[GRASS-SVN] r50521 - grass/trunk/lib/vector/Vlib
Sat Jan 28 07:02:07 EST 2012
Author: martinl
Date: 2012-01-28 04:02:07 -0800 (Sat, 28 Jan 2012)
New Revision: 50521
   grass/trunk/lib/vector/Vlib/header.c
vlib: Vect_get_ogr_*() - better check for HAVE_OGR
Modified: grass/trunk/lib/vector/Vlib/header.c
--- grass/trunk/lib/vector/Vlib/header.c	2012-01-28 11:21:43 UTC (rev 50520)
+++ grass/trunk/lib/vector/Vlib/header.c	2012-01-28 12:02:07 UTC (rev 50521)
@@ -259,6 +259,15 @@
 const char *Vect_get_ogr_dsn_name(const struct Map_info *Map)
+#ifndef HAVE_OGR
+    G_warning(_("GRASS is not compiled with OGR support"));
+#else
+    if (Map->format != GV_FORMAT_OGR &&
+	Map->format != GV_FORMAT_OGR_DIRECT)
+	G_warning(_("Format of vector map <%s> is not OGR"),
+		  Vect_get_full_name(Map));
+#endif
     return Map->fInfo.ogr.dsn;
@@ -271,6 +280,15 @@
 const char *Vect_get_ogr_layer_name(const struct Map_info *Map)
+#ifndef HAVE_OGR
+#else
+#endif
     return Map->fInfo.ogr.layer_name;
@@ -286,12 +304,20 @@
 const char *Vect_get_ogr_format_info(const struct Map_info *Map)
-#ifdef HAVE_OGR
+#ifndef HAVE_OGR
+#else
     if (!Map->fInfo.ogr.ds)
 	return NULL;
     return G_store(OGR_Dr_GetName(OGR_DS_GetDriver(Map->fInfo.ogr.ds)));
 #endif
     return NULL;
@@ -305,10 +331,17 @@
 const char *Vect_get_ogr_geometry_type(const struct Map_info *Map)
-#ifdef HAVE_OGR
+#ifndef HAVE_OGR
+#else
     OGRwkbGeometryType Ogr_geom_type;
     OGRFeatureDefnH    Ogr_feature_defn;
     if (!Map->fInfo.ogr.layer)
 	return NULL;
@@ -317,6 +350,7 @@
     return OGRGeometryTypeToName(Ogr_geom_type);
 #endif
     return NULL;
