[GRASS-SVN] r50315 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Fri Jan 20 06:56:17 EST 2012
Author: martinl
Date: 2012-01-20 03:56:17 -0800 (Fri, 20 Jan 2012)
New Revision: 50315
grass/trunk/lib/vector/Vlib/area.c
vlib: Vect_get_area_boundaries() - add note about negative ids
Modified: grass/trunk/lib/vector/Vlib/area.c
--- grass/trunk/lib/vector/Vlib/area.c 2012-01-20 11:51:15 UTC (rev 50314)
+++ grass/trunk/lib/vector/Vlib/area.c 2012-01-20 11:56:17 UTC (rev 50315)
@@ -5,10 +5,10 @@
Higher level functions for reading/writing/manipulating vectors.
- (C) 2001-2009, 2011 by the GRASS Development Team
+ (C) 2001-2009, 2011-2012 by the GRASS Development Team
This program is free software under the GNU General Public License
- (>=v2). Read the file COPYING that comes with GRASS for details.
+ (>=v2). Read the file COPYING that comes with GRASS for details.
\author Original author CERL, probably Dave Gerdes or Mike Higgins.
\author Update to GRASS 5.7 Radim Blazek and David D. Gray.
@@ -82,16 +82,15 @@
\brief Returns polygon array of points for given isle
- \param Map vector map
+ \param Map pointer to Map_info structure
\param isle island id
\param[out] BPoints points array
\return number of points
\return -1 on error
-int
-Vect_get_isle_points(const struct Map_info *Map,
- int isle, struct line_pnts *BPoints)
+int Vect_get_isle_points(const struct Map_info *Map,
+ int isle, struct line_pnts *BPoints)
int i, line, aline, dir;
const struct Plus_head *Plus;
@@ -139,7 +138,7 @@
\brief Returns centroid id for given area
\param area area id
\return centroid id of area
@@ -164,14 +163,17 @@
\brief Creates list of boundaries for given area
+ Note that ids in <b>List</b> can be negative. The sign indicates in
+ which direction the boundary should be read (negative for
+ backward).
\param area area id
\param[out] List pointer to list of boundaries
\return number of boundaries
-int
-Vect_get_area_boundaries(const struct Map_info *Map, int area, struct ilist *List)
+int Vect_get_area_boundaries(const struct Map_info *Map, int area, struct ilist *List)
int i, line;
@@ -198,14 +200,16 @@
\brief Creates list of boundaries for given isle
+ which direction the boundary should be read (negative for forward).
\param isle island number
\param[out] List pointer to list where boundaries are stored
-int
-Vect_get_isle_boundaries(const struct Map_info *Map, int isle, struct ilist *List)
+int Vect_get_isle_boundaries(const struct Map_info *Map, int isle, struct ilist *List)
int i, line;
@@ -232,7 +236,7 @@
\brief Returns number of isles for given area
\param area area id
\return number of isles for area
@@ -260,7 +264,7 @@
\brief Returns isle id for area
\param area area id
\param isle isle index (0 .. nisles - 1)
@@ -330,7 +334,7 @@
\brief Check if point is in area
\param x,y point coordinates
\param area area id
\param box area bounding box
@@ -370,7 +374,7 @@
\brief Returns area of area without areas of isles
\param area area id
\return area of area without areas of isles
@@ -414,7 +418,7 @@
\brief Get area categories
\param area area id
\param[out] Cats list of categories
@@ -442,7 +446,7 @@
\brief Find FIRST category of given field and area
\param area area id
\param field layer number
