[GRASS-SVN] r50603 - grass/branches/develbranch_6/gui/wxpython/xml
svn_grass at osgeo.org
Tue Jan 31 19:46:25 EST 2012
Author: martinl
Date: 2012-01-31 16:46:25 -0800 (Tue, 31 Jan 2012)
New Revision: 50603
grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
wxGUI: menu update (tools/update_menudata.py)
Modified: grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
--- grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml 2012-02-01 00:45:36 UTC (rev 50602)
+++ grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml 2012-02-01 00:46:25 UTC (rev 50603)
@@ -1074,7 +1074,7 @@
<items>
<menuitem>
<label>Raster to vector</label>
- <help>Converts a raster map into a vector map layer.</help>
+ <help>Converts a raster map into a vector map.</help>
<keywords>raster,conversion,vectorization</keywords>
<handler>OnMenuCmd</handler>
<command>r.to.vect</command>
@@ -1357,7 +1357,7 @@
</menuitem>
<menuitem>
<label>Watershed analysis</label>
- <help>Watershed basin analysis program.</help>
+ <help>Watershed basin analysis program</help>
<keywords>raster,hydrology</keywords>
<command>r.watershed</command>
@@ -1371,7 +1371,7 @@
</menuitem>
<menuitem>
<label>Watershed basin creation</label>
- <help>Watershed basin creation program.</help>
+ <help>Creates watershed basins.</help>
<command>r.water.outlet</command>
@@ -1380,7 +1380,7 @@
<menuitem>
<label>Groundwater modeling</label>
<help>Numerical calculation program for transient, confined and unconfined groundwater flow in two dimensions.</help>
- <keywords>raster,hydrology</keywords>
+ <keywords>raster</keywords>
<command>r.gwflow</command>
</menuitem>
@@ -1769,7 +1769,7 @@
<separator />
<menuitem>
<label>Fill NULL cells</label>
- <help>Fills no-data areas in raster maps using v.surf.rst splines interpolation.</help>
+ <help>Fills no-data areas in raster maps using spline interpolation.</help>
<keywords>raster,elevation,interpolation</keywords>
<command>r.fillnulls</command>
