[GRASS-SVN] r50536 - grass-addons/grass6/raster/r.area
svn_grass at osgeo.org
Sun Jan 29 12:49:43 EST 2012
Author: neteler
Date: 2012-01-29 09:49:43 -0800 (Sun, 29 Jan 2012)
New Revision: 50536
grass-addons/grass6/raster/r.area/description.html
grass-addons/grass6/raster/r.area/main.c
fixed missing module part; fixed description; fixed indentation
Modified: grass-addons/grass6/raster/r.area/description.html
--- grass-addons/grass6/raster/r.area/description.html 2012-01-29 16:29:10 UTC (rev 50535)
+++ grass-addons/grass6/raster/r.area/description.html 2012-01-29 17:49:43 UTC (rev 50536)
@@ -2,15 +2,17 @@
<dt><b>input</b></dt>
<dd>Name of input created with r.clump or another cell category map.</dd>
<dt><b>treshold</b></dt>
-<dd>Remove areas smaller than treshold, set null for removing areas</dd>
+<dd>Remove areas smaller than threshold, set null for removing areas</dd>
<dt><b>binary</b></dt>
<dd>Output map has only 0 and 1 values. If treshold is applied small areas are emoved and replaced by 0</dd>
<dt><b>output</b></dt>
-<dd>Original categories replaced with number of cells for each category. If areas belonging to category are not continuous every area belonging to the same category has the same area value.</dd>
-<p>
+<dd>Original categories replaced with number of cells for each category. If areas belonging
+to category are not continuous every area belonging to the same category has the same area value.</dd>
<h2>DESCRIPTION</h2>
-<p>module can be used to remove, areas smaller than treshold, reclass according areas (similar to r.reclass area, but work in cells, not hectares and allow create more classes)</p>
+<p>module can be used to remove, areas smaller than threshold, reclass according areas
+(similar to r.reclass area, but work in cells, not hectares and allow create more classes)</p>
<h2>SEE ALSO</h2>
<em>
@@ -23,4 +25,3 @@
<h2>AUTHOR</h2>
Jarek Jasiewicz
Modified: grass-addons/grass6/raster/r.area/main.c
--- grass-addons/grass6/raster/r.area/main.c 2012-01-29 16:29:10 UTC (rev 50535)
+++ grass-addons/grass6/raster/r.area/main.c 2012-01-29 17:49:43 UTC (rev 50536)
@@ -1,10 +1,9 @@
- * MODULE: r.fuzzy.logic
+ * MODULE: r.area
* AUTHOR(S): Jarek Jasiewicz <jarekj amu.edu.pl>
- * PURPOSE: Peroforms logical operatations on membership images created with
- * r.fuzzy or dofferent method. Use families for fuzzy logic
- * COPYRIGHT: (C) 1999-2010 by the GRASS Development Team
+ * PURPOSE: Module to calculate size of clumped areas
+ * COPYRIGHT: (C) 2010 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -22,148 +21,156 @@
int main(int argc, char *argv[])
- struct GModule *module;
- struct Option *input,
- *output,
- *par_treshold;
- struct Flag *flag_binary;
- struct Cell_head cellhd;
- struct Range range;
- struct History history;
+ struct GModule *module;
+ struct Option *input, *output, *par_treshold;
+ struct Flag *flag_binary;
- char *mapset;
- int nrows, ncols;
- int binary, treshold;
- int row, col;
- int infd, outfd;
- int *in_buf;
- int *out_buf;
- CELL c_min, c_max;
- int *ncells;
- int i;
- G_gisinit(argv[0]);
- input = G_define_standard_option(G_OPT_R_INPUT);
- input->description = _("Map created with r.clump");
- output = G_define_standard_option(G_OPT_R_OUTPUT);
- output->description = _("Map with area size (in cells)");
- par_treshold = G_define_option(); /* input stream mask file - optional */
- par_treshold->key = "treshold";
- par_treshold->type = TYPE_INTEGER;
- par_treshold->answer = "0";
- par_treshold->description = _("Remove areas lower than (0 for none):");
- flag_binary=G_define_flag();
- flag_binary->key = 'b';
- flag_binary->description = _("Binary output");
+ struct Cell_head cellhd;
+ struct Range range;
+ struct History history;
- if (G_parser(argc, argv))
+ char *mapset;
+ int nrows, ncols;
+ int binary, treshold;
+ int row, col;
+ int infd, outfd;
+ int *in_buf;
+ int *out_buf;
+ CELL c_min, c_max;
+ int *ncells;
+ int i;
+ G_gisinit(argv[0]);
+ /* Set description */
+ module = G_define_module();
+ module->keywords = _("raster");
+ module->description = _("Calculates size of clumped areas.");
+ input = G_define_standard_option(G_OPT_R_INPUT);
+ input->description = _("Map created with r.clump");
+ output = G_define_standard_option(G_OPT_R_OUTPUT);
+ output->description = _("Map with area size (in cells)");
+ par_treshold = G_define_option(); /* input stream mask file - optional */
+ par_treshold->key = "treshold";
+ par_treshold->type = TYPE_INTEGER;
+ par_treshold->answer = "0";
+ par_treshold->description = _("Remove areas lower than (0 for none):");
+ flag_binary = G_define_flag();
+ flag_binary->key = 'b';
+ flag_binary->description = _("Binary output");
+ if (G_parser(argc, argv))
exit(EXIT_FAILURE);
- treshold = atof(par_treshold->answer);
- binary = (flag_binary->answer != 0);
- mapset = G_find_cell2(input->answer, "");
- if (mapset == NULL)
+ treshold = atof(par_treshold->answer);
+ binary = (flag_binary->answer != 0);
+ mapset = G_find_cell2(input->answer, "");
+ if (mapset == NULL)
G_fatal_error(_("Raster map <%s> not found"), input->answer);
- if ((infd = G_open_cell_old(input->answer, mapset)) < 0)
+ if ((infd = G_open_cell_old(input->answer, mapset)) < 0)
G_fatal_error(_("Unable to open raster map <%s>"), input->answer);
- if (G_get_cellhd(input->answer, mapset, &cellhd) < 0)
+ if (G_get_cellhd(input->answer, mapset, &cellhd) < 0)
G_fatal_error(_("Unable to read file header of <%s>"), input->answer);
- if (G_raster_map_type(input->answer, mapset) != CELL_TYPE)
- G_fatal_error(_("<%s> is not of type CELL, probably not crated with r.clump"), input->answer);
- G_init_range(&range);
- G_read_range(input->answer,mapset,&range);
- G_get_range_min_max(&range, &c_min, &c_max);
- in_buf = G_allocate_raster_buf(CELL_TYPE);
- nrows = G_window_rows();
- ncols = G_window_cols();
- ncells=G_calloc(c_max+1,sizeof(int));
- G_message(_("Reading..."));
- for (row = 0; row < nrows; row++) {
- G_percent(row, nrows, 2);
- if (G_get_raster_row(infd, in_buf, row, CELL_TYPE)<0) {
- G_close_cell(infd);
- G_fatal_error(_("Cannot to read <%s> at row <%d>"), output->answer,row);
- for (col = 0; col < ncols; col++) {
- if(!G_is_c_null_value(&in_buf[col])) {
- if(in_buf[col]<c_min || in_buf[col] > c_max)
- G_fatal_error(_("Value at row %d, col %d out of range: %d"),row,col,in_buf[col]);
- ncells[in_buf[col]]++;
- } /* end for row */
- if(treshold) {
- for (i=1;i<c_max+1;++i)
- if(ncells[i]<treshold)
- ncells[i]=-1;
- if(binary) {
- ncells[i]= ncells[i]<treshold ? -1 : 1;
- if ((outfd = G_open_raster_new(output->answer, CELL_TYPE)) < 0)
+ if (G_raster_map_type(input->answer, mapset) != CELL_TYPE)
+ G_fatal_error(_("<%s> is not of type CELL, probably not crated with r.clump"),
+ input->answer);
+ G_init_range(&range);
+ G_read_range(input->answer, mapset, &range);
+ G_get_range_min_max(&range, &c_min, &c_max);
+ in_buf = G_allocate_raster_buf(CELL_TYPE);
+ nrows = G_window_rows();
+ ncols = G_window_cols();
+ ncells = G_calloc(c_max + 1, sizeof(int));
+ G_message(_("Reading..."));
+ for (row = 0; row < nrows; row++) {
+ G_percent(row, nrows, 2);
+ if (G_get_raster_row(infd, in_buf, row, CELL_TYPE) < 0) {
+ G_close_cell(infd);
+ G_fatal_error(_("Cannot to read <%s> at row <%d>"),
+ output->answer, row);
+ for (col = 0; col < ncols; col++) {
+ if (!G_is_c_null_value(&in_buf[col])) {
+ if (in_buf[col] < c_min || in_buf[col] > c_max)
+ G_fatal_error(_("Value at row %d, col %d out of range: %d"),
+ row, col, in_buf[col]);
+ ncells[in_buf[col]]++;
+ } /* end for row */
+ if (treshold) {
+ for (i = 1; i < c_max + 1; ++i)
+ if (ncells[i] < treshold)
+ ncells[i] = -1;
+ if (binary) {
+ ncells[i] = ncells[i] < treshold ? -1 : 1;
+ if ((outfd = G_open_raster_new(output->answer, CELL_TYPE)) < 0)
G_fatal_error(_("Unable to create raster map <%s>"), output->answer);
- out_buf = G_allocate_raster_buf(CELL_TYPE);
- G_message(_("Writing..."));
- if(G_is_c_null_value(&in_buf[col]) || ncells[in_buf[col]]==-1)
- if(binary)
- out_buf[col]=0;
- else
- G_set_c_null_value(&out_buf[col],1);
- else
- out_buf[col] = ncells[in_buf[col]];
- if (G_put_raster_row(outfd, out_buf, CELL_TYPE) < 0)
- G_fatal_error(_("Failed writing raster map <%s>"), output->answer);
- G_free(ncells);
- G_free(in_buf);
- G_free(out_buf);
- G_close_cell(outfd);
+ out_buf = G_allocate_raster_buf(CELL_TYPE);
- G_short_history(output->answer, "raster", &history);
- G_command_history(&history);
- G_write_history(output->answer, &history);
- G_message(_("Done!"));
- exit(EXIT_SUCCESS);
+ G_message(_("Writing..."));
+ if (G_is_c_null_value(&in_buf[col]) || ncells[in_buf[col]] == -1)
+ if (binary)
+ out_buf[col] = 0;
+ else
+ G_set_c_null_value(&out_buf[col], 1);
+ else
+ out_buf[col] = ncells[in_buf[col]];
+ if (G_put_raster_row(outfd, out_buf, CELL_TYPE) < 0)
+ G_fatal_error(_("Failed writing raster map <%s>"),
+ output->answer);
+ G_free(ncells);
+ G_free(in_buf);
+ G_free(out_buf);
+ G_close_cell(outfd);
+ G_short_history(output->answer, "raster", &history);
+ G_command_history(&history);
+ G_write_history(output->answer, &history);
+ G_message(_("Done!"));
+ exit(EXIT_SUCCESS);
