[GRASS-SVN] r50407 - grass-addons/grass6/raster/r.basin
svn_grass at osgeo.org
Tue Jan 24 05:36:29 EST 2012
Author: madi
Date: 2012-01-24 02:36:29 -0800 (Tue, 24 Jan 2012)
New Revision: 50407
grass-addons/grass6/raster/r.basin/r.basin.py
Perimeter bug fixed
Modified: grass-addons/grass6/raster/r.basin/r.basin.py
--- grass-addons/grass6/raster/r.basin/r.basin.py 2012-01-24 07:08:15 UTC (rev 50406)
+++ grass-addons/grass6/raster/r.basin/r.basin.py 2012-01-24 10:36:29 UTC (rev 50407)
@@ -194,19 +194,60 @@
overwrite = True)
# Basin mask (vector)
+ # Raster to vector
grass.run_command('r.to.vect', input = r_basin,
output = v_basin,
feature = 'area',
overwrite = True)
+ # Add two columns to the table: area and perimeter
+ grass.run_command('v.db.addcol', map = v_basin,
+ columns = 'area double precision')
+ columns = 'perimeter double precision')
+ # Populate perimeter column
grass.run_command('v.to.db', map = v_basin,
type = 'line,boundary',
layer = 1,
qlayer = 1,
option = 'perimeter',
units = 'kilometers',
- columns = 'cat',
- qcolumn = 'cat',
+ columns = 'perimeter',
overwrite = True)
+ # Read perimeter
+ tmp = grass.read_command('v.to.db', map = v_basin,
+ type = 'line,boundary',
+ layer = 1,
+ qlayer = 1,
+ option = 'perimeter',
+ units = 'kilometers',
+ qcolumn = 'perimeter',
+ flags = 'p')
+ perimeter_basin = float(tmp.split('\n')[1].split('|')[1])
+ # Populate area column
+ grass.run_command('v.to.db', map = v_basin,
+ layer = 1,
+ qlayer = 1,
+ option = 'area',
+ columns = 'area',
+ overwrite = True)
+ # Read area
+ layer = 1,
+ qlayer = 1,
+ option = 'area',
+ qcolumn = 'area',
+ flags = 'p')
+ area_basin = float(tmp.split('\n')[1].split('|')[1])
# Creation of order maps: strahler, horton, hack, shreeve
grass.message( "Creating %s" % r_hack )
@@ -222,6 +263,7 @@
grass.write_command('v.in.ascii', output = v_outlet,
stdin = "%s|%s|9999" % (east, north),
overwrite = True)
grass.run_command('v.to.rast', input = v_outlet,
output = r_outlet,
use = 'cat',
@@ -230,6 +272,7 @@
value = 1,
rows = 4096,
overwrite = True)
grass.run_command('r.stream.distance', stream = r_outlet,
dir = r_drainage,
flags = 'o',
@@ -295,20 +338,6 @@
nw = dict_region_basin['w'], dict_region_basin['n']
se = dict_region_basin['e'], dict_region_basin['s']
- # Area and perimeter of basin
- report_basin = grass.read_command('v.report', map = v_basin,
- layer = 1,
- option = 'area',
- units = 'kilometers')
- report_basin = report_basin.replace('\n',' ')
- report_basin = report_basin.split()
- area_basin = float(report_basin[1].split('|')[3])
- layer = 1,
- option = 'length',
- units = 'meters')
- perimeter_basin = float(report_basin.split('\n')[1].split('|')[0])
# Directing vector
delta_x = abs(float(basin_east) - east)
delta_y = abs(float(basin_north) - north)
@@ -337,11 +366,10 @@
overwrite = True)
param_mainchannel = grass.read_command('v.what', map = v_mainchannel,
east_north = '%s,%s' % (east,north) )
- dict_mainchannel = dict(x.split(':', 1) for x in param_mainchannel.split('\n')if ':' in x)
- mainchannel = float(dict_mainchannel['Length']) / 1000
+ tmp = param_mainchannel.split('\n')[8]
+ mainchannel = float(tmp.split()[1])
# Topological Diameter
- #grass.run_command('r.mapcalculator', amap = r_shreve , formula = '-(%s - %s)' % (r_mainchannel, r_shreve) , outfile = r_mainchannel_dim)
grass.mapcalc("$r_mainchannel_dim = -($r_mainchannel - $r_shreve) + 1",
r_mainchannel_dim = r_mainchannel_dim,
r_shreve = r_shreve,
@@ -390,8 +418,7 @@
mainchannel_slope = sum(pendenze) / len(pendenze) * 100
except :
pass
- #grass.message( "Mean slope of mainchannel = WARNING" )
# Elongation Ratio
R_al = (2 * math.sqrt( area_basin / math.pi) ) / mainchannel
@@ -612,9 +639,10 @@
grass.message( "\n" )
grass.message( "##################################" )
- grass.message( "ERROR" )
- grass.message( "Outlet coordinates must belong to the river network!" )
- grass.message( "Please run r.stream.extract and choose coordinates matching with the extracted stream map" )
+ grass.message( "An error occurred with the parameters calculation." )
+ grass.message( "Please note that outlet coordinates must belong to the river network." )
+ grass.message( "You might want to run r.stream.extract and choose coordinates matching with the extracted stream map." )
+ grass.message( "Please report to the authors any other problem not related with coordinates outlet." )
# Set region to original
grass.read_command('g.region', flags = 'p', region = 'original')
