[GRASS-SVN] r50566 - grass/trunk/locale/po
Mon Jan 30 13:06:13 EST 2012
Author: lucadelu
Date: 2012-01-30 10:06:12 -0800 (Mon, 30 Jan 2012)
New Revision: 50566
   grass/trunk/locale/po/grasslibs_it.po
   grass/trunk/locale/po/grassmods_it.po
update italian translation: Marco Curreli and Luca Delucchi cont'ed
Modified: grass/trunk/locale/po/grasslibs_it.po
--- grass/trunk/locale/po/grasslibs_it.po	2012-01-30 18:05:33 UTC (rev 50565)
+++ grass/trunk/locale/po/grasslibs_it.po	2012-01-30 18:06:12 UTC (rev 50566)
@@ -8,20 +8,21 @@
 # Giuseppe Patti <gpatt at tiscali.it>, 2006.
 # Tobias Vigl <vigltobias at icqmail.com>, 2007.
 # Andrea Giacomelli <pibinko at gmail.com>, 2010.
+# Luca Delucchi, 2012.
 msgid ""
 msgstr ""
 "Project-Id-Version: grasslibs_it\n"
 "Report-Msgid-Bugs-To: \n"
 "POT-Creation-Date: 2012-01-28 11:12+0100\n"
-"PO-Revision-Date: 2011-11-19 19:14+0100\n"
-"Last-Translator: Luca Delucchi <lucadeluge at gmail.com>\n"
+"PO-Revision-Date: 2012-01-30 19:00+0100\n"
+"Last-Translator: Luca Delucchi\n"
 "Language-Team: Italian <grass-translations at lists.osgeo.org>\n"
 "Language: it\n"
 "MIME-Version: 1.0\n"
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
 "Plural-Forms: nplurals=2; plural=(n != 1);\n"
-"X-Generator: KBabel 1.11.4\n"
+"X-Generator: Lokalize 1.2\n"
 #: ../lib/nviz/render.c:104
 msgid "Bad server connection"
@@ -81,11 +82,8 @@
 #: ../lib/symbol/read.c:260
 #, c-format
-msgid ""
-"Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
-msgstr ""
-"Nome del simbolo errato:  '%s' (dovrebbe essere: gruppo/nome o gruppo/"
-"nome at mapset)"
+msgid "Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
+msgstr "Nome del simbolo errato:  '%s' (dovrebbe essere: gruppo/nome o gruppo/nome at mapset)"
 #: ../lib/symbol/read.c:284
 #, c-format
@@ -132,13 +130,8 @@
 msgstr "Stringa del timestamp non valida"
 #: ../lib/sites/sites.c:255 ../lib/sites/sites.c:385
-msgid ""
-"Dev note: Adapted sites library used for vector points. (module should be "
-"updated to GRASS 6 vector library)"
-msgstr ""
-"Nota per sviluppatori: Per i vettoriali a punti viene usata una sites "
-"library modificata. (il modulo va aggiornato alla libreria vettoriale di "
-"GRASS6)"
+msgid "Dev note: Adapted sites library used for vector points. (module should be updated to GRASS 6 vector library)"
+msgstr "Nota per sviluppatori: Per i vettoriali a punti viene usata una sites library modificata. (il modulo va aggiornato alla libreria vettoriale di GRASS6)"
 #: ../lib/sites/sites.c:279 ../lib/ogsf/Gv3.c:342 ../lib/ogsf/Gp3.c:206
 #: ../lib/vector/neta/utils.c:119 ../lib/vector/neta/timetables.c:133
@@ -168,8 +161,7 @@
 msgstr "G_oldsite_new_struct: numero di dimensioni o campi non valido"
 #: ../lib/sites/sites.c:668
-msgid ""
-"G_oldsite_describe() must be called immediately after G_fopen_sites_old()."
+msgid "G_oldsite_describe() must be called immediately after G_fopen_sites_old()."
 msgstr ""
 #: ../lib/ogsf/gsd_label.c:58
@@ -276,9 +268,7 @@
 #: ../lib/ogsf/Gv3.c:406
 #, c-format
-msgid ""
-"%d features without category. Unable to determine color rules for features "
-"without category."
+msgid "%d features without category. Unable to determine color rules for features without category."
 msgstr ""
 #: ../lib/ogsf/Gp3.c:92 ../lib/vector/Vlib/map.c:87
@@ -304,9 +294,7 @@
 #: ../lib/ogsf/Gp3.c:286
 #, c-format
-msgid ""
-"%d points without category. Unable to determine color rules for features "
+msgid "%d points without category. Unable to determine color rules for features without category."
 msgstr ""
 #: ../lib/ogsf/gsd_prim.c:146
@@ -316,12 +304,8 @@
 #: ../lib/ogsf/gsd_prim.c:630
 #, c-format
-msgid ""
-"gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please "
-"advise GRASS developers of this error"
-msgstr ""
-"gsd_rot(): %c è una specifica dell'asse non valida. Rotazione ignorata. Si "
-"notifichino gli sviluppatori GRASS"
+msgid "gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please advise GRASS developers of this error"
+msgstr "gsd_rot(): %c è una specifica dell'asse non valida. Rotazione ignorata. Si notifichino gli sviluppatori GRASS"
 #: ../lib/ogsf/gsd_img_tif.c:64 ../lib/ogsf/GK2.c:216
 #: ../lib/ogsf/gsd_img_ppm.c:52 ../lib/ogsf/gsd_img_ppm.c:95
@@ -376,9 +360,7 @@
 #: ../lib/ogsf/gsd_img_mpeg.c:305
 msgid "Unable to deduce output format from file extension: using MPEG"
-msgstr ""
-"Impossibile ricavare il formato di output dall'estensione del file: si userà "
-"MPEG"
+msgstr "Impossibile ricavare il formato di output dall'estensione del file: si userà MPEG"
 #: ../lib/ogsf/gsd_img_mpeg.c:309
 msgid "Unable to find suitable output format"
@@ -516,9 +498,7 @@
 #: ../lib/ogsf/Gs3.c:596
 #, c-format
 msgid "Color table range doesn't match data (mincol=%d, maxcol=%d"
-msgstr ""
-"Il range della tabella di colori non corrisponde ai dati (mincol=%d, maxcol="
-"%d"
+msgstr "Il range della tabella di colori non corrisponde ai dati (mincol=%d, maxcol=%d"
 #: ../lib/ogsf/Gs3.c:658 ../lib/ogsf/Gs3.c:730
 #, c-format
@@ -562,24 +542,17 @@
 #: ../lib/proj/convert.c:139
 #, c-format
-msgid ""
-"OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
-msgstr ""
-"OGR non sa parsare la stringa di parametri in stile PROJ.4: %s (il codice di "
-"errore OGR era %d)"
+msgid "OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
+msgstr "OGR non sa parsare la stringa di parametri in stile PROJ.4: %s (il codice di errore OGR era %d)"
 #: ../lib/proj/convert.c:146
 #, c-format
 msgid "OGR can't get WKT-style parameter string (OGR Error code was %d)"
-msgstr ""
-"OGR non sa ottenere la stringa di parametri in stile WKT (il codice di "
+msgstr "OGR non sa ottenere la stringa di parametri in stile WKT (il codice di errore OGR era %d)"
 #: ../lib/proj/convert.c:406
 msgid "No projection name! Projection parameters likely to be meaningless."
-msgstr ""
-"Nome della proiezione mancante! Probabilmente i parametri di proiezione sono "
-"errati."
+msgstr "Nome della proiezione mancante! Probabilmente i parametri di proiezione sono errati."
 #: ../lib/proj/convert.c:442
 #, c-format
@@ -588,21 +561,13 @@
 #: ../lib/proj/convert.c:458
 #, c-format
-msgid ""
-"Datum <%s> apparently recognised by GRASS but no parameters found. You may "
-"want to look into this."
-msgstr ""
-"Datum <%s> è stato apparentemente riconosciuto da GRASS ma nessun parametro "
-"è stato trovato. Dovresto controllare all'interno di questo."
+msgid "Datum <%s> apparently recognised by GRASS but no parameters found. You may want to look into this."
+msgstr "Datum <%s> è stato apparentemente riconosciuto da GRASS ma nessun parametro è stato trovato. Dovresto controllare all'interno di questo."
 #: ../lib/proj/convert.c:462
 #, c-format
-msgid ""
-"Invalid transformation number %d; valid range is 1 to %d. Leaving datum "
-"transform parameters unspecified."
-msgstr ""
-"Numero di trasformazione %d non valido; il range valido è da 1 a %d. I "
-"parametri di trasformazione del datum non vengono specificati."
+msgid "Invalid transformation number %d; valid range is 1 to %d. Leaving datum transform parameters unspecified."
+msgstr "Numero di trasformazione %d non valido; il range valido è da 1 a %d. I parametri di trasformazione del datum non vengono specificati."
 #: ../lib/proj/datum.c:270 ../lib/proj/datum.c:350
 #, c-format
@@ -688,8 +653,7 @@
 #: ../lib/proj/ellipse.c:271 ../lib/gis/get_ellipse.c:321
 #, c-format
 msgid "Lines%s of ellipsoid table file <%s> are invalid"
-msgstr ""
-"Le linee %s della tabella degli ellissoidi nel file <%s> non sono valide"
+msgstr "Le linee %s della tabella degli ellissoidi nel file <%s> non sono valide"
 #: ../lib/raster3d/range.c:76
 #, fuzzy, c-format
@@ -877,8 +841,7 @@
 #: ../lib/raster3d/open.c:116
 #, fuzzy
 msgid "Rast3d_open_cell_old: projection does not match window projection"
-msgstr ""
-"Rast3d_openCellOld: proiezione non corrisponde alla proiezione della finestra"
+msgstr "Rast3d_openCellOld: proiezione non corrisponde alla proiezione della finestra"
 #: ../lib/raster3d/open.c:120
 #, fuzzy
@@ -918,8 +881,7 @@
 #: ../lib/raster3d/open.c:229
 #, fuzzy, c-format
 msgid "map <%s> is not in the current mapset"
-msgstr ""
-"Bug: attesa di aggiornamento di una mappa non presente nel mapset in uso"
+msgstr "Bug: attesa di aggiornamento di una mappa non presente nel mapset in uso"
 #: ../lib/raster3d/open.c:239
 #, fuzzy
@@ -949,8 +911,7 @@
 #: ../lib/raster3d/color.c:333
 #, fuzzy, c-format
 msgid "mapset <%s> is not the current mapset"
-msgstr ""
 #: ../lib/init/prompt.py:20
 msgid "[Raster and Volume MASKs present]"
@@ -976,8 +937,7 @@
 #: ../lib/init/lock.c:60
 #, c-format
 msgid "Unable to write lockfile %s (disk full? Permissions?)"
-msgstr ""
-"Impossibile scriver il lockfile %s (Fine dello spazio su disco? Permessi?)"
+msgstr "Impossibile scriver il lockfile %s (Fine dello spazio su disco? Permessi?)"
 #: ../lib/init/grass.py:69
 #, fuzzy
@@ -1151,8 +1111,7 @@
 #: ../lib/init/grass.py:591
 msgid ""
-"Error in GUI startup. If necessary, please report this error to the GRASS "
-"developers.\n"
+"Error in GUI startup. If necessary, please report this error to the GRASS developers.\n"
 "Switching to text mode now.\n"
 "\n"
 "Hit RETURN to continue..."
@@ -1188,9 +1147,7 @@
 #: ../lib/init/grass.py:653
 #, python-format
-msgid ""
-"%(user)s is currently running GRASS in selected mapset (file %(file)s "
-"found). Concurrent use not allowed."
+msgid "%(user)s is currently running GRASS in selected mapset (file %(file)s found). Concurrent use not allowed."
 msgstr ""
 #: ../lib/init/grass.py:657
@@ -1213,8 +1170,7 @@
 #: ../lib/init/grass.py:710
 #, python-format
 msgid ""
-"Job file '%s' has been defined in the 'GRASS_BATCH_JOB' variable but not "
-"found. Exiting.\n"
+"Job file '%s' has been defined in the 'GRASS_BATCH_JOB' variable but not found. Exiting.\n"
 "\n"
 "Use 'unset GRASS_BATCH_JOB' to disable batch job processing."
 msgstr ""
@@ -1308,8 +1264,7 @@
 "Unable to start GRASS. You can:\n"
 " - Launch GRASS with '-gui' switch (`grass70 -gui`)\n"
 " - Create manually GISRC file (%s)\n"
-" - Launch GRASS with path to the location/mapset as an argument (`grass70 /"
-"path/to/location/mapset`)"
+" - Launch GRASS with path to the location/mapset as an argument (`grass70 /path/to/location/mapset`)"
 msgstr ""
 #: ../lib/init/grass.py:1080
@@ -1389,9 +1344,7 @@
 #: ../lib/raster/init.c:62
 #, fuzzy
 msgid "Raster library not initialized. Programmer forgot to call Rast_init()."
-msgstr ""
-"ERRORE: Sistema non inizializzato. Il programmatore si è scordato di usare "
-"la funzione G_gisinit()\n"
+msgstr "ERRORE: Sistema non inizializzato. Il programmatore si è scordato di usare la funzione G_gisinit()\n"
 #: ../lib/raster/color_read.c:103
 #, fuzzy
@@ -1464,9 +1417,7 @@
 #: ../lib/raster/gdal.c:492
 #, c-format
-msgid ""
-"Driver <%s> does not support direct writing. Using MEM driver for "
-"intermediate dataset."
+msgid "Driver <%s> does not support direct writing. Using MEM driver for intermediate dataset."
 msgstr ""
 #: ../lib/raster/gdal.c:498
@@ -1510,21 +1461,15 @@
 msgstr "Impossibile aprire il file %s in %s"
 #: ../lib/raster/window.c:18
-msgid ""
-"Internal error: Rast_get_window() called with split window.Use "
-"Rast_get_input_window() or Rast_get_output_window() instead."
+msgid "Internal error: Rast_get_window() called with split window.Use Rast_get_input_window() or Rast_get_output_window() instead."
 msgstr ""
 #: ../lib/raster/window.c:77
-msgid ""
-"Internal error: Rast_window_rows() called with split window.Use "
-"Rast_input_window_rows() or Rast_output_window_rows() instead."
+msgid "Internal error: Rast_window_rows() called with split window.Use Rast_input_window_rows() or Rast_output_window_rows() instead."
 msgstr ""
 #: ../lib/raster/window.c:112
-msgid ""
-"Internal error: Rast_window_cols() called with split window.Use "
-"Rast_input_window_cols() or Rast_output_window_cols() instead."
+msgid "Internal error: Rast_window_cols() called with split window.Use Rast_input_window_cols() or Rast_output_window_cols() instead."
 msgstr ""
 #: ../lib/raster/color_rules.c:125
@@ -1567,12 +1512,8 @@
 #: ../lib/raster/set_window.c:131
 #, fuzzy
-msgid ""
-"Rast_set_read_window(): projection/zone differs from that of currently open "
-"raster maps"
-msgstr ""
-"G_set_window(): la proiezione/zona differisce da quella del raster "
-"attualmente aperto"
+msgid "Rast_set_read_window(): projection/zone differs from that of currently open raster maps"
+msgstr "G_set_window(): la proiezione/zona differisce da quella del raster attualmente aperto"
 #: ../lib/raster/set_window.c:158
 msgid "Input window changed while maps are open for read"
@@ -1600,8 +1541,7 @@
 #: ../lib/raster/reclass.c:171
 #, fuzzy, c-format
 msgid "Illegal reclass format in header file for <%s@%s>"
-msgstr ""
-"Formato illegale di riclassificazione nel file di intestazione per [%s in %s]"
+msgstr "Formato illegale di riclassificazione nel file di intestazione per [%s in %s]"
 #: ../lib/raster/reclass.c:273
 msgid "Illegal reclass request"
@@ -1624,8 +1564,7 @@
 #: ../lib/raster/get_row.c:37 ../lib/raster/get_row.c:882
 #, c-format
 msgid "Reading raster map <%s@%s> request for row %d is outside region"
-msgstr ""
-" Leggendo il raster <%s@%s> la richiesta per la riga %d è fuori dalla regione"
+msgstr " Leggendo il raster <%s@%s> la richiesta per la riga %d è fuori dalla regione"
 #: ../lib/raster/get_row.c:96 ../lib/raster/get_row.c:101
 #: ../lib/raster/get_row.c:134 ../lib/raster/get_row.c:140
@@ -1656,12 +1595,8 @@
 #: ../lib/raster/open.c:190
 #, c-format
-msgid ""
-"Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@"
-"%s> which does not exist"
-msgstr ""
-"impossibile aprire il raster <%s@%s> poiché è una riclassificazione di <%s@"
-"%s> che non esiste"
+msgid "Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@%s> which does not exist"
+msgstr "impossibile aprire il raster <%s@%s> poiché è una riclassificazione di <%s@%s> che non esiste"
 #: ../lib/raster/open.c:195
 #, fuzzy, c-format
@@ -1680,12 +1615,9 @@
 #: ../lib/raster/open.c:219
 #, fuzzy, c-format
-msgid ""
-"Raster map <%s> is in different projection than current region. Found <%s>, "
-"should be <%s>."
+msgid "Raster map <%s> is in different projection than current region. Found <%s>, should be <%s>."
 msgstr ""
-"[%s] nel mapset [%s] - proiezione differenza rispetto alla regione "
-"attualmente in uso:\n"
+"[%s] nel mapset [%s] - proiezione differenza rispetto alla regione attualmente in uso:\n"
 " la mappa trovata [%s] in: <%s>, deve essere <%s> "
 #: ../lib/raster/open.c:226
@@ -1700,8 +1632,7 @@
 #: ../lib/raster/open.c:256
 #, c-format
-msgid ""
-"Raster map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
+msgid "Raster map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
 msgstr ""
 #: ../lib/raster/open.c:264
@@ -1769,8 +1700,7 @@
 msgstr "Raster <%s> non è xdr: byte_order: %s"
 #: ../lib/raster/open.c:933
-msgid ""
-"Rast_set_quant_rules() can be called only for raster maps opened for reading"
+msgid "Rast_set_quant_rules() can be called only for raster maps opened for reading"
 msgstr ""
 #: ../lib/raster/null_val.c:64
@@ -1786,14 +1716,12 @@
 #: ../lib/raster/put_row.c:120
 #, fuzzy, c-format
 msgid "Error writing uncompressed FP data for row %d of <%s>"
-msgstr ""
-"errore nella lettura della mappa compressa [%s] nel mapset [%s], riga %d"
+msgstr "errore nella lettura della mappa compressa [%s] nel mapset [%s], riga %d"
 #: ../lib/raster/put_row.c:130
 #, fuzzy, c-format
 msgid "Error writing compressed FP data for row %d of <%s>"
-msgstr ""
 #: ../lib/raster/put_row.c:158
 #, c-format
@@ -1808,14 +1736,12 @@
 #: ../lib/raster/put_row.c:397 ../lib/raster/put_row.c:403
 #, fuzzy, c-format
 msgid "Error writing compressed data for row %d of <%s>"
-msgstr ""
 #: ../lib/raster/put_row.c:413
 #, fuzzy, c-format
 msgid "Error writing uncompressed data for row %d of <%s>"
-msgstr ""
 #: ../lib/raster/put_row.c:472
 #, fuzzy, c-format
@@ -1974,12 +1900,8 @@
 #: ../lib/raster/get_cellhd.c:66
 #, fuzzy, c-format
-msgid ""
-"Unable to read header file for raster map <%s@%s>.It is a reclass of raster "
-"map <%s@%s> %s"
-msgstr ""
-"impossibile aprire [%s] in [%s] poiché è una riclassificazione di [%s] in "
-"[%s] che non esiste"
+msgid "Unable to read header file for raster map <%s@%s>.It is a reclass of raster map <%s@%s> %s"
+msgstr "impossibile aprire [%s] in [%s] poiché è una riclassificazione di [%s] in [%s] che non esiste"
 #: ../lib/raster/get_cellhd.c:70
 msgid "which is missing."
@@ -2087,24 +2009,19 @@
 msgstr "gruppo <%s> fa riferimento ai seguenti raster\n"
 #: ../lib/imagery/sigsetfile.c:41
-#, fuzzy, c-format
-msgid ""
-"Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> "
-"is not current mapset"
-msgstr ""
-"Impossibile creare il file [%s] per il sottogruppo [%s] del gruppo [%s in %s]"
+#, c-format
+msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> is not current mapset"
+msgstr "Impossibile creare il file <%s> per il sottogruppo <%s> del gruppo <%s> - <%s> non è nel mapset attuale"
 #: ../lib/imagery/sigsetfile.c:57
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s>"
-msgstr ""
+msgstr "Impossibile creare il file <%s> per il sottogruppo <%s> del gruppo <%s>"
 #: ../lib/imagery/sigsetfile.c:86
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open signature file <%s> for subgroup <%s> of group <%s@%s>"
-msgstr ""
-"Impossibile aprire il file [%s] per il sottogruppo [%s] del gruppo [%s in %s]"
+msgstr "Impossibile aprire il file <%s> per il sottogruppo <%s> del gruppo <%s@%s>"
 #: ../lib/imagery/fopen.c:23
 #, c-format
@@ -2124,20 +2041,17 @@
 #: ../lib/imagery/fopen.c:79
 #, c-format
 msgid "Unable to create file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr ""
+msgstr "Impossibile creare il file [%s] per il sottogruppo [%s] del gruppo [%s in %s]"
 #: ../lib/imagery/fopen.c:101 ../lib/imagery/fopen.c:127
 #, c-format
 msgid "Unable to open file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr ""
+msgstr "Impossibile aprire il file [%s] per il sottogruppo [%s] del gruppo [%s in %s]"
 #: ../lib/imagery/fopen.c:116
 #, c-format
 msgid "Unable to find file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr ""
-"Impossibile trovare il file [%s] del subgroup [%s] del group [%s in %s]"
+msgstr "Impossibile trovare il file [%s] del subgroup [%s] del group [%s in %s]"
 #: ../lib/imagery/iclass.c:112
 #, fuzzy, c-format
@@ -2167,21 +2081,17 @@
 #: ../lib/imagery/points.c:124
 #, c-format
 msgid "Unable to open control point file for group [%s in %s]"
-msgstr ""
-"Impossibile aprire il file dei punti di controllo per il gruppo [%s in %s]"
+msgstr "Impossibile aprire il file dei punti di controllo per il gruppo [%s in %s]"
 #: ../lib/imagery/points.c:132
 #, c-format
 msgid "Bad format in control point file for group [%s in %s]"
-msgstr ""
-"Formato non supportato nel file dei punti di controllo per il gruppo [%s in "
-"%s]"
+msgstr "Formato non supportato nel file dei punti di controllo per il gruppo [%s in %s]"
 #: ../lib/imagery/points.c:159
 #, c-format
 msgid "Unable to create control point file for group [%s in %s]"
-msgstr ""
-"Impossibile creare il file dei punti di controllo per il gruppo [%s in %s]"
+msgstr "Impossibile creare il file dei punti di controllo per il gruppo [%s in %s]"
 #: ../lib/gmath/la.c:64 ../lib/gmath/la.c:120
 msgid "Matrix dimensions out of range"
@@ -2237,9 +2147,7 @@
 #: ../lib/gmath/la.c:531
 msgid "Matrix (or submatrix is singular). Solution undetermined"
-msgstr ""
-"La matrice (o sottomatrice) presenta singolarità. La soluzione è "
-"indeterminata."
+msgstr "La matrice (o sottomatrice) presenta singolarità. La soluzione è indeterminata."
 #: ../lib/gmath/la.c:535
 msgid "Problem in LA routine."
@@ -2247,8 +2155,7 @@
 #: ../lib/gmath/la.c:542
 msgid "Procedure not yet available for selected matrix type"
-msgstr ""
-"Procedura non ancora disponibile per la tipologia della matrice selezionata"
+msgstr "Procedura non ancora disponibile per la tipologia della matrice selezionata"
 #: ../lib/gmath/la.c:576
 msgid "Matrix is not square. Cannot determine inverse"
@@ -2856,8 +2763,7 @@
 #: ../lib/cairodriver/read_ppm.c:56
 #, c-format
-msgid ""
-"Cairo: input mask file has incorrect dimensions: expected: %dx%d got: %dx%d"
+msgid "Cairo: input mask file has incorrect dimensions: expected: %dx%d got: %dx%d"
 msgstr ""
 #: ../lib/cairodriver/Draw_bitmap.c:47
@@ -2867,8 +2773,7 @@
 #: ../lib/driver/parse_ftcap.c:84
 #, c-format
 msgid "%s: Unable to read font definition file; use the default"
-msgstr ""
-"%s: Impossibile leggere file definizione di scrittura; usa il predefinito"
+msgstr "%s: Impossibile leggere file definizione di scrittura; usa il predefinito"
 #: ../lib/driver/parse_ftcap.c:90
 #, c-format
@@ -2877,12 +2782,8 @@
 #: ../lib/python/raster.py:46
 #, fuzzy, python-format
-msgid ""
-"Unable to write history for <%(map)s>. Raster map <%(map)s> not found in "
-"current mapset."
-msgstr ""
-"Non posso cancellare la linea, la mappa '%s' non è aperta in modalità di "
-"scrittura ('write')"
+msgid "Unable to write history for <%(map)s>. Raster map <%(map)s> not found in current mapset."
+msgstr "Non posso cancellare la linea, la mappa '%s' non è aperta in modalità di scrittura ('write')"
 #: ../lib/python/raster.py:101
 msgid "An error occurred while running r.mapcalc"
@@ -2899,15 +2800,11 @@
 msgstr "Impossibile aprire %s"
 #: ../lib/python/temporal/core.py:42
-msgid ""
-"Unable to initialize the temporal DBMI interface. Use t.connect to specify "
-"the driver and the database string"
+msgid "Unable to initialize the temporal DBMI interface. Use t.connect to specify the driver and the database string"
 msgstr ""
 #: ../lib/python/temporal/core.py:60 ../lib/python/temporal/core.py:66
-msgid ""
-"Unable to initialize the temporal GIS DBMI interface. Use t.connect to "
-"specify the driver and the database string"
+msgid "Unable to initialize the temporal GIS DBMI interface. Use t.connect to specify the driver and the database string"
 msgstr ""
 #: ../lib/python/temporal/space_time_datasets_tools.py:57
@@ -2949,22 +2846,17 @@
 #: ../lib/python/temporal/space_time_datasets_tools.py:194
 #, python-format
-msgid ""
-"Unable to register %s map <%s> with layer %s. The map has no valid time and "
-"the start time is not set."
+msgid "Unable to register %s map <%s> with layer %s. The map has no valid time and the start time is not set."
 msgstr ""
 #: ../lib/python/temporal/space_time_datasets_tools.py:197
 #, python-format
-msgid ""
-"Unable to register %s map <%s>. The map has no valid time and the start time "
-"is not set."
+msgid "Unable to register %s map <%s>. The map has no valid time and the start time is not set."
 msgstr ""
 #: ../lib/python/temporal/space_time_datasets_tools.py:214
 #, python-format
-msgid ""
-"Unable to register %s map <%s> with layer. The temporal types are different."
+msgid "Unable to register %s map <%s> with layer. The temporal types are different."
 msgstr ""
 #: ../lib/python/temporal/space_time_datasets_tools.py:216
@@ -2994,8 +2886,7 @@
 #: ../lib/python/temporal/space_time_datasets_tools.py:618
-msgid ""
-"Set relative valid time for map <%s> with layer %s to %i - %s with unit %s"
+msgid "Set relative valid time for map <%s> with layer %s to %i - %s with unit %s"
 msgstr "Impossibile copiare il vettoriale <%s> in <%s>"
 #: ../lib/python/temporal/space_time_datasets_tools.py:620
@@ -3022,9 +2913,7 @@
 #: ../lib/python/temporal/aggregation.py:113
-msgid ""
-"Raster map <%s> is already in temporal database, use overwrite flag to "
-"overwrite"
+msgid "Raster map <%s> is already in temporal database, use overwrite flag to overwrite"
 msgstr "Il vettoriale '%s' è già presente e sarà sovrascritto"
 #: ../lib/python/temporal/aggregation.py:116
@@ -3039,8 +2928,7 @@
 #: ../lib/python/temporal/abstract_map_dataset.py:167
 msgid "Start time must be of type datetime for %s map <%s> with layer: %s"
-msgstr ""
-"Non riesco a creare il file %s di timestamp per la mappa %s nel mapset %s"
+msgstr "Non riesco a creare il file %s di timestamp per la mappa %s nel mapset %s"
 #: ../lib/python/temporal/abstract_map_dataset.py:169
@@ -3071,8 +2959,7 @@
 #: ../lib/python/temporal/abstract_map_dataset.py:244
 msgid "Unsupported relative time unit type for %s map <%s> with layer %s: %s"
-msgstr ""
 #: ../lib/python/temporal/abstract_map_dataset.py:246
@@ -3086,15 +2973,12 @@
 #: ../lib/python/temporal/abstract_map_dataset.py:333
 #, python-format
-msgid ""
-"Map <%s> with layer %s has incorrect time interval, start time is greater "
-"than end time"
+msgid "Map <%s> with layer %s has incorrect time interval, start time is greater than end time"
 msgstr ""
 #: ../lib/python/temporal/abstract_map_dataset.py:335
 #, python-format
-msgid ""
-"Map <%s> has incorrect time interval, start time is greater than end time"
+msgid "Map <%s> has incorrect time interval, start time is greater than end time"
 msgstr ""
 #: ../lib/python/temporal/abstract_map_dataset.py:338
@@ -3133,8 +3017,7 @@
 msgstr "Impossibile trovare il vettoriale <%s> in <%s>"
 #: ../lib/python/temporal/spatial_extent.py:38
-msgid ""
-"Projections are different. Unable to compute overlap_2d for spatial extents"
+msgid "Projections are different. Unable to compute overlap_2d for spatial extents"
 msgstr ""
 #: ../lib/python/temporal/spatial_extent.py:161
@@ -3180,10 +3063,7 @@
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:611
-msgid ""
-"More than one map found in a granule. Temporal granularity seems to be "
-"invalid or the chosen granularity is not a greatest common divider of all "
-"intervals and gaps in the dataset."
+msgid "More than one map found in a granule. Temporal granularity seems to be invalid or the chosen granularity is not a greatest common divider of all intervals and gaps in the dataset."
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:776
@@ -3232,9 +3112,7 @@
 #: ../lib/python/temporal/abstract_space_time_dataset.py:891
 #, python-format
-msgid ""
-"Temporal type of space time dataset <%s> and map <%s> with layer %s are "
-"different"
+msgid "Temporal type of space time dataset <%s> and map <%s> with layer %s are different"
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:893
@@ -3249,15 +3127,12 @@
 #: ../lib/python/temporal/abstract_space_time_dataset.py:906
 #, python-format
-msgid ""
-"Relative time units of space time dataset <%s> and map <%s> with layer %s "
-"are different"
+msgid "Relative time units of space time dataset <%s> and map <%s> with layer %s are different"
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:908
 #, python-format
-msgid ""
-"Relative time units of space time dataset <%s> and map <%s> are different"
+msgid "Relative time units of space time dataset <%s> and map <%s> are different"
 msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:914
@@ -3277,9 +3152,7 @@
 #: ../lib/python/temporal/abstract_space_time_dataset.py:962
 #: ../lib/python/temporal/abstract_space_time_dataset.py:1007
-msgid ""
-"Unable to create the space time %s dataset register table for map <%s> with "
-"layer %s"
+msgid "Unable to create the space time %s dataset register table for map <%s> with layer %s"
 msgstr "Impossibile creare il file di intestazione per [%s]"
 #: ../lib/python/temporal/abstract_space_time_dataset.py:965
@@ -3326,19 +3199,16 @@
 #: ../lib/python/temporal/abstract_space_time_dataset.py:1101
 msgid "Map <%s> with layer %s is not registered in space time dataset <%s>"
-msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:1103
 msgid "Map <%s> is not registered in space time dataset <%s>"
-msgstr ""
 #: ../lib/python/temporal/abstract_space_time_dataset.py:1146
 #, python-format
-msgid ""
-"Update metadata, spatial and temporal extent from all registered maps of <%s>"
+msgid "Update metadata, spatial and temporal extent from all registered maps of <%s>"
 msgstr ""
 #: ../lib/python/raster3d.py:86
@@ -3859,12 +3729,8 @@
 #: ../lib/arraystats/class.c:221
 #, c-format
-msgid ""
-"There are classbreaks outside the range min-max. Number of classes reduced "
-"to %i, but using probabilities for %i classes."
-msgstr ""
-"Ci sono interruzioni di classe fuori dal range min-max. Numero di classi "
-"ridotto a %i, ma saranno usate probabiltà per %i classi."
+msgid "There are classbreaks outside the range min-max. Number of classes reduced to %i, but using probabilities for %i classes."
+msgstr "Ci sono interruzioni di classe fuori dal range min-max. Numero di classi ridotto a %i, ma saranno usate probabiltà per %i classi."
 #: ../lib/vector/neta/utils.c:222 ../lib/vector/neta/utils.c:235
 #, c-format
@@ -3904,12 +3770,8 @@
 #: ../lib/vector/diglib/plus_node.c:217
 #, c-format
-msgid ""
-"Attempt to read line angle for the line which is not connected to the node: "
-"node %d, line %d"
-msgstr ""
-"Tentativo di leggere l'angolo della linea che non è connesso al nodo: nodo "
-"%d, linea %d"
+msgid "Attempt to read line angle for the line which is not connected to the node: node %d, line %d"
+msgstr "Tentativo di leggere l'angolo della linea che non è connesso al nodo: nodo %d, linea %d"
 #: ../lib/vector/diglib/file.c:159
 msgid "Writing to file loaded to memory not supported"
@@ -3925,23 +3787,17 @@
 #: ../lib/vector/diglib/spindex_rw.c:277
 #, c-format
-msgid ""
-"Spatial index format version %d.%d is not supported by this release. Try to "
-"rebuild topology or upgrade GRASS."
+msgid "Spatial index format version %d.%d is not supported by this release. Try to rebuild topology or upgrade GRASS."
 msgstr ""
 #: ../lib/vector/diglib/spindex_rw.c:284
 #, c-format
-msgid ""
-"Your GRASS version does not fully support spatial index format %d.%d of the "
-"vector. Consider to rebuild topology or upgrade GRASS."
+msgid "Your GRASS version does not fully support spatial index format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
 msgstr ""
 #: ../lib/vector/diglib/spindex_rw.c:293
 #, c-format
-msgid ""
-"Spatial index format version %d.%d is not supported by this release. Please "
-"rebuild topology."
+msgid "Spatial index format version %d.%d is not supported by this release. Please rebuild topology."
 msgstr ""
 #: ../lib/vector/diglib/spindex_rw.c:824
@@ -4064,23 +3920,17 @@
 #: ../lib/vector/diglib/plus_area.c:400
 #, c-format
 msgid "Dead centroid %d registered for area (bug in the vector library)"
-msgstr ""
-"Centroide inesistente %d registrato per l'area (baco nella libreria "
-"vettoriale)"
+msgstr "Centroide inesistente %d registrato per l'area (baco nella libreria vettoriale)"
 #: ../lib/vector/diglib/plus_area.c:425
 #, c-format
 msgid "Attempt to delete area %d info from dead isle %d"
-msgstr ""
-"Tentativo di cancellare le informazioni dell'area %d dall'isola inesistente "
-"%d"
+msgstr "Tentativo di cancellare le informazioni dell'area %d dall'isola inesistente %d"
 #: ../lib/vector/diglib/plus_area.c:762
 #, c-format
 msgid "Attempt to delete isle %d info from dead area %d"
-msgstr ""
-"Tentativo di cancellare le informazioni dell'isola %d dall'area inesistente "
-"%d"
+msgstr "Tentativo di cancellare le informazioni dell'isola %d dall'area inesistente %d"
 #: ../lib/vector/diglib/portable.c:210 ../lib/vector/diglib/portable.c:243
 #: ../lib/vector/diglib/portable.c:690 ../lib/vector/diglib/plus_struct.c:560
@@ -4094,28 +3944,22 @@
 #: ../lib/vector/diglib/test.c:75
 #, c-format
-msgid ""
-"Error in read/write portable double, byte_order = %d Written: %.16e3E Read: "
-"%.16e3E"
+msgid "Error in read/write portable double, byte_order = %d Written: %.16e3E Read: %.16e3E"
 msgstr ""
 #: ../lib/vector/diglib/test.c:89
 #, c-format
-msgid ""
-"Error in read/write portable float, byte_order = %d Written: %.8e3E Read: "
-"%.8e3E"
+msgid "Error in read/write portable float, byte_order = %d Written: %.8e3E Read: %.8e3E"
 msgstr ""
 #: ../lib/vector/diglib/test.c:104
 #, c-format
-msgid ""
-"Error in read/write portable off_t, byte_order = %d Written: %lu Read: %lu"
+msgid "Error in read/write portable off_t, byte_order = %d Written: %lu Read: %lu"
 msgstr ""
 #: ../lib/vector/diglib/test.c:119
 #, c-format
-msgid ""
-"Error in read/write portable long, byte_order = %d Written: %lu Read: %lu"
+msgid "Error in read/write portable long, byte_order = %d Written: %lu Read: %lu"
 msgstr ""
 #: ../lib/vector/diglib/test.c:134
@@ -4125,8 +3969,7 @@
 #: ../lib/vector/diglib/test.c:150
 #, c-format
-msgid ""
-"Error in read/write portable short, byte_order = %d Written: %d Read: %d"
+msgid "Error in read/write portable short, byte_order = %d Written: %d Read: %d"
 msgstr ""
 #: ../lib/vector/diglib/test.c:165
@@ -4136,31 +3979,18 @@
 #: ../lib/vector/diglib/plus_struct.c:520
 #, fuzzy, c-format
-msgid ""
-"Topology format version %d.%d is not supported by this release. Try to "
-msgstr ""
-"Versione %d.%d del formato dell'indice delle features non è supportata da "
-"questa release. Ricostruire la topologia o aggiornare GRASS."
+msgid "Topology format version %d.%d is not supported by this release. Try to rebuild topology or upgrade GRASS."
+msgstr "Versione %d.%d del formato dell'indice delle features non è supportata da questa release. Ricostruire la topologia o aggiornare GRASS."
 #: ../lib/vector/diglib/plus_struct.c:526
 #, fuzzy, c-format
-msgid ""
-"Your GRASS version does not fully support topology format %d.%d of the "
-msgstr ""
-"Questa versione di GRASS non supporta appieno il formato %d.%d dell'indice "
-"delle features del vettore. Si consiglia di ricostruire la topologia o "
-"aggiornare GRASS."
+msgid "Your GRASS version does not fully support topology format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
+msgstr "Questa versione di GRASS non supporta appieno il formato %d.%d dell'indice delle features del vettore. Si consiglia di ricostruire la topologia o aggiornare GRASS."
 #: ../lib/vector/diglib/plus_struct.c:536
 #, fuzzy, c-format
-msgid ""
-"Old topology format version %d.%d is not supported by this release. Try to "
-msgstr ""
+msgid "Old topology format version %d.%d is not supported by this release. Try to rebuild topology."
 #: ../lib/vector/Vlib/write_nat.c:52 ../lib/vector/Vlib/write_nat.c:86
 #, c-format
@@ -4183,14 +4013,12 @@
 #: ../lib/vector/Vlib/legal_vname.c:43
 #, c-format
 msgid "Illegal vector map name <%s>. May not contain '.' or 'NULL'."
-msgstr ""
-"Nome non valido per il vettoriale <%s>. Non deve contenere '.' oppure 'NULL'."
+msgstr "Nome non valido per il vettoriale <%s>. Non deve contenere '.' oppure 'NULL'."
 #: ../lib/vector/Vlib/legal_vname.c:50
 #, c-format
 msgid "Illegal vector map name <%s>. Must start with a letter."
-msgstr ""
-"Nome non valido per il vettoriale <%s>. Deve cominciare con una lettera."
+msgstr "Nome non valido per il vettoriale <%s>. Deve cominciare con una lettera."
 #: ../lib/vector/Vlib/legal_vname.c:58
 #, c-format
@@ -4199,11 +4027,8 @@
 #: ../lib/vector/Vlib/legal_vname.c:65
 #, c-format
-msgid ""
-"Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
-msgstr ""
-"Nome non valido per il vettoriale <%s>. Parole chiave di SQL non possono "
-"essere usate come nome della mappa."
+msgid "Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
+msgstr "Nome non valido per il vettoriale <%s>. Parole chiave di SQL non possono essere usate come nome della mappa."
 #: ../lib/vector/Vlib/legal_vname.c:97 ../lib/vector/Vlib/legal_vname.c:101
 #, c-format
@@ -4402,11 +4227,8 @@
 #: ../lib/vector/Vlib/build.c:1027
 #, fuzzy
-msgid ""
-"Unable to build spatial index from topology, vector map is not opened at "
-"topology level 2"
-msgstr ""
-"Non riesco a cancellare la linea, la mappa '%s' non è aperta a livello 2"
+msgid "Unable to build spatial index from topology, vector map is not opened at topology level 2"
+msgstr "Non riesco a cancellare la linea, la mappa '%s' non è aperta a livello 2"
 #: ../lib/vector/Vlib/build.c:1050
 #, fuzzy, c-format
@@ -4572,12 +4394,8 @@
 #: ../lib/vector/Vlib/geos.c:55
 #, c-format
-msgid ""
-"Vect_read_line_geos(): feature id %d is not reasonable (max features in "
-"vector map <%s>: %d)"
-msgstr ""
-"Vect_read_line_geos(): l'id %d della feature è irragionevole (numero massimo "
-"di features nel vettoriale <%s>: %d)"
+msgid "Vect_read_line_geos(): feature id %d is not reasonable (max features in vector map <%s>: %d)"
+msgstr "Vect_read_line_geos(): l'id %d della feature è irragionevole (numero massimo di features nel vettoriale <%s>: %d)"
 #: ../lib/vector/Vlib/geos.c:60
 msgid "only native format supported"
@@ -4591,9 +4409,7 @@
 #: ../lib/vector/Vlib/geos.c:104
 #, c-format
 msgid "Vect_read_area_geos(): unable to read isle id %d of area id %d"
-msgstr ""
-"Vect_read_area_geos(): impossibile leggere l'isola con id %d nell' area con "
-"id %d"
+msgstr "Vect_read_area_geos(): impossibile leggere l'isola con id %d nell' area con id %d"
 #: ../lib/vector/Vlib/geos.c:202
 #, c-format
@@ -4621,12 +4437,8 @@
 #: ../lib/vector/Vlib/read.c:132
 #, c-format
-msgid ""
-"Vect_read_line(): feature id %d is not reasonable (max features in vector "
-"map <%s>: %d)"
-msgstr ""
-"Vect_read_line(): l'id %d della feature è irragionevole (numero massimo di "
-"features nel vettoriale <%s>: %d)"
+msgid "Vect_read_line(): feature id %d is not reasonable (max features in vector map <%s>: %d)"
+msgstr "Vect_read_line(): l'id %d della feature è irragionevole (numero massimo di features nel vettoriale <%s>: %d)"
 #: ../lib/vector/Vlib/build_ogr.c:290
 #, c-format
@@ -4644,8 +4456,7 @@
 msgstr ""
 #: ../lib/vector/Vlib/build_ogr.c:387
-msgid ""
-"Random read is not supported by OGR for this layer, unable to build topology"
+msgid "Random read is not supported by OGR for this layer, unable to build topology"
 msgstr ""
 #: ../lib/vector/Vlib/build_ogr.c:392
@@ -4697,16 +4508,12 @@
 #: ../lib/vector/Vlib/net.c:250
 #, c-format
-msgid ""
-"Database record for line %d (cat = %d, forward/both direction(s)) not found "
-"(forward/both direction(s) of line skipped)"
+msgid "Database record for line %d (cat = %d, forward/both direction(s)) not found (forward/both direction(s) of line skipped)"
 msgstr ""
 #: ../lib/vector/Vlib/net.c:269
 #, c-format
-msgid ""
-"Database record for line %d (cat = %d, backword direction) not found"
-"(direction of line skipped)"
+msgid "Database record for line %d (cat = %d, backword direction) not found(direction of line skipped)"
 msgstr ""
 #: ../lib/vector/Vlib/net.c:318
@@ -4720,9 +4527,7 @@
 #: ../lib/vector/Vlib/net.c:398
 #, c-format
 msgid "Database record for node %d (cat = %d) not found (cost set to 0)"
-msgstr ""
-"Record del database non trovato per il nodo %d (cat = %d) (costo impostato a "
-"0)"
+msgstr "Record del database non trovato per il nodo %d (cat = %d) (costo impostato a 0)"
 #: ../lib/vector/Vlib/net.c:425
 msgid "Flattening the graph..."
@@ -4783,7 +4588,7 @@
 #: ../lib/vector/Vlib/build_nat.c:170
 msgid "Building areas..."
-msgstr "Crea edifici..."
+msgstr "Costruendo aree..."
 #: ../lib/vector/Vlib/build_nat.c:193
 #, c-format
@@ -4853,22 +4658,13 @@
 #: ../lib/vector/Vlib/open_ogr.c:175
 #, c-format
-msgid ""
-"Feature index format version %d.%d is not supported by this release. Try to "
-msgstr ""
+msgid "Feature index format version %d.%d is not supported by this release. Try to rebuild topology or upgrade GRASS."
 #: ../lib/vector/Vlib/open_ogr.c:180
 #, c-format
-msgid ""
-"Your GRASS version does not fully support feature index format %d.%d of the "
-msgstr ""
+msgid "Your GRASS version does not fully support feature index format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
 #: ../lib/vector/Vlib/open_ogr.c:250
 #, fuzzy, c-format
@@ -4934,15 +4730,12 @@
 #: ../lib/vector/Vlib/open_nat.c:152
 #, c-format
-msgid ""
-"Coor file of vector map <%s@%s> is larger than it should be (%ld bytes "
-"excess)"
+msgid "Coor file of vector map <%s@%s> is larger than it should be (%ld bytes excess)"
 msgstr ""
 #: ../lib/vector/Vlib/open_nat.c:156
 #, c-format
-msgid ""
-"Coor file of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
+msgid "Coor file of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
 msgstr ""
 #: ../lib/vector/Vlib/open.c:111
@@ -4953,15 +4746,11 @@
 #: ../lib/vector/Vlib/open.c:199
 #, fuzzy, c-format
 msgid "Vector map <%s> not found in current mapset"
-msgstr ""
 #: ../lib/vector/Vlib/open.c:213
-msgid ""
-"Vector map which is not in the current mapset cannot be opened for update"
-msgstr ""
-"Il vettoriale che non presente nel mapset in uso non può essere aperta per "
-"gli aggiornamenti"
+msgid "Vector map which is not in the current mapset cannot be opened for update"
+msgstr "Il vettoriale che non presente nel mapset in uso non può essere aperta per gli aggiornamenti"
 #: ../lib/vector/Vlib/open.c:250
 #, fuzzy, c-format
@@ -4985,12 +4774,8 @@
 #: ../lib/vector/Vlib/open.c:334 ../lib/vector/Vlib/open.c:353
 #, c-format
-msgid ""
-"Unable to open vector map <%s> on level %d. Try to rebuild vector topology "
-"by v.build."
-msgstr ""
-"Impossibile aprire il vettoriale <%s> sul livello %d. Provare a ricostruire "
-"la topologia con v.build."
+msgid "Unable to open vector map <%s> on level %d. Try to rebuild vector topology by v.build."
+msgstr "Impossibile aprire il vettoriale <%s> sul livello %d. Provare a ricostruire la topologia con v.build."
 #: ../lib/vector/Vlib/open.c:362
 #, fuzzy, c-format
@@ -5039,9 +4824,7 @@
 #: ../lib/vector/Vlib/open.c:888
 msgid "Size of 'coor' file differs from value saved in topology file"
-msgstr ""
-"La dimensione del file 'coor' differisce dal valore salvato nel file di "
-"topologia"
+msgstr "La dimensione del file 'coor' differisce dal valore salvato nel file di topologia"
 #: ../lib/vector/Vlib/open.c:899 ../lib/vector/Vlib/open.c:993
 #, c-format
@@ -5051,14 +4834,10 @@
 #: ../lib/vector/Vlib/open.c:982
 #, fuzzy
 msgid "Size of 'coor' file differs from value saved in sidx file"
-msgstr ""
-"La dimensione del file 'coor' è diverso dal valore salvato nel file di "
-"topologia"
+msgstr "La dimensione del file 'coor' è diverso dal valore salvato nel file di topologia"
 #: ../lib/vector/Vlib/dgraph.c:430
-msgid ""
-"Trying to add more edges to the planar_graph than the initial allocation "
-"size allows"
+msgid "Trying to add more edges to the planar_graph than the initial allocation size allows"
 msgstr ""
 #: ../lib/vector/Vlib/area.c:47
@@ -5098,9 +4877,7 @@
 #: ../lib/vector/Vlib/cats.c:403
 #, c-format
 msgid "Unable to convert category string '%s' (from '%s') to category range"
-msgstr ""
-"Impossibile convertire la stringa '%s' della categoria (da '%s') al range "
-"della categoria"
+msgstr "Impossibile convertire la stringa '%s' della categoria (da '%s') al range della categoria"
 #: ../lib/vector/Vlib/graph.c:138
 msgid "Unable to add network arc"
@@ -5170,13 +4947,11 @@
 msgstr ""
 #: ../lib/vector/Vlib/buffer2.c:589
-msgid ""
-"Next edge was visited (right) but it is not the first one !!! breaking loop"
+msgid "Next edge was visited (right) but it is not the first one !!! breaking loop"
 msgstr ""
 #: ../lib/vector/Vlib/buffer2.c:600
-msgid ""
-"Next edge was visited (left) but it is not the first one !!! breaking loop"
+msgid "Next edge was visited (left) but it is not the first one !!! breaking loop"
 msgstr ""
 #: ../lib/vector/Vlib/buffer2.c:648
@@ -5238,19 +5013,13 @@
 #: ../lib/vector/Vlib/write.c:232
 #, c-format
-msgid ""
-"Unable to delete feature %d, vector map <%s> is not opened on topology level"
-msgstr ""
-"Impossibile cancellare l'elemento %d, il vettoriale <%s> non è aperto sul "
-"livello topologico"
+msgid "Unable to delete feature %d, vector map <%s> is not opened on topology level"
+msgstr "Impossibile cancellare l'elemento %d, il vettoriale <%s> non è aperto sul livello topologico"
 #: ../lib/vector/Vlib/write.c:238
 #, c-format
-msgid ""
-"Unable to delete feature %d, vector map <%s> is not opened in 'write' mode"
-msgstr ""
-"Impossibile cancellare l'elemento %d, il vettoriale <%s> non è aperta in "
-"modalità di scrittura"
+msgid "Unable to delete feature %d, vector map <%s> is not opened in 'write' mode"
+msgstr "Impossibile cancellare l'elemento %d, il vettoriale <%s> non è aperta in modalità di scrittura"
 #: ../lib/vector/Vlib/write.c:250
 #, fuzzy, c-format
@@ -5259,19 +5028,13 @@
 #: ../lib/vector/Vlib/write.c:276
 #, c-format
-msgid ""
-"Unable to restore feature %d, vector map <%s> is not opened on topology level"
-msgstr ""
-"Impossibile ristabilire l'elemento %d, il vettoriale <%s> non è aperto sul "
+msgid "Unable to restore feature %d, vector map <%s> is not opened on topology level"
+msgstr "Impossibile ristabilire l'elemento %d, il vettoriale <%s> non è aperto sul livello topologico"
 #: ../lib/vector/Vlib/write.c:282
 #, c-format
-msgid ""
-"Unable to restore feature %d, vector map <%s> is not opened in 'write' mode"
-msgstr ""
-"Impossibile ristabilire l'elemento %d, il vettoriale <%s> non è aperta in "
+msgid "Unable to restore feature %d, vector map <%s> is not opened in 'write' mode"
+msgstr "Impossibile ristabilire l'elemento %d, il vettoriale <%s> non è aperta in modalità di scrittura"
 #: ../lib/vector/Vlib/write.c:294
 #, c-format
@@ -5326,9 +5089,7 @@
 #: ../lib/vector/Vlib/field.c:92
 #, fuzzy
 msgid "Unable to add attribute link, vector map is not opened in WRITE mode"
-msgstr ""
-"Non riesco ad aprire un collegamento database, la mappa non è stata aperta "
-"in modalità di SCRITTURA."
+msgstr "Non riesco ad aprire un collegamento database, la mappa non è stata aperta in modalità di SCRITTURA."
 #: ../lib/vector/Vlib/field.c:99
 #, fuzzy
@@ -5350,9 +5111,7 @@
 msgstr "La connessione del database non è definita per il layer %d"
 #: ../lib/vector/Vlib/field.c:181
-msgid ""
-"More DB links defined for input vector map. Using only first DB link for "
-"output."
+msgid "More DB links defined for input vector map. Using only first DB link for output."
 msgstr ""
 #: ../lib/vector/Vlib/field.c:256
@@ -5383,12 +5142,8 @@
 msgstr "Impossibile aprire il driver OGR DBMI"
 #: ../lib/vector/Vlib/field.c:679
-msgid ""
-"All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' "
-"available in OGR DB table"
-msgstr ""
-"Fallimento di tutti i test FID. Nella tabella DB OGR non è presente nessuno "
-"di: 'FID', 'ogc_fid', 'ogr_fid', 'gid'"
+msgid "All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' available in OGR DB table"
+msgstr "Fallimento di tutti i test FID. Nella tabella DB OGR non è presente nessuno di: 'FID', 'ogc_fid', 'ogr_fid', 'gid'"
 #: ../lib/vector/Vlib/field.c:735
 #, c-format
@@ -5403,13 +5158,11 @@
 #: ../lib/vector/Vlib/field.c:852
 #, c-format
 msgid "Unable to open vector database definition file '%s'"
-msgstr ""
-"Impossibile aprire il file %s delle definizioni del database vettoriale"
+msgstr "Impossibile aprire il file %s delle definizioni del database vettoriale"
 #: ../lib/vector/Vlib/field.c:947
 msgid "Bug: attempt to update map which is not in current mapset"
-msgstr ""
 #: ../lib/vector/Vlib/remove_areas.c:89
 msgid "Area is composed of dead boundary"
@@ -5682,22 +5435,13 @@
 msgstr ""
 #: ../lib/rst/interp_float/segmen2d.c:118
-msgid ""
-"Taking too long to find points for interpolation - please change the region "
-"to area where your points are. Continuing calculations..."
-msgstr ""
-"La ricerca dei punti per l'interpolazione sta durando troppo - si modifichi "
-"la regione per includere l'area dove si trovano i punti. Continuando i "
-"calcoli..."
+msgid "Taking too long to find points for interpolation - please change the region to area where your points are. Continuing calculations..."
+msgstr "La ricerca dei punti per l'interpolazione sta durando troppo - si modifichi la regione per includere l'area dove si trovano i punti. Continuando i calcoli..."
 #: ../lib/rst/interp_float/interp2d.c:214
 #, c-format
-msgid ""
-"Overshoot - increase in tension suggested. Overshoot occures at (%d,%d) "
-"cell. Z-value %f, zmin %f, zmax %f."
-msgstr ""
-"Overshoot - si suggerisce un aumento della tensione. L'overshoot avviene "
-"alla cella (%d,%d). Z-value %f, zmin %f, zmax %f."
+msgid "Overshoot - increase in tension suggested. Overshoot occures at (%d,%d) cell. Z-value %f, zmin %f, zmax %f."
+msgstr "Overshoot - si suggerisce un aumento della tensione. L'overshoot avviene alla cella (%d,%d). Z-value %f, zmin %f, zmax %f."
 #: ../lib/rst/interp_float/input2d.c:48
 #, c-format
@@ -5766,8 +5510,7 @@
 #: ../lib/rst/interp_float/vinput2d.c:249
 #, c-format
 msgid "There are points outside specified 2D/3D region - %d points ignored"
-msgstr ""
-"Ci sono punti fuori dalla regione 2D/3D specificata - %d punti ignorati"
+msgstr "Ci sono punti fuori dalla regione 2D/3D specificata - %d punti ignorati"
 #: ../lib/rst/interp_float/vinput2d.c:252
 #, c-format
@@ -5776,9 +5519,7 @@
 #: ../lib/rst/interp_float/vinput2d.c:256
 #, c-format
-msgid ""
-"%d points given for interpolation (after thinning) is less than given NPMIN="
-"%d"
+msgid "%d points given for interpolation (after thinning) is less than given NPMIN=%d"
 msgstr ""
 #: ../lib/rst/interp_float/vinput2d.c:261
@@ -5787,22 +5528,13 @@
 #: ../lib/rst/interp_float/vinput2d.c:266
 #, c-format
-msgid ""
-"Segmentation parameters set to invalid values: npmin= %d, segmax= %d for "
-"smooth connection of segments, npmin > segmax (see manual)"
-msgstr ""
-"Parametri di segmentazione impostati a valori non validi: npmin= %d, segmax= "
-"%d per connessione continua dei segmenti, npmin > segmax (consultare il "
-"manuale)"
+msgid "Segmentation parameters set to invalid values: npmin= %d, segmax= %d for smooth connection of segments, npmin > segmax (see manual)"
+msgstr "Parametri di segmentazione impostati a valori non validi: npmin= %d, segmax= %d per connessione continua dei segmenti, npmin > segmax (consultare il manuale)"
 #: ../lib/rst/interp_float/vinput2d.c:272
 #, c-format
-msgid ""
-"There are less than %d points for interpolation. No segmentation is "
-"necessary, to run the program faster set segmax=%d (see manual)"
-msgstr ""
-"Ci sono meno di %d punti per l'interpolazione. Non è richiesta "
-"segmentazione, per accelerare il programma impostare segmax=%d (cfr. manuale)"
+msgid "There are less than %d points for interpolation. No segmentation is necessary, to run the program faster set segmax=%d (see manual)"
+msgstr "Ci sono meno di %d punti per l'interpolazione. Non è richiesta segmentazione, per accelerare il programma impostare segmax=%d (cfr. manuale)"
 #: ../lib/rst/interp_float/vinput2d.c:276
 #, c-format
@@ -6103,12 +5835,8 @@
 msgstr "G_getenv(): variabile %s non impostata"
 #: ../lib/gis/gisinit.c:50 ../lib/gis/gisinit.c:82
-msgid ""
-"Incompatible library version for module. You need to rebuild GRASS or "
-"untangle multiple installations."
-msgstr ""
-"Versione incompatibile della libreria per il modulo. È necessario "
-"ricompilare GRASS o eliminare i conflitti tra installazioni multiple."
+msgid "Incompatible library version for module. You need to rebuild GRASS or untangle multiple installations."
+msgstr "Versione incompatibile della libreria per il modulo. È necessario ricompilare GRASS o eliminare i conflitti tra installazioni multiple."
 #: ../lib/gis/gisinit.c:60
 #, c-format
@@ -6122,9 +5850,7 @@
 #: ../lib/gis/gisinit.c:96
 msgid "System not initialized. Programmer forgot to call G_gisinit()."
-msgstr ""
-"Sistema non inizializzato. Il programmatore si è scordato di usare la "
-"funzione G_gisinit()."
+msgstr "Sistema non inizializzato. Il programmatore si è scordato di usare la funzione G_gisinit()."
 #: ../lib/gis/seek.c:52 ../lib/gis/seek.c:58
 msgid "Unable to seek"
@@ -6153,9 +5879,7 @@
 #: ../lib/gis/adj_cellhd.c:76 ../lib/gis/adj_cellhd.c:240
 #, c-format
 msgid "Fixing subtle input data rounding error of north boundary (%g>%g)"
-msgstr ""
-"Risolto leggero errore di arrotondamento del dato in input del confine nord "
-"(%g>%g)"
+msgstr "Risolto leggero errore di arrotondamento del dato in input del confine nord (%g>%g)"
 #: ../lib/gis/adj_cellhd.c:81 ../lib/gis/adj_cellhd.c:245
 msgid "Illegal latitude for North"
@@ -6164,9 +5888,7 @@
 #: ../lib/gis/adj_cellhd.c:87 ../lib/gis/adj_cellhd.c:251
 #, c-format
 msgid "Fixing subtle input data rounding error of south boundary (%g>%g)"
-msgstr ""
-"Risolto leggero errore di arrotondamento del dato in input del confine sud "
-"(%g>%g)"
+msgstr "Risolto leggero errore di arrotondamento del dato in input del confine sud (%g>%g)"
 #: ../lib/gis/adj_cellhd.c:92 ../lib/gis/adj_cellhd.c:256
 msgid "Illegal latitude for South"
@@ -6175,16 +5897,12 @@
 #: ../lib/gis/adj_cellhd.c:104 ../lib/gis/adj_cellhd.c:268
 #, c-format
 msgid "Fixing subtle input data rounding error of west boundary (%g>%g)"
-msgstr ""
-"Risolto leggero errore di arrotondamento del dato in input del confine ovest "
-"(%g>%g)"
+msgstr "Risolto leggero errore di arrotondamento del dato in input del confine ovest (%g>%g)"
 #: ../lib/gis/adj_cellhd.c:115 ../lib/gis/adj_cellhd.c:279
 #, c-format
 msgid "Fixing subtle input data rounding error of east boundary (%g>%g)"
-msgstr ""
-"Risolto leggero errore di arrotondamento del dato in input del confine est "
-"(%g>%g)"
+msgstr "Risolto leggero errore di arrotondamento del dato in input del confine est (%g>%g)"
 #: ../lib/gis/adj_cellhd.c:128 ../lib/gis/adj_cellhd.c:292
 msgid "North must be north of South"
@@ -6262,15 +5980,11 @@
 #: ../lib/gis/parser.c:484
 msgid "Use either --quiet or --verbose flag, not both. Assuming --verbose."
-msgstr ""
-"Usare una sola delle due flag --quiet o --verbose, non entrambe. Scelta "
-"automatica: --verbose."
+msgstr "Usare una sola delle due flag --quiet o --verbose, non entrambe. Scelta automatica: --verbose."
 #: ../lib/gis/parser.c:498
 msgid "Use either --quiet or --verbose flag, not both. Assuming --quiet."
-msgstr ""
-"automatica: --quiet."
+msgstr "Usare una sola delle due flag --quiet o --verbose, non entrambe. Scelta automatica: --quiet."
 #: ../lib/gis/parser.c:529
 #, fuzzy, c-format
@@ -6754,8 +6468,7 @@
 msgstr "Nome database"
 #: ../lib/gis/parser_standard_options.c:148
-msgid ""
-"Do not use this option if schemas are not supported by driver/database server"
+msgid "Do not use this option if schemas are not supported by driver/database server"
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:157
@@ -6854,9 +6567,7 @@
 msgstr "Tipo dati usato nel file di output"
 #: ../lib/gis/parser_standard_options.c:335
-msgid ""
-"Number of digits used as mantissa in the internal map storage, 0 -23 for "
-"float, 0 - 52 for double, max or default"
+msgid "Number of digits used as mantissa in the internal map storage, 0 -23 for float, 0 - 52 for double, max or default"
 msgstr ""
 #: ../lib/gis/parser_standard_options.c:345
@@ -6866,9 +6577,7 @@
 #: ../lib/gis/parser_standard_options.c:355
 #, fuzzy
-msgid ""
-"The dimensions of the tiles used in the output raster3d map (XxYxZ or "
-"default: 16x16x8)"
+msgid "The dimensions of the tiles used in the output raster3d map (XxYxZ or default: 16x16x8)"
 msgstr "I dimensioni dei tile usati nel file di output"
 #: ../lib/gis/parser_standard_options.c:365
@@ -6915,13 +6624,8 @@
 #: ../lib/gis/parser_standard_options.c:429
 #: ../lib/gis/parser_standard_options.c:441
 #, fuzzy
-msgid ""
-"A single vector map can be connected to multiple database tables. This "
-"number determines which table to use. When used with direct OGR access this "
-"is the layer name."
-msgstr ""
-"Una singola mappa vettoriale può essere connessa a database multiple. Questo "
-"numero determina quale tabella viene usata."
+msgid "A single vector map can be connected to multiple database tables. This number determines which table to use. When used with direct OGR access this is the layer name."
+msgstr "Una singola mappa vettoriale può essere connessa a database multiple. Questo numero determina quale tabella viene usata."
 #: ../lib/gis/parser_standard_options.c:439
 #, fuzzy
@@ -7040,17 +6744,12 @@
 #: ../lib/gis/view.c:545
 #, c-format
 msgid " Window saved in \"%s\" is completely outside of current GRASS window."
-msgstr ""
-" La finestra salvata in \"%s\" è completamente al di fuori della finestra "
-"GRASS attualmente in uso."
+msgstr " La finestra salvata in \"%s\" è completamente al di fuori della finestra GRASS attualmente in uso."
 #: ../lib/gis/view.c:549
 #, c-format
-msgid ""
-" Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
-msgstr ""
-" Solo  %d%% della finestra salvata in \"%s\" si sovrappone con la finestra "
-"GRASS in uso"
+msgid " Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
+msgstr " Solo  %d%% della finestra salvata in \"%s\" si sovrappone con la finestra GRASS in uso"
 #: ../lib/gis/parser_html.c:40
 msgid "NAME"
@@ -7279,44 +6978,51 @@
 #: ../lib/db/dbmi_base/legal_dbname.c:38
 #, fuzzy, c-format
 msgid "Illegal table map name <%s>. May not contain '.' or 'NULL'."
-msgstr ""
-"Nome della tabella della mappa <%s> non valido. Non deve contenere '.' o "
-"'NULL'.\n"
+msgstr "Nome della tabella della mappa <%s> non valido. Non deve contenere '.' o 'NULL'.\n"
 #: ../lib/db/dbmi_base/legal_dbname.c:45
 #, fuzzy, c-format
 msgid "Illegal table map name <%s>. Must start with a letter."
-msgstr ""
-"Nome della tabella della mappa <%s> non valido. Deve iniziare con una "
-"lettera.\n"
+msgstr "Nome della tabella della mappa <%s> non valido. Deve iniziare con una lettera.\n"
 #: ../lib/db/dbmi_base/legal_dbname.c:54
 #, fuzzy, c-format
 msgid "Illegal table map name <%s>. Character <%c> not allowed."
-msgstr ""
-"Il nome <%s> non è valido per una mappa vettoriale. Il carattere <%c> non è "
-"permesso.\n"
+msgstr "Il nome <%s> non è valido per una mappa vettoriale. Il carattere <%c> non è permesso.\n"
 #: ../lib/db/dbmi_base/xdrvalue.c:82
 msgid "send data: invalid C-type"
 msgstr ""
 #, fuzzy
-#~ msgid "Unable to open null device"
-#~ msgstr "Impossibile aprire %s"
+msgid "Unable to open null device"
+msgstr "Impossibile aprire %s"
 #, fuzzy
-#~ msgid "The support for OGR vector maps wasn't compiled in"
-#~ msgstr ""
-#~ "categoria di supporto per il file vettoriale [%s] nel mapset [%s] %s"
+msgid "The support for OGR vector maps wasn't compiled in"
+msgstr "categoria di supporto per il file vettoriale [%s] nel mapset [%s] %s"
-#~ msgid "Partial build for OGR is not supported"
-#~ msgstr "Build parziale per OGR non supportato"
+#, fuzzy
+msgid "End time must be later than start time"
+msgstr "L'Est deve essere più grande dell'Ovest"
 #, fuzzy
-#~ msgid "End time must be later than start time"
-#~ msgstr "L'Est deve essere più grande dell'Ovest"
+msgid "None"
+msgstr "nessuno"
+#, fuzzy
+msgid "Unknown"
+msgstr "sconosciuto"
+#, fuzzy
+msgid "Uknown column <%s>"
+msgstr ""
+"\n"
+"Comando sconosciuto: %d ultimo: %d\n"
+#~ msgid "Partial build for OGR is not supported"
+#~ msgstr "Build parziale per OGR non supportato"
 #~ msgid "Memory error in allocating timestamp"
 #~ msgstr "Errore di memoria nell'allocare il timestamp"
@@ -7326,20 +7032,6 @@
 #~ msgid "Cannot select attributes"
 #~ msgstr "Non è possibile selezionare attributi"
-#, fuzzy
-#~ msgid "None"
-#~ msgstr "nessuno"
-#, fuzzy
-#~ msgid "Unknown"
-#~ msgstr "sconosciuto"
-#, fuzzy
-#~ msgid "Uknown column <%s>"
-#~ msgstr ""
-#~ "\n"
-#~ "Comando sconosciuto: %d ultimo: %d\n"
 #~ msgid "projection field missing"
 #~ msgstr "campo proiezione mancante"
@@ -7522,12 +7214,8 @@
 #~ msgid "Cannot write quant rules for map %s"
 #~ msgstr "Non riesco a scrivere le regole quant per la mappa %s"
-#~ msgid ""
-#~ "G_set_window(): projection/zone differs from that of currently open "
-#~ "raster maps"
-#~ msgstr ""
-#~ "G_set_window(): la proiezione/zona differisce da quella del raster "
-#~ "attualmente aperto"
+#~ msgid "G_set_window(): projection/zone differs from that of currently open raster maps"
+#~ msgstr "G_set_window(): la proiezione/zona differisce da quella del raster attualmente aperto"
 #~ msgid "The floating data range for %s@%s is empty"
 #~ msgstr "Il valore floating per l'intervallo %s@%s è vuoto"
@@ -7566,8 +7254,7 @@
 #~ msgstr "categoria di supporto per [%s] nel mapset [%s] %s"
 #~ msgid "category support for vector map [%s] in mapset [%s] %s"
-#~ msgstr ""
+#~ msgstr "categoria di supporto per il file vettoriale [%s] nel mapset [%s] %s"
 #~ msgid "%s not found"
 #~ msgstr "%s non trovato"
@@ -7630,12 +7317,8 @@
 #~ msgid "Layer number"
 #~ msgstr "Numero layer"
-#~ msgid ""
-#~ "A single vector map can be connected to multiple database tables. This "
-#~ "number determines which table to use."
-#~ msgstr ""
-#~ "Un singolo vettoriale può essere connessa a database multiple. Questo "
-#~ "numero determina quale tabella viene usata."
+#~ msgid "A single vector map can be connected to multiple database tables. This number determines which table to use."
+#~ msgstr "Un singolo vettoriale può essere connessa a database multiple. Questo numero determina quale tabella viene usata."
 #~ msgid "Sorry <%s> is not a valid option\n"
 #~ msgstr "Mi spiace <%s> non è una opzione valida\n"
@@ -7808,8 +7491,7 @@
 #~ msgstr "timestamp specificato non valido per %s mappa %s nel mapset %s"
 #~ msgid "Can't open timestamp file for %s map %s in mapset %s"
-#~ msgstr ""
-#~ "Non riesco ad aprire il file timestamp %s per la mappa %s nel mapset %s"
+#~ msgstr "Non riesco ad aprire il file timestamp %s per la mappa %s nel mapset %s"
 #~ msgid "Can not create a new process!"
 #~ msgstr "impossibile creare un nuovo processo!"
@@ -7946,9 +7628,7 @@
 #~ msgstr "Troppe categorie di riclassificazione per [%s in %s]"
 #~ msgid "Illegal reclass format in header file for [%s in %s]"
-#~ msgstr ""
-#~ "Formato illegale di riclassificazione nel file di intestazione per [%s in "
-#~ "%s]"
+#~ msgstr "Formato illegale di riclassificazione nel file di intestazione per [%s in %s]"
 #~ msgid "Unable to create header file for [%s in %s]"
 #~ msgstr "Impossibile creare il file di intestazione per [%s in %s]"
@@ -7985,12 +7665,8 @@
 #~ msgid "Unable to get GIS_LOCK enviroment variable value"
 #~ msgstr "Impossibile ottenere il valore della variabile d'ambiente GIS_LOCK"
-#~ msgid ""
-#~ "G_distance_point_to_line_segment: shouldn't happen: code=%d P=(%f,%f) S="
-#~ "(%f,%f)(%f,%f)"
-#~ msgstr ""
-#~ "G_distance_point_to_line_segment: non dovrebbe accadere: code=%d P=(%f,"
-#~ "%f) S=(%f,%f)(%f,%f)"
+#~ msgid "G_distance_point_to_line_segment: shouldn't happen: code=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
+#~ msgstr "G_distance_point_to_line_segment: non dovrebbe accadere: code=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
 #~ msgid "G_malloc: unable to allocate %lu bytes at %s:%d"
 #~ msgstr "G_malloc: impossibile allocare %lu bytes a %s:%d"
@@ -8007,25 +7683,17 @@
 #~ msgid "Unable to find <%s@%s>"
 #~ msgstr "Impossibile trovare <%s@%s>"
-#~ msgid ""
-#~ "Raster map <%s@%s> is in different projection than current region. Found "
-#~ "raster map <%s@%s>, should be <%s>."
-#~ msgstr ""
-#~ "Raster <%s@%s> ha una proiezione differente rispetto alla regione "
-#~ "attualmente in uso:. Il raster trovato <%s@%s>, dovrebbe essere <%s>."
+#~ msgid "Raster map <%s@%s> is in different projection than current region. Found raster map <%s@%s>, should be <%s>."
+#~ msgstr "Raster <%s@%s> ha una proiezione differente rispetto alla regione attualmente in uso:. Il raster trovato <%s@%s>, dovrebbe essere <%s>."
-#~ msgid ""
-#~ "Raster map <%s@%s> is in different zone (%d) than current region (%d)"
+#~ msgid "Raster map <%s@%s> is in different zone (%d) than current region (%d)"
 #~ msgstr "Il raster <%s@%s> è in zona (%d) diversa dalla regione in uso (%d)"
 #~ msgid "Raster map <%s@%s>: bytes per cell (%d) too large"
 #~ msgstr "Il raster <%s@%s>: byte per cella (%d) troppo grande"
-#~ msgid ""
-#~ "map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
-#~ msgstr ""
-#~ "la mappa <%s@%s> è un link a GDAL, ma GRASS è stato compilato senza il "
-#~ "supporto a GDAL"
+#~ msgid "map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
+#~ msgstr "la mappa <%s@%s> è un link a GDAL, ma GRASS è stato compilato senza il supporto a GDAL"
 #~ msgid "<%s>: bad mapset"
 #~ msgstr "<%s>: mapset non valido"
@@ -8033,14 +7701,11 @@
 #~ msgid "G__open_raster_new(): no temp files available"
 #~ msgstr "G__open_raster_new(): non sono disponibili file temporanei"
-#~ msgid ""
-#~ "Unable to write embedded null values for raster map open for random access"
-#~ msgstr ""
-#~ "Non riesco a scrivere valori nulli nel raster aperto con accesso casuale"
+#~ msgid "Unable to write embedded null values for raster map open for random access"
+#~ msgstr "Non riesco a scrivere valori nulli nel raster aperto con accesso casuale"
 #~ msgid "G_set_fp_type(): can only be called with FCELL_TYPE or DCELL_TYPE"
-#~ msgstr ""
-#~ "G_set_fp_type(): può essere chiamato solo con FCELL_TYPE o DCELL_TYPE"
+#~ msgstr "G_set_fp_type(): può essere chiamato solo con FCELL_TYPE o DCELL_TYPE"
 #~ msgid "Unable to find '%s' in '%s'"
 #~ msgstr "Impossibile trovare '%s' in '%s'"
@@ -8048,11 +7713,8 @@
 #~ msgid "Unable to open '%s'"
 #~ msgstr "Impossibile aprire '%s'"
-#~ msgid ""
-#~ "G_set_quant_rules() can be called only for raster maps opened for reading"
-#~ msgstr ""
-#~ "G_set_quant_rules() può essere chiamato solo per le mappe raster aperte "
-#~ "in lettura"
+#~ msgid "G_set_quant_rules() can be called only for raster maps opened for reading"
+#~ msgstr "G_set_quant_rules() può essere chiamato solo per le mappe raster aperte in lettura"
 #~ msgid "Enter 'list' for the list of available datums\n"
 #~ msgstr "Digita 'list' per la lista dei datum disponibili\n"
@@ -8164,9 +7826,7 @@
 #~ msgstr "È una riclassificazione del raster <%s@%s>"
 #~ msgid " It is a reclass of raster map <%s@%s> whose header file is invalid."
-#~ msgstr ""
-#~ "È una riclassificazione del raster <%s@%s> il cui file header non è "
-#~ "valido."
+#~ msgstr "È una riclassificazione del raster <%s@%s> il cui file header non è valido."
 #~ msgid " Invalid format."
 #~ msgstr "Formato non valido."
@@ -8175,14 +7835,10 @@
 #~ msgstr "non riesco a scrivere le informazioni dello storico per [%s]"
 #~ msgid "Not enough room in history file to record command line."
-#~ msgstr ""
-#~ "Insufficiente spazio nel file della history per salvare la riga di "
-#~ "comando."
+#~ msgstr "Insufficiente spazio nel file della history per salvare la riga di comando."
 #~ msgid "Not enough room in history file for command line (truncated)."
-#~ msgstr ""
-#~ "comando (troncato)."
+#~ msgstr "Insufficiente spazio nel file della history per salvare la riga di comando (troncato)."
 #~ msgid "Graphics driver [%s] started"
 #~ msgstr "Driver grafico [%s] avviato"
@@ -8196,12 +7852,8 @@
 #~ msgid "not implemented"
 #~ msgstr "non implementato"
-#~ msgid ""
-#~ "Unable to build spatial index from topology, vector map is not opened at "
-#~ "topo level 2"
-#~ msgstr ""
-#~ "Impossibile costruire l'indice spaziale dalla topologia, il vettoriale "
-#~ "non è aperto al livello 2 della topologia"
+#~ msgid "Unable to build spatial index from topology, vector map is not opened at topo level 2"
+#~ msgstr "Impossibile costruire l'indice spaziale dalla topologia, il vettoriale non è aperto al livello 2 della topologia"
 #~ msgid "BUG (Vect_build_sidx_from_topo): node does not exist"
 #~ msgstr "BUG (Vect_build_sidx_from_topo): nodo inesistente"
@@ -8210,9 +7862,7 @@
 #~ msgstr "%d errori nella stringa della categoria"
 #~ msgid "Unable to add database link, map is not opened in WRITE mode"
-#~ msgstr ""
-#~ "Impossibile aprire il collegamento al database, la mappa non è stata "
-#~ "aperta in modalità di SCRITTURA"
+#~ msgstr "Impossibile aprire il collegamento al database, la mappa non è stata aperta in modalità di SCRITTURA"
 #~ msgid "Unable to add database link"
 #~ msgstr "Impossibile aggiungere un collegamento database"
@@ -8223,19 +7873,11 @@
 #~ msgid "Unknown keyword %s in vector head"
 #~ msgstr "Parola chiave %s sconosciuta nell'header del vettoriale"
-#~ msgid ""
-#~ "Coor files of vector map <%s@%s> is larger than it should be (%ld bytes "
-#~ "excess)"
-#~ msgstr ""
-#~ "Il file coor del vettoriale <%s@%s> è più grande dell'atteso (%ld bytes "
-#~ "in eccesso)"
+#~ msgid "Coor files of vector map <%s@%s> is larger than it should be (%ld bytes excess)"
+#~ msgstr "Il file coor del vettoriale <%s@%s> è più grande dell'atteso (%ld bytes in eccesso)"
-#~ msgid ""
-#~ "Coor files of vector <%s@%s> is shorter than it should be (%ld bytes "
-#~ "missing)."
-#~ msgstr ""
-#~ "Il file coor del vettoriale <%s@%s> è più piccolo dell'atteso (%ld bytes "
-#~ "mancanti)"
+#~ msgid "Coor files of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
+#~ msgstr "Il file coor del vettoriale <%s@%s> è più piccolo dell'atteso (%ld bytes mancanti)"
 #~ msgid "Intersections: %5d"
 #~ msgstr "Intersezione: %5d"
@@ -8253,15 +7895,10 @@
 #~ msgstr "Impossibile aprire il layer <%s>"
 #~ msgid "Unable to open category index file for vector map <%s@%s>"
-#~ msgstr ""
-#~ "Impossibile aprire il file di indici di categoria per il vettoriale <%s@"
-#~ "%s>"
+#~ msgstr "Impossibile aprire il file di indici di categoria per il vettoriale <%s@%s>"
-#~ msgid ""
-#~ "Random read is not supported by OGR for this layer, cannot build support"
-#~ msgstr ""
-#~ "Lettura random non è supportata da OGR per questo layer, non è possibile "
-#~ "costruire supporto"
+#~ msgid "Random read is not supported by OGR for this layer, cannot build support"
+#~ msgstr "Lettura random non è supportata da OGR per questo layer, non è possibile costruire supporto"
 #~ msgid "Feature: "
 #~ msgstr "Elemento: "
@@ -8290,11 +7927,8 @@
 #~ msgid "Matrix is not symmetric!"
 #~ msgstr "La matrice non è simmetrica!"
-#~ msgid ""
-#~ "Maximum number of iteration used to solver the linear equation system"
-#~ msgstr ""
-#~ "Numero massimo di iterazioni utilizzato per risolvere il sistema di "
-#~ "equazioni lineari"
+#~ msgid "Maximum number of iteration used to solver the linear equation system"
+#~ msgstr "Numero massimo di iterazioni utilizzato per risolvere il sistema di equazioni lineari"
 #~ msgid "test, gpde"
 #~ msgstr "test, gpde"
@@ -8333,8 +7967,7 @@
 #~ msgstr "G3d_openCellOld: errore in G3d_readHeader"
 #~ msgid "G3d_openCellOld: projection does not match window projection"
-#~ msgstr ""
-#~ "G3d_openCellOld: proiezione non corrisponde alla proiezione della finestra"
+#~ msgstr "G3d_openCellOld: proiezione non corrisponde alla proiezione della finestra"
 #~ msgid "G3d_openCellOld: zone does not match window zone"
 #~ msgstr "G3d_openCellOld: zona non corrisponde alla zona della finestra"
@@ -8367,16 +8000,39 @@
 #~ msgstr "G3d_openCellNew: errore in G3d_fillHeader"
 #~ msgid "Illegal table map name <%s>. May not contain '.' or 'NULL'.\n"
-#~ msgstr ""
-#~ "Nome della tabella della mappa <%s> non valido. Non deve contenere '.' o "
-#~ "'NULL'.\n"
+#~ msgstr "Nome della tabella della mappa <%s> non valido. Non deve contenere '.' o 'NULL'.\n"
 #~ msgid "Illegal table map name <%s>. Must start with a letter.\n"
-#~ msgstr ""
-#~ "Nome della tabella della mappa <%s> non valido. Deve iniziare con una "
-#~ "lettera.\n"
+#~ msgstr "Nome della tabella della mappa <%s> non valido. Deve iniziare con una lettera.\n"
 #~ msgid "Illegal table map name <%s>. Character <%c> not allowed.\n"
+#~ msgstr "Il nome <%s> non è valido per un vettoriale. Il carattere <%c> non è permesso.\n"
+#~ msgid "Unable to allocate memory for a null buffer"
+#~ msgstr "Impossibile allocare memoria per buffer nulla"
+#~ msgid "Vector map <%s> is not open on level >= 2"
+#~ msgstr "Il vettoriale <%s> non è aperto sul livello >= 2"
+#~ msgid "%s is not in the current mapset (%s)"
+#~ msgstr "%s non è disponibile nel mapset in uso (%s)"
+#~ msgid ""
+#~ "\n"
+#~ "Please specify ellipsoid name\n"
 #~ msgstr ""
-#~ "Il nome <%s> non è valido per un vettoriale. Il carattere <%c> non è "
-#~ "permesso.\n"
+#~ "\n"
+#~ "Per piacere specifica il nome dell'ellissoide\n"
+#~ msgid "Can't create timestamp file for %s map %s in mapset %s"
+#~ msgstr "Non riesco a creare il file %s di timestamp per la mappa %s nel mapset %s"
+#~ msgid "Invalid timestamp file for %s map %s in mapset %s"
+#~ msgstr "timestamp non valido nel file per %s mappa %s nel mapset %s"
+#~ msgid ""
+#~ "\n"
+#~ "Please specify datum name\n"
+#~ msgstr ""
+#~ "\n"
+#~ "Per piacere specifica il nome del datum\n"
Modified: grass/trunk/locale/po/grassmods_it.po
--- grass/trunk/locale/po/grassmods_it.po	2012-01-30 18:05:33 UTC (rev 50565)
+++ grass/trunk/locale/po/grassmods_it.po	2012-01-30 18:06:12 UTC (rev 50566)
@@ -8,20 +8,20 @@
 # Giuseppe Patti <gpatt at tiscali.it>, 2006.
 # Stefano Costa <steko at iosa.it>, 2006.
 # Luca Delucchi <lucadeluge at gmail.com>, 2008.
-# Marco Curreli <marcocurreli at tiscali it>, 2011.
+# Marco Curreli <marcocurreli at tiscali it>, 2011, 2012.
 msgid ""
 msgstr ""
 "Project-Id-Version: grassmods_it\n"
 "Report-Msgid-Bugs-To: \n"
 "POT-Creation-Date: 2012-01-28 11:12+0100\n"
-"PO-Revision-Date: 2012-01-27 00:30+0100\n"
+"PO-Revision-Date: 2012-01-29 21:12+0100\n"
 "Last-Translator: Marco Curreli <marcocurreli at tiscali.it>\n"
 "Language-Team: Italian <grass-translations at lists.osgeo.org>\n"
 "Language: it\n"
 "MIME-Version: 1.0\n"
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
-"X-Generator: KBabel 1.11.4\n"
+"X-Generator: Lokalize 1.4\n"
 "Plural-Forms: nplurals=2; plural=(n != 1);\n"
 "X-Poedit-Bookmarks: 1765,2474,415,1273,-1,-1,-1,-1,-1,-1\n"
 "X-Poedit-Language: Italian\n"
@@ -570,9 +570,9 @@
 #: ../vector/v.extrude/main.c:166 ../vector/v.generalize/misc.c:162
 #: ../vector/v.drape/main.c:228 ../vector/v.surf.bspline/crosscorr.c:109
 #: ../vector/v.to.rast/support.c:127 ../vector/v.to.rast/support.c:284
-#, fuzzy, c-format
+#, c-format
 msgid "Database connection not defined for layer %d"
-msgstr "Connessione al database non definita per il tematismo %d"
+msgstr "Connessione al database non definita per il layer %d"
 #: ../doc/vector/v.example/main.c:126 ../display/d.vect/opt.c:147
 #: ../display/d.thematic.area/main.c:200 ../vector/v.edit/select.c:506
@@ -652,8 +652,7 @@
 #: ../doc/vector/v.example/main.c:212
 #, c-format
 msgid "Unable to copy attribute table to vector map <%s>"
-msgstr ""
-"Impossibile copiare la tabella degli attributi nella mappa vettoriale <%s>"
+msgstr "Impossibile copiare la tabella degli attributi nella mappa vettoriale <%s>"
 #: ../raster3d/r3.mask/main.c:57 ../raster3d/r3.null/main.c:102
 #: ../raster3d/r3.out.ascii/main.c:330 ../raster3d/r3.out.v5d/main.c:309
@@ -726,8 +725,7 @@
 msgid "Cannot create mask file: RASTER3D_MASK already exists"
 msgstr ""
 "Impossibile creare la mask. MASK RASTER3D già esistente!\n"
-"Usa il comando 'g.remove rast3d=RASTER3D MASK' per rimuovere la maschera "
-"esistente"
+"Usa il comando 'g.remove rast3d=RASTER3D MASK' per rimuovere la maschera esistente"
 #: ../raster3d/r3.retile/main.c:54
 #, fuzzy
@@ -857,8 +855,7 @@
 #: ../raster3d/r3.info/r3.info.main.c:98
 msgid "Print 3D raster map resolution (NS-res, EW-res, TB-res) only"
-msgstr ""
-"Stampa solo la risoluzione della mappa raster 3D (NS-res, EW-res, TB-res)"
+msgstr "Stampa solo la risoluzione della mappa raster 3D (NS-res, EW-res, TB-res)"
 #: ../raster3d/r3.info/r3.info.main.c:102
 msgid "Print 3D raster map type (float/double) only"
@@ -879,9 +876,7 @@
 #: ../raster3d/r3.info/r3.info.main.c:119
 msgid "Print 3D raster map timestamp (day.month.year hour:minute:seconds) only"
-msgstr ""
-"Stampa esclusivamente il timestamp (giorno.mese.anno ora:minuti:secondi) di "
-"un raster 3D"
+msgstr "Stampa esclusivamente il timestamp (giorno.mese.anno ora:minuti:secondi) di un raster 3D"
 #: ../raster3d/r3.info/r3.info.main.c:128
 #, c-format
@@ -941,30 +936,22 @@
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:60
-msgid ""
-"Input 3D raster map providing the status for each cell, = 0 - inactive, 1 - "
-"active, 2 - dirichlet"
+msgid "Input 3D raster map providing the status for each cell, = 0 - inactive, 1 - active, 2 - dirichlet"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:65
 #, fuzzy
-msgid ""
-"Input 3D raster map with the x-part of the hydraulic conductivity tensor in "
-"[m/s]"
+msgid "Input 3D raster map with the x-part of the hydraulic conductivity tensor in [m/s]"
 msgstr "Nome del driver in output"
 #: ../raster3d/r3.gwflow/main.c:70
 #, fuzzy
-msgid ""
-"Input 3D raster map with the y-part of the hydraulic conductivity tensor in "
-"[m/s]"
+msgid "Input 3D raster map with the y-part of the hydraulic conductivity tensor in [m/s]"
 #: ../raster3d/r3.gwflow/main.c:75
 #, fuzzy
-msgid ""
-"Input 3D raster map with the z-part of the hydraulic conductivity tensor in "
-"[m/s]"
+msgid "Input 3D raster map with the z-part of the hydraulic conductivity tensor in [m/s]"
 #: ../raster3d/r3.gwflow/main.c:80
@@ -984,36 +971,27 @@
 #: ../raster3d/r3.gwflow/main.c:93
 #, fuzzy
-msgid ""
-"Output 3D raster map storing the piezometric head result of the numerical "
-"calculation"
+msgid "Output 3D raster map storing the piezometric head result of the numerical calculation"
 msgstr "Mostra il titolo del file raster"
 #: ../raster3d/r3.gwflow/main.c:99
 #, fuzzy
-msgid ""
-"Output 3D raster map storing the groundwater filter velocity vector part in "
-"x direction [m/s]"
+msgid "Output 3D raster map storing the groundwater filter velocity vector part in x direction [m/s]"
 #: ../raster3d/r3.gwflow/main.c:105
 #, fuzzy
-msgid ""
-"y direction [m/s]"
+msgid "Output 3D raster map storing the groundwater filter velocity vector part in y direction [m/s]"
 #: ../raster3d/r3.gwflow/main.c:111
 #, fuzzy
-msgid ""
-"z direction [m/s]"
+msgid "Output 3D raster map storing the groundwater filter velocity vector part in z direction [m/s]"
 #: ../raster3d/r3.gwflow/main.c:117
 #, fuzzy
-msgid ""
-"Output 3D raster map Storing the groundwater budget for each cell [m^3/s]\n"
+msgid "Output 3D raster map Storing the groundwater budget for each cell [m^3/s]\n"
 #: ../raster3d/r3.gwflow/main.c:127
@@ -1022,9 +1000,7 @@
 msgstr "Usa una mask RASTER3D (se esiste)"
 #: ../raster3d/r3.gwflow/main.c:131 ../raster/r.solute.transport/main.c:192
-msgid ""
-"Use a full filled quadratic linear equation system, default is a sparse "
-"linear equation system."
+msgid "Use a full filled quadratic linear equation system, default is a sparse linear equation system."
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:161 ../raster/r.uslek/main.c:54
@@ -1055,9 +1031,7 @@
 msgstr "Nome del file con il risultato della classificazione"
 #: ../raster3d/r3.gwflow/main.c:165
-msgid ""
-"Numerical calculation program for transient, confined groundwater flow in "
-"three dimensions"
+msgid "Numerical calculation program for transient, confined groundwater flow in three dimensions"
 msgstr ""
 #: ../raster3d/r3.gwflow/main.c:182
@@ -1081,12 +1055,8 @@
 msgstr "Errore nella chiusura del file g3d"
 #: ../raster3d/r3.mkdspf/main.c:82
-msgid ""
-"Creates a display file from an existing grid3 file according to specified "
-"threshold levels."
-msgstr ""
-"Crea un file display da un file grid3 in base ai livelli di soglia "
-"specificati."
+msgid "Creates a display file from an existing grid3 file according to specified threshold levels."
+msgstr "Crea un file display da un file grid3 in base ai livelli di soglia specificati."
 #: ../raster3d/r3.mkdspf/main.c:90
 msgid "Name of an existing 3d raster map"
@@ -1192,10 +1162,8 @@
 msgid "Print grass6 compatible format. Flags -d and -r are ignored."
 msgstr ""
-# maschera o mask ?
 #: ../raster3d/r3.out.ascii/main.c:124 ../raster3d/r3.to.rast/main.c:91
 #: ../raster3d/r3.cross.rast/main.c:109
-#, fuzzy
 msgid "Use 3D raster mask (if exists) with input map"
 msgstr "Usa una maschera raster 3D (se esiste) con la mappa in input"
@@ -1282,12 +1250,8 @@
 #: ../raster3d/r3.to.rast/main.c:96
 #, fuzzy
-msgid ""
-"Use the same resolution as the input 3D raster map for the 2D output maps, "
-"independent of the current region settings"
-msgstr ""
-"Utilizza la stessa risoluzione della map RASTER3D di input per la mappa "
-"output 2D, indipendentemente dalle impostazioni attuali della region"
+msgid "Use the same resolution as the input 3D raster map for the 2D output maps, independent of the current region settings"
+msgstr "Utilizza la stessa risoluzione della map RASTER3D di input per la mappa output 2D, indipendentemente dalle impostazioni attuali della region"
 #: ../raster3d/r3.to.rast/main.c:209
 msgid "Converts 3D raster maps to 2D raster maps"
@@ -1306,12 +1270,8 @@
 # windows settings
 #: ../raster3d/r3.to.rast/main.c:270 ../raster3d/r3.out.vtk/main.c:450
 #, fuzzy
-msgid ""
-"The 2D and 3D region settings are different. Using the 2D window settings to "
-"adjust the 2D part of the 3D region."
-msgstr ""
-"La regione 2D e 3D hanno impostazioni differenti. Saranno usate le "
-"impostazioni 2D per aggiustare la parte 2D della regione 3D."
+msgid "The 2D and 3D region settings are different. Using the 2D window settings to adjust the 2D part of the 3D region."
+msgstr "La regione 2D e 3D hanno impostazioni differenti. Saranno usate le impostazioni 2D per aggiustare la parte 2D della regione 3D."
 #: ../raster3d/r3.to.rast/main.c:294 ../raster/r.gwflow/main.c:366
 #: ../raster/r.to.rast3/main.c:244 ../raster/r.li/r.li.daemon/list.c:49
@@ -1359,8 +1319,7 @@
 #: ../raster3d/r3.to.rast/main.c:307
 #, fuzzy, c-format
-msgid ""
-"Raster map %d Filename: %s already exists. Use the flag --o to overwrite."
+msgid "Raster map %d Filename: %s already exists. Use the flag --o to overwrite."
 msgstr "Mappa raster %d Nome del file: %s già esistente. Sarà sovrascritto!"
 #: ../raster3d/r3.cross.rast/main.c:90
@@ -1376,18 +1335,12 @@
 msgstr ""
 #: ../raster3d/r3.cross.rast/main.c:232
-msgid ""
-"Creates cross section 2D raster map from 3D raster map based on 2D elevation "
-"map"
+msgid "Creates cross section 2D raster map from 3D raster map based on 2D elevation map"
 msgstr ""
 #: ../raster3d/r3.cross.rast/main.c:258
-msgid ""
-"The 2D and 3D region settings are different. Using the 3D raster map "
-"settings to adjust the 2D region."
-msgstr ""
-"impostazioni della mappa raster 3D per aggiustare la regione 2D."
+msgid "The 2D and 3D region settings are different. Using the 3D raster map settings to adjust the 2D region."
+msgstr "La regione 2D e 3D hanno impostazioni differenti. Saranno usate le impostazioni della mappa raster 3D per aggiustare la regione 2D."
 #: ../raster3d/r3.cross.rast/main.c:301
 msgid "Output map already exists. Will be overwritten!"
@@ -1404,25 +1357,20 @@
 #: ../raster3d/r3.out.vtk/writeVTKData.c:122
 msgid "write_vtk_points: Writing point coordinates"
-msgstr ""
+msgstr "write_vtk_points: Scrittura delle coordinate del punto"
 #: ../raster3d/r3.out.vtk/writeVTKData.c:256
 msgid "write_vtk_unstructured_grid_cells: Writing the cells"
-msgstr ""
+msgstr "write_vtk_unstructured_grid_cells: Scrittura delle celle"
 #: ../raster3d/r3.out.vtk/writeVTKData.c:335
 #, fuzzy, c-format
-msgid ""
-"write_vtk_data: Writing Celldata %s with rows %i cols %i depths %i to vtk-"
-"ascii file"
-msgstr ""
-"vrite_vtk_data: Scrittura in corso di Celldata %s con %i righe e %i colonne, "
-"profondità %i nel vtk-ascii file"
+msgid "write_vtk_data: Writing Celldata %s with rows %i cols %i depths %i to vtk-ascii file"
+msgstr "vrite_vtk_data: Scrittura in corso di Celldata %s con %i righe e %i colonne, profondità %i nel vtk-ascii file"
 #: ../raster3d/r3.out.vtk/writeVTKData.c:441
 msgid "Wrong 3d raster map values! Values should in between 0 and 255!\n"
-msgstr ""
-"Valori della mappa g3d errati! I valori devono essere compresi tra 0 e 255!\n"
+msgstr "Valori della mappa g3d errati! I valori devono essere compresi tra 0 e 255!\n"
 #: ../raster3d/r3.out.vtk/parameters.c:30
 msgid "RASTER3D map(s) to be converted to VTK-ASCII data format"
@@ -1434,8 +1382,7 @@
 #: ../raster3d/r3.out.vtk/parameters.c:41
 msgid "Float value to represent no data cell/points"
-msgstr ""
-"Valore a virgola mobile per rappresentare le celle/punti prive di valori"
+msgstr "Valore a virgola mobile per rappresentare le celle/punti prive di valori"
 #: ../raster3d/r3.out.vtk/parameters.c:47
 msgid "Create VTK pointdata instead of VTK celldata (celldata is default)"
@@ -1450,14 +1397,11 @@
 msgstr "mappa raster 2D della superficie inferiore"
 #: ../raster3d/r3.out.vtk/parameters.c:71
-msgid ""
-"Create 3d elevation output with a top and a bottom surface, both raster maps "
-"are required."
+msgid "Create 3d elevation output with a top and a bottom surface, both raster maps are required."
 msgstr ""
 #: ../raster3d/r3.out.vtk/parameters.c:82
-msgid ""
-"Three (R,G,B) 3D raster maps to create RGB values [redmap,greenmap,bluemap]"
+msgid "Three (R,G,B) 3D raster maps to create RGB values [redmap,greenmap,bluemap]"
 msgstr ""
 #: ../raster3d/r3.out.vtk/parameters.c:92
@@ -1474,12 +1418,11 @@
 #: ../display/d.rast.num/main.c:104 ../vector/v.out.ascii/args.c:67
 #: ../vector/v.out.vtk/main.c:71
 msgid "Number of significant digits (floating point only)"
-msgstr ""
+msgstr "Numero di cifre significative (solo valori a virgola mobile)"
 #: ../raster3d/r3.out.vtk/parameters.c:116
-#, fuzzy
 msgid "Use 3D raster mask (if exists) with input maps"
-msgstr "Utilizza maschera G3D (se esiste) con le mappe di input"
+msgstr "Utilizza una maschera G3D (se esiste) con le mappe di input"
 #: ../raster3d/r3.out.vtk/parameters.c:121
 msgid "Scale factor effects the origin"
@@ -1492,9 +1435,7 @@
 msgstr ""
 #: ../raster3d/r3.out.vtk/parameters.c:133
-msgid ""
-"Do not convert the top-bottom resolution in case of lat long projection to "
-"meters"
+msgid "Do not convert the top-bottom resolution in case of lat long projection to meters"
 msgstr ""
 #: ../raster3d/r3.out.vtk/main.c:117
@@ -1530,9 +1471,7 @@
 msgstr "Fornire tre mappe vettoriali G3D [x,y,z]"
 #: ../raster3d/r3.out.vtk/main.c:175
-msgid ""
-"No 3D raster data, RGB or xyz-vector maps are provided! Will only write the "
-"geometry."
+msgid "No 3D raster data, RGB or xyz-vector maps are provided! Will only write the geometry."
 msgstr ""
 #: ../raster3d/r3.out.vtk/main.c:209
@@ -1559,9 +1498,7 @@
 #: ../raster3d/r3.out.vtk/main.c:541
 msgid "Unable to close 3D raster map, the VTK file may be incomplete"
-msgstr ""
-"Errore nella chiusura della mappa raster 3D, il file VTK potrebbe essere "
-"incompleto."
+msgstr "Errore nella chiusura della mappa raster 3D, il file VTK potrebbe essere incompleto."
 #: ../raster3d/r3.out.vtk/main.c:556
 msgid "Unable to close VTK-ASCII file"
@@ -1585,9 +1522,7 @@
 #: ../raster3d/r3.in.ascii/main.c:98
 msgid "String representing NULL value data cell (use 'none' if no such value)"
-msgstr ""
-"Stringa rappresentante la cella con valore NULL (usare 'none' se non ci sono "
-"valori null)"
+msgstr "Stringa rappresentante la cella con valore NULL (usare 'none' se non ci sono valori null)"
 #: ../raster3d/r3.in.ascii/main.c:188
 #, fuzzy, c-format
@@ -1601,8 +1536,7 @@
 #: ../raster3d/r3.in.ascii/main.c:264
 msgid "End of file reached while still loading data."
-msgstr ""
-"Raggiunta la fine del file mentre è ancora in corso il caricamento dei dati."
+msgstr "Raggiunta la fine del file mentre è ancora in corso il caricamento dei dati."
 #: ../raster3d/r3.in.ascii/main.c:276
 #, fuzzy
@@ -1611,8 +1545,7 @@
 #: ../raster3d/r3.in.ascii/main.c:293
 #, c-format
-msgid ""
-"Data exists in input file after fully importing expected data.  [%.4f ...]"
+msgid "Data exists in input file after fully importing expected data.  [%.4f ...]"
 msgstr ""
 #: ../raster3d/r3.in.ascii/main.c:327 ../raster/r.external/main.c:56
@@ -1647,8 +1580,7 @@
 #: ../raster3d/r3.in.ascii/main.c:329
 #, fuzzy
 msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map."
-msgstr ""
-"Converte un file testuale raster ASCII 3D in un layer raster 3D (binario)"
+msgstr "Converte un file testuale raster ASCII 3D in un layer raster 3D (binario)"
 #: ../raster3d/r3.in.ascii/main.c:372
 msgid "Unable to close ASCII file"
@@ -1783,9 +1715,7 @@
 msgstr ""
 #: ../misc/m.nviz.script/main.c:439
-msgid ""
-"Skipping this point, selected point is outside region. Perhaps the camera "
-"setback distance puts it beyond the edge?"
+msgid "Skipping this point, selected point is outside region. Perhaps the camera setback distance puts it beyond the edge?"
 msgstr ""
 #: ../misc/m.nviz.image/args.c:51
@@ -2144,8 +2074,7 @@
 msgstr ""
 #: ../misc/m.nviz.image/args.c:822
-msgid ""
-"nw;North-West edge;ne;North-East edge;sw;South-West edge;se;South-East edge"
+msgid "nw;North-West edge;ne;North-East edge;sw;South-West edge;se;South-East edge"
 msgstr ""
 #: ../misc/m.nviz.image/args.c:826
@@ -2166,9 +2095,7 @@
 msgstr ""
 #: ../misc/m.nviz.image/args.c:854
-msgid ""
-"Place north arrow at given position \t(in screen coordinates from bottom "
-"left corner)"
+msgid "Place north arrow at given position \t(in screen coordinates from bottom left corner)"
 msgstr ""
 #: ../misc/m.nviz.image/args.c:856 ../misc/m.nviz.image/args.c:865
@@ -2295,9 +2222,7 @@
 msgstr ""
 #: ../misc/m.nviz.image/main.c:55
-msgid ""
-"Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster "
-"data) in 3D."
+msgid "Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster data) in 3D."
 msgstr ""
 #: ../misc/m.nviz.image/main.c:138
@@ -2378,9 +2303,7 @@
 msgstr "Distanza dalla zona(e)"
 #: ../misc/m.cogo/main.c:227
-msgid ""
-"A simple utility for converting bearing and distance measurements to "
-"coordinates and vice versa."
+msgid "A simple utility for converting bearing and distance measurements to coordinates and vice versa."
 msgstr ""
 #: ../misc/m.cogo/main.c:229
@@ -2493,11 +2416,7 @@
 msgstr ""
 #: ../misc/m.transform/main.c:336
-msgid ""
-"idx;point index;src;source coordinates;dst;destination coordinates;fwd;"
-"forward coordinates (destination);rev;reverse coordinates (source);fxy;"
-"forward coordinates difference (destination);rxy;reverse coordinates "
-"difference (source);fd;forward error (destination);rd;reverse error (source)"
+msgid "idx;point index;src;source coordinates;dst;destination coordinates;fwd;forward coordinates (destination);rev;reverse coordinates (source);fxy;forward coordinates difference (destination);rxy;reverse coordinates difference (source);fd;forward error (destination);rd;reverse error (source)"
 msgstr ""
 #: ../misc/m.transform/main.c:346 ../vector/v.out.ascii/args.c:51
@@ -2510,8 +2429,7 @@
 #: ../misc/m.transform/main.c:356
 msgid "File containing coordinates to transform (\"-\" to read from stdin)"
-msgstr ""
-"File contenente le coordinate da trasformare (\"-\" per leggere dallo stdin)"
+msgstr "File contenente le coordinate da trasformare (\"-\" per leggere dallo stdin)"
 #: ../misc/m.transform/main.c:357
 msgid "Local x,y coordinates to target east,north"
@@ -2554,8 +2472,7 @@
 #: ../misc/m.measure/main.c:63
 #, fuzzy
 msgid "Shell script style"
-msgstr ""
-"Stampa le impostazioni della region corrente (in stile script per la shell)"
+msgstr "Stampa le impostazioni della region corrente (in stile script per la shell)"
 #: ../misc/m.measure/main.c:106
 #, fuzzy
@@ -2568,9 +2485,7 @@
 msgstr "Area\n"
 #: ../raster/r.external/proj.c:18 ../raster/r.in.gdal/main.c:356
-msgid ""
-"Unable to convert input raster map projection information to GRASS format "
-"for checking"
+msgid "Unable to convert input raster map projection information to GRASS format for checking"
 msgstr ""
 #: ../raster/r.external/proj.c:34 ../raster/r.in.lidar/main.c:297
@@ -2586,8 +2501,7 @@
 "Projection of dataset does not appear to match current location.\n"
 "\n"
 msgstr ""
-"La proiezione del dataset sembra non corrispondere a quella della location "
-"corrente.\n"
+"La proiezione del dataset sembra non corrispondere a quella della location corrente.\n"
 "\n"
 #: ../raster/r.external/proj.c:47 ../raster/r.in.gdal/main.c:387
@@ -2608,33 +2522,22 @@
 #: ../raster/r.external/proj.c:107
 msgid ""
 "\n"
-"You can use the -o flag to r.external to override this check and use the "
-"location definition for the dataset.\n"
+"You can use the -o flag to r.external to override this check and use the location definition for the dataset.\n"
 msgstr ""
 #: ../raster/r.external/proj.c:110 ../raster/r.in.gdal/main.c:450
-msgid ""
-"Consider generating a new location from the input dataset using the "
-"'location' parameter.\n"
-msgstr ""
-"Si prenda in considerazione di generare una nuova location dal dataset di "
-"input usando il parametro location\n"
+msgid "Consider generating a new location from the input dataset using the 'location' parameter.\n"
+msgstr "Si prenda in considerazione di generare una nuova location dal dataset di input usando il parametro location\n"
 #: ../raster/r.external/proj.c:115 ../raster/r.in.lidar/main.c:380
 #: ../raster/r.in.gdal/main.c:455 ../vector/v.in.ogr/main.c:636
 #: ../vector/v.in.lidar/main.c:464
 msgid "Projection of input dataset and current location appear to match"
-msgstr ""
-"La proiezione del dataset di input e della location corrente sembrano "
-"corrispondere"
+msgstr "La proiezione del dataset di input e della location corrente sembrano corrispondere"
 #: ../raster/r.external/window.c:23
-msgid ""
-"Input raster map is rotated - cannot import. You may use 'gdalwarp' to "
-"transform the map to North-up."
-msgstr ""
-"Il raster di input è ruotato - non può essere importato. Si può utilizzare "
-"'gdalwarp' per trasformare la mappa col Nord in alto"
+msgid "Input raster map is rotated - cannot import. You may use 'gdalwarp' to transform the map to North-up."
+msgstr "Il raster di input è ruotato - non può essere importato. Si può utilizzare 'gdalwarp' per trasformare la mappa col Nord in alto"
 #: ../raster/r.external/window.c:26
 msgid "Applying horizontal flip"
@@ -2646,15 +2549,13 @@
 #: ../raster/r.external/window.c:93 ../raster/r.in.gdal/main.c:635
 #: ../vector/v.in.ogr/main.c:1257
-#, fuzzy
 msgid "Default region for this location updated"
-msgstr "Informazioni sulla proiezione aggiornate!"
+msgstr "La regione predefinita per questa location è stata aggiornata"
 #: ../raster/r.external/window.c:96 ../raster/r.in.gdal/main.c:638
 #: ../vector/v.in.ogr/main.c:1260
-#, fuzzy
 msgid "Region for the current mapset updated"
-msgstr "Utilizza la regione corrente"
+msgstr "La regione per questa location è stata aggiornata"
 #: ../raster/r.external/list.c:22
 #, fuzzy
@@ -2937,9 +2838,7 @@
 msgstr "File di input"
 #: ../raster/r.mode/main.c:58
-msgid ""
-"Finds the mode of values in a cover map within areas assigned the same "
-"category value in a user-specified base map."
+msgid "Finds the mode of values in a cover map within areas assigned the same category value in a user-specified base map."
 msgstr ""
 #: ../raster/r.mode/main.c:64
@@ -2982,8 +2881,7 @@
 #: ../raster/r.profile/main.c:79
 msgid "Resolution along profile (default = current region resolution)"
-msgstr ""
-"Risoluzione lungo profilo (default = risoluzione della regione attuale)"
+msgstr "Risoluzione lungo profilo (default = risoluzione della regione attuale)"
 #: ../raster/r.profile/main.c:86
 msgid "Character to represent no data cell"
@@ -3023,7 +2921,7 @@
 #: ../raster/r.profile/main.c:160
 msgid " [RGB Color]"
-msgstr ""
+msgstr " [Colore RGB]"
 #: ../raster/r.profile/main.c:170
 #, c-format
@@ -3052,12 +2950,8 @@
 "categoria: %d\n"
 #: ../raster/r.category/main.c:55
-msgid ""
-"Manages category values and labels associated with user-specified raster map "
-"layers."
-msgstr ""
-"Gestisce i valori delle categorie e le etichette associate con un raster "
-"specificato dall'utente"
+msgid "Manages category values and labels associated with user-specified raster map layers."
+msgstr "Gestisce i valori delle categorie e le etichette associate con un raster specificato dall'utente"
 #: ../raster/r.category/main.c:68
 msgid "Comma separated value list"
@@ -3080,14 +2974,11 @@
 #: ../raster/r.category/main.c:86
 msgid "File containing category label rules (or \"-\" to read from stdin)"
-msgstr ""
-"File contenente le regole per le etichette di categoria (oppure \"-\" per "
-"leggere dallo stdin)"
+msgstr "File contenente le regole per le etichette di categoria (oppure \"-\" per leggere dallo stdin)"
 #: ../raster/r.category/main.c:93
 msgid "Default label or format string for dynamic labeling"
-msgstr ""
-"Etichetta predefinita o stringa del formato per l'etichettatura dinamica"
+msgstr "Etichetta predefinita o stringa del formato per l'etichettatura dinamica"
 #: ../raster/r.category/main.c:95
 msgid "Used when no explicit label exists for the category"
@@ -3121,14 +3012,11 @@
 #: ../raster/r.category/main.c:249
 #, c-format
 msgid "Unable to read category file of raster map <%s> in <%s>"
-msgstr ""
-"Impossibile leggere il file delle categorie della mappa raster <%s> in <%s>"
+msgstr "Impossibile leggere il file delle categorie della mappa raster <%s> in <%s>"
 #: ../raster/r.category/main.c:265
 msgid "The map is floating point! Ignoring cats list, using vals list"
-msgstr ""
-"La mappa è con valori a virgola mobile! La lista delle categorie verrà "
-"ignorata, si sta usando la lista di valori"
+msgstr "La mappa è con valori a virgola mobile! La lista delle categorie verrà ignorata, si sta usando la lista di valori"
 #: ../raster/r.category/main.c:282
 msgid "vals argument is required for floating point map!"
@@ -3198,24 +3086,11 @@
 #, c-format
 msgid ""
 "USAGE for basin delineation:\n"
-"%s -4 elevation=elevation_map threshold=swale_threshold "
-"[flow=overland_flow_map] [drainage=drain_direction_map] "
-"[depression=depression_map] [accumulation=accumulation_map] "
-"[basin=watershed_basin_map] [stream=stream_segment_map]\n"
+"%s -4 elevation=elevation_map threshold=swale_threshold [flow=overland_flow_map] [drainage=drain_direction_map] [depression=depression_map] [accumulation=accumulation_map] [basin=watershed_basin_map] [stream=stream_segment_map]\n"
 "\n"
 "USAGE for slope length determination:\n"
-"%s [-4] elevation=elevation_map threshold=swale_threshold "
-"[drainage=drain_direction_map] [depression=depression_map] "
-"[accumulation=accumulation_map] [max_slope_length=max_slope_length] "
-"[blocking=overland_blocking_map] [slope_steepness=slope_steepness_map] "
-"length_slope=length_slope_map [disturbed_land=rill_erosion_map] "
-"[slope_deposition=slope_deposition value or map]USAGE for ARMSED FILE "
-"creation:\n"
-"[basin=watershed_basin_map] [stream=stream_segment_map] "
-"[half_basin=half_basin_map] ar=ARMSED_file_name\n"
+"%s [-4] elevation=elevation_map threshold=swale_threshold [drainage=drain_direction_map] [depression=depression_map] [accumulation=accumulation_map] [max_slope_length=max_slope_length] [blocking=overland_blocking_map] [slope_steepness=slope_steepness_map] length_slope=length_slope_map [disturbed_land=rill_erosion_map] [slope_deposition=slope_deposition value or map]USAGE for ARMSED FILE creation:\n"
+"%s [-4] elevation=elevation_map threshold=swale_threshold [flow=overland_flow_map] [drainage=drain_direction_map] [depression=depression_map] [accumulation=accumulation_map] [basin=watershed_basin_map] [stream=stream_segment_map] [half_basin=half_basin_map] ar=ARMSED_file_name\n"
 "\n"
 msgstr ""
@@ -3422,18 +3297,15 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:83
-msgid ""
-"depression map indicates all the locations in the current map window where"
+msgid "depression map indicates all the locations in the current map window where"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:84
-msgid ""
-"water accumulates and does not leave by the edge of the map. Lakes without"
+msgid "water accumulates and does not leave by the edge of the map. Lakes without"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:85
-msgid ""
-"outlet streams and sinkholes are examples of `depressions'.  If you wish to"
+msgid "outlet streams and sinkholes are examples of `depressions'.  If you wish to"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:86
@@ -3445,8 +3317,7 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:88
-msgid ""
-"Hit <return> by itself for the next question if there is no depression map."
+msgid "Hit <return> by itself for the next question if there is no depression map."
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:99
@@ -3457,14 +3328,11 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:101
-msgid ""
-"watershed basins.  The number of watershed basins is indirectly determined"
+msgid "watershed basins.  The number of watershed basins is indirectly determined"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:102
-msgid ""
-"by the `basin threshold' value.  The basin threshold is the area necessary "
-"for"
+msgid "by the `basin threshold' value.  The basin threshold is the area necessary for"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:103
@@ -3473,18 +3341,15 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:105
-msgid ""
-"`exterior drainage basins'.  An exterior drainage basin does not have any"
+msgid "`exterior drainage basins'.  An exterior drainage basin does not have any"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:106
-msgid ""
-"drainage basins flowing into it.  Interior drainage basin size is determined"
+msgid "drainage basins flowing into it.  Interior drainage basin size is determined"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:107
-msgid ""
-"by the surface flow going into stream segments between stream interceptions."
+msgid "by the surface flow going into stream segments between stream interceptions."
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:108
@@ -3497,18 +3362,15 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:111
-msgid ""
-"(i.e., areas with low infiltration capacities will need smaller areas to"
+msgid "(i.e., areas with low infiltration capacities will need smaller areas to"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:112
-msgid ""
-"develop stream channels than neighboring areas with high infiltration rates)."
+msgid "develop stream channels than neighboring areas with high infiltration rates)."
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:113
-msgid ""
-"The user can create a map layer with potential overland flow values, and"
+msgid "The user can create a map layer with potential overland flow values, and"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:114
@@ -3522,7 +3384,7 @@
 #: ../raster/r.watershed/shed/com_line.c:119
 msgid " 1) acres,          2) meters sq., 3) miles sq., 4) hectares,"
-msgstr ""
+msgstr "1) acri,          2) metri quadri, 3) miglia quadrate, 4) ettari,"
 #: ../raster/r.watershed/shed/com_line.c:120
 msgid " 5) kilometers sq., 6) map cells,  7) overland flow units"
@@ -3622,8 +3484,7 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:296
-msgid ""
-"ability to generate several variables in the Revised Universal Soil Loss"
+msgid "ability to generate several variables in the Revised Universal Soil Loss"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:297
@@ -3642,9 +3503,7 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:351
-msgid ""
-"where the value indicates the percent of disturbed (barren) land in that "
-"cell."
+msgid "where the value indicates the percent of disturbed (barren) land in that cell."
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:352
@@ -3685,8 +3544,7 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:384
-msgid ""
-"that prevents the surface flow distance from getting too long.  Normally,"
+msgid "that prevents the surface flow distance from getting too long.  Normally,"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:385
@@ -3700,8 +3558,7 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:401
-msgid ""
-"slope length.  You may input a raster map indicating the locations of these"
+msgid "slope length.  You may input a raster map indicating the locations of these"
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:402
@@ -3709,8 +3566,7 @@
 msgstr ""
 #: ../raster/r.watershed/shed/com_line.c:403
-msgid ""
-"Hit <return> by itself for the next question if there is no blocking map."
+msgid "Hit <return> by itself for the next question if there is no blocking map."
 msgstr ""
 #: ../raster/r.watershed/shed/basin_maps.c:12
@@ -3887,8 +3743,7 @@
 msgstr "Nome di una mappa raster contenente una superfice di altezze"
 #: ../raster/r.watershed/front/main.c:103
-msgid ""
-"For USLE. All non-NULL and non-zero cells are considered as blocking terrain."
+msgid "For USLE. All non-NULL and non-zero cells are considered as blocking terrain."
 msgstr ""
 #: ../raster/r.watershed/front/main.c:110
@@ -4003,13 +3858,11 @@
 #: ../raster/r.watershed/front/main.c:206
 msgid "Enable disk swap memory option: Operation is slow"
-msgstr ""
+msgstr "Abilita l'opzione per l'uso della memoria swap del disco. L'operazione è lenta"
 #: ../raster/r.watershed/front/main.c:208
-msgid ""
-"Only needed if memory requirements exceed available RAM; see manual on how "
-"to calculate memory requirements"
-msgstr ""
+msgid "Only needed if memory requirements exceed available RAM; see manual on how to calculate memory requirements"
+msgstr "Necessario solo se la richiesta di memoria supera la RAM disponibile: vedere il manuale per come calcolare il fabbisogno di memoria"
 #: ../raster/r.watershed/front/main.c:213
 msgid "Use positive flow accumulation even for likely underestimates"
@@ -4106,18 +3959,14 @@
 #: ../raster/r.drain/main.c:110
 msgid "Traces a flow through an elevation model on a raster map."
-msgstr ""
-"Traccia una linea di flusso su una mappa raster sulla base di un modello di "
-"elevazione."
+msgstr "Traccia una linea di flusso su una mappa raster sulla base di un modello di elevazione."
 #: ../raster/r.drain/main.c:120
 msgid "Name of movement direction map associated with the cost surface"
 msgstr ""
 #: ../raster/r.drain/main.c:130
-msgid ""
-"Output drain vector map (recommended for cost surface made using knight's "
-"move)"
+msgid "Output drain vector map (recommended for cost surface made using knight's move)"
 msgstr ""
 #: ../raster/r.drain/main.c:138
@@ -4147,9 +3996,7 @@
 msgstr "Numera progressivamente le celle lungo il percorso"
 #: ../raster/r.drain/main.c:162
-msgid ""
-"The input surface is a cost surface (if checked, a direction surface must "
-"also be specified"
+msgid "The input surface is a cost surface (if checked, a direction surface must also be specified"
 msgstr ""
 #: ../raster/r.drain/main.c:174
@@ -4161,9 +4008,7 @@
 msgstr ""
 #: ../raster/r.drain/main.c:183
-msgid ""
-"Direction raster not specified, if direction flag is on, a direction raster "
-"must be given"
+msgid "Direction raster not specified, if direction flag is on, a direction raster must be given"
 msgstr ""
 #: ../raster/r.drain/main.c:191
@@ -4214,9 +4059,7 @@
 #: ../raster/r.drain/main.c:310
 #, c-format
 msgid "Starting vector map <%s> contains no points in the current region"
-msgstr ""
-"La mappa vettoriale di partenza <%s> non contiene punti nella regione "
-"corrente"
+msgstr "La mappa vettoriale di partenza <%s> non contiene punti nella regione corrente"
 #: ../raster/r.drain/main.c:318
 msgid "No start/stop point(s) specified"
@@ -4258,9 +4101,7 @@
 msgstr "Estrae parametri del terreno da un DEM."
 #: ../raster/r.param.scale/interface.c:57
-msgid ""
-"Uses a multi-scale approach by taking fitting quadratic parameters to any "
-"size window (via least squares)."
+msgid "Uses a multi-scale approach by taking fitting quadratic parameters to any size window (via least squares)."
 msgstr ""
 #: ../raster/r.param.scale/interface.c:75
@@ -4362,9 +4203,7 @@
 #: ../raster/r.support/main.c:57
 msgid "Allows creation and/or modification of raster map layer support files."
-msgstr ""
-"Consente la creazione o la modifica dei file di supporto di un tematismo "
-"raster"
+msgstr "Consente la creazione o la modifica dei file di supporto di un tematismo raster"
 #: ../raster/r.support/main.c:67
 msgid "Text to use for map title"
@@ -4499,8 +4338,7 @@
 #: ../raster/r.topmodel/main.c:89 ../raster/r.fill.dir/main.c:99
 #, fuzzy
-msgid ""
-"Name for output flow direction map for depressionless elevation raster map"
+msgid "Name for output flow direction map for depressionless elevation raster map"
 msgstr "Nome del file raster in input"
 #: ../raster/r.topmodel/main.c:95
@@ -4662,9 +4500,7 @@
 msgstr ""
 #: ../raster/r.cross/main.c:76
-msgid ""
-"Creates a cross product of the category values from multiple raster map "
-"layers."
+msgid "Creates a cross product of the category values from multiple raster map layers."
 msgstr ""
 #: ../raster/r.cross/main.c:85
@@ -4730,9 +4566,7 @@
 #: ../raster/r.usler/main.c:70
-msgid ""
-"roose;Roosle (1975);morgan;Morgan (1974);foster;Foster (1981);elswaify;El-"
-"Swaify (1985)"
+msgid "roose;Roosle (1975);morgan;Morgan (1974);foster;Foster (1981);elswaify;El-Swaify (1985)"
 msgstr ""
 #: ../raster/r.distance/edges.c:46
@@ -4848,10 +4682,8 @@
 msgstr "vettore da rimuovere"
 #: ../raster/r.patch/main.c:55
-msgid ""
-"Creates a composite raster map layer by using known category values from one "
-"(or more) map layer(s) to fill in areas of \"no data\" in another map layer."
-msgstr ""
+msgid "Creates a composite raster map layer by using known category values from one (or more) map layer(s) to fill in areas of \"no data\" in another map layer."
+msgstr "Crea un tematismo raster composto utilizzando i valori di categoria conosciuti di uno o più tematismi per riempire le aree con \"nessun dato\" in un altro tematismo di mappa."
 #: ../raster/r.patch/main.c:62
 msgid "Name of raster maps to be patched together"
@@ -4886,8 +4718,7 @@
 #: ../raster/r.quant/main.c:51
 msgid "Produces the quantization file for a floating-point map."
-msgstr ""
-"Produce il file di quantizzazione per una mappa con valori a virgola mobile"
+msgstr "Produce il file di quantizzazione per una mappa con valori a virgola mobile"
 #: ../raster/r.quant/main.c:59
 msgid "Raster map(s) to be quantized"
@@ -4966,9 +4797,7 @@
 #: ../raster/r.quant/main.c:177
 msgid "No rules specified. Quant table(s) not changed."
-msgstr ""
-"Nessuna regola specificata. La tabella/e di quantizzazione rimangono "
-"invariate"
+msgstr "Nessuna regola specificata. La tabella/e di quantizzazione rimangono invariate"
 #: ../raster/r.quant/main.c:179 ../raster/r.recode/main.c:98
 #: ../raster/r.reclass/main.c:142
@@ -5027,16 +4856,11 @@
 msgstr "fallito"
 #: ../raster/r.spread/main.c:105
-msgid ""
-"Simulates elliptically anisotropic spread on a graphics window and generates "
-"a raster map of the cumulative time of spread, given raster maps containing "
-"the rates of spread (ROS), the ROS directions and the spread origins."
+msgid "Simulates elliptically anisotropic spread on a graphics window and generates a raster map of the cumulative time of spread, given raster maps containing the rates of spread (ROS), the ROS directions and the spread origins."
 msgstr ""
 #: ../raster/r.spread/main.c:110
-msgid ""
-"It optionally produces raster maps to contain backlink UTM coordinates for "
-"tracing spread paths."
+msgid "It optionally produces raster maps to contain backlink UTM coordinates for tracing spread paths."
 msgstr ""
 #: ../raster/r.spread/main.c:118 ../raster/r.spread/main.c:127
@@ -5064,19 +4888,15 @@
 msgstr ""
 #: ../raster/r.spread/main.c:155
-msgid ""
-"Name of raster map containing max SPOTting DISTance (m) (required w/ -s)"
+msgid "Name of raster map containing max SPOTting DISTance (m) (required w/ -s)"
 msgstr ""
 #: ../raster/r.spread/main.c:163
-msgid ""
-"Name of raster map containing midflame Wind SPEED (ft/min) (required w/ -s)"
+msgid "Name of raster map containing midflame Wind SPEED (ft/min) (required w/ -s)"
 msgstr ""
 #: ../raster/r.spread/main.c:171
-msgid ""
-"Name of raster map containing fine Fuel MOISture of the cell receiving a "
-"spotting firebrand (%) (required w/ -s)"
+msgid "Name of raster map containing fine Fuel MOISture of the cell receiving a spotting firebrand (%) (required w/ -s)"
 msgstr ""
 #: ../raster/r.spread/main.c:179
@@ -5154,19 +4974,12 @@
 msgstr ""
 #: ../raster/r.cost/main.c:143
-msgid ""
-"Creates a raster map showing the cumulative cost of moving between different "
-"geographic locations on an input raster map whose cell category values "
-"represent cost."
-msgstr ""
-"Crea una mappa raster che mostra il costo cumulativo per muoversi tra "
-"diverse località geografiche su una mappa raster di input i cui valori di "
-"categoria delle celle rappresentano dei costi"
+msgid "Creates a raster map showing the cumulative cost of moving between different geographic locations on an input raster map whose cell category values represent cost."
+msgstr "Crea una mappa raster che mostra il costo cumulativo per muoversi tra diverse località geografiche su una mappa raster di input i cui valori di categoria delle celle rappresentano dei costi"
 #: ../raster/r.cost/main.c:150
 msgid "Name of raster map containing grid cell cost information"
-msgstr ""
-"Nome della mappa raster che contiene la griglia con le informazioni del costo"
+msgstr "Nome della mappa raster che contiene la griglia con le informazioni del costo"
 #: ../raster/r.cost/main.c:158
 #, fuzzy
@@ -5208,9 +5021,7 @@
 #: ../raster/r.cost/main.c:220 ../raster/r.walk/main.c:266
 msgid "Cost assigned to null cells. By default, null cells are excluded"
-msgstr ""
-"Costo assegnato alle celle vuote. Se non specificato i valori nulli vengono "
-"esclusi."
+msgstr "Costo assegnato alle celle vuote. Se non specificato i valori nulli vengono esclusi."
 #: ../raster/r.cost/main.c:229 ../raster/r.walk/main.c:274
 #: ../raster/r.in.xyz/main.c:238 ../raster/r.in.lidar/main.c:211
@@ -5254,7 +5065,7 @@
 #: ../raster/r.cost/main.c:336
 msgid "Assigning negative cost to null cell. Null cells excluded."
-msgstr ""
+msgstr "Assegnamento di un costo negativo alle celle con valore null. Le celle con valore null vengono escluse."
 #: ../raster/r.cost/main.c:409 ../raster/r.cost/main.c:419
 #: ../raster/r.walk/main.c:562 ../raster/r.walk/main.c:572
@@ -5332,7 +5143,7 @@
 #: ../raster/r.cost/main.c:1204 ../raster/r.walk/main.c:1516
 #, c-format
 msgid "Peak cost value: %f."
-msgstr ""
+msgstr "Valore di costo massimo: %f."
 #: ../raster/r.cost/main.c:1226 ../raster/r.walk/main.c:1541
 #, c-format
@@ -5414,15 +5225,12 @@
 #: ../raster/r.out.vtk/parameters.c:69
 #: ../locale/scriptstrings/tr.out.vtk_to_translate.c:12
-msgid ""
-"Create VTK point data instead of VTK cell data (if no elevation map is given)"
+msgid "Create VTK point data instead of VTK cell data (if no elevation map is given)"
 msgstr ""
 #: ../raster/r.out.vtk/parameters.c:79
-msgid ""
-"Three (r,g,b) raster maps to create rgb values [redmap,greenmap,bluemap]"
-msgstr ""
-"Tre mappe raster (r,g,b) per creare valori rgb [redmap,greenmap,bluemap]"
+msgid "Three (r,g,b) raster maps to create rgb values [redmap,greenmap,bluemap]"
+msgstr "Tre mappe raster (r,g,b) per creare valori rgb [redmap,greenmap,bluemap]"
 #: ../raster/r.out.vtk/parameters.c:89
 msgid "Three (x,y,z) raster maps to create vector values [xmap,ymap,zmap]"
@@ -5437,8 +5245,7 @@
 msgstr ""
 #: ../raster/r.out.vtk/parameters.c:126
-msgid ""
-"Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
+msgid "Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
 msgstr ""
 #: ../raster/r.out.vtk/parameters.c:132
@@ -5451,9 +5258,7 @@
 msgstr "Converte un raster in formato VTK-Ascii"
 #: ../raster/r.out.vtk/main.c:72
-msgid ""
-"No input maps specified. You need to specify at least one input map or three "
-"vector maps or three rgb maps."
+msgid "No input maps specified. You need to specify at least one input map or three vector maps or three rgb maps."
 msgstr ""
 #: ../raster/r.out.vtk/main.c:130 ../raster/r.out.vtk/main.c:190
@@ -5468,17 +5273,14 @@
 #: ../raster/r.out.vtk/main.c:231
 msgid "Wrong RGB maps. Maps should have the same type! RGB output not added!"
-msgstr ""
-"Mappe RGB non corrette. Le mappe devono essere dello stesso tipo! Otput RGB "
-"non aggiunto!"
+msgstr "Mappe RGB non corrette. Le mappe devono essere dello stesso tipo! Otput RGB non aggiunto!"
 #: ../raster/r.out.vtk/main.c:260
 msgid "Writing VTK Vector Data\n"
 msgstr ""
 #: ../raster/r.out.vtk/main.c:270
-msgid ""
-"Wrong vector maps. Maps should have the same type! Vector output not added!"
+msgid "Wrong vector maps. Maps should have the same type! Vector output not added!"
 msgstr ""
 #: ../raster/r.out.vtk/main.c:282
@@ -5606,9 +5408,7 @@
 #: ../raster/r.statistics/main.c:86 ../raster/r.statistics2/main.c:143
 msgid "Cover values extracted from the category labels of the cover map"
-msgstr ""
-"Esegue i calcoli sui valori estratti dalle etichette di categoria della "
-"mappa di copertura"
+msgstr "Esegue i calcoli sui valori estratti dalle etichette di categoria della mappa di copertura"
 #: ../raster/r.statistics/main.c:92 ../raster/r.statistics/main.c:95
 msgid "This module currently only works for integer (CELL) maps"
@@ -5635,9 +5435,7 @@
 msgstr "Mappa(e) raster da leggere"
 #: ../raster/r.rescale.eq/main.c:54
-msgid ""
-"Rescales histogram equalized the range of category values in a raster map "
-"layer."
+msgid "Rescales histogram equalized the range of category values in a raster map layer."
 msgstr ""
 #: ../raster/r.rescale.eq/main.c:64 ../raster/r.rescale/main.c:60
@@ -5754,30 +5552,24 @@
 #: ../raster/r.los/main.c:162
 msgid "Lat/Long support is not (yet) implemented for this module."
-msgstr ""
-"Il supporto per Lat/Long non è (ancora) implementato per questo modulo."
+msgstr "Il supporto per Lat/Long non è (ancora) implementato per questo modulo."
 #: ../raster/r.los/main.c:167
 msgid "Specified observer coordinate is outside current region bounds."
-msgstr ""
-"L'osservatore specificato è al di fuori dei limiti della regione corrente"
+msgstr "L'osservatore specificato è al di fuori dei limiti della regione corrente"
 #: ../raster/r.los/main.c:211
 msgid "Pattern map should be a binary 0/1 CELL map"
 msgstr ""
 #: ../raster/r.los/main.c:245
-msgid ""
-"Problem to obtain current ellipsoid parameters, using sphere (6370997.0)"
-msgstr ""
-"Problemi nell'ottenere i parametri dell'ellisoide, si sta usando la sfera "
-"(6370997.0)"
+msgid "Problem to obtain current ellipsoid parameters, using sphere (6370997.0)"
+msgstr "Problemi nell'ottenere i parametri dell'ellisoide, si sta usando la sfera (6370997.0)"
 #: ../raster/r.los/main.c:250
 #, c-format
 msgid "Using maximum distance from the viewing point (meters): %f"
-msgstr ""
-"Si sta utilizzando la distanza massima dal punto di osservazione (metri): %f"
+msgstr "Si sta utilizzando la distanza massima dal punto di osservazione (metri): %f"
 #: ../raster/r.his/main.c:63 ../imagery/i.his.rgb/main.c:47
 #: ../imagery/i.rgb.his/main.c:47 ../display/d.his/main.c:63
@@ -5797,13 +5589,8 @@
 msgstr ""
 #: ../raster/r.his/main.c:67
-msgid ""
-"Generates red, green and blue raster map layers combining hue, intensity and "
-"saturation (HIS) values from user-specified input raster map layers."
-msgstr ""
-"Genera mappe raster separate per le componenti rosso, verde e blu combinando "
-"i valori di tonalità (hue), intensità (intensity), e saturazione "
-"(saturation) (HIS) di mappe raster di input definite dall’utente."
+msgid "Generates red, green and blue raster map layers combining hue, intensity and saturation (HIS) values from user-specified input raster map layers."
+msgstr "Genera mappe raster separate per le componenti rosso, verde e blu combinando i valori di tonalità (hue), intensità (intensity), e saturazione (saturation) (HIS) di mappe raster di input definite dall’utente."
 #: ../raster/r.his/main.c:76 ../display/d.his/main.c:76
 msgid "Name of layer to be used for HUE"
@@ -5856,12 +5643,8 @@
 msgstr "Nome mappa raster"
 #: ../raster/r.buffer/main.c:69
-msgid ""
-"Creates a raster map layer showing buffer zones surrounding cells that "
-"contain non-NULL category values."
-msgstr ""
-"Crea un raster mostrando una zona di buffer intorno alle celle che "
-"contengono valori non nulli."
+msgid "Creates a raster map layer showing buffer zones surrounding cells that contain non-NULL category values."
+msgstr "Crea un raster mostrando una zona di buffer intorno alle celle che contengono valori non nulli."
 #: ../raster/r.buffer/main.c:81
 #: ../locale/scriptstrings/r.buffer_to_translate.c:5
@@ -5876,8 +5659,7 @@
 #: ../raster/r.buffer/main.c:94
 #: ../locale/scriptstrings/r.buffer_to_translate.c:4
 msgid "Ignore zero (0) data cells instead of NULL cells"
-msgstr ""
-"Ignora le celle con valore zero (0) invece di ignorare quelle con valore NULL"
+msgstr "Ignora le celle con valore zero (0) invece di ignorare quelle con valore NULL"
 #: ../raster/r.buffer/main.c:131
 msgid "Parse distances error"
@@ -5982,17 +5764,8 @@
 msgstr "Mappa raster <%s> creata."
 #: ../raster/r.walk/main.c:183
-msgid ""
-"Outputs a raster map layer showing the anisotropic cumulative cost of moving "
-"between different geographic locations on an input elevation raster map "
-"layer whose cell category values represent elevation combined with an input "
-"raster map layer whose cell values represent friction cost."
-msgstr ""
-"Produce un tematismo raster che mostra ìl costo cumulativo anisotropico "
-"necessario per muoversi tra due punti geografici diversi su una mappa raster "
-"di elevazione di input i cui valori di categoria delle celle rappresentano "
-"l'elevazione, combinata con un tematismo raster di input i cui valori di "
-"categoria delle celle rappresentano il costo di attrito."
+msgid "Outputs a raster map layer showing the anisotropic cumulative cost of moving between different geographic locations on an input elevation raster map layer whose cell category values represent elevation combined with an input raster map layer whose cell values represent friction cost."
+msgstr "Produce un tematismo raster che mostra ìl costo cumulativo anisotropico necessario per muoversi tra due punti geografici diversi su una mappa raster di elevazione di input i cui valori di categoria delle celle rappresentano l'elevazione, combinata con un tematismo raster di input i cui valori di categoria delle celle rappresentano il costo di attrito."
 #: ../raster/r.walk/main.c:193
 msgid "Name of elevation input raster map"
@@ -6038,20 +5811,15 @@
 #: ../raster/r.walk/main.c:284
 msgid "Coefficients for walking energy formula parameters a,b,c,d"
-msgstr ""
-"Coefficienti per i parametri a,b,c,d per la formula dell'energia di cammino"
+msgstr "Coefficienti per i parametri a,b,c,d per la formula dell'energia di cammino"
 #: ../raster/r.walk/main.c:293
 msgid "Lambda coefficients for combining walking energy and friction cost"
-msgstr ""
-"Coefficienti lamda per combinare assieme l'energia di cammino e il costo di "
-"frizione"
+msgstr "Coefficienti lamda per combinare assieme l'energia di cammino e il costo di frizione"
 #: ../raster/r.walk/main.c:302
 msgid "Slope factor determines travel energy cost per height step"
-msgstr ""
-"Il fattore pendenza determina il costo di viaggio in termini di energia in "
-"relazione al dislivello"
+msgstr "Il fattore pendenza determina il costo di viaggio in termini di energia in relazione al dislivello"
 #: ../raster/r.walk/main.c:311
 msgid "Keep null values in output map"
@@ -6084,9 +5852,7 @@
 #: ../raster/r.walk/main.c:427
 msgid "Warning: assigning negative cost to null cell. Null cells excluded."
-msgstr ""
-"Attenzione: assegnazione di costi negativi alle celle vuote. I valori nulli "
-"vengono esclusi."
+msgstr "Attenzione: assegnazione di costi negativi alle celle vuote. I valori nulli vengono esclusi."
 #: ../raster/r.walk/main.c:612
 #, fuzzy, c-format
@@ -6168,8 +5934,7 @@
 #: ../raster/r.what/main.c:145
 msgid "Output integer category values, not cell values"
-msgstr ""
-"Visualizzare i valori delle categorie integer e non i valori delle celle"
+msgstr "Visualizzare i valori delle categorie integer e non i valori delle celle"
 #: ../raster/r.what/main.c:149
 msgid "Turn on cache reporting"
@@ -6196,9 +5961,7 @@
 #: ../raster/r.contour/main.c:90
 msgid "Produces a vector map of specified contours from a raster map."
-msgstr ""
-"Produce una mappa vettoriale di curve di livello in base a parametri "
-"specificati a partire da una mappa raster."
+msgstr "Produce una mappa vettoriale di curve di livello in base a parametri specificati a partire da una mappa raster."
 #: ../raster/r.contour/main.c:101
 msgid "List of contour levels"
@@ -6222,12 +5985,11 @@
 #: ../raster/r.contour/main.c:133
 msgid "Neither \"levels\" nor \"step\" parameter specified."
-msgstr ""
-"Non è stato specificato né il parametro \"levels\" né il parametro \"step\""
+msgstr "Non è stato specificato né il parametro \"levels\" né il parametro \"step\""
 # fp: valori a virgola mobile
 #: ../raster/r.contour/main.c:141 ../raster/r.stats/main.c:307
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to read fp range of raster map <%s>"
 msgstr "Impossibile leggere l'intervallo fp della mappa raster <%s>"
@@ -6321,15 +6083,11 @@
 #: ../raster/r.series/main.c:135
-msgid ""
-"Makes each output cell value a function of the values assigned to the "
-"corresponding cells in the input raster map layers."
+msgid "Makes each output cell value a function of the values assigned to the corresponding cells in the input raster map layers."
 msgstr ""
 #: ../raster/r.series/main.c:144
-msgid ""
-"Input file with raster map names and optional weights per line, field "
-"separator between name and weight is |"
+msgid "Input file with raster map names and optional weights per line, field separator between name and weight is |"
 msgstr ""
 #: ../raster/r.series/main.c:155
@@ -6337,8 +6095,7 @@
 msgstr ""
 #: ../raster/r.series/main.c:170
-msgid ""
-"Weighting factor for each input map, default value is 1.0 for each input map"
+msgid "Weighting factor for each input map, default value is 1.0 for each input map"
 msgstr ""
 #: ../raster/r.series/main.c:177
@@ -6602,17 +6359,12 @@
 msgstr ""
 #: ../raster/r.in.xyz/main.c:164
-msgid ""
-"Create a raster map from an assemblage of many coordinates using univariate "
-"statistics."
-msgstr ""
-"Crea un raster da un assemblaggio di molte coordinate usando statistiche "
-"univariate"
+msgid "Create a raster map from an assemblage of many coordinates using univariate statistics."
+msgstr "Crea un raster da un assemblaggio di molte coordinate usando statistiche univariate"
 #: ../raster/r.in.xyz/main.c:168
 msgid "ASCII file containing input data (or \"-\" to read from stdin)"
-msgstr ""
-"File ASCII contenente i dati di input (o \"-\" per leggere dallo stdin)"
+msgstr "File ASCII contenente i dati di input (o \"-\" per leggere dallo stdin)"
 #: ../raster/r.in.xyz/main.c:176 ../raster/r.in.lidar/main.c:177
 msgid "Statistic to use for raster values"
@@ -6654,9 +6406,7 @@
 msgstr ""
 #: ../raster/r.in.xyz/main.c:256 ../raster/r.in.lidar/main.c:229
-msgid ""
-"Discard <trim> percent of the smallest and <trim> percent of the largest "
-"observations"
+msgid "Discard <trim> percent of the smallest and <trim> percent of the largest observations"
 msgstr ""
 #: ../raster/r.in.xyz/main.c:261 ../raster/r.in.lidar/main.c:239
@@ -6688,8 +6438,7 @@
 msgstr ""
 #: ../raster/r.in.xyz/main.c:482
-msgid ""
-"If input is not from a file it is only possible to perform a single pass."
+msgid "If input is not from a file it is only possible to perform a single pass."
 msgstr ""
 #: ../raster/r.in.xyz/main.c:488 ../raster/r.in.lidar/main.c:561
@@ -6710,8 +6459,7 @@
 #: ../raster/r.in.xyz/main.c:1101 ../raster/r.in.xyz/main.c:1109
 #, c-format
 msgid ""
-"Not enough data columns. Incorrect delimiter or column number? Found the "
-"following character(s) in row %lu:\n"
+"Not enough data columns. Incorrect delimiter or column number? Found the following character(s) in row %lu:\n"
 "[%s]"
 msgstr ""
@@ -6758,8 +6506,7 @@
 msgstr "Tipo sconosciuto"
 #: ../raster/r.composite/main.c:75
-msgid ""
-"Combines red, green and blue raster maps into a single composite raster map."
+msgid "Combines red, green and blue raster maps into a single composite raster map."
 msgstr "Combina raster rosso, verde e blu in un singolo raster"
 #: ../raster/r.composite/main.c:89 ../raster/r.out.ppm3/main.c:63
@@ -6795,8 +6542,7 @@
 #: ../raster/r.composite/main.c:285
 msgid "Creating color table for output raster map..."
-msgstr ""
-"Creazione della tavola dei colori per la mappa raster di output in corso..."
+msgstr "Creazione della tavola dei colori per la mappa raster di output in corso..."
 #: ../raster/r.solute.transport/main.c:59
 msgid "The initial concentration in [kg/m^3]"
@@ -6816,9 +6562,7 @@
 msgstr ""
 #: ../raster/r.solute.transport/main.c:79
-msgid ""
-"The status for each cell, = 0 - inactive cell, 1 - active cell, 2 - "
-"dirichlet- and 3 - transfer boundary condition"
+msgid "The status for each cell, = 0 - inactive cell, 1 - active cell, 2 - dirichlet- and 3 - transfer boundary condition"
 msgstr ""
 #: ../raster/r.solute.transport/main.c:85
@@ -6844,14 +6588,11 @@
 msgstr ""
 #: ../raster/r.solute.transport/main.c:103
-msgid ""
-"Concentration sources and sinks bounded to a water source or sink in [kg/s]"
+msgid "Concentration sources and sinks bounded to a water source or sink in [kg/s]"
 msgstr ""
 #: ../raster/r.solute.transport/main.c:112
-msgid ""
-"Concentration of inner sources and inner sinks in [kg/s] (i.e. a chemical "
-"reaction)"
+msgid "Concentration of inner sources and inner sinks in [kg/s] (i.e. a chemical reaction)"
 msgstr ""
 #: ../raster/r.solute.transport/main.c:117
@@ -6871,21 +6612,15 @@
 msgstr "Superficie inferiore dell'acquifero in [m]"
 #: ../raster/r.solute.transport/main.c:132
-msgid ""
-"The resulting concentration of the numerical solute transport calculation "
-"will be written to this map. [kg/m^3]"
+msgid "The resulting concentration of the numerical solute transport calculation will be written to this map. [kg/m^3]"
 msgstr ""
 #: ../raster/r.solute.transport/main.c:140
-msgid ""
-"Calculate and store the groundwater filter velocity vector part in x "
-"direction [m/s]\n"
+msgid "Calculate and store the groundwater filter velocity vector part in x direction [m/s]\n"
 msgstr ""
 #: ../raster/r.solute.transport/main.c:147
-msgid ""
-"Calculate and store the groundwater filter velocity vector part in y "
+msgid "Calculate and store the groundwater filter velocity vector part in y direction [m/s]\n"
 msgstr ""
 #: ../raster/r.solute.transport/main.c:161
@@ -6897,9 +6632,7 @@
 msgstr ""
 #: ../raster/r.solute.transport/main.c:177
-msgid ""
-"Use this number of time loops if the CFL flag is off. The timestep will "
-"become dt/loops."
+msgid "Use this number of time loops if the CFL flag is off. The timestep will become dt/loops."
 msgstr ""
 #: ../raster/r.solute.transport/main.c:187
@@ -6916,17 +6649,14 @@
 msgstr "Nome del raster"
 #: ../raster/r.solute.transport/main.c:233
-msgid ""
-"Numerical calculation program for transient, confined and unconfined solute "
-"transport in two dimensions"
+msgid "Numerical calculation program for transient, confined and unconfined solute transport in two dimensions"
 msgstr ""
 #: ../raster/r.solute.transport/main.c:244 ../raster/r.gwflow/main.c:218
 #: ../raster/r.topidx/main.c:53
 #, c-format
 msgid "Lat/Long location is not supported by %s. Please reproject map first."
-msgstr ""
-"La location Lat/Long non è supportata da %s. Prima riproiettare la mappa."
+msgstr "La location Lat/Long non è supportata da %s. Prima riproiettare la mappa."
 #: ../raster/r.solute.transport/main.c:258
 msgid "The direct LU solver do not work with sparse matrices"
@@ -6958,8 +6688,7 @@
 #: ../raster/r.solute.transport/main.c:385
 #, c-format
-msgid ""
-"The time step is to large: %gs. The largest time step should be of size %gs."
+msgid "The time step is to large: %gs. The largest time step should be of size %gs."
 msgstr ""
 #: ../raster/r.solute.transport/main.c:397
@@ -6979,12 +6708,8 @@
 msgstr "colonne: %d"
 #: ../raster/r.volume/main.c:61
-msgid ""
-"Calculates the volume of data \"clumps\", and (optionally) produces a GRASS "
-"vector points map containing the calculated centroids of these clumps."
-msgstr ""
-"Calcola il volume dei \"gruppi\" di dati, e (opzionalmente) produce un "
-"vettoriale contenendo i centroidi calcolati di questi gruppi"
+msgid "Calculates the volume of data \"clumps\", and (optionally) produces a GRASS vector points map containing the calculated centroids of these clumps."
+msgstr "Calcola il volume dei \"gruppi\" di dati, e (opzionalmente) produce un vettoriale contenendo i centroidi calcolati di questi gruppi"
 #: ../raster/r.volume/main.c:67
 msgid "Existing raster map representing data that will be summed within clumps"
@@ -7016,23 +6741,17 @@
 #: ../raster/r.gwflow/main.c:62
-msgid ""
-"Name of input raster map providing Boundary condition status: 0-inactive, 1-"
-"active, 2-dirichlet"
+msgid "Name of input raster map providing Boundary condition status: 0-inactive, 1-active, 2-dirichlet"
 msgstr ""
 #: ../raster/r.gwflow/main.c:67
 #, fuzzy
-msgid ""
-"Name of input raster map with x-part of the hydraulic conductivity tensor in "
-"[m/s]"
+msgid "Name of input raster map with x-part of the hydraulic conductivity tensor in [m/s]"
 #: ../raster/r.gwflow/main.c:72
 #, fuzzy
-msgid ""
-"Name of input raster map with y-part of the hydraulic conductivity tensor in "
-"[m/s]"
+msgid "Name of input raster map with y-part of the hydraulic conductivity tensor in [m/s]"
 #: ../raster/r.gwflow/main.c:77
@@ -7041,9 +6760,7 @@
 msgstr "Nessuna mappa in input specificata"
 #: ../raster/r.gwflow/main.c:81
-msgid ""
-"Name of input raster map with storativity for confined or effective porosity "
-"for unconfined groundwater flow booth in [-] "
+msgid "Name of input raster map with storativity for confined or effective porosity for unconfined groundwater flow booth in [-] "
 msgstr ""
 #: ../raster/r.gwflow/main.c:86
@@ -7057,14 +6774,12 @@
 #: ../raster/r.gwflow/main.c:92
 #, fuzzy
-msgid ""
-"Name of input raster map describing the top surface of the aquifer in [m]"
+msgid "Name of input raster map describing the top surface of the aquifer in [m]"
 msgstr "mappa raster di base"
 #: ../raster/r.gwflow/main.c:96
 #, fuzzy
-msgid ""
-"Name of input raster map describing the bottom surface of the aquifer in [m]"
+msgid "Name of input raster map describing the bottom surface of the aquifer in [m]"
 #: ../raster/r.gwflow/main.c:100
@@ -7074,16 +6789,12 @@
 #: ../raster/r.gwflow/main.c:106
 #, fuzzy
-msgid ""
-"Output raster map to store the groundwater filter velocity vector part in x "
-"direction [m/s]"
+msgid "Output raster map to store the groundwater filter velocity vector part in x direction [m/s]"
 #: ../raster/r.gwflow/main.c:112
 #, fuzzy
-msgid ""
-"Output raster map to store the groundwater filter velocity vector part in y "
-"direction [m/s]"
+msgid "Output raster map to store the groundwater filter velocity vector part in y direction [m/s]"
 #: ../raster/r.gwflow/main.c:118
@@ -7102,35 +6813,26 @@
 #: ../raster/r.gwflow/main.c:140
 #, fuzzy
-msgid ""
-"Name of input raster map providing the water level (head) of the river with "
-"leakage connection in [m]"
+msgid "Name of input raster map providing the water level (head) of the river with leakage connection in [m]"
 #: ../raster/r.gwflow/main.c:147
 #, fuzzy
-msgid ""
-"Name of input raster map providing the leakage coefficient of the river bed "
-"in [1/s]."
+msgid "Name of input raster map providing the leakage coefficient of the river bed in [1/s]."
 #: ../raster/r.gwflow/main.c:155
 #, fuzzy
-msgid ""
-"Name of input raster map providing the height of the drainage bed in [m]"
+msgid "Name of input raster map providing the height of the drainage bed in [m]"
 #: ../raster/r.gwflow/main.c:162
 #, fuzzy
-msgid ""
-"Name of input raster map providing the leakage coefficient of the drainage "
-"bed in [1/s]"
+msgid "Name of input raster map providing the leakage coefficient of the drainage bed in [1/s]"
 #: ../raster/r.gwflow/main.c:173
-msgid ""
-"Allocate a full quadratic linear equation system, default is a sparse linear "
-"equation system."
+msgid "Allocate a full quadratic linear equation system, default is a sparse linear equation system."
 msgstr ""
 #: ../raster/r.gwflow/main.c:206
@@ -7139,9 +6841,7 @@
 msgstr "Colore del bordo"
 #: ../raster/r.gwflow/main.c:208
-msgid ""
-"Numerical calculation program for transient, confined and unconfined "
-"groundwater flow in two dimensions."
+msgid "Numerical calculation program for transient, confined and unconfined groundwater flow in two dimensions."
 msgstr ""
 #: ../raster/r.gwflow/main.c:233
@@ -7153,9 +6853,7 @@
 msgstr ""
 #: ../raster/r.gwflow/main.c:257
-msgid ""
-"The cholesky solver dos not work with sparse matrices. You may choose a full "
-"filled quadratic matrix, flag -f."
+msgid "The cholesky solver dos not work with sparse matrices. You may choose a full filled quadratic matrix, flag -f."
 msgstr ""
 #: ../raster/r.gwflow/main.c:287
@@ -7189,10 +6887,7 @@
 #: ../raster/r.topidx/file_io.c:30
 #, c-format
-msgid ""
-"Current region resolution [%.2fx%.2f] lower than input map resolution [%.2fx"
-"%.2f]! Needs to be at least identical or the current region resolution lower "
-"than the input map resolution"
+msgid "Current region resolution [%.2fx%.2f] lower than input map resolution [%.2fx%.2f]! Needs to be at least identical or the current region resolution lower than the input map resolution"
 msgstr ""
 #: ../raster/r.topidx/file_io.c:32 ../raster/r.fill.dir/main.c:184
@@ -7209,11 +6904,7 @@
 msgstr "Nome di una mappa raster esistente"
 #: ../raster/r.ros/main.c:215
-msgid ""
-"Generates three, or four raster map layers showing 1) the base "
-"(perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) the "
-"direction of the maximum ROS, and optionally 4) the maximum potential "
-"spotting distance."
+msgid "Generates three, or four raster map layers showing 1) the base (perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) the direction of the maximum ROS, and optionally 4) the maximum potential spotting distance."
 msgstr ""
 #: ../raster/r.ros/main.c:222
@@ -7266,23 +6957,17 @@
 msgstr ""
 #: ../raster/r.ros/main.c:296
-msgid ""
-"No dead fuel moisture is given. At least one of the 1-h, 10-h, 100-h "
-"moisture layers is required."
+msgid "No dead fuel moisture is given. At least one of the 1-h, 10-h, 100-h moisture layers is required."
 msgstr ""
 #: ../raster/r.ros/main.c:320
 #, c-format
-msgid ""
-"A wind direction layer should be given if the wind velocity layer <%s> has "
-"been given"
+msgid "A wind direction layer should be given if the wind velocity layer <%s> has been given"
 msgstr ""
 #: ../raster/r.ros/main.c:325
 #, c-format
-msgid ""
-"A wind velocity layer should be given if the wind direction layer <%s> has "
-"been given"
+msgid "A wind velocity layer should be given if the wind direction layer <%s> has been given"
 msgstr ""
 #: ../raster/r.ros/main.c:339
@@ -7312,10 +6997,8 @@
 #: ../raster/r.in.arc/main.c:63
 #, fuzzy
-msgid ""
-"Converts an ESRI ARC/INFO ascii raster file (GRID) into a GRASS raster map."
-msgstr ""
-"Converte un file raster ESRI ARC/INFO acii (GRID) in un raster (binario)"
+msgid "Converts an ESRI ARC/INFO ascii raster file (GRID) into a GRASS raster map."
+msgstr "Converte un file raster ESRI ARC/INFO acii (GRID) in un raster (binario)"
 #: ../raster/r.in.arc/main.c:70
 msgid "ARC/INFO ASCII raster file (GRID) to be imported"
@@ -7385,9 +7068,7 @@
 msgstr ""
 #: ../raster/r.fill.dir/main.c:88
-msgid ""
-"Filters and generates a depressionless elevation map and a flow direction "
-"map from a given elevation raster map."
+msgid "Filters and generates a depressionless elevation map and a flow direction map from a given elevation raster map."
 msgstr ""
 #: ../raster/r.fill.dir/main.c:104
@@ -7455,7 +7136,7 @@
 #: ../raster/r.mfilter/main.c:59
 msgid "Performs raster map matrix filter."
-msgstr ""
+msgstr "Applica un filtro matrice sulla mappa raster"
 #: ../raster/r.mfilter/main.c:70
 msgid "Path to filter file"
@@ -7533,9 +7214,7 @@
 msgstr "Formato del file del filtro non valido"
 #: ../raster/r.statistics2/main.c:104
-msgid ""
-"Calculates category or object oriented statistics (accumulator-based "
-"statistics)."
+msgid "Calculates category or object oriented statistics (accumulator-based statistics)."
 msgstr ""
 #: ../raster/r.statistics2/main.c:177
@@ -7567,8 +7246,7 @@
 #: ../raster/r.out.arc/main.c:71
 msgid "Name of an output ARC-GRID map (use out=- for stdout)"
-msgstr ""
-"Nome di output di una mappa ARC-GRID (usa out=- per lo standard output)"
+msgstr "Nome di output di una mappa ARC-GRID (usa out=- per lo standard output)"
 #: ../raster/r.out.arc/main.c:78
 msgid "Number of decimal places"
@@ -7601,12 +7279,8 @@
 msgstr ""
 #: ../raster/r.clump/main.c:50
-msgid ""
-"Recategorizes data in a raster map by grouping cells that form physically "
-"discrete areas into unique categories."
-msgstr ""
-"Ricategorizza i dati in una mappa raster raggruppando celle che formano aree "
-"fisicamente distinte in categorie singole."
+msgid "Recategorizes data in a raster map by grouping cells that form physically discrete areas into unique categories."
+msgstr "Ricategorizza i dati in una mappa raster raggruppando celle che formano aree fisicamente distinte in categorie singole."
 #: ../raster/r.clump/main.c:61
 msgid "Title"
@@ -7705,9 +7379,7 @@
 #: ../raster/r.colors/edit_colors.c:159
 #, fuzzy, c-format
 msgid "One of -%c or options <%s>, <%s> or <%s> must be specified"
-msgstr ""
-"Dev'essere specificato \"-i\" o \"-r\", o le opzioni \"color\", \"rast\" o "
-"\"rules\"!"
+msgstr "Dev'essere specificato \"-i\" o \"-r\", o le opzioni \"color\", \"rast\" o \"rules\"!"
 #: ../raster/r.colors/edit_colors.c:164
 #, fuzzy, c-format
@@ -7741,23 +7413,17 @@
 #: ../raster/r.colors/edit_colors.c:233
 #, fuzzy, c-format
 msgid "Color table 'random' is not supported for floating point %s map"
-msgstr ""
-"La tavola dei colori 'random' non è supportata dai raster con valori a "
-"virgola mobile"
+msgstr "La tavola dei colori 'random' non è supportata dai raster con valori a virgola mobile"
 #: ../raster/r.colors/edit_colors.c:237
 #, fuzzy, c-format
 msgid "Color table 'grey.eq' is not supported for floating point %s map"
-msgstr ""
-"La tavola dei colori 'grey.eq' non è supportata dai raster con valori a "
-"virgola mobile"
+msgstr "La tavola dei colori 'grey.eq' non è supportata dai raster con valori a virgola mobile"
 #: ../raster/r.colors/edit_colors.c:243
 #, fuzzy, c-format
 msgid "Color table 'grey.log' is not supported for floating point %s map"
-msgstr ""
-"La tavola dei colori 'grey.log' non è supportata dai raster con valori a "
-"virgola mobile"
+msgstr "La tavola dei colori 'grey.log' non è supportata dai raster con valori a virgola mobile"
 #: ../raster/r.colors/edit_colors.c:251
 #, c-format
@@ -7855,9 +7521,7 @@
 #: ../raster/r.colors/stats.c:84
 msgid "Unable to use logarithmic scaling if range includes zero"
-msgstr ""
-"Non è possibile usare lo scaling logaritmico se il campo di variazione "
-"include lo zero"
+msgstr "Non è possibile usare lo scaling logaritmico se il campo di variazione include lo zero"
 #: ../raster/r.colors/stats.c:112
 #, fuzzy, c-format
@@ -7899,12 +7563,8 @@
 msgstr "Nessuna mappa di output"
 #: ../raster/r.to.rast3/main.c:230 ../raster/r.to.rast3elev/main.c:427
-msgid ""
-"The 2d and 3d region settings are different. I will use the g3d settings to "
-"adjust the 2d region."
-msgstr ""
-"La regione 2D e 3D hanno impostazioni differenti. Saranno usate le "
-"impostazioni g3d per aggiustare la regione 2D"
+msgid "The 2d and 3d region settings are different. I will use the g3d settings to adjust the 2d region."
+msgstr "La regione 2D e 3D hanno impostazioni differenti. Saranno usate le impostazioni g3d per aggiustare la regione 2D"
 #: ../raster/r.to.rast3/main.c:262
 #, c-format
@@ -7928,22 +7588,8 @@
 msgstr "Radiazione solare e modello di irraggiamento"
 #: ../raster/r.sun/main.c:233
-msgid ""
-"Computes direct (beam), diffuse and reflected solar irradiation raster maps "
-"for given day, latitude, surface and atmospheric conditions. Solar "
-"parameters (e.g. sunrise, sunset times, declination, extraterrestrial "
-"irradiance, daylight length) are saved in the map history file. "
-"Alternatively, a local time can be specified to compute solar incidence "
-"angle and/or irradiance raster maps. The shadowing effect of the topography "
-"is optionally incorporated."
-msgstr ""
-"Calcola mappe raster di radiazione solare diretta, diffusa e riflessa per un "
-"dato giorno, latitudine e condizioni atmosferiche. I parametri solari (e.g. "
-"ora del sorgere e tramontare del sole, declinazione, radiazione "
-"extraterrestre, ore di luce) sono salvate in un file della cronologia. In "
-"alternativa può essere definita un'ora locale per calcolare mappe "
-"dell'angolo di incidenza o di radiazione. L'effetto ombreggiatura della "
-"topografia è incorporato opzionalmente."
+msgid "Computes direct (beam), diffuse and reflected solar irradiation raster maps for given day, latitude, surface and atmospheric conditions. Solar parameters (e.g. sunrise, sunset times, declination, extraterrestrial irradiance, daylight length) are saved in the map history file. Alternatively, a local time can be specified to compute solar incidence angle and/or irradiance raster maps. The shadowing effect of the topography is optionally incorporated."
+msgstr "Calcola mappe raster di radiazione solare diretta, diffusa e riflessa per un dato giorno, latitudine e condizioni atmosferiche. I parametri solari (e.g. ora del sorgere e tramontare del sole, declinazione, radiazione extraterrestre, ore di luce) sono salvate in un file della cronologia. In alternativa può essere definita un'ora locale per calcolare mappe dell'angolo di incidenza o di radiazione. L'effetto ombreggiatura della topografia è incorporato opzionalmente."
 #: ../raster/r.sun/main.c:247 ../raster/r.horizon/main.c:196
 msgid "Name of the input elevation raster map [meters]"
@@ -7967,34 +7613,24 @@
 msgstr "Opzioni di input"
 #: ../raster/r.sun/main.c:256
-msgid ""
-"Name of the input aspect map (terrain aspect or azimuth of the solar panel) "
-"[decimal degrees]"
-msgstr ""
-"Nome della mappa delle esposizioni (esposizione del terreno o azimuth del "
-"pannello solare) [gradi decimali]"
+msgid "Name of the input aspect map (terrain aspect or azimuth of the solar panel) [decimal degrees]"
+msgstr "Nome della mappa delle esposizioni (esposizione del terreno o azimuth del pannello solare) [gradi decimali]"
 #: ../raster/r.sun/main.c:265
 msgid "A single value of the orientation (aspect), 270 is south"
 msgstr "Un singolo valore dell'angolo di esposizione, il sud è 270"
 #: ../raster/r.sun/main.c:274
-msgid ""
-"Name of the input slope raster map (terrain slope or solar panel "
-"inclination) [decimal degrees]"
-msgstr ""
-"Nome dela mappa di input delle pendenze (pendenza del terreno o inclinazione "
-"del pannello solare) [gradi decimali]"
+msgid "Name of the input slope raster map (terrain slope or solar panel inclination) [decimal degrees]"
+msgstr "Nome dela mappa di input delle pendenze (pendenza del terreno o inclinazione del pannello solare) [gradi decimali]"
 #: ../raster/r.sun/main.c:282
 msgid "A single value of inclination (slope)"
 msgstr "Un sngolo valore di inclinazione (pendenza)"
 #: ../raster/r.sun/main.c:291
-msgid ""
-"Name of the Linke atmospheric turbidity coefficient input raster map [-]"
-msgstr ""
-"Nome della mappa raster di input dei coefficienti di torbidità di Linke [-]"
+msgid "Name of the Linke atmospheric turbidity coefficient input raster map [-]"
+msgstr "Nome della mappa raster di input dei coefficienti di torbidità di Linke [-]"
 #: ../raster/r.sun/main.c:301
 msgid "A single value of the Linke atmospheric turbidity coefficient [-]"
@@ -8010,25 +7646,20 @@
 #: ../raster/r.sun/main.c:331
 msgid "Name of input raster map containing latitudes [decimal degrees]"
-msgstr ""
-"Nome della mappa raster di input contenente le latitudini [gradi decimali]"
+msgstr "Nome della mappa raster di input contenente le latitudini [gradi decimali]"
 #: ../raster/r.sun/main.c:340
 msgid "Name of input raster map containing longitudes [decimal degrees]"
-msgstr ""
-"Nome della mappa raster di input contenente le longitudini [gradi decimali]"
+msgstr "Nome della mappa raster di input contenente le longitudini [gradi decimali]"
 #: ../raster/r.sun/main.c:349
 #, fuzzy
-msgid ""
-"Name of real-sky beam radiation coefficient (thick cloud) input raster map "
-"[0-1]"
+msgid "Name of real-sky beam radiation coefficient (thick cloud) input raster map [0-1]"
 msgstr "Nome della mappa raster di input dei coefficienti di albedo [-]"
 #: ../raster/r.sun/main.c:358
 #, fuzzy
-msgid ""
-"Name of real-sky diffuse radiation coefficient (haze) input raster map [0-1]"
+msgid "Name of real-sky diffuse radiation coefficient (haze) input raster map [0-1]"
 #: ../raster/r.sun/main.c:366
@@ -8041,7 +7672,7 @@
 #: ../raster/r.sun/main.c:383
 msgid "Output incidence angle raster map (mode 1 only)"
-msgstr ""
+msgstr "Mappa raster di output dell'angolo di incidenza (solo modalità 1)"
 #: ../raster/r.sun/main.c:384 ../raster/r.sun/main.c:393
 #: ../raster/r.sun/main.c:402 ../raster/r.sun/main.c:411
@@ -8056,40 +7687,24 @@
 msgstr "Opzioni di output"
 #: ../raster/r.sun/main.c:392
-msgid ""
-"Output beam irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
-"day-1] (mode 2)"
-msgstr ""
-"Mappa raster di output della radiazione diretta, istantanea [W.m-2] "
-"(modalità 1) o cumulata [Wh.m-2.giorno-1] (modalità 2)"
+msgid "Output beam irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgstr "Mappa raster di output della radiazione diretta, istantanea [W.m-2] (modalità 1) o cumulata [Wh.m-2.giorno-1] (modalità 2)"
 #: ../raster/r.sun/main.c:401
 msgid "Output insolation time raster map [h] (mode 2 only)"
 msgstr "Mappa raster di output del tempo di insolazione [h] (solo modalità 2)"
 #: ../raster/r.sun/main.c:410
-msgid ""
-"Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
-"day-1] (mode 2)"
-msgstr ""
-"Mappa raster di output della radiazione diffusa, istantanea [W.m-2] "
+msgid "Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgstr "Mappa raster di output della radiazione diffusa, istantanea [W.m-2] (modalità 1) o cumulata [Wh.m-2.giorno-1] (modalità 2)"
 #: ../raster/r.sun/main.c:419
-msgid ""
-"Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster "
-"map [Wh.m-2.day-1] (mode 2)"
-msgstr ""
-"Mappa raster di output della radiazione riflessa, istantanea [W.m-2] "
+msgid "Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgstr "Mappa raster di output della radiazione riflessa, istantanea [W.m-2] (modalità 1) o cumulata [Wh.m-2.giorno-1] (modalità 2)"
 #: ../raster/r.sun/main.c:428
-msgid ""
-"Output global (total) irradiance/irradiation [W.m-2] (mode 1) or irradiance/"
-"irradiation raster map [Wh.m-2.day-1] (mode 2)"
-msgstr ""
-"Mappa raster di output della radiazione globale (totale), istantanea [W.m-2] "
+msgid "Output global (total) irradiance/irradiation [W.m-2] (mode 1) or irradiance/irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgstr "Mappa raster di output della radiazione globale (totale), istantanea [W.m-2] (modalità 1) o cumulata [Wh.m-2.giorno-1] (modalità 2)"
 #: ../raster/r.sun/main.c:435
 msgid "No. of day of the year (1-365)"
@@ -8097,20 +7712,15 @@
 #: ../raster/r.sun/main.c:444
 msgid "Time step when computing all-day radiation sums [decimal hours]"
-msgstr ""
-"Cadenza temporale per calcolare la somma delle radiazioni per l'intera "
-"giornata [ore decimali]"
+msgstr "Frequenza oraria usata nel calcolo della somma delle radiazioni per l'intera giornata [ore decimali]"
 #: ../raster/r.sun/main.c:451
 msgid "Declination value (overriding the internally computed value) [radians]"
-msgstr ""
-"Valore della declinazione (che sostituisce il valore calcolato internamente) "
-"[radianti]"
+msgstr "Valore della declinazione (che sostituisce il valore calcolato internamente) [radianti]"
 #: ../raster/r.sun/main.c:459
 msgid "Local (solar) time (to be set for mode 1 only) [decimal hours]"
-msgstr ""
-"Ora locale (solare) (da impostare solo per la modalità 1) [ore decimali]"
+msgstr "Ora locale (solare) (da impostare solo per la modalità 1) [ore decimali]"
 #: ../raster/r.sun/main.c:482 ../raster/r.horizon/main.c:288
 msgid "Sampling distance step coefficient (0.5-1.5)"
@@ -8122,7 +7732,7 @@
 #: ../raster/r.sun/main.c:497
 msgid "Civil time zone value, if none, the time will be local solar time"
-msgstr ""
+msgstr "Valore del fuso orario legale; se non fornito l'ora sarà l'ora solare"
 #: ../raster/r.sun/main.c:503
 msgid "Incorporate the shadowing effect of terrain"
@@ -8134,8 +7744,7 @@
 #: ../raster/r.sun/main.c:555
 msgid "You must give the longitude raster if you use civil time"
-msgstr ""
-"Si deve fornire il raster delle longitudini per utilizzare l'ora legale"
+msgstr "Si deve fornire il raster delle longitudini per utilizzare l'ora legale"
 #: ../raster/r.sun/main.c:558
 msgid "Error reading civil time zone value"
@@ -8151,12 +7760,11 @@
 #: ../raster/r.sun/main.c:591
 msgid "Error reading time step size"
-msgstr ""
+msgstr "Errore nella lettura della frequenza oraria"
 #: ../raster/r.sun/main.c:593
-#, fuzzy
 msgid "Invalid time step size"
-msgstr "Metodo non valido: %s"
+msgstr "Misura della frequenza oraria non valida"
 #: ../raster/r.sun/main.c:597
 msgid "Error reading horizon step size"
@@ -8167,23 +7775,16 @@
 msgstr ""
 #: ../raster/r.sun/main.c:604
-msgid ""
-"If you use the horizon option you must also set the 'horizonstep' parameter."
-msgstr ""
-"Se si utilizza l'opzione horizon bisogna anche impostare il parametro "
-"'horizonstep'"
+msgid "If you use the horizon option you must also set the 'horizonstep' parameter."
+msgstr "Se si utilizza l'opzione horizon bisogna anche impostare il parametro 'horizonstep'"
 #: ../raster/r.sun/main.c:610
 msgid "Time and insol_time are incompatible options"
 msgstr "Time e insol_time sono opzioni incompatibili"
 #: ../raster/r.sun/main.c:612
-msgid ""
-"Mode 1: instantaneous solar incidence angle & irradiance using a set local "
-"time"
-msgstr ""
-"Modalità 1: angolo di incidenza e radiazione istantanei usando un'ora locale "
-"definita"
+msgid "Mode 1: instantaneous solar incidence angle & irradiance using a set local time"
+msgstr "Modalità 1: angolo di incidenza e radiazione istantanei usando un'ora locale definita"
 #: ../raster/r.sun/main.c:617
 msgid "incidout requires time parameter to be set"
@@ -8191,37 +7792,28 @@
 #: ../raster/r.sun/main.c:619
 msgid "Mode 2: integrated daily irradiation for a given day of the year"
-msgstr ""
-"Modalità 2: radiazione giornaliera integrata per un dato giorno dell'anno"
+msgstr "Modalità 2: radiazione giornaliera integrata per un dato giorno dell'anno"
 #: ../raster/r.sun/main.c:665
 msgid "If you use -s and no horizon rasters, numpartitions must be =1"
-msgstr ""
-"Se si usa -s e nessun raster dell'orizzonte, il numpartitions dev'essere=1"
+msgstr "Se si usa -s e nessun raster dell'orizzonte, il numpartitions dev'essere=1"
 #: ../raster/r.sun/main.c:678
-msgid ""
-"If you want to save memory and to use shadows, you must use pre-calculated "
-"horizons."
-msgstr ""
-"Per risparmiare memoria e usare l'ombreggiatura si devono usare orizzonti "
-"precalcolati"
+msgid "If you want to save memory and to use shadows, you must use pre-calculated horizons."
+msgstr "Per risparmiare memoria e usare l'ombreggiatura si devono usare orizzonti precalcolati"
 #: ../raster/r.sun/main.c:723 ../imagery/i.latlong/main.c:102
 #: ../display/d.where/main.c:106 ../general/g.region/printwindow.c:247
 #: ../general/g.region/printwindow.c:503 ../general/g.region/printwindow.c:622
 msgid "Can't get projection info of current location"
-msgstr ""
-"Non è possibile ottenere le informazioni sulla proiezione della location "
-"corrente"
+msgstr "Non è possibile ottenere le informazioni sulla proiezione della location corrente"
 #: ../raster/r.sun/main.c:727 ../raster/r.horizon/main.c:475
 #: ../imagery/i.latlong/main.c:104 ../display/d.where/main.c:109
 #: ../general/g.region/printwindow.c:250 ../general/g.region/printwindow.c:506
 #: ../general/g.region/printwindow.c:625
 msgid "Can't get projection units of current location"
-msgstr ""
-"Non è possibile ottenere le unità  della proiezione della location attuale"
+msgstr "Non è possibile ottenere le unità  della proiezione della location attuale"
 #: ../raster/r.sun/main.c:731 ../raster/r.horizon/main.c:479
 #: ../imagery/i.latlong/main.c:106 ../ps/ps.map/do_geogrid.c:271
@@ -8229,9 +7821,7 @@
 #: ../general/g.region/printwindow.c:253 ../general/g.region/printwindow.c:509
 #: ../general/g.region/printwindow.c:628
 msgid "Can't get projection key values of current location"
-msgstr ""
-"Non è possibile ottenere i valori chiave della proiezione della location "
-"attuale"
+msgstr "Non è possibile ottenere i valori chiave della proiezione della location attuale"
 #: ../raster/r.sun/main.c:741 ../raster/r.horizon/main.c:489
 #: ../imagery/i.latlong/main.c:115 ../ps/ps.map/do_geogrid.c:277
@@ -8249,33 +7839,17 @@
 msgstr "Devono essere fornite entrambe le mappe latin e longin, oppure nessuna"
 #: ../raster/r.le/r.le.patch/main.c:50
-msgid ""
-"Calculates attribute, patch size, core (interior) size, shape, fractal "
-"dimension, and perimeter measures for sets of patches in a landscape."
-msgstr ""
-"Calcola attributo, dimensione della patch, estensione dell'area centrale "
-"(interna), forma, dimensione frattale e misure di perimetro per insiemi di "
-"patch in un paesaggio"
+msgid "Calculates attribute, patch size, core (interior) size, shape, fractal dimension, and perimeter measures for sets of patches in a landscape."
+msgstr "Calcola attributo, dimensione della patch, estensione dell'area centrale (interna), forma, dimensione frattale e misure di perimetro per insiemi di patch in un paesaggio"
 #: ../raster/r.le/r.le.trace/main.c:58
-msgid ""
-"Displays the boundary of each r.le patch and shows how the boundary is "
-"traced, displays the attribute, size, perimeter and shape indices for each "
-"patch and saves the data in an output file."
-msgstr ""
-"Visualizza i contorni di ogni patch di r.le e mostra come sono stati "
-"tracciati, visualizza gli attributi, la dimensione, il perimetro e gli "
-"indici di forma per ogni patch e salva i dati in un file di output"
+msgid "Displays the boundary of each r.le patch and shows how the boundary is traced, displays the attribute, size, perimeter and shape indices for each patch and saves the data in an output file."
+msgstr "Visualizza i contorni di ogni patch di r.le e mostra come sono stati tracciati, visualizza gli attributi, la dimensione, il perimetro e gli indici di forma per ogni patch e salva i dati in un file di output"
 # ricontrollare
 #: ../raster/r.le/r.le.setup/main.c:59
-#, fuzzy
-msgid ""
-"Interactive tool used to setup the sampling and analysis framework that will "
-"be used by the other r.le programs."
-msgstr ""
-"Strumento interattivo utilizzato per configurare l'ambiente di lavoro per il "
-"campionamento e le analisi che sarà usato dagli altri programmi r.le."
+msgid "Interactive tool used to setup the sampling and analysis framework that will be used by the other r.le programs."
+msgstr "Strumento interattivo utilizzato per configurare l'ambiente di lavoro per il campionamento e le analisi che sarà usato dagli altri programmi r.le."
 #: ../raster/r.le/r.le.setup/main.c:63
 msgid "Raster map to use to setup sampling"
@@ -8292,12 +7866,8 @@
 msgstr "Impossibile leggere il vettore"
 #: ../raster/r.le/r.le.pixel/main.c:47
-msgid ""
-"Contains a set of measures for attributes, diversity, texture, "
-"juxtaposition, and edge."
-msgstr ""
-"Contiene una serie di misure per attributi, diversità, tessitura, "
-"giustapposizione e margine."
+msgid "Contains a set of measures for attributes, diversity, texture, juxtaposition, and edge."
+msgstr "Contiene una serie di misure per attributi, diversità, tessitura, giustapposizione e margine."
 #: ../raster/r.digit/get_label.c:31
 #, c-format
@@ -8314,9 +7884,7 @@
 msgstr ""
 #: ../raster/r.digit/main.c:46
-msgid ""
-"Interactive tool used to draw and save vector features on a graphics monitor "
-"using a pointing device (mouse) and save to a raster map."
+msgid "Interactive tool used to draw and save vector features on a graphics monitor using a pointing device (mouse) and save to a raster map."
 msgstr ""
 #: ../raster/r.digit/main.c:55
@@ -8454,8 +8022,7 @@
 #: ../raster/r.in.bin/main.c:262
 msgid "Get region info from GMT style header"
-msgstr ""
-"Recupera le informazioni sulla regione da una intestazione in stile GMT"
+msgstr "Recupera le informazioni sulla regione da una intestazione in stile GMT"
 #: ../raster/r.in.bin/main.c:263 ../raster/r.in.bin/main.c:303
 #: ../raster/r.in.bin/main.c:311 ../raster/r.in.bin/main.c:319
@@ -8544,8 +8111,7 @@
 #: ../raster/r.in.bin/main.c:428
 msgid "Either all or none of north=, south=, east= and west= must be given"
-msgstr ""
-"O tutti o nessuno di north=, south=, east= e west= devono essere passati"
+msgstr "O tutti o nessuno di north=, south=, east= e west= devono essere passati"
 #: ../raster/r.in.bin/main.c:435 ../display/d.grid/main.c:224
 #, c-format
@@ -8574,13 +8140,8 @@
 #: ../raster/r.in.bin/main.c:466
 #, c-format
-msgid ""
-"East-West (ewres: %f) and North-South (nwres: %f) resolution differ "
-"significantly. Did you assign east= and west= correctly?"
-msgstr ""
-"Le risoluzioni Est-Ovest (ewres: %f) e Nord-Sud (nwres: %f) differiscono in "
-"modo significativo. I parametri east= and west= sono stati definiti "
-"correttamente?"
+msgid "East-West (ewres: %f) and North-South (nwres: %f) resolution differ significantly. Did you assign east= and west= correctly?"
+msgstr "Le risoluzioni Est-Ovest (ewres: %f) e Nord-Sud (nwres: %f) differiscono in modo significativo. I parametri east= and west= sono stati definiti correttamente?"
 #: ../raster/r.in.bin/main.c:489
 msgid "File Size %"
@@ -8601,9 +8162,7 @@
 msgstr "Impossibile aprire il file <%s> per scrivere l'etichetta"
 #: ../raster/r.kappa/main.c:71
-msgid ""
-"Calculate error matrix and kappa parameter for accuracy assessment of "
-"classification result."
+msgid "Calculate error matrix and kappa parameter for accuracy assessment of classification result."
 msgstr ""
 #: ../raster/r.kappa/main.c:77
@@ -8708,10 +8267,7 @@
 msgstr "Non è possibile aprire il file world per la scrittura"
 #: ../raster/r.resamp.rst/main.c:151
-msgid ""
-"Reinterpolates and optionally computes topographic analysis from input "
-"raster map to a new raster map (possibly with different resolution) using "
-"regularized spline with tension and smoothing."
+msgid "Reinterpolates and optionally computes topographic analysis from input raster map to a new raster map (possibly with different resolution) using regularized spline with tension and smoothing."
 msgstr ""
 #: ../raster/r.resamp.rst/main.c:162
@@ -8941,23 +8497,17 @@
 #: ../raster/r.compress/main.c:110
 #, c-format
 msgid "[%s] is a reclass file of map <%s> in mapset <%s> - can't uncompress"
-msgstr ""
-"[%s] è un file di riclassificazione della mappa <%s> nel mapset <%s> - non "
-"può essere decompresso"
+msgstr "[%s] è un file di riclassificazione della mappa <%s> nel mapset <%s> - non può essere decompresso"
 #: ../raster/r.compress/main.c:112
 #, c-format
 msgid "[%s] is a reclass file of map <%s> in mapset <%s> - can't compress"
-msgstr ""
-"può essere compresso"
+msgstr "[%s] è un file di riclassificazione della mappa <%s> nel mapset <%s> - non può essere compresso"
 #: ../raster/r.compress/main.c:117
 #, fuzzy, c-format
 msgid "[%s] is a GDAL-linked map - can't (un)compress"
-msgstr ""
 #: ../raster/r.compress/main.c:159
 #, c-format
@@ -9020,12 +8570,8 @@
 msgstr "Statistiche per <%s> aggiornate"
 #: ../raster/r.spreadpath/main.c:93
-msgid ""
-"Recursively traces the least cost path backwards to cells from which the "
-"cumulative cost was determined."
-msgstr ""
-"Traccia ricorsivamente il percorso di minor costo partendo dalle celle da "
-"cui il costo complessivo è stato determinato."
+msgid "Recursively traces the least cost path backwards to cells from which the cumulative cost was determined."
+msgstr "Traccia ricorsivamente il percorso di minor costo partendo dalle celle da cui il costo complessivo è stato determinato."
 #: ../raster/r.spreadpath/main.c:102
 msgid "Name of raster map containing back-path easting information"
@@ -9063,8 +8609,7 @@
 #: ../raster/r.random/random.c:109
 #, c-format
 msgid "Writing raster map <%s> and vector map <%s> ..."
-msgstr ""
-"Scrittura della mappa raster <%s> e della mappa vettoriale <%s> in corso ..."
+msgstr "Scrittura della mappa raster <%s> e della mappa vettoriale <%s> in corso ..."
 #: ../raster/r.random/random.c:112
 #, c-format
@@ -9099,11 +8644,8 @@
 msgstr ""
 #: ../raster/r.random/main.c:55
-msgid ""
-"Creates a raster map layer and vector point map containing randomly located "
-"points."
-msgstr ""
-"Crea un raster e vettore puntuale contenenti punti posizionati casualmente."
+msgid "Creates a raster map layer and vector point map containing randomly located points."
+msgstr "Crea un raster e vettore puntuale contenenti punti posizionati casualmente."
 #: ../raster/r.random/main.c:59 ../raster/r.out.bin/main.c:290
 #: ../imagery/i.zc/main.c:65
@@ -9235,12 +8777,8 @@
 msgstr ""
 #: ../raster/r.report/parse.c:47
-msgid ""
-"mi;miles;me;meters;k;kilometers;a;acres;h;hectares;c;cell counts;p;percent "
-"cover"
-msgstr ""
-"mi;miglia;me;metri;k;chilometri;a;acri;h;ettari;c;conteggio delle celle;p;"
-"percentuale di copertura"
+msgid "mi;miles;me;meters;k;kilometers;a;acres;h;hectares;c;cell counts;p;percent cover"
+msgstr "mi;miglia;me;metri;k;chilometri;a;acri;h;ettari;c;conteggio delle celle;p;percentuale di copertura"
 #: ../raster/r.report/parse.c:50 ../raster/r.report/parse.c:86
 #: ../ps/ps.map/main.c:101 ../ps/ps.map/main.c:114 ../ps/ps.map/main.c:136
@@ -9313,9 +8851,7 @@
 #: ../raster/r.report/parse.c:129 ../raster/r.stats/main.c:200
 msgid "Read fp map as integer (use map's quant rules)"
-msgstr ""
-"Legge una mappa con valori a virgola mobile come mappa con valori interi "
-"(usa le regole di r.quant della mappa)"
+msgstr "Legge una mappa con valori a virgola mobile come mappa con valori interi (usa le regole di r.quant della mappa)"
 #: ../raster/r.report/parse.c:172
 msgid "nsteps has to be > 0; using nsteps=255"
@@ -9390,14 +8926,14 @@
 msgstr "Utilizzando le coordinate del centro della mappa\n"
 #: ../raster/r.water.outlet/main.c:97
-#, fuzzy, c-format
+#, c-format
 msgid "Illegal east coordinate <%s>\n"
-msgstr "Coordinate est non valide <%s>\n"
+msgstr "Coordinata est non valida <%s>\n"
 #: ../raster/r.water.outlet/main.c:102
-#, fuzzy, c-format
+#, c-format
 msgid "Illegal north coordinate <%s>\n"
-msgstr "Coordinate nord non valide <%s>"
+msgstr "Coordinata nord non valida <%s>\n"
 #: ../raster/r.water.outlet/main.c:109
 #, c-format
@@ -9421,8 +8957,7 @@
 msgstr "Elaborazione delle linee in corso ..."
 #: ../raster/r.carve/enforce_ds.c:174
-msgid ""
-"Vect runs out of region and re-enters - this case is not yet implemented."
+msgid "Vect runs out of region and re-enters - this case is not yet implemented."
 msgstr ""
 #: ../raster/r.carve/lobf.c:74
@@ -9434,9 +8969,7 @@
 msgstr ""
 #: ../raster/r.carve/main.c:77
-msgid ""
-"Takes vector stream data, transforms it to raster and subtracts depth from "
-"the output DEM."
+msgid "Takes vector stream data, transforms it to raster and subtracts depth from the output DEM."
 msgstr ""
 #: ../raster/r.carve/main.c:82
@@ -9509,15 +9042,11 @@
 #: ../raster/r.out.tiff/main.c:176
 #, c-format
-msgid ""
-"Raster map <%s>> is a floating point map. Fractional values will be rounded "
-"to integer"
+msgid "Raster map <%s>> is a floating point map. Fractional values will be rounded to integer"
 msgstr ""
 #: ../raster/r.out.tiff/main.c:182
-msgid ""
-"Color map for palette must have less than 256 colors for the available range "
-"of data"
+msgid "Color map for palette must have less than 256 colors for the available range of data"
 msgstr ""
 #: ../raster/r.out.tiff/main.c:196
@@ -9579,9 +9108,7 @@
 #: ../raster/r.null/main.c:125
 #, c-format
-msgid ""
-"Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy "
-"with r.mapcalc. Exiting."
+msgid "Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy with r.mapcalc. Exiting."
 msgstr ""
 #: ../raster/r.null/main.c:131
@@ -9617,8 +9144,7 @@
 #: ../raster/r.null/main.c:175
 #, c-format
 msgid "Writing new null file for raster map <%s>..."
-msgstr ""
-"Scrittura del nuovo file di valori nulli per la mappa raster <%s> in corso..."
+msgstr "Scrittura del nuovo file di valori nulli per la mappa raster <%s> in corso..."
 #: ../raster/r.null/main.c:185 ../raster/r.null/main.c:198
 #, c-format
@@ -9628,8 +9154,7 @@
 #: ../raster/r.null/main.c:192
 #, c-format
 msgid "Removing null file for raster map <%s>..."
-msgstr ""
-"Rimozione in corso del file di valori nulli per la mappa raster <%s>..."
+msgstr "Rimozione in corso del file di valori nulli per la mappa raster <%s>..."
 #: ../raster/r.null/main.c:262
 #, c-format
@@ -9691,10 +9216,8 @@
 msgstr "Numero di punti per l'interpolazione"
 #: ../raster/r.surf.idw2/main.c:84
-msgid ""
-"Lat/long databases not supported by r.surf.idw2. Use r.surf.idw instead!"
-msgstr ""
-"Lat/long non sono supportati da r.surf.idw2. Utilizzare invece r.surf.idw!"
+msgid "Lat/long databases not supported by r.surf.idw2. Use r.surf.idw instead!"
+msgstr "Lat/long non sono supportati da r.surf.idw2. Utilizzare invece r.surf.idw!"
 #: ../raster/r.surf.idw2/main.c:88
 #, c-format
@@ -9720,7 +9243,6 @@
 #: ../raster/r.univar/r3.univar_main.c:42 ../vector/v.db.select/main.c:85
 #: ../db/db.select/main.c:237
 #: ../locale/scriptstrings/r.out.xyz_to_translate.c:4
-#, fuzzy
 msgid "Name for output file (if omitted or \"-\" output to stdout)"
 msgstr "Nome per il file di output (se omesso o \"-\" l'uscita è sullo stdout)"
@@ -9746,8 +9268,7 @@
 #: ../raster/r.stats/main.c:162
 msgid "Print APPROXIMATE percents (total percent may not be 100%)"
-msgstr ""
-"Visualizza le percentuali approssimative (il totale potrebbe non essere 100%)"
+msgstr "Visualizza le percentuali approssimative (il totale potrebbe non essere 100%)"
 #: ../raster/r.stats/main.c:167
 msgid "Print category labels"
@@ -9770,7 +9291,6 @@
 msgstr "Non riporta i valori NULL"
 #: ../raster/r.stats/main.c:192
-#, fuzzy
 msgid "Suppress reporting of NULLs when all values are NULL"
 msgstr "Non riporta i valori NULL quando tutti i valori sono NULL"
@@ -9789,27 +9309,17 @@
 #: ../raster/r.stats/main.c:279
 #, c-format
-msgid ""
-"Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option "
-"will be ignored."
-msgstr ""
-"Il raster <%s> sta venendo letto come mappa intera! Flag '-%c' e/o '%s' "
-"saranno ignorate"
+msgid "Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option will be ignored."
+msgstr "Il raster <%s> sta venendo letto come mappa intera! Flag '-%c' e/o '%s' saranno ignorate"
 #: ../raster/r.stats/main.c:295
 #, c-format
-msgid ""
-"Cats for raster map <%s> are either missing or have no explicit labels. "
-"Using %s=%d."
-msgstr ""
-"Categorie per il raster <%s> sono mancanti o non hanno etichette esplicite. "
-"Si sta usando %s=%d."
+msgid "Cats for raster map <%s> are either missing or have no explicit labels. Using %s=%d."
+msgstr "Categorie per il raster <%s> sono mancanti o non hanno etichette esplicite. Si sta usando %s=%d."
 #: ../raster/r.stats/main.c:301
 #, c-format
-msgid ""
-"Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s' "
-"option"
+msgid "Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s' option"
 msgstr ""
 #: ../raster/r.region/main.c:54
@@ -9914,8 +9424,7 @@
 msgstr ""
 #: ../raster/r.univar/r.univar_main.c:99
-msgid ""
-"Calculates univariate statistics from the non-null cells of a raster map."
+msgid "Calculates univariate statistics from the non-null cells of a raster map."
 msgstr "Calcola le statistiche univariate per le celle non nulle di un raster"
 #: ../raster/r.univar/r3.univar_main.c:37
@@ -9923,16 +9432,12 @@
 msgstr ""
 #: ../raster/r.univar/r3.univar_main.c:102
-msgid ""
-"Calculates univariate statistics from the non-null 3d cells of a raster3d "
-"map."
-msgstr ""
-"Calcola le statistiche univariate per le celle 3d non nulle di un raster3d"
+msgid "Calculates univariate statistics from the non-null 3d cells of a raster3d map."
+msgstr "Calcola le statistiche univariate per le celle 3d non nulle di un raster3d"
 #: ../raster/r.describe/main.c:57
 msgid "Prints terse list of category values found in a raster map layer."
-msgstr ""
-"Stampa una lista concisa dei valori delle categorie trovate nel raster."
+msgstr "Stampa una lista concisa dei valori delle categorie trovate nel raster."
 #: ../raster/r.describe/main.c:76
 msgid "Number of quantization steps"
@@ -9952,8 +9457,7 @@
 #: ../raster/r.describe/main.c:98
 msgid "Read fp map as integer"
-msgstr ""
-"Legge la mappa di valori a virgola mobile (fp) come mappa di valori interi"
+msgstr "Legge la mappa di valori a virgola mobile (fp) come mappa di valori interi"
 #: ../raster/r.describe/main.c:110
 #, c-format
@@ -10032,8 +9536,7 @@
 #: ../raster/r.out.mat/main.c:260
 msgid "Exporting raster as double FP values"
-msgstr ""
-"Esportazione del raster come valori a virgola mobile con precisione doppia"
+msgstr "Esportazione del raster come valori a virgola mobile con precisione doppia"
 #: ../raster/r.out.mat/main.c:303
 msgid "Reading in map ... "
@@ -10051,9 +9554,7 @@
 #: ../raster/r.in.lidar/main.c:165
 #, fuzzy
 msgid "Create a raster map from LAS LiDAR points using univariate statistics."
-msgstr ""
-"univariate"
 #: ../raster/r.in.lidar/main.c:169
 #, fuzzy
@@ -10062,9 +9563,8 @@
 #: ../raster/r.in.lidar/main.c:235 ../vector/v.in.ogr/main.c:249
 #: ../vector/v.in.lidar/main.c:203
-#, fuzzy
 msgid "Override dataset projection (use location's projection)"
-msgstr "Sovrascrive la proiezione (utilizza quella della locazione)"
+msgstr "Sovrascrive la proiezione del dataset (utilizza quella della locazione)"
 #: ../raster/r.in.lidar/main.c:264 ../vector/v.in.lidar/main.c:239
 #, c-format
@@ -10073,9 +9573,7 @@
 #: ../raster/r.in.lidar/main.c:282 ../vector/v.in.ogr/main.c:538
 #: ../vector/v.in.lidar/main.c:366
-msgid ""
-"Unable to convert input map projection information to GRASS format for "
-"checking"
+msgid "Unable to convert input map projection information to GRASS format for checking"
 msgstr ""
 #: ../raster/r.in.lidar/main.c:312 ../vector/v.in.ogr/main.c:568
@@ -10093,9 +9591,7 @@
 #: ../raster/r.in.lidar/main.c:375 ../vector/v.in.ogr/main.c:631
 #: ../vector/v.in.lidar/main.c:459
-msgid ""
-"Consider generating a new location with 'location' parameter from input data "
-"set.\n"
+msgid "Consider generating a new location with 'location' parameter from input data set.\n"
 msgstr ""
 #: ../raster/r.in.lidar/main.c:597
@@ -10104,23 +9600,17 @@
 msgstr "Impossibile aprire il file di output <%s>"
 #: ../raster/r.sunmask/g_solposition.c:66
-msgid ""
-"Unable to calculate sun position in un-projected locations. Specify "
-"sunposition directly."
+msgid "Unable to calculate sun position in un-projected locations. Specify sunposition directly."
 msgstr ""
 #: ../raster/r.sunmask/g_solposition.c:88
 #, c-format
-msgid ""
-"Specified point %f, %f outside of current region, is that intended? Anyway, "
-"it will be used."
+msgid "Specified point %f, %f outside of current region, is that intended? Anyway, it will be used."
 msgstr ""
 #: ../raster/r.sunmask/g_solposition.c:98
 msgid "Unable to get projection info of current location"
-msgstr ""
-"Non è possibile ottenere informazioni sulla proiezione della location "
-"corrente"
+msgstr "Non è possibile ottenere informazioni sulla proiezione della location corrente"
 #: ../raster/r.sunmask/g_solposition.c:101
 msgid "Unable to get projection units of current location"
@@ -10139,9 +9629,7 @@
 #: ../general/g.region/printwindow.c:684 ../general/g.region/printwindow.c:692
 #: ../general/g.region/printwindow.c:700
 msgid "Error in pj_do_proj (projection of input coordinate pair)"
-msgstr ""
-"Errore nell'esecuzione di 'pj do proj' (ovvero nella coppia di coordinate di "
-"proiezione in input)"
+msgstr "Errore nell'esecuzione di 'pj do proj' (ovvero nella coppia di coordinate di proiezione in input)"
 #: ../raster/r.sunmask/main.c:117 ../raster/r.horizon/main.c:178
 #, fuzzy
@@ -10149,14 +9637,11 @@
 #: ../raster/r.sunmask/main.c:118
-msgid ""
-"Calculates cast shadow areas from sun position and elevation raster map."
+msgid "Calculates cast shadow areas from sun position and elevation raster map."
 msgstr ""
 #: ../raster/r.sunmask/main.c:119
-msgid ""
-"Either exact sun position (A) is specified, or date/time to calculate the "
-"sun position (B) by r.sunmask itself."
+msgid "Either exact sun position (A) is specified, or date/time to calculate the sun position (B) by r.sunmask itself."
 msgstr ""
 #: ../raster/r.sunmask/main.c:133
@@ -10249,27 +9734,20 @@
 msgstr "Sono state specificate delle coordinate nord vuote."
 #: ../raster/r.sunmask/main.c:276
-#, fuzzy
 msgid "Either define sun position or location/date/time parameters"
-msgstr "Definisci la posizione del sole oppure i parametri di luogo/data/tempo"
+msgstr "Definire la posizione del sole oppure i parametri di luogo/data/tempo"
 #: ../raster/r.sunmask/main.c:279
-msgid ""
-"Neither sun position nor east/north, date/time/timezone definition are "
-"complete"
+msgid "Neither sun position nor east/north, date/time/timezone definition are complete"
 msgstr ""
 #: ../raster/r.sunmask/main.c:283
 #, c-format
 msgid "Calculating sun position... (using solpos (V. %s) from NREL)"
-msgstr ""
-"Calcolo della posizione del sole in corso... (utilizzando solpos(V. %s) da "
-"NREL)"
+msgstr "Calcolo della posizione del sole in corso... (utilizzando solpos(V. %s) da NREL)"
 #: ../raster/r.sunmask/main.c:288
-msgid ""
-"Using user defined sun azimuth, altitude settings (ignoring eventual other "
-"values)"
+msgid "Using user defined sun azimuth, altitude settings (ignoring eventual other values)"
 msgstr ""
 #: ../raster/r.sunmask/main.c:396
@@ -10421,9 +9899,7 @@
 msgstr ""
 #: ../raster/r.regression.line/main.c:64
-msgid ""
-"ASCII file for storing regression coefficients (output to screen if file not "
-"specified)."
+msgid "ASCII file for storing regression coefficients (output to screen if file not specified)."
 msgstr ""
 #: ../raster/r.regression.line/main.c:68 ../general/g.region/main.c:141
@@ -10459,8 +9935,7 @@
 #: ../raster/r.out.bin/main.c:297
 msgid "Name for output binary map (use output=- for stdout)"
-msgstr ""
-"Nome della mappa binaria di output (usare out=- per lo standard output)"
+msgstr "Nome della mappa binaria di output (usare out=- per lo standard output)"
 #: ../raster/r.out.bin/main.c:304
 msgid "Value to write out for null"
@@ -10468,13 +9943,11 @@
 # di/con
 #: ../raster/r.out.bin/main.c:323
-#, fuzzy
 msgid "Generate integer output"
 msgstr "Genera un output di valori interi"
 # di/con
 #: ../raster/r.out.bin/main.c:327
-#, fuzzy
 msgid "Generate floating-point output"
 msgstr "Genera un output di valori a virgola mobile"
@@ -10571,9 +10044,7 @@
 msgstr "c=%d"
 #: ../raster/r.surf.random/main.c:40
-msgid ""
-"Produces a raster map of uniform random deviates whose range can be "
-"expressed by the user."
+msgid "Produces a raster map of uniform random deviates whose range can be expressed by the user."
 msgstr ""
 #: ../raster/r.surf.random/main.c:47
@@ -10772,8 +10243,7 @@
 msgstr ""
 #: ../raster/r.li/r.li.patchnum/main.c:35
-msgid ""
-"Calculates patch number index on a raster map, using a 4 neighbour algorithm."
+msgid "Calculates patch number index on a raster map, using a 4 neighbour algorithm."
 msgstr ""
 #: ../raster/r.li/r.li.simpson/simpson.c:38
@@ -10799,9 +10269,7 @@
 msgstr "Calcola l'indice di diversità di  Pielou su una mappa raster"
 #: ../raster/r.li/r.li.mps/mps.c:39
-msgid ""
-"Calculates mean patch size index on a raster map, using a 4 neighbour "
-"algorithm"
+msgid "Calculates mean patch size index on a raster map, using a 4 neighbour algorithm"
 msgstr ""
 #: ../raster/r.li/r.li.shannon/shannon.c:37
@@ -10821,8 +10289,7 @@
 msgstr ""
 #: ../raster/r.li/r.li.edgedensity/edgedensity.c:38
-msgid ""
-"Calculates edge density index on a raster map, using a 4 neighbour algorithm"
+msgid "Calculates edge density index on a raster map, using a 4 neighbour algorithm"
 msgstr ""
 #: ../raster/r.li/r.li.padrange/padrange.c:38
@@ -10910,8 +10377,7 @@
 msgstr ""
 #: ../raster/r.li/r.li.patchdensity/main.c:34
-msgid ""
-"Calculates patch density index on a raster map, using a 4 neighbour algorithm"
+msgid "Calculates patch density index on a raster map, using a 4 neighbour algorithm"
 msgstr ""
 #: ../raster/r.out.ppm/main.c:55
@@ -10933,7 +10399,7 @@
 msgstr "righe = %d, colonne = %d"
 #: ../raster/r.out.ppm/main.c:115
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open file <%s> for write"
 msgstr "Impossibile aprire il file <%s> per la scrittura"
@@ -11006,15 +10472,11 @@
 #: ../raster/r.out.ascii/main.c:79
-#, fuzzy
 msgid "Name for output ASCII grid map (use out=- for stdout)"
-msgstr ""
-"Nome in output di una mappa ASCII grid (usare out=- per lo standard output)"
+msgstr "Nome per la mappa ASCII grid di output (usare out=- per lo standard output)"
 #: ../raster/r.out.ascii/main.c:93
-msgid ""
-"Number of values printed before wrapping a line (only SURFER or MODFLOW "
-"format)"
+msgid "Number of values printed before wrapping a line (only SURFER or MODFLOW format)"
 msgstr ""
 #: ../raster/r.out.ascii/main.c:101
@@ -11050,7 +10512,7 @@
 msgstr "Usare -M o -s, non entrambi"
 #: ../raster/r.out.ascii/main.c:176
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to read fp range for <%s>"
 msgstr "Non è possibile leggere l'intervallo fp per <%s>"
@@ -11065,12 +10527,8 @@
 msgstr "Mostra il titolo del file raster"
 #: ../raster/r.slope.aspect/main.c:154
-msgid ""
-"Generates raster maps of slope, aspect, curvatures and partial derivatives "
-"from a elevation raster map."
-msgstr ""
-"Genera mappe raster della pendenza, esposizione, curvature e le derivate "
-"parziali da una mappa raster di elevazione."
+msgid "Generates raster maps of slope, aspect, curvatures and partial derivatives from a elevation raster map."
+msgstr "Genera mappe raster della pendenza, esposizione, curvature e le derivate parziali da una mappa raster di elevazione."
 #: ../raster/r.slope.aspect/main.c:156
 msgid "Aspect is calculated counterclockwise from east."
@@ -11101,45 +10559,37 @@
 msgstr "Nome della mappa raster di output della curvatura tangenziale"
 #: ../raster/r.slope.aspect/main.c:209
-msgid ""
-"Name for output first order partial derivative dx (E-W slope) raster map"
-msgstr ""
-"Nome della mappa raster di output della derivata parziale dx (pendenza E-O)"
+msgid "Name for output first order partial derivative dx (E-W slope) raster map"
+msgstr "Nome della mappa raster di output della derivata parziale dx (pendenza E-O)"
 #: ../raster/r.slope.aspect/main.c:216
-msgid ""
-"Name for output first order partial derivative dy (N-S slope) raster map"
-msgstr ""
+msgid "Name for output first order partial derivative dy (N-S slope) raster map"
+msgstr "Nome della mappa raster di output della derivata parziale di primo ordine dy (pendenza N-S)"
 #: ../raster/r.slope.aspect/main.c:223
 msgid "Name for output second order partial derivative dxx raster map"
-msgstr ""
-"Nome della mappa raster di output della derivata parziale di secondo ordine "
-"dxx"
+msgstr "Nome della mappa raster di output della derivata parziale di secondo ordine dxx"
 #: ../raster/r.slope.aspect/main.c:230
 msgid "Name for output second order partial derivative dyy raster map"
-msgstr ""
-"dyy"
+msgstr "Nome della mappa raster di output della derivata parziale di secondo ordine dyy"
 #: ../raster/r.slope.aspect/main.c:237
 msgid "Name for output second order partial derivative dxy raster map"
-msgstr ""
-"dxy"
+msgstr "Nome della mappa raster di output della derivata parziale di secondo ordine dxy"
 #: ../raster/r.slope.aspect/main.c:243
 msgid "Multiplicative factor to convert elevation units to meters"
-msgstr ""
+msgstr "Fattore moltiplicatore per convertire le unità di elevazione in metri"
 #: ../raster/r.slope.aspect/main.c:252
 msgid "Minimum slope val. (in percent) for which aspect is computed"
-msgstr ""
+msgstr "Valore minimo di pendenza (in percentuale) a partire dal quale viene calcolata l'esposizione"
+# layer/tematismo
 #: ../raster/r.slope.aspect/main.c:261
 msgid "Do not align the current region to the elevation layer"
-msgstr ""
+msgstr "Non allinea la regione corrente al layer elevazione"
 #: ../raster/r.slope.aspect/main.c:313
 #, c-format
@@ -11153,10 +10603,8 @@
 #: ../raster/r.slope.aspect/main.c:334
 #, c-format
-msgid ""
-"You must specify at least one of the parameters: <%s>, <%s>, <%s>, <%s>, <"
-"%s>, <%s>, <%s>, <%s> or <%s>"
-msgstr ""
+msgid "You must specify at least one of the parameters: <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s> or <%s>"
+msgstr "Si deve specificare almeno uno dei parametri: <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s> o <%s>"
 #: ../raster/r.slope.aspect/main.c:358
 #, c-format
@@ -11166,7 +10614,7 @@
 #: ../raster/r.slope.aspect/main.c:388
 #, c-format
 msgid "Converting units to meters, factor=%.6f"
-msgstr ""
+msgstr "Conversione delle unità in metri, factor=%.6f"
 #: ../raster/r.slope.aspect/main.c:968
 #, c-format
@@ -11176,7 +10624,7 @@
 #: ../raster/r.slope.aspect/main.c:987
 #, c-format
 msgid "Min computed aspect %.4f, max computed aspect %.4f"
-msgstr ""
+msgstr "Esposizione min calcolata %.4f, esposizione max calcolata %.4f"
 #: ../raster/r.slope.aspect/main.c:1051
 #, c-format
@@ -11186,7 +10634,7 @@
 #: ../raster/r.slope.aspect/main.c:1108
 #, c-format
 msgid "Min computed slope %.4f, max computed slope %.4f"
-msgstr ""
+msgstr "Pendenza min calcolata %.4f, pendenza max calcolata %.4f"
 #: ../raster/r.slope.aspect/main.c:1161
 #, c-format
@@ -11305,9 +10753,7 @@
 #: ../raster/r.to.vect/main.c:87
 #, fuzzy
 msgid "Name of attribute column to store value"
-msgstr ""
-"Nome della colonna della tabella degli attributi da utilizzare per le "
-"etichette"
+msgstr "Nome della colonna della tabella degli attributi da utilizzare per le etichette"
 #: ../raster/r.to.vect/main.c:88
 msgid "Name must be SQL compliant"
@@ -11338,8 +10784,7 @@
 #: ../raster/r.to.vect/main.c:104
 #, fuzzy
 msgid "Table is not created. Currently supported only for points."
-msgstr ""
-"Le statistiche estese attualmente sono supportate solo per punti/centroidi"
+msgstr "Le statistiche estese attualmente sono supportate solo per punti/centroidi"
 #: ../raster/r.to.vect/main.c:110
 #, fuzzy
@@ -11355,9 +10800,7 @@
 msgstr "il flag z è supportato solo per i punti"
 #: ../raster/r.to.vect/main.c:131
-msgid ""
-"Raster is not CELL, '-v' flag ignored, raster values will be written to the "
-"table."
+msgid "Raster is not CELL, '-v' flag ignored, raster values will be written to the table."
 msgstr ""
 #: ../raster/r.to.vect/main.c:209 ../vector/v.random/main.c:195
@@ -11394,22 +10837,16 @@
 msgstr "Estrazione dei punti in corso ..."
 #: ../raster/r.series.interp/main.c:68
-msgid ""
-"Interpolate raster maps located (temporal or spatial) in between input "
-"raster maps at specific sampling positions."
+msgid "Interpolate raster maps located (temporal or spatial) in between input raster maps at specific sampling positions."
 msgstr ""
 #: ../raster/r.series.interp/main.c:78
 #, fuzzy
 msgid "Data point position for each input map"
-msgstr ""
-"Impossibile ottenere informazioni sulla proiezione per la mappa raster di "
-"input"
+msgstr "Impossibile ottenere informazioni sulla proiezione per la mappa raster di input"
 #: ../raster/r.series.interp/main.c:83
-msgid ""
-"Input file with an input raster map name and data point position per line, "
-"field separator between name and sample point is |"
+msgid "Input file with an input raster map name and data point position per line, field separator between name and sample point is |"
 msgstr ""
 #: ../raster/r.series.interp/main.c:95
@@ -11418,9 +10855,7 @@
 msgstr "Selezione degli elementi in corso..."
 #: ../raster/r.series.interp/main.c:99
-msgid ""
-"Input infile with an output raster map name and sample point position per "
-"line, field separator between name and sample point is |"
+msgid "Input infile with an output raster map name and sample point position per line, field separator between name and sample point is |"
 msgstr ""
 #: ../raster/r.series.interp/main.c:109
@@ -11504,9 +10939,7 @@
 #: ../raster/r.series.interp/main.c:289
 #, c-format
-msgid ""
-"map <%s> at position %g was not interpolated. Check the interpolation "
-"interval."
+msgid "map <%s> at position %g was not interpolated. Check the interpolation interval."
 msgstr ""
 #: ../raster/r.series.interp/main.c:309
@@ -11522,9 +10955,7 @@
 #: ../raster/r.out.ppm3/main.c:58
 #, fuzzy
 msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file."
-msgstr ""
-"Converte 3 raster GRASS (R,G,B) in un'immagine PPM con la risoluzione del "
-"pixel della region corrente"
+msgstr "Converte 3 raster GRASS (R,G,B) in un'immagine PPM con la risoluzione del pixel della region corrente"
 #: ../raster/r.out.ppm3/main.c:83
 msgid "Name for new PPM file. (use out=- for stdout)"
@@ -11540,8 +10971,7 @@
 #: ../raster/r.resamp.bspline/main.c:86 ../vector/v.surf.bspline/main.c:96
 msgid "Bicubic or bilinear spline interpolation with Tykhonov regularization."
-msgstr ""
-"Interpolazione spline bicubica o bilineare con regolarizzazione Tykhonov"
+msgstr "Interpolazione spline bicubica o bilineare con regolarizzazione Tykhonov"
 #: ../raster/r.resamp.bspline/main.c:94
 #, fuzzy
@@ -11558,18 +10988,14 @@
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:108
-msgid ""
-"Length of each spline step in the east-west direction. Default: 1.5 * ewres."
+msgid "Length of each spline step in the east-west direction. Default: 1.5 * ewres."
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:116
-msgid ""
-"Length of each spline step in the north-south direction. Default: 1.5 * "
-"nsres."
+msgid "Length of each spline step in the north-south direction. Default: 1.5 * nsres."
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:123 ../vector/v.surf.bspline/main.c:157
-#, fuzzy
 msgid "Spline interpolation algorithm"
 msgstr "Algoritmo di interpolazione delle spline"
@@ -11583,9 +11009,7 @@
 msgstr "Tieni i valori nulli nella mappa in output"
 #: ../raster/r.resamp.bspline/main.c:144 ../vector/v.surf.bspline/main.c:101
-msgid ""
-"Find the best Tykhonov regularizing parameter using a \"leave-one-out\" "
-"cross validation method"
+msgid "Find the best Tykhonov regularizing parameter using a \"leave-one-out\" cross validation method"
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:151
@@ -11689,20 +11113,17 @@
 msgstr ""
 #: ../raster/r.resamp.bspline/main.c:735 ../vector/v.surf.bspline/main.c:856
-#, fuzzy
 msgid "Writing output..."
 msgstr "Scrittura dell'output in corso ..."
 #: ../raster/r.resamp.bspline/crosscorr.c:160
 #, c-format
-msgid ""
-"%d are too many cells, recommended are < 100 cells. The cross validation "
-"would take too much time."
+msgid "%d are too many cells, recommended are < 100 cells. The cross validation would take too much time."
 msgstr ""
 #: ../raster/r.resamp.bspline/crosscorr.c:169
 #: ../vector/v.surf.bspline/crosscorr.c:81
-#, fuzzy, c-format
+#, c-format
 msgid "%d points read in region"
 msgstr "%d punti letti nella regione"
@@ -11713,8 +11134,7 @@
 #: ../raster/r.resamp.bspline/crosscorr.c:193
 #: ../vector/v.surf.bspline/crosscorr.c:146
 #, c-format
-msgid ""
-"Too many splines (%d x %d). Consider changing spline steps \"sie=\" \"sin=\"."
+msgid "Too many splines (%d x %d). Consider changing spline steps \"sie=\" \"sin=\"."
 msgstr ""
 #: ../raster/r.resamp.bspline/crosscorr.c:211
@@ -11737,16 +11157,13 @@
 #: ../raster/r.resamp.bspline/crosscorr.c:313
 #: ../vector/v.surf.bspline/crosscorr.c:301
-msgid ""
-"Different number of splines and lambda_i values have been taken for the "
-"cross correlation"
+msgid "Different number of splines and lambda_i values have been taken for the cross correlation"
 msgstr ""
 #: ../raster/r.resamp.bspline/crosscorr.c:315
 #: ../vector/v.surf.bspline/crosscorr.c:303
 #, c-format
-msgid ""
-"The minimum value for the test (rms=%lf) was obtained with: lambda_i = %.3f"
+msgid "The minimum value for the test (rms=%lf) was obtained with: lambda_i = %.3f"
 msgstr ""
 #: ../raster/r.resamp.bspline/crosscorr.c:323
@@ -11781,8 +11198,7 @@
 msgstr "File di input"
 #: ../raster/r.transect/main.c:106
-msgid ""
-"Outputs raster map layer values lying along user defined transect line(s)."
+msgid "Outputs raster map layer values lying along user defined transect line(s)."
 msgstr ""
 #: ../raster/r.transect/main.c:110
@@ -11900,16 +11316,12 @@
 msgstr "Errore nella lettura del file dei colori per <%s>"
 #: ../raster/r.neighbors/main.c:121
-msgid ""
-"Makes each cell category value a function of the category values assigned to "
-"the cells around it, and stores new cell values in an output raster map "
-"layer."
+msgid "Makes each cell category value a function of the category values assigned to the cells around it, and stores new cell values in an output raster map layer."
 msgstr ""
 #: ../raster/r.neighbors/main.c:131
 #, fuzzy
-msgid ""
-"Name of an input raster map to select the cells which should be processed"
+msgid "Name of an input raster map to select the cells which should be processed"
 msgstr "Mappa raster con il nome dei risultati archiviati"
 #: ../raster/r.neighbors/main.c:149 ../vector/v.neighbors/main.c:69
@@ -12091,8 +11503,7 @@
 msgstr ""
 #: ../raster/r.proj/main.c:226
-msgid ""
-"Print input map's bounds in the current projection and exit (shell style)"
+msgid "Print input map's bounds in the current projection and exit (shell style)"
 msgstr ""
 #: ../raster/r.proj/main.c:251 ../vector/v.proj/main.c:144
@@ -12111,20 +11522,15 @@
 #: ../raster/r.proj/main.c:269
 msgid "Unable to get projection info of output raster map"
-msgstr ""
-"output"
+msgstr "Impossibile ottenere informazioni sulla proiezione per la mappa raster di output"
 #: ../raster/r.proj/main.c:272
 msgid "Unable to get projection units of output raster map"
-msgstr ""
-"Impossibile ottenere le unità della proiezione per la mappa raster di output"
+msgstr "Impossibile ottenere le unità della proiezione per la mappa raster di output"
 #: ../raster/r.proj/main.c:275
 msgid "Unable to get projection key values of output raster map"
-msgstr ""
-"Impossibile ottenere i valori chiave della proiezione per la mappa raster di "
-"output"
+msgstr "Impossibile ottenere i valori chiave della proiezione per la mappa raster di output"
 #: ../raster/r.proj/main.c:284
 #, c-format
@@ -12163,20 +11569,15 @@
 #: ../raster/r.proj/main.c:316
 msgid "Unable to get projection info of input map"
-msgstr ""
-"input"
 #: ../raster/r.proj/main.c:319
 msgid "Unable to get projection units of input map"
-msgstr ""
-"Impossibile ottenere le unità della proiezione per la mappa raster di input"
+msgstr "Impossibile ottenere le unità della proiezione per la mappa raster di input"
 #: ../raster/r.proj/main.c:322
 msgid "Unable to get projection key values of input map"
-msgstr ""
-"intput"
+msgstr "Impossibile ottenere i valori chiave della proiezione per la mappa raster di intput"
 #: ../raster/r.proj/main.c:337
 msgid "Unable to work with unprojected data (xy location)"
@@ -12302,12 +11703,8 @@
 #: ../raster/r.reclass/main.c:54
 #, fuzzy
-msgid ""
-"Creates a new raster map whose category values are based upon a "
-"reclassification of the categories in an existing raster map."
-msgstr ""
-"Crea un nuovo layer dove i valori della categoria sono basati sulla "
-"riclassificazione delle categorie esistenti in un altro raster"
+msgid "Creates a new raster map whose category values are based upon a reclassification of the categories in an existing raster map."
+msgstr "Crea un nuovo layer dove i valori della categoria sono basati sulla riclassificazione delle categorie esistenti in un altro raster"
 #: ../raster/r.reclass/main.c:59
 #, fuzzy
@@ -12334,8 +11731,7 @@
 #: ../raster/r.reclass/main.c:103
 #, c-format
 msgid "Enter rule(s), \"end\" when done, \"help\" if you need it\n"
-msgstr ""
-"Inserire regola/e, \"end\" quando finito, \"help\" in caso di necessità.\n"
+msgstr "Inserire regola/e, \"end\" quando finito, \"help\" in caso di necessità.\n"
 #: ../raster/r.reclass/main.c:105
 #, fuzzy, c-format
@@ -12364,7 +11760,7 @@
 #: ../raster/r.reclass/main.c:123
 msgid " - invalid reclass rule"
-msgstr ""
+msgstr " - regola di riclassificazione non valida"
 #: ../raster/r.reclass/main.c:139
 #, c-format
@@ -12393,12 +11789,8 @@
 msgstr ""
 #: ../raster/r.coin/main.c:69
-msgid ""
-"Tabulates the mutual occurrence (coincidence) of categories for two raster "
-"map layers."
-msgstr ""
-"Riporta in forma tabellare le reciproche occorrenze (coincidenze) delle "
-"categorie di due tematismi raster."
+msgid "Tabulates the mutual occurrence (coincidence) of categories for two raster map layers."
+msgstr "Riporta in forma tabellare le reciproche occorrenze (coincidenze) delle categorie di due tematismi raster."
 #: ../raster/r.coin/main.c:77
 msgid "Name of first raster map"
@@ -12413,13 +11805,8 @@
 msgstr "Unità di misura"
 #: ../raster/r.coin/main.c:92
-msgid ""
-"c(ells), p(ercent), x(percent of category [column]), y(percent of category "
-"[row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
-msgstr ""
-"c(celle), p(percentuale), x(percentuale di categoria [colonna]), y"
-"(percentuale di categoria [riga]), a(acri), h(ettari), k(chilometri "
-"quadrati), m(miglia quadrate)"
+msgid "c(ells), p(ercent), x(percent of category [column]), y(percent of category [row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
+msgstr "c(celle), p(percentuale), x(percentuale di categoria [colonna]), y(percentuale di categoria [riga]), a(acri), h(ettari), k(chilometri quadrati), m(miglia quadrate)"
 #: ../raster/r.coin/main.c:99
 msgid "Wide report, 132 columns (default: 80)"
@@ -12453,9 +11840,7 @@
 #: ../raster/r.texture/h_measure.c:123
 #, c-format
-msgid ""
-"Too many categories (found: %i, max: %i). Try to rescale or reclassify the "
-"map"
+msgid "Too many categories (found: %i, max: %i). Try to rescale or reclassify the map"
 msgstr ""
 #: ../raster/r.texture/main.c:67
@@ -12540,14 +11925,10 @@
 #: ../raster/r.in.gdal/main.c:111
 msgid "Name of location to read projection from for GCPs transformation"
-msgstr ""
-"Nome della location da cui leggere la proiezione per la trasformazione dei "
-"GPG"
+msgstr "Nome della location da cui leggere la proiezione per la trasformazione dei GPG"
 #: ../raster/r.in.gdal/main.c:127
-msgid ""
-"The offset will be added to the band number while output raster map name "
-"creation"
+msgid "The offset will be added to the band number while output raster map name creation"
 msgstr ""
 #: ../raster/r.in.gdal/main.c:134 ../vector/v.in.ogr/main.c:198
@@ -12557,9 +11938,7 @@
 #: ../raster/r.in.gdal/main.c:157
 msgid "Force Lat/Lon maps to fit into geographic coordinates (90N,S; 180E,W)"
-msgstr ""
-"Forza le mappe Lat/Lon per ricadere nelle coordinate geografiche (90N,S; "
-"180E,W)"
+msgstr "Forza le mappe Lat/Lon per ricadere nelle coordinate geografiche (90N,S; 180E,W)"
 #: ../raster/r.in.gdal/main.c:162
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:13
@@ -12567,15 +11946,12 @@
 msgstr "Usa i numeri delle bande invece che i nomi dei colori"
 #: ../raster/r.in.gdal/main.c:167
-msgid ""
-"Create the location specified by the \"location\" parameter and exit. Do not "
-"import the raster file."
+msgid "Create the location specified by the \"location\" parameter and exit. Do not import the raster file."
 msgstr ""
 #: ../raster/r.in.gdal/main.c:192
 msgid "You have to specify a target location different from output location"
-msgstr ""
-"Bisogna specificare una location d'origine differente da quella di output"
+msgstr "Bisogna specificare una location d'origine differente da quella di output"
 #: ../raster/r.in.gdal/main.c:196
 msgid "You need to specify valid location name."
@@ -12600,37 +11976,21 @@
 msgstr "La mappa raster <%s> esiste già"
 #: ../raster/r.in.gdal/main.c:260
-msgid ""
-"The polynomial rectification used in i.rectify does not work well with NOAA/"
-"AVHRR data. Try using gdalwarp with thin plate spline rectification instead. "
-"(-tps)"
-msgstr ""
-"La rettifica polinomiale usata in i.rectify non lavora bene con dati NOAA/"
-"AVHRR. Prova usando gdalwarp con la rettifica spline piana. (-tps)"
+msgid "The polynomial rectification used in i.rectify does not work well with NOAA/AVHRR data. Try using gdalwarp with thin plate spline rectification instead. (-tps)"
+msgstr "La rettifica polinomiale usata in i.rectify non lavora bene con dati NOAA/AVHRR. Prova usando gdalwarp con la rettifica spline piana. (-tps)"
 #: ../raster/r.in.gdal/main.c:276
-msgid ""
-"Input raster map is flipped or rotated - cannot import. You may use "
-"'gdalwarp' to transform the map to North-up."
-msgstr ""
-"Il raster di input è ruotato - non può essere importato. Si può utilizzare "
-"'gdalwarp' per trasformare la mappa col Nord in alto"
+msgid "Input raster map is flipped or rotated - cannot import. You may use 'gdalwarp' to transform the map to North-up."
+msgstr "Il raster di input è ruotato - non può essere importato. Si può utilizzare 'gdalwarp' per trasformare la mappa col Nord in alto"
 #: ../raster/r.in.gdal/main.c:317
-msgid ""
-"Map bounds have been constrained to geographic coordinates. You will almost "
-"certainly want to check map bounds and resolution with r.info and reset them "
-"with r.region before going any further."
+msgid "Map bounds have been constrained to geographic coordinates. You will almost certainly want to check map bounds and resolution with r.info and reset them with r.region before going any further."
 msgstr ""
 #: ../raster/r.in.gdal/main.c:337 ../vector/v.in.ogr/main.c:517
 #: ../vector/v.in.lidar/main.c:341
-msgid ""
-"Unable to convert input map projection to GRASS format; cannot create new "
-"location."
-msgstr ""
-"Non si è in grado di convertire la proiezione della mappa di input nel "
-"formato di GRASS; impossibile creare una nuova location."
+msgid "Unable to convert input map projection to GRASS format; cannot create new location."
+msgstr "Non si è in grado di convertire la proiezione della mappa di input nel formato di GRASS; impossibile creare una nuova location."
 #: ../raster/r.in.gdal/main.c:343 ../general/g.proj/create.c:15
 #: ../vector/v.in.ogr/main.c:523 ../vector/v.in.lidar/main.c:347
@@ -12641,12 +12001,10 @@
 #: ../raster/r.in.gdal/main.c:447
 msgid ""
 "\n"
-"You can use the -o flag to r.in.gdal to override this check and use the "
-"location definition for the dataset.\n"
+"You can use the -o flag to r.in.gdal to override this check and use the location definition for the dataset.\n"
 msgstr ""
 "\n"
-"Si può usare il flag -o perché r.in.gdal tralasci questa verifica e utilizzi "
-"la definizione della location per il dataset.\n"
+"Si può usare il flag -o perché r.in.gdal tralasci questa verifica e utilizzi la definizione della location per il dataset.\n"
 #: ../raster/r.in.gdal/main.c:565
 #, c-format
@@ -12684,9 +12042,7 @@
 #: ../raster/r.in.gdal/main.c:682
 #, fuzzy
 msgid "Unable to get projection info of target location"
-msgstr ""
-"Impossibile ottenere informazioni sulla proiezione della location definita "
-"dal parametro target"
+msgstr "Impossibile ottenere informazioni sulla proiezione della location definita dal parametro target"
 #: ../raster/r.in.gdal/main.c:684
 msgid "Unable to get projection units of target location"
@@ -12706,30 +12062,19 @@
 #: ../raster/r.in.gdal/main.c:949
 #, c-format
 msgid "Setting grey color table for <%s> (8bit, full range)"
-msgstr ""
-"Impostazione della tavola dei colori per il grigio per <%s>  (8 bit, intera "
-"gamma)"
+msgstr "Impostazione della tavola dei colori per il grigio per <%s>  (8 bit, intera gamma)"
 #: ../raster/r.in.gdal/main.c:962
 #, c-format
 msgid "Setting grey color table for <%s> (16bit, image range)"
-msgstr ""
-"Impostazione della tavola dei colori per il grigio per <%s> (16 bit, gamma "
-"dell'immagine)"
+msgstr "Impostazione della tavola dei colori per il grigio per <%s> (16 bit, gamma dell'immagine)"
 #: ../raster/r.horizon/main.c:180
 msgid "Horizon angle computation from a digital elevation model."
 msgstr ""
 #: ../raster/r.horizon/main.c:182
-msgid ""
-"Computes horizon angle height from a digital elevation model. The module has "
-"two different modes of operation:  1. Computes the entire horizon around a "
-"single point whose coordinates are given with the 'coord' option. The "
-"horizon height (in radians). 2. Computes one or more raster maps of the "
-"horizon height in a single direction.  The input for this is the angle (in "
-"degrees), which is measured  counterclockwise with east=0, north=90 etc. The "
-"output is the horizon height in radians."
+msgid "Computes horizon angle height from a digital elevation model. The module has two different modes of operation:  1. Computes the entire horizon around a single point whose coordinates are given with the 'coord' option. The horizon height (in radians). 2. Computes one or more raster maps of the horizon height in a single direction.  The input for this is the angle (in degrees), which is measured  counterclockwise with east=0, north=90 etc. The output is the horizon height in radians."
 msgstr ""
 #: ../raster/r.horizon/main.c:205
@@ -12737,33 +12082,23 @@
 msgstr ""
 #: ../raster/r.horizon/main.c:221
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer around the present "
-"region"
+msgid "For horizon rasters, read from the DEM an extra buffer around the present region"
 msgstr ""
 #: ../raster/r.horizon/main.c:229
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer eastward the present "
-"region"
+msgid "For horizon rasters, read from the DEM an extra buffer eastward the present region"
 msgstr ""
 #: ../raster/r.horizon/main.c:237
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer westward the present "
-"region"
+msgid "For horizon rasters, read from the DEM an extra buffer westward the present region"
 msgstr ""
 #: ../raster/r.horizon/main.c:245
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer northward the present "
-"region"
+msgid "For horizon rasters, read from the DEM an extra buffer northward the present region"
 msgstr ""
 #: ../raster/r.horizon/main.c:253
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer southward the present "
-"region"
+msgid "For horizon rasters, read from the DEM an extra buffer southward the present region"
 msgstr ""
 #: ../raster/r.horizon/main.c:261
@@ -12833,12 +12168,8 @@
 msgstr ""
 #: ../raster/r.horizon/main.c:471
-msgid ""
-"Can't get projection info of current location: please set latitude via 'lat' "
-"or 'latin' option!"
-msgstr ""
-"corrente: impostare la latitudine attraverso l'opzione 'lat' o 'latin'!"
+msgid "Can't get projection info of current location: please set latitude via 'lat' or 'latin' option!"
+msgstr "Non è possibile ottenere informazioni sulla proiezione della location corrente: impostare la latitudine attraverso l'opzione 'lat' o 'latin'!"
 #: ../raster/r.horizon/main.c:786 ../raster/r.horizon/main.c:804
 #: ../imagery/i.latlong/main.c:134 ../ps/ps.map/do_geogrid.c:86
@@ -12871,12 +12202,8 @@
 msgstr "Nome del raster"
 #: ../raster/simwe/r.sim.sediment/main.c:117
-msgid ""
-"Sediment transport and erosion/deposition simulation using path sampling "
-"method (SIMWE)."
-msgstr ""
-"Simulazione del trasporto e dell'erosione/deposizione di sedimenti usando il "
-"metodo path sampling (SIMWE)"
+msgid "Sediment transport and erosion/deposition simulation using path sampling method (SIMWE)."
+msgstr "Simulazione del trasporto e dell'erosione/deposizione di sedimenti usando il metodo path sampling (SIMWE)"
 #: ../raster/simwe/r.sim.sediment/main.c:124
 #, fuzzy
@@ -12934,9 +12261,7 @@
 msgstr "Nome della mappa di input"
 #: ../raster/simwe/r.sim.sediment/main.c:181
-msgid ""
-"Name of the sampling points output text file. For each observation vector "
-"point the time series of sediment transport is stored."
+msgid "Name of the sampling points output text file. For each observation vector point the time series of sediment transport is stored."
 msgstr ""
 #: ../raster/simwe/r.sim.sediment/main.c:187
@@ -12981,7 +12306,7 @@
 #: ../raster/simwe/r.sim.sediment/main.c:256
 #: ../raster/simwe/r.sim.water/main.c:258
 msgid "Water diffusion constant"
-msgstr ""
+msgstr "Costante di diffusione dell'acqua"
 #: ../raster/simwe/r.sim.sediment/main.c:336
 #: ../raster/simwe/r.sim.water/main.c:432
@@ -12992,7 +12317,7 @@
 #: ../raster/simwe/r.sim.water/main.c:438
 #, c-format
 msgid "default nwalk=%d, rwalk=%f"
-msgstr ""
+msgstr "predefinito nwalk=%d, rwalk=%f"
 #: ../raster/simwe/r.sim.sediment/main.c:351
 #: ../raster/simwe/r.sim.water/main.c:448
@@ -13008,7 +12333,7 @@
 #: ../raster/simwe/r.sim.water/main.c:455 ../vector/v.surf.rst/main.c:609
 #: ../vector/v.surf.rst/main.c:664
 msgid "Input failed"
-msgstr ""
+msgstr "Input non riuscito"
 #: ../raster/simwe/r.sim.sediment/main.c:384
 #: ../raster/simwe/r.sim.water/main.c:474
@@ -13017,9 +12342,7 @@
 #: ../raster/simwe/r.sim.water/main.c:113
 msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)."
-msgstr ""
-"Simulazione del ruscellamento superficiale usando il metodo path sampling "
-"(SIMWE)"
+msgstr "Simulazione del ruscellamento superficiale usando il metodo path sampling (SIMWE)"
 #: ../raster/simwe/r.sim.water/main.c:130
 #, fuzzy
@@ -13037,9 +12360,7 @@
 #: ../raster/simwe/r.sim.water/main.c:155
 msgid "Runoff infiltration rate unique value [mm/hr]"
-msgstr ""
-"Un singolo valore  della velocità di infiltrazione del deflusso superficiale "
-"[mm/h]"
+msgstr "Un singolo valore  della velocità di infiltrazione del deflusso superficiale [mm/h]"
 #: ../raster/simwe/r.sim.water/main.c:169
 msgid "Mannings n unique value"
@@ -13051,9 +12372,7 @@
 msgstr "Nome del file raster in input"
 #: ../raster/simwe/r.sim.water/main.c:190
-msgid ""
-"point the time series of water depth is stored."
+msgid "Name of the sampling points output text file. For each observation vector point the time series of water depth is stored."
 msgstr ""
 #: ../raster/simwe/r.sim.water/main.c:196
@@ -13102,7 +12421,7 @@
 #: ../raster/simwe/simlib/hydro.c:205
 #, c-format
 msgid "nwalk (%d) > maxw (%d)!"
-msgstr ""
+msgstr "nwalk (%d) > maxw (%d)!"
 #: ../raster/simwe/simlib/hydro.c:400
 msgid "Unable to write raster maps"
@@ -13120,10 +12439,8 @@
 #: ../raster/simwe/simlib/input.c:58
 #, c-format
-msgid ""
-"Raster map <%s> not found, and manin_val undefined, choose one to be allowed "
-"to process"
-msgstr ""
+msgid "Raster map <%s> not found, and manin_val undefined, choose one to be allowed to process"
+msgstr "Mappa raster <%s> non trovata e manin_val non definito, sceglierne uno per poter procedere all'elaborazione"
 #: ../raster/simwe/simlib/input.c:171
 msgid "Zero value in Mannings n"
@@ -13139,6 +12456,8 @@
 "Min elevation \t= %.2f m\n"
 "Max elevation \t= %.2f m\n"
 msgstr ""
+"Elevazione minima \t= %.2f m\n"
+"Elevazione massima \t= %.2f m\n"
 #: ../raster/simwe/simlib/input.c:248
 #, c-format
@@ -13148,12 +12467,12 @@
 #: ../raster/simwe/simlib/input.c:250
 #, c-format
 msgid "Mean flow velocity \t= %f m/s\n"
-msgstr ""
+msgstr "Velocità media della corrente \t= %f m/s\n"
 #: ../raster/simwe/simlib/input.c:251
 #, c-format
 msgid "Mean Mannings \t= %f\n"
-msgstr ""
+msgstr "Manning medio \t= %f\n"
 #: ../raster/simwe/simlib/input.c:255
 #, c-format
@@ -13163,7 +12482,7 @@
 #: ../raster/simwe/simlib/input.c:256
 #, c-format
 msgid "Time step \t= %.2f s\n"
-msgstr ""
+msgstr "Frequenza oraria \t= %.2f s\n"
 #: ../raster/simwe/simlib/input.c:258
 #, c-format
@@ -13171,11 +12490,13 @@
 "Sigmax \t= %f\n"
 "Max velocity \t= %f m/s\n"
 msgstr ""
+"Sigmax \t= %f\n"
+"Velocità massima \t= %f m/s\n"
 #: ../raster/simwe/simlib/input.c:260
 #, c-format
 msgid "Time step used \t= %.2f s\n"
-msgstr ""
+msgstr "Frequenza oraria utilizzata \t= %.2f s\n"
 #: ../raster/simwe/simlib/input.c:312
 msgid "Unable to write et file"
@@ -13251,17 +12572,11 @@
 #: ../raster/r.thin/thin_lines.c:175
 msgid "Thinning not completed, consider to increase 'iterations' parameter."
-msgstr ""
-"Assotigliamento non completato, considera di incrementare il parametro "
-"'iterations'"
+msgstr "Assotigliamento non completato, considera di incrementare il parametro 'iterations'"
 #: ../raster/r.covar/main.c:54
-msgid ""
-"Outputs a covariance/correlation matrix for user-specified raster map layer"
-"(s)."
-msgstr ""
-"Output una matrice della covarianza/correlazione per un raster specificato "
-"dall'utente."
+msgid "Outputs a covariance/correlation matrix for user-specified raster map layer(s)."
+msgstr "Output una matrice della covarianza/correlazione per un raster specificato dall'utente."
 #: ../raster/r.covar/main.c:61
 msgid "Print correlation matrix"
@@ -13283,32 +12598,22 @@
 #: ../raster/r.out.gdal/export_band.c:171
 #, c-format
-msgid ""
-"Input raster map contains cells with NULL-value (no-data). The value %d will "
-"be used to represent no-data values in the input map. You can specify a "
-"nodata value with the %s option."
+msgid "Input raster map contains cells with NULL-value (no-data). The value %d will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
 msgstr ""
 #: ../raster/r.out.gdal/export_band.c:176
 #, c-format
-msgid ""
-"Input raster map contains cells with NULL-value (no-data). The value %g will "
+msgid "Input raster map contains cells with NULL-value (no-data). The value %g will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
 msgstr ""
 #: ../raster/r.out.gdal/export_band.c:186
 #, c-format
-msgid ""
-"The default nodata value is present in rasterband <%s> and would lead to "
-"data loss. Please specify a custom nodata value with the %s parameter."
+msgid "The default nodata value is present in rasterband <%s> and would lead to data loss. Please specify a custom nodata value with the %s parameter."
 msgstr ""
 #: ../raster/r.out.gdal/export_band.c:193
 #, c-format
-msgid ""
-"The user given nodata value %g is present in rasterband <%s> and would lead "
-"to data loss. Please specify a different nodata value with the %s parameter."
+msgid "The user given nodata value %g is present in rasterband <%s> and would lead to data loss. Please specify a different nodata value with the %s parameter."
 msgstr ""
 #: ../raster/r.out.gdal/export_band.c:235
@@ -13435,9 +12740,7 @@
 msgstr ""
 #: ../raster/r.out.gdal/main.c:202
-msgid ""
-"In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. "
-"Not supported by all output format drivers."
+msgid "In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. Not supported by all output format drivers."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:212
@@ -13461,9 +12764,7 @@
 #: ../raster/r.out.gdal/main.c:266
 #, c-format
-msgid ""
-"Driver <%s> does not support direct writing. Using MEM driver for "
-"intermediate dataset."
+msgid "Driver <%s> does not support direct writing. Using MEM driver for intermediate dataset."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:271
@@ -13491,23 +12792,17 @@
 #: ../raster/r.out.gdal/main.c:434
 #, c-format
-msgid ""
-"Precision loss: Raster map <%s> of type %s to be exported as %s. This can be "
-"avoided by using %s."
+msgid "Precision loss: Raster map <%s> of type %s to be exported as %s. This can be avoided by using %s."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:445
 #, c-format
-msgid ""
-"Precision loss: The range of <%s> can not be accurately preserved with GDAL "
-"datatype Float32. This can be avoided by exporting to Int32 or Float64."
+msgid "Precision loss: The range of <%s> can not be accurately preserved with GDAL datatype Float32. This can be avoided by exporting to Int32 or Float64."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:453
 #, c-format
-msgid ""
-"Precision loss: Float32 can not preserve the DCELL precision of raster <%s>. "
-"This can be avoided by using Float64"
+msgid "Precision loss: Float32 can not preserve the DCELL precision of raster <%s>. This can be avoided by using Float64"
 msgstr ""
 #: ../raster/r.out.gdal/main.c:462 ../raster/r.out.gdal/main.c:505
@@ -13526,8 +12821,7 @@
 #: ../raster/r.out.gdal/main.c:491
 #, c-format
 msgid "Checking options for raster map <%s> (band %d)..."
-msgstr ""
-"Controllo delle opzioni per la mappa raster <%s> (banda %d) in corso..."
+msgstr "Controllo delle opzioni per la mappa raster <%s> (banda %d) in corso..."
 #: ../raster/r.out.gdal/main.c:536
 msgid "Unable to create dataset using memory raster driver"
@@ -13577,10 +12871,7 @@
 #: ../raster/r.out.gdal/main.c:743 ../raster/r.out.gdal/main.c:756
 #: ../raster/r.out.gdal/main.c:771
 #, c-format
-msgid ""
-"Mismatch between metadata nodata value and actual nodata value in exported "
-"raster: specified nodata value %g gets converted to %d by selected GDAL "
-"datatype."
+msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %g gets converted to %d by selected GDAL datatype."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:719 ../raster/r.out.gdal/main.c:746
@@ -13596,10 +12887,7 @@
 #: ../raster/r.out.gdal/main.c:785
 #, c-format
-msgid ""
-"raster: specified nodata value %g gets converted to %g by selected GDAL "
-"datatype."
+msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %g gets converted to %g by selected GDAL datatype."
 msgstr ""
 #: ../raster/r.out.gdal/main.c:788
@@ -13660,9 +12948,7 @@
 msgstr "G_malloc: memoria esaurita"
 #: ../raster/r.lake/main.c:269
-msgid ""
-"Given water level at seed point is below earth surface. Increase water level "
-"or move seed point."
+msgid "Given water level at seed point is below earth surface. Increase water level or move seed point."
 msgstr ""
 #: ../raster/r.lake/main.c:348
@@ -13682,15 +12968,10 @@
 #: ../raster/r.lake/main.c:351
 msgid "Volume is correct only if lake depth (terrain raster map) is in meters"
-msgstr ""
-"Il volume è corretto solo se la profondità del lago (mappa raster del "
-"terreno) è in metri."
+msgstr "Il volume è corretto solo se la profondità del lago (mappa raster del terreno) è in metri."
 #: ../raster/r.surf.gauss/main.c:42
-msgid ""
-"GRASS module to produce a raster map layer of gaussian deviates whose mean "
-"and standard deviation can be expressed by the user. It uses a gaussian "
-"random number generator."
+msgid "GRASS module to produce a raster map layer of gaussian deviates whose mean and standard deviation can be expressed by the user. It uses a gaussian random number generator."
 msgstr ""
 #: ../raster/r.surf.gauss/main.c:48
@@ -13742,10 +13023,8 @@
 msgstr "Converte un file raster ASCII in un raster binario"
 #: ../raster/r.in.ascii/main.c:77
-msgid ""
-"ASCII raster file to be imported. If not given reads from standard input"
-msgstr ""
-"File raster ASCII da importare. Se non è dato legge dallo standard input"
+msgid "ASCII raster file to be imported. If not given reads from standard input"
+msgstr "File raster ASCII da importare. Se non è dato legge dallo standard input"
 #: ../raster/r.in.ascii/main.c:103
 msgid "String representing NULL value data cell"
@@ -13791,9 +13070,7 @@
 #: ../raster/r.in.ascii/gethead.c:41
 msgid "error reading the column and row dimension from the Surfer grid file"
-msgstr ""
-"errore nella lettura della dimensione della riga e della colonna dal file "
-"Surfer grid"
+msgstr "errore nella lettura della dimensione della riga e della colonna dal file Surfer grid"
 #: ../raster/r.in.ascii/gethead.c:47
 msgid "error reading the X range from the Surfer grid file"
@@ -14257,9 +13534,7 @@
 msgstr ""
 #: ../raster/r.flow/main.c:425
-msgid ""
-"Computes flowlines, flowpath lengths, and flowaccumulation (contributing "
-"areas) from a elevation raster map."
+msgid "Computes flowlines, flowpath lengths, and flowaccumulation (contributing areas) from a elevation raster map."
 msgstr ""
 #: ../raster/r.flow/main.c:434
@@ -14313,9 +13588,7 @@
 msgstr ""
 #: ../raster/r.flow/main.c:550
-msgid ""
-"lat/long projection not supported by r.flow. Please use 'r.watershed' for "
-"calculating flow accumulation."
+msgid "lat/long projection not supported by r.flow. Please use 'r.watershed' for calculating flow accumulation."
 msgstr ""
 #: ../raster/r.flow/io.c:85
@@ -14402,9 +13675,7 @@
 #: ../imagery/i.evapo.pt/main.c:69
-msgid ""
-"Computes evapotranspiration calculation Prestley and Taylor formulation, "
-"1972."
+msgid "Computes evapotranspiration calculation Prestley and Taylor formulation, 1972."
 msgstr ""
 #: ../imagery/i.evapo.pt/main.c:75
@@ -14617,9 +13888,7 @@
 msgstr ""
 #: ../imagery/i.smap/main.c:43
-msgid ""
-"Performs contextual image classification using sequential maximum a "
-"posteriori (SMAP) estimation."
+msgid "Performs contextual image classification using sequential maximum a posteriori (SMAP) estimation."
 msgstr ""
 #: ../imagery/i.smap/parse.c:20 ../imagery/i.maxlik/main.c:79
@@ -14714,8 +13983,7 @@
 msgstr ""
 #: ../imagery/i.vi/main.c:88
-msgid ""
-"Uses red and nir bands mostly, and some indices require additional bands."
+msgid "Uses red and nir bands mostly, and some indices require additional bands."
 msgstr ""
 #: ../imagery/i.vi/main.c:93
@@ -14729,16 +13997,7 @@
 #: ../imagery/i.vi/main.c:97
-msgid ""
-"arvi;Atmospherically Resistant Vegetation Indices;dvi;Difference Vegetation "
-"Index;evi;Enhanced Vegetation Index;gvi;Green Vegetation Index;gari;Green "
-"atmospherically resistant vegetation index;gemi;Global Environmental "
-"Monitoring Index;ipvi;Infrared Percentage Vegetation Index;msavi;Modified "
-"Soil Adjusted Vegetation Index;msavi2;second Modified Soil Adjusted "
-"Vegetation Index;ndvi;Normalized Difference Vegetation Index;pvi;"
-"Perpendicular Vegetation Index;savi;Soil Adjusted Vegetation Index;sr;Simple "
-"Ratio;vari;Visible Atmospherically Resistant Index;wdvi;Weighted Difference "
-"Vegetation Index;"
+msgid "arvi;Atmospherically Resistant Vegetation Indices;dvi;Difference Vegetation Index;evi;Enhanced Vegetation Index;gvi;Green Vegetation Index;gari;Green atmospherically resistant vegetation index;gemi;Global Environmental Monitoring Index;ipvi;Infrared Percentage Vegetation Index;msavi;Modified Soil Adjusted Vegetation Index;msavi2;second Modified Soil Adjusted Vegetation Index;ndvi;Normalized Difference Vegetation Index;pvi;Perpendicular Vegetation Index;savi;Soil Adjusted Vegetation Index;sr;Simple Ratio;vari;Visible Atmospherically Resistant Index;wdvi;Weighted Difference Vegetation Index;"
 msgstr ""
 #: ../imagery/i.vi/main.c:118
@@ -14790,9 +14049,7 @@
 msgstr ""
 #: ../imagery/i.vi/main.c:178
-msgid ""
-"If your data is in Digital Numbers (i.e. integer type), give the max bits (i."
-"e. 8 for Landsat -> [0-255])"
+msgid "If your data is in Digital Numbers (i.e. integer type), give the max bits (i.e. 8 for Landsat -> [0-255])"
 msgstr ""
 #: ../imagery/i.vi/main.c:205
@@ -14828,8 +14085,7 @@
 msgstr ""
 #: ../imagery/i.vi/main.c:229
-msgid ""
-"msavi2 index requires red and nir maps, and 3 parameters related to soil line"
+msgid "msavi2 index requires red and nir maps, and 3 parameters related to soil line"
 msgstr ""
 #: ../imagery/i.vi/main.c:232
@@ -14858,9 +14114,7 @@
 #: ../imagery/i.landsat.acca/main.c:70
 #, c-format
-msgid ""
-"Input raster map <%s> is not floating point (process DN using i.landsat.toar "
-"to radiance first)"
+msgid "Input raster map <%s> is not floating point (process DN using i.landsat.toar to radiance first)"
 msgstr ""
 #: ../imagery/i.landsat.acca/main.c:104
@@ -14921,8 +14175,7 @@
 msgstr ""
 #: ../imagery/i.landsat.acca/main.c:159
-msgid ""
-"Bypass second-pass processing, and merge warm (not ambiguous) and cold clouds"
+msgid "Bypass second-pass processing, and merge warm (not ambiguous) and cold clouds"
 msgstr ""
 #: ../imagery/i.landsat.acca/main.c:164
@@ -15057,9 +14310,7 @@
 msgstr "Classifica la riflettanza spettrale nei dati dell'immagine"
 #: ../imagery/i.maxlik/main.c:67
-msgid ""
-"Classification is based on the spectral signature information generated by "
-"either i.cluster, i.class, or i.gensig."
+msgid "Classification is based on the spectral signature information generated by either i.cluster, i.class, or i.gensig."
 msgstr ""
 #: ../imagery/i.maxlik/main.c:80
@@ -15081,16 +14332,12 @@
 #: ../imagery/i.maxlik/open.c:27
 #, c-format
-msgid ""
-"Subgroup <%s> of group <%s> doesn't have any raster maps. The subgroup must "
-"have at least 2 raster maps."
+msgid "Subgroup <%s> of group <%s> doesn't have any raster maps. The subgroup must have at least 2 raster maps."
 msgstr ""
 #: ../imagery/i.maxlik/open.c:30
 #, c-format
-msgid ""
-"Subgroup <%s> of group <%s> only has 1 raster map. The subgroup must have at "
-"least 2 raster maps."
+msgid "Subgroup <%s> of group <%s> only has 1 raster map. The subgroup must have at least 2 raster maps."
 msgstr ""
 #: ../imagery/i.maxlik/open.c:47
@@ -15234,9 +14481,7 @@
 msgstr ""
 #: ../imagery/i.landsat.toar/main.c:66
-msgid ""
-"Calculates top-of-atmosphere radiance or reflectance and temperature for "
-"Landsat MSS/TM/ETM+."
+msgid "Calculates top-of-atmosphere radiance or reflectance and temperature for Landsat MSS/TM/ETM+."
 msgstr ""
 #: ../imagery/i.landsat.toar/main.c:69
@@ -15274,9 +14519,7 @@
 msgstr ""
 #: ../imagery/i.landsat.toar/main.c:101
-msgid ""
-"mss1;Landsat-1 MSS;mss2;Landsat-2 MSS;mss3;Landsat-3 MSS;tm4;Landsat-4 TM;"
-"tm5;Landsat-5 TM;tm7;Landsat-7 ETM+"
+msgid "mss1;Landsat-1 MSS;mss2;Landsat-2 MSS;mss3;Landsat-3 MSS;tm4;Landsat-4 TM;tm5;Landsat-5 TM;tm7;Landsat-7 ETM+"
 msgstr ""
 #: ../imagery/i.landsat.toar/main.c:115
@@ -15448,15 +14691,11 @@
 msgstr ""
 #: ../imagery/i.class/main.c:94
-msgid ""
-"Generates spectral signatures for an image by allowing the user to outline "
-"regions of interest."
+msgid "Generates spectral signatures for an image by allowing the user to outline regions of interest."
 msgstr ""
 #: ../imagery/i.class/main.c:97
-msgid ""
-"The resulting signature file can be used as input for i.maxlik or as a seed "
-"signature file for i.cluster."
+msgid "The resulting signature file can be used as input for i.maxlik or as a seed signature file for i.cluster."
 msgstr ""
 #: ../imagery/i.class/main.c:101 ../display/d.rast/main.c:60
@@ -15678,9 +14917,7 @@
 msgstr ""
 #: ../imagery/i.aster.toar/main.c:104
-msgid ""
-"Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature "
-"from ASTER DN.\n"
+msgid "Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature from ASTER DN.\n"
 msgstr ""
 #: ../imagery/i.aster.toar/main.c:108
@@ -15807,9 +15044,7 @@
 msgstr "Il sottogruppo <%s> nel gruppo <%s> non contiene mappe raster."
 #: ../imagery/i.his.rgb/main.c:51
-msgid ""
-"Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to "
-"RGB (Red-Green-Blue) color space."
+msgid "Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to RGB (Red-Green-Blue) color space."
 msgstr ""
 #: ../imagery/i.his.rgb/main.c:57
@@ -15837,9 +15072,7 @@
 msgstr "Nome del raster di output (blu)"
 #: ../imagery/i.evapo.mh/main.c:72
-msgid ""
-"Computes evapotranspiration calculation modified or original Hargreaves "
-"formulation, 2001."
+msgid "Computes evapotranspiration calculation modified or original Hargreaves formulation, 2001."
 msgstr ""
 #: ../imagery/i.evapo.mh/main.c:78
@@ -15897,8 +15130,7 @@
 #: ../imagery/i.rectify/rectify.c:105
 #, c-format
 msgid "Raster map <%s@%s>: projection don't match current settings"
-msgstr ""
-"Raster <%s@%s>: la proiezione non corrisponde alle impostazioni correnti"
+msgstr "Raster <%s@%s>: la proiezione non corrisponde alle impostazioni correnti"
 #: ../imagery/i.rectify/rectify.c:111
 #, c-format
@@ -15910,9 +15142,7 @@
 msgstr ""
 #: ../imagery/i.rectify/main.c:97
-msgid ""
-"Rectifies an image by computing a coordinate transformation for each pixel "
-"in the image based on the control points."
+msgid "Rectifies an image by computing a coordinate transformation for each pixel in the image based on the control points."
 msgstr ""
 #: ../imagery/i.rectify/main.c:111
@@ -15932,8 +15162,7 @@
 msgstr ""
 #: ../imagery/i.rectify/main.c:148
-msgid ""
-"Use current region settings in target location (def.=calculate smallest area)"
+msgid "Use current region settings in target location (def.=calculate smallest area)"
 msgstr ""
 #: ../imagery/i.rectify/main.c:152
@@ -16123,9 +15352,7 @@
 msgstr ""
 #: ../imagery/i.vpoints/main.c:97
-msgid ""
-"Set registration points for an imagery group from a vector map or keyboard "
-"entry."
+msgid "Set registration points for an imagery group from a vector map or keyboard entry."
 msgstr ""
 #: ../imagery/i.albedo/main.c:89 ../imagery/i.eb.netrad/main.c:65
@@ -16165,9 +15392,7 @@
 msgstr ""
 #: ../imagery/i.albedo/main.c:122 ../imagery/i.albedo/main.c:129
-msgid ""
-"Albedo dry run to calculate some water to beach/sand/desert stretching, a "
-"kind of simple atmospheric correction"
+msgid "Albedo dry run to calculate some water to beach/sand/desert stretching, a kind of simple atmospheric correction"
 msgstr ""
 #: ../imagery/i.albedo/main.c:127
@@ -16286,12 +15511,7 @@
 msgstr ""
 #: ../imagery/i.modis.qc/main.c:132
-msgid ""
-"mod09Q1;surf. refl. 250m 8-days;mod09A1;surf. refl. 500m 8-days;mod09A1s;"
-"surf. refl. 500m 8-days, State QA;mod11A1;LST 1Km daily (Day/Night);mod11A2;"
-"LST 1Km 8-days (Day/Night);mod13A2;VI 1Km 16-days;mcd43B2;Brdf-Albedo "
-"Quality (Ancillary SDS) 1Km 8-days;mcd43B2q;Brdf-Albedo Quality (BRDF SDS) "
-"1Km 8-days;"
+msgid "mod09Q1;surf. refl. 250m 8-days;mod09A1;surf. refl. 500m 8-days;mod09A1s;surf. refl. 500m 8-days, State QA;mod11A1;LST 1Km daily (Day/Night);mod11A2;LST 1Km 8-days (Day/Night);mod13A2;VI 1Km 16-days;mcd43B2;Brdf-Albedo Quality (Ancillary SDS) 1Km 8-days;mcd43B2q;Brdf-Albedo Quality (BRDF SDS) 1Km 8-days;"
 msgstr ""
 #: ../imagery/i.modis.qc/main.c:147
@@ -16300,37 +15520,7 @@
 msgstr "Nome di una mappa raster esistente"
 #: ../imagery/i.modis.qc/main.c:148
-msgid ""
-"adjcorr;mod09: Adjacency Correction;atcorr;mod09: Atmospheric Correction;"
-"cloud;mod09: Cloud State;data_quality;mod09: Band-Wise Data Quality Flag;"
-"diff_orbit_from_500m;mod09: 250m Band is at Different Orbit than 500m;"
-"modland_qa;mod09: MODIS Land General Quality Assessment;mandatory_qa_11A1;"
-"mod11A1: MODIS Land General Quality Assessment;data_quality_flag_11A1;"
-"mod11A1: Detailed Quality Indications;emis_error_11A1;mod11A1: Average "
-"Emissivity Error Classes;lst_error_11A1;mod11A1: Average LST Error Classes;"
-"data_quality_flag_11A2;mod11A2: Detailed Quality Indications;emis_error_11A2;"
-"mod11A2: Average Emissivity Error Classes;mandatory_qa_11A2;mod11A2: MODIS "
-"Land General Quality Assessment;lst_error_11A2;mod11A2: Average LST Error "
-"Classes;aerosol_quantity;mod09A1s: StateQA Internal Snow "
-"Maskbrdf_correction_performed;mod09A1s: StateQA Internal Snow "
-"Maskcirrus_detected;mod09A1s: StateQA Internal Snow Maskcloud_shadow;"
-"mod09A1s: StateQA Internal Snow Maskcloud_state;mod09A1s: StateQA Internal "
-"Snow Maskinternal_cloud_algorithm;mod09A1s: StateQA Internal Snow "
-"Maskinternal_fire_algorithm;mod09A1s: StateQA Internal Snow "
-"Maskinternal_snow_mask;mod09A1s: StateQA Internal Snow Maskland_water;"
-"mod09A1s: StateQA Internal Snow Maskmod35_snow_ice;mod09A1s: StateQA "
-"Internal Snow Maskpixel_adjacent_to_cloud;mod09A1s: StateQA Internal Snow "
-"Maskmodland_qa;mod13A2: MODIS Land General Quality Assessmentvi_usefulness;"
-"mod13A2: Quality estimation of the pixelaerosol_quantity;mod13A2: Quantity "
-"range of Aerosolpixel_adjacent_to_cloud;mod13A2: if pixel is a cloud "
-"neighbourbrdf_correction_performed;mod13A2: if BRDF correction "
-"performedmixed_clouds;mod13A2: if pixel mixed with cloudsland_water;mod13A2: "
-"separate land from various water objectspossible_snow_ice;mod13A2: if snow/"
-"ice present in pixelpossible_shadow;mod13A2: if shadow is present in "
-"pixelplatform;mcd43B2: Quality of BRDF correction performedland_water;"
-"mcd43B2: Quality of BRDF correction performedsun_z_angle_at_local_noon;"
-"mcd43B2: Quality of BRDF correction performedbrdf_correction_performed;"
-"mcd43B2q: Quality of BRDF correction performed"
+msgid "adjcorr;mod09: Adjacency Correction;atcorr;mod09: Atmospheric Correction;cloud;mod09: Cloud State;data_quality;mod09: Band-Wise Data Quality Flag;diff_orbit_from_500m;mod09: 250m Band is at Different Orbit than 500m;modland_qa;mod09: MODIS Land General Quality Assessment;mandatory_qa_11A1;mod11A1: MODIS Land General Quality Assessment;data_quality_flag_11A1;mod11A1: Detailed Quality Indications;emis_error_11A1;mod11A1: Average Emissivity Error Classes;lst_error_11A1;mod11A1: Average LST Error Classes;data_quality_flag_11A2;mod11A2: Detailed Quality Indications;emis_error_11A2;mod11A2: Average Emissivity Error Classes;mandatory_qa_11A2;mod11A2: MODIS Land General Quality Assessment;lst_error_11A2;mod11A2: Average LST Error Classes;aerosol_quantity;mod09A1s: StateQA Internal Snow Maskbrdf_correction_performed;mod09A1s: StateQA Internal Snow Maskcirrus_detected;mod09A1s: StateQA Internal Snow Maskcloud_shadow;mod09A1s: StateQA Internal Snow Maskcloud_state;mod09A1s: Stat
 eQA Internal Snow Maskinternal_cloud_algorithm;mod09A1s: StateQA Internal Snow Maskinternal_fire_algorithm;mod09A1s: StateQA Internal Snow Maskinternal_snow_mask;mod09A1s: StateQA Internal Snow Maskland_water;mod09A1s: StateQA Internal Snow Maskmod35_snow_ice;mod09A1s: StateQA Internal Snow Maskpixel_adjacent_to_cloud;mod09A1s: StateQA Internal Snow Maskmodland_qa;mod13A2: MODIS Land General Quality Assessmentvi_usefulness;mod13A2: Quality estimation of the pixelaerosol_quantity;mod13A2: Quantity range of Aerosolpixel_adjacent_to_cloud;mod13A2: if pixel is a cloud neighbourbrdf_correction_performed;mod13A2: if BRDF correction performedmixed_clouds;mod13A2: if pixel mixed with cloudsland_water;mod13A2: separate land from various water objectspossible_snow_ice;mod13A2: if snow/ice present in pixelpossible_shadow;mod13A2: if shadow is present in pixelplatform;mcd43B2: Quality of BRDF correction performedland_water;mcd43B2: Quality of BRDF correction performedsun_z_angle_at_loca
 l_noon;mcd43B2: Quality of BRDF correction performedbrdf_correction_performed;mcd43B2q: Quality of BRDF correction performed"
 msgstr ""
 #: ../imagery/i.modis.qc/main.c:191
@@ -16339,14 +15529,11 @@
 msgstr "Nome di un nuovo file raster"
 #: ../imagery/i.modis.qc/main.c:199
-msgid ""
-"Band number of Modis product mod09Q1=[1,2],mod09A1=[1-7], mcd43B2q=[1-7]"
+msgid "Band number of Modis product mod09Q1=[1,2],mod09A1=[1-7], mcd43B2q=[1-7]"
 msgstr ""
 #: ../imagery/i.modis.qc/main.c:200
-msgid ""
-"1;Band 1: Red;2;Band 2: NIR;3;Band 3: Blue;4;Band 4: Green;5;Band 5: SWIR "
-"1;6;Band 6: SWIR 2;7;Band 7: SWIR 3;"
+msgid "1;Band 1: Red;2;Band 2: NIR;3;Band 3: Blue;4;Band 4: Green;5;Band 5: SWIR 1;6;Band 6: SWIR 2;7;Band 7: SWIR 3;"
 msgstr ""
 #: ../imagery/i.modis.qc/main.c:211
@@ -16636,7 +15823,7 @@
 #: ../imagery/i.cluster/print2.c:28
 #, c-format
 msgid "  stddev"
-msgstr ""
+msgstr "deviazione standard"
 #: ../imagery/i.cluster/open_files.c:34
 #, c-format
@@ -16672,15 +15859,11 @@
 msgstr "Sto scrivendo gli attributi"
 #: ../imagery/i.cluster/main.c:79
-msgid ""
-"Generates spectral signatures for land cover types in an image using a "
-"clustering algorithm."
+msgid "Generates spectral signatures for land cover types in an image using a clustering algorithm."
 msgstr ""
 #: ../imagery/i.cluster/main.c:82
-msgid ""
-"The resulting signature file is used as input for i.maxlik, to generate an "
-"unsupervised image classification."
+msgid "The resulting signature file is used as input for i.maxlik, to generate an unsupervised image classification."
 msgstr ""
 #: ../imagery/i.cluster/main.c:101
@@ -16850,7 +16033,7 @@
 #: ../imagery/i.cluster/main.c:264
 #, c-format
 msgid " Maximum number of iterations: %d\n"
-msgstr ""
+msgstr " Numero massimo di iterazioni: %d\n"
 #: ../imagery/i.cluster/main.c:266
 #, c-format
@@ -16872,13 +16055,11 @@
 msgstr ""
 #: ../imagery/i.cluster/main.c:295
-msgid ""
-"Not enough sample points. Please run again and choose a larger sample size."
+msgid "Not enough sample points. Please run again and choose a larger sample size."
 msgstr ""
 #: ../imagery/i.cluster/main.c:299
-msgid ""
-"Not enough non-zero sample data points. Check your current region (and mask)."
+msgid "Not enough non-zero sample data points. Check your current region (and mask)."
 msgstr ""
 #: ../imagery/i.cluster/main.c:312
@@ -17032,9 +16213,7 @@
 msgstr ""
 #: ../imagery/i.eb.netrad/main.c:89
-msgid ""
-"Name of the difference of temperature from surface skin to about 2 m height "
-"[K]"
+msgid "Name of the difference of temperature from surface skin to about 2 m height [K]"
 msgstr ""
 #: ../imagery/i.eb.netrad/main.c:90
@@ -17096,9 +16275,7 @@
 msgstr "Impossibile aprire il file temp"
 #: ../imagery/i.eb.evapfr/main.c:53
-msgid ""
-"Computes evaporative fraction (Bastiaanssen, 1995) and root zone soil "
-"moisture (Makin, Molden and Bastiaanssen, 2001)."
+msgid "Computes evaporative fraction (Bastiaanssen, 1995) and root zone soil moisture (Makin, Molden and Bastiaanssen, 2001)."
 msgstr ""
 #: ../imagery/i.eb.evapfr/main.c:59 ../imagery/i.eb.soilheatflux/main.c:71
@@ -17131,9 +16308,7 @@
 msgstr ""
 #: ../imagery/i.evapo.time/main.c:79
-msgid ""
-"Computes temporal integration of satellite ET actual (ETa) following the "
-"daily ET reference (ETo) from meteorological station(s)."
+msgid "Computes temporal integration of satellite ET actual (ETa) following the daily ET reference (ETo) from meteorological station(s)."
 msgstr ""
 #: ../imagery/i.evapo.time/main.c:86
@@ -17264,9 +16439,7 @@
 msgstr "Sto creando centroidi...."
 #: ../imagery/i.rgb.his/main.c:51
-msgid ""
-"Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-"
-"Intensity-Saturation) color space."
+msgid "Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-Intensity-Saturation) color space."
 msgstr ""
 #: ../imagery/i.rgb.his/main.c:57
@@ -17294,9 +16467,7 @@
 msgstr "Nome del raster di output (saturazione)"
 #: ../imagery/i.evapo.pm/main.c:61
-msgid ""
-"Computes potential evapotranspiration calculation with hourly Penman-"
-"Monteith."
+msgid "Computes potential evapotranspiration calculation with hourly Penman-Monteith."
 msgstr ""
 #: ../imagery/i.evapo.pm/main.c:65
@@ -17377,9 +16548,8 @@
 #: ../ps/ps.map/r_info.c:48 ../ps/ps.map/r_colortable.c:62
 #: ../ps/ps.map/r_vlegend.c:49
-#, fuzzy
 msgid "illegal where request"
-msgstr "Regola di riclassificazione non valida -"
+msgstr "Interrogazione where non valida"
 #: ../ps/ps.map/r_info.c:67 ../ps/ps.map/ps_outline.c:87
 #: ../ps/ps.map/getgrid.c:61 ../ps/ps.map/getgrid.c:85
@@ -17434,7 +16604,7 @@
 msgstr "Nessun record per la categoria [%d]"
 #: ../ps/ps.map/ps_vpoints.c:182
-#, fuzzy, c-format
+#, c-format
 msgid "Attribute is of invalid size [%.3f] for category [%d]"
 msgstr "L'attributo della categoria [%d] ha una dimensione errata [%.3f]"
@@ -17587,9 +16757,7 @@
 #: ../ps/ps.map/r_vpoints.c:244
 #, c-format
-msgid ""
-"The mapping instruction <%s> will be renamed to <%s> in future versions of "
-"GRASS. Please use <%s> instead."
+msgid "The mapping instruction <%s> will be renamed to <%s> in future versions of GRASS. Please use <%s> instead."
 msgstr ""
 #: ../ps/ps.map/ps_outline.c:43
@@ -17642,9 +16810,8 @@
 msgstr ""
 #: ../ps/ps.map/r_colortable.c:170
-#, fuzzy
 msgid "No raster selected for colortable!"
-msgstr "Nessun record selezionato dalla tabella <%s>"
+msgstr "Nessun raster selezionato per la tavola dei colori!"
 #: ../ps/ps.map/do_scalebar.c:194
 #, fuzzy
@@ -17682,8 +16849,7 @@
 #: ../ps/ps.map/ps_fclrtbl.c:64
 msgid "A floating point colortable must contain a range of values"
-msgstr ""
-"Una tabella colori a virgola mobile deve contenere un intervallo di valori"
+msgstr "Una tabella colori a virgola mobile deve contenere un intervallo di valori"
 #: ../ps/ps.map/ps_fclrtbl.c:69 ../ps/ps.map/ps_clrtbl.c:44
 msgid "Unable to read colors for colorbar"
@@ -17692,16 +16858,12 @@
 #: ../ps/ps.map/ps_fclrtbl.c:92 ../ps/ps.map/ps_fclrtbl.c:97
 #: ../ps/ps.map/ps_clrtbl.c:69
 msgid "Colorbar y location beyond page margins. Adjusting."
-msgstr ""
-"Posizione y della barra colori esterna ai margini della pagina. Li "
-"aggiusto...."
+msgstr "Posizione y della barra colori esterna ai margini della pagina. Li aggiusto...."
 #: ../ps/ps.map/ps_fclrtbl.c:103 ../ps/ps.map/ps_fclrtbl.c:108
 #: ../ps/ps.map/ps_clrtbl.c:75
 msgid "Colorbar x location beyond page margins. Adjusting."
-msgstr ""
-"Posizione x della barra colori esterna ai margini della pagina. Li "
-"aggiusto...."
+msgstr "Posizione x della barra colori esterna ai margini della pagina. Li aggiusto...."
 #: ../ps/ps.map/getgrid.c:95 ../ps/ps.map/getgrid.c:206
 #, fuzzy
@@ -17724,7 +16886,6 @@
 #: ../ps/ps.map/r_plt.c:174
-#, fuzzy
 msgid "Can't open eps file"
 msgstr "Impossibile aprire il file eps"
@@ -17796,9 +16957,7 @@
 #: ../ps/ps.map/main.c:106
 #, fuzzy
 msgid "List paper formats (name width height left right top bottom(margin))"
-msgstr ""
-"Elenco dei formati di pagina per la stampa (nome largh. altezza sinistra "
-"destra alto basso[margine])"
+msgstr "Elenco dei formati di pagina per la stampa (nome largh. altezza sinistra destra alto basso[margine])"
 #: ../ps/ps.map/main.c:108 ../ps/ps.map/main.c:121
 #, fuzzy
@@ -17810,9 +16969,7 @@
 msgstr "Crea file EPS (Encapsulated PostScript) invece di PostScript"
 #: ../ps/ps.map/main.c:119
-msgid ""
-"Describe map-box's position on the page and exit (inches from top-left of "
-"paper)"
+msgid "Describe map-box's position on the page and exit (inches from top-left of paper)"
 msgstr ""
 #: ../ps/ps.map/main.c:124
@@ -17871,9 +17028,9 @@
 msgstr ""
 #: ../ps/ps.map/eps.c:18
-#, fuzzy, c-format
+#, c-format
 msgid "Can't open eps file <%s>"
-msgstr "Impossibile aprire il file delle regole <%s>"
+msgstr "Impossibile aprire il file eps <%s>"
 #: ../ps/ps.map/eps.c:37
 #, fuzzy, c-format
@@ -17887,10 +17044,7 @@
 msgstr "File delle categorie per <%s> non disponibile"
 #: ../ps/ps.map/ps_clrtbl.c:54
-msgid ""
-"Your cats/ file is invalid. A cats/ file with categories and labels is "
-"required for 'colortable' when using categorical legends; see the r.category "
-"help page. Colortable creation has been skipped."
+msgid "Your cats/ file is invalid. A cats/ file with categories and labels is required for 'colortable' when using categorical legends; see the r.category help page. Colortable creation has been skipped."
 msgstr ""
 #: ../ps/ps.map/do_plt.c:40
@@ -17903,9 +17057,7 @@
 msgstr "Importando punti ..."
 #: ../display/d.histogram/main.c:88
-msgid ""
-"Displays a histogram in the form of a pie or bar chart for a user-specified "
-"raster map."
+msgid "Displays a histogram in the form of a pie or bar chart for a user-specified raster map."
 msgstr ""
 #: ../display/d.histogram/main.c:92
@@ -17996,9 +17148,7 @@
 #: ../display/d.vect/lines.c:121
 #, fuzzy
-msgid ""
-"Unable to display features by id, topology not available. Please try to "
-"rebuild topology using v.build or v.build.all."
+msgid "Unable to display features by id, topology not available. Please try to rebuild topology using v.build or v.build.all."
 msgstr "Non è possibile mostrare le linee per id, topologia non disponibile"
 #: ../display/d.vect/lines.c:169
@@ -18042,9 +17192,7 @@
 msgstr ""
 #: ../display/d.vect/topo.c:17
-msgid ""
-"Unable to display topology, not available.Please try to rebuild topology "
-"using v.build or v.build.all."
+msgid "Unable to display topology, not available.Please try to rebuild topology using v.build or v.build.all."
 msgstr ""
 #: ../display/d.vect/main.c:72
@@ -18056,11 +17204,7 @@
 msgstr "Visualizza"
 #: ../display/d.vect/main.c:87
-msgid ""
-"shape;Display geometry of features;cat;Display category numbers of features;"
-"topo;Display topology information (nodes, edges);dir;Display direction of "
-"linear features;attr;Display selected attribute based on 'attrcolumn';zcoor;"
-"Display z-coordinate of features (only for 3D vector maps)"
+msgid "shape;Display geometry of features;cat;Display category numbers of features;topo;Display topology information (nodes, edges);dir;Display direction of linear features;attr;Display selected attribute based on 'attrcolumn';zcoor;Display z-coordinate of features (only for 3D vector maps)"
 msgstr ""
 #: ../display/d.vect/main.c:98 ../display/d.vect/main.c:101
@@ -18183,8 +17327,7 @@
 #: ../display/d.vect/main.c:192
 msgid "Name of numeric column containing symbol rotation angle"
-msgstr ""
-"Nome della colonna numerica contenente l'angolo di rotazione del simbolo"
+msgstr "Nome della colonna numerica contenente l'angolo di rotazione del simbolo"
 #: ../display/d.vect/main.c:194
 msgid "Measured in degrees CCW from east"
@@ -18245,13 +17388,11 @@
 msgstr ""
 #: ../display/d.vect/main.c:279
-msgid ""
-"Minimum region size (average from height and width) when map is displayed"
+msgid "Minimum region size (average from height and width) when map is displayed"
 msgstr ""
 #: ../display/d.vect/main.c:287
-msgid ""
-"Maximum region size (average from height and width) when map is displayed"
+msgid "Maximum region size (average from height and width) when map is displayed"
 msgstr ""
 #: ../display/d.vect/main.c:295
@@ -18259,9 +17400,7 @@
 msgstr ""
 #: ../display/d.vect/main.c:301
-msgid ""
-"Random colors according to category number (or layer number if 'layer=-1' is "
-"given)"
+msgid "Random colors according to category number (or layer number if 'layer=-1' is given)"
 msgstr ""
 #: ../display/d.vect/main.c:308
@@ -18277,29 +17416,21 @@
 msgstr ""
 #: ../display/d.vect/main.c:319
-msgid ""
-"This makes circle areas proportionate to the size_column values instead of "
-"circle radius"
+msgid "This makes circle areas proportionate to the size_column values instead of circle radius"
 msgstr ""
 #: ../display/d.vect/main.c:339
 #, fuzzy
 msgid "Region size is lower than minreg, nothing displayed"
-msgstr ""
-"La dimensione della regione è inferiore rispetto al valore di minreg, non "
-"verrà visualizzato nulla."
+msgstr "La dimensione della regione è inferiore rispetto al valore di minreg, non verrà visualizzato nulla."
 #: ../display/d.vect/main.c:347
 #, fuzzy
 msgid "Region size is greater than maxreg, nothing displayed"
-msgstr ""
-"La dimensione della regione è superiore rispetto al valore di maxreg, non "
+msgstr "La dimensione della regione è superiore rispetto al valore di maxreg, non verrà visualizzato nulla."
 #: ../display/d.vect/main.c:361
-msgid ""
-"The '-c' and '-a' flags cannot be used together, the '-c' flag will be "
-"ignored!"
+msgid "The '-c' and '-a' flags cannot be used together, the '-c' flag will be ignored!"
 msgstr ""
 #: ../display/d.vect/main.c:383 ../display/d.vect/main.c:389
@@ -18311,7 +17442,7 @@
 #: ../display/d.vect/main.c:393 ../vector/v.out.ascii/args.c:141
 #, c-format
 msgid "%d errors in cat option"
-msgstr ""
+msgstr "%d errori nell'opzione cat"
 #: ../display/d.vect/main.c:409
 #, fuzzy
@@ -18320,11 +17451,8 @@
 #: ../display/d.vect/main.c:417
 #, fuzzy
-msgid ""
-"The bounding box of the map is outside the current region, nothing drawn"
-msgstr ""
-"Il box di confine della mappa è al di fuori della regione in uso, non verrà "
-"visualizzato nulla."
+msgid "The bounding box of the map is outside the current region, nothing drawn"
+msgstr "Il box di confine della mappa è al di fuori della regione in uso, non verrà visualizzato nulla."
 #: ../display/d.vect/main.c:480
 #, fuzzy
@@ -18333,9 +17461,7 @@
 #: ../display/d.vect/area.c:37
 #, fuzzy
-msgid ""
-"Unable to display areas, topology not available. Please try to rebuild "
-"topology using v.build or v.build.all."
+msgid "Unable to display areas, topology not available. Please try to rebuild topology using v.build or v.build.all."
 msgstr "Non è possibile mostrare le aree, topologia non disponibile"
 #: ../display/d.vect/label.c:28
@@ -18354,9 +17480,7 @@
 #: ../display/d.vect/shape.c:58 ../display/d.thematic.area/plot1.c:129
 #, c-format
-msgid ""
-"Color definition column (%s) not a string. Column must be of form RRR:GGG:"
-"BBB where RGB values range 0-255."
+msgid "Color definition column (%s) not a string. Column must be of form RRR:GGG:BBB where RGB values range 0-255."
 msgstr ""
 #: ../display/d.vect/shape.c:63 ../display/d.vect/shape.c:92
@@ -18396,8 +17520,7 @@
 msgstr "La colonna della rotazione dei simboli (%s) non è numerica."
 #: ../display/d.vect/shape.c:173
-msgid ""
-"Vector map is not 3D. Unable to colorize features based on z-coordinates."
+msgid "Vector map is not 3D. Unable to colorize features based on z-coordinates."
 msgstr ""
 #: ../display/d.vect/shape.c:244 ../display/d.vect/shape.c:249
@@ -18448,9 +17571,7 @@
 msgstr "%s - longitudine non valida"
 #: ../display/d.where/main.c:47
-msgid ""
-"Identifies the geographic coordinates associated with point locations given "
-"in display coordinates."
+msgid "Identifies the geographic coordinates associated with point locations given in display coordinates."
 msgstr ""
 #: ../display/d.where/main.c:57
@@ -18461,9 +17582,7 @@
 #: ../display/d.where/main.c:62
 #, fuzzy
 msgid "File from which to read coordinates (\"-\" to read from stdin)"
-msgstr ""
-"File ASCII contenente la singola linea descrivente la proiezione WKT (- per "
-"stdin)"
+msgstr "File ASCII contenente la singola linea descrivente la proiezione WKT (- per stdin)"
 #: ../display/d.where/main.c:66
 msgid "Output lat/long in decimal degree"
@@ -18474,9 +17593,7 @@
 msgstr ""
 #: ../display/d.where/main.c:76
-msgid ""
-"Output lat/long referenced to WGS84 ellipsoid using datum transformation "
-"parameters defined in current location (if available)"
+msgid "Output lat/long referenced to WGS84 ellipsoid using datum transformation parameters defined in current location (if available)"
 msgstr ""
 #: ../display/d.where/main.c:82
@@ -18638,9 +17755,7 @@
 msgstr "attenzione: %s - file vettoriale non trovato\n"
 #: ../display/d.what.vect/main.c:61
-msgid ""
-"Allows the user to interactively query a vector map layer at user-selected "
-"locations within the current geographic region."
+msgid "Allows the user to interactively query a vector map layer at user-selected locations within the current geographic region."
 msgstr ""
 #: ../display/d.what.vect/main.c:68 ../display/d.what.rast/main.c:79
@@ -18685,9 +17800,7 @@
 msgstr ""
 #: ../display/d.text/main.c:142
-msgid ""
-"Draws text in the active display frame on the graphics monitor using the "
-"current font."
+msgid "Draws text in the active display frame on the graphics monitor using the current font."
 msgstr ""
 #: ../display/d.text/main.c:148
@@ -18703,20 +17816,15 @@
 msgstr ""
 #: ../display/d.text/main.c:173
-#, fuzzy
 msgid "Text background color, either a standard GRASS color or R:G:B triplet"
-msgstr ""
-"Colore per lo sfondo del testo, o un colore GRASS standard o una tripletta R:"
-"G:B"
+msgstr "Colore per lo sfondo del testo, o un colore GRASS standard o una tripletta R:G:B"
 #: ../display/d.text/main.c:182
 msgid "The screen line number on which text will begin to be drawn"
 msgstr ""
 #: ../display/d.text/main.c:190
-msgid ""
-"Screen position at which text will begin to be drawn (percentage, [0,0] is "
-"lower left)"
+msgid "Screen position at which text will begin to be drawn (percentage, [0,0] is lower left)"
 msgstr ""
 #: ../display/d.text/main.c:198
@@ -18788,9 +17896,7 @@
 msgstr ""
 #: ../display/d.linegraph/main.c:122
-msgid ""
-"Generates and displays simple line graphs in the active graphics monitor "
-"display frame."
+msgid "Generates and displays simple line graphs in the active graphics monitor display frame."
 msgstr ""
 #: ../display/d.linegraph/main.c:126
@@ -18886,10 +17992,7 @@
 msgstr "Stai cliccando fuori la mappa"
 #: ../display/d.what.rast/main.c:53
-msgid ""
-"Allows the user to interactively query the category contents of multiple "
-"raster map layers at user specified locations within the current geographic "
-"region."
+msgid "Allows the user to interactively query the category contents of multiple raster map layers at user specified locations within the current geographic region."
 msgstr ""
 #: ../display/d.what.rast/main.c:74
@@ -18910,9 +18013,7 @@
 #: ../display/d.info/main.c:34
 #, fuzzy
 msgid "Displays information about the active display monitor."
-msgstr ""
-"Seleziona il tipo di carattere con cui il testo deve essere rappresentato "
-"nel monitor grafico dell'utente."
+msgstr "Seleziona il tipo di carattere con cui il testo deve essere rappresentato nel monitor grafico dell'utente."
 #: ../display/d.info/main.c:36
 msgid "Display monitors are maintained by d.mon."
@@ -18944,8 +18045,7 @@
 msgstr "Nessun nome di mappa assegnato"
 #: ../display/d.vect.chart/main.c:66
-msgid ""
-"Displays charts of vector data in the active frame on the graphics monitor."
+msgid "Displays charts of vector data in the active frame on the graphics monitor."
 msgstr ""
 #: ../display/d.vect.chart/main.c:83
@@ -19020,9 +18120,7 @@
 msgstr "Disegna solo la barra della scala"
 #: ../display/d.barscale/main.c:92
-msgid ""
-"The screen coordinates for top-left corner of label ([0,0] is lower-left of "
-"frame)"
+msgid "The screen coordinates for top-left corner of label ([0,0] is lower-left of frame)"
 msgstr ""
 #: ../display/d.barscale/main.c:100
@@ -19050,9 +18148,7 @@
 msgstr ""
 #: ../display/d.erase/main.c:34
-msgid ""
-"Erases the contents of the active graphics display frame with user defined "
-"color."
+msgid "Erases the contents of the active graphics display frame with user defined color."
 msgstr ""
 #: ../display/d.erase/main.c:40
@@ -19064,9 +18160,7 @@
 msgstr ""
 #: ../display/d.zoom/main.c:64
-msgid ""
-"Allows the user to change the current geographic region settings "
-"interactively, with a mouse."
+msgid "Allows the user to change the current geographic region settings interactively, with a mouse."
 msgstr ""
 #: ../display/d.zoom/main.c:76 ../display/d.legend/main.c:91
@@ -19156,9 +18250,7 @@
 #: ../display/d.zoom/zoom.c:41
 #, c-format
 msgid "Note: run 'd.erase' for the new region to affect the graphics.\n"
-msgstr ""
-"Nota: esegue 'd.erase. affinché la nuova regione abbia effetto sul monitor "
-"grafico\n"
+msgstr "Nota: esegue 'd.erase. affinché la nuova regione abbia effetto sul monitor grafico\n"
 #: ../display/d.zoom/pan.c:17
 #, c-format
@@ -19171,12 +18263,8 @@
 msgstr "Destro: Esce\n"
 #: ../display/d.rast.num/main.c:74
-msgid ""
-"Overlays cell category values on a raster map layer displayed to the "
-"graphics monitor."
-msgstr ""
-"Sovrappone i valori di categoria delle celle su un tematismo raster "
-"visualizzato sul monitor grafico"
+msgid "Overlays cell category values on a raster map layer displayed to the graphics monitor."
+msgstr "Sovrappone i valori di categoria delle celle su un tematismo raster visualizzato sul monitor grafico"
 #: ../display/d.rast.num/main.c:86
 msgid "Color for drawing grid, or \"none\""
@@ -19212,8 +18300,7 @@
 #: ../display/d.rast.num/main.c:181
 msgid ""
 "\n"
-"Your current window setting may be too large. Cells displayed on your "
-"graphics window may be too small for cell category number to be visible."
+"Your current window setting may be too large. Cells displayed on your graphics window may be too small for cell category number to be visible."
 msgstr ""
 #: ../display/d.rast.num/main.c:187
@@ -19249,14 +18336,11 @@
 msgstr ""
 #: ../display/d.grid/main.c:54
-msgid ""
-"Overlays a user-specified grid in the active display frame on the graphics "
-"monitor."
+msgid "Overlays a user-specified grid in the active display frame on the graphics monitor."
 msgstr ""
 #: ../display/d.grid/main.c:62
-msgid ""
-"Size of grid to be drawn (0: north-south resolution of the current region)"
+msgid "Size of grid to be drawn (0: north-south resolution of the current region)"
 msgstr ""
 #: ../display/d.grid/main.c:63
@@ -19375,9 +18459,7 @@
 msgstr ""
 #: ../display/d.his/main.c:67
-msgid ""
-"Displays the result obtained by combining hue, intensity, and saturation "
-"(his) values from user-specified input raster map layers."
+msgid "Displays the result obtained by combining hue, intensity, and saturation (his) values from user-specified input raster map layers."
 msgstr ""
 #: ../display/d.his/main.c:95
@@ -19385,9 +18467,7 @@
 msgstr ""
 #: ../display/d.geodesic/main.c:46
-msgid ""
-"Displays a geodesic line, tracing the shortest distance between two "
-"geographic points along a great circle, in a longitude/latitude data set."
+msgid "Displays a geodesic line, tracing the shortest distance between two geographic points along a great circle, in a longitude/latitude data set."
 msgstr ""
 #: ../display/d.geodesic/main.c:69
@@ -19406,9 +18486,7 @@
 msgstr "Nome del database in input"
 #: ../display/d.labels/main.c:46
-msgid ""
-"Displays text labels (created with v.label) to the active frame on the "
+msgid "Displays text labels (created with v.label) to the active frame on the graphics monitor."
 msgstr ""
 #: ../display/d.labels/main.c:52
@@ -19434,15 +18512,11 @@
 #: ../display/d.labels/main.c:97
 msgid "Region size is lower than minreg, nothing displayed."
-msgstr ""
 #: ../display/d.labels/main.c:105
 msgid "Region size is greater than maxreg, nothing displayed."
-msgstr ""
 #: ../display/d.labels/main.c:114 ../vector/v.lrs/v.lrs.label/main.c:300
 #, c-format
@@ -19500,9 +18574,7 @@
 msgstr "Impossibile leggere il file dei colori"
 #: ../display/d.mon/main.c:41
-msgid ""
-"Controls graphics display monitors which can be controlled from the command "
-"line."
+msgid "Controls graphics display monitors which can be controlled from the command line."
 msgstr ""
 #: ../display/d.mon/main.c:46
@@ -19617,8 +18689,7 @@
 #: ../display/d.colortable/main.c:67
 msgid "Name of raster map whose color table is to be displayed"
-msgstr ""
-"Nome della mappa raster la cui tavola dei colori dev'essere visualizzata"
+msgstr "Nome della mappa raster la cui tavola dei colori dev'essere visualizzata"
 #: ../display/d.colortable/main.c:75
 msgid "Color of lines separating the colors of the color table"
@@ -19638,14 +18709,12 @@
 #: ../display/d.colortable/main.c:114
 #, c-format
-msgid ""
-"<%s> is floating-point; ignoring [lines] and drawing continuous color ramp"
+msgid "<%s> is floating-point; ignoring [lines] and drawing continuous color ramp"
 msgstr ""
 #: ../display/d.colortable/main.c:128
 #, c-format
-msgid ""
-"<%s> is floating-point; ignoring [cols] and drawing continuous color ramp"
+msgid "<%s> is floating-point; ignoring [cols] and drawing continuous color ramp"
 msgstr ""
 #: ../display/d.colortable/main.c:139
@@ -19691,9 +18760,7 @@
 msgstr "Nome del raster map in output"
 #: ../display/d.thematic.area/main.c:79
-msgid ""
-"Displays a thematic vector area map in the active frame on the graphics "
-"monitor."
+msgid "Displays a thematic vector area map in the active frame on the graphics monitor."
 msgstr ""
 #: ../display/d.thematic.area/main.c:89
@@ -19709,9 +18776,7 @@
 msgstr "Algoritmo da usare per la classificazione"
 #: ../display/d.thematic.area/main.c:105 ../vector/v.class/main.c:67
-msgid ""
-"int;simple intervals;std;standard deviations;qua;quantiles;equ;equiprobable "
-"(normal distribution);"
+msgid "int;simple intervals;std;standard deviations;qua;quantiles;equ;equiprobable (normal distribution);"
 msgstr ""
 #: ../display/d.thematic.area/main.c:116 ../vector/v.class/main.c:78
@@ -19743,9 +18808,7 @@
 msgstr ""
 #: ../display/d.thematic.area/main.c:164
-msgid ""
-"When printing legend info , include extended statistical info from "
-"classification algorithm"
+msgid "When printing legend info , include extended statistical info from classification algorithm"
 msgstr ""
 #: ../display/d.thematic.area/main.c:168
@@ -19755,15 +18818,14 @@
 #: ../display/d.thematic.area/main.c:187
 #, c-format
 msgid "%s: You must build topology on vector map. Run v.build."
-msgstr ""
-"%s: Si deve creare la topologia sulla mappa vettoriale. Eseguire v.build"
+msgstr "%s: Si deve creare la topologia sulla mappa vettoriale. Eseguire v.build"
 #: ../display/d.thematic.area/main.c:194
 msgid "'layer' must be > 0"
 msgstr "'layer' dev'essere > 0"
 #: ../display/d.thematic.area/main.c:220
-#, fuzzy, c-format
+#, c-format
 msgid "Data (%s) not numeric. Column must be numeric."
 msgstr "I dati (%s) non sono numerici. La colonna dev'essere di tipo numerico"
@@ -19780,9 +18842,7 @@
 msgstr "Colore sconosciuto: [%s]"
 #: ../display/d.thematic.area/main.c:298
-msgid ""
-"You gave both manual breaks and a classification algorithm or a number of "
-"classes. The manual breaks have precedence and will thus be used."
+msgid "You gave both manual breaks and a classification algorithm or a number of classes. The manual breaks have precedence and will thus be used."
 msgstr ""
 #: ../display/d.thematic.area/main.c:335
@@ -19797,7 +18857,7 @@
 msgstr ""
 #: ../display/d.thematic.area/main.c:353
-#, fuzzy, c-format
+#, c-format
 msgid "Error interpreting color %s"
 msgstr "Errore nell'interpretazione del colore %s"
@@ -19807,14 +18867,11 @@
 #: ../display/d.thematic.area/main.c:379
 #, fuzzy
-msgid ""
-"The bounding box of the map is outside the current region, nothing drawn."
-msgstr ""
+msgid "The bounding box of the map is outside the current region, nothing drawn."
 #: ../display/d.thematic.area/main.c:429
-#, fuzzy, c-format
+#, c-format
 msgid ""
 "\n"
 "Total number of records: %.0f\n"
@@ -19833,7 +18890,7 @@
 msgstr ""
 #: ../display/d.thematic.area/main.c:435 ../vector/v.class/main.c:193
-#, fuzzy, c-format
+#, c-format
 msgid "Mean: %f\tStandard deviation = %f\n"
 msgstr "Media: %f\tDeviazione standard = %f\n"
@@ -19867,9 +18924,7 @@
 #: ../display/d.thematic.area/plot1.c:278
 #, c-format
-msgid ""
-"Error in color definition column (%s), element %d with cat %d: colorstring "
-"[%s]"
+msgid "Error in color definition column (%s), element %d with cat %d: colorstring [%s]"
 msgstr ""
 #: ../display/d.thematic.area/plot1.c:285
@@ -19879,8 +18934,7 @@
 #: ../display/d.thematic.area/plot1.c:353
 #, c-format
-msgid ""
-"Error in line width column (%s), element %d with cat %d: line width [%d]"
+msgid "Error in line width column (%s), element %d with cat %d: line width [%d]"
 msgstr ""
 #: ../display/d.fontlist/main.c:40
@@ -19902,7 +18956,6 @@
 msgstr ""
 #: ../display/d.graph/do_graph.c:98
-#, fuzzy
 msgid "Unable to read color"
 msgstr "Non è possibile leggere il colore"
@@ -19914,14 +18967,11 @@
 msgstr ""
 #: ../display/d.graph/main.c:61
-msgid ""
-"Program for generating and displaying simple graphics on the display monitor."
+msgid "Program for generating and displaying simple graphics on the display monitor."
 msgstr ""
 #: ../display/d.graph/main.c:68
-msgid ""
-"Name of file containing graphics commands, if not given reads from standard "
-"input"
+msgid "Name of file containing graphics commands, if not given reads from standard input"
 msgstr ""
 #: ../display/d.graph/main.c:76
@@ -19938,13 +18988,11 @@
 msgstr ""
 #: ../display/d.rgb/main.c:57
-msgid ""
-"Displays three user-specified raster maps as red, green, and blue overlays "
-"in the active graphics frame."
+msgid "Displays three user-specified raster maps as red, green, and blue overlays in the active graphics frame."
 msgstr ""
 #: ../display/d.rgb/main.c:68
-#, fuzzy, c-format
+#, c-format
 msgid "Name of raster map to be used for '%s'"
 msgstr "Nome della mappa raster da utilizzare per '%s'"
@@ -20071,9 +19119,7 @@
 "\n"
 #: ../display/d.rast.arrow/main.c:98
-msgid ""
-"Draws arrows representing cell aspect direction for a raster map containing "
-"aspect data."
+msgid "Draws arrows representing cell aspect direction for a raster map containing aspect data."
 msgstr ""
 #: ../display/d.rast.arrow/main.c:102
@@ -20107,8 +19153,7 @@
 #: ../display/d.rast.arrow/main.c:162
 msgid "Raster map containing values used for arrow length"
-msgstr ""
-"Mappa raster che contiene i valori utilizzati per la lunghezza della freccia"
+msgstr "Mappa raster che contiene i valori utilizzati per la lunghezza della freccia"
 #: ../display/d.rast.arrow/main.c:169
 msgid "Scale factor for arrows (magnitude map)"
@@ -20167,9 +19212,7 @@
 msgstr ""
 #: ../display/d.legend/main.c:87
-msgid ""
-"Displays a legend for a raster map in the active frame of the graphics "
-"monitor."
+msgid "Displays a legend for a raster map in the active frame of the graphics monitor."
 msgstr ""
 #: ../display/d.legend/main.c:98
@@ -20189,8 +19232,7 @@
 msgstr ""
 #: ../display/d.legend/main.c:133
-msgid ""
-"Size and placement as percentage of screen coordinates (0,0 is lower left)"
+msgid "Size and placement as percentage of screen coordinates (0,0 is lower left)"
 msgstr ""
 #: ../display/d.legend/main.c:143
@@ -20275,9 +19317,7 @@
 msgstr ""
 #: ../display/d.measure/main.c:49
-msgid ""
-"Measures the lengths and areas of features drawn by the user in the active "
-"display frame on the graphics monitor."
+msgid "Measures the lengths and areas of features drawn by the user in the active display frame on the graphics monitor."
 msgstr ""
 #: ../display/d.measure/main.c:55
@@ -20301,8 +19341,7 @@
 msgstr ""
 #: ../display/d.title/main.c:52
-msgid ""
-"Create a TITLE for a raster map in a form suitable for display with d.text."
+msgid "Create a TITLE for a raster map in a form suitable for display with d.text."
 msgstr ""
 #: ../display/d.title/main.c:63
@@ -20334,12 +19373,8 @@
 #: ../display/d.font/main.c:49
-msgid ""
-"Selects the font in which text will be displayed on the user's graphics "
-"monitor."
-msgstr ""
+msgid "Selects the font in which text will be displayed on the user's graphics monitor."
 #: ../display/d.font/main.c:57
 msgid "Choose new current font"
@@ -20369,12 +19404,10 @@
 #: ../display/d.font/main.c:128
 #, c-format
-msgid ""
-"Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
+msgid "Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
 msgstr ""
 #: ../general/g.filename/main.c:41
-#, fuzzy
 msgid "Prints GRASS data base file names."
 msgstr "Stampa i nomi dei file del database di GRASS"
@@ -20569,9 +19602,7 @@
 #: ../general/g.findfile/main.c:97
 #, c-format
-msgid ""
-"Parameter 'file' contains reference to <%s> mapset, but mapset parameter <"
-"%s> does not correspond"
+msgid "Parameter 'file' contains reference to <%s> mapset, but mapset parameter <%s> does not correspond"
 msgstr ""
 #: ../general/g.proj/create.c:17
@@ -20580,7 +19611,7 @@
 msgstr "Non è possibile creare la location: %s"
 #: ../general/g.proj/create.c:20
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create projection files: %s"
 msgstr "Non è possibile creare i file della proiezione: %s"
@@ -20597,18 +19628,11 @@
 #: ../general/g.proj/create.c:36
 #, fuzzy, c-format
-msgid ""
-"You must select the PERMANENT mapset before updating the current location's "
-"projection (current mapset is <%s>)."
-msgstr ""
-"Devi selezionare il mapset PERMANENT prima di aggiornare la proioezione "
-"corrente della localtion. (Il mapset corrente è %s)"
+msgid "You must select the PERMANENT mapset before updating the current location's projection (current mapset is <%s>)."
+msgstr "Devi selezionare il mapset PERMANENT prima di aggiornare la proioezione corrente della localtion. (Il mapset corrente è %s)"
 #: ../general/g.proj/create.c:62
-msgid ""
-"Default region was updated to the new projection, but if you have multiple "
-"mapsets `g.region -d` should be run in each to update the region from the "
-"default"
+msgid "Default region was updated to the new projection, but if you have multiple mapsets `g.region -d` should be run in each to update the region from the default"
 msgstr ""
 #: ../general/g.proj/create.c:66
@@ -20623,9 +19647,7 @@
 #: ../general/g.proj/main.c:67
 #, fuzzy
-msgid ""
-"Prints and manipulates GRASS projection information files (in various co-"
-"ordinate system descriptions)."
+msgid "Prints and manipulates GRASS projection information files (in various co-ordinate system descriptions)."
 msgstr "Stampa e modifica i file di proiezione di GRASS"
 #: ../general/g.proj/main.c:70
@@ -20649,19 +19671,15 @@
 #: ../general/g.proj/main.c:92
 msgid "Verify datum information and print transformation parameters"
-msgstr ""
-"Verifica le informazioni sul datum e stampa i parametri di trasformazione"
+msgstr "Verifica le informazioni sul datum e stampa i parametri di trasformazione"
 #: ../general/g.proj/main.c:98
 msgid "Print projection information in PROJ.4 format"
 msgstr "Stampa le informazioni di proiezione in formato PROJ4"
 #: ../general/g.proj/main.c:104
-msgid ""
-"Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
-msgstr ""
-"Stampa output 'flat' senza interruzioni di riga (applicabile ad output WKT e "
-"PROJ4)"
+msgid "Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
+msgstr "Stampa output 'flat' senza interruzioni di riga (applicabile ad output WKT e PROJ4)"
 #: ../general/g.proj/main.c:114
 msgid "Print projection information in WKT format"
@@ -20680,14 +19698,12 @@
 #: ../general/g.proj/main.c:128
 #, fuzzy
 msgid "Name of georeferenced data file to read projection information from"
-msgstr ""
-"File di dati georeferenziati dai quali leggere le informazioni di proiezione"
+msgstr "File di dati georeferenziati dai quali leggere le informazioni di proiezione"
 #: ../general/g.proj/main.c:137
 #, fuzzy
 msgid "Name of ASCII file containing a WKT projection description"
-msgstr ""
-"File ASCII contenente la descrizione della proiezione WKT (- per stdin)"
+msgstr "File ASCII contenente la descrizione della proiezione WKT (- per stdin)"
 #: ../general/g.proj/main.c:139 ../general/g.proj/main.c:148
 #: ../vector/v.segment/main.c:69
@@ -20701,7 +19717,6 @@
 msgstr "Descrizione della proiezione in stile PROJ4 (- per sdin)"
 #: ../general/g.proj/main.c:156
-#, fuzzy
 msgid "EPSG projection code"
 msgstr "Codice EPSG della proiezione"
@@ -20718,16 +19733,13 @@
 msgstr ""
 #: ../general/g.proj/main.c:173
-msgid ""
-"Force override of datum transformation information in input co-ordinate "
-"system"
+msgid "Force override of datum transformation information in input co-ordinate system"
 msgstr ""
 #: ../general/g.proj/main.c:179
 #, fuzzy
 msgid "Create new projection files (modifies current location)"
-msgstr ""
-"Non è possibile ottenere le unità  della proiezione della location attuale"
+msgstr "Non è possibile ottenere le unità  della proiezione della location attuale"
 #: ../general/g.proj/main.c:187 ../general/g.mapset/main.c:83
 #: ../locale/scriptstrings/r.mask_to_translate.c:6
@@ -20736,15 +19748,13 @@
 msgstr ""
 #: ../general/g.proj/main.c:188
-#, fuzzy
 msgid "Name of new location to create"
 msgstr "Nome della nuova locazione da creare"
 #: ../general/g.proj/main.c:204
-#, fuzzy, c-format
+#, c-format
 msgid "Only one of '%s', '%s', '%s' or '%s' options may be specified"
-msgstr ""
-"Solo una delle seguenti opzioni: '%s', '%s' o '%s' può essere specificata"
+msgstr "Solo una delle seguenti opzioni: '%s', '%s' o '%s' può essere specificata"
 #: ../general/g.proj/main.c:233
 msgid "Projection files missing"
@@ -20753,8 +19763,7 @@
 #: ../general/g.proj/main.c:249
 #, fuzzy, c-format
 msgid "Only one of -%c, -%c, -%c, -%c, -%c or -%c flags may be specified"
-msgstr ""
-"Solo una delle seguenti opzioni: '%s', '%s' or '%s' deve essere specificata"
+msgstr "Solo una delle seguenti opzioni: '%s', '%s' or '%s' deve essere specificata"
 #: ../general/g.proj/main.c:276
 #, c-format
@@ -20767,7 +19776,6 @@
 msgstr ""
 #: ../general/g.proj/input.c:91
-#, fuzzy
 msgid "Error reading WKT projection description"
 msgstr "Errore nella lettura della descrizione della proiezione WKT"
@@ -20781,7 +19789,6 @@
 msgstr "Impossibile importare la stringa parametrica in stile PROJ4"
 #: ../general/g.proj/input.c:181
-#, fuzzy
 msgid "Unable to translate EPSG code"
 msgstr "Non è possibile tradurre il codice EPSG"
@@ -20798,19 +19805,14 @@
 msgstr "Provo a aprire con GDAL..."
 #: ../general/g.proj/input.c:254
-#, fuzzy, c-format
+#, c-format
 msgid "Could not read georeferenced file %s using either OGR nor GDAL"
 msgstr "Impossibile leggere il file georeferenziato %s né con GDAL né con OGR"
 #: ../general/g.proj/input.c:259
 #, c-format
-msgid ""
-"Read of file %s was successful, but it did not contain projection "
-"information. 'XY (unprojected)' will be used"
-msgstr ""
-"Lettura del file %s avvenuta con successo, ma non contiene alcuna "
-"informazione sullaproiezione. Verrà usata la proiezione 'XY (nessuna "
-"proiezione)'"
+msgid "Read of file %s was successful, but it did not contain projection information. 'XY (unprojected)' will be used"
+msgstr "Lettura del file %s avvenuta con successo, ma non contiene alcuna informazione sullaproiezione. Verrà usata la proiezione 'XY (nessuna proiezione)'"
 #: ../general/g.proj/output.c:181
 #, c-format
@@ -20848,9 +19850,7 @@
 #: ../general/g.mremove/main.c:66
 #, fuzzy
-msgid ""
-"Removes data base element files from the user's current mapset using regular "
-"expressions."
+msgid "Removes data base element files from the user's current mapset using regular expressions."
 msgstr "Rimuove i file degli elementi nel corrente mapset  nel database"
 #: ../general/g.mremove/main.c:71 ../general/g.mlist/main.c:102
@@ -20908,8 +19908,7 @@
 msgstr "Cambia il mapset corrente."
 #: ../general/g.mapset/main.c:52
-msgid ""
-"Optionally create new mapset or list available mapsets in given location."
+msgid "Optionally create new mapset or list available mapsets in given location."
 msgstr ""
 #: ../general/g.mapset/main.c:56
@@ -20927,9 +19926,7 @@
 #: ../general/g.mapset/main.c:76
 #, fuzzy
 msgid "Full path to the directory where the new location is"
-msgstr ""
-"Nuovo GISDBASE (percorso intero della directory dove la nuova location è "
-"situata)"
+msgstr "Nuovo GISDBASE (percorso intero della directory dove la nuova location è situata)"
 #: ../general/g.mapset/main.c:81
 msgid "Create mapset if it doesn't exist"
@@ -20946,7 +19943,7 @@
 msgstr "mostra i parametri della connessione in uso ed esce"
 #: ../general/g.mapset/main.c:149
-#, fuzzy, c-format
+#, c-format
 msgid "<%s> is already the current mapset"
 msgstr "<%s> è già il mapset corrente"
@@ -20961,7 +19958,6 @@
 msgstr "Il mapset non esiste. Usa l'opzione -c per crearlo"
 #: ../general/g.mapset/main.c:178
-#, fuzzy
 msgid "Unable to read GIS_LOCK environment variable"
 msgstr "Non è possibile leggere la variabile d'ambiente GIS_LOCK"
@@ -20998,12 +19994,11 @@
 msgstr ""
 #: ../general/g.mapset/main.c:233
-#, fuzzy, c-format
+#, c-format
 msgid "Your current mapset is <%s>"
 msgstr "Il mapset corrente è <%s>"
 #: ../general/g.pnmcat/main.c:30 ../general/g.pnmcomp/main.c:53
-#, fuzzy
 msgid "Error reading PPM file"
 msgstr "Errore durante la lettura del file PPM"
@@ -21152,9 +20147,7 @@
 msgstr ""
 #: ../general/g.mlist/main.c:66
-msgid ""
-"Lists available GRASS data base files of the user-specified data type "
-"optionally using the search pattern."
+msgid "Lists available GRASS data base files of the user-specified data type optionally using the search pattern."
 msgstr ""
 #: ../general/g.mlist/main.c:81
@@ -21174,8 +20167,7 @@
 #: ../general/g.mlist/main.c:94
 #, fuzzy
 msgid "Name of mapset to list (default: current search path)"
-msgstr ""
-"Mapset del quale fornire la lista (predefinito: percorso di ricerca corrente)"
+msgstr "Mapset del quale fornire la lista (predefinito: percorso di ricerca corrente)"
 #: ../general/g.mlist/main.c:113
 msgid "Print data types"
@@ -21190,7 +20182,6 @@
 msgstr ""
 #: ../general/g.mlist/main.c:128 ../general/g.list/main.c:59
-#, fuzzy
 msgid "Verbose listing (also list map titles)"
 msgstr "Lista dettagliata (fornisce anche i titoli delle mappe)"
@@ -21213,7 +20204,6 @@
 msgstr "Visualizza informazioni sulla versione e sul copyright"
 #: ../general/g.version/main.c:49
-#, fuzzy
 msgid "Print also the copyright message"
 msgstr "Stampa il messaggio sul copyright"
@@ -21377,28 +20367,22 @@
 msgstr "Stampa la regione corrente"
 #: ../general/g.region/main.c:87
-#, fuzzy
 msgid "Print the current region in lat/long using the current ellipsoid/datum"
-msgstr ""
-"Stampa la regione corrente in lat/long usando ellissoide/datum corrente"
+msgstr "Stampa la regione corrente in lat/long usando ellissoide/datum corrente"
 #: ../general/g.region/main.c:93
-#, fuzzy
 msgid "Print the current region extent"
 msgstr "Stampa l'estensione della regione corrente"
 #: ../general/g.region/main.c:99
-#, fuzzy
 msgid "Print the current region map center coordinates"
 msgstr "Stampa le coordinate del centro della mappa della regione corrente"
 #: ../general/g.region/main.c:105
-#, fuzzy
 msgid "Print the current region in GMT style"
 msgstr "Stampa la regione corrente in stile GMT"
 #: ../general/g.region/main.c:111
-#, fuzzy
 msgid "Print the current region in WMS style"
 msgstr "Stampa la regione corrente in stile WMS"
@@ -21411,9 +20395,7 @@
 msgstr ""
 #: ../general/g.region/main.c:124
-msgid ""
-"The difference between the projection's grid north and true north, measured "
-"at the center coordinates of the current region."
+msgid "The difference between the projection's grid north and true north, measured at the center coordinates of the current region."
 msgstr ""
 #: ../general/g.region/main.c:130
@@ -21421,18 +20403,12 @@
 msgstr "Stampa anche le impostazioni 3D"
 #: ../general/g.region/main.c:136
-#, fuzzy
 msgid "Print the maximum bounding box in lat/long on WGS84"
 msgstr "Stampa l'estensione massima in lat/long per la proiezione WGS84"
 #: ../general/g.region/main.c:147
-#, fuzzy
-msgid ""
-"Align region to resolution (default = align to bounds, works only for 2D "
-"resolution)"
-msgstr ""
-"Allinea la regione alla risoluzione (predefinito = allinea ai margini, "
-"funziona solo per la risoluzione 2D)"
+msgid "Align region to resolution (default = align to bounds, works only for 2D resolution)"
+msgstr "Allinea la regione alla risoluzione (predefinito = allinea ai margini, funziona solo per la risoluzione 2D)"
 #: ../general/g.region/main.c:153
 msgid "Do not update the current region"
@@ -21450,9 +20426,7 @@
 #: ../general/g.region/main.c:180
 msgid "Set region to match this 3D raster map (both 2D and 3D values)"
-msgstr ""
-"Imposta la regione in modo che corrisponda a questa mappa raster (sia valori "
-"2D che 3D)"
+msgstr "Imposta la regione in modo che corrisponda a questa mappa raster (sia valori 2D che 3D)"
 #: ../general/g.region/main.c:243
 msgid "Value for the top edge"
@@ -21506,10 +20480,8 @@
 msgstr ""
 #: ../general/g.region/main.c:349
-#, fuzzy
 msgid "Save current region settings in named region file"
-msgstr ""
-"Salva le impostazioni della regione corrente in un file di regione con nome"
+msgstr "Salva le impostazioni della regione corrente in un file di regione con nome"
 #: ../general/g.region/main.c:408
 #, c-format
@@ -21537,7 +20509,7 @@
 msgstr ""
 #: ../general/g.region/main.c:492
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to read header of 3D raster map <%s@%s>"
 msgstr "Non è possibile leggere l'intestazione della mappa raster <%s@%s>"
@@ -21547,29 +20519,25 @@
 msgstr "Impossibile aprire la mappa vettoriale <%s@%s>"
 #: ../general/g.region/main.c:805
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to set region <%s>"
 msgstr "Non è possibile impostare la regione <%s>"
 #: ../general/g.region/main.c:811
-#, fuzzy
 msgid "Unable to update current region"
 msgstr "Non è possibile aggiornare la regione corrente"
 #: ../general/g.region/main.c:819
 msgid "Unable to change default region. The current mapset is not <PERMANENT>."
-msgstr ""
-"Non è possibile cambiare la regione predefintia. Il mapset corrente non è "
-"<PERMANENT>"
+msgstr "Non è possibile cambiare la regione predefintia. Il mapset corrente non è <PERMANENT>"
 #: ../general/g.region/main.c:836
-#, fuzzy, c-format
+#, c-format
 msgid "Invalid input <%s=%s>"
 msgstr "Input <%s=%s> non valido"
 #: ../general/g.region/printwindow.c:263 ../general/g.region/printwindow.c:516
 #: ../general/g.region/printwindow.c:647
-#, fuzzy
 msgid "Unable to update lat/long projection parameters"
 msgstr "Non è possibile aggiornare i parametri della proiezione lat/long"
@@ -21578,18 +20546,12 @@
 msgstr ""
 #: ../general/g.region/printwindow.c:412
-msgid ""
-"You are in a simple XY location, projection to Lat/Lon is not possible. Use "
-"the -p flag instead."
+msgid "You are in a simple XY location, projection to Lat/Lon is not possible. Use the -p flag instead."
 msgstr ""
 #: ../general/g.region/printwindow.c:637
-msgid ""
-"WGS84 output not possible as this location does not contain datum "
-"transformation parameters. Try running g.setproj."
-msgstr ""
-"Output WGS84 impossible a causa dell'assenza di parametri di trasformazione "
-"del datum. Prova ad eseguire g.setproj."
+msgid "WGS84 output not possible as this location does not contain datum transformation parameters. Try running g.setproj."
+msgstr "Output WGS84 impossible a causa dell'assenza di parametri di trasformazione del datum. Prova ad eseguire g.setproj."
 #: ../general/g.region/printwindow.c:783
 msgid "Lat/Long calculations are not possible from a simple XY system"
@@ -21600,9 +20562,7 @@
 msgstr ""
 #: ../general/g.mkfontcap/main.c:73
-msgid ""
-"Generates the font configuration file by scanning various directories for "
-"fonts"
+msgid "Generates the font configuration file by scanning various directories for fonts"
 msgstr ""
 #: ../general/g.mkfontcap/main.c:79
@@ -21610,26 +20570,20 @@
 msgstr ""
 #: ../general/g.mkfontcap/main.c:84
-msgid ""
-"Write font configuration file to standard output instead of $GISBASE/etc"
+msgid "Write font configuration file to standard output instead of $GISBASE/etc"
 msgstr ""
 #: ../general/g.mkfontcap/main.c:92
-msgid ""
-"Comma-separated list of extra directories to scan for Freetype-compatible "
-"fonts as well as the defaults (see documentation)"
+msgid "Comma-separated list of extra directories to scan for Freetype-compatible fonts as well as the defaults (see documentation)"
 msgstr ""
 #: ../general/g.mkfontcap/main.c:109
 #, fuzzy, c-format
-msgid ""
-"Fontcap file %s already exists; use -%c flag if you wish to overwrite it"
+msgid "Fontcap file %s already exists; use -%c flag if you wish to overwrite it"
 msgstr "Mappa in uscita già esistente. Sarà sovrascritta!\n"
 #: ../general/g.mkfontcap/main.c:121
-msgid ""
-"This GRASS installation was compiled without Freetype support, extradirs "
-"parameter ignored"
+msgid "This GRASS installation was compiled without Freetype support, extradirs parameter ignored"
 msgstr ""
 #: ../general/g.mkfontcap/main.c:148
@@ -21660,7 +20614,6 @@
 msgstr "PERMANENT: permesso negato"
 #: ../general/g.setproj/main.c:105
-#, fuzzy
 msgid "Current region cannot be set"
 msgstr "La regione corrente non può essere impostata."
@@ -21673,7 +20626,6 @@
 msgstr ""
 #: ../general/g.setproj/main.c:137
-#, fuzzy
 msgid "The projection information will not be updated"
 msgstr "Le informazioni sulla proiezione non saranno aggiornate"
@@ -21689,7 +20641,6 @@
 msgstr "XY-location non può essere proiettata"
 #: ../general/g.setproj/main.c:192
-#, fuzzy
 msgid "Unknown projection"
 msgstr "Proiezione sconosciuta"
@@ -21708,13 +20659,10 @@
 msgstr "Il datum corrente è %s (%s)"
 #: ../general/g.setproj/main.c:217
-#, fuzzy
 msgid "Do you wish to change the datum (or datum transformation parameters)?"
-msgstr ""
-"Si vuole cambiare il datum (o i parametri di trasformazione del datum)?"
+msgstr "Si vuole cambiare il datum (o i parametri di trasformazione del datum)?"
 #: ../general/g.setproj/main.c:225
-#, fuzzy
 msgid "The datum information has not been changed"
 msgstr "Le informazioni sul datum non sono state cambiate"
@@ -21745,7 +20693,6 @@
 msgstr ""
 #: ../general/g.setproj/main.c:336
-#, fuzzy
 msgid "Invalid input ellipsoid"
 msgstr "Ellissoide di input non valido"
@@ -21759,15 +20706,11 @@
 msgstr ""
 #: ../general/g.setproj/main.c:451
-#, fuzzy
 msgid "UTM zone information has not been updated"
 msgstr "Le informazioni sulla zona UTM non sono state aggiornate"
 #: ../general/g.setproj/main.c:456
-msgid ""
-"But if you change zone, all the existing data will be interpreted by "
-"projection software. GRASS will not automatically re-project or even change "
-"the headers for existing maps."
+msgid "But if you change zone, all the existing data will be interpreted by projection software. GRASS will not automatically re-project or even change the headers for existing maps."
 msgstr ""
 #: ../general/g.setproj/main.c:461
@@ -21775,7 +20718,7 @@
 msgstr ""
 #: ../general/g.setproj/main.c:497
-#, fuzzy, c-format
+#, c-format
 msgid "Error writing PROJ_INFO file <%s>"
 msgstr "Errore durante la scrittura del file PROJ_INFO <%s>"
@@ -21790,7 +20733,7 @@
 msgstr ""
 #: ../general/g.setproj/main.c:611
-#, fuzzy, c-format
+#, c-format
 msgid "Enter conversion factor from %s to meters: "
 msgstr "Inserire il fattore di conversione da %s a metri"
@@ -21804,7 +20747,7 @@
 msgstr ""
 #: ../general/g.setproj/main.c:645
-#, fuzzy, c-format
+#, c-format
 msgid ""
 "\n"
 "Projection information has been recorded for this location\n"
@@ -21814,7 +20757,6 @@
 "Le informaizoni sulla proiezione sono state registrate per questa location\n"
 #: ../general/g.setproj/main.c:647
-#, fuzzy
 msgid "The geographic region information in WIND is now obsolete"
 msgstr "Le informazioni geografiche contenute in WIND ora sono obsolete"
@@ -21879,7 +20821,7 @@
 msgstr ""
 #: ../general/g.pnmcomp/main.c:111
-#, fuzzy, c-format
+#, c-format
 msgid "Invalid magic number: 'P%c'"
 msgstr "Magic number non valido: 'P%c'"
@@ -21888,12 +20830,10 @@
 msgstr "File PGM non valido"
 #: ../general/g.pnmcomp/main.c:246
-#, fuzzy
 msgid "Error writing PPM file"
 msgstr "Errore nella scrittura del file PPM"
 #: ../general/g.pnmcomp/main.c:263
-#, fuzzy
 msgid "Error writing PGM file"
 msgstr "Errore nella scrittura del file PGM"
@@ -21948,8 +20888,7 @@
 msgstr "File raster in output"
 #: ../general/g.message/main.c:36
-msgid ""
-"Prints a message, warning, progress info, or fatal error in the GRASS way."
+msgid "Prints a message, warning, progress info, or fatal error in the GRASS way."
 msgstr ""
 #: ../general/g.message/main.c:38
@@ -21991,7 +20930,6 @@
 msgstr ""
 #: ../general/g.message/main.c:75
-#, fuzzy
 msgid "Text of the message to be printed"
 msgstr "Testo del messaggio da stampare"
@@ -22004,7 +20942,6 @@
 msgstr ""
 #: ../general/g.message/main.c:104
-#, fuzzy
 msgid "Unable to parse input message"
 msgstr "Non è possibile eseguire il parsing del messaggio di input"
@@ -22031,13 +20968,10 @@
 msgstr "Modifica il percorso di ricerca corrente dell'utente"
 #: ../general/g.mapsets/main.c:63
-msgid ""
-"Affects the user's access to data existing under the other mapsets in the "
-"current location."
+msgid "Affects the user's access to data existing under the other mapsets in the current location."
 msgstr ""
 #: ../general/g.mapsets/main.c:71
-#, fuzzy
 msgid "Name(s) of existing mapset(s)"
 msgstr "Nome di uno o più mapset esistenti"
@@ -22047,19 +20981,14 @@
 msgstr "Percorso di ricerca"
 #: ../general/g.mapsets/main.c:80
-#, fuzzy
 msgid "Name(s) of existing mapset(s) to add to search path"
-msgstr ""
-"Nome di uno o più mapset esistenti da aggiungere al percorso di ricerca"
+msgstr "Nome di uno o più mapset esistenti da aggiungere al percorso di ricerca"
 #: ../general/g.mapsets/main.c:89
-#, fuzzy
 msgid "Name(s) of existing mapset(s) to remove from search path"
-msgstr ""
-"Nome di uno o più mapset esistenti da rimuovere dal percorso di ricerca"
+msgstr "Nome di uno o più mapset esistenti da rimuovere dal percorso di ricerca"
 #: ../general/g.mapsets/main.c:97
-#, fuzzy
 msgid "List all available mapsets in alphabetical order"
 msgstr "Elenca tutti i mapset disponibili in ordine alfabetico"
@@ -22072,12 +21001,12 @@
 msgstr ""
 #: ../general/g.mapsets/main.c:132 ../general/g.mapsets/main.c:161
-#, fuzzy, c-format
+#, c-format
 msgid "Mapset <%s> not found"
 msgstr "Mapset <%s> non trovato"
 #: ../general/g.mapsets/main.c:163
-#, fuzzy, c-format
+#, c-format
 msgid "Mapset <%s> added to search path"
 msgstr "Mapset <%s> aggiunto al percorso di ricerca"
@@ -22115,7 +21044,7 @@
 msgstr "<%s> esiste già nel mapset <%s>"
 #: ../general/g.rename/main.c:84
-#, fuzzy, c-format
+#, c-format
 msgid "%s=%s,%s: files could be the same, no rename possible"
 msgstr "%s=%s,%s: i file devono essere gli stessi, non è possibile rinominarli"
@@ -22129,9 +21058,7 @@
 #: ../general/g.copy/main.c:45
 #, fuzzy
-msgid ""
-"Copies available data files in the current mapset search path to the user's "
-"current mapset."
+msgid "Copies available data files in the current mapset search path to the user's current mapset."
 #: ../general/g.copy/main.c:52
@@ -22157,19 +21084,15 @@
 #: ../vector/v.random/main.c:88
 #, fuzzy
 msgid "Generates randomly 2D/3D vector points map."
-msgstr ""
-"Genera una mappa GRASS 2D/3D di punti vettoriali disposti in posizioni "
-"casuali"
+msgstr "Genera una mappa GRASS 2D/3D di punti vettoriali disposti in posizioni casuali"
 #: ../vector/v.random/main.c:96
 msgid "Number of points to be created"
 msgstr "Numero di punti da creare"
 #: ../vector/v.random/main.c:103
-#, fuzzy
 msgid "Minimum z height (needs -z flag or column name)"
-msgstr ""
-"Minimo valore di altezza z (necessita del parametro -z o del nome di colonna)"
+msgstr "Minimo valore di altezza z (necessita del parametro -z o del nome di colonna)"
 #: ../vector/v.random/main.c:105 ../vector/v.random/main.c:114
 #: ../vector/v.random/main.c:127 ../vector/v.random/main.c:137
@@ -22178,16 +21101,11 @@
 msgstr "Output 3D"
 #: ../vector/v.random/main.c:112
-#, fuzzy
 msgid "Maximum z height (needs -z flag or column name)"
-msgstr ""
-"Massimo valore di altezza z (necessita del parametro -z o del nome di "
-"colonna)"
+msgstr "Massimo valore di altezza z (necessita del parametro -z o del nome di colonna)"
 #: ../vector/v.random/main.c:121
-msgid ""
-"The seed to initialize the random generator. If not set the process id is "
-"used."
+msgid "The seed to initialize the random generator. If not set the process id is used."
 msgstr ""
 #: ../vector/v.random/main.c:124
@@ -22228,9 +21146,7 @@
 msgstr ""
 #: ../vector/v.random/main.c:236
-msgid ""
-"You have created unsupported column type. This module supports only INTEGER "
-"and DOUBLE PRECISION column types."
+msgid "You have created unsupported column type. This module supports only INTEGER and DOUBLE PRECISION column types."
 msgstr ""
 #: ../vector/v.random/main.c:272
@@ -22259,10 +21175,7 @@
 msgstr "linea"
 #: ../vector/v.net.iso/main.c:76
-msgid ""
-"Splits net to bands between cost isolines (direction from centre). Centre "
-"node must be opened (costs >= 0). Costs of centre node are used in "
-"calculation."
+msgid "Splits net to bands between cost isolines (direction from centre). Centre node must be opened (costs >= 0). Costs of centre node are used in calculation."
 msgstr ""
 #: ../vector/v.net.iso/main.c:100 ../vector/v.net.centrality/main.c:129
@@ -22293,9 +21206,7 @@
 msgstr "Colonna costo per i nodi (numero)"
 #: ../vector/v.net.iso/main.c:114
-msgid ""
-"Categories of centres (points on nodes) to which net will be allocated. "
-"Layer for this categories is given by nlayer option."
+msgid "Categories of centres (points on nodes) to which net will be allocated. Layer for this categories is given by nlayer option."
 msgstr ""
 #: ../vector/v.net.iso/main.c:123
@@ -22356,9 +21267,7 @@
 msgstr "Non riesco a trovare il file raster %s"
 #: ../vector/v.net.centrality/main.c:100
-msgid ""
-"Computes degree, centrality, betweeness, closeness and eigenvector "
-"centrality measures in the network."
+msgid "Computes degree, centrality, betweeness, closeness and eigenvector centrality measures in the network."
 msgstr ""
 #: ../vector/v.net.centrality/main.c:110 ../vector/v.net.centrality/main.c:116
@@ -22439,7 +21348,7 @@
 #: ../vector/v.net.flow/main.c:188 ../vector/v.net.timetable/main.c:112
 #: ../vector/v.net.allpairs/main.c:180 ../vector/v.net.components/main.c:191
 #: ../vector/v.net.path/path.c:117
-#, fuzzy, c-format
+#, c-format
 msgid "Cannot grant privileges on table <%s>"
 msgstr "Impossibile assegnare i privilegi sulla tabella <%s>"
@@ -22480,8 +21389,7 @@
 #: ../vector/v.build.polylines/main.c:225 ../vector/v.category/main.c:707
 #: ../vector/v.transform/main.c:279 ../vector/v.rectify/main.c:248
 msgid "Failed to copy attribute table to output map"
-msgstr ""
-"Copiatura della tabella degli attributi sulla mappa di output non riuscita"
+msgstr "Copiatura della tabella degli attributi sulla mappa di output non riuscita"
 #: ../vector/v.colors.out/make_colors.c:26
 #: ../vector/v.colors.out/scan_cats.c:22 ../vector/v.colors/main.c:229
@@ -22532,9 +21440,7 @@
 #: ../vector/v.colors.out/main.c:66
 #, fuzzy
 msgid "Name of attribute (numeric) column to which refer color rules"
-msgstr ""
-"Nome della colonna della tabella degli attributi da utilizzare per le "
-"etichette"
+msgstr "Nome della colonna della tabella degli attributi da utilizzare per le etichette"
 #: ../vector/v.colors.out/main.c:67
 msgid "If not given color rules are refered to categories"
@@ -22548,8 +21454,7 @@
 #: ../vector/v.colors.out/main.c:88
 #, fuzzy, c-format
 msgid "No color table defined for vector map <%s>"
-msgstr ""
-"Impossibile ottenere informazioni sul layer per la mappa vettoriale <%s>"
+msgstr "Impossibile ottenere informazioni sul layer per la mappa vettoriale <%s>"
 #: ../vector/v.voronoi/main.c:122 ../vector/v.delaunay/main.c:87
 #, fuzzy
@@ -22558,11 +21463,8 @@
 #: ../vector/v.voronoi/main.c:123
 #, fuzzy
-msgid ""
-"Creates a Voronoi diagram in current region from an input vector map "
-"containing points or centroids."
-msgstr ""
-"Crea un diagramma di Voronoi da un vettoriale contenente punti o centroidi."
+msgid "Creates a Voronoi diagram in current region from an input vector map containing points or centroids."
+msgstr "Crea un diagramma di Voronoi da un vettoriale contenente punti o centroidi."
 #: ../vector/v.voronoi/main.c:127 ../vector/v.sample/main.c:82
 #, fuzzy
@@ -22624,9 +21526,7 @@
 msgstr "Crea albero di Streiner per la rete e i punti scelti"
 #: ../vector/v.net.steiner/main.c:351
-msgid ""
-"Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm "
-"is used in this module so the result may be sub optimal"
+msgid "Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm is used in this module so the result may be sub optimal"
 msgstr ""
 #: ../vector/v.net.steiner/main.c:371
@@ -22660,8 +21560,7 @@
 #: ../vector/v.net.steiner/main.c:529
 #, c-format
-msgid ""
-"[%d] (not reachable) nodes removed from list of Steiner point candidates"
+msgid "[%d] (not reachable) nodes removed from list of Steiner point candidates"
 msgstr ""
 #: ../vector/v.net.steiner/main.c:534
@@ -22760,18 +21659,11 @@
 msgstr ""
 #: ../vector/v.overlay/main.c:99
-msgid ""
-"Feature is written to output if the result of operation 'ainput operator "
-"binput' is true. Input feature is considered to be true, if category of "
-"given layer is defined."
+msgid "Feature is written to output if the result of operation 'ainput operator binput' is true. Input feature is considered to be true, if category of given layer is defined."
 msgstr ""
 #: ../vector/v.overlay/main.c:104
-msgid ""
-"and;also known as 'intersection' in GIS;or;also known as 'union' in GIS "
-"(only for atype=area);not;features from ainput not overlayed by features "
-"from binput;xor;features from either ainput or binput but not those from "
-"ainput overlayed by binput (only for atype=area)"
+msgid "and;also known as 'intersection' in GIS;or;also known as 'union' in GIS (only for atype=area);not;features from ainput not overlayed by features from binput;xor;features from either ainput or binput but not those from ainput overlayed by binput (only for atype=area)"
 msgstr ""
 #: ../vector/v.overlay/main.c:117
@@ -22845,9 +21737,7 @@
 msgstr ""
 #: ../vector/v.kernel/main.c:109
-msgid ""
-"Generates a raster density map from vector point data using a moving kernel "
-"or optionally generates a vector density map on a vector network."
+msgid "Generates a raster density map from vector point data using a moving kernel or optionally generates a vector density map on a vector network."
 msgstr ""
 #: ../vector/v.kernel/main.c:113
@@ -22855,7 +21745,6 @@
 msgstr "Inserisci il vettore con i punti di controllo"
 #: ../vector/v.kernel/main.c:117
-#, fuzzy
 msgid "Input network vector map"
 msgstr "Mappa vettoriale della rete di input"
@@ -22889,34 +21778,23 @@
 msgstr "Metodo sconosciuto"
 #: ../vector/v.kernel/main.c:169
-msgid ""
-"none;No method applied at nodes with more than 2 arcs;split;Equal split "
-"(Okabe 2009) applied at nodes;"
+msgid "none;No method applied at nodes with more than 2 arcs;split;Equal split (Okabe 2009) applied at nodes;"
 msgstr ""
 #: ../vector/v.kernel/main.c:176
-#, fuzzy
 msgid "Kernel function"
-msgstr "Funzioni note:"
+msgstr "Funzione kernel"
 #: ../vector/v.kernel/main.c:184
-msgid ""
-"Try to calculate an optimal standard deviation with 'stddeviation' taken as "
-"maximum (experimental)"
-msgstr ""
-"Prova a calcolare una deviazione standard ottimale con 'stddeviation' presa "
-"come massimo (sperimentale)"
+msgid "Try to calculate an optimal standard deviation with 'stddeviation' taken as maximum (experimental)"
+msgstr "Prova a calcolare una deviazione standard ottimale con 'stddeviation' presa come massimo (sperimentale)"
 #: ../vector/v.kernel/main.c:189
 msgid "Only calculate optimal standard deviation and exit (no map is written)"
-msgstr ""
-"Calcola solo la deviazione standard ottimale ed esci (nessuna mappa verrà "
-"creata)"
+msgstr "Calcola solo la deviazione standard ottimale ed esci (nessuna mappa verrà creata)"
 #: ../vector/v.kernel/main.c:194
-msgid ""
-"In network mode, normalize values by sum of density multiplied by length of "
-"each segment. Integral over the output map then gives 1.0 * mult"
+msgid "In network mode, normalize values by sum of density multiplied by length of each segment. Integral over the output map then gives 1.0 * mult"
 msgstr ""
 #: ../vector/v.kernel/main.c:199
@@ -22929,20 +21807,15 @@
 #: ../vector/v.kernel/main.c:234
-#, fuzzy
 msgid "Unknown kernel function"
-msgstr "Proiezione sconosciuta"
+msgstr "Funzione kernel sconosciuta"
 #: ../vector/v.kernel/main.c:240
-msgid ""
-"Optimal standard deviation calculation is supported only for node method "
-"'none' and kernel function 'gaussian'."
+msgid "Optimal standard deviation calculation is supported only for node method 'none' and kernel function 'gaussian'."
 msgstr ""
 #: ../vector/v.kernel/main.c:244
-msgid ""
-"Optimal standard deviation calculation is supported only for kernel function "
-"'gaussian'."
+msgid "Optimal standard deviation calculation is supported only for kernel function 'gaussian'."
 msgstr ""
 #: ../vector/v.kernel/main.c:301
@@ -22952,12 +21825,8 @@
 #: ../vector/v.kernel/main.c:323
 #, fuzzy, c-format
-msgid ""
-"Automatic choice of smoothing parameter (standard deviation), maximum "
-"possible value of standard deviation is set to %f"
-msgstr ""
-"Scegli automaticamente i parametri di smoothing (deviazione standard), il "
-"massimo valore possibile della deviazione standard è stato posto pari a %f"
+msgid "Automatic choice of smoothing parameter (standard deviation), maximum possible value of standard deviation is set to %f"
+msgstr "Scegli automaticamente i parametri di smoothing (deviazione standard), il massimo valore possibile della deviazione standard è stato posto pari a %f"
 #: ../vector/v.kernel/main.c:330
 #, c-format
@@ -22976,12 +21845,8 @@
 #: ../vector/v.kernel/main.c:348
 #, c-format
-msgid ""
-"Distances between all points are beyond %e (4 * standard deviation), unable "
-"to calculate optimal value."
-msgstr ""
-"Le distanze tra tutti i punti sono oltre %e (4 * deviazione standard), "
-"impossibile calcolare il valore ottimale."
+msgid "Distances between all points are beyond %e (4 * standard deviation), unable to calculate optimal value."
+msgstr "Le distanze tra tutti i punti sono oltre %e (4 * deviazione standard), impossibile calcolare il valore ottimale."
 #: ../vector/v.kernel/main.c:359
 #, c-format
@@ -22995,8 +21860,7 @@
 "Writing output vector map using smooth parameter=%f."
 msgstr ""
 "\n"
-"Sto scrivendo il file vettoriale in output usando il parametro di smoothing="
-"%f."
+"Sto scrivendo il file vettoriale in output usando il parametro di smoothing=%f."
 #: ../vector/v.kernel/main.c:388 ../vector/v.kernel/main.c:495
 #, c-format
@@ -23073,9 +21937,7 @@
 msgstr "Opzionalmente cambia il tipo di input predefinito"
 #: ../vector/v.in.ogr/main.c:180
-msgid ""
-"point;import area centroids as points;line;import area boundaries as lines;"
-"boundary;import lines as area boundaries;centroid;import points as centroids"
+msgid "point;import area centroids as points;line;import area boundaries as lines;boundary;import lines as area boundaries;centroid;import points as centroids"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:191
@@ -23087,9 +21949,7 @@
 msgstr ""
 #: ../vector/v.in.ogr/main.c:207
-msgid ""
-"List of column names to be used instead of original names, first is used for "
-"category column"
+msgid "List of column names to be used instead of original names, first is used for category column"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:213 ../vector/v.external/args.c:47
@@ -23099,8 +21959,7 @@
 #: ../vector/v.in.ogr/main.c:219
 #, fuzzy
-msgid ""
-"List available OGR layers including feature types in data source and exit"
+msgid "List available OGR layers including feature types in data source and exit"
 msgstr "Visualizza i formati supportati ed esci"
 #: ../vector/v.in.ogr/main.c:233
@@ -23116,9 +21975,7 @@
 msgstr ""
 #: ../vector/v.in.ogr/main.c:272
-msgid ""
-"Create the location specified by the \"location\" parameter and exit. Do not "
-"import the vector data."
+msgid "Create the location specified by the \"location\" parameter and exit. Do not import the vector data."
 msgstr ""
 #: ../vector/v.in.ogr/main.c:291
@@ -23148,8 +22005,7 @@
 #: ../vector/v.in.ogr/main.c:399
 #, fuzzy, c-format
 msgid "All available OGR layers will be imported into vector map <%s>"
-msgstr ""
 #: ../vector/v.in.ogr/main.c:404 ../vector/v.edit/main.c:92
 #: ../vector/v.in.lidar/main.c:478
@@ -23192,9 +22048,7 @@
 #: ../vector/v.in.ogr/main.c:825
 #, c-format
-msgid ""
-"Width for column %s set to 255 (was not specified by OGR), some strings may "
-"be truncated!"
+msgid "Width for column %s set to 255 (was not specified by OGR), some strings may be truncated!"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:837
@@ -23220,7 +22074,7 @@
 #: ../vector/v.in.ogr/main.c:984
 #, c-format
 msgid "%d %s without geometry"
-msgstr ""
+msgstr "%d %s senza geometria"
 #: ../vector/v.in.ogr/main.c:1012
 msgid "Cleaning polygons, result is not guaranteed!"
@@ -23277,10 +22131,7 @@
 #: ../vector/v.in.ogr/main.c:1181
 #, c-format
-msgid ""
-"%d areas represent more (overlapping) features, because polygons overlap in "
-"input layer(s). Such areas are linked to more than 1 row in attribute table. "
-"The number of features for those areas is stored as category in layer %d"
+msgid "%d areas represent more (overlapping) features, because polygons overlap in input layer(s). Such areas are linked to more than 1 row in attribute table. The number of features for those areas is stored as category in layer %d"
 msgstr ""
 #: ../vector/v.in.ogr/main.c:1191
@@ -23324,9 +22175,7 @@
 msgstr "Aree senza categoria: %G (%d aree)"
 #: ../vector/v.in.ogr/main.c:1264
-msgid ""
-"Input data contains 3D features. Created vector is 2D only, use -z flag to "
-"import 3D vector."
+msgid "Input data contains 3D features. Created vector is 2D only, use -z flag to import 3D vector."
 msgstr ""
 #: ../vector/v.in.ogr/geom.c:195 ../vector/v.in.ogr/geom.c:216
@@ -23400,13 +22249,7 @@
 msgstr "Operazione da eseguire"
 #: ../vector/v.net/args.c:36
-msgid ""
-"nodes;new point is placed on each node (line end) if doesn't exist;connect;"
-"connect still unconnected points to vector network by inserting new line(s);"
-"arcs;new line is created from start point to end point;report;print to "
-"standard output {line_category start_point_category end_point_category};"
-"nreport;print to standard output {point_category line_category[,"
-"line_category...]}"
+msgid "nodes;new point is placed on each node (line end) if doesn't exist;connect;connect still unconnected points to vector network by inserting new line(s);arcs;new line is created from start point to end point;report;print to standard output {line_category start_point_category end_point_category};nreport;print to standard output {point_category line_category[,line_category...]}"
 msgstr ""
 #: ../vector/v.net/args.c:72
@@ -23593,9 +22436,7 @@
 #: ../vector/v.label/main.c:78 ../vector/v.label.sa/main.c:57
 msgid "Name of attribute column to be used for labels"
-msgstr ""
-"etichette"
 #: ../vector/v.label/main.c:89
 msgid "Rotate labels to align with lines"
@@ -23636,18 +22477,15 @@
 #: ../vector/v.label/main.c:137
 msgid "Space between letters for curled labels (in map-units)"
-msgstr ""
-"Spazio tra le lettere per le etichette disposte lungo la linea (in unità "
-"della mappa)"
+msgstr "Spazio tra le lettere per le etichette disposte lungo la linea (in unità della mappa)"
 #: ../vector/v.label/main.c:144
 msgid "Label size (in points)"
 msgstr "Dimensione delle etichette (in punti)"
 #: ../vector/v.label/main.c:156
-#, fuzzy
 msgid "Rotation angle (degrees counter-clockwise)"
-msgstr "Angolo di rotazione (in gradi antiorari da est)"
+msgstr "Angolo di rotazione (in gradi antiorari)"
 #: ../vector/v.label/main.c:166
 msgid "Border width"
@@ -23667,11 +22505,8 @@
 msgstr "Opaco ai vettori (rilevante solo se si sceglie un colore di sfondo)"
 #: ../vector/v.label/main.c:251
-msgid ""
-"size and space options vary significantly which may lead to crummy output"
-msgstr ""
-"Dimensione e spaziatura variano significativamente e possono fornire un "
-"output insoddisfacente!"
+msgid "size and space options vary significantly which may lead to crummy output"
+msgstr "Dimensione e spaziatura variano significativamente e possono fornire un output insoddisfacente!"
 #: ../vector/v.label/main.c:259
 msgid "Too many parameters for <reference>"
@@ -23697,20 +22532,16 @@
 #: ../vector/v.univar/main.c:67
 #, fuzzy
-msgid ""
-"Variance and standard deviation is calculated only for points if specified."
+msgid "Variance and standard deviation is calculated only for points if specified."
 msgstr "Varianza"
 #: ../vector/v.univar/main.c:122
-msgid ""
-"Incompatible vector type(s) specified, only number of features, minimum, "
-"maximum and range can be calculated"
+msgid "Incompatible vector type(s) specified, only number of features, minimum, maximum and range can be calculated"
 msgstr ""
 #: ../vector/v.univar/main.c:127
 msgid "Extended statistics is currently supported only for points/centroids"
-msgstr ""
-"Le statistiche estese attualmente sono supportate solo per punti/centroidi"
+msgstr "Le statistiche estese attualmente sono supportate solo per punti/centroidi"
 #: ../vector/v.univar/main.c:134
 #, fuzzy, c-format
@@ -23735,15 +22566,11 @@
 msgstr ""
 #: ../vector/v.net.distance/main.c:64
-msgid ""
-"Computes shortest distance via the network between the given sets of "
-"features."
+msgid "Computes shortest distance via the network between the given sets of features."
 msgstr ""
 #: ../vector/v.net.distance/main.c:67
-msgid ""
-"Finds the shortest paths from a feature 'to' to every feature 'from' and "
-"various information about this relation are uploaded to the attribute table."
+msgid "Finds the shortest paths from a feature 'to' to every feature 'from' and various information about this relation are uploaded to the attribute table."
 msgstr ""
 #: ../vector/v.net.distance/main.c:88
@@ -23787,12 +22614,8 @@
 msgstr ""
 #: ../vector/v.lrs/v.lrs.segment/main.c:74
-msgid ""
-"Creates points/segments from input lines, linear reference system and "
-"positions read from stdin or a file."
-msgstr ""
-"Crea punti/segmenti da linee, il sistema di riferimento lineare e i punti "
-"sono letti dallo stdin o da file"
+msgid "Creates points/segments from input lines, linear reference system and positions read from stdin or a file."
+msgstr "Crea punti/segmenti da linee, il sistema di riferimento lineare e i punti sono letti dallo stdin o da file"
 #: ../vector/v.lrs/v.lrs.segment/main.c:78
 #: ../vector/v.lrs/v.lrs.where/main.c:66
@@ -23957,9 +22780,7 @@
 msgstr "Scritte [%d] linee sulla mappa di output (%d perse)"
 #: ../vector/v.lrs/v.lrs.where/main.c:61
-msgid ""
-"Finds line id and real km+offset for given points in vector map using linear "
-"reference system."
+msgid "Finds line id and real km+offset for given points in vector map using linear reference system."
 msgstr ""
 #: ../vector/v.lrs/v.lrs.where/main.c:70
@@ -24001,8 +22822,7 @@
 #: ../vector/v.lrs/v.lrs.create/main.c:133
 msgid "Output vector map where oriented lines are written"
-msgstr ""
-"Nome della mappa vettoriale di output dove sono scritte le linee orientate"
+msgstr "Nome della mappa vettoriale di output dove sono scritte le linee orientate"
 #: ../vector/v.lrs/v.lrs.create/main.c:138
 msgid "Output vector map of errors"
@@ -24025,8 +22845,7 @@
 msgstr ""
 #: ../vector/v.lrs/v.lrs.create/main.c:182
-msgid ""
-"Column containing offset from milepost for the beginning of next segment"
+msgid "Column containing offset from milepost for the beginning of next segment"
 msgstr ""
 #: ../vector/v.lrs/v.lrs.create/main.c:191
@@ -24152,13 +22971,11 @@
 #: ../vector/v.lrs/v.lrs.create/main.c:864
 msgid "Building topology for output (out_lines) map..."
-msgstr ""
-"Costruzione della topologia per la mappa di output (out_lines) in corso..."
+msgstr "Costruzione della topologia per la mappa di output (out_lines) in corso..."
 #: ../vector/v.lrs/v.lrs.create/main.c:870
 msgid "Building topology for error (err) map..."
-msgstr ""
-"Costruzione della topologia per la mappa degli errori (err) in corso..."
+msgstr "Costruzione della topologia per la mappa degli errori (err) in corso..."
 #: ../vector/v.lrs/v.lrs.label/main.c:105
 msgid "Create stationing from input lines, and linear reference system"
@@ -24178,13 +22995,11 @@
 #: ../vector/v.lrs/v.lrs.label/main.c:161
 msgid "Offset label in label x-direction in map units"
-msgstr ""
-"Offset delle etichette nella direzione x dell'etichetta in unità di mappa"
+msgstr "Offset delle etichette nella direzione x dell'etichetta in unità di mappa"
 #: ../vector/v.lrs/v.lrs.label/main.c:168
 msgid "Offset label in label y-direction in map units"
-msgstr ""
-"Offset delle etichette nella direzione y dell'etichetta in unità di mappa"
+msgstr "Offset delle etichette nella direzione y dell'etichetta in unità di mappa"
 #: ../vector/v.lrs/v.lrs.label/main.c:203
 msgid "Line width of text"
@@ -24238,9 +23053,7 @@
 msgstr ""
 #: ../vector/v.out.ascii/args.c:52
-msgid ""
-"point;Simple point format (point per row);standard;GRASS ASCII vector format;"
-"wkt;OGC well-known text;"
+msgid "point;Simple point format (point per row);standard;GRASS ASCII vector format;wkt;OGC well-known text;"
 msgstr ""
 #: ../vector/v.out.ascii/args.c:57
@@ -24271,9 +23084,7 @@
 #: ../vector/v.out.ascii/main.c:49
 #, fuzzy
 msgid "Exports a vector map to a GRASS ASCII vector representation."
-msgstr ""
-"Converte una mappa vettoriale binaria di GRASS in una mappa vettoriale ASCII "
-"di GRASS"
+msgstr "Converte una mappa vettoriale binaria di GRASS in una mappa vettoriale ASCII di GRASS"
 #: ../vector/v.out.ascii/main.c:56
 #, fuzzy
@@ -24290,9 +23101,7 @@
 #: ../vector/v.out.ascii/main.c:76
 #, fuzzy, c-format
-msgid ""
-"Unable to open vector map <%s> at topology level. Areas will not be "
-"processed."
+msgid "Unable to open vector map <%s> at topology level. Areas will not be processed."
 msgstr "impossibile aprire <%s>"
 #: ../vector/v.out.ascii/main.c:116
@@ -24340,9 +23149,7 @@
 msgstr ""
 #: ../vector/v.parallel/main.c:91
-msgid ""
-"left;Parallel line is on the left;right;Parallel line is on the right;both;"
-"Parallel lines on both sides"
+msgid "left;Parallel line is on the left;right;Parallel line is on the right;both;Parallel lines on both sides"
 msgstr ""
 #: ../vector/v.parallel/main.c:101
@@ -24398,8 +23205,7 @@
 msgstr ""
 #: ../vector/v.support/main.c:118
-msgid ""
-"Command line to store into vector map history file (used for vector scripts)"
+msgid "Command line to store into vector map history file (used for vector scripts)"
 msgstr ""
 #: ../vector/v.support/main.c:122
@@ -24409,8 +23215,7 @@
 #: ../vector/v.support/main.c:183
 #, c-format
 msgid "Unable to open history file for vector map <%s>"
-msgstr ""
-"Non è possibile aprire il file della cronologia per la mappa vettoriale <%s>"
+msgstr "Non è possibile aprire il file della cronologia per la mappa vettoriale <%s>"
 #: ../vector/v.outlier/main.c:70
 msgid "Removes outliers from vector point data."
@@ -24423,9 +23228,7 @@
 #: ../vector/v.outlier/main.c:76 ../vector/v.lidar.edgedetection/main.c:82
 #: ../vector/v.lidar.correction/main.c:77 ../vector/v.surf.bspline/main.c:107
-msgid ""
-"Estimate point density and distance for the input vector points within the "
-"current region extends and quit"
+msgid "Estimate point density and distance for the input vector points within the current region extends and quit"
 msgstr ""
 #: ../vector/v.outlier/main.c:88
@@ -24456,13 +23259,11 @@
 #: ../vector/v.outlier/main.c:135 ../vector/v.lidar.edgedetection/main.c:169
 #: ../vector/v.lidar.correction/main.c:148 ../vector/v.surf.bspline/main.c:223
-#, fuzzy
 msgid "Unable to read name of database"
 msgstr "Non è possibile leggere il nome del database"
 #: ../vector/v.outlier/main.c:138 ../vector/v.lidar.edgedetection/main.c:172
 #: ../vector/v.lidar.correction/main.c:151 ../vector/v.surf.bspline/main.c:226
-#, fuzzy
 msgid "Unable to read name of driver"
 msgstr "Non è possibile leggere il nome del driver"
@@ -24473,11 +23274,9 @@
 #: ../vector/v.lidar.correction/main.c:165
 #: ../vector/v.lidar.correction/main.c:225 ../vector/v.surf.bspline/main.c:242
 #: ../vector/v.surf.bspline/main.c:398 ../vector/v.lidar.growing/main.c:163
-#, fuzzy, c-format
+#, c-format
 msgid "No database connection for driver <%s> is defined. Run db.connect."
-msgstr ""
-"Non è stata definita nessuna connessione al database per il driver <%s>. "
-"Eseguire db.connect."
+msgstr "Non è stata definita nessuna connessione al database per il driver <%s>. Eseguire db.connect."
 #: ../vector/v.outlier/main.c:170 ../vector/v.lidar.edgedetection/main.c:192
 #: ../vector/v.lidar.edgedetection/main.c:204
@@ -24487,24 +23286,23 @@
 #: ../vector/v.outlier/main.c:177 ../vector/v.surf.bspline/main.c:255
 #: ../vector/v.surf.bspline/main.c:315
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open vector map <%s> at the topological level"
 msgstr "Non è possibile  aprire la mappa vettoriale <%s> al livello topologico"
 #: ../vector/v.outlier/main.c:182 ../vector/v.lidar.edgedetection/main.c:223
 #: ../vector/v.lidar.correction/main.c:186
-#, fuzzy, c-format
+#, c-format
 msgid "Input vector map <%s> is not 3D!"
 msgstr "La mappa vettoriale di input <%s> non è 3D!"
 #: ../vector/v.outlier/main.c:192 ../vector/v.lidar.edgedetection/main.c:233
 #: ../vector/v.lidar.correction/main.c:196 ../vector/v.surf.bspline/main.c:279
-#, fuzzy
 msgid "No points in current region!"
 msgstr "Nessun punto nella regione corrente!"
 #: ../vector/v.outlier/main.c:239
-#, fuzzy, c-format
+#, c-format
 msgid "It was impossible to create <%s> table."
 msgstr "Non è stato possibile creare la tabella <%s>."
@@ -24573,9 +23371,7 @@
 msgstr ""
 #: ../vector/v.build/main.c:62
-msgid ""
-"build;build topology;dump;write topology to stdout;sdump;write spatial index "
-"to stdout;cdump;write category index to stdout"
+msgid "build;build topology;dump;write topology to stdout;sdump;write spatial index to stdout;cdump;write category index to stdout"
 msgstr ""
 #: ../vector/v.build/main.c:68
@@ -24588,9 +23384,7 @@
 #: ../vector/v.build/main.c:96
 #, c-format
-msgid ""
-"Direct read access to OGR layers is not supported by this module. Run %s to "
-"create a link as GRASS vector map in the current mapset."
+msgid "Direct read access to OGR layers is not supported by this module. Run %s to create a link as GRASS vector map in the current mapset."
 msgstr ""
 #: ../vector/v.build/main.c:101
@@ -24741,9 +23535,7 @@
 msgstr ""
 #: ../vector/v.edit/args.c:157
-msgid ""
-"length;Select only lines or boundaries shorter/longer than threshold "
-"distance;dangle;Select dangles shorter/longer than threshold distance"
+msgid "length;Select only lines or boundaries shorter/longer than threshold distance;dangle;Select dangles shorter/longer than threshold distance"
 msgstr ""
 #: ../vector/v.edit/args.c:165
@@ -24751,15 +23543,11 @@
 msgstr "Nome della mappa/e vettoriale di sfondo"
 #: ../vector/v.edit/args.c:172
-msgid ""
-"Snap added or modified features in the given threshold to the nearest "
-"existing feature"
+msgid "Snap added or modified features in the given threshold to the nearest existing feature"
 msgstr ""
 #: ../vector/v.edit/args.c:174
-msgid ""
-"no;Not apply snapping;node;Snap only to node;vertex;Allow snapping also to "
-"vertex"
+msgid "no;Not apply snapping;node;Snap only to node;vertex;Allow snapping also to vertex"
 msgstr ""
 #: ../vector/v.edit/args.c:182
@@ -24819,12 +23607,8 @@
 msgstr "Esistente"
 #: ../vector/v.edit/main.c:58
-msgid ""
-"Edits a vector map, allows adding, deleting and modifying selected vector "
-"features."
-msgstr ""
-"Modifica un vettore, permette aggiunte, eliminzione e modifica degli "
-"elementi del vettore selezionato"
+msgid "Edits a vector map, allows adding, deleting and modifying selected vector features."
+msgstr "Modifica un vettore, permette aggiunte, eliminzione e modifica degli elementi del vettore selezionato"
 #: ../vector/v.edit/main.c:67
 #, c-format
@@ -24843,9 +23627,7 @@
 #: ../vector/v.edit/main.c:145
 #, c-format
-msgid ""
-"Unable to open vector map <%s> as the background map. It is given as vector "
-"map to be edited."
+msgid "Unable to open vector map <%s> as the background map. It is given as vector map to be edited."
 msgstr ""
 #: ../vector/v.edit/main.c:156
@@ -24867,9 +23649,7 @@
 #: ../vector/v.edit/main.c:219
 #, c-format
-msgid ""
-"Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. Please convert "
-"the vector map to 3D using e.g. %s."
+msgid "Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. Please convert the vector map to 3D using e.g. %s."
 msgstr ""
 #: ../vector/v.edit/main.c:255
@@ -24936,9 +23716,7 @@
 #: ../vector/v.edit/main.c:345
 #, c-format
-msgid ""
-"Multiple background maps were given. Selected features will be copied only "
-"from vector map <%s>."
+msgid "Multiple background maps were given. Selected features will be copied only from vector map <%s>."
 msgstr ""
 #: ../vector/v.edit/main.c:355
@@ -25054,7 +23832,7 @@
 #: ../vector/v.in.dwg/main.c:287
 #, c-format
 msgid "%d elements processed"
-msgstr ""
+msgstr "%d elementi elaborati"
 #: ../vector/v.mapcalc/map.c:67
 #, c-format
@@ -25134,21 +23912,13 @@
 #: ../vector/v.net.alloc/main.c:66
 #, fuzzy
-msgid ""
-"center node must be opened (costs >= 0). Costs of center node are used in "
-"calculation"
-msgstr ""
-"Il nodo definito come centro dev'essere aperto (costi >= 0). I costi del "
-"nodo centrale vengono utilizzati nel calcolo"
+msgid "center node must be opened (costs >= 0). Costs of center node are used in calculation"
+msgstr "Il nodo definito come centro dev'essere aperto (costi >= 0). I costi del nodo centrale vengono utilizzati nel calcolo"
 #: ../vector/v.net.alloc/main.c:111
 #, fuzzy
-msgid ""
-"Categories of centers (points on nodes) to which net will be allocated, "
-"layer for this categories is given by nlayer option"
-msgstr ""
-"Categorie dei centri (punti o nodi) ai quali dev'essere assegnata la rete, "
-"il layer per queste categorie è dato dall'opzione nlayer"
+msgid "Categories of centers (points on nodes) to which net will be allocated, layer for this categories is given by nlayer option"
+msgstr "Categorie dei centri (punti o nodi) ai quali dev'essere assegnata la rete, il layer per queste categorie è dato dall'opzione nlayer"
 #: ../vector/v.net.alloc/main.c:189
 #, fuzzy, c-format
@@ -25194,8 +23964,7 @@
 #: ../vector/v.kcv/main.c:159
 #, c-format
 msgid "Unable to get layer info for vector map <%s>"
-msgstr ""
 #: ../vector/v.kcv/main.c:183
 #, fuzzy, c-format
@@ -25219,9 +23988,7 @@
 #: ../vector/v.extract/extract.c:225
 #, fuzzy
-msgid ""
-"Topology level required for extracting areas for OGR layers. Areas will be "
-"not processed."
+msgid "Topology level required for extracting areas for OGR layers. Areas will be not processed."
 msgstr "Calcolo dei centroidi per le aree in corso..."
 #: ../vector/v.extract/copy_tab.c:86
@@ -25250,12 +24017,8 @@
 #: ../vector/v.extract/main.c:81
 #, fuzzy
-msgid ""
-"Selects vector features from an existing vector map and creates a new vector "
-"map containing only the selected features."
-msgstr ""
-"Seleziona oggetti vettoriali da una mappa esistente e crea una nuova mappa "
-"contenento solo gli oggetti selezionati."
+msgid "Selects vector features from an existing vector map and creates a new vector map containing only the selected features."
+msgstr "Seleziona oggetti vettoriali da una mappa esistente e crea una nuova mappa contenento solo gli oggetti selezionati."
 #: ../vector/v.extract/main.c:86
 msgid "Dissolve common boundaries (default is no)"
@@ -25295,9 +24058,7 @@
 #: ../vector/v.extract/main.c:159
 #, fuzzy, c-format
-msgid ""
-"Options <%s>, <%s>, <%s> and <%s> options are exclusive. Please specify only "
-"one of them."
+msgid "Options <%s>, <%s>, <%s> and <%s> options are exclusive. Please specify only one of them."
 msgstr "I flag -g e -a sono mutualmente esclusivi"
 #: ../vector/v.extract/main.c:204
@@ -25336,9 +24097,7 @@
 msgstr "%d categrie caricate dalla tabella"
 #: ../vector/v.extract/main.c:280
-msgid ""
-"This map has no categories attached. Use v.category to attach categories to "
-"this vector map."
+msgid "This map has no categories attached. Use v.category to attach categories to this vector map."
 msgstr ""
 #: ../vector/v.extract/main.c:287
@@ -25347,22 +24106,16 @@
 #: ../vector/v.extract/main.c:291
 #, c-format
-msgid ""
-"Random category count must be smaller than feature count. There are only %d "
-"features of type(s): %s"
+msgid "Random category count must be smaller than feature count. There are only %d features of type(s): %s"
 msgstr ""
 #: ../vector/v.extract/main.c:314
 #, c-format
-msgid ""
-"Random category count is larger or equal to uniq <%s> feature category count "
-"%d"
+msgid "Random category count is larger or equal to uniq <%s> feature category count %d"
 msgstr ""
 #: ../vector/v.extract/main.c:319
-msgid ""
-"There are more categories than random number generator can reach. Report "
-"this as a GRASS bug."
+msgid "There are more categories than random number generator can reach. Report this as a GRASS bug."
 msgstr ""
 #: ../vector/v.extract/main.c:350
@@ -25429,9 +24182,7 @@
 #: ../vector/v.db.connect/main.c:55
 msgid "Prints/sets DB connection for a vector map to attribute table."
-msgstr ""
-"Visualizza/imposta la connessione per una mappa vettoriale alla tabella "
-"degli attributi"
+msgstr "Visualizza/imposta la connessione per una mappa vettoriale alla tabella degli attributi"
 #: ../vector/v.db.connect/main.c:77
 msgid "Format: layer number[/layer name]"
@@ -25444,8 +24195,7 @@
 #: ../vector/v.db.connect/main.c:86
 msgid "Print all map connection parameters and exit"
-msgstr ""
-"Stampa tutti i parametri di connessione al database della mappa ed esce"
+msgstr "Stampa tutti i parametri di connessione al database della mappa ed esce"
 #: ../vector/v.db.connect/main.c:91
 #, fuzzy
@@ -25458,8 +24208,7 @@
 #: ../vector/v.db.connect/main.c:99
 msgid "Print types/names of table columns for specified layer and exit"
-msgstr ""
-"Stampa i tipi/nomi delle colonne della tabella del layer selezionato ed esce"
+msgstr "Stampa i tipi/nomi delle colonne della tabella del layer selezionato ed esce"
 #: ../vector/v.db.connect/main.c:106
 msgid "Overwrite connection parameter for certain layer"
@@ -25467,8 +24216,7 @@
 #: ../vector/v.db.connect/main.c:111
 msgid "Delete connection for certain layer (not the table)"
-msgstr ""
-"Cancella la connessione al database di alcuni layer (ma non la tabella)"
+msgstr "Cancella la connessione al database di alcuni layer (ma non la tabella)"
 #: ../vector/v.db.connect/main.c:145
 msgid "Please choose only one print style"
@@ -25476,8 +24224,7 @@
 #: ../vector/v.db.connect/main.c:153
 msgid "Unable to modify vector map stored in other mapset"
-msgstr ""
-"Impossibile modificare la mappa vettoriale che si trova in un altro mapset"
+msgstr "Impossibile modificare la mappa vettoriale che si trova in un altro mapset"
 #: ../vector/v.db.connect/main.c:161
 #, fuzzy, c-format
@@ -25491,14 +24238,12 @@
 #: ../vector/v.db.connect/main.c:195
 #, c-format
-msgid ""
-"layer <%d/%s> table <%s> in database <%s> through driver <%s> with key <%s>\n"
+msgid "layer <%d/%s> table <%s> in database <%s> through driver <%s> with key <%s>\n"
 msgstr ""
 #: ../vector/v.db.connect/main.c:201
 #, c-format
-msgid ""
-"layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
+msgid "layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
 msgstr ""
 #: ../vector/v.db.connect/main.c:264
@@ -25524,12 +24269,8 @@
 #: ../vector/v.db.connect/main.c:300 ../vector/v.db.connect/main.c:318
 #, c-format
-msgid ""
-"The table <%s> is now part of vector map <%s> and may be deleted or "
-"overwritten by GRASS modules"
-msgstr ""
-"La tabella <%s> è ora parte del vettoriale <%s> e può essere cancellata o "
-"sovrascritta dai moduli GRASS"
+msgid "The table <%s> is now part of vector map <%s> and may be deleted or overwritten by GRASS modules"
+msgstr "La tabella <%s> è ora parte del vettoriale <%s> e può essere cancellata o sovrascritta dai moduli GRASS"
 #: ../vector/v.db.connect/main.c:339
 #, c-format
@@ -25541,12 +24282,8 @@
 msgstr "Permessi selezionati concessi alla tabella"
 #: ../vector/v.db.connect/main.c:349
-msgid ""
-"For defining a new connection you have to specify these parameters: driver, "
-"database, table [, key [, layer]]"
-msgstr ""
-"Per definire una nuova connessione, devi specificare i seguenti parametri: "
-"driver, database, tabella [, chiave [, layer]]"
+msgid "For defining a new connection you have to specify these parameters: driver, database, table [, key [, layer]]"
+msgstr "Per definire una nuova connessione, devi specificare i seguenti parametri: driver, database, tabella [, chiave [, layer]]"
 #: ../vector/v.in.ascii/main.c:51
 #, fuzzy
@@ -25580,9 +24317,7 @@
 msgstr ""
 #: ../vector/v.in.ascii/main.c:92
-msgid ""
-"For example: 'x double precision, y double precision, cat int, name varchar"
-"(10)'"
+msgid "For example: 'x double precision, y double precision, cat int, name varchar(10)'"
 msgstr ""
 #: ../vector/v.in.ascii/main.c:104 ../vector/v.in.ascii/main.c:114
@@ -25609,9 +24344,7 @@
 msgstr "Nome della colonna usata come categoria (points mode)"
 #: ../vector/v.in.ascii/main.c:136
-msgid ""
-"First column is 1. If 0, unique category is assigned to each row and written "
-"to new column 'cat'"
+msgid "First column is 1. If 0, unique category is assigned to each row and written to new column 'cat'"
 msgstr ""
 #: ../vector/v.in.ascii/main.c:145
@@ -25679,13 +24412,11 @@
 msgstr ""
 #: ../vector/v.in.ascii/main.c:270
-msgid ""
-"z column number > minimum last column number (incorrect field separator?)"
+msgid "z column number > minimum last column number (incorrect field separator?)"
 msgstr ""
 #: ../vector/v.in.ascii/main.c:275
-msgid ""
-"cat column number > minimum last column number (incorrect field separator?)"
+msgid "cat column number > minimum last column number (incorrect field separator?)"
 msgstr ""
 #: ../vector/v.in.ascii/main.c:281
@@ -25710,8 +24441,7 @@
 #: ../vector/v.in.ascii/main.c:416
 #, c-format
-msgid ""
-"Number of columns defined (%d) does not match number of columns (%d) in input"
+msgid "Number of columns defined (%d) does not match number of columns (%d) in input"
 msgstr ""
 #: ../vector/v.in.ascii/main.c:444
@@ -25754,9 +24484,7 @@
 msgstr ""
 #: ../vector/v.in.ascii/main.c:528
-msgid ""
-"Could not close attribute table. The DBMI driver did not accept all "
-"attributes"
+msgid "Could not close attribute table. The DBMI driver did not accept all attributes"
 msgstr ""
 #: ../vector/v.in.ascii/points.c:83
@@ -25791,9 +24519,7 @@
 #: ../vector/v.colors/make_colors.c:14
 #, fuzzy, c-format
 msgid "Color table '%s' is not supported for floating point attributes"
-msgstr ""
-"La tavola dei colori 'random' non è supportata dai raster con valori a "
-"virgola mobile"
+msgstr "La tavola dei colori 'random' non è supportata dai raster con valori a virgola mobile"
 #: ../vector/v.colors/make_colors.c:18 ../vector/v.colors/make_colors.c:25
 #, fuzzy, c-format
@@ -25903,9 +24629,7 @@
 #: ../vector/v.colors/main.c:179
 #, fuzzy, c-format
 msgid "One of -%c, -%c or options <%s>, <%s> or <%s> must be specified"
-msgstr ""
-"Dev'essere specificato \"-i\" o \"-r\", o le opzioni \"color\", \"rast\" o "
-"\"rules\"!"
+msgstr "Dev'essere specificato \"-i\" o \"-r\", o le opzioni \"color\", \"rast\" o \"rules\"!"
 #: ../vector/v.colors/main.c:193
 #, fuzzy, c-format
@@ -26013,12 +24737,8 @@
 msgstr "Mappa raster risultante"
 #: ../vector/v.distance/main.c:87
-msgid ""
-"Finds the nearest element in vector map 'to' for elements in vector map "
-"'from'."
-msgstr ""
-"Trova l'elemento più vicino nel vettoriale 'to' per gli elementi nel "
-"vettoriale 'from'."
+msgid "Finds the nearest element in vector map 'to' for elements in vector map 'from'."
+msgstr "Trova l'elemento più vicino nel vettoriale 'to' per gli elementi nel vettoriale 'from'."
 #: ../vector/v.distance/main.c:91
 msgid "Name of existing vector map (from)"
@@ -26048,9 +24768,7 @@
 #: ../vector/v.distance/main.c:126
 msgid "Name for output vector map containing lines connecting nearest elements"
-msgstr ""
-"Nome di una mappa vettoriale di output contenente le linee che collegano gli "
-"elementi più vicini"
+msgstr "Nome di una mappa vettoriale di output contenente le linee che collegano gli elementi più vicini"
 #: ../vector/v.distance/main.c:134
 msgid "Maximum distance or -1 for no limit"
@@ -26065,19 +24783,11 @@
 msgstr ""
 #: ../vector/v.distance/main.c:152
-msgid ""
-"cat;category of the nearest feature;dist;minimum distance to nearest feature;"
-"to_x;x coordinate of the nearest point on the 'to' feature;to_y;y coordinate "
-"of the nearest point on the 'to' feature;to_along;distance to the nearest "
-"point on the 'to' feature along that linear feature;to_angle;angle along the "
-"nearest linear feature in the 'to' map, measured CCW from the +x axis, in "
-"radians, between -Pi and Pi inclusive;to_attr;attribute of nearest feature "
-"given by to_column option"
+msgid "cat;category of the nearest feature;dist;minimum distance to nearest feature;to_x;x coordinate of the nearest point on the 'to' feature;to_y;y coordinate of the nearest point on the 'to' feature;to_along;distance to the nearest point on the 'to' feature along that linear feature;to_angle;angle along the nearest linear feature in the 'to' map, measured CCW from the +x axis, in radians, between -Pi and Pi inclusive;to_attr;attribute of nearest feature given by to_column option"
 msgstr ""
 #: ../vector/v.distance/main.c:173
-msgid ""
-"Column name(s) where values specified by 'upload' option will be uploaded"
+msgid "Column name(s) where values specified by 'upload' option will be uploaded"
 msgstr ""
 #: ../vector/v.distance/main.c:174
@@ -26105,9 +24815,7 @@
 msgstr ""
 #: ../vector/v.distance/main.c:199
-msgid ""
-"Output is written to stdout but may be uploaded to a new table created by "
-"this module; multiple 'upload' options may be used."
+msgid "Output is written to stdout but may be uploaded to a new table created by this module; multiple 'upload' options may be used."
 msgstr ""
 #: ../vector/v.distance/main.c:254
@@ -26213,9 +24921,7 @@
 #: ../vector/v.to.db/update.c:28 ../vector/v.to.db/update.c:32
 #, c-format
 msgid "Database connection not defined for layer %d. Use v.db.connect first."
-msgstr ""
-"Connessione al database non definita per il layer %d. Usare prima v.db."
-"connect"
+msgstr "Connessione al database non definita per il layer %d. Usare prima v.db.connect"
 #: ../vector/v.to.db/query.c:93
 msgid "Querying database... "
@@ -26223,9 +24929,7 @@
 #: ../vector/v.to.db/query.c:108
 #, c-format
-msgid ""
-"Query for category '0' (no category) was not executed because of too many "
-"(%d) query categories. All later reported values for cat 0 are not valid."
+msgid "Query for category '0' (no category) was not executed because of too many (%d) query categories. All later reported values for cat 0 are not valid."
 msgstr ""
 #: ../vector/v.to.db/query.c:145
@@ -26272,8 +24976,7 @@
 #: ../vector/v.to.db/parse.c:41
 msgid "For coor valid point/centroid, for length valid line/boundary"
-msgstr ""
-"Per coor sono validi point/centroid, per length sono validi line/boundary"
+msgstr "Per coor sono validi point/centroid, per length sono validi line/boundary"
 #: ../vector/v.to.db/parse.c:46
 #, fuzzy
@@ -26356,9 +25059,7 @@
 #: ../vector/v.to.db/report.c:197
 #, c-format
 msgid "%d categories read from vector map don't exist in selection from table"
-msgstr ""
-"%d categorie lette dalla mappa vettoriale mancano nella selezione dalla "
-"tabella"
+msgstr "%d categorie lette dalla mappa vettoriale mancano nella selezione dalla tabella"
 #: ../vector/v.to.db/report.c:199
 #, c-format
@@ -26470,19 +25171,16 @@
 msgstr ""
 #: ../vector/v.build.polylines/main.c:126
-msgid ""
-"no;Do not assign any category number to polyline;first;Assign category "
-"number of first line to polyline;multi;Assign multiple category numbers to "
-"polyline"
+msgid "no;Do not assign any category number to polyline;first;Assign category number of first line to polyline;multi;Assign multiple category numbers to polyline"
 msgstr ""
 #: ../vector/v.build.polylines/main.c:217
-#, fuzzy, c-format
+#, c-format
 msgid "%d lines or boundaries found in vector map <%s@%s>"
 msgstr "%d linee o confini trovati nella mappa vettoriale  <%s@%s>"
 #: ../vector/v.build.polylines/main.c:219
-#, fuzzy, c-format
+#, c-format
 msgid "%d polylines stored in vector map <%s@%s>"
 msgstr "%d polilinee memorizzate nella mappa vettoriale <%s@%s>"
@@ -26496,12 +25194,8 @@
 msgstr "Sto disegnando ..."
 #: ../vector/v.delaunay/main.c:88
-msgid ""
-"Creates a Delaunay triangulation from an input vector map containing points "
-"or centroids."
-msgstr ""
-"Crea una triangolazione Delaunay da un vettoriale contenente punti o "
-"centroidi."
+msgid "Creates a Delaunay triangulation from an input vector map containing points or centroids."
+msgstr "Crea una triangolazione Delaunay da un vettoriale contenente punti o centroidi."
 #: ../vector/v.delaunay/main.c:98 ../vector/v.normal/main.c:97
 msgid "Use only points in current region"
@@ -26545,9 +25239,7 @@
 #: ../vector/v.qcount/main.c:71
 #, fuzzy
-msgid ""
-"Name for output quadrant centres map (number of points is written as "
-"category)"
+msgid "Name for output quadrant centres map (number of points is written as category)"
 msgstr "Nome di un file vettoriale in output"
 #: ../vector/v.qcount/main.c:77
@@ -26558,8 +25250,8 @@
 msgid "Quadrat radius"
 msgstr ""
+# per la shell/di schell
 #: ../vector/v.qcount/main.c:87
-#, fuzzy
 msgid "Print results in shell script style"
 msgstr "Stampa i risultati in stile script per la shell"
@@ -26585,14 +25277,7 @@
 msgstr "Azione da eseguire"
 #: ../vector/v.category/main.c:101
-msgid ""
-"add;add a new category;del;delete category (-1 to delete all categories of "
-"given layer);chlayer;change layer number (e.g. layer=3,1 changes layer 3 to "
-"layer 1);sum;add the value specified by cat option to the current category "
-"value;transfer;copy values from one layer to another (e.g. layer=1,2,3 "
-"copies values from layer 1 to layer 2 and 3);report;print report "
-"(statistics), in shell style: layer type count min max;print;print category "
-"values, more cats in the same layer are separated by '/'"
+msgid "add;add a new category;del;delete category (-1 to delete all categories of given layer);chlayer;change layer number (e.g. layer=3,1 changes layer 3 to layer 1);sum;add the value specified by cat option to the current category value;transfer;copy values from one layer to another (e.g. layer=1,2,3 copies values from layer 1 to layer 2 and 3);report;print report (statistics), in shell style: layer type count min max;print;print category values, more cats in the same layer are separated by '/'"
 msgstr ""
 #: ../vector/v.category/main.c:118
@@ -26609,14 +25294,11 @@
 msgstr ""
 #: ../vector/v.category/main.c:141
-msgid ""
-"Database connection and attribute tables for concerned layers are not changed"
+msgid "Database connection and attribute tables for concerned layers are not changed"
 msgstr ""
 #: ../vector/v.category/main.c:162
-msgid ""
-"Invalid category number (must be equal to or greater than 0). Normally "
-"category number starts at 1."
+msgid "Invalid category number (must be equal to or greater than 0). Normally category number starts at 1."
 msgstr ""
 #: ../vector/v.category/main.c:171
@@ -26677,9 +25359,8 @@
 msgstr "linea"
 #: ../vector/v.category/main.c:632
-#, fuzzy
 msgid "boundary"
-msgstr "Limiti"
+msgstr "limiti"
 #: ../vector/v.category/main.c:636
 #: ../locale/scriptstrings/v.centroids_to_translate.c:3
@@ -26810,9 +25491,7 @@
 msgstr ""
 #: ../vector/v.buffer/main.c:272
-msgid ""
-"Maximum distance between theoretical arc and polygon segments as multiple of "
-"buffer"
+msgid "Maximum distance between theoretical arc and polygon segments as multiple of buffer"
 msgstr ""
 #: ../vector/v.buffer/main.c:277
@@ -26828,10 +25507,7 @@
 msgstr ""
 #: ../vector/v.buffer/main.c:296
-msgid ""
-"The bufcol option may contain bugs during the cleaning step. If you "
-"encounter problems, use the debug option or clean manually with v.clean "
-"tool=break; v.category step=0; v.extract -d type=area"
+msgid "The bufcol option may contain bugs during the cleaning step. If you encounter problems, use the debug option or clean manually with v.clean tool=break; v.category step=0; v.extract -d type=area"
 msgstr ""
 #: ../vector/v.buffer/main.c:313
@@ -26858,9 +25534,7 @@
 msgstr "Non è possibile selezionare dati dalla tabella <%s>"
 #: ../vector/v.buffer/main.c:417
-msgid ""
-"No features available for buffering. Check type option and features "
-"available in the input vector."
+msgid "No features available for buffering. Check type option and features available in the input vector."
 msgstr ""
 #: ../vector/v.buffer/main.c:432
@@ -26916,10 +25590,7 @@
 msgstr ""
 #: ../vector/v.surf.rst/main.c:147
-msgid ""
-"Spatial approximation and topographic analysis from given point or isoline "
-"data in vector format to floating point raster format using regularized "
-"spline with tension."
+msgid "Spatial approximation and topographic analysis from given point or isoline data in vector format to floating point raster format using regularized spline with tension."
 msgstr ""
 #: ../vector/v.surf.rst/main.c:154
@@ -27000,8 +25671,7 @@
 msgstr ""
 #: ../vector/v.surf.rst/main.c:311
-msgid ""
-"Maximum distance between points on isoline (to insert additional points)"
+msgid "Maximum distance between points on isoline (to insert additional points)"
 msgstr ""
 #: ../vector/v.surf.rst/main.c:320
@@ -27016,23 +25686,18 @@
 #: ../vector/v.surf.rst/main.c:401 ../vector/v.surf.rst/main.c:406
 #, c-format
 msgid "Output vector map name <%s> is not valid map name"
-msgstr ""
-"Il nome della mappa vettoriale di output  <%s> non è un nome di mappa valido"
+msgstr "Il nome della mappa vettoriale di output  <%s> non è un nome di mappa valido"
 #: ../vector/v.surf.rst/main.c:419
 msgid "You are not outputting any raster or vector maps"
 msgstr ""
 #: ../vector/v.surf.rst/main.c:428
-msgid ""
-"Both cross-validation options (-c flag and cvdev vector output) must be "
-"specified"
+msgid "Both cross-validation options (-c flag and cvdev vector output) must be specified"
 msgstr ""
 #: ../vector/v.surf.rst/main.c:431
-msgid ""
-"The cross-validation cannot be computed simultaneously with output raster or "
-"devi file"
+msgid "The cross-validation cannot be computed simultaneously with output raster or devi file"
 msgstr ""
 #: ../vector/v.surf.rst/main.c:449
@@ -27089,9 +25754,7 @@
 #: ../vector/v.surf.rst/main.c:648
 #, c-format
-msgid ""
-"Processing all selected output files will require %d bytes of disk space for "
-"temp files"
+msgid "Processing all selected output files will require %d bytes of disk space for temp files"
 msgstr ""
 #: ../vector/v.surf.rst/main.c:668
@@ -27109,12 +25772,8 @@
 msgstr "Nome della mappa raster risultante"
 #: ../vector/v.transform/main.c:72
-msgid ""
-"Performs an affine transformation (shift, scale and rotate, or GPCs) on "
-"vector map."
-msgstr ""
-"Esegue una trasformazione affine (shift, riscalare e ruotare, o GPCs) su una "
-"mappa vettoriale"
+msgid "Performs an affine transformation (shift, scale and rotate, or GPCs) on vector map."
+msgstr "Esegue una trasformazione affine (shift, riscalare e ruotare, o GPCs) su una mappa vettoriale"
 #: ../vector/v.transform/main.c:77
 msgid "Shift all z values to bottom=0"
@@ -27182,9 +25841,7 @@
 msgstr ""
 #: ../vector/v.transform/main.c:186
-msgid ""
-"Name of table and name for output vector map must be different. Otherwise "
-"the table is overwritten."
+msgid "Name of table and name for output vector map must be different. Otherwise the table is overwritten."
 msgstr ""
 #: ../vector/v.transform/main.c:256
@@ -27205,17 +25862,17 @@
 #: ../vector/v.transform/main.c:286
 #, c-format
 msgid " N: %-10.3f    S: %-10.3f"
-msgstr ""
+msgstr " N: %-10.3f    S: %-10.3f"
 #: ../vector/v.transform/main.c:287
 #, c-format
 msgid " E: %-10.3f    W: %-10.3f"
-msgstr ""
+msgstr " E: %-10.3f    W: %-10.3f"
 #: ../vector/v.transform/main.c:288
 #, c-format
 msgid " B: %6.3f    T: %6.3f"
-msgstr ""
+msgstr " B: %6.3f    T: %6.3f"
 #: ../vector/v.transform/trans_digit.c:97
 #, c-format
@@ -27224,17 +25881,12 @@
 #: ../vector/v.transform/trans_digit.c:105
 #, c-format
-msgid ""
-"Unable to select value for category %d from table <%s>, column <%s>. For "
-"category %d using default transformation parameter %.3f."
+msgid "Unable to select value for category %d from table <%s>, column <%s>. For category %d using default transformation parameter %.3f."
 msgstr ""
 #: ../vector/v.transform/trans_digit.c:116
-#, fuzzy
 msgid "No category number defined. Using default transformation parameters."
-msgstr ""
-"Nessun numero di categoria definito. Si stanno usando i parametri di "
-"trasformazione predefiniti"
+msgstr "Nessun numero di categoria definito. Si stanno usando i parametri di trasformazione predefiniti"
 #: ../vector/v.reclass/main.c:69 ../vector/v.class/main.c:45
 #, fuzzy
@@ -27242,18 +25894,12 @@
 msgstr "Attributi"
 #: ../vector/v.reclass/main.c:71
-msgid ""
-"Changes vector category values for an existing vector map according to "
-"results of SQL queries or a value in attribute table column."
-msgstr ""
-"Cambia i valori delle categorie per un esistente vettoriale secondo "
-"risultati di interrogazioni SQL o valori di una colonna della tabella degli "
-"attributi"
+msgid "Changes vector category values for an existing vector map according to results of SQL queries or a value in attribute table column."
+msgstr "Cambia i valori delle categorie per un esistente vettoriale secondo risultati di interrogazioni SQL o valori di una colonna della tabella degli attributi"
 #: ../vector/v.reclass/main.c:88
 msgid "The name of the column whose values are to be used as new categories"
-msgstr ""
-"Il nome della colonna i cui valori devono essere usati come nuove categorie"
+msgstr "Il nome della colonna i cui valori devono essere usati come nuove categorie"
 #: ../vector/v.reclass/main.c:89
 msgid "The source for the new key column must be type integer or string"
@@ -27289,7 +25935,6 @@
 msgstr "Impossibile inserire i dati: [%s]"
 #: ../vector/v.reclass/main.c:313
-#, fuzzy
 msgid "Column type must be integer or string"
 msgstr "Il formato della colonna chiave dev'essere di tipo integer o string"
@@ -27355,10 +26000,7 @@
 #: ../vector/v.neighbors/main.c:53
-msgid ""
-"Makes each cell value a function of the attribute values assigned to the "
-"vector points or centroids around it, and stores new cell values in an "
-"output raster map."
+msgid "Makes each cell value a function of the attribute values assigned to the vector points or centroids around it, and stores new cell values in an output raster map."
 msgstr ""
 #: ../vector/v.neighbors/main.c:75
@@ -27542,8 +26184,7 @@
 #: ../vector/v.external/args.c:53
 #, fuzzy
-msgid ""
-"List available OGR layers including feature types in datatsource and exit"
+msgid "List available OGR layers including feature types in datatsource and exit"
 #: ../vector/v.external/list.c:13
@@ -27745,7 +26386,7 @@
 msgstr ""
 #: ../vector/v.lidar.edgedetection/main.c:256
-#, fuzzy, c-format
+#, c-format
 msgid "It was impossible to create <%s>."
 msgstr "Non è stato possibile creare <%s>"
@@ -27781,9 +26422,7 @@
 msgstr "Tipo/i di elemento"
 #: ../vector/v.out.ogr/args.c:17
-msgid ""
-"Combination of types is not supported by all output formats. Default is to "
-"use first type found in input vector map."
+msgid "Combination of types is not supported by all output formats. Default is to use first type found in input vector map."
 msgstr ""
 #: ../vector/v.out.ogr/args.c:28
@@ -27828,30 +26467,24 @@
 msgstr ""
 #: ../vector/v.out.ogr/args.c:88
-msgid ""
-"Also export features without category (not labeled). Otherwise only features "
-"with category are exported."
+msgid "Also export features without category (not labeled). Otherwise only features with category are exported."
 msgstr ""
 #: ../vector/v.out.ogr/args.c:94
 msgid "Use ESRI-style .prj file format (applies to Shapefile output only)"
-msgstr ""
-"Usa il file .prj in formato ESRI-style  (applicato solo all'output Shapefile)"
+msgstr "Usa il file .prj in formato ESRI-style  (applicato solo all'output Shapefile)"
 #: ../vector/v.out.ogr/args.c:100
 #, fuzzy
 msgid "Create 3D output if input is 3D (applies to Shapefile output only)"
-msgstr ""
 #: ../vector/v.out.ogr/args.c:106
 msgid "Export lines as polygons"
 msgstr ""
 #: ../vector/v.out.ogr/args.c:112
-msgid ""
-"Create a new empty OGR layer in defined OGR datasource and exit. Nothing is "
-"read from input."
+msgid "Create a new empty OGR layer in defined OGR datasource and exit. Nothing is read from input."
 msgstr ""
 #: ../vector/v.out.ogr/create.c:20
@@ -27876,9 +26509,7 @@
 #: ../vector/v.out.ogr/main.c:87
 #, fuzzy
 msgid "Converts a vector map to any of the supported OGR vector formats."
-msgstr ""
-"di GRASS"
 #: ../vector/v.out.ogr/main.c:155
 #, fuzzy
@@ -27900,96 +26531,74 @@
 msgstr ""
 #: ../vector/v.out.ogr/main.c:265
-msgid ""
-"The map contains islands. With the -c flag, islands will appear as filled "
-"areas, not holes in the output map."
+msgid "The map contains islands. With the -c flag, islands will appear as filled areas, not holes in the output map."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:271
 #, c-format
-msgid ""
-"%d point(s) found, but not requested to be exported. Verify 'type' parameter."
+msgid "%d point(s) found, but not requested to be exported. Verify 'type' parameter."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:276
 #, c-format
-msgid ""
-"%d line(s) found, but not requested to be exported. Verify 'type' parameter."
+msgid "%d line(s) found, but not requested to be exported. Verify 'type' parameter."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:282
 #, c-format
-msgid ""
-"%d boundary(ies) found, but not requested to be exported. Verify 'type' "
-"parameter."
+msgid "%d boundary(ies) found, but not requested to be exported. Verify 'type' parameter."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:288
 #, c-format
-msgid ""
-"%d centroid(s) found, but not requested to be exported. Verify 'type' "
-"parameter."
+msgid "%d centroid(s) found, but not requested to be exported. Verify 'type' parameter."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:293
 #, c-format
-msgid ""
-"%d area(s) found, but not requested to be exported. Verify 'type' parameter."
+msgid "%d area(s) found, but not requested to be exported. Verify 'type' parameter."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:297
 #, c-format
-msgid ""
-"%d face(s) found, but not requested to be exported. Verify 'type' parameter."
+msgid "%d face(s) found, but not requested to be exported. Verify 'type' parameter."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:302
 #, c-format
-msgid ""
-"%d volume(s) found, but not requested to be exported. Verify 'type' "
-"parameter."
+msgid "%d volume(s) found, but not requested to be exported. Verify 'type' parameter."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:308
-msgid ""
-"No points found, but requested to be exported. Will skip this feature type."
+msgid "No points found, but requested to be exported. Will skip this feature type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:317
-msgid ""
-"No lines found, but requested to be exported. Will skip this feature type."
+msgid "No lines found, but requested to be exported. Will skip this feature type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:327
-msgid ""
-"No boundaries found, but requested to be exported. Will skip this feature "
-"type."
+msgid "No boundaries found, but requested to be exported. Will skip this feature type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:336
-msgid ""
-"No areas found, but requested to be exported. Will skip this feature type."
+msgid "No areas found, but requested to be exported. Will skip this feature type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:346
-msgid ""
-"No centroids found, but requested to be exported. Will skip this feature "
-"type."
+msgid "No centroids found, but requested to be exported. Will skip this feature type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:355
-msgid ""
-"No faces found, but requested to be exported. Will skip this feature type."
+msgid "No faces found, but requested to be exported. Will skip this feature type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:364
-msgid ""
-"No kernels found, but requested to be exported. Will skip this feature type."
+msgid "No kernels found, but requested to be exported. Will skip this feature type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:373
-msgid ""
-"No volumes found, but requested to be exported. Will skip this feature type."
+msgid "No volumes found, but requested to be exported. Will skip this feature type."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:384
@@ -28003,9 +26612,7 @@
 #: ../vector/v.out.ogr/main.c:408
 #, c-format
-msgid ""
-"Append existing layer requires opening data source in update mode, forcing '-"
-"%c' flag"
+msgid "Append existing layer requires opening data source in update mode, forcing '-%c' flag"
 msgstr ""
 #: ../vector/v.out.ogr/main.c:426
@@ -28034,23 +26641,17 @@
 #: ../vector/v.out.ogr/main.c:493
 #, c-format
-msgid ""
-"Vector map <%s> is 3D. Use format specific layer creation options SHPT "
-"(parameter 'lco') or '-z' flag to export in 3D rather than 2D (default)"
+msgid "Vector map <%s> is 3D. Use format specific layer creation options SHPT (parameter 'lco') or '-z' flag to export in 3D rather than 2D (default)"
 msgstr ""
 #: ../vector/v.out.ogr/main.c:505
 #, c-format
-msgid ""
-"Vector map <%s> is 3D. Use format specific layer creation options DIM "
-"(parameter 'lco') to export in 3D rather than 2D (default)."
+msgid "Vector map <%s> is 3D. Use format specific layer creation options DIM (parameter 'lco') to export in 3D rather than 2D (default)."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:512
 #, c-format
-msgid ""
-"Vector map <%s> is 3D. Use format specific layer creation options (parameter "
-"'lco') to export in 3D rather than 2D (default)."
+msgid "Vector map <%s> is 3D. Use format specific layer creation options (parameter 'lco') to export in 3D rather than 2D (default)."
 msgstr ""
 #: ../vector/v.out.ogr/main.c:529 ../db/drivers/ogr/execute.c:56
@@ -28101,9 +26702,9 @@
 msgstr ""
 #: ../vector/v.out.ogr/main.c:928
-#, fuzzy, c-format
+#, c-format
 msgid "Exporting %i volumes..."
-msgstr "Esportando %i punti/linee..."
+msgstr "Esportazione di %i volumi in corso..."
 #: ../vector/v.out.ogr/main.c:929
 msgid "Export of volumes not implemented yet. Skipping."
@@ -28145,14 +26746,11 @@
 msgstr "Importa un file raster binario in una mappa raster GRASS"
 #: ../vector/v.patch/main.c:81
-msgid ""
-"Name for output vector map where bounding boxes of input vector maps are "
-"written to"
+msgid "Name for output vector map where bounding boxes of input vector maps are written to"
 msgstr ""
 #: ../vector/v.patch/main.c:85
-msgid ""
-"Append files to existing file (overwriting existing files must be activated)"
+msgid "Append files to existing file (overwriting existing files must be activated)"
 msgstr ""
 #: ../vector/v.patch/main.c:90
@@ -28281,9 +26879,7 @@
 msgstr "Utilizzando le coordinate del centro della mappa\n"
 #: ../vector/v.out.pov/main.c:76
-msgid ""
-"This string is appended to each z coordinate. Examples: '*10', '+1000', "
-"'*10+100', '*exaggeration'"
+msgid "This string is appended to each z coordinate. Examples: '*10', '+1000', '*10+100', '*exaggeration'"
 msgstr ""
 #: ../vector/v.out.pov/main.c:84
@@ -28317,15 +26913,11 @@
 msgstr "Numero del layer (mappa vettoriale B)"
 #: ../vector/v.select/args.c:45
-#, fuzzy
 msgid "Operator defines required relation between features"
 msgstr "L'operatore definisce la relazione fra elementi richiesta"
 #: ../vector/v.select/args.c:47
-msgid ""
-"A feature is written to output if the result of operation 'ainput operator "
-"binput' is true. An input feature is considered to be true, if category of "
+msgid "A feature is written to output if the result of operation 'ainput operator binput' is true. An input feature is considered to be true, if category of given layer is defined."
 msgstr ""
 #: ../vector/v.select/args.c:52
@@ -28333,15 +26925,7 @@
 msgstr ""
 #: ../vector/v.select/args.c:57
-msgid ""
-"overlap;features partially or completely overlap;equals;features are "
-"spatially equals (using GEOS);disjoint;features do not spatially intersect "
-"(using GEOS);intersects;features spatially intersect (using GEOS);touches;"
-"features spatially touches (using GEOS);crosses;features spatially crosses "
-"(using GEOS);within;feature A is completely inside feature B (using GEOS);"
-"contains;feature B is completely inside feature A (using GEOS);overlaps;"
-"features spatially overlap (using GEOS);relate;feature A is spatially "
-"related to feature B (using GEOS, requires 'relate' option);"
+msgid "overlap;features partially or completely overlap;equals;features are spatially equals (using GEOS);disjoint;features do not spatially intersect (using GEOS);intersects;features spatially intersect (using GEOS);touches;features spatially touches (using GEOS);crosses;features spatially crosses (using GEOS);within;feature A is completely inside feature B (using GEOS);contains;feature B is completely inside feature A (using GEOS);overlaps;features spatially overlap (using GEOS);relate;feature A is spatially related to feature B (using GEOS, requires 'relate' option);"
 msgstr ""
 #: ../vector/v.select/args.c:74
@@ -28349,7 +26933,6 @@
 msgstr ""
 #: ../vector/v.select/args.c:83
-#, fuzzy
 msgid "Do not skip features without category"
 msgstr "Considera anche gli elementi senza categoria"
@@ -28368,11 +26951,8 @@
 msgstr ""
 #: ../vector/v.select/main.c:50
-msgid ""
-"Selects features from vector map (A) by features from other vector map (B)."
-msgstr ""
-"Elementi selezionati di un vettoriale (A) con gli elementi di un altro "
-"vettoriale (B)."
+msgid "Selects features from vector map (A) by features from other vector map (B)."
+msgstr "Elementi selezionati di un vettoriale (A) con gli elementi di un altro vettoriale (B)."
 #: ../vector/v.select/main.c:83
 #, fuzzy, c-format
@@ -28477,9 +27057,7 @@
 msgstr ""
 #: ../vector/v.convert/read.c:99
-msgid ""
-"Input file is not portable. We will attempt to convert anyway but conversion "
-"may fail. Please read manual for detail information."
+msgid "Input file is not portable. We will attempt to convert anyway but conversion may fail. Please read manual for detail information."
 msgstr ""
 #: ../vector/v.convert/read.c:185
@@ -28665,8 +27243,7 @@
 #: ../vector/v.clean/prune.c:215
 #, c-format
-msgid ""
-"%d vertices from input %d (vertices of given type) removed, i.e. %.2f %%"
+msgid "%d vertices from input %d (vertices of given type) removed, i.e. %.2f %%"
 msgstr ""
 #: ../vector/v.clean/prune.c:219
@@ -28699,9 +27276,7 @@
 msgstr ""
 #: ../vector/v.clean/main.c:95
-msgid ""
-"change the type of boundary dangle to line, threshold ignored if < 0, input "
-"line type is ignored"
+msgid "change the type of boundary dangle to line, threshold ignored if < 0, input line type is ignored"
 msgstr ""
 #: ../vector/v.clean/main.c:97
@@ -28709,9 +27284,7 @@
 msgstr ""
 #: ../vector/v.clean/main.c:98
-msgid ""
-"change the type of bridges connecting area and island or 2 islands from "
-"boundary to line"
+msgid "change the type of bridges connecting area and island or 2 islands from boundary to line"
 msgstr ""
 #: ../vector/v.clean/main.c:100
@@ -28724,13 +27297,7 @@
 msgstr ""
 #: ../vector/v.clean/main.c:102
-msgid ""
-"break (topologically clean) polygons (imported from non topological format, "
-"like ShapeFile). Boundaries are broken on each point shared between 2 and "
-"more polygons where angles of segments are different;prune;remove vertices "
-"in threshold from lines and boundaries, boundary is pruned only if topology "
-"is not damaged (new intersection, changed attachement of centroid), first "
-"and last segment of the boundary is never changed"
+msgid "break (topologically clean) polygons (imported from non topological format, like ShapeFile). Boundaries are broken on each point shared between 2 and more polygons where angles of segments are different;prune;remove vertices in threshold from lines and boundaries, boundary is pruned only if topology is not damaged (new intersection, changed attachement of centroid), first and last segment of the boundary is never changed"
 msgstr ""
 #: ../vector/v.clean/main.c:109
@@ -28839,8 +27406,7 @@
 #: ../vector/v.clean/main.c:314
 #, fuzzy
 msgid "Failed to copy attribute table to output vector map"
-msgstr ""
-"Copiatura della tabella degli attributi sulla mappa di output non riuscita"
+msgstr "Copiatura della tabella degli attributi sulla mappa di output non riuscita"
 #: ../vector/v.clean/main.c:329 ../vector/v.clean/main.c:340
 msgid "Rebuilding parts of topology..."
@@ -28943,8 +27509,7 @@
 #: ../vector/v.external.out/args.c:51
 #, fuzzy
 msgid "Print current status in shell script style"
-msgstr ""
-"Stampa le impostazioni della region corrente (in stile script per la shell)"
+msgstr "Stampa le impostazioni della region corrente (in stile script per la shell)"
 #: ../vector/v.external.out/list.c:73
 #, fuzzy
@@ -29012,9 +27577,7 @@
 #: ../vector/v.perturb/main.c:66
 #, fuzzy
 msgid "Random location perturbations of vector points."
-msgstr ""
-"Genera una mappa GRASS 2D/3D di punti vettoriali disposti in posizioni "
-"casuali"
+msgstr "Genera una mappa GRASS 2D/3D di punti vettoriali disposti in posizioni casuali"
 #: ../vector/v.perturb/main.c:80
 msgid "Distribution of perturbation"
@@ -29026,10 +27589,7 @@
 msgstr "Numero di passi attraverso il dataset"
 #: ../vector/v.perturb/main.c:88
-msgid ""
-"If the distribution is uniform, only one parameter, the maximum, is needed. "
-"For a normal distribution, two parameters, the mean and standard deviation, "
-"are required."
+msgid "If the distribution is uniform, only one parameter, the maximum, is needed. For a normal distribution, two parameters, the mean and standard deviation, are required."
 msgstr ""
 #: ../vector/v.perturb/main.c:98
@@ -29106,9 +27666,7 @@
 msgstr "Nome di colonna o espressione"
 #: ../vector/v.vect.stats/main.c:189
-msgid ""
-"Column to hold points count, must be of type integer, will be created if not "
-"existing"
+msgid "Column to hold points count, must be of type integer, will be created if not existing"
 msgstr ""
 #: ../vector/v.vect.stats/main.c:196
@@ -29117,9 +27675,7 @@
 #: ../vector/v.vect.stats/main.c:198
-msgid ""
-"Column to hold statistics, must be of type double, will be created if not "
-"existing"
+msgid "Column to hold statistics, must be of type double, will be created if not existing"
 msgstr ""
 #: ../vector/v.vect.stats/main.c:208
@@ -29134,9 +27690,7 @@
 #: ../vector/v.vect.stats/main.c:263
 #, c-format
 msgid "Vector map <%s> is not in user mapset and cannot be updated"
-msgstr ""
-"La mappa vettoriale <%s> non è nel mapset dell'utente e non può essere "
-"aggiornata"
+msgstr "La mappa vettoriale <%s> non è nel mapset dell'utente e non può essere aggiornata"
 #: ../vector/v.vect.stats/main.c:310 ../vector/v.vect.stats/main.c:386
 #, fuzzy, c-format
@@ -29210,10 +27764,7 @@
 msgstr "Non riesco a selezionare dati dalla tabella"
 #: ../vector/v.class/main.c:161
-msgid ""
-"The discontinuities algorithm indicates that some class breaks are not "
-"statistically significant at alpha=0.05. You are advised to reduce the "
-"number of classes."
+msgid "The discontinuities algorithm indicates that some class breaks are not statistically significant at alpha=0.05. You are advised to reduce the number of classes."
 msgstr ""
 #: ../vector/v.class/main.c:190
@@ -29234,6 +27785,8 @@
 "%15s%15s%15s\n"
 "\n"
 msgstr ""
+"%15s%15s%15s\n"
+"\n"
 #: ../vector/v.class/main.c:215
 #, c-format
@@ -29264,9 +27817,7 @@
 #: ../vector/v.info/main.c:45
 #, fuzzy
 msgid "Outputs basic information about a vector map."
-msgstr ""
-"Mostra le informazioni di base riguardo la mappa raster specificata "
-"dall'utente"
+msgstr "Mostra le informazioni di base riguardo la mappa raster specificata dall'utente"
 #: ../vector/v.info/parse.c:24
 #, fuzzy
@@ -29275,11 +27826,8 @@
 #: ../vector/v.info/parse.c:30
 #, fuzzy
-msgid ""
-"Print types/names of table columns for specified layer instead of info and "
-"exit"
-msgstr ""
+msgid "Print types/names of table columns for specified layer instead of info and exit"
 #: ../vector/v.info/parse.c:35
 #, fuzzy
@@ -29299,8 +27847,7 @@
 #: ../vector/v.info/print.c:130
 #, c-format
 msgid "Database connection for map <%s> is not defined in DB file"
-msgstr ""
-"La connessione al database per la mappa <%s> non è definita nel file DB"
+msgstr "La connessione al database per la mappa <%s> non è definita nel file DB"
 #: ../vector/v.info/print.c:134
 #, c-format
@@ -29493,9 +28040,7 @@
 msgstr "Tipo di tavola dei colori"
 #: ../vector/v.lidar.correction/main.c:71
-msgid ""
-"Correction of the v.lidar.growing output. It is the last of the three "
-"algorithms for LIDAR filtering."
+msgid "Correction of the v.lidar.growing output. It is the last of the three algorithms for LIDAR filtering."
 msgstr ""
 #: ../vector/v.lidar.correction/main.c:81
@@ -29503,7 +28048,6 @@
 msgstr ""
 #: ../vector/v.lidar.correction/main.c:84
-#, fuzzy
 msgid "Output classified vector map name"
 msgstr "Nome della mappa vettoriale classificata di output"
@@ -29543,7 +28087,6 @@
 msgstr ""
 #: ../vector/v.lidar.correction/main.c:368
-#, fuzzy
 msgid "Mean calculation"
 msgstr "Calcolo della media"
@@ -29667,8 +28210,7 @@
 msgstr "Indicatore di valore nullo"
 #: ../vector/v.db.select/main.c:90
-msgid ""
-"Print minimal region extent of selected vector features instead of attributes"
+msgid "Print minimal region extent of selected vector features instead of attributes"
 msgstr ""
 #: ../vector/v.db.select/main.c:94 ../db/db.select/main.c:241
@@ -29681,9 +28223,7 @@
 #: ../vector/v.db.select/main.c:135
 #, c-format
-msgid ""
-"Unable to open vector map <%s> at topology level. Flag '%c' requires "
-"topology level."
+msgid "Unable to open vector map <%s> at topology level. Flag '%c' requires topology level."
 msgstr ""
 #: ../vector/v.db.select/main.c:169
@@ -29802,11 +28342,9 @@
 msgstr ""
 #: ../vector/v.in.dxf/write_vect.c:245
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to add database link for vector map <%s>"
-msgstr ""
-"Impossibile aggiungere il collegamento al database per la mappa vettoriale <"
-"%s>"
+msgstr "Impossibile aggiungere il collegamento al database per la mappa vettoriale <%s>"
 #: ../vector/v.split/main.c:54
 msgid "Splits vector lines to shorter segments."
@@ -29864,19 +28402,15 @@
 #: ../vector/v.what.rast/main.c:74
 msgid "Uploads raster values at positions of vector points to the table."
-msgstr ""
-"Carica valori di un raster nella tabella degli attributi di un vettoriale "
-"puntuale"
+msgstr "Carica valori di un raster nella tabella degli attributi di un vettoriale puntuale"
 #: ../vector/v.what.rast/main.c:78
 #: ../locale/scriptstrings/v.what.vect_to_translate.c:5
 #, fuzzy
 msgid "Name of vector points map for which to edit attributes"
-msgstr ""
-"Nome della mappa vettoriale di punti della quale editare la tabella attributi"
+msgstr "Nome della mappa vettoriale di punti della quale editare la tabella attributi"
 #: ../vector/v.what.rast/main.c:84
-#, fuzzy
 msgid "Name of existing raster map to be queried"
 msgstr "Nome della mappa raster esistente da interrogare"
@@ -29888,7 +28422,7 @@
 #: ../vector/v.what.rast/main.c:136 ../vector/v.to.rast/support.c:314
 #: ../vector/v.to.rast/vect2rast.c:61
-#, fuzzy, c-format
+#, c-format
 msgid "Column <%s> not found"
 msgstr "Colonna <%s> non trovata"
@@ -29898,9 +28432,7 @@
 #: ../vector/v.what.rast/main.c:145
 msgid "Raster type is float and column type is integer, some data lost!!"
-msgstr ""
-"Il raster è di tipo float mentre la colonna è di tipo integer, attenzione "
-"alla possibile perdita di dati!"
+msgstr "Il raster è di tipo float mentre la colonna è di tipo integer, attenzione alla possibile perdita di dati!"
 #: ../vector/v.what.rast/main.c:159
 #, fuzzy
@@ -29908,20 +28440,19 @@
 msgstr "Lettura degli elementi in corso ..."
 #: ../vector/v.what.rast/main.c:229
-#, fuzzy, c-format
+#, c-format
 msgid "%d points outside current region were skipped"
 msgstr "%d punti al di fuori della regione corrente non considerati"
 #: ../vector/v.what.rast/main.c:233
-#, fuzzy, c-format
+#, c-format
 msgid "%d points without category were skipped"
 msgstr "%d punti senza categoria non considerati"
 #: ../vector/v.what.rast/main.c:282
 #, c-format
 msgid "More points (%d) of category %d, value set to 'NULL'"
-msgstr ""
-"Ho assegnato il valore 'NULL' agli ulteriori punti (%d) con categoria %d."
+msgstr "Ho assegnato il valore 'NULL' agli ulteriori punti (%d) con categoria %d."
 #: ../vector/v.what.rast/main.c:351
 #, c-format
@@ -29949,13 +28480,10 @@
 #: ../vector/v.net.salesman/main.c:108
 msgid "Creates a cycle connecting given nodes (Traveling salesman problem)."
-msgstr ""
-"Crea un ciclo connettendo i nodi dati (problema del commesso viaggiatore)"
+msgstr "Crea un ciclo connettendo i nodi dati (problema del commesso viaggiatore)"
 #: ../vector/v.net.salesman/main.c:110
-msgid ""
-"Note that TSP is NP-hard, heuristic algorithm is used by this module and "
-"created cycle may be sub optimal"
+msgid "Note that TSP is NP-hard, heuristic algorithm is used by this module and created cycle may be sub optimal"
 msgstr ""
 #: ../vector/v.net.salesman/main.c:128
@@ -30406,16 +28934,7 @@
 msgstr ""
 #: ../vector/v.generalize/main.c:103
-msgid ""
-"douglas;Douglas-Peucker Algorithm;douglas_reduction;Douglas-Peucker "
-"Algorithm with reduction parameter;lang;Lang Simplification Algorithm;"
-"reduction;Vertex Reduction Algorithm eliminates points close to each other;"
-"reumann;Reumann-Witkam Algorithm;boyle;Boyle's Forward-Looking Algorithm;"
-"sliding_averaging;McMaster's Sliding Averaging Algorithm;distance_weighting;"
-"McMaster's Distance-Weighting Algorithm;chaiken;Chaiken's Algorithm;hermite;"
-"Interpolation by Cubic Hermite Splines;snakes;Snakes method for line "
-"smoothing;network;Network generalization;displacement;Displacement of lines "
-"close to each other;"
+msgid "douglas;Douglas-Peucker Algorithm;douglas_reduction;Douglas-Peucker Algorithm with reduction parameter;lang;Lang Simplification Algorithm;reduction;Vertex Reduction Algorithm eliminates points close to each other;reumann;Reumann-Witkam Algorithm;boyle;Boyle's Forward-Looking Algorithm;sliding_averaging;McMaster's Sliding Averaging Algorithm;distance_weighting;McMaster's Distance-Weighting Algorithm;chaiken;Chaiken's Algorithm;hermite;Interpolation by Cubic Hermite Splines;snakes;Snakes method for line smoothing;network;Network generalization;displacement;Displacement of lines close to each other;"
 msgstr ""
 #: ../vector/v.generalize/main.c:117
@@ -30479,9 +28998,8 @@
 msgstr ""
 #: ../vector/v.generalize/main.c:329
-#, fuzzy
 msgid "Network generalization..."
-msgstr "Generalizzazione vettoriale"
+msgstr "Generalizzazione vettoriale..."
 #: ../vector/v.generalize/main.c:344
 msgid "Attributes are needed for 'where' option, copying table"
@@ -30504,8 +29022,7 @@
 #: ../vector/v.generalize/main.c:492
 #, c-format
-msgid ""
-"%d boundaries were not modified because modification would damage topology"
+msgid "%d boundaries were not modified because modification would damage topology"
 msgstr ""
 #: ../vector/v.generalize/main.c:495
@@ -30528,9 +29045,7 @@
 msgstr "Righe cambiate"
 #: ../vector/v.vol.rst/main.c:245
-msgid ""
-"Interpolates point data to a 3D raster map using regularized spline with "
-"tension (RST) algorithm."
+msgid "Interpolates point data to a 3D raster map using regularized spline with tension (RST) algorithm."
 msgstr ""
 #: ../vector/v.vol.rst/main.c:253
@@ -30546,7 +29061,6 @@
 msgstr "Nome della colonna contenente l'attributo w da interpolare"
 #: ../vector/v.vol.rst/main.c:292
-#, fuzzy
 msgid "Name of the column with smoothing parameters"
 msgstr "Nome della colonna coi parametri di smoothing"
@@ -30640,8 +29154,7 @@
 msgstr ""
 #: ../vector/v.vol.rst/user1.c:128
-msgid ""
-"Column type of smooth column is not supported (must be integer or double)"
+msgid "Column type of smooth column is not supported (must be integer or double)"
 msgstr ""
 #: ../vector/v.to.rast3/main.c:51
@@ -30652,8 +29165,7 @@
 #: ../vector/v.to.rast3/main.c:62
 #, fuzzy
 msgid "Name of attribute column (data type must be numeric)"
-msgstr ""
-"Nome della colonna per il parametro attr (tipo di dato dovrà essere numerico)"
+msgstr "Nome della colonna per il parametro attr (tipo di dato dovrà essere numerico)"
 #: ../vector/v.to.rast3/main.c:104
 msgid "Unable to create output map"
@@ -30726,8 +29238,7 @@
 msgstr "Spessore del bordo (solo per l'output di ps.map)"
 #: ../vector/v.in.db/main.c:57
-msgid ""
-"Creates new vector (points) map from database table containing coordinates."
+msgid "Creates new vector (points) map from database table containing coordinates."
 msgstr "Crea un nuovo vettoriale (punti) da una tabella contenente coordinate"
 #: ../vector/v.in.db/main.c:61
@@ -30763,8 +29274,7 @@
 #: ../vector/v.in.db/main.c:133
 #, c-format
-msgid ""
-"Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
+msgid "Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
 msgstr ""
 #: ../vector/v.in.db/main.c:183
@@ -30785,12 +29295,8 @@
 msgstr "scritti %d punti nella mappa vettoriale"
 #: ../vector/v.surf.idw/main.c:90
-msgid ""
-"Surface interpolation from vector point data by Inverse Distance Squared "
-"Weighting."
-msgstr ""
-"Interpolazione della superficie da un vettore puntuale con peso inverso "
-"delle distanze al quadrato IDW"
+msgid "Surface interpolation from vector point data by Inverse Distance Squared Weighting."
+msgstr "Interpolazione della superficie da un vettore puntuale con peso inverso delle distanze al quadrato IDW"
 #: ../vector/v.surf.idw/main.c:99
 #, fuzzy
@@ -30806,9 +29312,7 @@
 msgstr ""
 #: ../vector/v.surf.idw/main.c:116
-msgid ""
-"Slower but uses less memory and includes points from outside region in the "
-"interpolation"
+msgid "Slower but uses less memory and includes points from outside region in the interpolation"
 msgstr ""
 #: ../vector/v.surf.idw/main.c:131
@@ -30823,8 +29327,7 @@
 #: ../vector/v.surf.idw/main.c:251
 #, c-format
 msgid "Interpolating raster map <%s> (%d rows, %d cols)... "
-msgstr ""
-"Interpolazione della mappa raster <%s> in corso (%d righe, %d colonne)..."
+msgstr "Interpolazione della mappa raster <%s> in corso (%d righe, %d colonne)..."
 #: ../vector/v.surf.idw/read_sites.c:88
 #: ../vector/v.surf.bspline/crosscorr.c:214
@@ -30846,17 +29349,15 @@
 msgstr ""
 #: ../vector/v.hull/main.c:64
-#, fuzzy
 msgid "Use all vector points (do not limit to current region)"
-msgstr ""
-"Utilizza tutti i punti vettoriali (non solo quelli nella regione corrente)"
+msgstr "Utilizza tutti i punti vettoriali (non solo quelli nella regione corrente)"
 #: ../vector/v.hull/main.c:69
 msgid "Create a 'flat' 2D hull even if the input is 3D points"
 msgstr ""
 #: ../vector/v.hull/main.c:88
-#, fuzzy, c-format
+#, c-format
 msgid "Error loading vector points from <%s>"
 msgstr "Errore nel caricare i punti vettoriali da <%s>"
@@ -30866,9 +29367,9 @@
 msgstr ""
 #: ../vector/v.hull/main.c:93
-#, fuzzy, c-format
+#, c-format
 msgid "%d points read from vector map <%s>"
-msgstr "Letti %d punti dalla mappa vettoriale <&s>"
+msgstr "Letti %d punti dalla mappa vettoriale <%s>"
 #: ../vector/v.out.dxf/main.c:59
 #, fuzzy
@@ -30881,22 +29382,22 @@
 msgstr "Nome del file in output"
 #: ../vector/v.out.dxf/main.c:91
-#, fuzzy, c-format
+#, c-format
 msgid "%d features written to '%s'."
 msgstr "%d elementi scritti in '%s'."
 #: ../vector/v.out.dxf/write_dxf.c:21
-#, fuzzy, c-format
+#, c-format
 msgid "The file '%s' already exists."
 msgstr "Il file '%s' esiste già."
 #: ../vector/v.out.dxf/write_dxf.c:23
-#, fuzzy, c-format
+#, c-format
 msgid "The file '%s' already exists and will be overwritten."
 msgstr "Il file '%s' esiste già e verrà sovrascritto."
 #: ../vector/v.out.dxf/write_dxf.c:27
-#, fuzzy, c-format
+#, c-format
 msgid "%s: Cannot write dxf file."
 msgstr "%s: Impossibile scrivere il file dxf"
@@ -30938,25 +29439,23 @@
 msgstr ""
 #: ../vector/v.drape/main.c:384
-msgid ""
-"No features drapped. Check your computational region and input vector map."
+msgid "No features drapped. Check your computational region and input vector map."
 msgstr ""
 #: ../vector/v.net.path/path.c:82
-#, fuzzy, c-format
+#, c-format
 msgid "[%d] points without category (nfield: [%d])"
 msgstr "[%d] punti senza categoria (nfield: [%d])"
 #: ../vector/v.net.path/path.c:168 ../vector/v.net.path/path.c:188
-#, fuzzy, c-format
+#, c-format
 msgid "No point with category [%d]"
 msgstr "Nessun punto con categoria [%d]"
 #: ../vector/v.net.path/path.c:209
 #, c-format
 msgid "Point with category [%d] is not reachable from point with category [%d]"
-msgstr ""
-"Il punto con categoria [%d] non è raggiungibile dal punto con categoria [%d]"
+msgstr "Il punto con categoria [%d] non è raggiungibile dal punto con categoria [%d]"
 #: ../vector/v.net.path/path.c:266
 #, c-format
@@ -30964,7 +29463,7 @@
 msgstr "Il punto  %f,%f  non è raggiungibile dal punto %f,%f"
 #: ../vector/v.net.path/path.c:331
-#, fuzzy, c-format
+#, c-format
 msgid "[%d] input format errors"
 msgstr "[%d] errori nel formato di input"
@@ -30983,8 +29482,7 @@
 msgstr "Trova il percorso più breve in una rete vettoriale."
 #: ../vector/v.net.path/main.c:66
-msgid ""
-"Name of file containing start and end points. If not given, read from stdin"
+msgid "Name of file containing start and end points. If not given, read from stdin"
 msgstr ""
 #: ../vector/v.net.path/main.c:93
@@ -30992,10 +29490,7 @@
 msgstr ""
 #: ../vector/v.net.path/main.c:94
-msgid ""
-"If start/end are given as coordinates. If start/end point is outside this "
-"threshold, the path is not found and error message is printed. To speed up "
-"the process, keep this value as low as possible."
+msgid "If start/end are given as coordinates. If start/end point is outside this threshold, the path is not found and error message is printed. To speed up the process, keep this value as low as possible."
 msgstr ""
 #: ../vector/v.net.path/main.c:107
@@ -31003,9 +29498,7 @@
 msgstr ""
 #: ../vector/v.rectify/main.c:66
-msgid ""
-"Rectifies a vector by computing a coordinate transformation for each object "
-"in the vector based on the control points."
+msgid "Rectifies a vector by computing a coordinate transformation for each object in the vector based on the control points."
 msgstr ""
 #: ../vector/v.rectify/main.c:81
@@ -31132,7 +29625,6 @@
 msgstr "%s è vuoto"
 #: ../vector/v.surf.bspline/main.c:120
-#, fuzzy
 msgid "Name of input vector map of sparse points"
 msgstr "Nome della mappa vettoriale di punti sparsi di input"
@@ -31182,15 +29674,13 @@
 msgstr ""
 #: ../vector/v.surf.bspline/main.c:307
-#, fuzzy, c-format
+#, c-format
 msgid "Vector map <%s> of sparse points will be interpolated"
 msgstr "La mappa vettoriale di punti sparsi <%s> sarà interpolata"
 #: ../vector/v.surf.bspline/main.c:323
 #, c-format
-msgid ""
-"Sorry, <%s> driver is not allowed for vector output in this module. Try with "
-"a raster output or other driver."
+msgid "Sorry, <%s> driver is not allowed for vector output in this module. Try with a raster output or other driver."
 msgstr ""
 #: ../vector/v.surf.bspline/main.c:345
@@ -31208,16 +29698,14 @@
 msgstr ""
 #: ../vector/v.surf.bspline/main.c:386
-#, fuzzy, c-format
+#, c-format
 msgid "[%d] records selected from table"
 msgstr "[%d] record selezionati dalla tabella"
 #: ../vector/v.surf.bspline/main.c:405
-#, fuzzy, c-format
+#, c-format
 msgid "Interpolation: Creating table: It was impossible to create table <%s>."
-msgstr ""
-"Interpolazione: Creazione della tabella: Non è stato possibile creare la "
-"tabella <%s>."
+msgstr "Interpolazione: Creazione della tabella: Non è stato possibile creare la tabella <%s>."
 #: ../vector/v.surf.bspline/main.c:473
 #, fuzzy
@@ -31225,7 +29713,7 @@
 #: ../vector/v.surf.bspline/main.c:714
-#, fuzzy, c-format
+#, c-format
 msgid "Interpolation: (%d,%d): No record for point (cat = %d)"
 msgstr "Interpolazione: (%d,%d): Nessun record per il punto (cat = %d)"
@@ -31239,9 +29727,7 @@
 msgstr ""
 #: ../vector/v.surf.bspline/crosscorr.c:85
-msgid ""
-"Maybe, it takes too long. It will depend on how many points you are "
-"considering."
+msgid "Maybe, it takes too long. It will depend on how many points you are considering."
 msgstr ""
 #: ../vector/v.surf.bspline/crosscorr.c:114
@@ -31250,7 +29736,7 @@
 msgstr ""
 #: ../vector/v.surf.bspline/crosscorr.c:131
-#, fuzzy, c-format
+#, c-format
 msgid "No records selected from table <%s> "
 msgstr "Nessun record selezionato dalla tabella <%s> "
@@ -31259,9 +29745,7 @@
 msgstr ""
 #: ../vector/v.lidar.growing/main.c:78
-msgid ""
-"Building contour determination and Region Growing algorithm for determining "
-"the building inside"
+msgid "Building contour determination and Region Growing algorithm for determining the building inside"
 msgstr ""
 #: ../vector/v.lidar.growing/main.c:83
@@ -31419,17 +29903,12 @@
 msgstr ""
 #: ../vector/v.to.rast/main.c:64
-msgid ""
-"attr;read values from attribute table;cat;use category values;val;use value "
-"specified by value option;z;use z coordinate (points or contours only);dir;"
-"output as flow direction (lines only)"
+msgid "attr;read values from attribute table;cat;use category values;val;use value specified by value option;z;use z coordinate (points or contours only);dir;output as flow direction (lines only)"
 msgstr ""
 #: ../vector/v.to.rast/main.c:73
 msgid "Name of column for 'attr' parameter (data type must be numeric)"
-msgstr ""
-"Nome della colonna per il parametro 'attr' (il tipo di dato dev'essere "
-"numerico)"
+msgstr "Nome della colonna per il parametro 'attr' (il tipo di dato dev'essere numerico)"
 #: ../vector/v.to.rast/main.c:79
 msgid "Name of color definition column (with RRR:GGG:BBB entries)"
@@ -31493,8 +29972,7 @@
 msgstr "Centroidi di area senza categoria"
 #: ../vector/v.out.vtk/writeVTK.c:186
-msgid ""
-"No coordinates to generate the output! Maybe an empty vector type chosen?"
+msgid "No coordinates to generate the output! Maybe an empty vector type chosen?"
 msgstr ""
 #: ../vector/v.out.vtk/head.c:27
@@ -31584,9 +30062,7 @@
 msgstr "Stampa la cronologia del raster invece delle informazioni"
 #: ../vector/v.in.lidar/main.c:218
-msgid ""
-"Create the location specified by the \"location\" parameter and exit. Do not "
-"import the vector file."
+msgid "Create the location specified by the \"location\" parameter and exit. Do not import the vector file."
 msgstr ""
 #: ../vector/v.in.lidar/main.c:279
@@ -31697,12 +30173,8 @@
 #: ../db/drivers/ogr/describe.c:192
 #, c-format
-msgid ""
-"column '%s', type 'string': unknown width -> stored as varchar(250) some "
-"data may be lost"
-msgstr ""
-"colonna '%s', tipo 'string': dimensione sconosciuta -> archiviata come "
-"varchar(250) alcuni dati possono essere persi"
+msgid "column '%s', type 'string': unknown width -> stored as varchar(250) some data may be lost"
+msgstr "colonna '%s', tipo 'string': dimensione sconosciuta -> archiviata come varchar(250) alcuni dati possono essere persi"
 #: ../db/drivers/ogr/select.c:50
 #, fuzzy
@@ -31805,8 +30277,7 @@
 #: ../db/drivers/mysql/parse.c:76 ../db/drivers/postgres/parse.c:63
 msgid "'password' in database definition is not supported, use db.login"
-msgstr ""
-"'password' non è supportata nella definizione del database, usa db.login"
+msgstr "'password' non è supportata nella definizione del database, usa db.login"
 #: ../db/drivers/mysql/parse.c:81
 #, fuzzy
@@ -31859,12 +30330,8 @@
 #: ../db/drivers/mysql/describe.c:127
 #, c-format
-msgid ""
-"column '%s' : type BIGINT is stored as integer (4 bytes) some data may be "
-"damaged"
-msgstr ""
-"colonna '%s' : il tipo BIGINT è archiviata come integer (4 byte) alcuni dati "
-"possono essere corrotti"
+msgid "column '%s' : type BIGINT is stored as integer (4 bytes) some data may be damaged"
+msgstr "colonna '%s' : il tipo BIGINT è archiviata come integer (4 byte) alcuni dati possono essere corrotti"
 #: ../db/drivers/mysql/select.c:42
 #, fuzzy
@@ -31975,8 +30442,7 @@
 #: ../db/drivers/postgres/describe.c:112
 #, fuzzy, c-format
-msgid ""
-"PostgreSQL driver: PostGIS column '%s', type 'geometry' will not be converted"
+msgid "PostgreSQL driver: PostGIS column '%s', type 'geometry' will not be converted"
 msgstr "Driver MySQL: colonna '%s', di tipo %d non supportata"
 #: ../db/drivers/postgres/describe.c:119
@@ -31986,30 +30452,18 @@
 #: ../db/drivers/postgres/describe.c:126
 #, c-format
-msgid ""
-"column '%s' : type int8 (bigint) is stored as integer (4 bytes) some data "
-"may be damaged"
-msgstr ""
-"colonna '%s' : type int8 (bigint) è archiviata come integer (4 byte) alcuni "
-"dati possono essere corrotti"
+msgid "column '%s' : type int8 (bigint) is stored as integer (4 bytes) some data may be damaged"
+msgstr "colonna '%s' : type int8 (bigint) è archiviata come integer (4 byte) alcuni dati possono essere corrotti"
 #: ../db/drivers/postgres/describe.c:130
 #, c-format
-msgid ""
-"column '%s' : type character varying is stored as varchar(250) some data may "
-"be lost"
-msgstr ""
-"colonna '%s' : tipo character varying è archiviata come varchar(250) alcuni "
-"dati possono essere persi"
+msgid "column '%s' : type character varying is stored as varchar(250) some data may be lost"
+msgstr "colonna '%s' : tipo character varying è archiviata come varchar(250) alcuni dati possono essere persi"
 #: ../db/drivers/postgres/describe.c:136
 #, c-format
-msgid ""
-"column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1 "
-"(true)"
-msgstr ""
-"colonna '%s' : tipo bool (boolean) è archiviata come char(1), valori: 0 "
-"(false), 1 (true)"
+msgid "column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1 (true)"
+msgstr "colonna '%s' : tipo bool (boolean) è archiviata come char(1), valori: 0 (false), 1 (true)"
 #: ../db/drivers/postgres/select.c:31
 msgid "Unable set DATESTYLE"
@@ -32061,8 +30515,7 @@
 msgstr "Impossibile creare la mappa raster"
 #: ../db/drivers/sqlite/fetch.c:218
-msgid ""
-"SQLite driver: parsing of interval values not implemented; assuming seconds"
+msgid "SQLite driver: parsing of interval values not implemented; assuming seconds"
 msgstr ""
 #: ../db/drivers/sqlite/fetch.c:223
@@ -32348,8 +30801,7 @@
 #: ../db/db.connect/main.c:48
 #, fuzzy
 msgid "Prints/sets general DB connection for current mapset."
-msgstr ""
-"Stampa/imposta la connessione generale al DB per il mapset corrente ed esce."
+msgstr "Stampa/imposta la connessione generale al DB per il mapset corrente ed esce."
 #: ../db/db.connect/main.c:52
 msgid "Print current connection parameters and exit"
@@ -32370,9 +30822,7 @@
 #: ../db/db.connect/main.c:86
 msgid "Default group of database users to which select privilege is granted"
-msgstr ""
-"Gruppo utenti predefinito del database al quale è assegnato il privilegio "
-"select"
+msgstr "Gruppo utenti predefinito del database al quale è assegnato il privilegio select"
 #: ../db/db.connect/main.c:121
 msgid "Database connection not defined. Run db.connect."
@@ -32412,12 +30862,8 @@
 # opzionalmente?
 #: ../db/db.copy/main.c:40
-msgid ""
-"Either 'from_table' (optionally with 'where') can be used or 'select' "
-"option, but not 'from_table' and 'select' at the same time."
-msgstr ""
-"Può essere utilizzata sia l'opzione 'from_table' (in opzione con 'where') "
-"che 'select', ma non contemporaneamente."
+msgid "Either 'from_table' (optionally with 'where') can be used or 'select' option, but not 'from_table' and 'select' at the same time."
+msgstr "Può essere utilizzata sia l'opzione 'from_table' (in opzione con 'where') che 'select', ma non contemporaneamente."
 #: ../db/db.copy/main.c:46
 msgid "Input driver name"
@@ -32445,9 +30891,7 @@
 #: ../db/db.copy/main.c:87
 msgid "Full select statement (only, if 'from_table' and 'where' is not used)"
-msgstr ""
-"Istruzione select completa (solo se 'from_table' a 'where' non sono "
-"utilizzati)"
+msgstr "Istruzione select completa (solo se 'from_table' a 'where' non sono utilizzati)"
 #: ../db/db.copy/main.c:88
 msgid "E.g.: SELECT dedek FROM starobince WHERE obec = 'Frimburg'"
@@ -32546,8 +30990,7 @@
 #: ../db/db.describe/main.c:103
 msgid "Print column names only instead of full column descriptions"
-msgstr ""
-"Mostra soltanto i nomi delle colonne invece che la completa descrizione"
+msgstr "Mostra soltanto i nomi delle colonne invece che la completa descrizione"
 #: ../db/db.describe/main.c:108
 msgid "Print table structure"
@@ -32566,9 +31009,7 @@
 msgstr "Crea un database vuoto"
 #: ../locale/scriptstrings/v.in.gns_to_translate.c:1
-msgid ""
-"Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector "
-"points map."
+msgid "Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector points map."
 msgstr ""
 #: ../locale/scriptstrings/v.in.gns_to_translate.c:4
@@ -32642,9 +31083,7 @@
 #: ../locale/scriptstrings/tr.list_to_translate.c:9
 #: ../locale/scriptstrings/t.list_to_translate.c:8
 #: ../locale/scriptstrings/tr3.extract_to_translate.c:6
-msgid ""
-"A where statement for selected listing without \"WHERE\" e.g: \"start_time < "
-"'2001-01-01' AND end_time > '2001-01-01'\""
+msgid "A where statement for selected listing without \"WHERE\" e.g: \"start_time < '2001-01-01' AND end_time > '2001-01-01'\""
 msgstr ""
 #: ../locale/scriptstrings/tv.list_to_translate.c:10
@@ -32657,8 +31096,7 @@
 #: ../locale/scriptstrings/tr.list_to_translate.c:11
 #: ../locale/scriptstrings/t.list_to_translate.c:10
 #: ../locale/scriptstrings/tr3.list_to_translate.c:11
-msgid ""
-"The field separator character between the columns, default is tabular \"\t\""
+msgid "The field separator character between the columns, default is tabular \"\t\""
 msgstr ""
 #: ../locale/scriptstrings/tv.list_to_translate.c:12
@@ -32671,9 +31109,7 @@
 msgstr "Nome della colonna chiave"
 #: ../locale/scriptstrings/t.time.abs_to_translate.c:1
-msgid ""
-"Set the absolute valid time interval for maps of type raster, vector and "
-"raster3d"
+msgid "Set the absolute valid time interval for maps of type raster, vector and raster3d"
 msgstr ""
 #: ../locale/scriptstrings/t.time.abs_to_translate.c:3
@@ -32692,37 +31128,25 @@
 #: ../locale/scriptstrings/tv.unregister_to_translate.c:5
 #: ../locale/scriptstrings/tv.register_to_translate.c:6
 #: ../locale/scriptstrings/t.time.rel_to_translate.c:8
-msgid ""
-"Id(s)/Name(s) of existing vector map layer or the identifier \"file\" in "
-"case the layer definition is in the input file"
+msgid "Id(s)/Name(s) of existing vector map layer or the identifier \"file\" in case the layer definition is in the input file"
 msgstr ""
 #: ../locale/scriptstrings/t.time.abs_to_translate.c:9
 #: ../locale/scriptstrings/tv.register_to_translate.c:7
 #: ../locale/scriptstrings/t.time.rel_to_translate.c:9
-msgid ""
-"Input file with vector map names, one per line. Additionally the layer, the "
-"start time and the end time can be specified per line"
+msgid "Input file with vector map names, one per line. Additionally the layer, the start time and the end time can be specified per line"
 msgstr ""
 #: ../locale/scriptstrings/t.time.abs_to_translate.c:10
-msgid ""
-"The valid start date and time of the first raster map. Time format is \"yyyy-"
-"mm-dd HH:MM:SS\" or only \"yyyy-mm-dd\", or \"file\" in case the start time "
-"is located in the input file"
+msgid "The valid start date and time of the first raster map. Time format is \"yyyy-mm-dd HH:MM:SS\" or only \"yyyy-mm-dd\", or \"file\" in case the start time is located in the input file"
 msgstr ""
 #: ../locale/scriptstrings/t.time.abs_to_translate.c:11
-msgid ""
-"The valid end date and time of the first raster map. Time format is \"yyyy-"
+msgid "The valid end date and time of the first raster map. Time format is \"yyyy-mm-dd HH:MM:SS\" or only \"yyyy-mm-dd\", or \"file\" in case the start time is located in the input file"
 msgstr ""
 #: ../locale/scriptstrings/t.time.abs_to_translate.c:12
-msgid ""
-"Time increment between maps for valid time interval creation. Interval "
-"format: NNN seconds, minutes, hours, days, weeks, months, years"
+msgid "Time increment between maps for valid time interval creation. Interval format: NNN seconds, minutes, hours, days, weeks, months, years"
 msgstr ""
 #: ../locale/scriptstrings/t.time.abs_to_translate.c:13
@@ -32745,8 +31169,7 @@
 #: ../locale/scriptstrings/t.time.rel_to_translate.c:16
 #: ../locale/scriptstrings/tr3.register_to_translate.c:12
 #: ../locale/scriptstrings/tr.register_to_translate.c:12
-msgid ""
-"Create an interval (start and end time) in case an increment is provided"
+msgid "Create an interval (start and end time) in case an increment is provided"
 msgstr ""
 #: ../locale/scriptstrings/g.manual_to_translate.c:1
@@ -32777,12 +31200,8 @@
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:1
 #, fuzzy
-msgid ""
-"Calculates univariate statistics from a raster map based on vector polygon "
-"map and uploads statistics to new attribute columns."
-msgstr ""
-"Calcola statistiche univariate da un raster basandosi su poligoni vettoriale "
-"e carica le statistiche in una nuova colonna della tabella degli attributi."
+msgid "Calculates univariate statistics from a raster map based on vector polygon map and uploads statistics to new attribute columns."
+msgstr "Calcola statistiche univariate da un raster basandosi su poligoni vettoriale e carica le statistiche in una nuova colonna della tabella degli attributi."
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:5
 msgid "Continue if upload column(s) already exist"
@@ -32814,8 +31233,7 @@
 #: ../locale/scriptstrings/t.topology_to_translate.c:5
 #, fuzzy
-msgid ""
-"Type of the space time dataset, default is space time raster dataset (strds)"
+msgid "Type of the space time dataset, default is space time raster dataset (strds)"
 msgstr "Nome del raster in output"
 #: ../locale/scriptstrings/t.topology_to_translate.c:6
@@ -32830,11 +31248,8 @@
 #: ../locale/scriptstrings/t.remove_to_translate.c:5
 #, fuzzy
-msgid ""
-"Name(s) of the space time or map dataset to be removed from the temporal "
-"database"
-msgstr ""
-"Nome di uno o più mapset esistenti da rimuovere dal percorso di ricerca"
+msgid "Name(s) of the space time or map dataset to be removed from the temporal database"
+msgstr "Nome di uno o più mapset esistenti da rimuovere dal percorso di ricerca"
 #: ../locale/scriptstrings/t.remove_to_translate.c:6
 #: ../locale/scriptstrings/tr.unregister_to_translate.c:5
@@ -33020,8 +31435,7 @@
 #: ../locale/scriptstrings/r.shaded.relief_to_translate.c:1
 msgid "Creates shaded relief map from an elevation map (DEM)."
-msgstr ""
-"Crea mappa dell'ombreggiatura dei rilievi da una mappa dell'elevatione (DEM)"
+msgstr "Crea mappa dell'ombreggiatura dei rilievi da una mappa dell'elevatione (DEM)"
 #: ../locale/scriptstrings/r.shaded.relief_to_translate.c:3
 #: ../locale/scriptstrings/r.plane_to_translate.c:3
@@ -33058,21 +31472,16 @@
 msgstr "File di input"
 #: ../locale/scriptstrings/r.shaded.relief_to_translate.c:10
-msgid ""
-"Set scaling factor (applies to lat./long. locations only, none: scale=1)"
+msgid "Set scaling factor (applies to lat./long. locations only, none: scale=1)"
 msgstr ""
 #: ../locale/scriptstrings/v.db.droprow_to_translate.c:1
 #, fuzzy
 msgid "Removes a vector feature from a vector map through attribute selection."
-msgstr ""
-"Visualizza/imposta la connessione per una mappa vettoriale alla tabella "
-"degli attributi"
+msgstr "Visualizza/imposta la connessione per una mappa vettoriale alla tabella degli attributi"
 #: ../locale/scriptstrings/tv.unregister_to_translate.c:1
-msgid ""
-"Unregister vector map(s) from a specific or from all space time vector "
-"dataset in which it is registered"
+msgid "Unregister vector map(s) from a specific or from all space time vector dataset in which it is registered"
 msgstr ""
 #: ../locale/scriptstrings/tv.unregister_to_translate.c:2
@@ -33082,10 +31491,7 @@
 msgstr "Aggiorna i metadati della mappa vettoriale"
 #: ../locale/scriptstrings/tv.unregister_to_translate.c:4
-msgid ""
-"Name of an existing space time vector dataset. If no name is provided the "
-"vector map(s) are unregistered from all space time datasets in which they "
-"are registered."
+msgid "Name of an existing space time vector dataset. If no name is provided the vector map(s) are unregistered from all space time datasets in which they are registered."
 msgstr ""
 #: ../locale/scriptstrings/tv.unregister_to_translate.c:6
@@ -33116,9 +31522,7 @@
 msgstr ""
 #: ../locale/scriptstrings/tr.aggregate.ds_to_translate.c:1
-msgid ""
-"Aggregated data of an existing space time raster dataset using the temporal "
-"topology of a second space time dataset"
+msgid "Aggregated data of an existing space time raster dataset using the temporal topology of a second space time dataset"
 msgstr ""
 #: ../locale/scriptstrings/tr.aggregate.ds_to_translate.c:2
@@ -33146,9 +31550,7 @@
 msgstr "Nome di una mappa raster esistente"
 #: ../locale/scriptstrings/tr.aggregate.ds_to_translate.c:6
-msgid ""
-"The time intervals from this space time dataset (raster, vector or raster3d) "
-"are used for aggregation computation."
+msgid "The time intervals from this space time dataset (raster, vector or raster3d) are used for aggregation computation."
 msgstr ""
 #: ../locale/scriptstrings/tr.aggregate.ds_to_translate.c:7
@@ -33213,11 +31615,8 @@
 msgstr "Schema del database"
 #: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:1
-msgid ""
-"Renames a column in the attribute table connected to a given vector map."
-msgstr ""
-"Rinomina una colonna nella tabella degli attributi connessa a una mappa "
-"vettoriale"
+msgid "Renames a column in the attribute table connected to a given vector map."
+msgstr "Rinomina una colonna nella tabella degli attributi connessa a una mappa vettoriale"
 #: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:5
 msgid "Old and new name of the column (old,new)"
@@ -33419,12 +31818,8 @@
 #: ../locale/scriptstrings/tv.what.rast_to_translate.c:1
 #, fuzzy
-msgid ""
-"Uploads raster map values at spatial and temporal positions of vector points "
-"to the tables. The maps are registered in space time datasets"
-msgstr ""
-"puntuale"
+msgid "Uploads raster map values at spatial and temporal positions of vector points to the tables. The maps are registered in space time datasets"
 #: ../locale/scriptstrings/tv.what.rast_to_translate.c:2
 #, fuzzy
@@ -33442,24 +31837,15 @@
 msgstr "Aggiorna statistiche per un raster"
 #: ../locale/scriptstrings/tv.what.rast_to_translate.c:7
-msgid ""
-"Name of the vector column to be created and to store sampled raster values. "
-"The use of a column name forces tv.what.rast to sample only values from the "
-"first map found in an interval. Otherwise the raster map names are used as "
-"column names."
+msgid "Name of the vector column to be created and to store sampled raster values. The use of a column name forces tv.what.rast to sample only values from the first map found in an interval. Otherwise the raster map names are used as column names."
 msgstr ""
 #: ../locale/scriptstrings/tv.what.rast_to_translate.c:8
-msgid ""
-"A where statement for attribute selection related to the input dataset "
-"without \"WHERE\" e.g: \"cat < 200\""
+msgid "A where statement for attribute selection related to the input dataset without \"WHERE\" e.g: \"cat < 200\""
 msgstr ""
 #: ../locale/scriptstrings/tv.what.rast_to_translate.c:9
-msgid ""
-"A where statement for temporal selection related to the input dataset "
-"without \"WHERE\" e.g: \"start_time < '2001-01-01' AND end_time > "
-"'2001-01-01'\""
+msgid "A where statement for temporal selection related to the input dataset without \"WHERE\" e.g: \"start_time < '2001-01-01' AND end_time > '2001-01-01'\""
 msgstr ""
 #: ../locale/scriptstrings/tv.what.rast_to_translate.c:10
@@ -33468,9 +31854,7 @@
 msgstr "Mappa raster da usare per impostare il campionamento"
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:1
-msgid ""
-"Calculates univariate statistics on selected table column for a GRASS vector "
-"map."
+msgid "Calculates univariate statistics on selected table column for a GRASS vector map."
 msgstr ""
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:4
@@ -33480,15 +31864,12 @@
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:5
 #, fuzzy
 msgid "Print stats in shell script style"
-msgstr ""
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:6
 #, fuzzy
-msgid ""
-"Name of attribute column on which to calculate statistics (must be numeric)"
-msgstr ""
+msgid "Name of attribute column on which to calculate statistics (must be numeric)"
 #: ../locale/scriptstrings/v.report_to_translate.c:1
 #, fuzzy
@@ -33530,12 +31911,8 @@
 msgstr "Nomi di file di input"
 #: ../locale/scriptstrings/r.reclass.area_to_translate.c:1
-msgid ""
-"Reclasses a raster map greater or less than user specified area size (in "
-"hectares)."
-msgstr ""
-"Riclassifica un raster maggiore o minore della dimensione di un'area "
-"specificata dall'utente (in ettaari)."
+msgid "Reclasses a raster map greater or less than user specified area size (in hectares)."
+msgstr "Riclassifica un raster maggiore o minore della dimensione di un'area specificata dall'utente (in ettaari)."
 #: ../locale/scriptstrings/r.reclass.area_to_translate.c:5
 msgid "Lesser value option that sets the <= area size limit [hectares]"
@@ -33566,18 +31943,11 @@
 msgstr "Nome della mappa vettoriale esistente"
 #: ../locale/scriptstrings/tv.register_to_translate.c:8
-msgid ""
-"The valid start date and time of the first vector map, in case the map has "
-"no valid time (format absolute: \"yyyy-mm-dd HH:MM:SS\", format relative "
-"5.0). Use \"file\" as identifier in case the start time is located in an "
-"input file"
+msgid "The valid start date and time of the first vector map, in case the map has no valid time (format absolute: \"yyyy-mm-dd HH:MM:SS\", format relative 5.0). Use \"file\" as identifier in case the start time is located in an input file"
 msgstr ""
 #: ../locale/scriptstrings/tv.register_to_translate.c:9
-msgid ""
-"The valid end date and time of the first vector map. Absolute time format is "
-"\"yyyy-mm-dd HH:MM:SS\" and \"yyyy-mm-dd\", relative time format id double. "
-"Use \"file\" as identifier in case the end time is located in the input file"
+msgid "The valid end date and time of the first vector map. Absolute time format is \"yyyy-mm-dd HH:MM:SS\" and \"yyyy-mm-dd\", relative time format id double. Use \"file\" as identifier in case the end time is located in the input file"
 msgstr ""
 #: ../locale/scriptstrings/tv.register_to_translate.c:10
@@ -33591,11 +31961,7 @@
 #: ../locale/scriptstrings/tv.register_to_translate.c:11
 #: ../locale/scriptstrings/tr3.register_to_translate.c:10
 #: ../locale/scriptstrings/tr.register_to_translate.c:10
-msgid ""
-"Time increment between maps for valid time interval creation (format "
-"absolute: NNN seconds, minutes, hours, days, weeks, months, years; format "
-"relative is integer: 5), or \"file\" in case the increment is located in an "
-"input file"
+msgid "Time increment between maps for valid time interval creation (format absolute: NNN seconds, minutes, hours, days, weeks, months, years; format relative is integer: 5), or \"file\" in case the increment is located in an input file"
 msgstr ""
 #: ../locale/scriptstrings/tr.extract_to_translate.c:1
@@ -33607,8 +31973,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:1
-msgid ""
-"Drops a column from the attribute table connected to a given vector map."
+msgid "Drops a column from the attribute table connected to a given vector map."
 msgstr ""
 #: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:5
@@ -33617,16 +31982,11 @@
 msgstr "Numero di colonne"
 #: ../locale/scriptstrings/tr.aggregate_to_translate.c:1
-msgid ""
-"Create a new space time raster dataset from the aggregated data of an "
-"existing space time raster dataset"
+msgid "Create a new space time raster dataset from the aggregated data of an existing space time raster dataset"
 msgstr ""
 #: ../locale/scriptstrings/tr.aggregate_to_translate.c:6
-msgid ""
-"The aggregation granularity, format absolue time \"x years, x months, x "
-"weeks, x days, x hours, x minutes, x seconds\" or a double value for "
-"relative time"
+msgid "The aggregation granularity, format absolue time \"x years, x months, x weeks, x days, x hours, x minutes, x seconds\" or a double value for relative time"
 msgstr ""
 #: ../locale/scriptstrings/v.krige_to_translate.c:1
@@ -33721,12 +32081,8 @@
 msgstr ""
 #: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:1
-msgid ""
-"Adds one or more columns to the attribute table connected to a given vector "
-"map."
-msgstr ""
-"Aggiunge una o più colonne alla tabella degli attributi connessa ad una "
-"mappa vettoriale"
+msgid "Adds one or more columns to the attribute table connected to a given vector map."
+msgstr "Aggiunge una o più colonne alla tabella degli attributi connessa ad una mappa vettoriale"
 #: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:5
 msgid "Layer number where to add column(s)"
@@ -33737,9 +32093,7 @@
 msgstr ""
 #: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:7
-msgid ""
-"Data types depend on database backend, but all support VARCHAR(), INT, "
-"DOUBLE PRECISION and DATE"
+msgid "Data types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE"
 msgstr ""
 #: ../locale/scriptstrings/r.pack_to_translate.c:1
@@ -33795,8 +32149,7 @@
 msgstr ""
 #: ../locale/scriptstrings/i.spectral_to_translate.c:1
-msgid ""
-"Displays spectral response at user specified locations in group or images."
+msgid "Displays spectral response at user specified locations in group or images."
 msgstr ""
 #: ../locale/scriptstrings/i.spectral_to_translate.c:4
@@ -33819,16 +32172,11 @@
 #: ../locale/scriptstrings/r.out.xyz_to_translate.c:1
 #, fuzzy
-msgid ""
-"Exports a raster map to a text file as x,y,z values based on cell centers."
-msgstr ""
-"Esporta un raster in un file di testo come valori x,y,z basato sui centri "
-"delle celle"
+msgid "Exports a raster map to a text file as x,y,z values based on cell centers."
+msgstr "Esporta un raster in un file di testo come valori x,y,z basato sui centri delle celle"
 #: ../locale/scriptstrings/r.plane_to_translate.c:1
-msgid ""
-"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
-"point."
+msgid "Creates raster plane map given dip (inclination), aspect (azimuth) and one point."
 msgstr ""
 #: ../locale/scriptstrings/r.plane_to_translate.c:4
@@ -33856,21 +32204,15 @@
 msgstr "Tipo della mappa raster da creare"
-msgid ""
-"Set the relative valid time point or interval for maps of type raster, "
-"vector and raster3d"
+msgid "Set the relative valid time point or interval for maps of type raster, vector and raster3d"
 msgstr ""
 #: ../locale/scriptstrings/t.time.rel_to_translate.c:10
-msgid ""
-"The valid integer start value for all maps, or the identifier \"file\" in "
-"case the start time is located in the input file"
+msgid "The valid integer start value for all maps, or the identifier \"file\" in case the start time is located in the input file"
 msgstr ""
 #: ../locale/scriptstrings/t.time.rel_to_translate.c:11
-msgid ""
-"The valid integer end value for all maps, or the identifier \"file\" in case "
-"the start time is located in the input file"
+msgid "The valid integer end value for all maps, or the identifier \"file\" in case the start time is located in the input file"
 msgstr ""
 #: ../locale/scriptstrings/t.time.rel_to_translate.c:13
@@ -33907,9 +32249,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.in.aster_to_translate.c:1
-msgid ""
-"Georeference, rectify, and import Terra-ASTER imagery and relative DEMs "
-"using gdalwarp."
+msgid "Georeference, rectify, and import Terra-ASTER imagery and relative DEMs using gdalwarp."
 msgstr ""
 #: ../locale/scriptstrings/r.in.aster_to_translate.c:5
@@ -33922,15 +32262,12 @@
 msgstr ""
 #: ../locale/scriptstrings/r.in.aster_to_translate.c:7
-msgid ""
-"List L1A or L1B band to translate (1,2,3n,...), or enter 'all' to translate "
-"all bands"
+msgid "List L1A or L1B band to translate (1,2,3n,...), or enter 'all' to translate all bands"
 msgstr ""
 #: ../locale/scriptstrings/r.in.aster_to_translate.c:8
 #, fuzzy
-msgid ""
-"Base name for output raster map (band number will be appended to base name)"
+msgid "Base name for output raster map (band number will be appended to base name)"
 msgstr "Mostra il titolo del file raster"
 #: ../locale/scriptstrings/db.droptable_to_translate.c:1
@@ -33981,25 +32318,15 @@
 msgstr "Nome di mappa(e) raster esistente(i)"
 #: ../locale/scriptstrings/tr3.register_to_translate.c:6
-msgid ""
-"Input file with raster3d map names, one per line. Additionally the start "
-"time and the end time can be specified per line"
+msgid "Input file with raster3d map names, one per line. Additionally the start time and the end time can be specified per line"
 msgstr ""
 #: ../locale/scriptstrings/tr3.register_to_translate.c:7
-msgid ""
-"The valid start date and time of the first raster3d map, in case the map has "
-"input file"
+msgid "The valid start date and time of the first raster3d map, in case the map has no valid time (format absolute: \"yyyy-mm-dd HH:MM:SS\", format relative 5.0). Use \"file\" as identifier in case the start time is located in an input file"
 msgstr ""
 #: ../locale/scriptstrings/tr3.register_to_translate.c:8
-msgid ""
-"The valid end date and time of the first raster3d map. Absolute time format "
-"is \"yyyy-mm-dd HH:MM:SS\" and \"yyyy-mm-dd\", relative time format id "
-"double. Use \"file\" as identifier in case the end time is located in the "
-"input file"
+msgid "The valid end date and time of the first raster3d map. Absolute time format is \"yyyy-mm-dd HH:MM:SS\" and \"yyyy-mm-dd\", relative time format id double. Use \"file\" as identifier in case the end time is located in the input file"
 msgstr ""
 #: ../locale/scriptstrings/d.rast.edit_to_translate.c:1
@@ -34033,22 +32360,16 @@
 msgstr "Numero massimo di colonne da caricare"
 #: ../locale/scriptstrings/v.db.update_to_translate.c:1
-msgid ""
-"Allows to update a column in the attribute table connected to a vector map."
-msgstr ""
-"Permette di aggiornare una colonna nella tabella degli attributi connessa a "
-"una mappa vettoriale"
+msgid "Allows to update a column in the attribute table connected to a vector map."
+msgstr "Permette di aggiornare una colonna nella tabella degli attributi connessa a una mappa vettoriale"
 #: ../locale/scriptstrings/v.db.update_to_translate.c:5
 #, fuzzy
 msgid "Name of attribute column to update"
-msgstr ""
-"Nome della colonna della tabella degli attributi da utilizzare per le "
-"etichette"
+msgstr "Nome della colonna della tabella degli attributi da utilizzare per le etichette"
 #: ../locale/scriptstrings/v.db.update_to_translate.c:6
-msgid ""
-"Value to update the column with, can be (combination of) other column(s)"
+msgid "Value to update the column with, can be (combination of) other column(s)"
 msgstr ""
 #: ../locale/scriptstrings/v.db.update_to_translate.c:7
@@ -34088,27 +32409,21 @@
 msgstr "Nome del file di output"
 #: ../locale/scriptstrings/tr.out.vtk_to_translate.c:10
-msgid ""
-"A where statement for selected listing e.g: (start_time < '2001-01-01' and "
-"end_time > '2001-01-01')"
+msgid "A where statement for selected listing e.g: (start_time < '2001-01-01' and end_time > '2001-01-01')"
 msgstr ""
 #: ../locale/scriptstrings/tr.out.vtk_to_translate.c:14
-msgid ""
-"Export files using the space time dataset granularity for equidistant time "
-"between maps, where statement will be ignored"
+msgid "Export files using the space time dataset granularity for equidistant time between maps, where statement will be ignored"
 msgstr ""
 #: ../locale/scriptstrings/v.in.sites.all_to_translate.c:1
-msgid ""
-"Converts all old GRASS < Ver5.7 sites maps in current mapset to vector maps."
+msgid "Converts all old GRASS < Ver5.7 sites maps in current mapset to vector maps."
 msgstr ""
 #: ../locale/scriptstrings/r.fillnulls_to_translate.c:1
 #, fuzzy
 msgid "Fills no-data areas in raster maps using spline interpolation."
-msgstr ""
-"Riempi aree senza dati di un raster usando interpolazione spline v.surf.rst "
+msgstr "Riempi aree senza dati di un raster usando interpolazione spline v.surf.rst "
 #: ../locale/scriptstrings/r.fillnulls_to_translate.c:5
 msgid "Spline tension parameter"
@@ -34131,16 +32446,12 @@
 msgstr ""
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:1
-msgid ""
-"Creates and connects a new attribute table to a given layer of an existing "
-"vector map."
+msgid "Creates and connects a new attribute table to a given layer of an existing vector map."
 msgstr ""
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:5
 msgid "Name of new attribute table (default: vector map name)"
-msgstr ""
-"Nome della nuova tabella degli attributi (predefinito: nome della mappa "
-"vettoriale)"
+msgstr "Nome della nuova tabella degli attributi (predefinito: nome della mappa vettoriale)"
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:6
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:8
@@ -34153,30 +32464,22 @@
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:7
 #, fuzzy
 msgid "Layer number where to add new attribute table"
-msgstr ""
-"Mappa vettoriale per la quale aggiungere una nuova tabella degli attributi"
+msgstr "Mappa vettoriale per la quale aggiungere una nuova tabella degli attributi"
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:10
 msgid "Name and type of the new column(s)"
 msgstr ""
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:11
-msgid ""
-"Types depend on database backend, but all support VARCHAR(), INT, DOUBLE "
-"PRECISION and DATE. Example: \"label varchar(250), type integer\""
+msgid "Types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE. Example: \"label varchar(250), type integer\""
 msgstr ""
 #: ../locale/scriptstrings/tr.unregister_to_translate.c:1
-msgid ""
-"Unregister raster map(s) from a specific or from all space time raster "
+msgid "Unregister raster map(s) from a specific or from all space time raster dataset in which it is registered"
 msgstr ""
 #: ../locale/scriptstrings/tr.unregister_to_translate.c:4
-msgid ""
-"Name of an existing space time raster dataset. If no name is provided the "
-"raster map(s) are unregistered from all space time datasets in which they "
-"are registered."
+msgid "Name of an existing space time raster dataset. If no name is provided the raster map(s) are unregistered from all space time datasets in which they are registered."
 msgstr ""
 #: ../locale/scriptstrings/tr.unregister_to_translate.c:6
@@ -34199,9 +32502,7 @@
 #: ../locale/scriptstrings/v.what.vect_to_translate.c:1
 msgid "Uploads vector values at positions of vector points to the table."
-msgstr ""
-"Carica valori di un vettoriale nella tabella degli attributi di un "
-"vettoriale puntuale"
+msgstr "Carica valori di un vettoriale nella tabella degli attributi di un vettoriale puntuale"
 #: ../locale/scriptstrings/v.what.vect_to_translate.c:7
 #, fuzzy
@@ -34211,9 +32512,7 @@
 #: ../locale/scriptstrings/v.what.vect_to_translate.c:8
 #, fuzzy
 msgid "Name of attribute column to be queried"
-msgstr ""
-"etichette"
 #: ../locale/scriptstrings/v.what.vect_to_translate.c:9
 msgid "Maximum query distance in map units"
@@ -34249,9 +32548,7 @@
 #: ../locale/scriptstrings/db.test_to_translate.c:1
 msgid "Test database driver, database must exist and set by db.connect."
-msgstr ""
-"Prova il driver del database, il database deve esistere e impostato "
-"utilizzando db.connect"
+msgstr "Prova il driver del database, il database deve esistere e impostato utilizzando db.connect"
 #: ../locale/scriptstrings/db.test_to_translate.c:4
 msgid "Test name"
@@ -34259,9 +32556,7 @@
 #: ../locale/scriptstrings/tr.univar_to_translate.c:1
 #, fuzzy
-msgid ""
-"Calculates univariate statistics from the non-null cells for each registred "
-"raster map of a space time raster dataset"
+msgid "Calculates univariate statistics from the non-null cells for each registred raster map of a space time raster dataset"
 msgstr "Calcola le statistiche univariate per le celle non nulle di un raster"
 #: ../locale/scriptstrings/tr.univar_to_translate.c:6
@@ -34269,20 +32564,15 @@
 msgstr ""
 #: ../locale/scriptstrings/v.convert.all_to_translate.c:1
-msgid ""
-"Converts all older versions of GRASS vector maps in current mapset to "
-"current format."
-msgstr ""
-"Converte tutte le versioni più  vecchie delle mappe vettoriali di GRASS del "
-"mapset corrente nel formato corrente"
+msgid "Converts all older versions of GRASS vector maps in current mapset to current format."
+msgstr "Converte tutte le versioni più  vecchie delle mappe vettoriali di GRASS del mapset corrente nel formato corrente"
 #: ../locale/scriptstrings/g.extension.rebuild.all_to_translate.c:1
 msgid "Rebuilds all locally installed GRASS Addons extensions."
 msgstr ""
 #: ../locale/scriptstrings/g.extension.rebuild.all_to_translate.c:2
-msgid ""
-"By default only extensions built against different GIS Library are rebuilt."
+msgid "By default only extensions built against different GIS Library are rebuilt."
 msgstr ""
 #: ../locale/scriptstrings/g.extension.rebuild.all_to_translate.c:4
@@ -34311,16 +32601,11 @@
 #: ../locale/scriptstrings/tr3.unregister_to_translate.c:1
-msgid ""
-"Unregister raster3d map(s) from a specific or from all space time raster3d "
+msgid "Unregister raster3d map(s) from a specific or from all space time raster3d dataset in which it is registered"
 msgstr ""
 #: ../locale/scriptstrings/tr3.unregister_to_translate.c:4
-msgid ""
-"Name of an existing space time raster3d dataset. If no name is provided the "
-"raster3d map(s) are unregistered from all space time datasets in which they "
-"are registered."
+msgid "Name of an existing space time raster3d dataset. If no name is provided the raster3d map(s) are unregistered from all space time datasets in which they are registered."
 msgstr ""
 #: ../locale/scriptstrings/tr3.unregister_to_translate.c:5
@@ -34410,9 +32695,7 @@
 msgstr ""
 #: ../locale/scriptstrings/m.proj_to_translate.c:19
-msgid ""
-"Output long/lat in decimal degrees, or other projections with many decimal "
-"places"
+msgid "Output long/lat in decimal degrees, or other projections with many decimal places"
 msgstr ""
 #: ../locale/scriptstrings/m.proj_to_translate.c:21
@@ -34464,9 +32747,7 @@
 #: ../locale/scriptstrings/v.db.droptable_to_translate.c:6
 #, fuzzy
 msgid "Table name (default: vector map name)"
-msgstr ""
-"vettoriale)"
 #: ../locale/scriptstrings/r.grow_to_translate.c:3
 #, fuzzy
@@ -34475,12 +32756,8 @@
 #: ../locale/scriptstrings/r.buffer_to_translate.c:1
 #, fuzzy
-msgid ""
-"Creates a raster map showing buffer zones surrounding cells that contain non-"
-"NULL category values."
-msgstr ""
-"Crea un raster mostrando una zona di buffer intorno alle celle che "
-"contengono valori non nulli."
+msgid "Creates a raster map showing buffer zones surrounding cells that contain non-NULL category values."
+msgstr "Crea un raster mostrando una zona di buffer intorno alle celle che contengono valori non nulli."
 msgid "List space time and map datasets"
@@ -34492,15 +32769,11 @@
 msgstr "Nome del nuovo database"
 #: ../locale/scriptstrings/t.list_to_translate.c:6
-msgid ""
-"Sort the space time dataset by category. Columns number_of_maps and "
-"granularity only available fpr space time datasets"
+msgid "Sort the space time dataset by category. Columns number_of_maps and granularity only available fpr space time datasets"
 msgstr ""
 #: ../locale/scriptstrings/t.list_to_translate.c:7
-msgid ""
-"Which columns should be printed to stdout. Columns number_of_maps and "
-"granularity only available for space time datasets"
+msgid "Which columns should be printed to stdout. Columns number_of_maps and granularity only available for space time datasets"
 msgstr ""
 #: ../locale/scriptstrings/t.list_to_translate.c:11
@@ -34521,9 +32794,7 @@
 msgstr "Creazione"
 #: ../locale/scriptstrings/tr.series_to_translate.c:1
-msgid ""
-"Performe different aggregation algorithms from r.series on all or a subset "
-"of raster maps in a space time raster dataset"
+msgid "Performe different aggregation algorithms from r.series on all or a subset of raster maps in a space time raster dataset"
 msgstr ""
 #: ../locale/scriptstrings/tr.series_to_translate.c:5
@@ -34537,8 +32808,7 @@
 msgstr ""
 #: ../locale/scriptstrings/tr.series_to_translate.c:8
-msgid ""
-"Assign the space time raster dataset start and end time to the output map"
+msgid "Assign the space time raster dataset start and end time to the output map"
 msgstr ""
 #: ../locale/scriptstrings/i.image.mosaic_to_translate.c:1
@@ -34551,10 +32821,8 @@
 #: ../locale/scriptstrings/v.out.gps_to_translate.c:1
 #, fuzzy
-msgid ""
-"Exports a vector map to a GPS receiver or file format supported by GPSBabel."
-msgstr ""
-"Esporta un vettore in un GPS o un file con un formato supportato da GPSBabel"
+msgid "Exports a vector map to a GPS receiver or file format supported by GPSBabel."
+msgstr "Esporta un vettore in un GPS o un file con un formato supportato da GPSBabel"
 #: ../locale/scriptstrings/v.out.gps_to_translate.c:4
 msgid "GPS"
@@ -34587,9 +32855,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.tileset_to_translate.c:1
-msgid ""
-"Produces tilings of the source projection for use in the destination region "
-"and projection."
+msgid "Produces tilings of the source projection for use in the destination region and projection."
 msgstr ""
 #: ../locale/scriptstrings/r.tileset_to_translate.c:3
@@ -34606,8 +32872,7 @@
 msgstr ""
 #: ../locale/scriptstrings/r.tileset_to_translate.c:6
-msgid ""
-"Name of region to use instead of current region for bounds and resolution"
+msgid "Name of region to use instead of current region for bounds and resolution"
 msgstr ""
 #: ../locale/scriptstrings/r.tileset_to_translate.c:7
@@ -34655,9 +32920,7 @@
 msgstr "Usa la versione del programma a bassa memoria"
 #: ../locale/scriptstrings/tr.export_to_translate.c:10
-msgid ""
-"A where statement for selected listing e.g: start_time < '2001-01-01' and "
-"end_time > '2001-01-01\"'"
+msgid "A where statement for selected listing e.g: start_time < '2001-01-01' and end_time > '2001-01-01\"'"
 msgstr ""
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:1
@@ -34783,8 +33046,7 @@
 msgstr ""
 #: ../locale/scriptstrings/i.tasscap_to_translate.c:1
-msgid ""
-"Performs Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data."
+msgid "Performs Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data."
 msgstr ""
 #: ../locale/scriptstrings/i.tasscap_to_translate.c:4
@@ -34839,24 +33101,15 @@
 #: ../locale/scriptstrings/tr.register_to_translate.c:6
-msgid ""
-"Input file with raster map names, one per line. Additionally the start time "
-"and the end time can be specified per line"
+msgid "Input file with raster map names, one per line. Additionally the start time and the end time can be specified per line"
 msgstr ""
 #: ../locale/scriptstrings/tr.register_to_translate.c:7
-msgid ""
-"The valid start date and time of the first raster map, in case the map has "
-"input file"
+msgid "The valid start date and time of the first raster map, in case the map has no valid time (format absolute: \"yyyy-mm-dd HH:MM:SS\", format relative 5.0). Use \"file\" as identifier in case the start time is located in an input file"
 msgstr ""
 #: ../locale/scriptstrings/tr.register_to_translate.c:8
-msgid ""
-"The valid end date and time of the first raster map. Absolute time format is "
+msgid "The valid end date and time of the first raster map. Absolute time format is \"yyyy-mm-dd HH:MM:SS\" and \"yyyy-mm-dd\", relative time format id double. Use \"file\" as identifier in case the end time is located in the input file"
 msgstr ""
 #: ../locale/scriptstrings/db.dropcolumn_to_translate.c:1
@@ -34869,9 +33122,7 @@
 msgstr "Converte mappe raster 3D in mappe raster 2D"
 #: ../locale/scriptstrings/t.sample_to_translate.c:1
-msgid ""
-"Sample the input space time dataset with a sample space time dataset and "
-"print the result to stdout"
+msgid "Sample the input space time dataset with a sample space time dataset and print the result to stdout"
 msgstr ""
 #: ../locale/scriptstrings/t.sample_to_translate.c:5
@@ -34891,15 +33142,11 @@
 #: ../locale/scriptstrings/t.sample_to_translate.c:8
 #, fuzzy
-msgid ""
-"Type of the input space time dataset, default is space time raster dataset "
-"(strds)"
+msgid "Type of the input space time dataset, default is space time raster dataset (strds)"
 #: ../locale/scriptstrings/t.sample_to_translate.c:9
-msgid ""
-"Type of the sample space time dataset, default is space time raster dataset "
-"(strds)"
+msgid "Type of the sample space time dataset, default is space time raster dataset (strds)"
 msgstr ""
 #: ../locale/scriptstrings/t.sample_to_translate.c:10
@@ -34908,15 +33155,11 @@
 msgstr "Testo da usare per il titolo della mappa"
 #: ../locale/scriptstrings/t.sample_to_translate.c:11
-msgid ""
-"The field separator character between the columns, default is tabular \" | "
-"\". Do not use \",\" as this char is reserved to list several map ids in a "
-"sample granule"
+msgid "The field separator character between the columns, default is tabular \" | \". Do not use \",\" as this char is reserved to list several map ids in a sample granule"
 msgstr ""
 #: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:1
-msgid ""
-"Brovey transform to merge multispectral and high-res panchromatic channels"
+msgid "Brovey transform to merge multispectral and high-res panchromatic channels"
 msgstr ""
 #: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:3
@@ -34968,9 +33211,7 @@
 msgstr ""
 #: ../locale/scriptstrings/g.extension_to_translate.c:2
-msgid ""
-"Downloads, installs extensions from GRASS Addons SVN repository into local "
-"GRASS installation or removes installed extensions."
+msgid "Downloads, installs extensions from GRASS Addons SVN repository into local GRASS installation or removes installed extensions."
 msgstr ""
 #: ../locale/scriptstrings/g.extension_to_translate.c:6
@@ -34992,16 +33233,12 @@
 #: ../locale/scriptstrings/g.extension_to_translate.c:12
 #, fuzzy
-msgid ""
-"List available extensions in the GRASS Addons SVN repository including "
-"module description"
+msgid "List available extensions in the GRASS Addons SVN repository including module description"
 msgstr "Visualizza i formati supportati ed esci"
 #: ../locale/scriptstrings/g.extension_to_translate.c:14
 #, fuzzy
-msgid ""
-"List available extensions in the GRASS Addons SVN repository (shell script "
-"style)"
+msgid "List available extensions in the GRASS Addons SVN repository (shell script style)"
 #: ../locale/scriptstrings/g.extension_to_translate.c:16
@@ -35067,9 +33304,7 @@
 #: ../locale/scriptstrings/tr3.list_to_translate.c:9
-msgid ""
-"A where statement for selected listing e.g: \"start_time < '2001-01-01' and "
-"end_time > '2001-01-01'\""
+msgid "A where statement for selected listing e.g: \"start_time < '2001-01-01' and end_time > '2001-01-01'\""
 msgstr ""
 #: ../locale/scriptstrings/t.support_to_translate.c:1
@@ -35093,17 +33328,12 @@
 #: ../locale/scriptstrings/t.support_to_translate.c:10
-msgid ""
-"Update metadata information, temporal and spatial extent from registered maps"
+msgid "Update metadata information, temporal and spatial extent from registered maps"
 msgstr ""
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:1
-msgid ""
-"Dissolves boundaries between adjacent areas sharing a common category number "
-"or attribute."
-msgstr ""
-"Dissolve i confini tra aree adiacenti che condividono categorie o attributi "
-"comuni."
+msgid "Dissolves boundaries between adjacent areas sharing a common category number or attribute."
+msgstr "Dissolve i confini tra aree adiacenti che condividono categorie o attributi comuni."
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:4
 msgid "dissolve"
@@ -35138,250 +33368,244 @@
 msgid "Percent to brighten"
 msgstr ""
-#~ msgid "Input grid3 filename"
-#~ msgstr "Nome del file grid3 di input"
-#~ msgid "Grid3 <%s> not found %s"
-#~ msgstr "Grid3 <%s> non trovato %s"
 #, fuzzy
-#~ msgid "Input raster map with specific yield in [1/m]"
-#~ msgstr "Nessuna mappa in input specificata"
+msgid "Input raster map with specific yield in [1/m]"
+msgstr "Nessuna mappa in input specificata"
 #, fuzzy
-#~ msgid "Raster map <%s> is not valid"
-#~ msgstr "Mappa raster <%s> non trovata"
+msgid "Raster map <%s> is not valid"
+msgstr "Mappa raster <%s> non trovata"
 #, fuzzy
-#~ msgid "Print raster map resolution (NS-res, EW-res) only"
-#~ msgstr "Stampa solo la risoluzione della mappa raster (NS-ris, EO-ris)"
+msgid "If not given read from standard input"
+msgstr "File raster ascii da importare"
-#~ msgid "Print raster map type only"
-#~ msgstr "Stampa solo il tipo di mappa raster"
-#~ msgid "Print map region only"
-#~ msgstr "Stampa solo la regione della mappa"
-#~ msgid "Print map title only"
-#~ msgstr "Stampa solo il titolo della mappa"
 #, fuzzy
-#~ msgid "If not given read from standard input"
-#~ msgstr "File raster ascii da importare"
+msgid "Print basic info in shell script style"
+msgstr "Stampa in stile script per la shell"
-#~ msgid "Reading coordinates from file."
-#~ msgstr "Lettura delle coordinate dal file"
 #, fuzzy
-#~ msgid "Unable to open file with coordinates <%s>"
-#~ msgstr "Non è possibile trovare il file con le coordinate <%s>"
+msgid "Projection:"
+msgstr "Sto disegnando ..."
-#~ msgid "Error reading coordinates file"
-#~ msgstr "Errore nella lettura del file delle coordinate"
-#~ msgid "Number of points that have been entered [%d]"
-#~ msgstr "Numero di punti che sono stati inseriti [%d]"
-#~ msgid "Error creating transformation"
-#~ msgstr "Errore nel creare la trasformazione"
 #, fuzzy
-#~ msgid "Print basic info in shell script style"
-#~ msgstr "Stampa in stile script per la shell"
+msgid "DBMI-OGR driver error:\n"
+msgstr "Errore del driver DBMI-MySQL:\n"
 #, fuzzy
-#~ msgid "Projection:"
-#~ msgstr "Sto disegnando ..."
+msgid "relative"
+msgstr "Creazione"
-#~ msgid "Column name (will be updated by raster values)"
-#~ msgstr "Nome della colonna (che sarà aggiornata con i valori raster)"
-#~ msgid "DBMI-MySQL driver error:\n"
-#~ msgstr "Errore del driver DBMI-MySQL:\n"
-#~ msgid "Cannot select data: \n"
-#~ msgstr "Non riesco a seleziona i dati:\n"
 #, fuzzy
-#~ msgid "DBMI-OGR driver error:\n"
+msgid "Display the HTML man pages of GRASS GIS"
+msgstr "Visualizza la pagina di supporto HTML di GRASS "
 #, fuzzy
-#~ msgid "relative"
-#~ msgstr "Creazione"
+msgid "Join column in table"
+msgstr "Colonna sconosciuta <%s> nella tabella <%s>"
-#~ msgid "Computing means for band %d..."
-#~ msgstr "Calcolo delle medie per la banda %d in corso..."
-#~ msgid "Unable to allocate memory for raster row"
-#~ msgstr "Impossibile allocare memoria per la riga raster"
-#~ msgid "Transforming <%s>..."
-#~ msgstr "Sto trasformando <%s>..."
 #, fuzzy
-#~ msgid "Display the HTML man pages of GRASS GIS"
-#~ msgstr "Visualizza la pagina di supporto HTML di GRASS "
+msgid "Unable to parse '%s'\n"
+msgstr "impossibile leggere %s"
 #, fuzzy
-#~ msgid "Join column in table"
-#~ msgstr "Colonna sconosciuta <%s> nella tabella <%s>"
+msgid "Driver <%s> doesn't support creating new fields"
+msgstr "Gruppo <%s> non esiste ancora. Sto creandolo..."
 #, fuzzy
-#~ msgid "Unable to parse '%s'\n"
-#~ msgstr "impossibile leggere %s"
+msgid "Unable to add new field <%s>"
+msgstr "Impossibile aprire il file label <%s> nel mapset <%s>"
 #, fuzzy
-#~ msgid "Driver <%s> doesn't support creating new fields"
-#~ msgstr "Gruppo <%s> non esiste ancora. Sto creandolo..."
+msgid "Name of raster map from which to copy color table"
+msgstr "Nome della mappa raster da cui copiare la tabella colore"
 #, fuzzy
-#~ msgid "Unable to add new field <%s>"
-#~ msgstr "Impossibile aprire il file label <%s> nel mapset <%s>"
+msgid "Name of file containing rules"
+msgstr "Nome del file contenente i comandi SQL"
 #, fuzzy
-#~ msgid "Name of raster map from which to copy color table"
-#~ msgstr "Nome della mappa raster da cui copiare la tabella colore"
+msgid "Creating support files for <%s>"
+msgstr "Errore nella lettura del file dbmscap\n"
 #, fuzzy
-#~ msgid "Name of file containing rules"
-#~ msgstr "Nome del file contenente i comandi SQL"
+msgid "Title for new raster file."
+msgstr "Titolo per la nuova mappa raster"
 #, fuzzy
-#~ msgid "Creating support files for <%s>"
-#~ msgstr "Errore nella lettura del file dbmscap\n"
+msgid "Unable it load G3d range"
+msgstr "Impossibile leggere il file range"
 #, fuzzy
-#~ msgid "Title for new raster file."
-#~ msgstr "Titolo per la nuova mappa raster"
+msgid "\raster\" and \"volume\" options are mutually exclusive"
+msgstr "Le opzioni \"color\", \"rules\", e \"raster\" sono mutualmente esclusive"
 #, fuzzy
-#~ msgid "Unable it load G3d range"
-#~ msgstr "Impossibile leggere il file range"
+msgid "Exports the color table associated with a raster3d map layer."
+msgstr "Esporta la tavola dei colori associata ad un tematismo raster"
 #, fuzzy
-#~ msgid "\raster\" and \"volume\" options are mutually exclusive"
-#~ msgstr ""
-#~ "Le opzioni \"color\", \"rules\", e \"raster\" sono mutualmente esclusive"
+msgid "Could not close RASTER3D map"
+msgstr "Impossibile chiudere la mappa RASTER3D"
 #, fuzzy
-#~ msgid "Exports the color table associated with a raster3d map layer."
-#~ msgstr "Esporta la tavola dei colori associata ad un tematismo raster"
+msgid "Could not close RASTER3D map <%s>"
+msgstr "impossibile chiudere la mappa RASTER3D <%s>"
 #, fuzzy
-#~ msgid "Could not close RASTER3D map"
-#~ msgstr "Impossibile chiudere la mappa RASTER3D"
+msgid "Name for v5d output file"
+msgstr "Nome del file v5d di output"
 #, fuzzy
-#~ msgid "Could not close RASTER3D map <%s>"
-#~ msgstr "impossibile chiudere la mappa RASTER3D <%s>"
+msgid "Converts a 3D raster map into a 3-dimensional Vis5D file."
+msgstr "Esporta raster GRASS 3D in un file Vis5D tridimensionale"
 #, fuzzy
-#~ msgid "Name for v5d output file"
-#~ msgstr "Nome del file v5d di output"
+msgid "Name for output flowline density raster map"
+msgstr "Nome della tabella in output"
 #, fuzzy
-#~ msgid "Converts a 3D raster map into a 3-dimensional Vis5D file."
-#~ msgstr "Esporta raster GRASS 3D in un file Vis5D tridimensionale"
+msgid "Remove dangles:"
+msgstr "Rimuovi i doppi"
 #, fuzzy
-#~ msgid "Name for output flowline density raster map"
-#~ msgstr "Nome della tabella in output"
+msgid "Unable to create 3D vector and attribute table at same time"
+msgstr "impossibile aprire <%s>"
 #, fuzzy
-#~ msgid "Remove dangles:"
-#~ msgstr "Rimuovi i doppi"
+msgid "Coordinates"
+msgstr "Coordinate non validi"
 #, fuzzy
-#~ msgid "Unable to create 3D vector and attribute table at same time"
-#~ msgstr "impossibile aprire <%s>"
+msgid "vector, interpolation, kriging"
+msgstr "Mostra il titolo del file raster"
 #, fuzzy
-#~ msgid "Coordinates"
-#~ msgstr "Coordinate non validi"
+msgid "reclass raster output map"
+msgstr "Nome della mappa di output"
 #, fuzzy
-#~ msgid "vector, interpolation, kriging"
-#~ msgstr "Mostra il titolo del file raster"
+msgid "Vector map for which to drop vector objects"
+msgstr "Non riesco a descrivere la tabella"
 #, fuzzy
-#~ msgid "reclass raster output map"
-#~ msgstr "Nome della mappa di output"
+msgid "Layer of attribute table to use for selection"
+msgstr "Nome della mappa raster da utilizzare per <%s>"
 #, fuzzy
-#~ msgid "Vector map for which to drop vector objects"
-#~ msgstr "Non riesco a descrivere la tabella"
+msgid "Raster map to use as mask"
+msgstr "Mappa(e) raster da leggere"
 #, fuzzy
-#~ msgid "Layer of attribute table to use for selection"
-#~ msgstr "Nome della mappa raster da utilizzare per <%s>"
+msgid "Overwrite existing file"
+msgstr "Sovrascrivi la MASK esistente"
 #, fuzzy
-#~ msgid "Raster map to use as mask"
-#~ msgstr "Mappa(e) raster da leggere"
+msgid "Name of input vector polygon map"
+msgstr "Nome di un file vettoriale in output"
 #, fuzzy
-#~ msgid "Overwrite existing file"
-#~ msgstr "Sovrascrivi la MASK esistente"
+msgid "raster, import, copying"
+msgstr "File di input"
 #, fuzzy
-#~ msgid "Name of input vector polygon map"
-#~ msgstr "Nome di un file vettoriale in output"
+msgid "raster, export, copying"
 #, fuzzy
-#~ msgid "raster, import, copying"
-#~ msgstr "File di input"
+msgid "Name of input elevation map"
+msgstr "Nome di  2-%d mappe raster in input"
 #, fuzzy
-#~ msgid "raster, export, copying"
+msgid "zenith"
+msgstr "Lunghezza: %f\n"
 #, fuzzy
-#~ msgid "Name of input elevation map"
-#~ msgstr "Nome di  2-%d mappe raster in input"
+msgid "topographic correction method"
+msgstr "Visualizza il raster della direzione"
 #, fuzzy
-#~ msgid "zenith"
-#~ msgstr "Lunghezza: %f\n"
+msgid "Elevation file of unknown type"
+msgstr "Coordinate dell'altezza di un punto nel piano"
+msgid "Converts a 3D raster map layer into an ASCII text file"
+msgstr "Converte un raster 3D in un file di testo ASCII"
+msgid "Convert a 3D ASCII raster text file into a (binary) 3D raster map layer"
+msgstr "Converte un file testuale raster ASCII 3D in un layer raster 3D (binario)"
+msgid "Converts 3D raster maps (RASTER3D) into the VTK-Ascii format"
+msgstr "Converte una mappa raster 3D (RASTER3D) nel formato VTK-Ascii"
 #, fuzzy
-#~ msgid "topographic correction method"
-#~ msgstr "Visualizza il raster della direzione"
+msgid "unable to close top raster map"
+msgstr "impossibile chiudere la mappa raster superiore"
 #, fuzzy
-#~ msgid "Elevation file of unknown type"
-#~ msgstr "Coordinate dell'altezza di un punto nel piano"
+msgid "unable to close bottom raster map"
+msgstr "impossibile chiudere la mappa raster inferiore"
-#~ msgid "Converts a 3D raster map layer into an ASCII text file"
-#~ msgstr "Converte un raster 3D in un file di testo ASCII"
+msgid ""
+"Cannot create mask file: RASTER3D_MASK already exists!\n"
+" Use 'g.remove rast3d=RASTER3D_MASK' to remove the existing mask."
+msgstr ""
+"Impossibile creare la mask. MASK RASTER3D già esistente!\n"
+"Usa il comando 'g.remove rast3d=RASTER3D MASK' per rimuovere la maschera esistente"
-#~ msgid ""
-#~ "Convert a 3D ASCII raster text file into a (binary) 3D raster map layer"
-#~ msgstr ""
-#~ "Converte un file testuale raster ASCII 3D in un layer raster 3D (binario)"
+msgid "Name of input base raster map (elevation or ilumination)"
+msgstr "Nome del raster in input (elevazione o illuminazione)"
-#~ msgid "Converts 3D raster maps (RASTER3D) into the VTK-Ascii format"
-#~ msgstr "Converte una mappa raster 3D (RASTER3D) nel formato VTK-Ascii"
+#~ msgid "Input grid3 filename"
+#~ msgstr "Nome del file grid3 di input"
-#, fuzzy
-#~ msgid "unable to close top raster map"
-#~ msgstr "impossibile chiudere la mappa raster superiore"
+#~ msgid "Grid3 <%s> not found %s"
+#~ msgstr "Grid3 <%s> non trovato %s"
-#, fuzzy
-#~ msgid "unable to close bottom raster map"
-#~ msgstr "impossibile chiudere la mappa raster inferiore"
+#~ msgid "Print raster map resolution (NS-res, EW-res) only"
+#~ msgstr "Stampa solo la risoluzione della mappa raster (NS-ris, EO-ris)"
-#~ msgid ""
-#~ "Cannot create mask file: RASTER3D_MASK already exists!\n"
-#~ " Use 'g.remove rast3d=RASTER3D_MASK' to remove the existing mask."
-#~ msgstr ""
-#~ "Impossibile creare la mask. MASK RASTER3D già esistente!\n"
-#~ "Usa il comando 'g.remove rast3d=RASTER3D MASK' per rimuovere la maschera "
-#~ "esistente"
+#~ msgid "Print raster map type only"
+#~ msgstr "Stampa solo il tipo di mappa raster"
-#~ msgid "Name of input base raster map (elevation or ilumination)"
-#~ msgstr "Nome del raster in input (elevazione o illuminazione)"
+#~ msgid "Print map region only"
+#~ msgstr "Stampa solo la regione della mappa"
+#~ msgid "Print map title only"
+#~ msgstr "Stampa solo il titolo della mappa"
+#~ msgid "Reading coordinates from file."
+#~ msgstr "Lettura delle coordinate dal file"
+#~ msgid "Unable to open file with coordinates <%s>"
+#~ msgstr "Non è possibile trovare il file con le coordinate <%s>"
+#~ msgid "Error reading coordinates file"
+#~ msgstr "Errore nella lettura del file delle coordinate"
+#~ msgid "Number of points that have been entered [%d]"
+#~ msgstr "Numero di punti che sono stati inseriti [%d]"
+#~ msgid "Error creating transformation"
+#~ msgstr "Errore nel creare la trasformazione"
+#~ msgid "Column name (will be updated by raster values)"
+#~ msgstr "Nome della colonna (che sarà aggiornata con i valori raster)"
+#~ msgid "DBMI-MySQL driver error:\n"
+#~ msgstr "Errore del driver DBMI-MySQL:\n"
+#~ msgid "Cannot select data: \n"
+#~ msgstr "Non riesco a seleziona i dati:\n"
+#~ msgid "Computing means for band %d..."
+#~ msgstr "Calcolo delle medie per la banda %d in corso..."
+#~ msgid "Unable to allocate memory for raster row"
+#~ msgstr "Impossibile allocare memoria per la riga raster"
+#~ msgid "Transforming <%s>..."
+#~ msgstr "Sto trasformando <%s>..."
 #~ msgid "Surface area estimation for rasters."
 #~ msgstr "Stima della superfice per raster"
@@ -35474,8 +33698,7 @@
 #~ msgstr "Errore nell'apertura della mappa g3d <%s>"
 #~ msgid "\"color\", \"rules\", and \"raster\" options are mutually exclusive"
-#~ msgstr ""
+#~ msgstr "Le opzioni \"color\", \"rules\", e \"raster\" sono mutualmente esclusive"
 #~ msgid "-g and -a flags are mutually exclusive"
 #~ msgstr "I flag -g e -a sono mutualmente esclusivi"
@@ -35545,12 +33768,8 @@
 #~ msgid "Error closing g3d vector map."
 #~ msgstr "Errore nella chiusura della mappa vettoriale g3d."
-#~ msgid ""
-#~ "The 2d and 3d region settings are different. The g3d settings are used to "
-#~ "adjust the 2d region."
-#~ msgstr ""
-#~ "La regione 2D e 3D hanno impostazioni differenti. Saranno usate le "
-#~ "impostazioni g3d per aggiustare la regione 2D"
+#~ msgid "The 2d and 3d region settings are different. The g3d settings are used to adjust the 2d region."
+#~ msgstr "La regione 2D e 3D hanno impostazioni differenti. Saranno usate le impostazioni g3d per aggiustare la regione 2D"
 #, fuzzy
 #~ msgid "unable to close input 3d raster map"
@@ -35573,23 +33792,14 @@
 #~ msgid "Error while writing grid. Disk full?"
 #~ msgstr "Errore nella scrittura della grid. Disco pieno?"
-#~ msgid ""
-#~ "Converts co-ordinate system descriptions (i.e. projection information) "
-#~ "between various formats (including GRASS format)."
-#~ msgstr ""
-#~ "Converte le descrizioni del sistema di coordinate (es. informazioni sulla "
-#~ "proiezione) utilizzando diversi formati (incluso quello di GRASS)."
+#~ msgid "Converts co-ordinate system descriptions (i.e. projection information) between various formats (including GRASS format)."
+#~ msgstr "Converte le descrizioni del sistema di coordinate (es. informazioni sulla proiezione) utilizzando diversi formati (incluso quello di GRASS)."
-#, fuzzy
 #~ msgid "Create/Edit"
 #~ msgstr "Crea/Modifica"
-#~ msgid ""
-#~ "Create new projection files (modifies current location unless 'location' "
-#~ "option specified)"
-#~ msgstr ""
-#~ "Crea un nuovo file contenente le informazioni sulla proiezione (modifica "
-#~ "la location attuale a meno che l'opzione 'location' venga specificata)"
+#~ msgid "Create new projection files (modifies current location unless 'location' option specified)"
+#~ msgstr "Crea un nuovo file contenente le informazioni sulla proiezione (modifica la location attuale a meno che l'opzione 'location' venga specificata)"
 #~ msgid "Location %s created!"
 #~ msgstr "Location %s creata!"
@@ -35649,20 +33859,14 @@
 #~ msgid "Field separator"
 #~ msgstr "Separatore di campo"
-#~ msgid ""
-#~ "A single vector map can be connected to multiple database tables. This "
-#~ "number determines which table to use."
-#~ msgstr ""
-#~ "Una singola mappa vettoriale può essere connessa a più tabelle di un "
-#~ "database. Questo numero determina quale tabella viene utilizzata."
+#~ msgid "A single vector map can be connected to multiple database tables. This number determines which table to use."
+#~ msgstr "Una singola mappa vettoriale può essere connessa a più tabelle di un database. Questo numero determina quale tabella viene utilizzata."
 #~ msgid "Vector map from which to remove attribute table"
 #~ msgstr "Mappa vettoriale dalla quale rimuovere la tabella degli attributi"
 #~ msgid "Name of existing attribute table (default: vector map name)"
-#~ msgstr ""
-#~ "Nome della tabella degli attributi esistente (predefinito: nome della "
-#~ "mappa vettoriale)"
+#~ msgstr "Nome della tabella degli attributi esistente (predefinito: nome della mappa vettoriale)"
 #~ msgid "Name of data table"
 #~ msgstr "Nome della tabella dei dati"
@@ -35736,12 +33940,10 @@
 #~ msgstr "Mappa raster di base <%s> non trovata"
 #~ msgid "Base map and output map <%s> must be different"
-#~ msgstr ""
-#~ "La mappa di origine <%s> e quella di output devono essere differenti"
+#~ msgstr "La mappa di origine <%s> e quella di output devono essere differenti"
 #~ msgid "Unable to read category labels of raster map <%s>"
-#~ msgstr ""
-#~ "Impossibile leggere le etichette di categoria della mappa raster <%s>"
+#~ msgstr "Impossibile leggere le etichette di categoria della mappa raster <%s>"
 #~ msgid "raster, color transformation"
 #~ msgstr "raster, trasformazione del colore"
@@ -35755,12 +33957,8 @@
 #~ msgid "Error reading 'saturation' map"
 #~ msgstr "Errore nella lettura della mappa 'saturazione'"
-#~ msgid ""
-#~ "The '-v' flag is superseded and will be removed in future. Please use '--"
-#~ "verbose' instead."
-#~ msgstr ""
-#~ "Il flag '-v' è superato e in futuro verrà rimosso. Al suo posto usare '--"
-#~ "verbose'."
+#~ msgid "The '-v' flag is superseded and will be removed in future. Please use '--verbose' instead."
+#~ msgstr "Il flag '-v' è superato e in futuro verrà rimosso. Al suo posto usare '--verbose'."
 #~ msgid "raster, import"
 #~ msgstr "raster, importazione"
@@ -35774,12 +33972,8 @@
 #~ msgid "Run quietly"
 #~ msgstr "Avvia in maniera silenziosa"
-#~ msgid ""
-#~ "The '-q' and '-n' flag is superseded and will be removed in future. "
-#~ "Please use '--quiet' instead."
-#~ msgstr ""
-#~ "I flag '-q' and '-n sono superati e in futuro verranno rimossi. Al loro "
-#~ "posto usare '--quiet'."
+#~ msgid "The '-q' and '-n' flag is superseded and will be removed in future. Please use '--quiet' instead."
+#~ msgstr "I flag '-q' and '-n sono superati e in futuro verranno rimossi. Al loro posto usare '--quiet'."
 #~ msgid "Converts a raster map layer into a height-field file for POVRAY."
 #~ msgstr "Converte una mappa raster in un file height field per POVRAY"
@@ -35790,12 +33984,8 @@
 #~ msgid "raster, metadata"
 #~ msgstr "raster, metadati"
-#~ msgid ""
-#~ "The '-q' flag is superseded and will be removed in future. Please use '--"
-#~ "quiet' instead."
-#~ msgstr ""
-#~ "Il flag '-q' è superato e in futuro verrà rimosso. Al suo posto usare '--"
-#~ "quiet'."
+#~ msgid "The '-q' flag is superseded and will be removed in future. Please use '--quiet' instead."
+#~ msgstr "Il flag '-q' è superato e in futuro verrà rimosso. Al suo posto usare '--quiet'."
 #~ msgid "%s: [%s] not found"
 #~ msgstr "%s: [%s] non trovato"
@@ -35873,16 +34063,13 @@
 #~ msgstr "La mappa di output è: cella di tipo a valori interi"
 #~ msgid "Output map is: Floating point (float) cell type"
-#~ msgstr ""
-#~ "La mappa di output è: cella di tipo con valori a virgola mobile (float)"
+#~ msgstr "La mappa di output è: cella di tipo con valori a virgola mobile (float)"
 #~ msgid "Output map is: Floating point (double) cell type"
-#~ msgstr ""
-#~ "La mappa di output è: cella di tipo con valori a virgola mobile con "
-#~ "precisione doppia (double)"
+#~ msgstr "La mappa di output è: cella di tipo con valori a virgola mobile con precisione doppia (double)"
 #~ msgid " EW resolution %s (%lf)"
-#~ msgstr "Risoluzione E-O %s (%lf)"
+#~ msgstr " Risoluzione E-O %s (%lf)"
 #~ msgid " NS resolution %s (%lf)"
 #~ msgstr "Risoluzione N-S %s (%lf)"
@@ -35897,14 +34084,10 @@
 #~ msgstr "Impossibile allocare memoria per il segmento fbuff == NULL"
 #~ msgid "Raster output map <%s> not found (no start_points given)"
-#~ msgstr ""
-#~ "Mappa raster di output <%s> non trovata (nessun punto di partenza "
-#~ "definito)"
+#~ msgstr "Mappa raster di output <%s> non trovata (nessun punto di partenza definito)"
 #~ msgid "Memory allocation error on reading start points from raster map %s"
-#~ msgstr ""
-#~ "Errore nell'allocazione della memoria nel leggere i punti di partenza "
-#~ "dalla mappa raster %s"
+#~ msgstr "Errore nell'allocazione della memoria nel leggere i punti di partenza dalla mappa raster %s"
 #~ msgid "End of map!"
 #~ msgstr "Fine della mappa!"
@@ -35949,8 +34132,7 @@
 #~ msgstr "Nome della mappa raster di input delle longitudini [gradi decimali]"
 #~ msgid "Import GDAL supported raster file into a binary raster map layer."
-#~ msgstr ""
-#~ "Importa un file raster supportato da GDAL in un layer raster binario"
+#~ msgstr "Importa un file raster supportato da GDAL in un layer raster binario"
 #~ msgid "Required"
 #~ msgstr "Richiesto"
@@ -35971,7 +34153,6 @@
 #~ msgid "Update the statistics (histogram, range) for [%s]? "
 #~ msgstr "Aggiorna le statistiche (istogramma, range) per [%s]?"
-#, fuzzy
 #~ msgid "Not enough room in history file"
 #~ msgstr "Spazio insufficiente nel file della cronologia"
@@ -35993,12 +34174,10 @@
 #~ msgid ""
 #~ "\n"
-#~ "Do you want to create/reset the null file for [%s] so that null cell "
-#~ "values are considered valid data? "
+#~ "Do you want to create/reset the null file for [%s] so that null cell values are considered valid data? "
 #~ msgstr ""
 #~ "\n"
-#~ "Si vuole creare/ricreare il file dei nulli per [%s] affinché i valori "
-#~ "null siano considerati dati validi?"
+#~ "Si vuole creare/ricreare il file dei nulli per [%s] affinché i valori null siano considerati dati validi?"
 #~ msgid "Error writing null row [%d]."
 #~ msgstr "Errore scrivendo una riga nulla [%d]."
@@ -36028,9 +34207,7 @@
 #~ msgstr "        Mappa floating point"
 #~ msgid "rows * cols * bytes per cell must be same as file size (%lu)"
-#~ msgstr ""
-#~ "righe * colonne * bytes per cella devone essere gli stessi della "
-#~ "dimensione del file (%lu)"
+#~ msgstr "righe * colonne * bytes per cella devone essere gli stessi della dimensione del file (%lu)"
 #~ msgid "** Negative values not allowed!"
 #~ msgstr "** Valori negativi non permessi!"
@@ -36045,14 +34222,10 @@
 #~ msgstr "[%s] non può essere trovato"
 #~ msgid "[%s] is a reclass of [%s] - cannot edit header! Run support on [%s]."
-#~ msgstr ""
-#~ "[%s] è una riclassificazione di [%s] - non è possibile editare "
-#~ "l'intestazione! Eseguire supporto su [%s]"
+#~ msgstr "[%s] è una riclassificazione di [%s] - non è possibile editare l'intestazione! Eseguire supporto su [%s]"
 #~ msgid "[%s] is a reclass of [%s in %s] - cannot edit header!"
-#~ msgstr ""
-#~ "[%s] è una riclassificazione di [%s in %s] - l'intestazione non può "
-#~ "essere editata!"
+#~ msgstr "[%s] è una riclassificazione di [%s in %s] - l'intestazione non può essere editata!"
 #~ msgid "Cannot open raster map [%s]!"
 #~ msgstr "Impossibile aprire la mapa raster [%s]!"
@@ -36147,7 +34320,7 @@
 #, fuzzy
 #~ msgid "Unable to read raster <map %d of %d> row %d"
-#~ msgstr "Non è possibile leggere la mappa raster <map %d of %d> riga %d"
+#~ msgstr "Non è possibile leggere la mapp raster <map %d of %d> riga %d"
 #~ msgid "raster, map management"
 #~ msgstr "raster, gestione delle mappe"
@@ -36209,12 +34382,8 @@
 #~ msgid "Bilinear interpolation utility for raster map layers."
 #~ msgstr "Strumento per l'interpolazione bilineare per layer raster."
-#~ msgid ""
-#~ "Specific input value to be assigned to the north and/or south poles for "
-#~ "longitude-latitude grids"
-#~ msgstr ""
-#~ "Specifica un valore di input da assegnare ai poli nord e/o sud per le "
-#~ "griglie di longitudine-latitudine"
+#~ msgid "Specific input value to be assigned to the north and/or south poles for longitude-latitude grids"
+#~ msgstr "Specifica un valore di input da assegnare ai poli nord e/o sud per le griglie di longitudine-latitudine"
 #~ msgid "This module is deprecated. Please use 'r.resamp.interp' instead."
 #~ msgstr "Questo modulo è deprecato. Al suo posto usare 'r.resamp.interp'."
@@ -36238,12 +34407,10 @@
 #~ msgstr "Nome della mappa raster delle derivate rispetto a y [m/m]"
 #~ msgid "Name of the detachment capacity coefficient raster map [s/m]"
-#~ msgstr ""
-#~ "Nome della mappa raster del coefficiente della capacità di distacco [s/m]"
+#~ msgstr "Nome della mappa raster del coefficiente della capacità di distacco [s/m]"
 #~ msgid "Name of the transport capacity coefficient raster map [s]"
-#~ msgstr ""
-#~ "Nome della mappa raster del coefficiente della capacità di trasporto [s]"
+#~ msgstr "Nome della mappa raster del coefficiente della capacità di trasporto [s]"
 #~ msgid "Name of the Mannings n raster map"
 #~ msgstr "Nome della mappa raster dei coefficienti n di Manning"
@@ -36255,8 +34422,7 @@
 #~ msgstr "Mappa raster di output della capacità di trasporto [kg/ms]"
 #~ msgid "Output sediment concentration raster map [particle/m3]"
-#~ msgstr ""
-#~ "Mappa raster di output della concentrazione di sedimenti [particelle/m3]"
+#~ msgstr "Mappa raster di output della concentrazione di sedimenti [particelle/m3]"
 #~ msgid "Output sediment flux raster map [kg/ms]"
 #~ msgstr "Mappa raster di output del flusso dei sedimenti [kg/ms]"
@@ -36268,19 +34434,13 @@
 #~ msgstr "raster, flusso, idrologia"
 #~ msgid "Name of the rainfall excess rate (rain-infilt) raster map [mm/hr]"
-#~ msgstr ""
-#~ "Nome della mappa raster del tasso di pioggia eccedente (intensità di "
-#~ "pioggia - velocità di infiltrazione) [mm/h]"
+#~ msgstr "Nome della mappa raster del tasso di pioggia eccedente (intensità di pioggia - velocità di infiltrazione) [mm/h]"
 #~ msgid "Name of the runoff infiltration rate raster map [mm/hr]"
-#~ msgstr ""
-#~ "Nome della mappa raster della velocità di infiltrazione del deflusso "
-#~ "superficiale [mm/h]"
+#~ msgstr "Nome della mappa raster della velocità di infiltrazione del deflusso superficiale [mm/h]"
 #~ msgid "Name of the flow controls raster map (permeability ratio 0-1)"
-#~ msgstr ""
-#~ "Nome della mappa raster delle strutture per il controllo del flusso "
-#~ "(coeff. di permeabilità 0-1)"
+#~ msgstr "Nome della mappa raster delle strutture per il controllo del flusso (coeff. di permeabilità 0-1)"
 #~ msgid "Output water depth raster map [m]"
 #~ msgstr "Mappa raster di output delle altezze d'acqua"
@@ -36291,12 +34451,8 @@
 #~ msgid "Output simulation error raster map [m]"
 #~ msgstr "Mappa raster di output degli errori di simulazione [m]"
-#~ msgid ""
-#~ "Threshold water depth [m] (diffusion increases after this water depth is "
-#~ "reached)"
-#~ msgstr ""
-#~ "Altezza d'acqua di soglia [m] (la diffusione aumenta una volta "
-#~ "raggiuntaquesta altezza)"
+#~ msgid "Threshold water depth [m] (diffusion increases after this water depth is reached)"
+#~ msgstr "Altezza d'acqua di soglia [m] (la diffusione aumenta una volta raggiuntaquesta altezza)"
 #~ msgid "Unable to close input map"
 #~ msgstr "Non è possibile chiudere la mappa di input"
@@ -36307,19 +34463,11 @@
 #~ msgid "Could not get raster row from elev map"
 #~ msgstr "Impossibile ottenere la riga raster per la mappa di elevazione"
-#~ msgid ""
-#~ "Converts a GRASS raster map to a PPM image file at the pixel resolution "
-#~ "of the currently defined region."
-#~ msgstr ""
-#~ "Converte un raster GRASS in un'immagine PPM con una risoluzione dei pixel "
-#~ "della region corrente"
+#~ msgid "Converts a GRASS raster map to a PPM image file at the pixel resolution of the currently defined region."
+#~ msgstr "Converte un raster GRASS in un'immagine PPM con una risoluzione dei pixel della region corrente"
-#~ msgid ""
-#~ "Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel "
-#~ "resolution of the CURRENTLY DEFINED REGION."
-#~ msgstr ""
-#~ "Converte 3 raster GRASS (R,G,B) in un'immagine PPM con la risoluzione del "
-#~ "pixel della region corrente"
+#~ msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel resolution of the CURRENTLY DEFINED REGION."
+#~ msgstr "Converte 3 raster GRASS (R,G,B) in un'immagine PPM con la risoluzione del pixel della region corrente"
 # transetto?
 #, fuzzy
@@ -36336,8 +34484,7 @@
 #~ msgstr "Impossibile leggere la riga [%d] del raster dalla mappa raster <%s>"
 #~ msgid "Cannot read raster row [%d] from cover raster map <%s>"
-#~ msgstr ""
-#~ "Impossibile leggere la riga [%d] del raster dal raster di copertura <%s>"
+#~ msgstr "Impossibile leggere la riga [%d] del raster dal raster di copertura <%s>"
 #, fuzzy
 #~ msgid "raster, viewshed"
@@ -36349,13 +34496,11 @@
 #~ msgid "Failed writing raster map <%s> row %d"
 #~ msgstr "Scrittura della mappa raster <%s> riga %d non riuscita"
-#, fuzzy
 #~ msgid "raster, fire"
 #~ msgstr "raster, incendi"
 #~ msgid "Raster map <%s> already exists in mapset <%s>, select another name"
-#~ msgstr ""
-#~ "La mappa raster <%s> esiste già nel mapset <%s>, selezionare un altro nome"
+#~ msgstr "La mappa raster <%s> esiste già nel mapset <%s>, selezionare un altro nome"
 #~ msgid "Name of raster map to contain results (several new layers)"
 #~ msgstr "Nome del raster contenente i risultati (diversi layers nuovi)"
@@ -36376,7 +34521,6 @@
 #~ "\n"
 #~ "Usare il mouse per disegnare la linea di profilo\n"
-#, fuzzy
 #~ msgid "Buttons:\n"
 #~ msgstr "Bottoni:\n"
@@ -36405,13 +34549,8 @@
 #~ msgid "Unable to open raster map <%s> in mapset <%s>"
 #~ msgstr "Impossibile aprire la mappa raster <%s> nel mapset <%s>"
-#~ msgid ""
-#~ "Finds the average of values in a cover map within areas assigned the same "
-#~ "category value in a user-specified base map."
-#~ msgstr ""
-#~ "Trova la media dei valori in una mappa di copertura all'interno di aree "
-#~ "che hanno lo stesso valore di categoria in una mappa di base definita "
-#~ "dall'utente."
+#~ msgid "Finds the average of values in a cover map within areas assigned the same category value in a user-specified base map."
+#~ msgstr "Trova la media dei valori in una mappa di copertura all'interno di aree che hanno lo stesso valore di categoria in una mappa di base definita dall'utente."
 #~ msgid "%s: ERROR running %s command"
 #~ msgstr "%s: ERRORE nell'eseguire il comando %s"
@@ -36527,12 +34666,8 @@
 #~ msgid "Failed writing raster map row %d"
 #~ msgstr "Scrittura della riga %d della mappa raster non riuscita"
-#~ msgid ""
-#~ "Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel "
-#~ "resolution of the currently defined region."
-#~ msgstr ""
-#~ "Esporta un raster GRASS in un'immagine TIFF 8/24bit con la risoluzione "
-#~ "del pixel definita della regione corrente"
+#~ msgid "Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel resolution of the currently defined region."
+#~ msgstr "Esporta un raster GRASS in un'immagine TIFF 8/24bit con la risoluzione del pixel definita della regione corrente"
 #~ msgid "Unable to read header of raster map <%s>"
 #~ msgstr "Impossibile leggere l'intestazione della mappa raster <%s>"
@@ -36556,18 +34691,13 @@
 #~ msgstr "Nome della mappa raster da cui copiare la tavola dei colori"
 #~ msgid "Path to rules file (\"-\" to read rules from stdin)"
-#~ msgstr ""
-#~ "Percorso del file delle regole (\"-\" per leggere le regole dallo stdin)"
+#~ msgstr "Percorso del file delle regole (\"-\" per leggere le regole dallo stdin)"
 #~ msgid "Enter rules interactively"
 #~ msgstr "Immissione delle regole in modo interattivo"
-#~ msgid ""
-#~ "Interactive mode is incompatible with \"color\", \"rules\", and \"raster"
-#~ "\" options"
-#~ msgstr ""
-#~ "La modalità interattiva è incompatibile con le opzioni \"color\", \"rules"
-#~ "\" e \"raster\""
+#~ msgid "Interactive mode is incompatible with \"color\", \"rules\", and \"raster\" options"
+#~ msgstr "La modalità interattiva è incompatibile con le opzioni \"color\", \"rules\" e \"raster\""
 #~ msgid "Output map <%s> ignored"
 #~ msgstr "Mappa di output <%s> ignorata"
@@ -36627,8 +34757,7 @@
 #~ msgstr "(i)   Mappa di elevazione"
 #~ msgid "Unable to write color table for raster map <%s>"
-#~ msgstr ""
-#~ "Non è possibile scrivere la tavola dei colori per la mappa raster <%s>"
+#~ msgstr "Non è possibile scrivere la tavola dei colori per la mappa raster <%s>"
 #~ msgid "<%s> is an ilegal name"
 #~ msgstr "<%s> è un nome non valido"
@@ -36636,12 +34765,8 @@
 #~ msgid "%s: Error reading from raster map <%s> in mapset <%s>"
 #~ msgstr "%s: Errore nel leggere dalla mappa raster <%s> nel mapset <%s>"
-#~ msgid ""
-#~ "Creates a new map layer whose category values are based upon a "
-#~ "reclassification of the categories in an existing raster map layer."
-#~ msgstr ""
-#~ "Crea un nuovo layer dove i valori delle categorie sono basati sulla "
-#~ "riclassificazione delle categorie esistenti in un altro raster"
+#~ msgid "Creates a new map layer whose category values are based upon a reclassification of the categories in an existing raster map layer."
+#~ msgstr "Crea un nuovo layer dove i valori delle categorie sono basati sulla riclassificazione delle categorie esistenti in un altro raster"
 #~ msgid "Raster map to be reclassified"
 #~ msgstr "Mappa raster da riclassificare"
@@ -36676,18 +34801,14 @@
 #~ msgid "Illegal output file name <%s>"
 #~ msgstr "Nome del file di output <%s> non valido"
-#~ msgid ""
-#~ "This utility will allow you to compare the coincidence of two map layers\n"
-#~ msgstr ""
-#~ "Questo programma di utilità consente di confrontare le coincidenze di due "
-#~ "tematismi raster\n"
+#~ msgid "This utility will allow you to compare the coincidence of two map layers\n"
+#~ msgstr "Questo programma di utilità consente di confrontare le coincidenze di due tematismi raster\n"
 #~ msgid "The report can be made in one of 8 units."
 #~ msgstr "Il rapporto può essere fatto in una delle 8 unità di misura"
 #~ msgid "Please choose a unit by entering one of the following letter codes:"
-#~ msgstr ""
-#~ "Scegliere un'unità di misura immettendo uno dei seguenti codici letterali:"
+#~ msgstr "Scegliere un'unità di misura immettendo uno dei seguenti codici letterali:"
 #~ msgid "     'c': cells"
 #~ msgstr "     'c': celle"
@@ -36726,17 +34847,11 @@
 #~ "Inserire il nome del file o il persorso\n"
-#~ msgid ""
-#~ "Do you wish to print this report (requires Unix lpr command)? (y/n) [n] "
-#~ msgstr ""
-#~ "Si vuol stampare questo rapporto (richiede il comando Unix lpr (y/n) [n] "
+#~ msgid "Do you wish to print this report (requires Unix lpr command)? (y/n) [n] "
+#~ msgstr "Si vuol stampare questo rapporto (richiede il comando Unix lpr (y/n) [n] "
-#~ msgid ""
-#~ "Do you wish to run this report with a different unit of measure? (y/n) "
-#~ "[y] "
-#~ msgstr ""
-#~ "Si vuole generare questo rapporto con una diversa unità di misurà? (y/n) "
-#~ "[y] "
+#~ msgid "Do you wish to run this report with a different unit of measure? (y/n) [y] "
+#~ msgstr "Si vuole generare questo rapporto con una diversa unità di misurà? (y/n) [y] "
 #~ msgid "Error reading input"
 #~ msgstr "Errore nella lettura dell'input"
@@ -36745,15 +34860,13 @@
 #~ msgstr "L'intervallo dati della mappa raster <%s> è vuoto"
 #~ msgid "Data range of raster map <%s> is %s to %s (entire map)"
-#~ msgstr ""
-#~ "L'intervallo dati della mappa raster <%s> è da %s a %s (l'intera mappa)"
+#~ msgstr "L'intervallo dati della mappa raster <%s> è da %s a %s (l'intera mappa)"
 #~ msgid "Integer data range of raster map <%s> is empty"
 #~ msgstr "L'intervallo dati dei valori interi della mappa raster <%s> è vuoto"
 #~ msgid "Integer data range of raster mao <%s> is %d to %d"
-#~ msgstr ""
-#~ "L'intervallo dati dei valori interi della mappa raster <%s> è da %d a %d"
+#~ msgstr "L'intervallo dati dei valori interi della mappa raster <%s> è da %d a %d"
 #~ msgid "raster, volume"
 #~ msgstr "raster, volume"
@@ -36771,9 +34884,7 @@
 #~ msgstr "Nome della mappa vettoriale che contiene il corso/i d'acqua"
 #~ msgid "Stream width (in meters). Default is raster cell width"
-#~ msgstr ""
-#~ "Ampiezza del corso d'acqua (in metri). Il valore predefinito è l'ampiezza "
-#~ "della cella del raster"
+#~ msgstr "Ampiezza del corso d'acqua (in metri). Il valore predefinito è l'ampiezza della cella del raster"
 #~ msgid "%s: cover raster map not found"
 #~ msgstr "%s: mappa raster di copertura non trovata"
@@ -36833,17 +34944,13 @@
 #~ msgstr "La location Lat/Long non è supportata"
 #~ msgid "Cannot write category file for raster map <%s>"
-#~ msgstr ""
-#~ "Impossibile scrivere il file delle categorie per la mappa raster <%s>"
+#~ msgstr "Impossibile scrivere il file delle categorie per la mappa raster <%s>"
 #~ msgid "raster, geomorphology"
 #~ msgstr "raster, geomorfologia"
-#~ msgid ""
-#~ "Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster "
-#~ "map layer."
-#~ msgstr ""
-#~ "Converte un file raster ESRI ARC/INFO ascii (GRID) in un raster (binario)"
+#~ msgid "Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster map layer."
+#~ msgstr "Converte un file raster ESRI ARC/INFO ascii (GRID) in un raster (binario)"
 #~ msgid "File containing weights"
 #~ msgstr "File contenente i pesi"
@@ -36857,11 +34964,8 @@
 #~ msgid "%s file(s) to be removed"
 #~ msgstr "%s file da rimuovere"
-#, fuzzy
 #~ msgid "Mapset to list (default: current search path)"
-#~ msgstr ""
-#~ "Mapset del quale fornire la lista (predefinito: percorso di ricerca "
-#~ "corrente)"
+#~ msgstr "Mapset del quale fornire la lista (predefinito: percorso di ricerca corrente)"
 #~ msgid "%s file(s) to be renamed"
 #~ msgstr "%s file da rinominare"
@@ -36875,8 +34979,7 @@
 #~ "\n"
 #~ "ATTENZIONE!  Un file della proiezione esiste già per questa location\n"
-#~ msgid ""
-#~ "Would you still like to overwrite the current projection information "
+#~ msgid "Would you still like to overwrite the current projection information "
 #~ msgstr "Vuoi ancora sovrascrivere le attuali informazioni sulla proiezione"
 #~ msgid "Error writing PROJ_INFO"
@@ -36888,22 +34991,15 @@
 #~ msgid "The projection information will not be updated."
 #~ msgstr "Le informazioni sulla proiezione non saranno aggiornate"
-#, fuzzy
-#~ msgid ""
-#~ "GIS data directory (full path to the directory where the new location is)"
-#~ msgstr ""
-#~ "Directory dei dati GIS (percorso intero della directory dove la nuova "
-#~ "location è situata)"
+#~ msgid "GIS data directory (full path to the directory where the new location is)"
+#~ msgstr "Directory dei dati GIS (percorso intero della directory dove la nuova location è situata)"
-#, fuzzy
 #~ msgid "Erasing monitors..."
 #~ msgstr "Cancellazione dei monitor in corso ..."
-#, fuzzy
 #~ msgid "<%s> not found in mapset list"
 #~ msgstr "<%s> non trovato nella lista dei mapset"
-#, fuzzy
 #~ msgid "general, settings, search path"
 #~ msgstr "general, impostazioni, percorso di ricerca"
@@ -36931,7 +35027,6 @@
 #~ msgid "format"
 #~ msgstr "formato"
-#, fuzzy
 #~ msgid "Unable to open raster map <%s> in <%s>"
 #~ msgstr "impossibile aprire la mappa raster <%s> in <%s>"
@@ -36978,9 +35073,8 @@
 #~ "\n"
 #~ "Bottoni:\n"
-#, fuzzy
 #~ msgid "display, distance"
-#~ msgstr "Unità della distanza"
+#~ msgstr "visualizzazione, distanza"
 #, fuzzy
 #~ msgid "display, menu"
@@ -36990,7 +35084,6 @@
 #~ msgid "found %d visuals of type TrueColor"
 #~ msgstr "trovate %d viste per il tipo TrueColor"
-#, fuzzy
 #~ msgid "searching for highest bit depth"
 #~ msgstr "ricerca del valore massimo di bit depth"
@@ -36998,7 +35091,6 @@
 #~ msgid "selected %d bit depth"
 #~ msgstr "bit depth %d selezionata"
-#, fuzzy
 #~ msgid "using default visual which is %s"
 #~ msgstr "si sta usando la vista predefinita che è %s"
@@ -37011,11 +35103,9 @@
 #~ msgid "Monitor: XGetWMName failed"
 #~ msgstr "Monitor: XGetWMName fallito"
-#, fuzzy
 #~ msgid "Monitor: XGetWMName: bad result"
 #~ msgstr "Monitor: XGetWMName: risultato sbagliato"
-#, fuzzy
 #~ msgid "Setting release of FreeType"
 #~ msgstr "Imposta la versione di FreeType"
@@ -37042,7 +35132,6 @@
 #~ msgid "Display number of colors"
 #~ msgstr "Mostra numero di colori"
-#, fuzzy
 #~ msgid "Error reading row of data"
 #~ msgstr "Errore nella lettura della riga dei dati"
@@ -37055,9 +35144,8 @@
 #~ msgid "No predefined font"
 #~ msgstr "Nessun font predefinito"
-#, fuzzy
 #~ msgid "display, color transformation"
-#~ msgstr "Si sta effettuando la trasformazione logaritmica"
+#~ msgstr "visualizzazione, trasformazione di colore"
 #~ msgid "Error reading hue data"
 #~ msgstr "Errore nella lettura dei dati di tonalità"
@@ -37074,9 +35162,8 @@
 #~ msgid "Invalid rendering method <%s>"
 #~ msgstr "Metodo di rendering <%s> non valido"
-#, fuzzy
 #~ msgid "display, histogram, statistics"
-#~ msgstr "Aggiorna statistiche per un raster"
+#~ msgstr "visualizzazione, istogramma, statistica"
 #~ msgid "Error - Monitor '%s' in use by another user"
 #~ msgstr "Errore - Il monitor '%s' è in uso da un altro utente"
@@ -37091,8 +35178,7 @@
 #~ msgstr " Centrale: abilita colore flash\n"
 #~ msgid "List of values to be displayed (FP maps)"
-#~ msgstr ""
-#~ "Lista dei valori da visualizzare (mappe di valori a virgola mobile [FP])"
+#~ msgstr "Lista dei valori da visualizzare (mappe di valori a virgola mobile [FP])"
 #~ msgid "You must select more than one point"
 #~ msgstr "Devi selezionare più di un punto"
@@ -37138,13 +35224,11 @@
 #~ msgid "vector, database, attribute table"
 #~ msgstr "vettoriale, database, tabella degli attributi"
-#, fuzzy
 #~ msgid "vector, network, allocation"
-#~ msgstr "N"
+#~ msgstr "vettore, rete, allocazione"
-#, fuzzy
 #~ msgid "vector, networking, maintenance"
-#~ msgstr "Esegue la manutenzione della rete."
+#~ msgstr "vettore, rete, manutenzione"
 #~ msgid "Name of input point vector map"
 #~ msgstr "Nome della mappa vettoriale di punti di input"
@@ -37179,25 +35263,17 @@
 #~ msgid "Query layer number (read from)"
 #~ msgstr "Numero del layer da interrogare (da cui leggere)"
-#~ msgid ""
-#~ "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),r(adians),d"
-#~ "(egrees)"
+#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),r(adians),d(egrees)"
 #~ msgstr ""
-#~ "(egrees)\n"
+#~ "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),r(adians),d(egrees)\n"
 #~ "(miglia, piedi, metri, chilometri, acri, ettari, radianti, gradi)"
-#, fuzzy
 #~ msgid "Attribute table column with values to interpolate (if layer>0)"
-#~ msgstr ""
-#~ "Colonna della tabella degli attributi coi valori da interpolare (se "
-#~ "layer>0)"
+#~ msgstr "Colonna della tabella degli attributi coi valori da interpolare (se layer>0)"
-#, fuzzy
 #~ msgid "Unable to access table <%s>"
 #~ msgstr "Non è possibile accedere alla tabella <%s>"
-#, fuzzy
 #~ msgid "<%s> has not been created in database."
 #~ msgstr "<%s> non è stata creata nel database"
@@ -37223,24 +35299,20 @@
 #~ msgid "Layer 0 not supported"
 #~ msgstr "Layer 0 non supportato"
-#, fuzzy
 #~ msgid "vector, network, isolines"
-#~ msgstr "N"
+#~ msgstr "vettore, rete, isolinee"
-#, fuzzy
 #~ msgid "vector, network, salesman"
-#~ msgstr "N"
+#~ msgstr "vettore, rete, salesman"
-#, fuzzy
 #~ msgid "vector, geometry, statistics"
-#~ msgstr "N"
+#~ msgstr "vettore, geometria, statistica"
 #~ msgid "Random location perturbations of GRASS vector points"
 #~ msgstr "Disturbo casuale del posizionamento di punti vettoriali"
-#, fuzzy
 #~ msgid "vector, network, shortest path"
-#~ msgstr "N"
+#~ msgstr "vettore, rete, persorso minimo"
 #~ msgid "Layer number (from)"
 #~ msgstr "Numero del layer (da)"
@@ -37278,15 +35350,13 @@
 #~ msgid "Either 'rules' or 'col' must be specified"
 #~ msgstr "Dev'essere specificato il parametro 'rules' o 'col'"
-#, fuzzy
 #~ msgid "Network input map <%s> not found"
-#~ msgstr "Mappa della rete <%s> non trovata"
+#~ msgstr "Mappa di input della rete <%s> non trovata"
 #~ msgid "Unable to read MASK"
 #~ msgstr "Impossibile leggere MASK"
-#~ msgid ""
-#~ "Converts GRASS vector map to one of the supported OGR vector formats."
+#~ msgid "Converts GRASS vector map to one of the supported OGR vector formats."
 #~ msgstr "Converte in uno dei formati vettoriali supportati da OGR"
 #~ msgid "OGR format"
@@ -37295,9 +35365,8 @@
 #~ msgid "Key column '%s' not found"
 #~ msgstr "Colonna chiave '%s' non trovata"
-#, fuzzy
 #~ msgid "Exporting %i geometries..."
-#~ msgstr "Esportando %i punti/linee..."
+#~ msgstr "Esportazione di %i geometrie in corso..."
 #~ msgid "Cannot open %s"
 #~ msgstr "Impossibile aprire %s"
@@ -37312,20 +35381,14 @@
 #~ msgid "Cannot alter table: %s"
 #~ msgstr "Non posso modificare la tabella: %s"
-#~ msgid ""
-#~ "Creates a buffer around features of given type (areas must contain "
-#~ "centroid)."
-#~ msgstr ""
-#~ "Crea un buffer intorno agli elementi di un dato tipo (aree devono "
-#~ "contenere centroide)."
+#~ msgid "Creates a buffer around features of given type (areas must contain centroid)."
+#~ msgstr "Crea un buffer intorno agli elementi di un dato tipo (aree devono contenere centroide)."
-#, fuzzy
 #~ msgid "vector, geometry, triangulation"
-#~ msgstr "N"
+#~ msgstr "vettore, geometria, triangolazione"
-#, fuzzy
 #~ msgid "vector, network, steiner tree"
+#~ msgstr "vettore, rete, albero di steiner"
 #~ msgid "Queries a vector map layer at given locations."
 #~ msgstr "Interroga un vettoriale a una certa posizione."
@@ -37333,17 +35396,11 @@
 #~ msgid "Type: %s"
 #~ msgstr "Tipo: %s"
-#, fuzzy
-#~ msgid ""
-#~ "The '%c' flag is deprecated and will be removed in future. Please use '--"
-#~ msgstr ""
-#~ "Il flag '%c' è deprecato e in futuro verrà rimosso. Al suo posto usare '--"
-#~ "quiet'"
+#~ msgid "The '%c' flag is deprecated and will be removed in future. Please use '--quiet' instead."
+#~ msgstr "Il flag '%c' è deprecato e in futuro verrà rimosso. Al suo posto usare '--quiet'"
 #~ msgid "Copying vector objects from vector map <%s>..."
-#~ msgstr ""
-#~ "Copia in corso degli oggetti vettoriali dalla mappa vettoriale <%s>..."
+#~ msgstr "Copia in corso degli oggetti vettoriali dalla mappa vettoriale <%s>..."
 #~ msgid "Name of input vector map containing lines"
 #~ msgstr "Nome della mappa vettoriale di input contenente le linee"
@@ -37354,12 +35411,8 @@
 #~ msgid "Doing log transformation"
-#~ msgid ""
-#~ "Calculates univariate statistics for attribute. Variance and standard "
-#~ "deviation is calculated only for points if specified."
-#~ msgstr ""
-#~ "Calcola statistiche univariate per gli attributi. Varianza e deviazione "
-#~ "standard è calcolate solo per punti se specificato."
+#~ msgid "Calculates univariate statistics for attribute. Variance and standard deviation is calculated only for points if specified."
+#~ msgstr "Calcola statistiche univariate per gli attributi. Varianza e deviazione standard è calcolate solo per punti se specificato."
 #~ msgid "Column name"
 #~ msgstr "Nome della colonna"
@@ -37374,8 +35427,7 @@
 #~ msgstr "Impossibile scrivere le categorie per la mappa rster <%s>"
 #~ msgid "Create points along input lines in new vector with 2 layers."
-#~ msgstr ""
-#~ "Crea punti lungo una linea di input in un nuovo vettoriale con 2 layer"
+#~ msgstr "Crea punti lungo una linea di input in un nuovo vettoriale con 2 layer"
 #~ msgid "Output vector map where points will be written"
 #~ msgstr "Mappa vettoriale di output su cui scrivere i punti"
@@ -37397,8 +35449,7 @@
 #~ msgstr "Crea un vettore da file ASCI points o ASCII vector"
 #~ msgid "ASCII file to be imported, if not given reads from standard input"
-#~ msgstr ""
-#~ "File ASCII da importare, se non viene fornito legge dallo standard input"
+#~ msgstr "File ASCII da importare, se non viene fornito legge dallo standard input"
 #~ msgid "Creates a new vector as a read-only link to OGR layer."
 #~ msgstr "Crea nuovo vettore come link in sola lettura a un layer OGR"
@@ -37473,8 +35524,7 @@
 #~ msgstr "Estrusione delle primitive vettoriali in corso..."
 #~ msgid "Attach, delete or report vector categories to map geometry."
-#~ msgstr ""
-#~ "Attacca, elimina o visualizza le categorie per geometrie della mappa."
+#~ msgstr "Attacca, elimina o visualizza le categorie per geometrie della mappa."
 #~ msgid "Output slope raster map"
 #~ msgstr "Mappa raster di output delle pendenze"
@@ -37582,33 +35632,28 @@
 #~ msgid "Unselect"
 #~ msgstr "Nessun monitor selezionato"
-#, fuzzy
 #~ msgid "Cannot open driver\n"
-#~ msgstr "Impossibile aprire %s"
+#~ msgstr "Impossibile aprire il driver\n"
-#, fuzzy
 #~ msgid "Cannot open database\n"
+#~ msgstr "Impossibile aprire il database\n"
-#, fuzzy
 #~ msgid "Cannot describe table\n"
-#~ msgstr "Non posso copiare la tabella"
+#~ msgstr "Impossibile descrivere la tabella\n"
 #, fuzzy
 #~ msgid "Cannot find column type"
 #~ msgstr "Tipo di colonna sconosciuto"
-#, fuzzy
 #~ msgid "Cannot update table"
-#~ msgstr "Non posso modificare la tabella: %s"
+#~ msgstr "Impossibile aggiornare la tabella"
 #, fuzzy
 #~ msgid "Form"
 #~ msgstr "Formato"
-#, fuzzy
 #~ msgid "New record was created.<BR>"
-#~ msgstr "Non verrà creato nessun dato vettoriale."
+#~ msgstr "È stato creato un nuovo record.<BR>"
 #, fuzzy
 #~ msgid "Record for this category already existed.<BR>"
@@ -37676,9 +35721,7 @@
 # di shell
 #~ msgid "Print all map connection parameters and exit in shell script style"
-#~ msgstr ""
-#~ "Stampa tutti i parametri di connessione della mappa ed esce in stile "
-#~ "script per la shell"
+#~ msgstr "Stampa tutti i parametri di connessione della mappa ed esce in stile script per la shell"
 #~ msgid "Exports GRASS vector map layers to DXF file format."
 #~ msgstr "Esporta vettore GRASS in un file DXF"
@@ -37704,25 +35747,17 @@
 #~ msgstr "Impossibile leggere la riga del raster"
 #, fuzzy
-#~ msgid ""
-#~ "List paper formats ( name width height left right top bottom(margin) )"
-#~ msgstr ""
-#~ "Elenco dei formati di pagina per la stampa (nome largh. altezza sinistra "
-#~ "destra alto basso[margine])"
+#~ msgid "List paper formats ( name width height left right top bottom(margin) )"
+#~ msgstr "Elenco dei formati di pagina per la stampa (nome largh. altezza sinistra destra alto basso[margine])"
-#~ msgid ""
-#~ "File containing mapping instructions (or use input=- to enter from "
-#~ "keyboard)"
-#~ msgstr ""
-#~ "File contenente le istruzioni (o usa input=- per inserire da tastiera)"
+#~ msgid "File containing mapping instructions (or use input=- to enter from keyboard)"
+#~ msgstr "File contenente le istruzioni (o usa input=- per inserire da tastiera)"
 #~ msgid "PostScript output file"
 #~ msgstr "File PostScript di output"
-#~ msgid ""
-#~ "Scale of the output map, e.g. 1:25000 (default: Auto-sized to fit page)"
-#~ msgstr ""
-#~ "Scala della mappa in output, e.g. 1:25000 (default: Adatta alla pagina)"
+#~ msgid "Scale of the output map, e.g. 1:25000 (default: Auto-sized to fit page)"
+#~ msgstr "Scala della mappa in output, e.g. 1:25000 (default: Adatta alla pagina)"
 #~ msgid ""
 #~ "ERROR: Required parameter <%s> not set:\n"
@@ -37753,16 +35788,10 @@
 #~ msgstr "database, tabella degli attributi, impostazioni di connessione"
 #~ msgid "Prints/sets general DB connection for current mapset and exits."
-#~ msgstr ""
-#~ "Stampa/imposta la connessione generale al DB per il mapset corrente ed "
-#~ "esce."
+#~ msgstr "Stampa/imposta la connessione generale al DB per il mapset corrente ed esce."
-#~ msgid ""
-#~ "Do not use this option if schemas are not supported by driver/database "
-#~ "server"
-#~ msgstr ""
-#~ "Non utilizzare questa opzione se lo schema non è supportato dal driver/"
-#~ "database server"
+#~ msgid "Do not use this option if schemas are not supported by driver/database server"
+#~ msgstr "Non utilizzare questa opzione se lo schema non è supportato dal driver/database server"
 #~ msgid "database, SQL"
 #~ msgstr "database, SQL"
@@ -37805,9 +35834,7 @@
 #~ msgstr "Immagini"
 #~ msgid "Width and height of output image (overrides resolution setting)"
-#~ msgstr ""
-#~ "Larghezza e altezza dell'immagine di output (sovrascrive le impostazioni "
-#~ "della risoluzione)"
+#~ msgstr "Larghezza e altezza dell'immagine di output (sovrascrive le impostazioni della risoluzione)"
 #~ msgid "Compression for PNG files"
 #~ msgstr "Compressione per i file PNG"
@@ -37828,8 +35855,7 @@
 #~ msgstr "Usa il driver Cario per restituire immagini"
 #~ msgid "Set paper orientation to landscape (for PostScript output)"
-#~ msgstr ""
-#~ "Imposta l'orientazione del foglio in orizzontale (per uscita PostScript)"
+#~ msgstr "Imposta l'orientazione del foglio in orizzontale (per uscita PostScript)"
 #~ msgid "Name of input raster map (NIR: tm4 | qbird_nir | spot2)"
 #~ msgstr "Nome del raster di input (NIR: tm4 | qbird_nir | spot2)"
@@ -37870,11 +35896,8 @@
 #~ msgid "Mapsets to use. Specify multiple mapsets comma separated"
 #~ msgstr "Mapset da usare. Specificare multipli mapset separati dalla virgola"
-#~ msgid ""
-#~ "Download waypoints, routes, and tracks from a Garmin GPS receiver into a "
-#~ "vector map."
-#~ msgstr ""
-#~ "Scarica punti di interesse, rotte e tracce da un GPS Garmin in un vettore"
+#~ msgid "Download waypoints, routes, and tracks from a Garmin GPS receiver into a vector map."
+#~ msgstr "Scarica punti di interesse, rotte e tracce da un GPS Garmin in un vettore"
 #~ msgid "Download Waypoints from GPS"
 #~ msgstr "Scarica punti di rilevamento da un GPS"
@@ -37888,13 +35911,8 @@
 #~ msgid "Port Garmin receiver is connected to"
 #~ msgstr "La porta del ricevitore Garmin è connessa a"
-#~ msgid ""
-#~ "Calculates univariate statistics from a raster map based on vector "
-#~ "polygons and uploads statistics to new attribute columns."
-#~ msgstr ""
-#~ "Calcola statistiche univariate da un raster basandosi su poligoni "
-#~ "vettoriali e carica le statistiche in una nuova colonna della tabella "
-#~ "degli attributi."
+#~ msgid "Calculates univariate statistics from a raster map based on vector polygons and uploads statistics to new attribute columns."
+#~ msgstr "Calcola statistiche univariate da un raster basandosi su poligoni vettoriali e carica le statistiche in una nuova colonna della tabella degli attributi."
 #~ msgid "Name of .dmrc settings file"
 #~ msgstr "Nome del file di impostazioni .dmrc"
@@ -37944,12 +35962,8 @@
 #~ msgid "Display monitor to start"
 #~ msgstr "Mostra monitor all'avvio"
-#~ msgid ""
-#~ "Import waypoints, routes, and tracks from a GPS receiver or GPS download "
-#~ "file into a vector map."
-#~ msgstr ""
-#~ "Scarica punti di interesse, rotte e tracce da un GPS o da un file di dati "
-#~ "scaricati da un GPS in un vettore"
+#~ msgid "Import waypoints, routes, and tracks from a GPS receiver or GPS download file into a vector map."
+#~ msgstr "Scarica punti di interesse, rotte e tracce da un GPS o da un file di dati scaricati da un GPS in un vettore"
 #~ msgid "Import track"
 #~ msgstr "Importa tracce"
@@ -37958,15 +35972,10 @@
 #~ msgstr "Dispositivo o file utilizzato per l'importazione dei dati"
 #~ msgid "Format of GPS input data (use gpsbabel supported formats)"
-#~ msgstr ""
-#~ "Formato dei dati di input del GPS (usare formati supportati da gpsbabel)"
+#~ msgstr "Formato dei dati di input del GPS (usare formati supportati da gpsbabel)"
-#~ msgid ""
-#~ "Projection of input data (PROJ.4 style), if not set Lat/Lon WGS84 is "
-#~ "assumed"
-#~ msgstr ""
-#~ "Proiezione dei dati in input (modello PROJ.4), se non impostato è "
-#~ "utilizzato WGS84 Lat/Lon"
+#~ msgid "Projection of input data (PROJ.4 style), if not set Lat/Lon WGS84 is assumed"
+#~ msgstr "Proiezione dei dati in input (modello PROJ.4), se non impostato è utilizzato WGS84 Lat/Lon"
 #~ msgid "Layer number. If -1, all layers are extracted."
 #~ msgstr "Numero di layer. Se -1, tutti i layer sono estratti."
@@ -37978,8 +35987,7 @@
 #~ msgstr "Importa GetFeature da WFS"
 #~ msgid "Saves active display monitor to PNG file in home directory"
-#~ msgstr ""
-#~ "Salva il monitor attivo visualizzato in un file PNG nella directory home"
+#~ msgstr "Salva il monitor attivo visualizzato in un file PNG nella directory home"
 #~ msgid "Name of PNG file"
 #~ msgstr "Nome del file PNG"
@@ -38124,17 +36132,14 @@
 #, fuzzy
 #~ msgid "Exporting raster as double values (bytes=%d)"
-#~ msgstr ""
-#~ "Esportazione in corso del raster come valori a precisione doppia (double) "
-#~ "(bytes=%d)"
+#~ msgstr "Esportazione in corso del raster come valori a precisione doppia (double) (bytes=%d)"
 #, fuzzy
 #~ msgid "Reading map"
 #~ msgstr "Lettura della mappa"
 #~ msgid "Signed data (high bit means negative value)"
-#~ msgstr ""
-#~ "Dati costituiti da numeri relativi (un bit alto significa valore negativo)"
+#~ msgstr "Dati costituiti da numeri relativi (un bit alto significa valore negativo)"
 #~ msgid "Number of bytes per cell (1, 2, 4)"
 #~ msgstr "Numero di byte per cella (1, 2, 4)"
@@ -38241,12 +36246,8 @@
 #~ msgstr "Nome del nuovo MAPSET"
 #, fuzzy
-#~ msgid ""
-#~ "Displays and overlays raster map layers in the active display frame on "
-#~ "the graphics monitor."
-#~ msgstr ""
-#~ "Seleziona il tipo di carattere con cui il testo deve essere rappresentato "
-#~ "nel monitor grafico dell'utente."
+#~ msgid "Displays and overlays raster map layers in the active display frame on the graphics monitor."
+#~ msgstr "Seleziona il tipo di carattere con cui il testo deve essere rappresentato nel monitor grafico dell'utente."
 #~ msgid "                No topology present"
 #~ msgstr "                Nessuna topologia presente"
@@ -38255,14 +36256,8 @@
 #~ msgid "Failed in attempt to open %s"
-#~ msgid ""
-#~ "Generates raster map layers of slope, aspect, curvatures and partial "
-#~ "derivatives from a raster map layer of true elevation values. Aspect is "
-#~ "calculated counterclockwise from east."
-#~ msgstr ""
-#~ "Genera raster della pendenza, esposizione, curvature e le derivate "
-#~ "parziali da un raster con valori dell'elevazione. Esposizione è calcolata "
-#~ "in senso antiorario partendo dall'est."
+#~ msgid "Generates raster map layers of slope, aspect, curvatures and partial derivatives from a raster map layer of true elevation values. Aspect is calculated counterclockwise from east."
+#~ msgstr "Genera raster della pendenza, esposizione, curvature e le derivate parziali da un raster con valori dell'elevazione. Esposizione è calcolata in senso antiorario partendo dall'est."
 #, fuzzy
 #~ msgid "Output slope filename"
@@ -38293,9 +36288,7 @@
 #~ msgid "Uses a GRASS vector points map to produce a convex hull vector map."
-#~ msgstr ""
-#~ "Usa un vettoriale di punti per produrre un vettoriale di poligoni "
-#~ "convessi."
+#~ msgstr "Usa un vettoriale di punti per produrre un vettoriale di poligoni convessi."
 #, fuzzy
 #~ msgid "Name of output vector area map"
@@ -38320,29 +36313,18 @@
 #~ "Lo si vuol sampare in 80 o 132 colonne?\n"
-#, fuzzy
 #~ msgid "Converts a 3D raster map layer into an ASCII text file."
 #~ msgstr "Converte un tematismo raster 3D in un file di testo ASCII"
 # tematismo raster
-#, fuzzy
-#~ msgid ""
-#~ "Converts a 3D ASCII raster text file into a (binary) 3D raster map layer."
-#~ msgstr ""
+#~ msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map layer."
+#~ msgstr "Converte un file testuale raster ASCII 3D in un tematismo raster 3D (binario)"
 #~ msgid "Wrong 3D raster map datatype! Unable to create raster map."
-#~ msgstr ""
-#~ "Il tipo di dati della mappa raster 3D è errato! Non è possibile creare la "
-#~ "mappa raster."
+#~ msgstr "Il tipo di dati della mappa raster 3D è errato! Non è possibile creare la mappa raster."
-#~ msgid ""
-#~ "Use the same resolution as the input 3D raster map for the 2D outputmaps, "
-#~ "independent of the current region settings"
-#~ msgstr ""
-#~ "Utilizza la stessa risoluzione della mappa raster 3D di input per le "
-#~ "mappe di output 2D, indipendentemente dalle impostazioni attuali della "
-#~ "regione"
+#~ msgid "Use the same resolution as the input 3D raster map for the 2D outputmaps, independent of the current region settings"
+#~ msgstr "Utilizza la stessa risoluzione della mappa raster 3D di input per le mappe di output 2D, indipendentemente dalle impostazioni attuali della regione"
 #~ msgid "Raster map %d Filename: %s already exists. Will be overwritten!"
 #~ msgstr "Mappa raster %d Nome del file: %s già esistente. Sarà sovrascritto!"
@@ -38372,17 +36354,14 @@
 #~ msgstr "Impossibile leggere la riga del raster inferiore \n"
 #~ msgid "Wrong 3D raster map values: Values should in between 0 and 255\n"
-#~ msgstr ""
-#~ "Valori della mappa raster 3D errati! I valori devono essere compresi tra "
-#~ "0 e 255\n"
+#~ msgstr "Valori della mappa raster 3D errati! I valori devono essere compresi tra 0 e 255\n"
 #~ msgid ""
 #~ "Cannot create mask file: G3D_MASK already exists!\n"
 #~ " Use 'g.remove rast3d=G3D_MASK' to remove the existing mask."
 #~ msgstr ""
 #~ "Impossibile creare la mask. MASK G3D già esistente!\n"
-#~ "Usa il comando 'g.remove rast3d=G3D MASK' per rimuovere la maschera "
-#~ "esistente"
+#~ "Usa il comando 'g.remove rast3d=G3D MASK' per rimuovere la maschera esistente"
 #~ msgid "Name of base raster map"
 #~ msgstr "Nome della mappa raster di base"
@@ -38411,41 +36390,28 @@
 #~ msgid "No raster map specified"
 #~ msgstr "Nessuna mappa raster specificata"
-#~ msgid ""
-#~ "One of \"-i\" or \"-r\" or options \"color\", \"rast\" or \"rules\" must "
-#~ "be specified!"
-#~ msgstr ""
-#~ "Dev'essere specificato \"-i\" o \"-r\", o le opzioni \"color\", \"rast\" "
-#~ "o \"rules\"!"
+#~ msgid "One of \"-i\" or \"-r\" or options \"color\", \"rast\" or \"rules\" must be specified!"
+#~ msgstr "Dev'essere specificato \"-i\" o \"-r\", o le opzioni \"color\", \"rast\" o \"rules\"!"
 #~ msgid "Unable to remove color table of raster map <%s>"
-#~ msgstr ""
-#~ "Non è possibile rimuovere la tavola dei colori della mappa raster <%s>"
+#~ msgstr "Non è possibile rimuovere la tavola dei colori della mappa raster <%s>"
 #~ msgid "Color table of raster map <%s> not found"
 #~ msgstr "Tavola dei colori della mappa raster <%s> non trovata"
 #~ msgid "Color table 'random' is not supported for floating point raster map"
-#~ msgstr ""
-#~ "La tavola dei colori 'random' non è supportata dai raster con valori a "
-#~ "virgola mobile"
+#~ msgstr "La tavola dei colori 'random' non è supportata dai raster con valori a virgola mobile"
 #~ msgid "Color table 'grey.eq' is not supported for floating point raster map"
-#~ msgstr ""
-#~ "La tavola dei colori 'grey.eq' non è supportata dai raster con valori a "
+#~ msgstr "La tavola dei colori 'grey.eq' non è supportata dai raster con valori a virgola mobile"
-#~ msgid ""
-#~ "Color table 'grey.log' is not supported for floating point raster map"
-#~ msgstr ""
-#~ "La tavola dei colori 'grey.log' non è supportata dai raster con valori a "
+#~ msgid "Color table 'grey.log' is not supported for floating point raster map"
+#~ msgstr "La tavola dei colori 'grey.log' non è supportata dai raster con valori a virgola mobile"
 #~ msgid "Color table for raster map <%s> set to '%s'"
 #~ msgstr "Tavola dei colori per la mappa raster <%s> impostata a '%s'"
 # della quale/per la quale
-#, fuzzy
 #~ msgid "Name of raster map for which to edit null file"
 #~ msgstr "Nome della mappa raster della quale modificare il valore null"
@@ -38468,7 +36434,6 @@
 #~ msgid "Unable to load 3D raster range"
-#, fuzzy
 #~ msgid "Unable to open file [%s] for reading"
 #~ msgstr "Impossibile aprire il file [%s] per la lettura"
@@ -38479,30 +36444,20 @@
 #~ msgstr "Stampa le informazioni di proiezione in formato GRASS"
 #~ msgid "Georeferenced data file to read projection information from"
-#~ msgstr ""
-#~ "File di dati georeferenziati dai quali leggere le informazioni di "
-#~ "proiezione"
+#~ msgstr "File di dati georeferenziati dai quali leggere le informazioni di proiezione"
-#, fuzzy
 #~ msgid "ASCII file containing a WKT projection description (- for stdin)"
-#~ msgstr ""
-#~ "File ASCII contenente la descrizione della proiezione WKT (- per stdin)"
+#~ msgstr "File ASCII contenente la descrizione di una proiezione WKT (- per stdin)"
 #~ msgid "PROJ.4 projection description (- for stdin)"
 #~ msgstr "Descrizione della proiezione in stile PROJ4 (- per sdin)"
-#, fuzzy
 #~ msgid "Unable to create location: %s"
 #~ msgstr "Non è possibile creare la location: %s"
-#~ msgid ""
-#~ "You must select the PERMANENT mapset before updating the current "
-#~ "location's projection. (Current mapset is %s)"
-#~ msgstr ""
-#~ "Devi selezionare il mapset PERMANENT prima di aggiornare la proioezione "
-#~ "corrente della localtion. (Il mapset corrente è %s)"
+#~ msgid "You must select the PERMANENT mapset before updating the current location's projection. (Current mapset is %s)"
+#~ msgstr "Devi selezionare il mapset PERMANENT prima di aggiornare la proioezione corrente della localtion. (Il mapset corrente è %s)"
-#, fuzzy
 #~ msgid "Projection information updated!"
 #~ msgstr "Informazioni sulla proiezione aggiornate!"
@@ -38563,19 +36518,11 @@
 #~ msgid "Allocate subnets for nearest centres (direction from centre)."
 #~ msgstr "Assegna sottoreti per i centri più vicini (direzione dal centro)."
-#~ msgid ""
-#~ "Centre node must be opened (costs >= 0). Costs of centre node are used in "
-#~ "calculation"
-#~ msgstr ""
-#~ "Il nodo definito come centro dev'essere aperto (costi >= 0). I costi del "
-#~ "nodo centrale vengono utilizzati nel calcolo"
+#~ msgid "Centre node must be opened (costs >= 0). Costs of centre node are used in calculation"
+#~ msgstr "Il nodo definito come centro dev'essere aperto (costi >= 0). I costi del nodo centrale vengono utilizzati nel calcolo"
-#~ msgid ""
-#~ "Categories of centres (points on nodes) to which net will be allocated, "
-#~ "layer for this categories is given by nlayer option"
-#~ msgstr ""
-#~ "Categorie dei centri (punti o nodi) ai quali dev'essere assegnata la "
-#~ "rete, il layer per queste categorie è dato dall'opzione nlayer"
+#~ msgid "Categories of centres (points on nodes) to which net will be allocated, layer for this categories is given by nlayer option"
+#~ msgstr "Categorie dei centri (punti o nodi) ai quali dev'essere assegnata la rete, il layer per queste categorie è dato dall'opzione nlayer"
 #~ msgid "Number of centres: [%d] (nlayer: [%d])"
 #~ msgstr "Numero di centri: [%d] (nlayer: [%d])"
@@ -38592,12 +36539,8 @@
 #~ msgid "Cannot write part of geometry"
 #~ msgstr "Non posso scrivere parte della geometria"
-#~ msgid ""
-#~ "Selects vector objects from an existing vector map and creates a new map "
-#~ "containing only the selected objects."
-#~ msgstr ""
-#~ "Seleziona oggetti vettoriali da una mappa esistente e crea una nuova "
-#~ "mappa contenento solo gli oggetti selezionati."
+#~ msgid "Selects vector objects from an existing vector map and creates a new map containing only the selected objects."
+#~ msgstr "Seleziona oggetti vettoriali da una mappa esistente e crea una nuova mappa contenento solo gli oggetti selezionati."
 #~ msgid "%d categories loaded from table <%s>"
 #~ msgstr "%d categrie caricate dalla tabella <%s>"
@@ -38666,12 +36609,8 @@
 #~ msgid "Display the HTML man pages of GRASS"
 #~ msgstr "Visualizza la pagina di supporto HTML di GRASS "
-#~ msgid ""
-#~ "Exports a vector map to a GPS receiver or file format supported by "
-#~ "GpsBabel."
-#~ msgstr ""
-#~ "Esporta un vettore in un GPS o un file con un formato supportato da "
-#~ "GPSBabel"
+#~ msgid "Exports a vector map to a GPS receiver or file format supported by GpsBabel."
+#~ msgstr "Esporta un vettore in un GPS o un file con un formato supportato da GPSBabel"
 #~ msgid "GpsBabel supported output format"
 #~ msgstr "Formato di output supportato da GpsBabel"
@@ -38679,17 +36618,11 @@
 #~ msgid "Name of the column"
-#~ msgid ""
-#~ "Export a raster map to a text file as x,y,z values based on cell centers."
-#~ msgstr ""
-#~ "Esporta un raster in un file di testo come valori x,y,z basato sui centri "
-#~ "delle celle"
+#~ msgid "Export a raster map to a text file as x,y,z values based on cell centers."
+#~ msgstr "Esporta un raster in un file di testo come valori x,y,z basato sui centri delle celle"
-#~ msgid ""
-#~ "Fills no-data areas in raster maps using v.surf.rst splines interpolation"
-#~ msgstr ""
-#~ "Riempi aree senza dati di un raster usando interpolazione spline v.surf."
-#~ "rst "
+#~ msgid "Fills no-data areas in raster maps using v.surf.rst splines interpolation"
+#~ msgstr "Riempi aree senza dati di un raster usando interpolazione spline v.surf.rst "
 #~ msgid "raster input map (LANDSAT channel 1)"
 #~ msgstr "raster di input (LANDSAT canale 1)"
@@ -38710,8 +36643,7 @@
 #~ msgstr "raster di input (LANDSAT canale 7)"
 #~ msgid "Vector map for which to add new attribute table"
-#~ msgstr ""
-#~ "Mappa vettoriale per la quale aggiungere una nuova tabella degli attributi"
+#~ msgstr "Mappa vettoriale per la quale aggiungere una nuova tabella degli attributi"
 #~ msgid "Name of aspect raster map"
 #~ msgstr "Nome della mappa raster delle esposizioni"
@@ -38729,9 +36661,8 @@
 #~ msgid "Name of reflectance raster maps to be corrected topographically"
 #~ msgstr "Nome dei raster da unire insieme"
-#, fuzzy
 #~ msgid "Name of input base raster map (elevation or illumination)"
+#~ msgstr "Nome della mappa raster di base in input (elevazione o illuminazione)"
 #, fuzzy
 #~ msgid "Output sun illumination terrain model"
@@ -38771,13 +36702,10 @@
 #~ msgid "Unused"
 #~ msgstr "Non usato"
+# row%s : singolare/plurale?
 #, fuzzy
-#~ msgid ""
-#~ "Header indicates %d row%s in the raster map, but the actual file format "
-#~ "indicates %d row%s"
-#~ msgstr ""
-#~ "L'intestazione indica %d righe%s nella mappa raster, ma il formato reale "
-#~ "del file indica %d righe%s"
+#~ msgid "Header indicates %d row%s in the raster map, but the actual file format indicates %d row%s"
+#~ msgstr "L'intestazione indica %d righe%s nella mappa raster, ma il formato reale del file indica %d righe%s"
 #~ msgid "Edit header for [%s]? "
 #~ msgstr "Modificare l'intestazione per [%s]?"
@@ -38796,18 +36724,11 @@
 #~ msgid "Quant table not changed for %s"
 #~ msgstr "Tabella di quantizzazione invariata per %s"
-#~ msgid ""
-#~ "quiet' instead"
-#~ msgstr ""
-#~ "Il flag '-q' è superato e in futuro verrà rimosso. Usare invece '--quiet"
+#~ msgid "The '-q' flag is superseded and will be removed in future. Please use '--quiet' instead"
+#~ msgstr "Il flag '-q' è superato e in futuro verrà rimosso. Usare invece '--quiet"
-#~ msgid ""
-#~ "Mode 1: instantaneous solar incidence angle & irradiance given a set "
-#~ "local time"
-#~ msgstr ""
-#~ "Modalità 1: angolo di incidenza e radiazione istantanei usando un'ora "
-#~ "locale definita"
+#~ msgid "Mode 1: instantaneous solar incidence angle & irradiance given a set local time"
+#~ msgstr "Modalità 1: angolo di incidenza e radiazione istantanei usando un'ora locale definita"
 #~ msgid "rows changed from %d to %d"
 #~ msgstr "righe cambiate da %d a %d"
@@ -38815,20 +36736,14 @@
 #~ msgid "cols changed from %d to %d"
 #~ msgstr "colonne cambiate da %d a %d"
-#, fuzzy
 #~ msgid "raster, landscape structure analysis, patch index"
 #~ msgstr "raster, analisi della struttura del paesaggio, indice di patch"
 #~ msgid "Verbose mode"
 #~ msgstr "Modalità verbosa"
-#~ msgid ""
-#~ "Finds the median of values in a cover map within areas assigned the same "
-#~ msgstr ""
-#~ "Trova la mediana dei valori di una mappa di copertura all'interno di aree "
-#~ "di una mappa di base definita dall'utente appartenenti alla stessa "
-#~ "categoria."
+#~ msgid "Finds the median of values in a cover map within areas assigned the same category value in a user-specified base map."
+#~ msgstr "Trova la mediana dei valori di una mappa di copertura all'interno di aree di una mappa di base definita dall'utente appartenenti alla stessa categoria."
 #~ msgid "raster, mask"
 #~ msgstr "raster, maschera"
@@ -38838,3 +36753,138 @@
 #~ msgid "GeoTIFF"
 #~ msgstr "GeoTIFF"
+#~ msgid "Unable to create raster map"
+#~ msgstr "Impossibile creare la mappa raster"
+#~ msgid "Link to raster map <%s> created"
+#~ msgstr "Collegamento alla mappa raster <%s> creato"
+#~ msgid "Unable to set window"
+#~ msgstr "Non è possibile impostare la finestra"
+#~ msgid "%s: base raster map not found"
+#~ msgstr "%s: mappa raster di base non trovata"
+#~ msgid "NULL value computed (row %d, col %d)"
+#~ msgstr "Valore NULL calcolato (riga %d colonna %d)"
+#~ msgid "Illegal delete request"
+#~ msgstr "Richiesta di cancellazione non valida"
+#~ msgid "Bad start cell"
+#~ msgstr "Cella iniziale non corretta"
+#~ msgid "The height of the river bed in [m]"
+#~ msgstr "L'altezza del letto del fiume in [m]"
+#~ msgid "Name of real-sky beam radiation coefficient raster map [-]"
+#~ msgstr "Nome della mappa raster del coefficiente di radiazione diretta in condizioni di cielo reali [-]"
+#~ msgid "Name of real-sky diffuse radiation coefficient raster map [-]"
+#~ msgstr "Nome della mappa raster del coefficiente di radiazione diffusa in condizioni di cielo reali [-]"
+#~ msgid "Name for distance output map"
+#~ msgstr "Nome della mappa di output delle distanze"
+#~ msgid "Unable to update boundaries"
+#~ msgstr "Non è possibile aggiornare i confini"
+#~ msgid "raster, sun position"
+#~ msgstr "raster, posizione del sole"
+#~ msgid "Output basic information about a raster map layer."
+#~ msgstr "Stampa informazioni basi di un raster."
+#~ msgid "Input map"
+#~ msgstr "Mappa di input"
+#~ msgid "Error writing G3D double data"
+#~ msgstr "Errore nella scrittura dei dati a precisione doppia G3D"
+#~ msgid "raster, raster3d, voxel, conversion"
+#~ msgstr "raster, raster3d, voxel, conversione"
+#~ msgid "Calculating covariance matrix..."
+#~ msgstr "Calcolo della matrice di covarianza in corso..."
+#~ msgid " 1. nearest neighbor\n"
+#~ msgstr " 1. vicino più prossimo\n"
+#~ msgid " 2. bilinear\n"
+#~ msgstr " 2. bilineare\n"
+#, fuzzy
+#~ msgid " 3. bicubic\n"
+#~ msgstr " 3. bicubica\n"
+#~ msgid "Reading raster map <%s in %s> ..."
+#~ msgstr "Lettura della mappa raster <%s in %s> in corso ..."
+#~ msgid "Unable to set size"
+#~ msgstr "impossibile impostare la dimensione"
+#~ msgid "List available mapsets"
+#~ msgstr "Elenco dei mapset disponibili"
+#~ msgid "You don't have permission to use this mapset"
+#~ msgstr "Non hai i permessi per usare questo mapset"
+#~ msgid "The mapset does not exist. Use -c flag to create it."
+#~ msgstr "Il mapset non esiste. Usa l'opzione -c per crearlo"
+#~ msgid "Creates a Voronoi diagram from an input vector map containing points or centroids."
+#~ msgstr "Crea un diagramma di Voronoi da un vettoriale contenente punti o centroidi."
+#~ msgid "Unknown column type '%s'"
+#~ msgstr "Tipo di colonna sconosciuto '%s'"
+#, fuzzy
+#~ msgid "Delete line and exit"
+#~ msgstr "Mostra le tabelle ed esce"
+#~ msgid "Key column name"
+#~ msgstr "Nome della colonna chiave"
+#~ msgid "%d features written"
+#~ msgstr "%d elementi scritti"
+#~ msgid "Unknown operator"
+#~ msgstr "Operatore sconosciuto"
+#~ msgid "Copying vector lines..."
+#~ msgstr "Sto copiando linee vettoriali..."
+#~ msgid "Print topology information only"
+#~ msgstr "Stampa solo le informazioni sulla topologia"
+#~ msgid "Name of input vector points map for which to edit attribute table"
+#~ msgstr "Nome della mappa vettoriale di punti della quale editare la tabella attributi"
+#~ msgid "Cannot connect to MySQL: "
+#~ msgstr "Non riesco a connettermi a MySQL"
+#~ msgid "Cannot get list of tables:\n"
+#~ msgstr "Non riesco a mostrare i database:\n"
+#~ msgid "Cannot recognize boolean value"
+#~ msgstr "Non riesco ad individuare il valore booleano"
+#~ msgid "List available modules in the GRASS Addons SVN repository"
+#~ msgstr "Elenca i moduli disponibili nel repository SVN Addons di GRASS "
+#, fuzzy
+#~ msgid "Error writing row %d"
+#~ msgstr "Errore durante la scrittura della riga %d"
+#, fuzzy
+#~ msgid "Displays vector data in the active frame on the graphics monitor."
+#, fuzzy
+#~ msgid "Name of input vector points map"
+#~ msgstr "Nome della mappa di input"
+#, fuzzy
+#~ msgid "Cannot open vector map <%s>"
+#~ msgstr "Non riesco a trovare il file raster %s"
