[GRASS-SVN] r50299 - grass/trunk/gui/wxpython/vdigit
svn_grass at osgeo.org
Thu Jan 19 09:57:58 EST 2012
Author: martinl
Date: 2012-01-19 06:57:57 -0800 (Thu, 19 Jan 2012)
New Revision: 50299
grass/trunk/gui/wxpython/vdigit/mapwindow.py
grass/trunk/gui/wxpython/vdigit/toolbars.py
grass/trunk/gui/wxpython/vdigit/wxdigit.py
grass/trunk/gui/wxpython/vdigit/wxdisplay.py
wxGUI/vdigit: add new tool for deleting areas
major improvents in undo
Modified: grass/trunk/gui/wxpython/vdigit/mapwindow.py
--- grass/trunk/gui/wxpython/vdigit/mapwindow.py 2012-01-19 14:51:06 UTC (rev 50298)
+++ grass/trunk/gui/wxpython/vdigit/mapwindow.py 2012-01-19 14:57:57 UTC (rev 50299)
@@ -458,12 +458,12 @@
self.UpdateMap(render = False, renderVector = False)
- elif action in ["deleteLine", "moveLine", "splitLine",
+ elif action in ["deleteLine", "deleteArea", "moveLine", "splitLine",
"addVertex", "removeVertex", "moveVertex",
"copyCats", "flipLine", "mergeLine",
"snapLine", "connectLine", "copyLine",
"queryLine", "breakLine", "typeConv"]:
- # varios tools -> unselected selected features
+ # various tools -> unselected selected features
self.digit.GetDisplay().SetSelected([])
if action in ["moveLine", "moveVertex", "editLine"] and \
hasattr(self, "moveInfo"):
@@ -789,6 +789,7 @@
action = self.toolbar.GetAction()
if action in ("deleteLine",
+ "deleteArea",
"moveLine",
"moveVertex",
"copyCats",
@@ -921,6 +922,11 @@
if self.digit.DeleteSelectedLines() < 0:
return
self._updateATM()
+ elif action == "deleteArea":
+ # -> delete selected vector areas
+ if self.digit.DeleteSelectedAreas() < 0:
+ return
+ self._updateATM()
elif action == "splitLine":
# split line
if self.digit.SplitLine(self.Pixel2Cell(self.mouse['begin'])) < 0:
Modified: grass/trunk/gui/wxpython/vdigit/toolbars.py
--- grass/trunk/gui/wxpython/vdigit/toolbars.py 2012-01-19 14:51:06 UTC (rev 50298)
+++ grass/trunk/gui/wxpython/vdigit/toolbars.py 2012-01-19 14:57:57 UTC (rev 50299)
@@ -105,6 +105,9 @@
'deleteLine' : MetaIcon(img = 'line-delete',
label = _('Delete feature(s)'),
desc = _('Left: Select; Ctrl+Left: Unselect; Right: Confirm')),
+ 'deleteArea' : MetaIcon(img = 'polygon-delete',
+ label = _('Delete area(s)'),
+ desc = _('Left: Select; Ctrl+Left: Unselect; Right: Confirm')),
'displayAttr' : MetaIcon(img = 'attributes-display',
label = _('Display/update attributes'),
desc = _('Left: Select')),
@@ -181,6 +184,10 @@
data.append(("deleteLine", icons["deleteLine"],
self.OnDeleteLine,
wx.ITEM_CHECK))
+ if not self.tools or 'deleteArea' in self.tools:
+ data.append(("deleteArea", icons["deleteArea"],
+ self.OnDeleteArea,
+ wx.ITEM_CHECK))
if not self.tools or 'displayCats' in self.tools:
data.append(("displayCats", icons["displayCats"],
self.OnDisplayCats,
@@ -352,6 +359,13 @@
'id' : self.deleteLine }
self.MapWindow.mouse['box'] = 'box'
+ def OnDeleteArea(self, event):
+ """!Delete Area"""
+ Debug.msg(2, "Digittoolbar.OnDeleteArea():")
+ self.action = { 'desc' : "deleteArea",
+ 'id' : self.deleteArea }
+ self.MapWindow.mouse['box'] = 'box'
def OnDisplayCats(self, event):
"""!Display/update categories"""
Debug.msg(2, "Digittoolbar.OnDisplayCats():")
Modified: grass/trunk/gui/wxpython/vdigit/wxdigit.py
--- grass/trunk/gui/wxpython/vdigit/wxdigit.py 2012-01-19 14:51:06 UTC (rev 50298)
+++ grass/trunk/gui/wxpython/vdigit/wxdigit.py 2012-01-19 14:57:57 UTC (rev 50299)
@@ -169,7 +169,7 @@
self.UpdateSettings() # -> self._settings
# undo/redo
- self.changesets = dict()
+ self.changesets = list()
self.changesetCurrent = -1 # first changeset to apply
self.changesetEnd = -1 # last changeset to be applied
@@ -264,13 +264,12 @@
return cat
- def _breakLineAtIntersection(self, line, pointsLine, changeset):
+ def _breakLineAtIntersection(self, line, pointsLine):
"""!Break given line at intersection
\param line line id
\param pointsLine line geometry
- \param changeset id
\return number of modified lines
if not self._checkMap():
@@ -315,22 +314,9 @@
WITHOUT_Z):
Vect_list_append(listBreak, lineBreak)
- nlines = Vect_get_num_lines(self.poMapInfo)
- for i in range(listBreak.contents.n_values):
- self._addActionToChangeset(changeset, listBreak.contents.value[i], add = False)
ret = Vect_break_lines_list(self.poMapInfo, listBreak, listRef,
GV_LINES, None)
- if Vect_line_alive(self.poMapInfo, listBreak.contents.value[i]):
- self._removeActionFromChangeset(changeset, listBreak.contents.value[i],
- add = False)
- for line in range(nlines + 1, Vect_get_num_lines(self.poMapInfo) + 1):
- self._addActionToChangeset(changeset, line, add = True)
Vect_destroy_line_struct(pointsCheck)
Vect_destroy_boxlist(listLine)
@@ -339,18 +325,19 @@
return ret
- def _addActionsBefore(self):
- """!Register action before operation
- @return changeset id
- changeset = len(self.changesets)
- for line in self._display.selected['ids']:
- if Vect_line_alive(self.poMapInfo, line):
- self._addActionToChangeset(changeset, line, add = False)
+ def _addChangeset(self):
+ data = list()
+ for i in range(Vect_get_num_updated_lines(self.poMapInfo) - 1, -1, -1):
+ line = Vect_get_updated_line(self.poMapInfo, i)
+ offset = Vect_get_updated_line_offset(self.poMapInfo, i)
+ data.append({ 'line' : line,
+ 'offset' : offset })
- return changeset
+ self.changesetCurrent += 1
+ self.changesets.insert(self.changesetCurrent, data)
+ Vect_reset_updated(self.poMapInfo)
def _applyChangeset(self, changeset, undo):
"""!Apply changeset (undo/redo changeset)
@@ -361,101 +348,48 @@
@return 0 changeset not applied
@return -1 on error
- if changeset < 0 or changeset > len(self.changesets.keys()):
+ if changeset < 0 or changeset >= len(self.changesets):
return -1
if self.changesetEnd < 0:
self.changesetEnd = changeset
ret = 0
actions = self.changesets[changeset]
for action in actions:
- add = action['add']
+ add = bool(action['offset'] > 0)
line = action['line']
if (undo and add) or \
(not undo and not add):
Debug.msg(3, "IVDigit._applyChangeset(): changeset=%d, action=add, line=%d -> deleted",
changeset, line)
Vect_delete_line(self.poMapInfo, line)
ret = 1
else:
Debug.msg(3, "Digit.ApplyChangeset(): changeset=%d, action=add, line=%d dead",
changeset, line)
else: # delete
- offset = action['offset']
+ offset = abs(action['offset'])
if not Vect_line_alive(self.poMapInfo, line):
Debug.msg(3, "Digit.ApplyChangeset(): changeset=%d, action=delete, line=%d -> added",
changeset, line)
if Vect_restore_line(self.poMapInfo, line, offset) < 0:
return -1
ret = 1
else:
Debug.msg(3, "Digit.ApplyChangeset(): changeset=%d, action=delete, line=%d alive",
changeset, line)
+ action['offset'] *= -1
return ret
- def _addActionsAfter(self, changeset, nlines):
- """!Register action after operation
- @param changeset changeset id
- @param nline number of lines
- self._removeActionFromChangeset(changeset, line, add = False)
- for line in range(nlines + 1, Vect_get_num_lines(self.poMapInfo)):
- def _addActionToChangeset(self, changeset, line, add):
- """!Add action to changeset
- @param changeset id of changeset
- @param line feature id
- @param add True to add, otherwise delete
- if not self._checkMap():
- return
- if not Vect_line_alive(self.poMapInfo, line):
- return
- offset = Vect_get_line_offset(self.poMapInfo, line)
- if changeset not in self.changesets:
- self.changesets[changeset] = list()
- self.changesetCurrent = changeset
- self.changesets[changeset].append({ 'add' : add,
- 'line' : line,
- 'offset' : offset })
- Debug.msg(3, "IVDigit._addActionToChangeset(): changeset=%d, add=%d, line=%d, offset=%d",
- changeset, add, line, offset)
- def _removeActionFromChangeset(self, changeset, line, add):
- """!Remove action from changeset
- @param line line id
- @param add True for add, False for delete
- @return number of actions in changeset
- @return -1 on error
- if changeset not in self.changesets.keys():
- return -1
- alist = self.changesets[changeset]
- for action in alist:
- if action['add'] == add and action['line'] == line:
- alist.remove(action)
- return len(alist)
def AddFeature(self, ftype, points):
"""!Add new feature
@@ -498,87 +432,106 @@
@return number of deleted features
- deleteRec = UserSettings.Get(group = 'vdigit', key = 'delRecord', subkey = 'enabled')
return -1
- n_dblinks = Vect_get_num_dblinks(self.poMapInfo)
- Cats_del = None
- # collect categories for delete if requested
+ # colect categories for delete if requested
+ deleteRec = UserSettings.Get(group = 'vdigit', key = 'delRecord', subkey = 'enabled')
+ catDict = dict()
if deleteRec:
- poCatsDel = Vect_new_cats_struct()
for i in self._display.selected['ids']:
if Vect_read_line(self.poMapInfo, None, self.poCats, i) < 0:
- Vect_destroy_cats_struct(poCatsDel)
self._error.ReadLine(i)
cats = self.poCats.contents
for j in range(cats.n_cats):
- Vect_cat_set(poCatsDel, cats.field[j], cats.cat[j])
+ if cats.field[j] not in catDict.keys():
+ catDict[cats.field[j]] = list()
+ catDict[cats.field[j]].append(cats.cat[j])
- # register changeset
- changeset = self._addActionsBefore()
poList = self._display.GetSelectedIList()
nlines = Vedit_delete_lines(self.poMapInfo, poList)
Vect_destroy_list(poList)
self._display.selected['ids'] = list()
- if nlines > 0 and deleteRec:
- handle = dbHandle()
- poHandle = pointer(handle)
- stmt = dbString()
- poStmt = pointer(stmt)
+ if nlines > 0:
+ if deleteRec:
+ self._deleteRecords(cats)
+ self._addChangeset()
+ self.toolbar.EnableUndo()
+ return nlines
- for dblink in range(n_dblinks):
- poFi = Vect_get_dblink(self.poMapInfo, dblink)
- if poFi is None:
- self._error.DbLink(dblink)
- return -1
- Fi = poFi.contents
- poDriver = db_start_driver(Fi.driver)
- if poDriver is None:
- self._error.Driver(Fi.driver)
- return -1
- db_init_handle(poHandle)
- db_set_handle(poHandle, Fi.database, None)
- if db_open_database(poDriver, poHandle) != DB_OK:
- self._error.Database(Fi.driver, Fi.database)
- return -1
- db_init_string(poStmt)
- db_set_string(poStmt, "DELETE FROM %s WHERE" % Fi.table)
- n_cats = 0;
- catsDel = poCatsDel.contents
- for c in range(catsDel.n_cats):
- if catsDel.field[c] == Fi.number:
- if n_cats > 0:
- db_append_string(poStmt, " or")
+ def _deleteRecords(self, cats):
+ """!Delete records from attribute table
+ @param cats directory field/list of cats
+ handle = dbHandle()
+ poHandle = pointer(handle)
+ stmt = dbString()
+ poStmt = pointer(stmt)
+ for dblink in range(Vect_get_num_dblinks(self.poMapInfo)):
+ poFi = Vect_get_dblink(self.poMapInfo, dblink)
+ if poFi is None:
+ self._error.DbLink(dblink)
+ return -1
+ Fi = poFi.contents
+ if Fi.table not in cats.keys():
+ continue
+ poDriver = db_start_driver(Fi.driver)
+ if poDriver is None:
+ self._error.Driver(Fi.driver)
+ return -1
+ db_init_handle(poHandle)
+ db_set_handle(poHandle, Fi.database, None)
+ if db_open_database(poDriver, poHandle) != DB_OK:
+ self._error.Database(Fi.driver, Fi.database)
+ return -1
+ db_init_string(poStmt)
+ db_set_string(poStmt, "DELETE FROM %s WHERE" % Fi.table)
+ n_cats = 0
+ for cat in cats[Fi.table]:
+ if n_cats > 0:
+ db_append_string(poStmt, " or")
- db_append_string(poStmt, " %s = %d" % (Fi.key, catsDel.cat[c]))
- n_cats += 1
+ db_append_string(poStmt, " %s = %d" % (Fi.key, cats))
+ n_cats += 1
- Vect_cat_del(poCatsDel, Fi.number)
- if n_cats and \
- db_execute_immediate(poDriver, poStmt) != DB_OK:
- self._error.DbExecute(db_get_string(poStmt))
- return -1
- db_close_database(poDriver)
- db_shutdown_driver(poDriver)
+ if n_cats > 0 and \
+ db_execute_immediate(poDriver, poStmt) != DB_OK:
+ self._error.DbExecute(db_get_string(poStmt))
+ return -1
+ db_close_shutdown_database(poDriver)
- if poCatsDel:
+ def DeleteSelectedAreas(self):
+ """!Delete selected areas (centroid+boundaries)
+ @return number of deleted
+ poList = self._display.GetSelectedIList()
+ cList = poList.contents
- if nlines > 0:
+ nareas = 0
+ for i in range(cList.n_values):
+ if Vect_get_line_type(self.poMapInfo, cList.value[i]) != GV_CENTROID:
+ continue
+ nareas += Vedit_delete_area_centroid(self.poMapInfo, cList.value[i])
+ if nareas > 0:
- return nlines
+ return nareas
def MoveSelectedLines(self, move):
"""!Move selected features
@@ -590,11 +543,6 @@
thresh = self._display.GetThreshold()
snap = self._getSnapMode()
nlines = Vedit_move_lines(self.poMapInfo, self.popoBgMapInfo, int(self.poBgMapInfo is not None),
poList,
@@ -602,16 +550,12 @@
snap, thresh)
- if nlines > 0:
- self._addActionsAfter(changeset, nlines)
- else:
- del self.changesets[changeset]
if nlines > 0 and self._settings['breakLines']:
for i in range(1, nlines):
self._breakLineAtIntersection(nlines + i, None, changeset)
if nlines > 0:
return nlines
@@ -635,10 +579,6 @@
Vect_reset_line(self.poPoints)
Vect_append_point(self.poPoints, point[0], point[1], 0.0)
# move only first found vertex in bbox
moved = Vedit_move_vertex(self.poMapInfo, self.popoBgMapInfo, int(self.poBgMapInfo is not None),
@@ -649,16 +589,12 @@
1, self._getSnapMode())
- if moved > 0:
- else:
if moved > 0 and self._settings['breakLines']:
self._breakLineAtIntersection(Vect_get_num_lines(self.poMapInfo),
- None, changeset)
+ None)
if moved > 0:
return moved
@@ -713,19 +649,13 @@
ret = Vedit_split_lines(self.poMapInfo, poList,
self.poPoints, thresh, None)
if ret > 0:
+ self.addChangeset()
- else:
return ret
@@ -767,21 +697,17 @@
Vedit_snap_line(self.poMapInfo, self.popoBgMapInfo,
-1, self.poPoints, self._display.GetThreshold(), modeSnap)
newline = Vect_rewrite_line(self.poMapInfo, line, ltype,
self.poPoints, self.poCats)
- if newline > 0:
- self.toolbar.EnableUndo()
- else:
if newline > 0 and self._settings['breakLines']:
- self._breakLineAtIntersection(newline, None, changeset)
+ self._breakLineAtIntersection(newline, None)
+ if newline > 0:
return newline
def FlipLine(self):
@@ -795,18 +721,13 @@
ret = Vedit_flip_lines(self.poMapInfo, poList)
if ret > 0:
- else:
return ret
@@ -819,20 +740,14 @@
return -1
ret = Vedit_merge_lines(self.poMapInfo, poList)
if ret > 0:
- else:
return ret
def BreakLine(self):
@@ -844,21 +759,15 @@
return -1
ret = Vect_break_lines_list(self.poMapInfo, poList, None,
GV_LINES, None)
if ret > 0:
- else:
return ret
def SnapLine(self):
@@ -871,19 +780,14 @@
return -1
Vect_snap_lines_list(self.poMapInfo, poList,
self._display.GetThreshold(), None)
if nlines < Vect_get_num_lines(self.poMapInfo):
- else:
def ConnectLine(self):
"""!Connect selected lines/boundaries
@@ -895,21 +799,14 @@
return -1
ret = Vedit_connect_lines(self.poMapInfo, poList,
self._display.GetThreshold())
if ret > 0:
- else:
return ret
@@ -931,18 +828,14 @@
poList)
- if ret > 0:
- for line in (range(nlines + 1, Vect_get_num_lines(self.poMapInfo))):
- else:
if ret > 0 and self.poBgMapInfo and self._settings['breakLines']:
for i in range(1, ret):
- self._breakLineAtIntersection(nlines + i, None, changeset)
+ self._breakLineAtIntersection(nlines + i, None)
+ if ret > 0:
return ret
def CopyCats(self, fromId, toId, copyAttrb = False):
@@ -1275,13 +1168,11 @@
else:
Vect_field_cat_del(self.poCats, layer, c)
if newline > 0:
if update:
@@ -1303,20 +1194,13 @@
return -1
ret = Vedit_chtype_lines(self.poMapInfo, poList)
if ret > 0:
- else:
return ret
@@ -1327,31 +1211,31 @@
@return id of current changeset
- changesetLast = len(self.changesets.keys()) - 1
+ changesetLast = len(self.changesets) - 1
if changesetLast < 0:
return changesetLast
if self.changesetCurrent == -2: # value uninitialized
self.changesetCurrent = changesetLast
if level > 0 and self.changesetCurrent < 0:
self.changesetCurrent = 0
if level == 0:
# 0 -> undo all
level = -1 * changesetLast + 1
Debug.msg(2, "Digit.Undo(): changeset_last=%d, changeset_current=%d, level=%d",
changesetLast, self.changesetCurrent, level)
if level < 0: # undo
if self.changesetCurrent + level < -1:
- return changesetCurrent;
+ return self.changesetCurrent
for changeset in range(self.changesetCurrent, self.changesetCurrent + level, -1):
self._applyChangeset(changeset, undo = True)
elif level > 0: # redo
- if self.changesetCurrent + level > len(self.changesets.keys()):
+ if self.changesetCurrent + level > len(self.changesets):
for changeset in range(self.changesetCurrent, self.changesetCurrent + level):
self._applyChangeset(changeset, undo = False)
@@ -1369,7 +1253,7 @@
if self.changesetCurrent < 0: # disable undo tool
self.toolbar.EnableUndo(False)
def ZBulkLines(self, pos1, pos2, start, step):
"""!Z-bulk labeling
@@ -1384,11 +1268,6 @@
return -1
ret = Vedit_bulk_labeling(self.poMapInfo, poList,
pos1[0], pos1[1], pos2[0], pos2[1],
@@ -1396,10 +1275,8 @@
if ret > 0:
- else:
return ret
@@ -1606,13 +1483,11 @@
Vect_destroy_line_struct(bpoints)
- self._addActionToChangeset(changeset, newline, add = True)
# break at intersection
if self._settings['breakLines']:
- self._breakLineAtIntersection(newline, self.poPoints, changeset)
+ self._breakLineAtIntersection(newline, self.poPoints)
return (len(fids), fids)
@@ -1639,11 +1514,8 @@
Vect_append_point(self.poPoints, coords[0], coords[1], 0.0)
thresh = self._display.GetThreshold(type = 'selectThresh')
if add:
ret = Vedit_add_vertex(self.poMapInfo, poList,
self.poPoints, thresh)
@@ -1652,14 +1524,12 @@
- if ret > 0:
- else:
if not add and ret > 0 and self._settings['breakLines']:
- None, changeset)
+ None)
+ if ret > 0:
return nlines + 1 # feature is write at the end of the file
Modified: grass/trunk/gui/wxpython/vdigit/wxdisplay.py
--- grass/trunk/gui/wxpython/vdigit/wxdisplay.py 2012-01-19 14:51:06 UTC (rev 50298)
+++ grass/trunk/gui/wxpython/vdigit/wxdisplay.py 2012-01-19 14:57:57 UTC (rev 50299)
@@ -871,6 +871,7 @@
# open existing map
if update:
ret = Vect_open_update(self.poMapInfo, name, mapset)
+ Vect_set_updated(self.poMapInfo, True) # track updated lines
else:
ret = Vect_open_old(self.poMapInfo, name, mapset)
self.is3D = Vect_is_3d(self.poMapInfo)
