[GRASS-SVN] r50294 - in grass/trunk: include/defs include/vect lib/vector/Vlib lib/vector/diglib
Thu Jan 19 08:43:46 EST 2012
Author: martinl
Date: 2012-01-19 05:43:46 -0800 (Thu, 19 Jan 2012)
New Revision: 50294
   grass/trunk/include/defs/vector.h
   grass/trunk/include/vect/dig_structs.h
   grass/trunk/lib/vector/Vlib/build.c
   grass/trunk/lib/vector/Vlib/level_two.c
   grass/trunk/lib/vector/Vlib/open.c
   grass/trunk/lib/vector/Vlib/read.c
   grass/trunk/lib/vector/Vlib/write.c
   grass/trunk/lib/vector/Vlib/write_nat.c
   grass/trunk/lib/vector/Vlib/write_ogr.c
   grass/trunk/lib/vector/diglib/plus_area.c
   grass/trunk/lib/vector/diglib/plus_line.c
   grass/trunk/lib/vector/diglib/update.c
vlib: allow to optionally maintain list of updated lines/nodes
Modified: grass/trunk/include/defs/vector.h
--- grass/trunk/include/defs/vector.h	2012-01-19 12:11:50 UTC (rev 50293)
+++ grass/trunk/include/defs/vector.h	2012-01-19 13:43:46 UTC (rev 50294)
@@ -282,8 +282,11 @@
 /* Level 2 update only */
 int Vect_get_num_updated_lines(const struct Map_info *);
 int Vect_get_updated_line(const struct Map_info *, int);
+off_t Vect_get_updated_line_offset(const struct Map_info *, int);
 int Vect_get_num_updated_nodes(const struct Map_info *);
 int Vect_get_updated_node(const struct Map_info *, int);
+void Vect_set_updated(struct Map_info *, int);
+void Vect_reset_updated(struct Map_info *);
 /* History */
 int Vect_hist_command(struct Map_info *);
Modified: grass/trunk/include/vect/dig_structs.h
--- grass/trunk/include/vect/dig_structs.h	2012-01-19 12:11:50 UTC (rev 50293)
+++ grass/trunk/include/vect/dig_structs.h	2012-01-19 13:43:46 UTC (rev 50294)
@@ -1008,39 +1008,52 @@
     /*** level 2 ***/
-      \brief Used internaly in diglib to know if list is maintained
+      \brief List of updated lines/nodes
+      Note: Vect_set_updated() must be called to maintain this list
-    int do_uplist;
+    struct {
+	  \brief Used internaly in diglib to know if list is maintained
+	int do_uplist;
+	  \brief Array of updated lines
+	  List of lines and nodes updated (topo info for the line was
+	  changed) by last write/rewrite/delete operation.
+	  Lines/nodes in the list may be deleted (e.g. delete
+	  boundary: first added for delete area and then delete
+	int *uplines;
+	  \brief Array of updated lines - offset
-      \brief Array of updated lines
-      List of lines and nodes updated (topo info for the line was
-      changed) by last write/rewrite/delete operation.  Lines/nodes in
-      the list may be deleted (e.g. delete boundary: first added for
-      delete area and then delete
-    int *uplines;
-      \brief Allocated array (level 2)
-    int alloc_uplines;
-      \brief Number of updated lines (level 2)
-    int n_uplines;
-      \brief Array of updated nodes (level 2)
-    int *upnodes;
-    int alloc_upnodes;
-      \brief number of updated nodes (level 2)
-    int n_upnodes;
+	  Negative value for dead (deleted) lines - used by Vect_restore_line()
+	off_t *uplines_offset;
+	  \brief Allocated array of lines
+	int alloc_uplines;
+	  \brief Number of updated lines
+	int n_uplines;
+	  \brief Array of updated nodes
+	int *upnodes;
+	  \brief Allocated array of nodes
+	int alloc_upnodes;
+	  \brief number of updated nodes
+	int n_upnodes;
+    } uplist;
 /*! \brief
Modified: grass/trunk/lib/vector/Vlib/build.c
--- grass/trunk/lib/vector/Vlib/build.c	2012-01-19 12:11:50 UTC (rev 50293)
+++ grass/trunk/lib/vector/Vlib/build.c	2012-01-19 13:43:46 UTC (rev 50294)
@@ -455,7 +455,7 @@
 		Area->centroid = centr;
 		topo->area = sel_area;
-		if (sel_area != orig_area && plus->do_uplist)
+		if (sel_area != orig_area && plus->uplist.do_uplist)
 		    dig_line_add_updated(plus, centr);
 	    else if (Area->centroid != centr) {	/* duplicate centroid */
@@ -464,7 +464,7 @@
 		G_debug(3, "\tduplicate centroid -> do not attach to area");
 		topo->area = -sel_area;
-		if (-sel_area != orig_area && plus->do_uplist)
+		if (-sel_area != orig_area && plus->uplist.do_uplist)
Modified: grass/trunk/lib/vector/Vlib/level_two.c
--- grass/trunk/lib/vector/Vlib/level_two.c	2012-01-19 12:11:50 UTC (rev 50293)
+++ grass/trunk/lib/vector/Vlib/level_two.c	2012-01-19 13:43:46 UTC (rev 50294)
@@ -3,23 +3,31 @@
    \brief Vector library - topology level functions
-   (C) 2001-2009, 2011 by the GRASS Development Team
+   (C) 2001-2009, 2011-2012 by the GRASS Development Team
    This program is free software under the GNU General Public License
-   (>=v2).  Read the file COPYING that comes with GRASS for details.
+   (>=v2). Read the file COPYING that comes with GRASS for details.
    \author Original author CERL, probably Dave Gerdes or Mike Higgins.
    \author Update to GRASS 5.7 Radim Blazek and David D. Gray.
+   \author Update to GRASS 7 by Martin Landa <landa.martin gmail.com>
 #include <stdlib.h>
 #include <grass/vector.h>
 #include <grass/glocale.h>
+static void check_level(const struct Map_info *Map)
+    if (Map->level < 2)
+	G_fatal_error(_("Vector map <%s> is not open at topological level"),
+		      Vect_get_full_name(Map));
    \brief Get number of nodes in vector map
-   \param Map vector map
+   \param Map pointer to Map_info struct
    \return number of nodes
@@ -31,7 +39,7 @@
    \brief Get number of primitives in vector map
-   \param map vector map
+   \param map pointer to Map_info struct
    \patam type feature type
    \return number of primitives
@@ -59,7 +67,7 @@
    \brief Fetch number of features (points, lines, boundaries, centroids) in vector map
    \return number of features
@@ -71,7 +79,7 @@
    \brief Get number of areas in vector map
    \return number of areas
@@ -83,7 +91,7 @@
    \brief Fetch number of kernels in vector map
    \return number of kernels
@@ -96,7 +104,7 @@
    \brief Get number of faces in vector map
    \return number of faces
@@ -109,7 +117,7 @@
    \brief Fetch number of volumes in vector map
    \return number of volumes
@@ -122,7 +130,7 @@
    \brief Get number of islands in vector map
    \return number of islands
@@ -135,7 +143,7 @@
    \brief Fetch number of holes in vector map
    \return number of holes
@@ -148,7 +156,7 @@
    \brief Get number of defined dblinks
    \return number of dblinks
@@ -161,68 +169,90 @@
    \brief Get number of updated features
+   Note: Vect_set_updated() must be called to maintain list of updated
+   features
    \return number of updated features
 int Vect_get_num_updated_lines(const struct Map_info *Map)
-    return (Map->plus.n_uplines);
+    return (Map->plus.uplist.n_uplines);
    \brief Get updated line by index
+   features
    \param idx index
    \return updated line
 int Vect_get_updated_line(const struct Map_info *Map, int idx)
-    return (Map->plus.uplines[idx]);
+    return (Map->plus.uplist.uplines[idx]);
+   \brief Get updated line offset by index
+   features
+   \param idx index
+   \return updated line
+off_t Vect_get_updated_line_offset(const struct Map_info *Map, int idx)
+    return (Map->plus.uplist.uplines_offset[idx]);
    \brief Get number of updated nodes
    \return number of updated nodes
 int Vect_get_num_updated_nodes(const struct Map_info *Map)
-    return (Map->plus.n_upnodes);
+    return (Map->plus.uplist.n_upnodes);
    \brief Get updated node by index
+   features
    \param idx index
    \return updated node
 int Vect_get_updated_node(const struct Map_info *Map, int idx)
-    return (Map->plus.upnodes[idx]);
+    return (Map->plus.uplist.upnodes[idx]);
    \brief Get line type
    \param line line id
    \return line type
-int
-Vect_get_line_type(const struct Map_info *Map, int line)
+int Vect_get_line_type(const struct Map_info *Map, int line)
-    if (Map->level < 2)
-	G_fatal_error(_("Vector map <%s> is not open on level >= 2"),
-		      Vect_get_full_name(Map));
+    check_level(Map);
     if (!Vect_line_alive(Map, line))
 	return 0;
@@ -232,7 +262,7 @@
    \brief Get node coordinates
    \param num node id
    \param x,y,z coordinates values (for 2D coordinates z is NULL)
@@ -257,7 +287,7 @@
    \brief Get line nodes
    \param line line id
    \param n1, n2 ids of line nodes (or NULL)
@@ -267,9 +297,7 @@
     char type;
+    check_level(Map);
     type = Vect_get_line_type(Map, line);
@@ -299,7 +327,7 @@
    \brief Get area/isle ids on the left and right
    \param line line id
    \param[out] left,right area/isle id on the left and right
@@ -309,10 +337,8 @@
     struct P_topo_b *topo;
+    check_level(Map);
     if (!Map->plus.Line[line]->topo)
 	G_fatal_error(_("Areas not available for line %d"), line);
@@ -332,18 +358,15 @@
    \brief Get number of lines for node
    \param node node id
    \return numbers of lines
 int Vect_get_node_n_lines(const struct Map_info *Map, int node)
+    check_level(Map);
     return (Map->plus.Node[node]->n_lines);
@@ -351,7 +374,7 @@
    \brief Get line id for node line index
    \param node node id
    \param line line index (range: 0 - Vect_get_node_n_lines())
@@ -359,17 +382,15 @@
 int Vect_get_node_line(const struct Map_info *Map, int node, int line)
+    check_level(Map);
     return (Map->plus.Node[node]->lines[line]);
    \brief Angle of segment of the line connected to the node
    \param node node number
@@ -377,9 +398,7 @@
 float Vect_get_node_line_angle(const struct Map_info *Map, int node, int line)
+    check_level(Map);
     return (Map->plus.Node[node]->angles[line]);
@@ -387,7 +406,7 @@
    \brief Get area id the centroid is within
    \param centroid centroid id
    \return area id the centroid is within
@@ -398,10 +417,8 @@
     struct P_topo_c *topo;
+    check_level(Map);
     if (Map->plus.Line[centroid]->type != GV_CENTROID)
 	return 0;
@@ -411,3 +428,34 @@
     return (topo->area);
+  \brief Enable/disable maintanance of list of updated lines/nodes
+  See Plus_head.uplist for details.
+  \param enable TRUE/FALSE to enable/disable
+void Vect_set_updated(struct Map_info *Map, int enable)
+    check_level(Map);
+    Map->plus.uplist.do_uplist = enable != 0 ? TRUE : FALSE;
+  \brief Reset list of updated lines/nodes
+void Vect_reset_updated(struct Map_info *Map)
+    struct Plus_head *Plus;
+    check_level(Map);
+    Plus = &(Map->plus);
+    dig_line_reset_updated(Plus);
+    dig_node_reset_updated(Plus);
Modified: grass/trunk/lib/vector/Vlib/open.c
--- grass/trunk/lib/vector/Vlib/open.c	2012-01-19 12:11:50 UTC (rev 50293)
+++ grass/trunk/lib/vector/Vlib/open.c	2012-01-19 13:43:46 UTC (rev 50294)
@@ -5,7 +5,7 @@
  * Higher level functions for reading/writing/manipulating vectors.
- * (C) 2001-2009 by the GRASS Development Team
+ * (C) 2001-2009, 2012 by the GRASS Development Team
  * This program is free software under the GNU General Public License
  * (>=v2).  Read the file COPYING that comes with GRASS for details.
@@ -120,8 +120,6 @@
  * \brief Open existing vector map for reading (internal use only)
- * In case of error, the functions respect fatal error settings.
  * \param[out] Map pointer to Map_info structure
  * \param name name of vector map to open
  * \param mapset mapset name ("" for search path)
@@ -412,7 +410,7 @@
 	Map->plus.built = GV_BUILD_ALL;	/* highest level of topology for level 2 */
-    Map->plus.do_uplist = 0;
+    Map->plus.uplist.do_uplist = FALSE;
     /* read db links */
     Map->dblnk = Vect_new_dblinks_struct();
@@ -476,8 +474,6 @@
  * This function is replaced by Vect_open_old2() to handle also direct
  * OGR support.
@@ -493,8 +489,6 @@
  * \brief Open existing vector map for reading (native and OGR format)
@@ -515,7 +509,8 @@
  * This function is replaced by Vect_open_update2() to handle also
  * direct OGR support.
+ * By default list of updated features is not maintained, see
+ * Vect_set_updated() for details.
  * \param name name of vector map to update
@@ -526,32 +521,15 @@
 int Vect_open_update(struct Map_info *Map, const char *name, const char *mapset)
-    int ret;
-    ret = Vect__open_old(Map, name, mapset, NULL, 1, 0);
-    /* the update lists are unused, a waste of time and memory */
-    if (ret > 0) {
-	Map->plus.do_uplist = 1;
-	Map->plus.uplines = NULL;
-	Map->plus.n_uplines = 0;
-	Map->plus.alloc_uplines = 0;
-	Map->plus.upnodes = NULL;
-	Map->plus.n_upnodes = 0;
-	Map->plus.alloc_upnodes = 0;
-    return ret;
+    return Vect__open_old(Map, name, mapset, NULL, 1, 0);
  * \brief Open existing vector map for reading/writing (native or OGR
  * format)
@@ -563,11 +541,7 @@
 int Vect_open_update2(struct Map_info *Map, const char *name, const char *mapset, const char *layer)
-    int ret;
-    ret = Vect__open_old(Map, name, mapset, layer, 1, 0);
-    return ret;
+    return Vect__open_old(Map, name, mapset, layer, 1, 0);
@@ -578,8 +552,6 @@
  * This function is replaced by Vect_open_old_head2() to handle also
  * \param name name of vector map to read (dsn for OGR)
@@ -596,8 +568,6 @@
  * \brief Reads only info about vector map from headers of 'head',
  * 'dbln', 'topo' and 'cidx' file (native or OGR format)
@@ -615,8 +585,6 @@
  * \brief Open header file of existing vector map for updating (mostly
  * for database link updates)
@@ -630,27 +598,16 @@
     int ret;
     ret = Vect__open_old(Map, name, mapset, NULL, 1, 1);
-    if (ret > 0) {
     return ret;
  * \brief Create new vector map for reading/writing
  * \param[in,out] Map pointer to Map_info structure
  * \param with_z non-zero value for 3D vector data
@@ -769,7 +726,7 @@
     Map->support_updated = 0;
     Map->plus.built = GV_BUILD_NONE;
     Map->mode = GV_MODE_RW;
     Vect_set_proj(Map, G_projection());
     Vect_set_zone(Map, G_zone());
Modified: grass/trunk/lib/vector/Vlib/read.c
--- grass/trunk/lib/vector/Vlib/read.c	2012-01-19 12:11:50 UTC (rev 50293)
+++ grass/trunk/lib/vector/Vlib/read.c	2012-01-19 13:43:46 UTC (rev 50294)
@@ -215,7 +215,7 @@
   \return feature offset
   \return -1 on error
-off_t Vect_get_line_offset(const const struct Map_info *Map, int line)
+off_t Vect_get_line_offset(const struct Map_info *Map, int line)
     if (line < 1 || line > Map->plus.n_lines)
 	return -1;
Modified: grass/trunk/lib/vector/Vlib/write.c
--- grass/trunk/lib/vector/Vlib/write.c	2012-01-19 12:11:50 UTC (rev 50293)
+++ grass/trunk/lib/vector/Vlib/write.c	2012-01-19 13:43:46 UTC (rev 50294)
@@ -149,8 +149,6 @@
     if (!VECT_OPEN(Map))
 	G_fatal_error(_("Unable to write feature, vector map is not opened"));
-    dig_line_reset_updated(&(Map->plus));
-    dig_node_reset_updated(&(Map->plus));
     if (!(Map->plus.update_cidx)) {
 	Map->plus.cidx_up_to_date = 0;
@@ -195,8 +193,6 @@
 	G_fatal_error(_("Unable to rewrite feature, vector map is not opened"));
@@ -244,8 +240,6 @@
 		      line, Map->name);
@@ -290,8 +284,6 @@
 		      line, Map->name);
Modified: grass/trunk/lib/vector/Vlib/write_nat.c
--- grass/trunk/lib/vector/Vlib/write_nat.c	2012-01-19 12:11:50 UTC (rev 50293)
+++ grass/trunk/lib/vector/Vlib/write_nat.c	2012-01-19 13:43:46 UTC (rev 50294)
@@ -375,8 +375,8 @@
     V2__add_line_to_topo_nat(Map, line, points, cats);
-    G_debug(3, "updated lines : %d , updated nodes : %d", plus->n_uplines,
-	    plus->n_upnodes);
+    G_debug(3, "updated lines : %d , updated nodes : %d", plus->uplist.n_uplines,
+	    plus->uplist.n_upnodes);
     /* returns int line, but is defined as off_t for compatibility with
      * Vect_write_line_array in write.c */
@@ -496,8 +496,8 @@
-	    plus->n_upnodes);
      * Vect_rewrite_line_array in write.c */
@@ -690,7 +690,6 @@
     /* Update category index */
     if (plus->update_cidx) {
 	for (i = 0; i < Cats->n_cats; i++) {
 	    dig_cidx_del_cat(plus, Cats->field[i], Cats->cat[i], line, type);
@@ -848,8 +847,9 @@
-	    plus->n_upnodes);
     return ret;
@@ -968,8 +968,8 @@
-	    plus->n_upnodes);
     return ret;
Modified: grass/trunk/lib/vector/Vlib/write_ogr.c
--- grass/trunk/lib/vector/Vlib/write_ogr.c	2012-01-19 12:11:50 UTC (rev 50293)
+++ grass/trunk/lib/vector/Vlib/write_ogr.c	2012-01-19 13:43:46 UTC (rev 50294)
@@ -341,8 +341,8 @@
-	    plus->n_upnodes);
      * Write_line_array in write.c */
Modified: grass/trunk/lib/vector/diglib/plus_area.c
--- grass/trunk/lib/vector/diglib/plus_area.c	2012-01-19 12:11:50 UTC (rev 50293)
+++ grass/trunk/lib/vector/diglib/plus_area.c	2012-01-19 13:43:46 UTC (rev 50294)
@@ -209,7 +209,7 @@
 	Area->lines[i] = line;
 	Line = plus->Line[abs(line)];
 	topo = (struct P_topo_b *)Line->topo;
-	if (plus->do_uplist)
+	if (plus->uplist.do_uplist)
 	    dig_line_add_updated(plus, abs(line));
 	if (line < 0) {		/* revers direction -> area on left */
 	    if (topo->left != 0) {
@@ -368,7 +368,7 @@
 	line = Area->lines[i];	/* >0 = clockwise -> right, <0 = counterclockwise ->left */
 	btopo = (struct P_topo_b *)Line->topo;
 	if (line > 0) {
 	    G_debug(3, "  Set line %d right side to 0", line);
@@ -403,7 +403,7 @@
 	else {
 	    ctopo = (struct P_topo_c *)Line->topo;
 	    ctopo->area = 0;
 		dig_line_add_updated(plus, line);
@@ -687,7 +687,7 @@
 	Isle->lines[i] = line;
 	if (line < 0) {		/* revers direction -> isle on left */
@@ -747,7 +747,7 @@
 	line = Isle->lines[i];	/* >0 = clockwise -> right, <0 = counterclockwise ->left */
 	if (line > 0)
 	    topo->right = 0;
Modified: grass/trunk/lib/vector/diglib/plus_line.c
--- grass/trunk/lib/vector/diglib/plus_line.c	2012-01-19 12:11:50 UTC (rev 50293)
+++ grass/trunk/lib/vector/diglib/plus_line.c	2012-01-19 13:43:46 UTC (rev 50294)
@@ -31,9 +31,11 @@
     line->offset = offset;
     dig_spidx_add_line(plus, lineid, box);
+    if (plus->uplist.do_uplist) {
 	dig_line_add_updated(plus, lineid);
+	plus->uplist.uplines_offset[plus->uplist.n_uplines - 1] = line->offset;
     if (type & GV_POINT) {
 	line->topo = NULL;
 	return (lineid);
@@ -77,7 +79,7 @@
     dig_node_add_line(plus, node, lineid, Points, type);
 	dig_node_add_updated(plus, node);
     lp = Points->n_points - 1;
@@ -105,7 +107,7 @@
     dig_node_add_line(plus, node, -lineid, Points, type);
     return (lineid);
@@ -216,6 +218,11 @@
     Line = plus->Line[line];
     dig_spidx_del_line(plus, line, x, y, z);
+	dig_line_add_updated(plus, line);
+	plus->uplist.uplines_offset[plus->uplist.n_uplines - 1] = -1 * Line->offset;
     if (!(Line->type & GV_LINES)) {
 	/* Delete line */
 	dig_free_line(Line);
@@ -252,7 +259,6 @@
     Node->n_lines--;
     if (Node->n_lines == 0) {
 	G_debug(3, "    node %d has 0 lines -> delete", N1);
 	dig_spidx_del_node(plus, N1);
 	/* free structures */
@@ -260,7 +266,7 @@
 	plus->Node[N1] = NULL;
     else {
 	    dig_node_add_updated(plus, N1);
@@ -296,7 +302,7 @@
 	plus->Node[N2] = NULL;
     else {
 	    dig_node_add_updated(plus, N2);
Modified: grass/trunk/lib/vector/diglib/update.c
--- grass/trunk/lib/vector/diglib/update.c	2012-01-19 12:11:50 UTC (rev 50293)
+++ grass/trunk/lib/vector/diglib/update.c	2012-01-19 13:43:46 UTC (rev 50294)
@@ -24,7 +24,7 @@
 void dig_line_reset_updated(struct Plus_head *Plus)
-    Plus->n_uplines = 0;
+    Plus->uplist.n_uplines = 0;
@@ -39,21 +39,24 @@
     G_debug(3, "dig_line_add_updated(): line = %d", line);
-    /* Check if already in list */
-    for (i = 0; i < Plus->n_uplines; i++)
-	if (Plus->uplines[i] == line)
+    /* Check if already in list
+    for (i = 0; i < Plus->uplist.n_uplines; i++)
+	if (Plus->uplist.uplines[i] == line)
 	    return;
     /* Alloc space if needed */
-    if (Plus->n_uplines == Plus->alloc_uplines) {
-	Plus->alloc_uplines += 1000;
-	Plus->uplines =
-	    (int *)G_realloc(Plus->uplines,
-			     Plus->alloc_uplines * sizeof(int));
+    if (Plus->uplist.n_uplines == Plus->uplist.alloc_uplines) {
+	Plus->uplist.alloc_uplines += 1000;
+	Plus->uplist.uplines =
+	    (int *)G_realloc(Plus->uplist.uplines,
+			     Plus->uplist.alloc_uplines * sizeof(int));
+	Plus->uplist.uplines_offset =
+	    (off_t *)G_realloc(Plus->uplist.uplines_offset,
+			     Plus->uplist.alloc_uplines * sizeof(off_t));
-    Plus->uplines[Plus->n_uplines] = line;
-    Plus->n_uplines++;
+    Plus->uplist.uplines[Plus->uplist.n_uplines] = line;
+    Plus->uplist.n_uplines++;
@@ -63,7 +66,7 @@
 void dig_node_reset_updated(struct Plus_head *Plus)
-    Plus->n_upnodes = 0;
+    Plus->uplist.n_upnodes = 0;
@@ -79,18 +82,18 @@
     G_debug(3, "dig_node_add_updated(): node = %d", node);
-    for (i = 0; i < Plus->n_upnodes; i++)
-	if (Plus->upnodes[i] == node)
+    for (i = 0; i < Plus->uplist.n_upnodes; i++)
+	if (Plus->uplist.upnodes[i] == node)
 	    return;
-    if (Plus->n_upnodes == Plus->alloc_upnodes) {
-	Plus->alloc_upnodes += 1000;
-	Plus->upnodes =
-	    (int *)G_realloc(Plus->upnodes,
-			     Plus->alloc_upnodes * sizeof(int));
+    if (Plus->uplist.n_upnodes == Plus->uplist.alloc_upnodes) {
+	Plus->uplist.alloc_upnodes += 1000;
+	Plus->uplist.upnodes =
+	    (int *)G_realloc(Plus->uplist.upnodes,
+			     Plus->uplist.alloc_upnodes * sizeof(int));
-    Plus->upnodes[Plus->n_upnodes] = node;
-    Plus->n_upnodes++;
+    Plus->uplist.upnodes[Plus->uplist.n_upnodes] = node;
+    Plus->uplist.n_upnodes++;
