[GRASS-SVN] r50466 - grass/trunk/lib/temporal/SQL
svn_grass at osgeo.org
Thu Jan 26 07:22:41 EST 2012
Author: huhabla
Date: 2012-01-26 04:22:41 -0800 (Thu, 26 Jan 2012)
New Revision: 50466
grass/trunk/lib/temporal/SQL/map_tables_template.sql
grass/trunk/lib/temporal/SQL/vector_metadata_table.sql
Implemented handling of time-stamped vector layers
Modified: grass/trunk/lib/temporal/SQL/map_tables_template.sql
--- grass/trunk/lib/temporal/SQL/map_tables_template.sql 2012-01-26 12:22:21 UTC (rev 50465)
+++ grass/trunk/lib/temporal/SQL/map_tables_template.sql 2012-01-26 12:22:41 UTC (rev 50466)
@@ -15,9 +15,10 @@
--PRAGMA foreign_keys = ON;
CREATE TABLE GRASS_MAP_base (
- id VARCHAR NOT NULL, -- The id (PK) is the unique identifier for all tables, it is based on name and mapset (name at mapset) and is used as primary key
+ id VARCHAR NOT NULL, -- The id (PK) is the unique identifier for all tables, it is based on name (layer) and mapset (name(:layer)@mapset) and is used as primary key
name VARCHAR NOT NULL, -- name of the grass map
mapset VARCHAR NOT NULL, -- mapset of the grass map
+ layer VARCHAR, -- The layer id of the map, this is currently only in use by vector maps
creator VARCHAR NOT NULL,
temporal_type VARCHAR, -- The temporal type of the grass map "absolute" or "relative" or NULL in case no time stamp is available
creation_time TIMESTAMP NOT NULL, -- The time of creation of the grass map
Modified: grass/trunk/lib/temporal/SQL/vector_metadata_table.sql
--- grass/trunk/lib/temporal/SQL/vector_metadata_table.sql 2012-01-26 12:22:21 UTC (rev 50465)
+++ grass/trunk/lib/temporal/SQL/vector_metadata_table.sql 2012-01-26 12:22:41 UTC (rev 50466)
@@ -20,7 +20,7 @@
CREATE VIEW vector_view_abs_time AS SELECT
A1.id, A1.mapset,
- A1.name, A1.temporal_type,
+ A1.name, A1.layer, A1.temporal_type,
A1.creation_time,
-- Uncommented due to performance issues
-- A1.modification_time, A1.revision,
@@ -34,7 +34,7 @@
CREATE VIEW vector_view_rel_time AS SELECT
A1.id, A1.mapset,
A1.creation_time,
