[GRASS-SVN] r50392 - grass-addons/grass7/vector/v.out.ply
Mon Jan 23 10:28:53 EST 2012
Author: mmetz
Date: 2012-01-23 07:28:53 -0800 (Mon, 23 Jan 2012)
New Revision: 50392
   grass-addons/grass7/vector/v.out.ply/body.c
   grass-addons/grass7/vector/v.out.ply/header.c
   grass-addons/grass7/vector/v.out.ply/main.c
reduce database overhead
Modified: grass-addons/grass7/vector/v.out.ply/body.c
--- grass-addons/grass7/vector/v.out.ply/body.c	2012-01-23 13:06:34 UTC (rev 50391)
+++ grass-addons/grass7/vector/v.out.ply/body.c	2012-01-23 15:28:53 UTC (rev 50392)
@@ -13,7 +13,7 @@
     int type, i, cat, n_lines, line;
     static struct line_pnts *Points;
-    struct line_cats *Cats, *ACats;
+    struct line_cats *Cats;
     char *fs = G_store(" ");
     struct ilist *fcats;
@@ -30,6 +30,7 @@
     char buf[2000];
     dbCursor cursor;
     int *coltypes = NULL;
+    char *all_columns = NULL;
     n_lines = ncats = 0;
@@ -37,6 +38,8 @@
     db_init_string(&dbstring);
     if (columns) {
+	int len_all = 0;
 	Fi = Vect_get_field(Map, field);
 	if (!Fi) {
 	    G_fatal_error(_("Database connection not defined for layer %d"),
@@ -53,24 +56,30 @@
 	if (db_open_database(driver, &handle) != DB_OK)
 	    G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
 			  Fi->database, Fi->driver);
 	i = 0;
-	while (columns[i++]);
+	while (columns[i])
+	    len_all += strlen(columns[i++]);
 	coltypes = G_malloc(i * sizeof(int));
+	all_columns = G_malloc(len_all + i + 2);
 	i = 0;
+	strcpy(all_columns, columns[0]);
 	while (columns[i]) {
 	    coltypes[i] = db_column_Ctype(driver, Fi->table, columns[i]);
+	    if (i > 0) {
+		strcat(all_columns, ",");
+		strcat(all_columns, columns[i]);
 	    i++;
+	G_debug(0, "all column string: %s", all_columns);
     Points = Vect_new_line_struct();
     Cats = Vect_new_cats_struct();
-    ACats = Vect_new_cats_struct();
     fcats = Vect_new_list();
     /* by default, read_next_line will NOT read Dead lines */
@@ -137,13 +146,28 @@
 	/* print attributes */
 	if (columns) {
+	    sprintf(buf, "SELECT %s FROM %s WHERE %s = %d",
+		    all_columns, Fi->table, Fi->key, fcats->value[0]);
+	    G_debug(2, "SQL: %s", buf);
+	    db_set_string(&dbstring, buf);
+	    if (db_open_select_cursor
+			    (driver, &dbstring, &cursor, DB_SEQUENTIAL) != DB_OK) {
+		db_close_database(driver);
+		db_shutdown_driver(driver);
+		G_fatal_error(_("Cannot select attributes for cat = %d"),
+		  fcats->value[0]);
+	    if (db_fetch(&cursor, DB_NEXT, &more) != DB_OK) {
+		G_fatal_error(_("Unable to fetch data from table"));
+	    Table = db_get_cursor_table(&cursor);
 	    for(i = 0; columns[i]; i++) {
-		sprintf(buf, "SELECT %s FROM %s WHERE %s = %d",
-		        columns[i], Fi->table, Fi->key, fcats->value[0]);
-		G_debug(2, "SQL: %s", buf);
-		db_set_string(&dbstring, buf);
 		/* original
 		if (db_select_value(driver, Fi->table, Fi->key, fcats->value[0],
 				    columns[i], &value) < 0)
@@ -151,16 +175,7 @@
 				  Fi->table, Fi->key, columns[i]);
-		if (db_open_select_cursor
-				(driver, &dbstring, &cursor, DB_SEQUENTIAL) != DB_OK) {
-			G_fatal_error(_("Cannot select attributes for cat = %d"),
-		      fcats->value[0]);
-		if (db_fetch(&cursor, DB_NEXT, &more) != DB_OK)
-		    G_fatal_error(_("Unable to fetch data from table"));
-		Table = db_get_cursor_table(&cursor);
-		Column = db_get_table_column(Table, 0);
+		Column = db_get_table_column(Table, i);
 		Value = db_get_column_value(Column);
 		if (db_test_value_isnull(Value)) {
@@ -190,15 +205,22 @@
 		    case DB_C_TYPE_DATETIME: {
 			break;
-		    case -1:
+		    case -1: {
 			G_fatal_error(_("Column <%s> not found in table <%s>"),
 				      columns[i], Fi->table);
-		    default: G_fatal_error(_("Column <%s>: unsupported data type"),
+		    default: {
+			G_fatal_error(_("Column <%s>: unsupported data type"),
 					   columns[i]);
-		db_close_cursor(&cursor);
+	    db_close_cursor(&cursor);
 	fprintf(fp, "\n");
@@ -208,7 +230,6 @@
     db_free_string(&dbstring);
     Vect_destroy_line_struct(Points);
     Vect_destroy_cats_struct(Cats);
-    Vect_destroy_cats_struct(ACats);
     return n_lines;
Modified: grass-addons/grass7/vector/v.out.ply/header.c
--- grass-addons/grass7/vector/v.out.ply/header.c	2012-01-23 13:06:34 UTC (rev 50391)
+++ grass-addons/grass7/vector/v.out.ply/header.c	2012-01-23 15:28:53 UTC (rev 50392)
@@ -59,9 +59,12 @@
 			  fi->database, fi->driver);
 	db_init_string(&table_name);
 	db_set_string(&table_name, fi->table);
-	if (db_describe_table(driver, &table_name, &table) != DB_OK)
+	if (db_describe_table(driver, &table_name, &table) != DB_OK) {
 	    G_fatal_error(_("Unable to describe table <%s>"),
 			  fi->table);
 	for (i = 0; columns[i]; i++) {
@@ -82,18 +85,21 @@
 		fprintf(fp, "property %s %s\n", dbltype, columns[i]);
 		break;
-	    case DB_C_TYPE_STRING: {
-		break;
-	    case DB_C_TYPE_DATETIME: {
-		break;
-	    case -1:
+	    case -1: {
 			      columns[i], fi->table);
-				   columns[i]);
+	    default: {
+		G_fatal_error(_("Column <%s>: unsupported data type <%s>"),
+			      columns[i],
+			      db_sqltype_name(db_column_sqltype(driver,
+						fi->table, columns[i])));
Modified: grass-addons/grass7/vector/v.out.ply/main.c
--- grass-addons/grass7/vector/v.out.ply/main.c	2012-01-23 13:06:34 UTC (rev 50391)
+++ grass-addons/grass7/vector/v.out.ply/main.c	2012-01-23 15:28:53 UTC (rev 50392)
@@ -69,6 +69,10 @@
     /* get the region */
     G_get_window(&window);
     Vect_region_box(&window, &box);
+    if (!Vect_is_3d(&Map)) {
+	box.T = PORT_DOUBLE_MAX;
+	box.B = -PORT_DOUBLE_MAX;
     /* count points */
@@ -98,7 +102,6 @@
     write_ply_body_ascii(fp, &Map, dp, region, field,
 			   (const char **)columns, &box);
     if (fp != NULL)
 	fclose(fp);
