[GRASS-SVN] r50361 -
grass/branches/releasebranch_6_4/gui/wxpython/docs
svn_grass at osgeo.org
Sat Jan 21 13:19:14 EST 2012
Author: martinl
Date: 2012-01-21 10:19:14 -0800 (Sat, 21 Jan 2012)
New Revision: 50361
grass/branches/releasebranch_6_4/gui/wxpython/docs/wxGUI.html
grass/branches/releasebranch_6_4/gui/wxpython/docs/wxGUI_layer_manager.jpg
wxGUI: update manual (toolbars)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/docs/wxGUI.html
--- grass/branches/releasebranch_6_4/gui/wxpython/docs/wxGUI.html 2012-01-21 18:08:38 UTC (rev 50360)
+++ grass/branches/releasebranch_6_4/gui/wxpython/docs/wxGUI.html 2012-01-21 18:19:14 UTC (rev 50361)
@@ -107,30 +107,11 @@
<em>Start new map display</em></dt>
<dd>Opens a new map display and creates empty layer tree tab in Layer Manager.</dd>
- <dt><img src="icons/layer-open.png">
- <em>Load / import map layers into workspace</em></dt>
- <dd>Loads or imports selected raster or vector maps into current layer tree.
+ <dt><img src="icons/create.png">
+ <em>Create new workspace</em></dt>
+ <dd>Removes all layers from the layer tree and creates a new, empty tree
+ where new layers can be added.</dd>
- <dl>
- <dt><img src="icons/create.png">
- <em>Create new workspace file</em></dt>
- <dd>Removes all layers in the layer tree and creates a new, empty tree
- where new layers can be added.</dd>
- <em>Load map layers into workspace</em></dt>
- <dd>Loads selected raster or vector maps into current layer tree.</dd>
- <dt><img src="icons/layer-import.png">
- <em>Import raster data</em></dt>
- <dd>Import selected raster data into GRASS and load them into current layer tree.</dd>
- <em>Import vector data</em></dt>
- <dd>Import selected vector data into GRASS and load them into current layer tree.</dd>
- </dl>
- </dd>
<dt><img src="icons/open.png">
<em>Open existing workspace file</em></dt>
<dd>Opens an previously saved workspace file, containing a set of display
@@ -141,6 +122,10 @@
<dd>Saves current set of layers and their options to a workspace
file.</dd>
+ <dt><img src="icons/layer-open.png">
+ <em>Load map layers into workspace</em></dt>
+ <dd>Loads selected raster or vector maps into current layer tree.</dd>
<dt><img src="icons/layer-raster-add.png">
<em>Add raster map layer</em></dt>
<dd>Adds raster map to layer tree,
@@ -277,14 +262,54 @@
<em>Show attribute table</em></dt>
<dd>Opens <em><a href="wxGUI.Attribute_Table_Manager.html">attribute table manager</a></em> for selected vector map.</dd>
+ <em>Import raster or vector data</em></dt>
+ <dd>
+ <dl>
+ <dt><img src="icons/layer-import.png">
+ <em>Import raster data</em></dt>
+ <dd>Import selected raster data into GRASS
+ using <em><a href="r.in.gdal.html">r.in.gdal</a></em> and load
+ them into current layer tree.</dd>
+ <em>Import vector data</em></dt>
+ <dd>Import selected vector data into GRASS
+ using <em><a href="v.in.ogr.html">v.in.ogr</a></em> and load
+ </dl>
+</dd>
+ <dt><img src="icons/calculator.png">
+ <em>Raster Map Calculator</em></dt>
+ <dd>Launches Raster Calculator GUI front-end
+ for <em><a href="r.mapcalc.html">r.mapcalc</a></em>.</dd>
<dt><img src="icons/modeler-main.png">
- <em>Start Graphical Modeler</em></dt>
- <dd>Opens <em><a href="wxGUI.Modeler.html">graphical modeler</a></em> to create models and run them.</dd>
+ <em>Graphical Modeler</em></dt>
+ <dd>Launches <em><a href="wxGUI.Modeler.html">graphical
+ modeler</a></em> to create models and run them.</dd>
+ <dt><img src="icons/georectify.png">
+ <em>Georectifier Tool</em></dt>
+ <dd>Launches <em><a href="wxGUI.GCP_Manager.html">GCP
+ Manager</a></em> to create, edit, and manage Ground Control
+ Points.</dd>
+ <dt><img src="icons/print-compose.png">
+ <em>Cartographic Composer</em></dt>
+ <dd>Launches <em><a href="wxGUI.PsMap.html">Cartographic
+ Composer</a></em> to create interactively hardcopy map
+ outputs.</dd>
<dt><img src="icons/settings.png">
<em>Show GUI settings</em></dt>
- <dd>Opens dialog to change GUI preferences.</dd>
+ <dd>Opens dialog to change GUI settings.</dd>
+ <dt><img src="icons/help.png">
+ <em>Show help</em></dt>
+ <dd>Opens GRASS manual.</dd>
</dl>
<h4>Key shortcuts</h4>
@@ -492,9 +517,10 @@
see <em><a href="gm_profile.html">Profile Tool help page</a></em>.</dd>
<dt><img src="icons/layer-raster-histogram.png">
- <em>Histogram tool</em></dt>
- <dd>Displays histogram of selected raster map or image in new window,
- see <em><a href="d.histogram.html">d.histogram</a></em>.</dd>
+ <em>Histogramming tool</em></dt>
+ <dd>Displays histogram of selected raster map or image in new
+ window,
+ see <em><a href="d.histogram.html">d.histogram</a></em>.</dd>
</dl>
</dd>
Modified: grass/branches/releasebranch_6_4/gui/wxpython/docs/wxGUI_layer_manager.jpg
(Binary files differ)
