[GRASS-SVN] r50394 - in grass/branches/develbranch_6/gui/wxpython: core gmodeler gui_core modules tools
Mon Jan 23 14:47:29 EST 2012
Author: martinl
Date: 2012-01-23 11:47:29 -0800 (Mon, 23 Jan 2012)
New Revision: 50394
   grass/branches/develbranch_6/gui/wxpython/core/globalvar.py
   grass/branches/develbranch_6/gui/wxpython/core/utils.py
   grass/branches/develbranch_6/gui/wxpython/gmodeler/dialogs.py
   grass/branches/develbranch_6/gui/wxpython/gmodeler/model.py
   grass/branches/develbranch_6/gui/wxpython/gui_core/forms.py
   grass/branches/develbranch_6/gui/wxpython/gui_core/goutput.py
   grass/branches/develbranch_6/gui/wxpython/gui_core/menu.py
   grass/branches/develbranch_6/gui/wxpython/gui_core/prompt.py
   grass/branches/develbranch_6/gui/wxpython/modules/extensions.py
   grass/branches/develbranch_6/gui/wxpython/tools/update_menudata.py
wxGUI: reorganize command lists
Modified: grass/branches/develbranch_6/gui/wxpython/core/globalvar.py
--- grass/branches/develbranch_6/gui/wxpython/core/globalvar.py	2012-01-23 17:50:57 UTC (rev 50393)
+++ grass/branches/develbranch_6/gui/wxpython/core/globalvar.py	2012-01-23 19:47:29 UTC (rev 50394)
@@ -102,40 +102,37 @@
 MAP_WINDOW_SIZE = (800, 600)
 GM_WINDOW_SIZE = (500, 600)
-"""!File name extension binaries/scripts"""
-if sys.platform == 'win32':
-    EXT_BIN = '.exe'
-    EXT_SCT = ''
-else:
-    EXT_BIN = ''
-    EXT_SCT = ''
-def GetGRASSCmds(scriptsOnly = False):
+def GetGRASSCommands():
     """!Create list of available GRASS commands to use when parsing
     string from the command line
-    @param scriptsOnly True to report only scripts
+    @return list of commands (set) and directory of scripts (collected
+    by extension - MS Windows only)
     gisbase = os.environ['GISBASE']
     cmd = list()
+    if sys.platform == 'win32':
+        scripts = { 'bat' : list(),
+                    'py'  : list()
+    else:
+        scripts = {}
     # scan bin/
-    if not scriptsOnly and os.path.exists(os.path.join(gisbase, 'bin')):
+    if os.path.exists(os.path.join(gisbase, 'bin')):
         for fname in os.listdir(os.path.join(gisbase, 'bin')):
-            name, ext = os.path.splitext(fname)
-            if not EXT_BIN:
-                cmd.append(fname)
-            elif ext == EXT_BIN:
+            if scripts: # win32
+                name, ext = os.path.splitext(fname)
                 cmd.append(name)
+                if ext in scripts.keys():
+                    scripts[ext].append(name)
+            else:
+                cmd.append(fname)
-    # scan scripts/
-    if os.path.exists(os.path.join(gisbase, 'scripts')):
+    # scan scripts/ (not on MS Windows)
+    if not scripts and os.path.exists(os.path.join(gisbase, 'scripts')):
         for fname in os.listdir(os.path.join(gisbase, 'scripts')):
-            if not EXT_SCT:
-                cmd.append(fname)
-            elif ext == EXT_SCT:
-                cmd.append(name)
+            cmd.append(fname)
     # scan gui/scripts/
     if os.path.exists(os.path.join(gisbase, 'etc', 'gui', 'scripts')):
@@ -149,27 +146,24 @@
             if not os.path.exists(path) or not os.path.isdir(path):
                 continue
             for fname in os.listdir(path):
-                if not scriptsOnly and ext == EXT_BIN:
-                        cmd.append(name)
-                if scriptsOnly:
-                    if ext == EXT_SCT:
-                        cmd.append(name)
-                    elif ext == '.py':
-                        cmd.append(fname)
+                    cmd.append(name)
+                else:
+                    cmd.append(fname)
-    return set(cmd)
+    return set(cmd), scripts
 """@brief Collected GRASS-relared binaries/scripts"""
-grassCmd = {}
-grassCmd['all']    = GetGRASSCmds()
-grassCmd['script'] = GetGRASSCmds(scriptsOnly = True)
+grassCmd, grassScripts = GetGRASSCommands()
 """@Toolbar icon size"""
 toolbarSize = (24, 24)
 """@Is g.mlist available?"""
-if 'g.mlist' in grassCmd['all']:
+if 'g.mlist' in grassCmd:
     have_mlist = True
 else:
     have_mlist = False
Modified: grass/branches/develbranch_6/gui/wxpython/core/utils.py
--- grass/branches/develbranch_6/gui/wxpython/core/utils.py	2012-01-23 17:50:57 UTC (rev 50393)
+++ grass/branches/develbranch_6/gui/wxpython/core/utils.py	2012-01-23 19:47:29 UTC (rev 50394)
@@ -21,7 +21,7 @@
 import re
 import locale
-from core.globalvar import ETCDIR
+from core.globalvar import ETCDIR, grassScripts
 sys.path.append(os.path.join(ETCDIR, "python"))
 from grass.script import core as grass
@@ -764,3 +764,13 @@
         return os.path.join(os.getenv('APPDATA'), 'grass%d' % version)
     return os.path.join(os.getenv('HOME'), '.grass%d' % version)
+def GetRealCmd(cmd):
+    """!Return real command name - only for MS Windows
+        for ext in grassScripts.keys():
+            if cmd in grassScripts[ext]:
+                return cmd + ext
+    return cmd
Modified: grass/branches/develbranch_6/gui/wxpython/gmodeler/dialogs.py
--- grass/branches/develbranch_6/gui/wxpython/gmodeler/dialogs.py	2012-01-23 17:50:57 UTC (rev 50393)
+++ grass/branches/develbranch_6/gui/wxpython/gmodeler/dialogs.py	2012-01-23 19:47:29 UTC (rev 50394)
@@ -207,7 +207,7 @@
                                "Unable to add new action to the model."))
             return
-        if cmd[0] not in globalvar.grassCmd['all']:
+        if cmd[0] not in globalvar.grassCmd:
             GError(parent = self,
                    message = _("'%s' is not a GRASS module.\n\n"
                                "Unable to add new action to the model.") % cmd[0])
Modified: grass/branches/develbranch_6/gui/wxpython/gmodeler/model.py
--- grass/branches/develbranch_6/gui/wxpython/gmodeler/model.py	2012-01-23 17:50:57 UTC (rev 50393)
+++ grass/branches/develbranch_6/gui/wxpython/gmodeler/model.py	2012-01-23 19:47:29 UTC (rev 50394)
@@ -2221,7 +2221,7 @@
     def _createPage(self, name, params):
         """!Define notebook page"""
-        if name in globalvar.grassCmd['all']:
+        if name in globalvar.grassCmd:
             task = gtask.grassTask(name)
         else:
             task = gtask.grassTask()
Modified: grass/branches/develbranch_6/gui/wxpython/gui_core/forms.py
--- grass/branches/develbranch_6/gui/wxpython/gui_core/forms.py	2012-01-23 17:50:57 UTC (rev 50393)
+++ grass/branches/develbranch_6/gui/wxpython/gui_core/forms.py	2012-01-23 19:47:29 UTC (rev 50394)
@@ -1833,7 +1833,7 @@
         # parse the interface decription
         try:
             global _blackList
-            self.grass_task = gtask.parse_interface(cmd[0],
+            self.grass_task = gtask.parse_interface(utils.GetRealCmd(cmd[0]),
                                                     blackList = _blackList)
         except (grass.ScriptError, ValueError), e:
             raise gcmd.GException(e.value)
@@ -1985,10 +1985,7 @@
     if sys.argv[1] !=  'test':
         q = wx.LogNull()
         cmd = utils.split(sys.argv[1])
-        if sys.platform == 'win32':
-            if cmd[0] in globalvar.grassCmd['script']:
-                cmd[0] += globalvar.EXT_SCT
-        task = gtask.grassTask(cmd[0])
+        task = gtask.grassTask(utils.GetRealCmd(cmd[0]))
         task.set_options(cmd[1:])
         app = GrassGUIApp(task)
         app.MainLoop()
Modified: grass/branches/develbranch_6/gui/wxpython/gui_core/goutput.py
--- grass/branches/develbranch_6/gui/wxpython/gui_core/goutput.py	2012-01-23 17:50:57 UTC (rev 50393)
+++ grass/branches/develbranch_6/gui/wxpython/gui_core/goutput.py	2012-01-23 19:47:29 UTC (rev 50394)
@@ -474,7 +474,7 @@
             finally:
                 fileHistory.close()
-        if command[0] in globalvar.grassCmd['all']:
+        if command[0] in globalvar.grassCmd:
             # send GRASS command without arguments to GUI command interface
             # except display commands (they are handled differently)
             if self.parent.GetName() == "LayerManager" and \
@@ -522,10 +522,6 @@
             else:
                 # other GRASS commands (r|v|g|...)
-                    if command[0] in globalvar.grassCmd['script']:
-                        command[0] += globalvar.EXT_SCT
                 hasParams = False
                 if command[0] != 'r.mapcalc':
                     task = GUI(show = None).ParseCommand(command)
@@ -806,7 +802,7 @@
         if self.parent.GetName() == "LayerManager":
             self.btnCmdAbort.Enable(False)
-            if event.cmd[0] not in globalvar.grassCmd['all'] or \
+            if event.cmd[0] not in globalvar.grassCmd or \
                     event.cmd[0] == 'r.mapcalc':
                 return
Modified: grass/branches/develbranch_6/gui/wxpython/gui_core/menu.py
--- grass/branches/develbranch_6/gui/wxpython/gui_core/menu.py	2012-01-23 17:50:57 UTC (rev 50393)
+++ grass/branches/develbranch_6/gui/wxpython/gui_core/menu.py	2012-01-23 19:47:29 UTC (rev 50394)
@@ -87,7 +87,7 @@
                 cmd = utils.split(str(gcmd))
             except UnicodeError:
                 cmd = utils.split(EncodeString((gcmd)))
-            if cmd and cmd[0] not in globalvar.grassCmd['all']:
+            if cmd and cmd[0] not in globalvar.grassCmd:
                 menuItem.Enable(False)
         rhandler = eval('self.parent.' + handler)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_core/prompt.py
--- grass/branches/develbranch_6/gui/wxpython/gui_core/prompt.py	2012-01-23 17:50:57 UTC (rev 50393)
+++ grass/branches/develbranch_6/gui/wxpython/gui_core/prompt.py	2012-01-23 19:47:29 UTC (rev 50394)
@@ -90,7 +90,7 @@
         listmix.ColumnSorterMixin.__init__(self, 1)
         # set choices (list of GRASS modules)
-        self._choicesCmd = globalvar.grassCmd['all']
+        self._choicesCmd = globalvar.grassCmd
         self._choicesMap = dict()
         for type in ('raster', 'vector'):
             self._choicesMap[type] = grass.list_strings(type = type[:4])
@@ -556,7 +556,7 @@
     def _getListOfModules(self):
         """!Get list of modules"""
         result = dict()
-        for module in globalvar.grassCmd['all']:
+        for module in globalvar.grassCmd:
             try:
                 group, name = module.split('.',1)
             except ValueError:
@@ -803,11 +803,8 @@
                 self.UpdateCmdHistory([cmd])
                 self.OnCmdErase(None)
             else:
-                    if cmd in globalvar.grassCmd['script']:
-                        cmd += globalvar.EXT_SCT
                 try:
-                    self.cmdDesc = gtask.parse_interface(cmd)
+                    self.cmdDesc = gtask.parse_interface(utils.GetRealCmd(cmd))
                 except IOError:
                     self.cmdDesc = None
@@ -835,7 +832,7 @@
             return None
         if len(utils.split(str(entry))) > 1:
-            if cmd in globalvar.grassCmd['all']:
+            if cmd in globalvar.grassCmd:
                 toComplete['cmd'] = cmd
                 if entry[-1] == ' ':
                     words = entry.split(' ')
@@ -980,7 +977,7 @@
             #complete command
             if self.toComplete['entity'] == 'command':
-                for command in globalvar.grassCmd['all']:
+                for command in globalvar.grassCmd:
                     if command.find(self.toComplete['cmd']) == 0:
                         dotNumber = list(self.toComplete['cmd']).count('.')
                         self.autoCompList.append(command.split('.',dotNumber)[-1])
@@ -1042,15 +1039,11 @@
             except IndexError:
                 cmd = ''
-            if cmd not in globalvar.grassCmd['all']:
+            if cmd not in globalvar.grassCmd:
                 return
+            info = gtask.command_info(utils.GetRealCmd(cmd))
-            info = gtask.command_info(cmd)
             self.CallTipSetBackground("#f4f4d1")
             self.CallTipSetForeground("BLACK")
             self.CallTipShow(pos, info['usage'] + '\n\n' + info['description'])
@@ -1122,14 +1115,12 @@
             items = self.GetTextLeft().split()
             if len(items) == 1:
                 cmd = items[0].strip()
-                if cmd in globalvar.grassCmd['all'] and \
+                if cmd in globalvar.grassCmd and \
                         cmd != 'r.mapcalc' and \
                         (not self.cmdDesc or cmd != self.cmdDesc.get_name()):
                     try:
                     except IOError:
                         self.cmdDesc = None
             event.Skip()
Modified: grass/branches/develbranch_6/gui/wxpython/modules/extensions.py
--- grass/branches/develbranch_6/gui/wxpython/modules/extensions.py	2012-01-23 17:50:57 UTC (rev 50393)
+++ grass/branches/develbranch_6/gui/wxpython/modules/extensions.py	2012-01-23 19:47:29 UTC (rev 50394)
@@ -227,7 +227,7 @@
             return
         name = self.tree.GetItemText(item)
-        globalvar.grassCmd['all'].add(name)
+        globalvar.grassCmd.add(name)
     def OnItemSelected(self, event):
         """!Item selected"""
Modified: grass/branches/develbranch_6/gui/wxpython/tools/update_menudata.py
--- grass/branches/develbranch_6/gui/wxpython/tools/update_menudata.py	2012-01-23 17:50:57 UTC (rev 50393)
+++ grass/branches/develbranch_6/gui/wxpython/tools/update_menudata.py	2012-01-23 19:47:29 UTC (rev 50394)
@@ -45,9 +45,9 @@
                 'g.parser',
                 'vcolors' ]
-    count = len(grassCmd['all'])
+    count = len(grassCmd)
     i = 0
-    for module in grassCmd['all']:
+    for module in grassCmd:
         i += 1
         if i % 10 == 0:
             grass.info('* %d/%d' % (i, count))
