semantic data description used for aggregation/decomposition algorithm selection
+  creation_time TIMESTAMP NOT NULL,    -- The time of creation of the space-time dataset
+--  revision SMALLINT NOT NULL,            -- The revision number        -- The revision number
+  PRIMARY KEY (id)
+CREATE TABLE  STDS_relative_time (
+  id VARCHAR NOT NULL,            -- Id of the space-time dataset, this is the primary foreign key
+  granularity DOUBLE PRECISION,   -- The granularity in [days]
+  map_time VARCHAR,               -- The temporal type of the registered maps, may be interval, point or mixed
+  PRIMARY KEY (id),
+CREATE TABLE  STDS_absolute_time (
+  start_time TIMESTAMP,           -- Start of the valid time, can be NULL if no map is registered
+  end_time TIMESTAMP,             -- End of the valid time, can be NULL if no map is registered
+  granularity VARCHAR,            -- The granularity "NNN seconds, NNN minutes, NNN hours, NNN days, NNN weeks, NNN months, NNN years"
+  timezone SMALLINT,              -- The time zone number
+  PRIMARY KEY (id),
+CREATE TABLE  STDS_spatial_extent (
+  north DOUBLE PRECISION,   -- The spatial north extent, derived from the registered maps
+  south DOUBLE PRECISION,   -- The spatial south extent, derived from the registered maps
+  east DOUBLE PRECISION,    -- The spatial east extent, derived from the registered maps
+  west DOUBLE PRECISION,    -- The spatial west extent, derived from the registered maps
+  top DOUBLE PRECISION,     -- The spatial top extent, derived from the registered maps
+  bottom DOUBLE PRECISION,  -- The spatial bottom extent, derived from the registered maps
+  proj VARCHAR,      -- The projection of the space time dataset (XY of LL)
+  PRIMARY KEY (id),
+--CREATE TRIGGER update_STDS_abs_time AFTER UPDATE ON STDS_absolute_time
+--  BEGIN
+--    UPDATE STDS_base SET modification_time = datetime("NOW") WHERE id = old.id;
+--    UPDATE STDS_base SET revision = (revision + 1) WHERE id = old.id;
+--  END;
+--CREATE TRIGGER update_STDS_rel_time AFTER UPDATE ON STDS_relative_time
+--  BEGIN
+--  END;
+--CREATE TRIGGER update_STDS_spatial_extent AFTER UPDATE ON STDS_spatial_extent
+--  BEGIN
+--  END;
Copied: grass/trunk/lib/temporal/SQL/stds_vector_register_trigger_template.sql (from rev 50164, grass/trunk/lib/temporal/stds_vector_register_trigger_template.sql)
--- grass/trunk/lib/temporal/SQL/stds_vector_register_trigger_template.sql	                        (rev 0)
+++ grass/trunk/lib/temporal/SQL/stds_vector_register_trigger_template.sql	2012-01-19 00:11:22 UTC (rev 50284)
@@ -0,0 +1,6 @@
+-- This SQL script is for now a placeholder, till the vector metadata
+-- concept is clear
\ No newline at end of file
Copied: grass/trunk/lib/temporal/SQL/str3ds_metadata_table.sql (from rev 50164, grass/trunk/lib/temporal/str3ds_metadata_table.sql)
--- grass/trunk/lib/temporal/SQL/str3ds_metadata_table.sql	                        (rev 0)
+++ grass/trunk/lib/temporal/SQL/str3ds_metadata_table.sql	2012-01-19 00:11:22 UTC (rev 50284)
@@ -0,0 +1,80 @@
+-- This SQL script generates the space time raster3d dataset metadata table,
+-- view and trigger
+CREATE TABLE  str3ds_metadata (
+  id VARCHAR NOT NULL,          -- Id of the space-time raster3d dataset, this is the primary foreign key
+  raster3d_register VARCHAR,    -- The id of the table in which the raster3d maps are registered for this dataset
+  number_of_maps INTEGER,       -- The number of registered raster3d maps
+  max_min DOUBLE PRECISION,     -- The minimal maximum of the registered raster3d maps
+  min_min DOUBLE PRECISION,     -- The minimal minimum of the registered raster3d maps
+  max_max DOUBLE PRECISION,     -- The maximal maximum of the registered raster3d maps
+  min_max DOUBLE PRECISION,     -- The maximal minimum of the registered raster3d maps
+  nsres_min DOUBLE PRECISION,   -- The lowest north-south resolution of the registered raster3d maps
+  nsres_max DOUBLE PRECISION,   -- The highest north-south resolution of the registered raster3d maps
+  ewres_min DOUBLE PRECISION,   -- The lowest east-west resolution of the registered raster3d maps
+  ewres_max DOUBLE PRECISION,   -- The highest east-west resolution of the registered raster3d maps
+  tbres_min DOUBLE PRECISION,   -- The lowest top-bottom resolution of the registered raster3d maps
+  tbres_max DOUBLE PRECISION,   -- The highest top-bottom resolution of the registered raster3d maps
+  title VARCHAR,                -- Title of the space-time raster3d dataset
+  description VARCHAR,          -- Detailed description of the space-time raster3d dataset
+  PRIMARY KEY (id),
+  FOREIGN KEY (id) REFERENCES  str3ds_base (id) ON DELETE CASCADE
+-- Create the views to access all cols for absolute or relative time
+CREATE VIEW str3ds_view_abs_time AS SELECT
+            A1.id, A1.name, A1.mapset, A1.temporal_type,
+            A1.semantic_type,
+            A1.creation_time,
+            A1.creator,
+	    A2.start_time, A2.end_time, A2.timezone, A2.granularity,
+	    A4.raster3d_register,
+	    A4.number_of_maps,
+            A4.nsres_min, A4.ewres_min,
+            A4.nsres_max, A4.ewres_max,
+            A4.tbres_min, A4.tbres_max,
+	    A4.min_min, A4.min_max,
+	    A4.max_min, A4.max_max,
+            A4.title, A4.description
+	    FROM str3ds_base A1, str3ds_absolute_time A2,
+            str3ds_spatial_extent A3, str3ds_metadata A4 WHERE A1.id = A2.id AND
+	    A1.id = A3.id AND A1.id = A4.id;
+CREATE VIEW str3ds_view_rel_time AS SELECT
+            A1.semantic_type,
+            A1.creation_time,
+            A1.creator,
+	    A2.start_time, A2.end_time, A2.granularity,
+	    FROM str3ds_base A1, str3ds_relative_time A2,
+--CREATE TRIGGER update_str3ds_metadata AFTER UPDATE ON str3ds_metadata
+--  BEGIN
+--    UPDATE str3ds_base SET modification_time = datetime("NOW") WHERE id = old.id;
+--    UPDATE str3ds_base SET revision = (revision + 1) WHERE id = old.id;
+--  END;
Copied: grass/trunk/lib/temporal/SQL/strds_metadata_table.sql (from rev 50164, grass/trunk/lib/temporal/strds_metadata_table.sql)
--- grass/trunk/lib/temporal/SQL/strds_metadata_table.sql	                        (rev 0)
+++ grass/trunk/lib/temporal/SQL/strds_metadata_table.sql	2012-01-19 00:11:22 UTC (rev 50284)
@@ -0,0 +1,76 @@
+-- This SQL script generates the space time raster dataset metadata table,
+CREATE TABLE  strds_metadata (
+  raster_register VARCHAR,      -- The id of the table in which the raster maps are registered for this dataset
+  number_of_maps INTEGER,       -- The number of registered raster maps
+  max_min DOUBLE PRECISION,     -- The minimal maximum of the registered raster maps
+  min_min DOUBLE PRECISION,     -- The minimal minimum of the registered raster maps
+  max_max DOUBLE PRECISION,     -- The maximal maximum of the registered raster maps
+  min_max DOUBLE PRECISION,     -- The maximal minimum of the registered raster maps
+  nsres_min DOUBLE PRECISION,   -- The lowest north-south resolution of the registered raster maps
+  nsres_max DOUBLE PRECISION,   -- The highest north-south resolution of the registered raster maps
+  ewres_min DOUBLE PRECISION,   -- The lowest east-west resolution of the registered raster maps
+  ewres_max DOUBLE PRECISION,   -- The highest east-west resolution of the registered raster maps
+  title VARCHAR,                -- Title of the space-time raster dataset
+  description VARCHAR,          -- Detailed description of the space-time raster dataset
+  PRIMARY KEY (id),
+  FOREIGN KEY (id) REFERENCES  strds_base (id) ON DELETE CASCADE
+CREATE VIEW strds_view_abs_time AS SELECT
+            A1.semantic_type,
+            A1.creation_time,
+            A1.creator,
+	    A4.raster_register,
+	    FROM strds_base A1, strds_absolute_time A2,
+            strds_spatial_extent A3, strds_metadata A4 WHERE A1.id = A2.id AND
+CREATE VIEW strds_view_rel_time AS SELECT
+            A1.semantic_type,
+            A1.creation_time,
+            A1.creator,
+	    FROM strds_base A1, strds_relative_time A2,
+--CREATE TRIGGER update_strds_metadata AFTER UPDATE ON strds_metadata
+--  BEGIN
+--    UPDATE strds_base SET modification_time = datetime("NOW") WHERE id = old.id;
+--    UPDATE strds_base SET revision = (revision + 1) WHERE id = old.id;
+--  END;
Copied: grass/trunk/lib/temporal/SQL/stvds_metadata_table.sql (from rev 50164, grass/trunk/lib/temporal/stvds_metadata_table.sql)
--- grass/trunk/lib/temporal/SQL/stvds_metadata_table.sql	                        (rev 0)
+++ grass/trunk/lib/temporal/SQL/stvds_metadata_table.sql	2012-01-19 00:11:22 UTC (rev 50284)
@@ -0,0 +1,61 @@
+-- This SQL script generates the space time vector dataset metadata table,
+CREATE TABLE  stvds_metadata (
+  id VARCHAR NOT NULL,                -- Name of the space-time vector dataset, this is the primary foreign key
+  vector_register VARCHAR,                    -- The id of the table in which the vector maps are registered for this dataset
+  number_of_maps INTEGER,          -- The number of registered vector maps
+  title VARCHAR,                              -- Title of the space-time vector dataset
+  description VARCHAR,                        -- Detailed description of the space-time vector dataset
+  PRIMARY KEY (id),
+  FOREIGN KEY (id) REFERENCES  stvds_base (id) ON DELETE CASCADE
+-- Create the views to access all columns for absolute or relative time
+CREATE VIEW stvds_view_abs_time AS SELECT
+            A1.semantic_type,
+            A1.creation_time,
+            A1.creator,
+            A2.granularity,
+	    A4.vector_register,
+	    FROM stvds_base A1, stvds_absolute_time A2,
+            stvds_spatial_extent A3, stvds_metadata A4 WHERE A1.id = A2.id AND
+CREATE VIEW stvds_view_rel_time AS SELECT
+            A1.semantic_type,
+            A1.creation_time,
+            A1.creator,
+	    FROM stvds_base A1, stvds_relative_time A2,
+--CREATE TRIGGER update_stvds_metadata AFTER UPDATE ON stvds_metadata
+--  BEGIN
+--    UPDATE stvds_base SET modification_time = datetime("NOW") WHERE id = old.id;
+--    UPDATE stvds_base SET revision = (revision + 1) WHERE id = old.id;
+--  END;
Copied: grass/trunk/lib/temporal/SQL/test.temporal.py (from rev 50164, grass/trunk/lib/temporal/test.temporal.py)
--- grass/trunk/lib/temporal/SQL/test.temporal.py	                        (rev 0)
+++ grass/trunk/lib/temporal/SQL/test.temporal.py	2012-01-19 00:11:22 UTC (rev 50284)
@@ -0,0 +1,836 @@
+import os
+from grass.script.tgis_core import *
+from grass.script.tgis_base import *
+from grass.script.tgis_temporal_extent import *
+from grass.script.tgis_spatial_extent import *
+from grass.script.tgis_metadata import *
+from grass.script.tgis_abstract_datasets import *
+from grass.script.tgis_space_time_datasets import *
+import grass.script as grass
+def test_dict_sql_serializer():
+    t = dict_sql_serializer()
+    t.test()
+def test_dataset_identifer():
+	for i in range(2):
+	    base = raster_base(ident="soil" + str(i) + "@PERMANENT", name="soil" + str(i), mapset="PERMANENT", creator="soeren", temporal_type="absolute", revision=1)
+	    base.insert()
+	    base.select()
+	    base.print_self()
+	    base.clear()
+	    base.set_creator("rene")
+	    base.update()
+	    base.select()
+	    base.print_self()
+	    base = raster3d_base(ident="soil" + str(i) + "@PERMANENT", name="soil" + str(i), mapset="PERMANENT", temporal_type="absolute", creator="soeren")
+	    base.insert()
+	    base.select()
+	    base.print_self()
+	    base.clear()
+	    base.update()
+	    base.select()
+	    base.print_self()
+	    base = vector_base(ident="soil" + str(i) + "@PERMANENT", name="soil" + str(i), mapset="PERMANENT", temporal_type="absolute", creator="soeren")
+	    base.insert()
+	    base.select()
+	    base.print_self()
+	    base.clear()
+	    base.update()
+	    base.select()
+	    base.print_self()
+	    base = strds_base(ident="soil" + str(i) + "@PERMANENT", name="soil" + str(i), mapset="PERMANENT", creator="soeren", semantic_type="event", temporal_type="absolute", revision=1)
+	    base.insert()
+	    base.select()
+	    base.print_self()
+	    base.clear()
+	    base.update()
+	    base.select()
+	    base.print_self()
+	    base = str3ds_base(ident="soil" + str(i) + "@PERMANENT", name="soil" + str(i), mapset="PERMANENT", temporal_type="absolute", semantic_type="event", creator="soeren")
+	    base.insert()
+	    base.select()
+	    base.print_self()
+	    base.clear()
+	    base.update()
+	    base.select()
+	    base.print_self()
+	    base = stvds_base(ident="soil" + str(i) + "@PERMANENT", name="soil" + str(i), mapset="PERMANENT", temporal_type="absolute", semantic_type="event", creator="soeren")
+	    base.insert()
+	    base.select()
+	    base.print_self()
+	    base.clear()
+	    base.update()
+	    base.select()
+	    base.print_self()
+def test_absolute_timestamp():
+	    base = raster_absolute_time(ident="soil" + str(i) + "@PERMANENT", start_time=datetime(2011,01,01), end_time=datetime(2011,07,01), timezone=1)
+	    base.insert()
+	    base.select()
+	    base.print_self()
+	    base.clear()
+	    base.set_start_time(datetime(2010,01,01))
+	    base.update()
+	    base.select()
+	    base.print_self()
+	    base = raster3d_absolute_time(ident="soil" + str(i) + "@PERMANENT", start_time=datetime(2011,01,01), end_time=datetime(2011,07,01), timezone=1)
+	    base.insert()
+	    base.select()
+	    base.print_self()
+	    base.clear()
+	    base.update()
+	    base.select()
+	    base.print_self()
+	    base = vector_absolute_time(ident="soil" + str(i) + "@PERMANENT", start_time=datetime(2011,01,01), end_time=datetime(2011,07,01), timezone=1)
+	    base.insert()
+	    base.select()
+	    base.print_self()
+	    base.clear()
+	    base.update()
+	    base.select()
+	    base.print_self()
+	    base = strds_absolute_time(ident="soil" + str(i) + "@PERMANENT", start_time=datetime(2011,01,01), end_time=datetime(2011,07,01), granularity="1 day", timezone=1)
+	    base.insert()
+	    base.select()
+	    base.print_self()
+	    base.clear()
+	    base.update()
+	    base.select()
+	    base.print_self()
+	    base = str3ds_absolute_time(ident="soil" + str(i) + "@PERMANENT", start_time=datetime(2011,01,01), end_time=datetime(2011,07,01), granularity="1 day", timezone=1)
+	    base.insert()
+	    base.select()
+	    base.print_self()
+	    base.clear()
+	    base.update()
+	    base.select()
+	    base.print_self()
+	    base = stvds_absolute_time(ident="soil" + str(i) + "@PERMANENT", start_time=datetime(2011,01,01), end_time=datetime(2011,07,01), granularity="1 day", timezone=1)
+	    base.insert()
+	    base.select()
+	    base.print_self()
+	    base.clear()
+	    base.update()
+	    base.select()
+	    base.print_self()
+def test_spatial_extent():
+	    base = raster_spatial_extent(ident="soil" + str(i) + "@PERMANENT", north=100 + i, south=10+i, east=50+i, west=20+i, top=i, bottom=0)
+	    base.insert()
+	    base.select()
+	    base.print_self()
+	    base.clear()
+	    base.set_north(120+i)
+	    base.update()
+	    base.select()
+	    base.print_self()
+	    base = raster3d_spatial_extent(ident="soil" + str(i) + "@PERMANENT", north=100 + i, south=10+i, east=50+i, west=20+i, top=i, bottom=0)
+	    base.insert()
+	    base.select()
+	    base.print_self()
+	    base.clear()
+	    base.update()
+	    base.select()
+	    base.print_self()
+	    base = vector_spatial_extent(ident="soil" + str(i) + "@PERMANENT", north=100 + i, south=10+i, east=50+i, west=20+i, top=i, bottom=0)
+	    base.insert()
+	    base.select()
+	    base.print_self()
+	    base.clear()
+	    base.update()
+	    base.select()
+	    base.print_self()
+	    base = strds_spatial_extent(ident="soil" + str(i) + "@PERMANENT", north=100 + i, south=10+i, east=50+i, west=20+i, top=i, bottom=0)
+	    base.insert()
+	    base.select()
+	    base.print_self()
+	    base.clear()
+	    base.update()
+	    base.select()
+	    base.print_self()
+	    base = str3ds_spatial_extent(ident="soil" + str(i) + "@PERMANENT", north=100 + i, south=10+i, east=50+i, west=20+i, top=i, bottom=0)
+	    base.insert()
+	    base.select()
+	    base.print_self()
+	    base.clear()
+	    base.update()
+	    base.select()
+	    base.print_self()
+	    base = stvds_spatial_extent(ident="soil" + str(i) + "@PERMANENT", north=100 + i, south=10+i, east=50+i, west=20+i, top=i, bottom=0)
+	    base.insert()
+	    base.select()
+	    base.print_self()
+	    base.clear()
+	    base.update()
+	    base.select()
+	    base.print_self()
+def test_relative_timestamp():
+	    base = raster_relative_time(ident="soil" + str(i) + "@PERMANENT", interval=i)
+	    base.insert()
+	    base.select()
+	    base.print_self()
+	    base.clear()
+	    base.set_interval(i+1)
+	    base.update()
+	    base.select()
+	    base.print_self()
+	    base = raster3d_relative_time(ident="soil" + str(i) + "@PERMANENT", interval=i)
+	    base.insert()
+	    base.select()
+	    base.print_self()
+	    base.clear()
+	    base.update()
+	    base.select()
+	    base.print_self()
+	    base = vector_relative_time(ident="soil" + str(i) + "@PERMANENT", interval=i)
+	    base.insert()
+	    base.select()
+	    base.print_self()
+	    base.clear()
+	    base.update()
+	    base.select()
+	    base.print_self()
+	    base = strds_relative_time(ident="soil" + str(i) + "@PERMANENT", interval=i, granularity=5.5)
+	    base.insert()
+	    base.select()
+	    base.print_self()
+	    base.clear()
+	    base.update()
+	    base.select()
+	    base.print_self()
+	    base = str3ds_relative_time(ident="soil" + str(i) + "@PERMANENT", interval=i, granularity=5.5)
+	    base.insert()
+	    base.select()
+	    base.print_self()
+	    base.clear()
+	    base.update()
+	    base.select()
+	    base.print_self()
+	    base = stvds_relative_time(ident="soil" + str(i) + "@PERMANENT", interval=i, granularity=5.5)
+	    base.insert()
+	    base.select()
+	    base.print_self()
+	    base.clear()
+	    base.update()
+	    base.select()
+	    base.print_self()
+def test_map_metadata():
+	    base = raster_metadata(ident="soil" + str(i) + "@PERMANENT", strds_register="PERMANENT_soil_strds_register", datatype="CELL", \
+			    cols=500, rows=400, number_of_cells=200000,nsres=1, ewres=1, min=0, max=33)
+	    base.insert()
+	    base.select()
+	    base.print_self()
+	    base.clear()
+	    base.set_datatype("FCELL")
+	    base.update()
+	    base.select()
+	    base.print_self()
+	    base = raster3d_metadata(ident="soil" + str(i) + "@PERMANENT", str3ds_register="PERMANENT_soil_str3ds_register", datatype="FCELL", \
+			    cols=500, rows=400, depths=20, number_of_cells=200000,nsres=1, ewres=1, tbres=10, min=0, max=33)
+	    base.insert()
+	    base.select()
+	    base.print_self()
+	    base.clear()
+	    base.set_datatype("DCELL")
+	    base.update()
+	    base.select()
+	    base.print_self()
+	    base = vector_metadata(ident="soil" + str(i) + "@PERMANENT", stvds_register="PERMANENT_soil_stvds_register")
+	    base.insert()
+	    base.select()
+	    base.print_self()
+	    base.clear()
+	    base.set_stvds_register("PERMANENT_soil_stvds_register")
+	    base.update()
+	    base.select()
+	    base.print_self()
+	    base = strds_metadata(ident="soil" + str(i) + "@PERMANENT", raster_register="PERMANENT_soil_raster_register", \
+                                   title="Test", description="Test description")
+	    base.insert()
+	    base.select()
+	    base.print_self()
+	    base.clear()
+	    base.set_title("More tests")
+	    base.update()
+	    base.select()
+	    base.print_self()
+	    base = str3ds_metadata(ident="soil" + str(i) + "@PERMANENT", raster3d_register="PERMANENT_soil_raster3d_register", \
+	    base.insert()
+	    base.select()
+	    base.print_self()
+	    base.clear()
+	    base.update()
+	    base.select()
+	    base.print_self()
+	    base = stvds_metadata(ident="soil" + str(i) + "@PERMANENT", vector_register="PERMANENT_soil_vector_register", \
+	    base.insert()
+	    base.select()
+	    base.print_self()
+	    base.clear()
+	    base.update()
+	    base.select()
+	    base.print_self()
+def test_base_absolute_time_extent_metadata():
+	for i in range(10):
+	    base = vector_base(ident="water" + str(i) + "@PERMANENT", name="water" + str(i), mapset="PERMANENT", creator="soeren")
+	    base.insert()
+	    base = raster_base(ident="water" + str(i) + "@PERMANENT", name="water" + str(i), mapset="PERMANENT", creator="soeren")
+	    base.insert()
+	    base = raster3d_base(ident="water" + str(i) + "@PERMANENT", name="water" + str(i), mapset="PERMANENT", creator="soeren")
+	    base.insert()
+	    base = vector_base(ident="water" + str(i) + "@PERMANENT")
+	    base.update()
+	    base = raster_base(ident="water" + str(i) + "@PERMANENT")
+	    base.update()
+	    base = raster3d_base(ident="water" + str(i) + "@PERMANENT")
+	    base.update()
+	    base = vector_absolute_time(ident="water" + str(i) + "@PERMANENT", start_time=datetime.now(), end_time=datetime.now(), timezone=1)
+	    base.insert()
+	    base = raster_absolute_time(ident="water" + str(i) + "@PERMANENT", start_time=datetime.now(), end_time=datetime.now(), timezone=1)
+	    base.insert()
+	    base = raster3d_absolute_time(ident="water" + str(i) + "@PERMANENT", start_time=datetime.now(), end_time=datetime.now(), timezone=1)
+	    base.insert()
+	    base = vector_absolute_time(ident="water" + str(i) + "@PERMANENT")
+	    base.set_start_time(datetime(2010, 6, 1))
+	    base.update()
+	    base = raster_absolute_time(ident="water" + str(i) + "@PERMANENT")
+	    base.update()
+	    base = raster3d_absolute_time(ident="water" + str(i) + "@PERMANENT")
+	    base.update()
+	    base = vector_spatial_extent(ident="water" + str(i) + "@PERMANENT", north=100 + i, south=10+i, east=50+i, west=20+i, top=i, bottom=0)
+	    base.insert()
+	    base = raster_spatial_extent(ident="water" + str(i) + "@PERMANENT", north=100 + i, south=10+i, east=50+i, west=20+i, top=0, bottom=0)
+	    base.insert()
+	    base = raster3d_spatial_extent(ident="water" + str(i) + "@PERMANENT", north=100 + i, south=10+i, east=50+i, west=20+i, top=i, bottom=0)
+	    base.insert()
+	    base = vector_spatial_extent(ident="water" + str(i) + "@PERMANENT")
+	    base.set_north(120 + i)
+	    base.set_south(20 + i)
+	    base.update()
+	    base = raster_spatial_extent(ident="water" + str(i) + "@PERMANENT")
+	    base.update()
+	    base = raster3d_spatial_extent(ident="water" + str(i) + "@PERMANENT")
+	    base.update()
+	    base = vector_metadata(ident="water" + str(i) + "@PERMANENT", stvds_register="PERMANENT_water_stvds_register")
+	    base.insert()
+	    base = raster_metadata(ident="water" + str(i) + "@PERMANENT", strds_register="PERMANENT_water_strds-register", datatype="CELL", \
+	    base.insert()
+	    base = raster3d_metadata(ident="water" + str(i) + "@PERMANENT", str3ds_register="PERMANENT_water_str3ds-register", datatype="FCELL", \
+	    base.insert()
+	    base = vector_metadata(ident="water" + str(i) + "@PERMANENT")
+	    base.set_stvds_register("PERMANENT_water_stvds_register")
+	    base.update()
+	    base = raster_metadata(ident="water" + str(i) + "@PERMANENT")
+	    base.update()
+	    base = raster3d_metadata(ident="water" + str(i) + "@PERMANENT")
+	    base.update()
+	    base.select()
+	    base.print_self()
+	    base.select()
+	    base.print_self()
+	    base.select()
+	    base.print_self()
+	print "Create a raster object"
+	rds = raster_dataset("water0 at PERMANENT")
+	rds.select()
+	rds.print_self()
+	print rds.temporal_relation(rds)
+def test_absolut_time_temporal_relations():
+    A = raster_absolute_time(ident="test1 at PERMANENT", start_time=datetime(year=2000, month=1, day=1), \
+		                                        end_time=datetime(year=2001, month=1, day=1), timezone=1)
+    B = raster_absolute_time(ident="test2 at PERMANENT", start_time=datetime(year=2001, month=1, day=1), \
+		                                        end_time=datetime(year=2002, month=1, day=1), timezone=1)
+    print "Precedes: ", A.temporal_relation(B)
+    print "Follows:  ", B.temporal_relation(A)
+    B = raster_absolute_time(ident="test2 at PERMANENT", start_time=datetime(year=2001, month=1, day=2), \
+    print "Before:   ", A.temporal_relation(B)
+    print "After:    ", B.temporal_relation(A)
+    B = raster_absolute_time(ident="test2 at PERMANENT", start_time=datetime(year=2000, month=1, day=1), \
+    print "Starts:   ", A.temporal_relation(B)
+    print "Started:  ", B.temporal_relation(A)
+    B = raster_absolute_time(ident="test2 at PERMANENT", start_time=datetime(year=2000, month=1, day=2), \
+    print "Finished: ", A.temporal_relation(B)
+    print "Finishes: ", B.temporal_relation(A)
+    B = raster_absolute_time(ident="test2 at PERMANENT", start_time=datetime(year=2000, month=3, day=1), \
+		                                        end_time=datetime(year=2000, month=9, day=1), timezone=1)
+    print "Contains: ", A.temporal_relation(B)
+    print "During:   ", B.temporal_relation(A)
+		                                        end_time=datetime(year=2000, month=6, day=1), timezone=1)
+    print "Overlap:   ", A.temporal_relation(B)
+    print "Overlapped:", B.temporal_relation(A)
+		                                        end_time=datetime(year=2000, month=1, day=1), timezone=1)
+    print "Equivalent:", A.temporal_relation(B)
+    print "Equivalent:", B.temporal_relation(A)
+def test_raster_dataset():
+    # Create a test map
+    grass.raster.mapcalc("test = sin(x()) + cos(y())", overwrite = True)
+    name = "test"
+    mapset =  grass.gisenv()["MAPSET"]
+    # We need to specify the name and the mapset as identifier
+    rds = raster_dataset(name + "@" + mapset)
+    # Load data from the raster map in the mapset
+    rds.load()
+    print "Is in db: ", rds.is_in_db()
+    if rds.is_in_db():
+        # Remove the entry if it is in the db
+        rds.delete()
+    # Set the absolute valid time
+    rds.set_absolute_time(start_time= datetime(year=2000, month=1, day=1), \
+                            end_time= datetime(year=2010, month=1, day=1))
+    # Insert the map data into the SQL database
+    rds.insert()
+    # Print self info
+    rds.print_self()
+    # The temporal relation must be equal
+def test_raster3d_dataset():
+    grass.raster3d.mapcalc3d("test = sin(x()) + cos(y()) + sin(z())", overwrite = True)
+    name = "test"
+    r3ds = raster3d_dataset(name + "@" + mapset)
+    r3ds.load()
+    print "Is in db: ", r3ds.is_in_db()
+    if r3ds.is_in_db():
+        r3ds.delete()
+    r3ds.set_absolute_time(start_time= datetime(year=2000, month=1, day=1), \
+    r3ds.insert()
+    # Print self info
+    r3ds.print_self()
+    print r3ds.temporal_relation(r3ds)
+def test_vector_dataset():
+    grass.run_command("v.random", output="test", n=20, column="height", zmin=0, \
+                      zmax=100, flags="z", overwrite = True)
+    name = "test"
+    print "Create a vector object"
+    vds = vector_dataset(name + "@" + mapset)
+    vds.load()
+    print "Is in db: ", vds.is_in_db()
+    if vds.is_in_db():
+        vds.delete()
+    vds.set_absolute_time(start_time= datetime(year=2000, month=1, day=1), \
+    vds.insert()
+    # Print self info
+    vds.print_self()
+    print vds.temporal_relation(vds)
+def test_strds_dataset():
+    name = "strds_test_1"
+    print "Create a strds object"
+    strds = space_time_raster_dataset(ident = name + "@" + mapset)
+    # Check if in db
+    print "Is strds in db: ", strds.is_in_db()
+    # Create a new entry if not in db
+    if strds.is_in_db() == False:
+        strds.set_initial_values(temporal_type = "absolute", granularity="1 day",\
+        semantic_type="event", title="This is a test space time raster dataset", description="A space time raster dataset for testing")
+        strds.insert()
+    # Reread the data from the db
+    strds.select()
+    # Print self info
+    #strds.print_self()
+    # Create a test maps
+    for i in range(11):
+        i = i + 1
+        grass.raster.mapcalc("test" + str(i) + " = sin(x()) + cos(y())", overwrite = True)
+        name = "test" + str(i)
+        ident = name + "@" + mapset
+        rds = raster_dataset(ident)
+        rds.load()
+        print "Is raster in db: ", rds.is_in_db()
+            rds.select()
+            rds.print_self()
+            rds.delete()
+            rds.reset(ident)
+            rds.load()
+        rds.set_absolute_time(start_time= datetime(year=2000, month=i, day=1), \
+                                end_time= datetime(year=2000, month=i + 1, day=1))
+        rds.insert()
+        # Register the map in the space time raster dataset
+        strds.register_map(rds)
+        # Print self info
+        #rds.print_self()
+    strds.update_from_registered_maps()
+    strds.select()
+    # Print self info
+    strds.print_self()
+    # Delete the dataset
+    strds.delete()
+def test_str3ds_dataset():
+    name = "str3ds_test_1"
+    print "Create a str3ds object"
+    str3ds = space_time_raster3d_dataset(ident = name + "@" + mapset)
+    # Check if in db
+    print "Is str3ds in db: ", str3ds.is_in_db()
+    if str3ds.is_in_db() == False:
+        str3ds.set_initial_values(temporal_type = "absolute", granularity="1 day",\
+        semantic_type="event", title="This is a test space time raster3d dataset", description="A space time raster3d dataset for testing")
+        str3ds.insert()
+    str3ds.select()
+    # Print self info
+    #str3ds.print_self()
+        i = i + 1
+        grass.raster3d.mapcalc3d("test" + str(i) + " = sin(x()) + cos(y()) + z()", overwrite = True)
+        print "Create a raster3d object"
+        r3ds = raster3d_dataset(ident)
+        # Load data from the raster3d map in the mapset
+        r3ds.load()
+        print "Is raster3d in db: ", r3ds.is_in_db()
+            r3ds.select()
+            r3ds.print_self()
+            r3ds.delete()
+            r3ds.reset(ident)
+            r3ds.load()
+        r3ds.set_absolute_time(start_time= datetime(year=2000, month=i, day=1), \
+        r3ds.insert()
+        # Register the map in the space time raster3d dataset
+        str3ds.register_map(r3ds)
+        # Print self info
+        #r3ds.print_self()
+    str3ds.update_from_registered_maps()
+    str3ds.select()
+    # Print self info
+    str3ds.print_self()
+    str3ds.delete()
+def test_stvds_dataset():
+    name = "stvds_test_1"
+    print "Create a stvds object"
+    stvds = space_time_vector_dataset(ident = name + "@" + mapset)
+    # Check if in db
+    print "Is stvds in db: ", stvds.is_in_db()
+    if stvds.is_in_db() == False:
+        stvds.set_initial_values(temporal_type = "absolute", granularity="1 day",\
+        semantic_type="event", title="This is a test space time vector dataset", description="A space time vector dataset for testing")
+        stvds.insert()
+    stvds.select()
+    # Print self info
+    #stvds.print_self()
+        i = i + 1
+        grass.run_command("v.random", output=name, n=100, zmin=0, zmax=100, column="height" ,flags="z" , overwrite = True)
+        vds = vector_dataset(ident)
+        vds.load()
+        print "Is vector in db: ", vds.is_in_db()
+            vds.select()
+            vds.print_self()
+            vds.delete()
+            vds.reset(ident)
+            vds.load()
+        vds.set_absolute_time(start_time= datetime(year=2000, month=i, day=1), \
+        vds.insert()
+        stvds.register_map(vds)
+        # Print self info
+        #vds.print_self()
+    stvds.update_from_registered_maps()
+    stvds.select()
+    # Print self info
+    stvds.print_self()
+    stvds.delete()
+test_dict_sql_serializer()
+create_temporal_database()
+#test_dataset_identifer()
+#test_absolute_timestamp()
+#test_relative_timestamp()
+#test_spatial_extent()
+#test_map_metadata()
+#test_base_absolute_time_extent_metadata()
+#test_absolut_time_temporal_relations()
+test_raster_dataset()
+test_raster3d_dataset()
+test_vector_dataset()
+test_strds_dataset()
+test_str3ds_dataset()
+test_stvds_dataset()
+test_increment_datetime_by_string()
Copied: grass/trunk/lib/temporal/SQL/update_stds_spatial_temporal_extent_template.sql (from rev 50164, grass/trunk/lib/temporal/update_stds_spatial_temporal_extent_template.sql)
--- grass/trunk/lib/temporal/SQL/update_stds_spatial_temporal_extent_template.sql	                        (rev 0)
+++ grass/trunk/lib/temporal/SQL/update_stds_spatial_temporal_extent_template.sql	2012-01-19 00:11:22 UTC (rev 50284)
@@ -0,0 +1,66 @@
+-- This SQL script is to update the spatial and temporal extent as well as
+-- the modifcation time and revision of a space time dataset. This script
+-- should be called when maps inserted or deleted in a space time dataset.
+-- Number of registered maps
+UPDATE STDS_metadata SET number_of_maps =
+       (SELECT count(id) FROM SPACETIME_NAME_GRASS_MAP_register)
+       WHERE id = 'SPACETIME_ID';
+-- Update the temporal extent
+UPDATE STDS_absolute_time SET start_time =
+       (SELECT min(start_time) FROM GRASS_MAP_absolute_time WHERE GRASS_MAP_absolute_time.id IN
+    		(SELECT id FROM SPACETIME_NAME_GRASS_MAP_register)
+       ) WHERE id = 'SPACETIME_ID';
+UPDATE STDS_absolute_time SET end_time =
+       (SELECT max(end_time) FROM GRASS_MAP_absolute_time WHERE GRASS_MAP_absolute_time.id IN
+UPDATE STDS_relative_time SET start_time =
+       (SELECT min(start_time) FROM GRASS_MAP_relative_time WHERE GRASS_MAP_relative_time.id IN
+UPDATE STDS_relative_time SET end_time =
+       (SELECT max(end_time) FROM GRASS_MAP_relative_time WHERE GRASS_MAP_relative_time.id IN
+-- Update the spatial extent
+UPDATE STDS_spatial_extent SET north =
+       (SELECT max(north) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
+UPDATE STDS_spatial_extent SET south =
+       (SELECT min(south) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
+UPDATE STDS_spatial_extent SET east =
+       (SELECT max(east) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
+UPDATE STDS_spatial_extent SET west =
+       (SELECT min(west) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
+UPDATE STDS_spatial_extent SET top =
+       (SELECT max(top) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
+UPDATE STDS_spatial_extent SET bottom =
+       (SELECT min(bottom) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
+UPDATE STDS_spatial_extent SET proj =
+       (SELECT min(proj) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
Copied: grass/trunk/lib/temporal/SQL/update_str3ds_metadata_template.sql (from rev 50164, grass/trunk/lib/temporal/update_str3ds_metadata_template.sql)
--- grass/trunk/lib/temporal/SQL/update_str3ds_metadata_template.sql	                        (rev 0)
+++ grass/trunk/lib/temporal/SQL/update_str3ds_metadata_template.sql	2012-01-19 00:11:22 UTC (rev 50284)
@@ -0,0 +1,51 @@
+-- This SQL script is to update a space-time raster3d dataset metadata
+-- Update the min and max values
+UPDATE str3ds_metadata SET min_min =
+       (SELECT min(min) FROM raster3d_metadata WHERE raster3d_metadata.id IN
+    		(SELECT id FROM SPACETIME_NAME_raster3d_register)
+UPDATE str3ds_metadata SET min_max =
+       (SELECT max(min) FROM raster3d_metadata WHERE raster3d_metadata.id IN
+UPDATE str3ds_metadata SET max_min =
+       (SELECT min(max) FROM raster3d_metadata WHERE raster3d_metadata.id IN
+UPDATE str3ds_metadata SET max_max =
+       (SELECT max(max) FROM raster3d_metadata WHERE raster3d_metadata.id IN
+-- Update the resolution
+UPDATE str3ds_metadata SET nsres_min =
+       (SELECT min(nsres) FROM raster3d_metadata WHERE raster3d_metadata.id IN
+UPDATE str3ds_metadata SET nsres_max =
+       (SELECT max(nsres) FROM raster3d_metadata WHERE raster3d_metadata.id IN
+UPDATE str3ds_metadata SET ewres_min =
+       (SELECT min(ewres) FROM raster3d_metadata WHERE raster3d_metadata.id IN
+UPDATE str3ds_metadata SET ewres_max =
+       (SELECT max(ewres) FROM raster3d_metadata WHERE raster3d_metadata.id IN
+UPDATE str3ds_metadata SET tbres_min =
+       (SELECT min(tbres) FROM raster3d_metadata WHERE raster3d_metadata.id IN
+UPDATE str3ds_metadata SET tbres_max =
+       (SELECT max(tbres) FROM raster3d_metadata WHERE raster3d_metadata.id IN
Copied: grass/trunk/lib/temporal/SQL/update_strds_metadata_template.sql (from rev 50164, grass/trunk/lib/temporal/update_strds_metadata_template.sql)
--- grass/trunk/lib/temporal/SQL/update_strds_metadata_template.sql	                        (rev 0)
+++ grass/trunk/lib/temporal/SQL/update_strds_metadata_template.sql	2012-01-19 00:11:22 UTC (rev 50284)
@@ -0,0 +1,43 @@
+-- This SQL is to update a space-time raster dataset metadata
+UPDATE strds_metadata SET min_min =
+       (SELECT min(min) FROM raster_metadata WHERE raster_metadata.id IN
+    		(SELECT id FROM SPACETIME_NAME_raster_register)
+UPDATE strds_metadata SET min_max =
+       (SELECT max(min) FROM raster_metadata WHERE raster_metadata.id IN
+UPDATE strds_metadata SET max_min =
+       (SELECT min(max) FROM raster_metadata WHERE raster_metadata.id IN
+UPDATE strds_metadata SET max_max =
+       (SELECT max(max) FROM raster_metadata WHERE raster_metadata.id IN
+UPDATE strds_metadata SET nsres_min =
+       (SELECT min(nsres) FROM raster_metadata WHERE raster_metadata.id IN
+UPDATE strds_metadata SET nsres_max =
+       (SELECT max(nsres) FROM raster_metadata WHERE raster_metadata.id IN
+UPDATE strds_metadata SET ewres_min =
+       (SELECT min(ewres) FROM raster_metadata WHERE raster_metadata.id IN
+UPDATE strds_metadata SET ewres_max =
+       (SELECT max(ewres) FROM raster_metadata WHERE raster_metadata.id IN
Copied: grass/trunk/lib/temporal/SQL/update_stvds_metadata_template.sql (from rev 50164, grass/trunk/lib/temporal/update_stvds_metadata_template.sql)
--- grass/trunk/lib/temporal/SQL/update_stvds_metadata_template.sql	                        (rev 0)
+++ grass/trunk/lib/temporal/SQL/update_stvds_metadata_template.sql	2012-01-19 00:11:22 UTC (rev 50284)
@@ -0,0 +1,6 @@
Copied: grass/trunk/lib/temporal/SQL/vector_metadata_table.sql (from rev 50164, grass/trunk/lib/temporal/vector_metadata_table.sql)
--- grass/trunk/lib/temporal/SQL/vector_metadata_table.sql	                        (rev 0)
+++ grass/trunk/lib/temporal/SQL/vector_metadata_table.sql	2012-01-19 00:11:22 UTC (rev 50284)
@@ -0,0 +1,55 @@
+-- This SQL script generates the vector table to store
+-- metadata for SQL queries and temporal GIS support.
+CREATE TABLE  vector_metadata (
+  stvds_register VARCHAR, -- The name of the table storing all space-time vector datasets in which this map is registered
+  PRIMARY KEY (id),
+  FOREIGN KEY (id) REFERENCES  vector_base (id) ON DELETE CASCADE
+-- Create the views to access all columns for the absolute and relative time
+CREATE VIEW vector_view_abs_time AS SELECT
+            A1.id, A1.mapset,
+            A1.creation_time,
+            A1.creator,
+	    A4.stvds_register
+	    FROM vector_base A1, vector_absolute_time A2,
+            vector_spatial_extent A3, vector_metadata A4
+CREATE VIEW vector_view_rel_time AS SELECT
+            A1.id, A1.mapset,
+            A1.creation_time,
+            A1.creator,
+	    A4.stvds_register
+	    FROM vector_base A1, vector_relative_time A2,
+--CREATE TRIGGER update_vector_metadata AFTER UPDATE ON vector_metadata
+--  BEGIN
+--    UPDATE vector_base SET modification_time = datetime("NOW") WHERE id = old.id;
+--    UPDATE vector_base SET revision = (revision + 1) WHERE id = old.id;
+--  END;
Deleted: grass/trunk/lib/temporal/map_stds_register_table_template.sql
--- grass/trunk/lib/temporal/map_stds_register_table_template.sql	2012-01-18 22:33:23 UTC (rev 50283)
+++ grass/trunk/lib/temporal/map_stds_register_table_template.sql	2012-01-19 00:11:22 UTC (rev 50284)
@@ -1,38 +0,0 @@
--- This SQL script generates the table listing all STDS in
--- which the GRASS_MAP map is registered
--- This table is map specific and created for each GRASS_MAP map which is registered
--- in a STDS. TABLE_NAME is a placeholder for the table name which must be unique.
--- A uuid is used as unique identifier across mapsets.
--- Author: Soeren Gebbert soerengebbert <at> googlemail <dot> com
---PRAGMA foreign_keys = ON;
--- TABLE_NAME is a placeholder for specific table name (SQL compliant)
--- MAP_ID is a placeholder for specific map id: name at mapset
--- GRASS_MAP is a placeholder for specific map type: raster, raster3d or vector
--- STDS is a placeholder for specific space-time dataset type: strds, str3ds, stvds
--- This table stores the names of the space-time datasets in which this map is registered
-CREATE TABLE  TABLE_NAME_STDS_register (
-  id VARCHAR NOT NULL, -- This column is a primary foreign key storing the STDS names
-  PRIMARY KEY (id),
-  FOREIGN KEY (id) REFERENCES  STDS_base (id) ON DELETE CASCADE
---CREATE TRIGGER TABLE_NAME_STDS_register_insert AFTER INSERT ON TABLE_NAME_STDS_register
---  BEGIN
---    UPDATE GRASS_MAP_base SET modification_time = datetime("NOW") WHERE GRASS_MAP_base.id = 'MAP_ID';
---    UPDATE GRASS_MAP_base SET revision = (revision + 1) WHERE GRASS_MAP_base.id = 'MAP_ID';
---  END;
---CREATE TRIGGER TABLE_NAME_STDS_register_delete AFTER DELETE ON TABLE_NAME_STDS_register
---  BEGIN
---  END;
Deleted: grass/trunk/lib/temporal/map_tables_template.sql
--- grass/trunk/lib/temporal/map_tables_template.sql	2012-01-18 22:33:23 UTC (rev 50283)
+++ grass/trunk/lib/temporal/map_tables_template.sql	2012-01-19 00:11:22 UTC (rev 50284)
@@ -1,83 +0,0 @@
--- This SQL script generates the grass map tables to store time stamps, revision
--- and spatial extent for SQL queries and temporal GIS support.
--- Additionally several triggers are created for convenient functions
--- The grass map metadata is map specific (raster, raster3d and vector maps are
--- supported)
--- The placeholder GRASS_MAP will be replaced by raster, raster3d and vector
-CREATE TABLE  GRASS_MAP_base (
-  id VARCHAR NOT NULL,                  -- The id (PK) is the unique identifier for all tables, it is based on name and mapset (name at mapset) and is used as primary key
-  name VARCHAR NOT NULL,                -- name of the grass map
-  mapset VARCHAR NOT NULL,              -- mapset of the grass map
-  creator VARCHAR NOT NULL,
-  temporal_type VARCHAR,                -- The temporal type of the grass map "absolute" or "relative" or NULL in case no time stamp is available
-  creation_time TIMESTAMP NOT NULL,      -- The time of creation of the grass map
--- Uncommented due to performance issues
---  modification_time TIMESTAMP NOT NULL,  -- The time of the last modification of the grass map
---  revision SMALLINT NOT NULL,           -- The revision number
-  PRIMARY KEY (id)
--- Relative valid time interval with start and end time
-CREATE TABLE  GRASS_MAP_relative_time (
-  id VARCHAR NOT NULL,          -- The id (PFK) is the unique identifier for all tables, it is based on name and mapset (name at mapset) and is used as primary foreign key
-  start_time DOUBLE PRECISION,  -- The relative valid start time in [days]
-  end_time DOUBLE PRECISION,    -- The relative valid end time in [days]
-  PRIMARY KEY (id),
-  FOREIGN KEY (id) REFERENCES  GRASS_MAP_base (id) ON DELETE CASCADE
-CREATE TABLE  GRASS_MAP_absolute_time (
-  start_time TIMESTAMP,  --  Start of the valid time, can be NULL if no time information is available
-  end_time TIMESTAMP,    --  End of the valid time, can be NULL if no time information is available or valid time is a single point in time
-  timezone SMALLINT,     -- The timezone of the valid time
-  PRIMARY KEY (id),
--- The spatial extent of a raster map
-CREATE TABLE  GRASS_MAP_spatial_extent (
-  id VARCHAR NOT NULL,                  -- The id (PFK) is the unique identifier for all tables, it is based on name and mapset (name at mapset) and is used as primary foreigen key
-  -- below is the spatial extent of the map
-  north DOUBLE PRECISION NOT NULL,
-  south DOUBLE PRECISION NOT NULL,
-  east DOUBLE PRECISION NOT NULL,
-  west DOUBLE PRECISION NOT NULL,
-  top DOUBLE PRECISION NOT NULL,
-  bottom DOUBLE PRECISION NOT NULL,
-  proj VARCHAR,
-  PRIMARY KEY (id),
--- Create a trigger to update the modification time and revision number in case the metadata or timestanps have been updated
---CREATE TRIGGER update_GRASS_MAP_absolute_time AFTER UPDATE ON GRASS_MAP_absolute_time
---  BEGIN
---    UPDATE GRASS_MAP_base SET modification_time = datetime("NOW") WHERE id = old.id;
---    UPDATE GRASS_MAP_base SET revision = (revision + 1) WHERE id = old.id;
--- END;
---CREATE TRIGGER update_GRASS_MAP_relative_time AFTER UPDATE ON GRASS_MAP_relative_time
---  BEGIN
---  END;
---CREATE TRIGGER update_GRASS_MAP_spatial_extent AFTER UPDATE ON GRASS_MAP_spatial_extent
---  BEGIN
---  END;
Deleted: grass/trunk/lib/temporal/raster3d_metadata_table.sql
--- grass/trunk/lib/temporal/raster3d_metadata_table.sql	2012-01-18 22:33:23 UTC (rev 50283)
+++ grass/trunk/lib/temporal/raster3d_metadata_table.sql	2012-01-19 00:11:22 UTC (rev 50284)
@@ -1,74 +0,0 @@
--- This SQL script generates the raster3d metadata table to store
--- and metadata for SQL queries and temporal GIS support. Additionally two views
--- are created to access all map specific tables
--- The metadata table reflects most of the raster3d metadata available in grass
-CREATE TABLE  raster3d_metadata (
-  str3ds_register VARCHAR, -- The name of the table storing all space-time raster3d datasets in which this map is registered
-  datatype VARCHAR NOT NULL,
-  cols INTEGER NOT NULL,
-  rows INTEGER NOT NULL,
-  depths INTEGER NOT NULL,
-  number_of_cells INTEGER NOT NULL,
-  nsres DOUBLE PRECISION NOT NULL,
-  ewres DOUBLE PRECISION NOT NULL,
-  tbres DOUBLE PRECISION NOT NULL,
-  min DOUBLE PRECISION,
-  max DOUBLE PRECISION,
-  PRIMARY KEY (id),
-  FOREIGN KEY (id) REFERENCES  raster3d_base (id) ON DELETE CASCADE
--- Create the views to access all cols for the absolute and relative time
-CREATE VIEW raster3d_view_abs_time AS SELECT
-            A1.id, A1.mapset,
-            A1.name, A1.temporal_type,
-            A1.creation_time,
---            A1.modification_time, A1.revision,
-            A1.creator,
-	    A2.start_time, A2.end_time, A2.timezone,
-            A3.north, A3.south, A3.east, A3.west, A3.proj,
-	    A4.datatype, A4.cols, A4.rows, A4.depths,
-            A4.nsres, A4.ewres, A4.tbres,
-            A4.min, A4.max,
-	    A4.str3ds_register,
-            A4.number_of_cells
-	    FROM raster3d_base A1, raster3d_absolute_time A2,
-            raster3d_spatial_extent A3, raster3d_metadata A4
-	    WHERE A1.id = A2.id AND A1.id = A3.id AND A1.id = A4.id;
-CREATE VIEW raster3d_view_rel_time AS SELECT
-            A1.id, A1.mapset,
-            A1.creation_time,
-            A1.creator,
-            A4.min, A4.max,
-	    FROM raster3d_base A1, raster3d_relative_time A2,
--- Create a trigger to update the modification time and revision number in case the metadata have been updated
---CREATE TRIGGER update_raster3d_metadata AFTER UPDATE ON raster3d_metadata
---  BEGIN
---    UPDATE raster3d_base SET modification_time = datetime("NOW") WHERE id = old.id;
---    UPDATE raster3d_base SET revision = (revision + 1) WHERE id = old.id;
---  END;
Deleted: grass/trunk/lib/temporal/raster_metadata_table.sql
--- grass/trunk/lib/temporal/raster_metadata_table.sql	2012-01-18 22:33:23 UTC (rev 50283)
+++ grass/trunk/lib/temporal/raster_metadata_table.sql	2012-01-19 00:11:22 UTC (rev 50284)
@@ -1,71 +0,0 @@
--- This SQL script generates the raster metadata table to store
--- The metadata table reflects most of the raster metadata available in grass
-CREATE TABLE  raster_metadata (
-  strds_register VARCHAR,            -- The name of the table storing all space-time raster datasets in which this map is registered
-  PRIMARY KEY (id),
-  FOREIGN KEY (id) REFERENCES  raster_base (id) ON DELETE CASCADE
-CREATE VIEW raster_view_abs_time AS SELECT
-            A1.id, A1.mapset,
-            A1.creation_time,
-            A1.creator,
-            A4.nsres, A4.ewres, A4.min, A4.max,
-	    A4.strds_register,
-	    FROM raster_base A1, raster_absolute_time A2,
-            raster_spatial_extent A3, raster_metadata A4
-CREATE VIEW raster_view_rel_time AS SELECT
-            A1.id, A1.mapset,
-            A1.creation_time,
-            A1.creator,
-	    FROM raster_base A1, raster_relative_time A2,
---CREATE TRIGGER update_raster_metadata AFTER UPDATE ON raster_metadata
---  BEGIN
---    UPDATE raster_base SET modification_time = datetime("NOW") WHERE id = old.id;
---    UPDATE raster_base SET revision = (revision + 1) WHERE id = old.id;
---  END;
Deleted: grass/trunk/lib/temporal/sqlite3_delete_trigger.sql
--- grass/trunk/lib/temporal/sqlite3_delete_trigger.sql	2012-01-18 22:33:23 UTC (rev 50283)
+++ grass/trunk/lib/temporal/sqlite3_delete_trigger.sql	2012-01-19 00:11:22 UTC (rev 50284)
@@ -1,51 +0,0 @@
--- Create trigger for automated deletion of dependent rows, this should normally be done using foreign keys
-CREATE TRIGGER delete_strds_base AFTER DELETE ON strds_base
-  BEGIN
-    DELETE FROM strds_absolute_time WHERE id = old.id;
-    DELETE FROM strds_relative_time WHERE id = old.id;
-    DELETE FROM strds_spatial_extent WHERE id = old.id;
-    DELETE FROM strds_metadata WHERE id = old.id;
-  END;
-CREATE TRIGGER delete_raster_base AFTER DELETE ON raster_base
-  BEGIN
-    DELETE FROM raster_absolute_time WHERE id = old.id;
-    DELETE FROM raster_relative_time WHERE id = old.id;
-    DELETE FROM raster_spatial_extent WHERE id = old.id;
-    DELETE FROM raster_metadata WHERE id = old.id;
-  END;
-CREATE TRIGGER delete_str3ds_base AFTER DELETE ON str3ds_base
-  BEGIN
-    DELETE FROM str3ds_absolute_time WHERE id = old.id;
-    DELETE FROM str3ds_relative_time WHERE id = old.id;
-    DELETE FROM str3ds_spatial_extent WHERE id = old.id;
-    DELETE FROM str3ds_metadata WHERE id = old.id;
-  END;
-CREATE TRIGGER delete_raster3d_base AFTER DELETE ON raster3d_base
-  BEGIN
-    DELETE FROM raster3d_absolute_time WHERE id = old.id;
-    DELETE FROM raster3d_relative_time WHERE id = old.id;
-    DELETE FROM raster3d_spatial_extent WHERE id = old.id;
-    DELETE FROM raster3d_metadata WHERE id = old.id;
-  END;
-CREATE TRIGGER delete_stvds_base AFTER DELETE ON stvds_base
-  BEGIN
-    DELETE FROM stvds_absolute_time WHERE id = old.id;
-    DELETE FROM stvds_relative_time WHERE id = old.id;
-    DELETE FROM stvds_spatial_extent WHERE id = old.id;
-    DELETE FROM stvds_metadata WHERE id = old.id;
-  END;
-CREATE TRIGGER delete_vector_base AFTER DELETE ON vector_base
-  BEGIN
-    DELETE FROM vector_absolute_time WHERE id = old.id;
-    DELETE FROM vector_relative_time WHERE id = old.id;
-    DELETE FROM vector_spatial_extent WHERE id = old.id;
-    DELETE FROM vector_metadata WHERE id = old.id;
-  END;
Added: grass/trunk/lib/temporal/src/Makefile
--- grass/trunk/lib/temporal/src/Makefile	                        (rev 0)
+++ grass/trunk/lib/temporal/src/Makefile	2012-01-19 00:11:22 UTC (rev 50284)
@@ -0,0 +1,14 @@
+MODULE_TOPDIR = ../../..
+EXTRA_LIBS = $(GISLIB) $(DBMILIB) $(DATETIMELIB)
+# needed? $(OMPLIBPATH)
+LIB = TEMPORAL
+include $(MODULE_TOPDIR)/include/Make/Lib.make
+include $(MODULE_TOPDIR)/include/Make/Doxygen.make
+default: lib
+#doxygen:
+DOXNAME=temporal
Added: grass/trunk/lib/temporal/src/connect.c
--- grass/trunk/lib/temporal/src/connect.c	                        (rev 0)
+++ grass/trunk/lib/temporal/src/connect.c	2012-01-19 00:11:22 UTC (rev 50284)
@@ -0,0 +1,52 @@
+  \file lib/temporal/src/connect.c
+  \brief Temporal GIS Library - connect to TGIS DB
+  (C) 2012 by the GRASS Development Team
+  This program is free software under the GNU General Public License
+  (>=v2). Read the file COPYING that comes with GRASS for details.
+  \author Soeren Gebbert
+          Code is based on the dbmi library written by
+          Joel Jones (CERL/UIUC) and Radim Blazek
+#include <grass/temporal.h>
+  \brief Set default Temporal GIS DB connection settings
+  This function sets enviromental variables as TGISDB_DRIVER, TGISDB_DATABASE.
+  \param connection pointer to dbConnection with default settings
+  \return DB_OK
+int tgis_set_connection(dbConnection * connection)
+    if (connection->driverName)
+	G_setenv2("TGISDB_DRIVER", connection->driverName, G_VAR_MAPSET);
+    if (connection->databaseName)
+	G_setenv2("TGISDB_DATABASE", connection->databaseName, G_VAR_MAPSET);
+    return DB_OK;
+  \brief Get Temporal GIS DB connection settings
+  \param[out] connection pointer to dbConnection to be modified
+  \return DB_OK
+int tgis_get_connection(dbConnection * connection)
+    G_zero(connection, sizeof(dbConnection));
+    connection->driverName = (char *)G__getenv2("TGISDB_DRIVER", G_VAR_MAPSET);
+    connection->databaseName = (char *)G__getenv2("TGISDB_DATABASE", G_VAR_MAPSET);
+    return DB_OK;
Added: grass/trunk/lib/temporal/src/default_name.c
--- grass/trunk/lib/temporal/src/default_name.c	                        (rev 0)
+++ grass/trunk/lib/temporal/src/default_name.c	2012-01-19 00:11:22 UTC (rev 50284)
@@ -0,0 +1,77 @@
+  \file lib/db/dbmi_base/default_name.c
+  \brief Temporal GIS Library (base) - default settings
+#include <stdlib.h>
+#include <string.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+  \brief Get default TGIS driver name
+  \return pointer to default TGIS driver name
+  \return NULL if not set
+const char *tgis_get_default_driver_name(void)
+    const char *drv;
+    if ((drv = G__getenv2("TGISDB_DRIVER", G_VAR_MAPSET)))
+	return G_store(drv);
+    return NULL;
+  \brief Get default TGIS database name
+  \return pointer to default TGIS database name
+const char *tgis_get_default_database_name(void)
+    const char *drv;
+    if ((drv = G__getenv2("TGISDB_DATABASE", G_VAR_MAPSET)))
+    return NULL;
+  \brief Sets up TGIS database connection settings using GRASS default from temporal.h
+  \return returns DB_OK
+int tgis_set_default_connection(void)
+    dbConnection connection;
+    G_debug(1,
+	    "Creating new default TGIS DB params with tgis_set_default_connection()");
+    if (strcmp(TGISDB_DEFAULT_DRIVER, "sqlite") == 0) {
+	connection.driverName = "sqlite";
+	connection.databaseName =
+	    "$GISDBASE/$LOCATION_NAME/PERMANENT/tgis.db";
+	tgis_set_connection(&connection);
+    else
+	G_fatal_error(_("Programmer error"));
+    return DB_OK;
Deleted: grass/trunk/lib/temporal/stds_map_register_table_template.sql
--- grass/trunk/lib/temporal/stds_map_register_table_template.sql	2012-01-18 22:33:23 UTC (rev 50283)
+++ grass/trunk/lib/temporal/stds_map_register_table_template.sql	2012-01-19 00:11:22 UTC (rev 50284)
@@ -1,129 +0,0 @@
--- This SQL script generates the table in which all registered GRASS_MAP maps
--- are listed in.
--- This table will be created for each STDS.
--- SPACETIME_NAME is a placeholder for specific stds name (SQL compliant): name_mapset
--- SPACETIME_ID is a placeholder for specific stds id: name at mapset
--- This table stores the.ids of the GRASS_MAP maps registered in the current spacetime GRASS_MAP table
-CREATE TABLE  SPACETIME_NAME_GRASS_MAP_register (
-  id VARCHAR NOT NULL, -- This colum is a primary foreign key storing the registered GRASS_MAP map.ids
-  PRIMARY KEY (id),
--- Triggers are disabled due to huge performance issues
---CREATE TRIGGER SPACETIME_NAME_GRASS_MAP_register_insert_trigger AFTER INSERT ON SPACETIME_NAME_GRASS_MAP_register
---  BEGIN
---    UPDATE STDS_base SET modification_time = datetime("NOW") WHERE id = 'SPACETIME_ID';
---    UPDATE STDS_base SET revision = (revision + 1) WHERE id = 'SPACETIME_ID';
---    -- Number of registered maps
---    UPDATE STDS_metadata SET number_of_maps =
---           (SELECT count(id) FROM SPACETIME_NAME_GRASS_MAP_register)
---           WHERE id = 'SPACETIME_ID';
---    -- Update the temporal extent
---    UPDATE STDS_absolute_time SET start_time =
---           (SELECT min(start_time) FROM GRASS_MAP_absolute_time WHERE GRASS_MAP_absolute_time.id IN
---			(SELECT id FROM SPACETIME_NAME_GRASS_MAP_register)
---           ) WHERE id = 'SPACETIME_ID';
---    UPDATE STDS_absolute_time SET end_time =
---           (SELECT max(end_time) FROM GRASS_MAP_absolute_time WHERE GRASS_MAP_absolute_time.id IN
---    UPDATE STDS_relative_time SET start_time =
---           (SELECT min(start_time) FROM GRASS_MAP_relative_time WHERE GRASS_MAP_relative_time.id IN
---    UPDATE STDS_relative_time SET end_time =
---           (SELECT max(end_time) FROM GRASS_MAP_relative_time WHERE GRASS_MAP_relative_time.id IN
---    -- Update the spatial extent
---    UPDATE STDS_spatial_extent SET north =
---           (SELECT max(north) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
---    UPDATE STDS_spatial_extent SET south =
---           (SELECT min(south) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
---    UPDATE STDS_spatial_extent SET east =
---           (SELECT max(east) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
---    UPDATE STDS_spatial_extent SET west =
---           (SELECT min(west) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
---    UPDATE STDS_spatial_extent SET top =
---           (SELECT max(top) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
---    UPDATE STDS_spatial_extent SET bottom =
---           (SELECT min(bottom) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
---    UPDATE STDS_spatial_extent SET proj =
---           (SELECT min(proj) FROM GRASS_MAP_spatial_extent WHERE GRASS_MAP_spatial_extent.id IN
---  END;
---CREATE TRIGGER SPACETIME_NAME_GRASS_MAP_register_delete_trigger AFTER DELETE ON SPACETIME_NAME_GRASS_MAP_register
--- BEGIN
---  END;
Deleted: grass/trunk/lib/temporal/stds_raster3d_register_trigger_template.sql
--- grass/trunk/lib/temporal/stds_raster3d_register_trigger_template.sql	2012-01-18 22:33:23 UTC (rev 50283)
+++ grass/trunk/lib/temporal/stds_raster3d_register_trigger_template.sql	2012-01-19 00:11:22 UTC (rev 50284)
@@ -1,113 +0,0 @@
--- This SQL script creates a trigger to update a space-time raster3d dataset
--- metadata
---CREATE TRIGGER SPACETIME_NAME_raster3d_metadata_register_insert_trigger AFTER INSERT ON SPACETIME_NAME_raster3d_register
---  BEGIN
---    -- Update the min and max values
---    UPDATE str3ds_metadata SET min_min =
---           (SELECT min(min) FROM raster3d_metadata WHERE raster3d_metadata.id IN
---			(SELECT id FROM SPACETIME_NAME_raster3d_register)
---    UPDATE str3ds_metadata SET min_max =
---           (SELECT max(min) FROM raster3d_metadata WHERE raster3d_metadata.id IN
---    UPDATE str3ds_metadata SET max_min =
---           (SELECT min(max) FROM raster3d_metadata WHERE raster3d_metadata.id IN
---    UPDATE str3ds_metadata SET max_max =
---           (SELECT max(max) FROM raster3d_metadata WHERE raster3d_metadata.id IN
---    -- Update the resolution
---    UPDATE str3ds_metadata SET nsres_min =
---           (SELECT min(nsres) FROM raster3d_metadata WHERE raster3d_metadata.id IN
---    UPDATE str3ds_metadata SET nsres_max =
---           (SELECT max(nsres) FROM raster3d_metadata WHERE raster3d_metadata.id IN
---    UPDATE str3ds_metadata SET ewres_min =
---           (SELECT min(ewres) FROM raster3d_metadata WHERE raster3d_metadata.id IN
---    UPDATE str3ds_metadata SET ewres_max =
---           (SELECT max(ewres) FROM raster3d_metadata WHERE raster3d_metadata.id IN
---    UPDATE str3ds_metadata SET tbres_min =
---           (SELECT min(tbres) FROM raster3d_metadata WHERE raster3d_metadata.id IN
---    UPDATE str3ds_metadata SET tbres_max =
---           (SELECT max(tbres) FROM raster3d_metadata WHERE raster3d_metadata.id IN
---  END;
---CREATE TRIGGER SPACETIME_NAME_raster3d_metadata_register_delete_trigger AFTER DELETE ON SPACETIME_NAME_raster3d_register
---  BEGIN
---  END;
Deleted: grass/trunk/lib/temporal/stds_raster_register_trigger_template.sql
--- grass/trunk/lib/temporal/stds_raster_register_trigger_template.sql	2012-01-18 22:33:23 UTC (rev 50283)
+++ grass/trunk/lib/temporal/stds_raster_register_trigger_template.sql	2012-01-19 00:11:22 UTC (rev 50284)
@@ -1,113 +0,0 @@
--- This SQL script creates a trigger to update a space-time raster dataset
--- metadata
---CREATE TRIGGER SPACETIME_NAME_raster_metadata_register_insert_trigger AFTER INSERT ON SPACETIME_NAME_raster_register
---  BEGIN
---    UPDATE strds_metadata SET min_min =
---           (SELECT min(min) FROM raster_metadata WHERE raster_metadata.id IN
---			(SELECT id FROM SPACETIME_NAME_raster_register)
---    UPDATE strds_metadata SET min_max =
---           (SELECT max(min) FROM raster_metadata WHERE raster_metadata.id IN
---    UPDATE strds_metadata SET max_min =
---           (SELECT min(max) FROM raster_metadata WHERE raster_metadata.id IN
---    UPDATE strds_metadata SET max_max =
---           (SELECT max(max) FROM raster_metadata WHERE raster_metadata.id IN
---    UPDATE strds_metadata SET nsres_min =
---           (SELECT min(nsres) FROM raster_metadata WHERE raster_metadata.id IN
---    UPDATE strds_metadata SET nsres_max =
---           (SELECT max(nsres) FROM raster_metadata WHERE raster_metadata.id IN
---    UPDATE strds_metadata SET ewres_min =
---           (SELECT min(ewres) FROM raster_metadata WHERE raster_metadata.id IN
---    UPDATE strds_metadata SET ewres_max =
---           (SELECT max(ewres) FROM raster_metadata WHERE raster_metadata.id IN
---  END;
---CREATE TRIGGER SPACETIME_NAME_raster_metadata_register_delete_trigger AFTER DELETE ON SPACETIME_NAME_raster_register
---  BEGIN
---  END;
Deleted: grass/trunk/lib/temporal/stds_tables_template.sql
--- grass/trunk/lib/temporal/stds_tables_template.sql	2012-01-18 22:33:23 UTC (rev 50283)
+++ grass/trunk/lib/temporal/stds_tables_template.sql	2012-01-19 00:11:22 UTC (rev 50284)
@@ -1,79 +0,0 @@
--- This SQL script generates the space time dataset tables to store time
--- stamps and revision for SQL queries and temporal GIS support.
-CREATE TABLE  STDS_base (
-  id VARCHAR NOT NULL,                 -- Id of the space-time dataset, name at mapset this is the primary key
-  name VARCHAR NOT NULL,               -- name of the space-time dataset
-  mapset VARCHAR NOT NULL,             -- mapset of the space-time dataset
-  creator VARCHAR NOT NULL,            -- Name of the creator
-  temporal_type VARCHAR NOT NULL,      -- The temporal type of the dataset "absolute" or "relative"
-  semantic_type VARCHAR NOT NULL,      -- The semantic data description used for aggregation/decomposition algorithm selection
-  creation_time TIMESTAMP NOT NULL,    -- The time of creation of the space-time dataset
---  revision SMALLINT NOT NULL,            -- The revision number        -- The revision number
-  PRIMARY KEY (id)
-CREATE TABLE  STDS_relative_time (
-  id VARCHAR NOT NULL,            -- Id of the space-time dataset, this is the primary foreign key
-  granularity DOUBLE PRECISION,   -- The granularity in [days]
-  map_time VARCHAR,               -- The temporal type of the registered maps, may be interval, point or mixed
-  PRIMARY KEY (id),
-CREATE TABLE  STDS_absolute_time (
-  start_time TIMESTAMP,           -- Start of the valid time, can be NULL if no map is registered
-  end_time TIMESTAMP,             -- End of the valid time, can be NULL if no map is registered
-  granularity VARCHAR,            -- The granularity "NNN seconds, NNN minutes, NNN hours, NNN days, NNN weeks, NNN months, NNN years"
-  timezone SMALLINT,              -- The time zone number
-  PRIMARY KEY (id),
-CREATE TABLE  STDS_spatial_extent (
-  north DOUBLE PRECISION,   -- The spatial north extent, derived from the registered maps
-  south DOUBLE PRECISION,   -- The spatial south extent, derived from the registered maps
-  east DOUBLE PRECISION,    -- The spatial east extent, derived from the registered maps
-  west DOUBLE PRECISION,    -- The spatial west extent, derived from the registered maps
-  top DOUBLE PRECISION,     -- The spatial top extent, derived from the registered maps
-  bottom DOUBLE PRECISION,  -- The spatial bottom extent, derived from the registered maps
-  proj VARCHAR,      -- The projection of the space time dataset (XY of LL)
-  PRIMARY KEY (id),
---CREATE TRIGGER update_STDS_abs_time AFTER UPDATE ON STDS_absolute_time
---  BEGIN
---    UPDATE STDS_base SET modification_time = datetime("NOW") WHERE id = old.id;
---    UPDATE STDS_base SET revision = (revision + 1) WHERE id = old.id;
---  END;
---CREATE TRIGGER update_STDS_rel_time AFTER UPDATE ON STDS_relative_time
---  BEGIN
---  END;
---CREATE TRIGGER update_STDS_spatial_extent AFTER UPDATE ON STDS_spatial_extent
---  BEGIN
---  END;
Deleted: grass/trunk/lib/temporal/stds_vector_register_trigger_template.sql
--- grass/trunk/lib/temporal/stds_vector_register_trigger_template.sql	2012-01-18 22:33:23 UTC (rev 50283)
+++ grass/trunk/lib/temporal/stds_vector_register_trigger_template.sql	2012-01-19 00:11:22 UTC (rev 50284)
@@ -1,6 +0,0 @@
--- This SQL script is for now a placeholder, till the vector metadata
--- concept is clear
Deleted: grass/trunk/lib/temporal/str3ds_metadata_table.sql
--- grass/trunk/lib/temporal/str3ds_metadata_table.sql	2012-01-18 22:33:23 UTC (rev 50283)
+++ grass/trunk/lib/temporal/str3ds_metadata_table.sql	2012-01-19 00:11:22 UTC (rev 50284)
@@ -1,80 +0,0 @@
--- This SQL script generates the space time raster3d dataset metadata table,
--- view and trigger
-CREATE TABLE  str3ds_metadata (
-  id VARCHAR NOT NULL,          -- Id of the space-time raster3d dataset, this is the primary foreign key
-  raster3d_register VARCHAR,    -- The id of the table in which the raster3d maps are registered for this dataset
-  number_of_maps INTEGER,       -- The number of registered raster3d maps
-  max_min DOUBLE PRECISION,     -- The minimal maximum of the registered raster3d maps
-  min_min DOUBLE PRECISION,     -- The minimal minimum of the registered raster3d maps
-  max_max DOUBLE PRECISION,     -- The maximal maximum of the registered raster3d maps
-  min_max DOUBLE PRECISION,     -- The maximal minimum of the registered raster3d maps
-  nsres_min DOUBLE PRECISION,   -- The lowest north-south resolution of the registered raster3d maps
-  nsres_max DOUBLE PRECISION,   -- The highest north-south resolution of the registered raster3d maps
-  ewres_min DOUBLE PRECISION,   -- The lowest east-west resolution of the registered raster3d maps
-  ewres_max DOUBLE PRECISION,   -- The highest east-west resolution of the registered raster3d maps
-  tbres_min DOUBLE PRECISION,   -- The lowest top-bottom resolution of the registered raster3d maps
-  tbres_max DOUBLE PRECISION,   -- The highest top-bottom resolution of the registered raster3d maps
-  title VARCHAR,                -- Title of the space-time raster3d dataset
-  description VARCHAR,          -- Detailed description of the space-time raster3d dataset
-  PRIMARY KEY (id),
-  FOREIGN KEY (id) REFERENCES  str3ds_base (id) ON DELETE CASCADE
--- Create the views to access all cols for absolute or relative time
-CREATE VIEW str3ds_view_abs_time AS SELECT
-            A1.id, A1.name, A1.mapset, A1.temporal_type,
-            A1.semantic_type,
-            A1.creation_time,
-            A1.creator,
-	    A2.start_time, A2.end_time, A2.timezone, A2.granularity,
-	    A4.raster3d_register,
-	    A4.number_of_maps,
-            A4.nsres_min, A4.ewres_min,
-            A4.nsres_max, A4.ewres_max,
-            A4.tbres_min, A4.tbres_max,
-	    A4.min_min, A4.min_max,
-	    A4.max_min, A4.max_max,
-            A4.title, A4.description
-	    FROM str3ds_base A1, str3ds_absolute_time A2,
-            str3ds_spatial_extent A3, str3ds_metadata A4 WHERE A1.id = A2.id AND
-	    A1.id = A3.id AND A1.id = A4.id;
-CREATE VIEW str3ds_view_rel_time AS SELECT
-            A1.semantic_type,
-            A1.creation_time,
-            A1.creator,
-	    A2.start_time, A2.end_time, A2.granularity,
-	    FROM str3ds_base A1, str3ds_relative_time A2,
---CREATE TRIGGER update_str3ds_metadata AFTER UPDATE ON str3ds_metadata
---  BEGIN
---    UPDATE str3ds_base SET modification_time = datetime("NOW") WHERE id = old.id;
---    UPDATE str3ds_base SET revision = (revision + 1) WHERE id = old.id;
---  END;
Deleted: grass/trunk/lib/temporal/strds_metadata_table.sql
--- grass/trunk/lib/temporal/strds_metadata_table.sql	2012-01-18 22:33:23 UTC (rev 50283)
+++ grass/trunk/lib/temporal/strds_metadata_table.sql	2012-01-19 00:11:22 UTC (rev 50284)
@@ -1,76 +0,0 @@
--- This SQL script generates the space time raster dataset metadata table,
-CREATE TABLE  strds_metadata (
-  raster_register VARCHAR,      -- The id of the table in which the raster maps are registered for this dataset
-  number_of_maps INTEGER,       -- The number of registered raster maps
-  max_min DOUBLE PRECISION,     -- The minimal maximum of the registered raster maps
-  min_min DOUBLE PRECISION,     -- The minimal minimum of the registered raster maps
-  max_max DOUBLE PRECISION,     -- The maximal maximum of the registered raster maps
-  min_max DOUBLE PRECISION,     -- The maximal minimum of the registered raster maps
-  nsres_min DOUBLE PRECISION,   -- The lowest north-south resolution of the registered raster maps
-  nsres_max DOUBLE PRECISION,   -- The highest north-south resolution of the registered raster maps
-  ewres_min DOUBLE PRECISION,   -- The lowest east-west resolution of the registered raster maps
-  ewres_max DOUBLE PRECISION,   -- The highest east-west resolution of the registered raster maps
-  title VARCHAR,                -- Title of the space-time raster dataset
-  description VARCHAR,          -- Detailed description of the space-time raster dataset
-  PRIMARY KEY (id),
-  FOREIGN KEY (id) REFERENCES  strds_base (id) ON DELETE CASCADE
-CREATE VIEW strds_view_abs_time AS SELECT
-            A1.semantic_type,
-            A1.creation_time,
-            A1.creator,
-	    A4.raster_register,
-	    FROM strds_base A1, strds_absolute_time A2,
-            strds_spatial_extent A3, strds_metadata A4 WHERE A1.id = A2.id AND
-CREATE VIEW strds_view_rel_time AS SELECT
-            A1.semantic_type,
-            A1.creation_time,
-            A1.creator,
-	    FROM strds_base A1, strds_relative_time A2,
---CREATE TRIGGER update_strds_metadata AFTER UPDATE ON strds_metadata
---  BEGIN
---    UPDATE strds_base SET modification_time = datetime("NOW") WHERE id = old.id;
---    UPDATE strds_base SET revision = (revision + 1) WHERE id = old.id;
---  END;
Deleted: grass/trunk/lib/temporal/stvds_metadata_table.sql
--- grass/trunk/lib/temporal/stvds_metadata_table.sql	2012-01-18 22:33:23 UTC (rev 50283)
+++ grass/trunk/lib/temporal/stvds_metadata_table.sql	2012-01-19 00:11:22 UTC (rev 50284)
@@ -1,61 +0,0 @@
--- This SQL script generates the space time vector dataset metadata table,
-CREATE TABLE  stvds_metadata (
-  id VARCHAR NOT NULL,                -- Name of the space-time vector dataset, this is the primary foreign key
-  vector_register VARCHAR,                    -- The id of the table in which the vector maps are registered for this dataset
-  number_of_maps INTEGER,          -- The number of registered vector maps
-  title VARCHAR,                              -- Title of the space-time vector dataset
-  description VARCHAR,                        -- Detailed description of the space-time vector dataset
-  PRIMARY KEY (id),
-  FOREIGN KEY (id) REFERENCES  stvds_base (id) ON DELETE CASCADE
--- Create the views to access all columns for absolute or relative time
-CREATE VIEW stvds_view_abs_time AS SELECT
-            A1.semantic_type,
-            A1.creation_time,
-            A1.creator,
-            A2.granularity,
-	    A4.vector_register,
-	    FROM stvds_base A1, stvds_absolute_time A2,
-            stvds_spatial_extent A3, stvds_metadata A4 WHERE A1.id = A2.id AND
-CREATE VIEW stvds_view_rel_time AS SELECT
-            A1.semantic_type,
-            A1.creation_time,
-            A1.creator,
-	    FROM stvds_base A1, stvds_relative_time A2,
---CREATE TRIGGER update_stvds_metadata AFTER UPDATE ON stvds_metadata
---  BEGIN
---    UPDATE stvds_base SET modification_time = datetime("NOW") WHERE id = old.id;
---    UPDATE stvds_base SET revision = (revision + 1) WHERE id = old.id;
---  END;
Deleted: grass/trunk/lib/temporal/test.temporal.py
--- grass/trunk/lib/temporal/test.temporal.py	2012-01-18 22:33:23 UTC (rev 50283)
+++ grass/trunk/lib/temporal/test.temporal.py	2012-01-19 00:11:22 UTC (rev 50284)
@@ -1,836 +0,0 @@
-import os
-from grass.script.tgis_core import *
-from grass.script.tgis_base import *
-from grass.script.tgis_temporal_extent import *
-from grass.script.tgis_spatial_extent import *
-from grass.script.tgis_metadata import *
-from grass.script.tgis_abstract_datasets import *
-from grass.script.tgis_space_time_datasets import *
-import grass.script as grass
-def test_dict_sql_serializer():
-    t = dict_sql_serializer()
-    t.test()
-def test_dataset_identifer():
-	for i in range(2):
-	    base = raster_base(ident="soil" + str(i) + "@PERMANENT", name="soil" + str(i), mapset="PERMANENT", creator="soeren", temporal_type="absolute", revision=1)
-	    base.insert()
-	    base.select()
-	    base.print_self()
-	    base.clear()
-	    base.set_creator("rene")
-	    base.update()
-	    base.select()
-	    base.print_self()
-	    base = raster3d_base(ident="soil" + str(i) + "@PERMANENT", name="soil" + str(i), mapset="PERMANENT", temporal_type="absolute", creator="soeren")
-	    base.insert()
-	    base.select()
-	    base.print_self()
-	    base.clear()
-	    base.update()
-	    base.select()
-	    base.print_self()
-	    base = vector_base(ident="soil" + str(i) + "@PERMANENT", name="soil" + str(i), mapset="PERMANENT", temporal_type="absolute", creator="soeren")
-	    base.insert()
-	    base.select()
-	    base.print_self()
-	    base.clear()
-	    base.update()
-	    base.select()
-	    base.print_self()
-	    base = strds_base(ident="soil" + str(i) + "@PERMANENT", name="soil" + str(i), mapset="PERMANENT", creator="soeren", semantic_type="event", temporal_type="absolute", revision=1)
-	    base.insert()
-	    base.select()
-	    base.print_self()
-	    base.clear()
-	    base.update()
-	    base.select()
-	    base.print_self()
-	    base = str3ds_base(ident="soil" + str(i) + "@PERMANENT", name="soil" + str(i), mapset="PERMANENT", temporal_type="absolute", semantic_type="event", creator="soeren")
-	    base.insert()
-	    base.select()
-	    base.print_self()
-	    base.clear()
-	    base.update()
-	    base.select()
-	    base.print_self()
-	    base = stvds_base(ident="soil" + str(i) + "@PERMANENT", name="soil" + str(i), mapset="PERMANENT", temporal_type="absolute", semantic_type="event", creator="soeren")
-	    base.insert()
-	    base.select()
-	    base.print_self()
-	    base.clear()
-	    base.update()
-	    base.select()
-	    base.print_self()
-def test_absolute_timestamp():
-	    base = raster_absolute_time(ident="soil" + str(i) + "@PERMANENT", start_time=datetime(2011,01,01), end_time=datetime(2011,07,01), timezone=1)
-	    base.insert()
-	    base.select()
-	    base.print_self()
-	    base.clear()
-	    base.set_start_time(datetime(2010,01,01))
-	    base.update()
-	    base.select()
-	    base.print_self()
-	    base = raster3d_absolute_time(ident="soil" + str(i) + "@PERMANENT", start_time=datetime(2011,01,01), end_time=datetime(2011,07,01), timezone=1)
-	    base.insert()
-	    base.select()
-	    base.print_self()
-	    base.clear()
-	    base.update()
-	    base.select()
-	    base.print_self()
-	    base = vector_absolute_time(ident="soil" + str(i) + "@PERMANENT", start_time=datetime(2011,01,01), end_time=datetime(2011,07,01), timezone=1)
-	    base.insert()
-	    base.select()
-	    base.print_self()
-	    base.clear()
-	    base.update()
-	    base.select()
-	    base.print_self()
-	    base = strds_absolute_time(ident="soil" + str(i) + "@PERMANENT", start_time=datetime(2011,01,01), end_time=datetime(2011,07,01), granularity="1 day", timezone=1)
-	    base.insert()
-	    base.select()
-	    base.print_self()
-	    base.clear()
-	    base.update()
-	    base.select()
-	    base.print_self()
-	    base = str3ds_absolute_time(ident="soil" + str(i) + "@PERMANENT", start_time=datetime(2011,01,01), end_time=datetime(2011,07,01), granularity="1 day", timezone=1)
-	    base.insert()
-	    base.select()
-	    base.print_self()
-	    base.clear()
-	    base.update()
-	    base.select()
-	    base.print_self()
-	    base = stvds_absolute_time(ident="soil" + str(i) + "@PERMANENT", start_time=datetime(2011,01,01), end_time=datetime(2011,07,01), granularity="1 day", timezone=1)
-	    base.insert()
-	    base.select()
-	    base.print_self()
-	    base.clear()
-	    base.update()
-	    base.select()
-	    base.print_self()
-def test_spatial_extent():
-	    base = raster_spatial_extent(ident="soil" + str(i) + "@PERMANENT", north=100 + i, south=10+i, east=50+i, west=20+i, top=i, bottom=0)
-	    base.insert()
-	    base.select()
-	    base.print_self()
-	    base.clear()
-	    base.set_north(120+i)
-	    base.update()
-	    base.select()
-	    base.print_self()
-	    base = raster3d_spatial_extent(ident="soil" + str(i) + "@PERMANENT", north=100 + i, south=10+i, east=50+i, west=20+i, top=i, bottom=0)
-	    base.insert()
-	    base.select()
-	    base.print_self()
-	    base.clear()
-	    base.update()
-	    base.select()
-	    base.print_self()
-	    base = vector_spatial_extent(ident="soil" + str(i) + "@PERMANENT", north=100 + i, south=10+i, east=50+i, west=20+i, top=i, bottom=0)
-	    base.insert()
-	    base.select()
-	    base.print_self()
-	    base.clear()
-	    base.update()
-	    base.select()
-	    base.print_self()
-	    base = strds_spatial_extent(ident="soil" + str(i) + "@PERMANENT", north=100 + i, south=10+i, east=50+i, west=20+i, top=i, bottom=0)
-	    base.insert()
-	    base.select()
-	    base.print_self()
-	    base.clear()
-	    base.update()
-	    base.select()
-	    base.print_self()
-	    base = str3ds_spatial_extent(ident="soil" + str(i) + "@PERMANENT", north=100 + i, south=10+i, east=50+i, west=20+i, top=i, bottom=0)
-	    base.insert()
-	    base.select()
-	    base.print_self()
-	    base.clear()
-	    base.update()
-	    base.select()
-	    base.print_self()
-	    base = stvds_spatial_extent(ident="soil" + str(i) + "@PERMANENT", north=100 + i, south=10+i, east=50+i, west=20+i, top=i, bottom=0)
-	    base.insert()
-	    base.select()
-	    base.print_self()
-	    base.clear()
-	    base.update()
-	    base.select()
-	    base.print_self()
-def test_relative_timestamp():
-	    base = raster_relative_time(ident="soil" + str(i) + "@PERMANENT", interval=i)
-	    base.insert()
-	    base.select()
-	    base.print_self()
-	    base.clear()
-	    base.set_interval(i+1)
-	    base.update()
-	    base.select()
-	    base.print_self()
-	    base = raster3d_relative_time(ident="soil" + str(i) + "@PERMANENT", interval=i)
-	    base.insert()
-	    base.select()
-	    base.print_self()
-	    base.clear()
-	    base.update()
-	    base.select()
-	    base.print_self()
-	    base = vector_relative_time(ident="soil" + str(i) + "@PERMANENT", interval=i)
-	    base.insert()
-	    base.select()
-	    base.print_self()
-	    base.clear()
-	    base.update()
-	    base.select()
-	    base.print_self()
-	    base = strds_relative_time(ident="soil" + str(i) + "@PERMANENT", interval=i, granularity=5.5)
-	    base.insert()
-	    base.select()
-	    base.print_self()
-	    base.clear()
-	    base.update()
-	    base.select()
-	    base.print_self()
-	    base = str3ds_relative_time(ident="soil" + str(i) + "@PERMANENT", interval=i, granularity=5.5)
-	    base.insert()
-	    base.select()
-	    base.print_self()
-	    base.clear()
-	    base.update()
-	    base.select()
-	    base.print_self()
-	    base = stvds_relative_time(ident="soil" + str(i) + "@PERMANENT", interval=i, granularity=5.5)
-	    base.insert()
-	    base.select()
-	    base.print_self()
-	    base.clear()
-	    base.update()
-	    base.select()
-	    base.print_self()
-def test_map_metadata():
-	    base = raster_metadata(ident="soil" + str(i) + "@PERMANENT", strds_register="PERMANENT_soil_strds_register", datatype="CELL", \
-			    cols=500, rows=400, number_of_cells=200000,nsres=1, ewres=1, min=0, max=33)
-	    base.insert()
-	    base.select()
-	    base.print_self()
-	    base.clear()
-	    base.set_datatype("FCELL")
-	    base.update()
-	    base.select()
-	    base.print_self()
-	    base = raster3d_metadata(ident="soil" + str(i) + "@PERMANENT", str3ds_register="PERMANENT_soil_str3ds_register", datatype="FCELL", \
-			    cols=500, rows=400, depths=20, number_of_cells=200000,nsres=1, ewres=1, tbres=10, min=0, max=33)
-	    base.insert()
-	    base.select()
-	    base.print_self()
-	    base.clear()
-	    base.set_datatype("DCELL")
-	    base.update()
-	    base.select()
-	    base.print_self()
-	    base = vector_metadata(ident="soil" + str(i) + "@PERMANENT", stvds_register="PERMANENT_soil_stvds_register")
-	    base.insert()
-	    base.select()
-	    base.print_self()
-	    base.clear()
-	    base.set_stvds_register("PERMANENT_soil_stvds_register")
-	    base.update()
-	    base.select()
-	    base.print_self()
-	    base = strds_metadata(ident="soil" + str(i) + "@PERMANENT", raster_register="PERMANENT_soil_raster_register", \
-                                   title="Test", description="Test description")
-	    base.insert()
-	    base.select()
-	    base.print_self()
-	    base.clear()
-	    base.set_title("More tests")
-	    base.update()
-	    base.select()
-	    base.print_self()
-	    base = str3ds_metadata(ident="soil" + str(i) + "@PERMANENT", raster3d_register="PERMANENT_soil_raster3d_register", \
-	    base.insert()
-	    base.select()
-	    base.print_self()
-	    base.clear()
-	    base.update()
-	    base.select()
-	    base.print_self()
-	    base = stvds_metadata(ident="soil" + str(i) + "@PERMANENT", vector_register="PERMANENT_soil_vector_register", \
-	    base.insert()
-	    base.select()
-	    base.print_self()
-	    base.clear()
-	    base.update()
-	    base.select()
-	    base.print_self()
-def test_base_absolute_time_extent_metadata():
-	for i in range(10):
-	    base = vector_base(ident="water" + str(i) + "@PERMANENT", name="water" + str(i), mapset="PERMANENT", creator="soeren")
-	    base.insert()
-	    base = raster_base(ident="water" + str(i) + "@PERMANENT", name="water" + str(i), mapset="PERMANENT", creator="soeren")
-	    base.insert()
-	    base = raster3d_base(ident="water" + str(i) + "@PERMANENT", name="water" + str(i), mapset="PERMANENT", creator="soeren")
-	    base.insert()
-	    base = vector_base(ident="water" + str(i) + "@PERMANENT")
-	    base.update()
-	    base = raster_base(ident="water" + str(i) + "@PERMANENT")
-	    base.update()
-	    base = raster3d_base(ident="water" + str(i) + "@PERMANENT")
-	    base.update()
-	    base = vector_absolute_time(ident="water" + str(i) + "@PERMANENT", start_time=datetime.now(), end_time=datetime.now(), timezone=1)
-	    base.insert()
-	    base = raster_absolute_time(ident="water" + str(i) + "@PERMANENT", start_time=datetime.now(), end_time=datetime.now(), timezone=1)
-	    base.insert()
-	    base = raster3d_absolute_time(ident="water" + str(i) + "@PERMANENT", start_time=datetime.now(), end_time=datetime.now(), timezone=1)
-	    base.insert()
-	    base = vector_absolute_time(ident="water" + str(i) + "@PERMANENT")
-	    base.set_start_time(datetime(2010, 6, 1))
-	    base.update()
-	    base = raster_absolute_time(ident="water" + str(i) + "@PERMANENT")
-	    base.update()
-	    base = raster3d_absolute_time(ident="water" + str(i) + "@PERMANENT")
-	    base.update()
-	    base = vector_spatial_extent(ident="water" + str(i) + "@PERMANENT", north=100 + i, south=10+i, east=50+i, west=20+i, top=i, bottom=0)
-	    base.insert()
-	    base = raster_spatial_extent(ident="water" + str(i) + "@PERMANENT", north=100 + i, south=10+i, east=50+i, west=20+i, top=0, bottom=0)
-	    base.insert()
-	    base = raster3d_spatial_extent(ident="water" + str(i) + "@PERMANENT", north=100 + i, south=10+i, east=50+i, west=20+i, top=i, bottom=0)
-	    base.insert()
-	    base = vector_spatial_extent(ident="water" + str(i) + "@PERMANENT")
-	    base.set_north(120 + i)
-	    base.set_south(20 + i)
-	    base.update()
-	    base = raster_spatial_extent(ident="water" + str(i) + "@PERMANENT")
-	    base.update()
-	    base = raster3d_spatial_extent(ident="water" + str(i) + "@PERMANENT")
-	    base.update()
-	    base = vector_metadata(ident="water" + str(i) + "@PERMANENT", stvds_register="PERMANENT_water_stvds_register")
-	    base.insert()
-	    base = raster_metadata(ident="water" + str(i) + "@PERMANENT", strds_register="PERMANENT_water_strds-register", datatype="CELL", \
-	    base.insert()
-	    base = raster3d_metadata(ident="water" + str(i) + "@PERMANENT", str3ds_register="PERMANENT_water_str3ds-register", datatype="FCELL", \
-	    base.insert()
-	    base = vector_metadata(ident="water" + str(i) + "@PERMANENT")
-	    base.set_stvds_register("PERMANENT_water_stvds_register")
-	    base.update()
-	    base = raster_metadata(ident="water" + str(i) + "@PERMANENT")
-	    base.update()
-	    base = raster3d_metadata(ident="water" + str(i) + "@PERMANENT")
-	    base.update()
-	    base.select()
-	    base.print_self()
-	    base.select()
-	    base.print_self()
-	    base.select()
-	    base.print_self()
-	print "Create a raster object"
-	rds = raster_dataset("water0 at PERMANENT")
-	rds.select()
-	rds.print_self()
-	print rds.temporal_relation(rds)
-def test_absolut_time_temporal_relations():
-    A = raster_absolute_time(ident="test1 at PERMANENT", start_time=datetime(year=2000, month=1, day=1), \
-		                                        end_time=datetime(year=2001, month=1, day=1), timezone=1)
-    B = raster_absolute_time(ident="test2 at PERMANENT", start_time=datetime(year=2001, month=1, day=1), \
-		                                        end_time=datetime(year=2002, month=1, day=1), timezone=1)
-    print "Precedes: ", A.temporal_relation(B)
-    print "Follows:  ", B.temporal_relation(A)
-    B = raster_absolute_time(ident="test2 at PERMANENT", start_time=datetime(year=2001, month=1, day=2), \
-    print "Before:   ", A.temporal_relation(B)
-    print "After:    ", B.temporal_relation(A)
-    B = raster_absolute_time(ident="test2 at PERMANENT", start_time=datetime(year=2000, month=1, day=1), \
-    print "Starts:   ", A.temporal_relation(B)
-    print "Started:  ", B.temporal_relation(A)
-    B = raster_absolute_time(ident="test2 at PERMANENT", start_time=datetime(year=2000, month=1, day=2), \
-    print "Finished: ", A.temporal_relation(B)
-    print "Finishes: ", B.temporal_relation(A)
-    B = raster_absolute_time(ident="test2 at PERMANENT", start_time=datetime(year=2000, month=3, day=1), \
-		                                        end_time=datetime(year=2000, month=9, day=1), timezone=1)
-    print "Contains: ", A.temporal_relation(B)
-    print "During:   ", B.temporal_relation(A)
-		                                        end_time=datetime(year=2000, month=6, day=1), timezone=1)
-    print "Overlap:   ", A.temporal_relation(B)
-    print "Overlapped:", B.temporal_relation(A)
-		                                        end_time=datetime(year=2000, month=1, day=1), timezone=1)
-    print "Equivalent:", A.temporal_relation(B)
-    print "Equivalent:", B.temporal_relation(A)
-def test_raster_dataset():
-    # Create a test map
-    grass.raster.mapcalc("test = sin(x()) + cos(y())", overwrite = True)
-    name = "test"
-    mapset =  grass.gisenv()["MAPSET"]
-    # We need to specify the name and the mapset as identifier
-    rds = raster_dataset(name + "@" + mapset)
-    # Load data from the raster map in the mapset
-    rds.load()
-    print "Is in db: ", rds.is_in_db()
-    if rds.is_in_db():
-        # Remove the entry if it is in the db
-        rds.delete()
-    # Set the absolute valid time
-    rds.set_absolute_time(start_time= datetime(year=2000, month=1, day=1), \
-                            end_time= datetime(year=2010, month=1, day=1))
-    # Insert the map data into the SQL database
-    rds.insert()
-    # Print self info
-    rds.print_self()
-    # The temporal relation must be equal
-def test_raster3d_dataset():
-    grass.raster3d.mapcalc3d("test = sin(x()) + cos(y()) + sin(z())", overwrite = True)
-    name = "test"
-    r3ds = raster3d_dataset(name + "@" + mapset)
-    r3ds.load()
-    print "Is in db: ", r3ds.is_in_db()
-    if r3ds.is_in_db():
-        r3ds.delete()
-    r3ds.set_absolute_time(start_time= datetime(year=2000, month=1, day=1), \
-    r3ds.insert()
-    # Print self info
-    r3ds.print_self()
-    print r3ds.temporal_relation(r3ds)
-def test_vector_dataset():
-    grass.run_command("v.random", output="test", n=20, column="height", zmin=0, \
-                      zmax=100, flags="z", overwrite = True)
-    name = "test"
-    print "Create a vector object"
-    vds = vector_dataset(name + "@" + mapset)
-    vds.load()
-    print "Is in db: ", vds.is_in_db()
-    if vds.is_in_db():
-        vds.delete()
-    vds.set_absolute_time(start_time= datetime(year=2000, month=1, day=1), \
-    vds.insert()
-    # Print self info
-    vds.print_self()
-    print vds.temporal_relation(vds)
-def test_strds_dataset():
-    name = "strds_test_1"
-    print "Create a strds object"
-    strds = space_time_raster_dataset(ident = name + "@" + mapset)
-    # Check if in db
-    print "Is strds in db: ", strds.is_in_db()
-    # Create a new entry if not in db
-    if strds.is_in_db() == False:
-        strds.set_initial_values(temporal_type = "absolute", granularity="1 day",\
-        semantic_type="event", title="This is a test space time raster dataset", description="A space time raster dataset for testing")
-        strds.insert()
-    # Reread the data from the db
-    strds.select()
-    # Print self info
-    #strds.print_self()
-    # Create a test maps
-    for i in range(11):
-        i = i + 1
-        grass.raster.mapcalc("test" + str(i) + " = sin(x()) + cos(y())", overwrite = True)
-        name = "test" + str(i)
-        ident = name + "@" + mapset
-        rds = raster_dataset(ident)
-        rds.load()
-        print "Is raster in db: ", rds.is_in_db()
-            rds.select()
-            rds.print_self()
-            rds.delete()
-            rds.reset(ident)
-            rds.load()
-        rds.set_absolute_time(start_time= datetime(year=2000, month=i, day=1), \
-                                end_time= datetime(year=2000, month=i + 1, day=1))
-        rds.insert()
-        # Register the map in the space time raster dataset
-        strds.register_map(rds)
-        # Print self info
-        #rds.print_self()
-    strds.update_from_registered_maps()
-    strds.select()
-    # Print self info
-    strds.print_self()
-    # Delete the dataset
-    strds.delete()
-def test_str3ds_dataset():
-    name = "str3ds_test_1"
-    print "Create a str3ds object"
-    str3ds = space_time_raster3d_dataset(ident = name + "@" + mapset)
-    # Check if in db
-    print "Is str3ds in db: ", str3ds.is_in_db()
-    if str3ds.is_in_db() == False:
-        str3ds.set_initial_values(temporal_type = "absolute", granularity="1 day",\
-        semantic_type="event", title="This is a test space time raster3d dataset", description="A space time raster3d dataset for testing")
-        str3ds.insert()
-    str3ds.select()
-    # Print self info
-    #str3ds.print_self()
-        i = i + 1
-        grass.raster3d.mapcalc3d("test" + str(i) + " = sin(x()) + cos(y()) + z()", overwrite = True)
-        print "Create a raster3d object"
-        r3ds = raster3d_dataset(ident)
-        # Load data from the raster3d map in the mapset
-        r3ds.load()
-        print "Is raster3d in db: ", r3ds.is_in_db()
-            r3ds.select()
-            r3ds.print_self()
-            r3ds.delete()
-            r3ds.reset(ident)
-            r3ds.load()
-        r3ds.set_absolute_time(start_time= datetime(year=2000, month=i, day=1), \
-        r3ds.insert()
-        # Register the map in the space time raster3d dataset
-        str3ds.register_map(r3ds)
-        # Print self info
-        #r3ds.print_self()
-    str3ds.update_from_registered_maps()
-    str3ds.select()
-    # Print self info
-    str3ds.print_self()
-    str3ds.delete()
-def test_stvds_dataset():
-    name = "stvds_test_1"
-    print "Create a stvds object"
-    stvds = space_time_vector_dataset(ident = name + "@" + mapset)
-    # Check if in db
-    print "Is stvds in db: ", stvds.is_in_db()
-    if stvds.is_in_db() == False:
-        stvds.set_initial_values(temporal_type = "absolute", granularity="1 day",\
-        semantic_type="event", title="This is a test space time vector dataset", description="A space time vector dataset for testing")
-        stvds.insert()
-    stvds.select()
-    # Print self info
-    #stvds.print_self()
-        i = i + 1
-        grass.run_command("v.random", output=name, n=100, zmin=0, zmax=100, column="height" ,flags="z" , overwrite = True)
-        vds = vector_dataset(ident)
-        vds.load()
-        print "Is vector in db: ", vds.is_in_db()
-            vds.select()
-            vds.print_self()
-            vds.delete()
-            vds.reset(ident)
-            vds.load()
-        vds.set_absolute_time(start_time= datetime(year=2000, month=i, day=1), \
-        vds.insert()
-        stvds.register_map(vds)
-        # Print self info
-        #vds.print_self()
-    stvds.update_from_registered_maps()
-    stvds.select()
-    # Print self info
-    stvds.print_self()
-    stvds.delete()
-test_dict_sql_serializer()
-create_temporal_database()
-#test_dataset_identifer()
-#test_absolute_timestamp()
-#test_relative_timestamp()
-#test_spatial_extent()
-#test_map_metadata()
-#test_base_absolute_time_extent_metadata()
-#test_absolut_time_temporal_relations()
-test_raster_dataset()
-test_raster3d_dataset()
-test_vector_dataset()
-test_strds_dataset()
-test_str3ds_dataset()
-test_stvds_dataset()
-test_increment_datetime_by_string()
Deleted: grass/trunk/lib/temporal/update_stds_spatial_temporal_extent_template.sql
--- grass/trunk/lib/temporal/update_stds_spatial_temporal_extent_template.sql	2012-01-18 22:33:23 UTC (rev 50283)
+++ grass/trunk/lib/temporal/update_stds_spatial_temporal_extent_template.sql	2012-01-19 00:11:22 UTC (rev 50284)
@@ -1,66 +0,0 @@
--- This SQL script is to update the spatial and temporal extent as well as
--- the modifcation time and revision of a space time dataset. This script
--- should be called when maps inserted or deleted in a space time dataset.
--- Number of registered maps
-UPDATE STDS_metadata SET number_of_maps =
--- Update the temporal extent
-UPDATE STDS_absolute_time SET start_time =
-UPDATE STDS_absolute_time SET end_time =
-UPDATE STDS_relative_time SET start_time =
-UPDATE STDS_relative_time SET end_time =
--- Update the spatial extent
-UPDATE STDS_spatial_extent SET north =
-UPDATE STDS_spatial_extent SET south =
-UPDATE STDS_spatial_extent SET east =
-UPDATE STDS_spatial_extent SET west =
-UPDATE STDS_spatial_extent SET top =
-UPDATE STDS_spatial_extent SET bottom =
-UPDATE STDS_spatial_extent SET proj =
Deleted: grass/trunk/lib/temporal/update_str3ds_metadata_template.sql
--- grass/trunk/lib/temporal/update_str3ds_metadata_template.sql	2012-01-18 22:33:23 UTC (rev 50283)
+++ grass/trunk/lib/temporal/update_str3ds_metadata_template.sql	2012-01-19 00:11:22 UTC (rev 50284)
@@ -1,51 +0,0 @@
--- This SQL script is to update a space-time raster3d dataset metadata
--- Update the min and max values
-UPDATE str3ds_metadata SET min_min =
-UPDATE str3ds_metadata SET min_max =
-UPDATE str3ds_metadata SET max_min =
-UPDATE str3ds_metadata SET max_max =
--- Update the resolution
-UPDATE str3ds_metadata SET nsres_min =
-UPDATE str3ds_metadata SET nsres_max =
-UPDATE str3ds_metadata SET ewres_min =
-UPDATE str3ds_metadata SET ewres_max =
-UPDATE str3ds_metadata SET tbres_min =
-UPDATE str3ds_metadata SET tbres_max =
Deleted: grass/trunk/lib/temporal/update_strds_metadata_template.sql
--- grass/trunk/lib/temporal/update_strds_metadata_template.sql	2012-01-18 22:33:23 UTC (rev 50283)
+++ grass/trunk/lib/temporal/update_strds_metadata_template.sql	2012-01-19 00:11:22 UTC (rev 50284)
@@ -1,43 +0,0 @@
--- This SQL is to update a space-time raster dataset metadata
-UPDATE strds_metadata SET min_min =
-UPDATE strds_metadata SET min_max =
-UPDATE strds_metadata SET max_min =
-UPDATE strds_metadata SET max_max =
-UPDATE strds_metadata SET nsres_min =
-UPDATE strds_metadata SET nsres_max =
-UPDATE strds_metadata SET ewres_min =
-UPDATE strds_metadata SET ewres_max =
Deleted: grass/trunk/lib/temporal/update_stvds_metadata_template.sql
--- grass/trunk/lib/temporal/update_stvds_metadata_template.sql	2012-01-18 22:33:23 UTC (rev 50283)
+++ grass/trunk/lib/temporal/update_stvds_metadata_template.sql	2012-01-19 00:11:22 UTC (rev 50284)
@@ -1,6 +0,0 @@
\ No newline at end of file
Deleted: grass/trunk/lib/temporal/vector_metadata_table.sql
--- grass/trunk/lib/temporal/vector_metadata_table.sql	2012-01-18 22:33:23 UTC (rev 50283)
+++ grass/trunk/lib/temporal/vector_metadata_table.sql	2012-01-19 00:11:22 UTC (rev 50284)
@@ -1,55 +0,0 @@
--- This SQL script generates the vector table to store
--- metadata for SQL queries and temporal GIS support.
-CREATE TABLE  vector_metadata (
-  stvds_register VARCHAR, -- The name of the table storing all space-time vector datasets in which this map is registered
-  PRIMARY KEY (id),
-  FOREIGN KEY (id) REFERENCES  vector_base (id) ON DELETE CASCADE
--- Create the views to access all columns for the absolute and relative time
-CREATE VIEW vector_view_abs_time AS SELECT
-            A1.id, A1.mapset,
-            A1.creation_time,
-            A1.creator,
-	    A4.stvds_register
-	    FROM vector_base A1, vector_absolute_time A2,
-            vector_spatial_extent A3, vector_metadata A4
-CREATE VIEW vector_view_rel_time AS SELECT
-            A1.id, A1.mapset,
-            A1.creation_time,
-            A1.creator,
-	    A4.stvds_register
-	    FROM vector_base A1, vector_relative_time A2,
---CREATE TRIGGER update_vector_metadata AFTER UPDATE ON vector_metadata
---  BEGIN
---    UPDATE vector_base SET modification_time = datetime("NOW") WHERE id = old.id;
---    UPDATE vector_base SET revision = (revision + 1) WHERE id = old.id;
---  END;
