[GRASS-SVN] r50492 - grass/branches/develbranch_6/vector/v.to.rast
svn_grass at osgeo.org
Fri Jan 27 05:23:30 EST 2012
Author: hamish
Date: 2012-01-27 02:23:30 -0800 (Fri, 27 Jan 2012)
New Revision: 50492
grass/branches/develbranch_6/vector/v.to.rast/support.c
less spinning of wheels (merge r50488 from trunk)
Modified: grass/branches/develbranch_6/vector/v.to.rast/support.c
--- grass/branches/develbranch_6/vector/v.to.rast/support.c 2012-01-27 10:22:08 UTC (rev 50491)
+++ grass/branches/develbranch_6/vector/v.to.rast/support.c 2012-01-27 10:23:30 UTC (rev 50492)
@@ -269,9 +269,15 @@
switch (use) {
case USE_ATTR:
- G_set_raster_cats_title("Labels", &rast_cats);
int is_fp = G_raster_map_is_fp(rast_name, G_mapset());
+ if (!label_column) {
+ G_verbose_message(_("Label column was not specified, no labels will be written"));
+ break;
+ G_set_raster_cats_title("Labels", &rast_cats);
/* open vector map and database driver */
Vect_open_old(&Map, vector_map, G_find_vector2(vector_map, ""));
@@ -303,18 +309,9 @@
G_malloc(sizeof(struct My_labels_rule) * nrec);
/* get column type */
- if (!label_column) {
- G_verbose_message(_("Label column was not specified, no labels will be written"));
- db_close_database_shutdown_driver(Driver);
- break;
- else {
- if ((col_type =
- db_column_Ctype(Driver, Fi->table,
- label_column)) == -1) {
- G_fatal_error(_("Column <%s> not found"), label_column);
+ if ((col_type =
+ db_column_Ctype(Driver, Fi->table, label_column)) == -1)
+ G_fatal_error(_("Column <%s> not found"), label_column);
/* for each attribute */
for (i = 0; i < cvarr.n_values; i++) {
