[GRASS-SVN] r50333 - in grass/branches/releasebranch_6_4:
gui/wxpython/gui_modules locale/po
svn_grass at osgeo.org
Fri Jan 20 16:46:12 EST 2012
Author: neteler
Date: 2012-01-20 13:46:12 -0800 (Fri, 20 Jan 2012)
New Revision: 50333
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/dbm.py
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/render.py
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/vdigit.py
grass/branches/releasebranch_6_4/locale/po/grasswxpy_cs.po
grass/branches/releasebranch_6_4/locale/po/grasswxpy_de.po
grass/branches/releasebranch_6_4/locale/po/grasswxpy_el.po
grass/branches/releasebranch_6_4/locale/po/grasswxpy_es.po
grass/branches/releasebranch_6_4/locale/po/grasswxpy_fr.po
grass/branches/releasebranch_6_4/locale/po/grasswxpy_id.po
grass/branches/releasebranch_6_4/locale/po/grasswxpy_it.po
grass/branches/releasebranch_6_4/locale/po/grasswxpy_ja.po
grass/branches/releasebranch_6_4/locale/po/grasswxpy_ml.po
grass/branches/releasebranch_6_4/locale/po/grasswxpy_pl.po
grass/branches/releasebranch_6_4/locale/po/grasswxpy_pt.po
grass/branches/releasebranch_6_4/locale/po/grasswxpy_pt_br.po
grass/branches/releasebranch_6_4/locale/po/grasswxpy_ru.po
grass/branches/releasebranch_6_4/locale/po/grasswxpy_th.po
grass/branches/releasebranch_6_4/locale/po/grasswxpy_tr.po
grass/branches/releasebranch_6_4/locale/po/grasswxpy_vi.po
grass/branches/releasebranch_6_4/locale/po/grasswxpy_zh.po
typos discovered by Vincent Bain fixed
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/dbm.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/dbm.py 2012-01-20 19:14:58 UTC (rev 50332)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/dbm.py 2012-01-20 21:46:12 UTC (rev 50333)
@@ -1167,7 +1167,7 @@
if UserSettings.Get(group='atm', key='askOnDeleteRec', subkey='enabled'):
deleteDialog = wx.MessageBox(parent=self,
- message=_("Selected data records (%d) will permanently deleted "
+ message=_("Selected data records (%d) will be permanently deleted "
"from table. Do you want to delete them?") % \
(len(self.listOfSQLStatements)),
caption=_("Delete records"),
@@ -1213,7 +1213,7 @@
list = self.FindWindowById(self.layerPage[self.layer]['data'])
- message=_("All data records (%d) will permanently deleted "
+ message=_("All data records (%d) will be permanently deleted "
(len(list.itemIndexMap)),
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/render.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/render.py 2012-01-20 19:14:58 UTC (rev 50332)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/render.py 2012-01-20 21:46:12 UTC (rev 50333)
@@ -1177,7 +1177,7 @@
self.overlays.append(overlay)
if l_render and command != '' and not overlay.Render():
- raise gcmd.GException(_("Unable render overlay <%s>.") %
+ raise gcmd.GException(_("Unable to render overlay <%s>.") %
name)
return self.overlays[-1]
@@ -1216,7 +1216,7 @@
overlay.SetOpacity(kargs['opacity'])
if render and command != [] and not overlay.Render():
- raise gcmd.GException(_("Unable render overlay <%s>") %
name)
return overlay
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/vdigit.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/vdigit.py 2012-01-20 19:14:58 UTC (rev 50332)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/vdigit.py 2012-01-20 21:46:12 UTC (rev 50333)
@@ -1021,7 +1021,7 @@
self.list.SetStringItem(itemIndex, 1, str(catNew))
dlg = wx.MessageDialog(self, _("Unable to add new layer/category <%(layer)s/%(category)s>.\n"
"Layer and category number must be integer.\n"
- "Layer number must be greater then zero.") %
+ "Layer number must be greater than zero.") %
{ 'layer': self.layerNew.GetStringSelection(),
'category' : str(self.catNew.GetValue()) },
_("Error"), wx.OK | wx.ICON_ERROR)
Modified: grass/branches/releasebranch_6_4/locale/po/grasswxpy_cs.po
--- grass/branches/releasebranch_6_4/locale/po/grasswxpy_cs.po 2012-01-20 19:14:58 UTC (rev 50332)
+++ grass/branches/releasebranch_6_4/locale/po/grasswxpy_cs.po 2012-01-20 21:46:12 UTC (rev 50333)
@@ -282,12 +282,12 @@
#: ../gui/wxpython/gui_modules/render.py:1180
#, python-format
-msgid "Unable render overlay <%s>."
+msgid "Unable to render overlay <%s>."
msgstr "Nelze vykreslit pøekrytí <%s>."
#: ../gui/wxpython/gui_modules/render.py:1219
#, python-format
-msgid "Unable render overlay <%s>"
+msgid "Unable to render overlay <%s>"
msgstr "Nelze vykreslit pøekrytí <%s>"
#: ../gui/wxpython/gui_modules/profile.py:34
@@ -1399,7 +1399,7 @@
#: ../gui/wxpython/gui_modules/dbm.py:1170
#, python-format
msgid ""
-"Selected data records (%d) will permanently deleted from table. Do you want "
+"Selected data records (%d) will be permanently deleted from table. Do you want "
"to delete them?"
msgstr ""
"Vybrané záznamy dat (%d) budou natrvalo smazány z tabulky. Pøejete si je "
@@ -6822,7 +6822,7 @@
msgid ""
-"Layer number must be greater then zero."
+"Layer number must be greater than zero."
msgstr ""
"Nelze pøidat identifikátor nové vrstvy/kategorie <%(layer)s/%(category)s>.\n"
"Identifikátor vrstvy a kategorie musí být celé èíslo.\n"
@@ -7117,7 +7117,7 @@
#: ../gui/wxpython/gui_modules/dbm.py:1216
#, python-format
msgid ""
-"All data records (%d) will permanently deleted from table. Do you want to "
+"All data records (%d) will be permanently deleted from table. Do you want to "
"delete them?"
msgstr ""
"V¹echny záznamy dat (%d) budou natrvalo smazány z tabulky. pøejete se je "
Modified: grass/branches/releasebranch_6_4/locale/po/grasswxpy_de.po
--- grass/branches/releasebranch_6_4/locale/po/grasswxpy_de.po 2012-01-20 19:14:58 UTC (rev 50332)
+++ grass/branches/releasebranch_6_4/locale/po/grasswxpy_de.po 2012-01-20 21:46:12 UTC (rev 50333)
@@ -266,12 +266,12 @@
#, python-format
msgstr "Kann die Überlagerung <%s> nicht rendern."
#, python-format
msgstr "Kann die Überlagerung <%s> nicht rendern"
@@ -1347,7 +1347,7 @@
#: ../gui/wxpython/gui_modules/gmodeler.py:4469
#, python-format
-msgid "Selected data records (%d) will permanently deleted from table. Do you want to delete them?"
+msgid "Selected data records (%d) will be permanently deleted from table. Do you want to delete them?"
msgstr "Selektierte Datensätze (%d) werden unwiderruflich aus der Tabelle gelöscht. Wollen Sie diese Datensätze löschen?"
#: ../gui/wxpython/gui_modules/gmodeler.py:4472
@@ -6524,7 +6524,7 @@
msgid ""
msgstr ""
"Kann den neuen Layer/Kategorie <%(layer)s/%(category)s> nicht hinzufügen.\n"
"Layer und Kategorie Nummern müssen integer sein.\n"
@@ -6804,7 +6804,7 @@
#, python-format
-msgid "All data records (%d) will permanently deleted from table. Do you want to delete them?"
+msgid "All data records (%d) will be permanently deleted from table. Do you want to delete them?"
msgstr "Alle Datensätze (%d) werden unwiderruflich aus der Tabelle gelöscht. Wollen Sie diese Datensätze löschen?"
#: ../gui/wxpython/gui_modules/dbm.py:1362
Modified: grass/branches/releasebranch_6_4/locale/po/grasswxpy_el.po
--- grass/branches/releasebranch_6_4/locale/po/grasswxpy_el.po 2012-01-20 19:14:58 UTC (rev 50332)
+++ grass/branches/releasebranch_6_4/locale/po/grasswxpy_el.po 2012-01-20 21:46:12 UTC (rev 50333)
@@ -260,12 +260,12 @@
#, python-format
msgstr ""
#, python-format
msgstr ""
@@ -1329,7 +1329,7 @@
#, python-format
msgid ""
"to delete them?"
msgstr ""
@@ -6467,7 +6467,7 @@
msgid ""
msgstr ""
#: ../gui/wxpython/gui_modules/vdigit.py:1218
@@ -6747,7 +6747,7 @@
#, python-format
msgid ""
"delete them?"
msgstr ""
Modified: grass/branches/releasebranch_6_4/locale/po/grasswxpy_es.po
--- grass/branches/releasebranch_6_4/locale/po/grasswxpy_es.po 2012-01-20 19:14:58 UTC (rev 50332)
+++ grass/branches/releasebranch_6_4/locale/po/grasswxpy_es.po 2012-01-20 21:46:12 UTC (rev 50333)
@@ -286,12 +286,12 @@
#, python-format
msgstr "No se ha podido realizar la presentación de la superposicion <%s>."
#, python-format
@@ -1409,7 +1409,7 @@
#, python-format
msgid ""
"to delete them?"
msgstr ""
"Los registros seleccionados (%d) serán borrados permanentemente de la tabla. "
@@ -6784,7 +6784,7 @@
msgid ""
msgstr ""
"No ha sido posible añadir una nueva capa / categoría <%(layer)s/"
"%(category)s>.\n"
@@ -7086,7 +7086,7 @@
#, python-format
msgid ""
"delete them?"
msgstr ""
"Todos los registros (%d) serán borrados de la tabla permanentemente. ¿Desea "
Modified: grass/branches/releasebranch_6_4/locale/po/grasswxpy_fr.po
--- grass/branches/releasebranch_6_4/locale/po/grasswxpy_fr.po 2012-01-20 19:14:58 UTC (rev 50332)
+++ grass/branches/releasebranch_6_4/locale/po/grasswxpy_fr.po 2012-01-20 21:46:12 UTC (rev 50333)
@@ -267,12 +267,12 @@
#, python-format
msgstr ""
#, python-format
msgstr ""
@@ -1357,7 +1357,7 @@
#, python-format
msgid ""
"to delete them?"
msgstr ""
@@ -6598,7 +6598,7 @@
msgid ""
msgstr ""
@@ -6881,7 +6881,7 @@
#, python-format
msgid ""
"delete them?"
msgstr ""
Modified: grass/branches/releasebranch_6_4/locale/po/grasswxpy_id.po
--- grass/branches/releasebranch_6_4/locale/po/grasswxpy_id.po 2012-01-20 19:14:58 UTC (rev 50332)
+++ grass/branches/releasebranch_6_4/locale/po/grasswxpy_id.po 2012-01-20 21:46:12 UTC (rev 50333)
@@ -272,12 +272,12 @@
#, python-format
msgstr "Tidak dapat merender overlay <%s>."
#, python-format
msgstr "Tidak dapat merender overlay <%s>"
@@ -1427,7 +1427,7 @@
#, python-format
msgid ""
"to delete them?"
msgstr ""
"Rekaman data terpilih (%d) akan dihapus secara permanen dari tabel. Anda "
@@ -7087,7 +7087,7 @@
msgid ""
msgstr ""
"Tidak mampu menambahkan layer/kategori baru <%(layer)s/%(category)s>.\n"
"Layer dan kategori harus integer.\n"
@@ -7388,7 +7388,7 @@
#, python-format
msgid ""
"delete them?"
msgstr ""
"Semua rekaman data (%d) akan dihapus secara permanen dari tabel. Apakah Anda "
Modified: grass/branches/releasebranch_6_4/locale/po/grasswxpy_it.po
--- grass/branches/releasebranch_6_4/locale/po/grasswxpy_it.po 2012-01-20 19:14:58 UTC (rev 50332)
+++ grass/branches/releasebranch_6_4/locale/po/grasswxpy_it.po 2012-01-20 21:46:12 UTC (rev 50333)
@@ -269,12 +269,12 @@
#, python-format
msgstr "Impossibile visualizzare <%s> sovrapposto"
#, python-format
@@ -1353,7 +1353,7 @@
#, python-format
msgstr "I record (%d) selezionati saranno permanentemente eliminati della tabella. Vuoi eliminarli?"
@@ -6549,7 +6549,7 @@
msgid ""
msgstr ""
"Impossibile aggiungere nuovo layer/categoria <%(layer)s/%(category)s>.\n"
"Numero di layer e categoria dev'essere intero.\n"
@@ -6830,7 +6830,7 @@
#, python-format
msgstr "Tutti i record (%d) saranno permanentemente eliminati della tabella. Vuoi eliminarli?"
Modified: grass/branches/releasebranch_6_4/locale/po/grasswxpy_ja.po
--- grass/branches/releasebranch_6_4/locale/po/grasswxpy_ja.po 2012-01-20 19:14:58 UTC (rev 50332)
+++ grass/branches/releasebranch_6_4/locale/po/grasswxpy_ja.po 2012-01-20 21:46:12 UTC (rev 50333)
@@ -270,12 +270,12 @@
#, python-format
msgstr "<%s> ãã¬ã³ãã¼ãªã¼ãã¼ã¬ã¤ã§ãã¾ãã"
#, python-format
@@ -1361,7 +1361,7 @@
#, python-format
msgid ""
"to delete them?"
msgstr ""
"鏿ããã¬ã³ã¼ã (%d) ã¯ããã¼ãã«ããå®å
¨ã«æ¶å»ããã¾ã åé¤ãã¦ããããã§"
@@ -6592,7 +6592,7 @@
msgid ""
msgstr ""
"ã¬ã¤ã¤ã¼/ã«ãã´ãªã¼ãæ°ãã追å åºæ¥ã¾ãã <%(layer)s/%(category)s>.\n"
"ã¬ã¤ã¤ã¼ãã«ãã´ãªã¼çªå·ã¯æ´æ°ã§ç¡ããã°ãªãã¾ãã.\n"
@@ -6886,7 +6886,7 @@
#, python-format
msgid ""
"delete them?"
msgstr ""
"å
¨ã¦ã®ã¬ã³ã¼ã (%d) ã¯ããã¼ãã«ããå®å
¨ã«æ¶å»ããã¾ã åé¤ãã¦ããããã§ã"
Modified: grass/branches/releasebranch_6_4/locale/po/grasswxpy_ml.po
--- grass/branches/releasebranch_6_4/locale/po/grasswxpy_ml.po 2012-01-20 19:14:58 UTC (rev 50332)
+++ grass/branches/releasebranch_6_4/locale/po/grasswxpy_ml.po 2012-01-20 21:46:12 UTC (rev 50333)
@@ -268,12 +268,12 @@
#, python-format
msgstr ""
#, python-format
msgstr ""
@@ -1383,7 +1383,7 @@
#, python-format
msgid ""
"to delete them?"
msgstr ""
@@ -6709,7 +6709,7 @@
msgid ""
msgstr ""
@@ -6991,7 +6991,7 @@
#, python-format
msgid ""
"delete them?"
msgstr ""
Modified: grass/branches/releasebranch_6_4/locale/po/grasswxpy_pl.po
--- grass/branches/releasebranch_6_4/locale/po/grasswxpy_pl.po 2012-01-20 19:14:58 UTC (rev 50332)
+++ grass/branches/releasebranch_6_4/locale/po/grasswxpy_pl.po 2012-01-20 21:46:12 UTC (rev 50333)
@@ -278,12 +278,12 @@
#, python-format
msgstr "Nie można wyÅwietliÄ nakÅadki <%s>."
#, python-format
msgstr "Nie można wyÅwietliÄ nakÅadki <%s>"
@@ -1368,7 +1368,7 @@
#, python-format
msgid ""
"to delete them?"
msgstr ""
"Wybrane rekordy (%d) zostanÄ
caÅkowicie usuniÄte z tabeli. Chcesz je "
@@ -6611,7 +6611,7 @@
msgid ""
msgstr ""
"Nie powiodÅo siÄ dodanie nowej warstwy/kategorii <%(layer)s/%(category)s>.\n"
"Numer warstwy i kategorii musi byÄ liczbÄ
caÅkowitÄ
.\n"
@@ -6905,7 +6905,7 @@
#, python-format
msgid ""
"delete them?"
msgstr ""
"Wszystkie rekordy (%d) zostanÄ
Modified: grass/branches/releasebranch_6_4/locale/po/grasswxpy_pt.po
--- grass/branches/releasebranch_6_4/locale/po/grasswxpy_pt.po 2012-01-20 19:14:58 UTC (rev 50332)
+++ grass/branches/releasebranch_6_4/locale/po/grasswxpy_pt.po 2012-01-20 21:46:12 UTC (rev 50333)
#, python-format
msgstr ""
#, python-format
msgstr ""
@@ -1421,7 +1421,7 @@
#, python-format
msgid ""
"to delete them?"
msgstr ""
"Seleccionar os dados de registo (%d) irá apagar definitivamente os dados da "
@@ -7130,7 +7130,7 @@
msgid ""
msgstr ""
"Não é possÃvel adicionar nova camada/categoria <%(layer)s/%(category)s>.\n"
"Número de camada e categoria deve ser um inteiro.\n"
@@ -7437,7 +7437,7 @@
#, python-format
msgid ""
"delete them?"
msgstr ""
Modified: grass/branches/releasebranch_6_4/locale/po/grasswxpy_pt_br.po
--- grass/branches/releasebranch_6_4/locale/po/grasswxpy_pt_br.po 2012-01-20 19:14:58 UTC (rev 50332)
+++ grass/branches/releasebranch_6_4/locale/po/grasswxpy_pt_br.po 2012-01-20 21:46:12 UTC (rev 50333)
@@ -276,12 +276,12 @@
#, python-format
msgstr ""
#, python-format
msgstr ""
@@ -1499,7 +1499,7 @@
#, fuzzy, python-format
msgid ""
"to delete them?"
msgstr ""
@@ -7448,7 +7448,7 @@
msgid ""
msgstr ""
@@ -7780,7 +7780,7 @@
#, python-format
msgid ""
"delete them?"
msgstr ""
Modified: grass/branches/releasebranch_6_4/locale/po/grasswxpy_ru.po
--- grass/branches/releasebranch_6_4/locale/po/grasswxpy_ru.po 2012-01-20 19:14:58 UTC (rev 50332)
+++ grass/branches/releasebranch_6_4/locale/po/grasswxpy_ru.po 2012-01-20 21:46:12 UTC (rev 50333)
#, python-format
msgstr "Ðевозможно пеÑеÑиÑоваÑÑ Ð¾Ð²ÐµÑлей <%s>."
#, python-format
msgstr "Ðевозможно пеÑеÑиÑоваÑÑ Ð¾Ð²ÐµÑлей <%s>"
@@ -1411,7 +1411,7 @@
#, python-format
msgid ""
"to delete them?"
msgstr ""
"ÐÑбÑаннÑе запиÑи (%d) бÑдÑÑ Ð½Ð°Ð²Ñегда ÑÐ´Ð°Ð»ÐµÐ½Ñ Ð¸Ð· ÑаблиÑÑ. ÐÑ Ñ
оÑиÑе иÑ
@@ -7017,7 +7017,7 @@
msgid ""
msgstr ""
"Ðевозможно добавиÑÑ Ð½Ð¾Ð²Ñй Ñлой/каÑегоÑÐ¸Ñ <%(layer)s/%(category)s>.\n"
"ÐÐ¾Ð¼ÐµÑ ÑÐ»Ð¾Ñ Ð¸ каÑегоÑии Ð´Ð¾Ð»Ð¶Ð½Ñ Ð±ÑÑÑ ÑелÑми ÑиÑлами.\n"
@@ -7321,7 +7321,7 @@
#, python-format
msgid ""
"delete them?"
msgstr ""
"ÐÑе запиÑи (%d) бÑдÑÑ Ð½Ð°Ð²Ñегда ÑÐ´Ð°Ð»ÐµÐ½Ñ Ð¸Ð· ÑаблиÑÑ. ÐÑ Ñ
оÑиÑе иÑ
ÑдалиÑÑ?"
Modified: grass/branches/releasebranch_6_4/locale/po/grasswxpy_th.po
--- grass/branches/releasebranch_6_4/locale/po/grasswxpy_th.po 2012-01-20 19:14:58 UTC (rev 50332)
+++ grass/branches/releasebranch_6_4/locale/po/grasswxpy_th.po 2012-01-20 21:46:12 UTC (rev 50333)
@@ -264,12 +264,12 @@
#, python-format
msgstr ""
#, python-format
msgstr ""
#, python-format
msgid ""
"to delete them?"
msgstr ""
@@ -6711,7 +6711,7 @@
msgid ""
msgstr ""
@@ -6998,7 +6998,7 @@
#, python-format
msgid ""
"delete them?"
msgstr ""
Modified: grass/branches/releasebranch_6_4/locale/po/grasswxpy_tr.po
--- grass/branches/releasebranch_6_4/locale/po/grasswxpy_tr.po 2012-01-20 19:14:58 UTC (rev 50332)
+++ grass/branches/releasebranch_6_4/locale/po/grasswxpy_tr.po 2012-01-20 21:46:12 UTC (rev 50333)
#, python-format
msgstr ""
#, python-format
msgstr ""
@@ -1448,7 +1448,7 @@
#, python-format
msgid ""
"to delete them?"
msgstr ""
@@ -6993,7 +6993,7 @@
msgid ""
msgstr ""
@@ -7290,7 +7290,7 @@
#, python-format
msgid ""
"delete them?"
msgstr ""
"Tüm (%d) veri kayıtları tablodan kalıcı olarak silinecek. Onları silmek "
Modified: grass/branches/releasebranch_6_4/locale/po/grasswxpy_vi.po
--- grass/branches/releasebranch_6_4/locale/po/grasswxpy_vi.po 2012-01-20 19:14:58 UTC (rev 50332)
+++ grass/branches/releasebranch_6_4/locale/po/grasswxpy_vi.po 2012-01-20 21:46:12 UTC (rev 50333)
@@ -275,12 +275,12 @@
#, python-format
msgstr "Không thá» vẽ chá»ng <%s>."
#, python-format
msgstr "Không thá» vẽ chá»ng <%s>"
@@ -1433,7 +1433,7 @@
#, python-format
msgid ""
"to delete them?"
msgstr ""
"Các bản ghi dữ liá»u Äã ÄÆ°á»£c chá»n (%d) sẽ bá» xóa bá» hoà n toà n khá»i bảng. Bạn "
@@ -6979,7 +6979,7 @@
msgid ""
msgstr ""
"Không thá» thêm lá»p/phạm trù má»i <%(layer)s/%(category)s>.\n"
"â©Sá» lá»p và sá» phạm trù phải là sá» nguyên.\n"
@@ -7277,7 +7277,7 @@
#, python-format
msgid ""
"delete them?"
msgstr ""
"Tất cả các bản ghi dữ liá»u (%d) sẽ bá» xóa bá» hoà n toà n khá»i bảng. Bạn có "
Modified: grass/branches/releasebranch_6_4/locale/po/grasswxpy_zh.po
--- grass/branches/releasebranch_6_4/locale/po/grasswxpy_zh.po 2012-01-20 19:14:58 UTC (rev 50332)
+++ grass/branches/releasebranch_6_4/locale/po/grasswxpy_zh.po 2012-01-20 21:46:12 UTC (rev 50333)
#, python-format
msgstr ""
#, python-format
msgstr ""
@@ -1395,7 +1395,7 @@
#, python-format
msgid ""
"to delete them?"
msgstr ""
@@ -6879,7 +6879,7 @@
msgid ""
msgstr ""
@@ -7168,7 +7168,7 @@
#, python-format
msgid ""
"delete them?"
msgstr ""
