[GRASS-SVN] r50524 - grass/trunk/vector/v.info
Sat Jan 28 07:35:43 EST 2012
Author: martinl
Date: 2012-01-28 04:35:43 -0800 (Sat, 28 Jan 2012)
New Revision: 50524
   grass/trunk/vector/v.info/print.c
v.info: show name and mapset also for non-native formats
Modified: grass/trunk/vector/v.info/print.c
--- grass/trunk/vector/v.info/print.c	2012-01-28 12:30:37 UTC (rev 50523)
+++ grass/trunk/vector/v.info/print.c	2012-01-28 12:35:43 UTC (rev 50524)
@@ -170,21 +170,11 @@
     int map_type;
     map_type = Vect_maptype(Map);
-    if (map_type == GV_FORMAT_OGR ||
-	map_type == GV_FORMAT_OGR_DIRECT) {
-	fprintf(stdout, "ogr_layer=%s\n",
-		Vect_get_ogr_layer_name(Map));
-	fprintf(stdout, "ogr_dsn=%s\n",
-		Vect_get_ogr_dsn_name(Map));
-    else {
-	fprintf(stdout, "name=%s\n",
-		Vect_get_name(Map));
-	fprintf(stdout, "mapset=%s\n",
-		Vect_get_mapset(Map));
+    fprintf(stdout, "name=%s\n",
+	    Vect_get_name(Map));
+    fprintf(stdout, "mapset=%s\n",
+	    Vect_get_mapset(Map));
     fprintf(stdout, "location=%s\n",
 	    G_location());
     fprintf(stdout, "database=%s\n",
@@ -198,6 +188,10 @@
 	fprintf(stdout, "format=%s,%s\n",
 		Vect_maptype_info(Map), Vect_get_ogr_format_info(Map));
+	fprintf(stdout, "ogr_layer=%s\n",
+		Vect_get_ogr_layer_name(Map));
+	fprintf(stdout, "ogr_dsn=%s\n",
+		Vect_get_ogr_dsn_name(Map));
     else {
 	fprintf(stdout, "format=%s\n",
@@ -255,24 +249,12 @@
     divider('+');
-	/* for OGR format print also datasource and layer */
-	sprintf(line, "%-17s%s", _("OGR layer:"),
-	printline(line);
-	sprintf(line, "%-17s%s", _("OGR datasource:"),
-	printline(line);
-    else {
-	sprintf(line, "%-17s%s", _("Name:"),
-	printline(line);
-	sprintf(line, "%-17s%s", _("Mapset:"),
-	printline(line);
+    sprintf(line, "%-17s%s", _("Name:"),
+    printline(line);
+    sprintf(line, "%-17s%s", _("Mapset:"),
+    printline(line);
     sprintf(line, "%-17s%s", _("Location:"),
 	    G_location());
@@ -280,6 +262,7 @@
     sprintf(line, "%-17s%s", _("Database:"),
 	    G_gisdbase());
     printline(line);
     sprintf(line, "%-17s%s", _("Title:"),
 	    Vect_get_map_name(Map));
     printline(line);
@@ -291,13 +274,22 @@
 	sprintf(line, "%-17s%s (%s)", _("Map format:"),
+	printline(line);
+	/* for OGR format print also datasource and layer */
+	sprintf(line, "%-17s%s", _("OGR layer:"),
+	printline(line);
+	sprintf(line, "%-17s%s", _("OGR datasource:"),
+	printline(line);
     else {
 	sprintf(line, "%-17s%s", _("Map format:"),
 		Vect_maptype_info(Map));
+	printline(line);
-    printline(line);
     sprintf(line, "%-17s%s", _("Name of creator:"),
 	    Vect_get_person(Map));
     printline(line);
