[GRASS-SVN] r50384 - grass/trunk/lib/gis
svn_grass at osgeo.org
Sun Jan 22 15:25:48 EST 2012
Author: mmetz
Date: 2012-01-22 12:25:48 -0800 (Sun, 22 Jan 2012)
New Revision: 50384
grass/trunk/lib/gis/asprintf.c
libgis: change fn names to better refelct what they do
Modified: grass/trunk/lib/gis/asprintf.c
--- grass/trunk/lib/gis/asprintf.c 2012-01-22 20:24:57 UTC (rev 50383)
+++ grass/trunk/lib/gis/asprintf.c 2012-01-22 20:25:48 UTC (rev 50384)
@@ -29,9 +29,10 @@
* \brief Safe replacement for <i>asprintf()</i>.
* Allocate a string large enough to hold the new output, including the
- * terminating NULL, and returns a pointer to the first parameter. The
- * pointer should be passed to <i>G_free()</i> to release the allocated
- * storage when it is no longer needed.
+ * terminating NULL, and return the number of characters printed. The
+ * pointer out is set to the output string and should be passed to
+ * <i>G_free()</i> to release the allocated storage when it is no longer
+ * needed.
* \param[out] out
* \param[in] fmt
@@ -77,12 +78,14 @@
#endif /* G_asprintf */
- * \brief Safe replacement for <i>asprintf()</i>.
+ * \brief Reallocating version of <i>asprintf()</i>.
- * (Re-)Allocate a string large enough to hold the new output, including the
+ * Reallocate a string large enough to hold the output, including the
+ * Contrary to <i>G_asprintf()</i>, any existing buffer pointed to by
+ * out of size osize is used to hold the output and enlarged if
+ * necessary. This is usefull when <i>G_rasprintf</i> is called many
+ * times in a loop.
* \param[out] out
* \param[out] size
@@ -90,39 +93,39 @@
* \return number of bytes written
-int G_vasprintf2(char **out, size_t *size, const char *fmt, va_list ap)
+int G_vsnprintf(char **out, size_t *osize, const char *fmt, va_list ap)
char *buf = *out;
int count;
- size_t s = *size;
+ size_t size = *osize;
- if (s < strlen(fmt) + 50) {
- s = strlen(fmt) + 50;
- buf = G_realloc(buf, s);
+ if (size < strlen(fmt) + 50) {
+ size = strlen(fmt) + 50;
+ buf = G_realloc(buf, size);
for (;;) {
- count = vsnprintf(buf, s, fmt, ap);
- if (count >= 0 && count < s)
+ count = vsnprintf(buf, size, fmt, ap);
+ if (count >= 0 && count < size)
break;
- s *= 2;
+ size *= 2;
buf = G_realloc(buf, count + 1);
*out = buf;
- *size = s;
+ *osize = size;
return count;
-int G_asprintf2(char **out, size_t *size, const char *fmt, ...)
+int G_rasprintf(char **out, size_t *size, const char *fmt, ...)
va_list ap;
int count;
va_start(ap, fmt);
- count = G_vasprintf2(out, size, fmt, ap);
+ count = G_vsnprintf(out, size, fmt, ap);
va_end(ap);
return count;
