[GRASS-SVN] r50576 - grass/trunk/debian
Mon Jan 30 21:25:58 EST 2012
Author: hamish
Date: 2012-01-30 18:25:58 -0800 (Mon, 30 Jan 2012)
New Revision: 50576
   grass/trunk/debian/README.debian
wordo, beware old versions lying about (merge from devbr6)
Modified: grass/trunk/debian/README.debian
--- grass/trunk/debian/README.debian	2012-01-31 02:25:19 UTC (rev 50575)
+++ grass/trunk/debian/README.debian	2012-01-31 02:25:58 UTC (rev 50576)
@@ -26,16 +26,18 @@
   nano debian/changelog
-# After that, you can build current version of GRASS with
+# After that, you can build the current version of GRASS with
   debuild -i -uc -us -b
 # in main GRASS source directory. After the packages are generated, you can
-# install them with
+# install them with:
   dpkg -i ../grass*.deb
+# (make sure to remove older grass*.deb files first)
 # to try again, first clean out the old build by running:
 #  (from the main source dir)
