[GRASS-SVN] r50489 - grass/trunk/vector/v.to.rast3
svn_grass at osgeo.org
Fri Jan 27 05:13:41 EST 2012
Author: mmetz
Date: 2012-01-27 02:13:41 -0800 (Fri, 27 Jan 2012)
New Revision: 50489
grass/trunk/vector/v.to.rast3/main.c
fix typo
Modified: grass/trunk/vector/v.to.rast3/main.c
--- grass/trunk/vector/v.to.rast3/main.c 2012-01-27 09:59:15 UTC (rev 50488)
+++ grass/trunk/vector/v.to.rast3/main.c 2012-01-27 10:13:41 UTC (rev 50489)
@@ -59,7 +59,7 @@
col_opt = G_define_standard_option(G_OPT_DB_COLUMN);
col_opt->required = YES;
- col_opt->description = _("Name or attrbitute column (data type must be numeric)");
+ col_opt->description = _("Name of attrbitute column (data type must be numeric)");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
