[GRASS-SVN] r50570 - in grass/trunk: gui/wxpython/core
gui/wxpython/gui_core lib/python
svn_grass at osgeo.org
Mon Jan 30 15:32:16 EST 2012
Author: martinl
Date: 2012-01-30 12:32:16 -0800 (Mon, 30 Jan 2012)
New Revision: 50570
grass/trunk/gui/wxpython/core/gcmd.py
grass/trunk/gui/wxpython/gui_core/forms.py
grass/trunk/gui/wxpython/gui_core/goutput.py
grass/trunk/lib/python/core.py
grass/trunk/lib/python/task.py
wxGUI: attempt to catch error when getting interface description
Modified: grass/trunk/gui/wxpython/core/gcmd.py
--- grass/trunk/gui/wxpython/core/gcmd.py 2012-01-30 20:22:25 UTC (rev 50569)
+++ grass/trunk/gui/wxpython/core/gcmd.py 2012-01-30 20:32:16 UTC (rev 50570)
@@ -140,7 +140,7 @@
self.value = value
def __str__(self):
- return str(self.value)
+ return self.value
class Popen(subprocess.Popen):
"""!Subclass subprocess.Popen"""
Modified: grass/trunk/gui/wxpython/gui_core/forms.py
--- grass/trunk/gui/wxpython/gui_core/forms.py 2012-01-30 20:22:25 UTC (rev 50569)
+++ grass/trunk/gui/wxpython/gui_core/forms.py 2012-01-30 20:32:16 UTC (rev 50570)
@@ -2010,8 +2010,8 @@
global _blackList
self.grass_task = gtask.parse_interface(gcmd.GetRealCmd(cmd[0]),
blackList = _blackList)
- except (grass.ScriptError, ValueError), e:
- raise gcmd.GException(e.value)
+ except (grass.ScriptError, ValueError), e:
+ raise gcmd.GException(e)
# if layer parameters previously set, re-insert them into dialog
if completed is not None:
Modified: grass/trunk/gui/wxpython/gui_core/goutput.py
--- grass/trunk/gui/wxpython/gui_core/goutput.py 2012-01-30 20:22:25 UTC (rev 50569)
+++ grass/trunk/gui/wxpython/gui_core/goutput.py 2012-01-30 20:32:16 UTC (rev 50570)
@@ -528,7 +528,13 @@
else:
# other GRASS commands (r|v|g|...)
- task = GUI(show = None).ParseCommand(command)
+ try:
+ task = GUI(show = None).ParseCommand(command)
+ except GException, e:
+ GError(parent = self,
+ message = unicode(e),
+ showTraceback = False)
+ return
hasParams = False
if task:
Modified: grass/trunk/lib/python/core.py
--- grass/trunk/lib/python/core.py 2012-01-30 20:22:25 UTC (rev 50569)
+++ grass/trunk/lib/python/core.py 2012-01-30 20:32:16 UTC (rev 50570)
@@ -61,9 +61,9 @@
class ScriptError(Exception):
def __init__(self, msg):
self.value = msg
def __str__(self):
- return repr(self.value)
+ return self.value
raise_on_error = False # raise exception instead of calling fatal()
debug_level = 0 # DEBUG level
Modified: grass/trunk/lib/python/task.py
--- grass/trunk/lib/python/task.py 2012-01-30 20:22:25 UTC (rev 50569)
+++ grass/trunk/lib/python/task.py 2012-01-30 20:32:16 UTC (rev 50570)
@@ -433,6 +433,7 @@
try:
cmdout, cmderr = Popen([cmd, '--interface-description'], stdout = PIPE,
stderr = PIPE).communicate()
# TODO: replace ugly hack bellow
if not cmdout and sys.platform == 'win32':
if os.path.splitext(cmd)[1] == '':
@@ -441,6 +442,11 @@
os.chdir(os.path.join(os.getenv('GISBASE'), 'scripts'))
cmdout, cmderr = Popen([sys.executable, cmd, '--interface-description'], stdout = PIPE,
+ if cmderr:
+ raise ScriptError, _("Unable to fetch interface description for command '%(cmd)s'."
+ "\n\nDetails: %(det)s") % { 'cmd' : cmd, 'det' : decode(cmderr) }
except OSError, e:
"\n\nDetails: %(det)s") % { 'cmd' : cmd, 'det' : e }
