[GRASS-SVN] r50370 - grass/trunk/lib/db/dbmi_base
Sat Jan 21 16:05:55 EST 2012
Author: mmetz
Date: 2012-01-21 13:05:54 -0800 (Sat, 21 Jan 2012)
New Revision: 50370
   grass/trunk/lib/db/dbmi_base/string.c
db lib: attempt to fix some more memory leaks
Modified: grass/trunk/lib/db/dbmi_base/string.c
--- grass/trunk/lib/db/dbmi_base/string.c	2012-01-21 20:53:13 UTC (rev 50369)
+++ grass/trunk/lib/db/dbmi_base/string.c	2012-01-21 21:05:54 UTC (rev 50370)
@@ -24,7 +24,7 @@
 void db_init_string(dbString * x)
-    x->string = "";
+    x->string = NULL;
     x->nalloc = 0;
@@ -79,7 +79,8 @@
 void db_zero_string(dbString * x)
-    db_zero((void *)db_get_string(x), db_sizeof_string(x));
+    if (db_get_string(x) && x->nalloc > 0)
+	db_zero((void *)db_get_string(x), x->nalloc);
 static int set_string(dbString * x, char *s, int copy)
@@ -103,7 +104,7 @@
     else {
 	db_free_string(x);
 	x->string = s;
-	x->nalloc = -1;
+	x->nalloc = -1; /* fixme */
     return DB_OK;
@@ -119,9 +120,14 @@
 int db_enlarge_string(dbString * x, int len)
-    if (x->nalloc < len) {
-	if (x->nalloc <= 0)
-	    x->string = db_store("");
+    if (x->nalloc <= 0) {
+	x->string = db_malloc(len * sizeof(char));
+	if (x->string == NULL)
+	    return DB_MEMORY_ERR;
+	x->nalloc = len;
+	strcpy(x->string, "");
+    else if (x->nalloc < len) {
 	x->string = db_realloc((void *)x->string, len);
@@ -149,7 +155,7 @@
 void db_free_string(dbString * x)
-    if (x->nalloc > 0)
+    if (x->nalloc != 0)
 	db_free(x->string);
     db_init_string(x);
@@ -207,7 +213,10 @@
     int len;
     int stat;
-    len = strlen(db_get_string(x)) + strlen(s) + 1;
+    if (db_get_string(x))
+	len = strlen(db_get_string(x)) + strlen(s) + 1;
+    else
+	len = strlen(s) + 1;
     stat = db_enlarge_string(x, len);
     if (stat != DB_OK)
 	return stat;
