[GRASS-SVN] r52256 - grass/trunk/gui/wxpython/mapdisp
Sun Jul 1 03:27:45 PDT 2012
Author: martinl
Date: 2012-07-01 03:27:45 -0700 (Sun, 01 Jul 2012)
New Revision: 52256
   grass/trunk/gui/wxpython/mapdisp/mapwindow.py
wxGUI: GraphicsSet/GraphicsSetItem implemented by Stepan Turek
Modified: grass/trunk/gui/wxpython/mapdisp/mapwindow.py
--- grass/trunk/gui/wxpython/mapdisp/mapwindow.py	2012-07-01 08:46:09 UTC (rev 52255)
+++ grass/trunk/gui/wxpython/mapdisp/mapwindow.py	2012-07-01 10:27:45 UTC (rev 52256)
@@ -5,6 +5,8 @@
 Classes:
  - mapwindow::BufferedWindow
+ - mapwindow::GraphicsSet
+ - mapwindow::GraphicsSetItem
 (C) 2006-2012 by the GRASS Development Team
@@ -15,13 +17,14 @@
 @author Michael Barton
 @author Jachym Cepicky
 @author Vaclav Petras <wenzeslaus gmail.com> (handlers support)
- at author Stepan Turek <stepan.turek seznam.cz> (handlers support)
+ at author Stepan Turek <stepan.turek seznam.cz> (handlers support, GraphicsSet)
 import os
 import time
 import math
 import sys
+from copy import copy
 import wx
@@ -113,6 +116,9 @@
         self.dragid   = -1
         self.lastpos  = (0, 0)
+        # list for registration of graphics to draw
+        self.graphicsSetList = []
     def _definePseudoDC(self):
         """!Define PseudoDC objects to use
@@ -636,20 +642,27 @@
         # redraw pdcTmp if needed
+        # draw registered graphics
+        if  len(self.graphicsSetList) > 0:
+            penOrig = self.pen
+            polypenOrig = self.polypen
+            for item in self.graphicsSetList:
+                try:
+                    item.Draw(self.pdcTmp)
+                except:
+                    GError(parent = self,
+                           message = _('Unable to draw registered graphics. '
+                                       'The graphics was unregistered.'))
+                    self.UnregisterGraphicsToDraw(item)
+            self.pen = penOrig
+            self.polypen = polypenOrig
         if len(self.polycoords) > 0:
             self.DrawLines(self.pdcTmp)
-        if not self.parent.IsStandalone() and \
-                self.parent.GetLayerManager().gcpmanagement:
-            # -> georectifier (redraw GCPs)
-            if 'gcpdisp' in self.parent.toolbars.keys():
-                if self == self.parent.TgtMapWindow:
-                    coordtype = 'target'
-                else:
-                    coordtype = 'source'
-                self.parent.DrawGCP(coordtype)
         # clear measurement
@@ -873,7 +886,7 @@
         @todo implement rotation
         @param pdc PseudoDC
-        @param coord center coordinates
+        @param coords center coordinates
         @param rotation rotate symbol
         @param text draw also text (text, font, color, rotation)
         @param textAlign alignment (default 'lower-right')
@@ -1716,7 +1729,7 @@
             os.environ["GRASS_REGION"] = tmpreg
     def Distance(self, beginpt, endpt, screen = True):
-        """!Calculete distance
+        """!Calculates distance
         Ctypes required for LL-locations
@@ -1759,3 +1772,334 @@
         toolbar.action['id'] = vars(toolbar)["pointer"]
         toolbar.OnTool(None)
         self.parent.OnPointer(event = None)
+    def RegisterGraphicsToDraw(self, graphicsType, setStatusFunc = None, drawFunc = None):
+        """! Method allows to register graphics to draw.
+        @param type (string) - graphics type: "point" or "line"
+        @param setStatusFunc (function reference) - function called before drawing each item
+                Status function should be in this form: setStatusFunc(item, itemOrderNum)
+                    item - passes instance of GraphicsSetItem which will be drawn
+                    itemOrderNum - number of item in drawing order (from O)
+                                   Hidden items are also counted in drawing order.
+        @param drawFunc (function reference) - allows to define own function for drawing
+                            If function is not defined DrawCross method is used for type "point"
+                            or DrawLines method for type "line".
+        @return reference to GraphicsSet, which was added.
+        item = GraphicsSet(parentMapWin = self,
+                           graphicsType = graphicsType,
+                           setStatusFunc = setStatusFunc,
+                           drawFunc = drawFunc)
+        self.graphicsSetList.append(item)
+        return item
+    def UnregisterGraphicsToDraw(self, item):
+        """!Unregisteres GraphicsSet instance
+        @param item (GraphicsSetItem) - item to unregister
+        @return True - if item was unregistered
+        @return False - if item was not found
+        if item in self.graphicsSetList:
+            self.graphicsSetList.remove(item)
+            return True
+        return False
+class GraphicsSet:
+    def __init__(self, parentMapWin, graphicsType, setStatusFunc = None, drawFunc = None):
+        """!Class, which contains instances of GraphicsSetItem and
+            draws them For description of parameters look at method
+            RegisterGraphicsToDraw in BufferedWindow class.
+        self.pens =  {
+            "default"  :  wx.Pen(colour = wx.BLACK, width = 2, style = wx.SOLID),
+            "selected" :  wx.Pen(colour = wx.GREEN, width = 2, style = wx.SOLID),
+            "unused"   :  wx.Pen(colour = wx.LIGHT_GREY, width = 2, style = wx.SOLID),
+            "highest"  :  wx.Pen(colour = wx.RED, width = 2, style = wx.SOLID)
+        # list contains instances of GraphicsSetItem
+        self.itemsList = []
+        self.properties    = {}
+        self.graphicsType  = graphicsType
+        self.parentMapWin  = parentMapWin
+        self.setStatusFunc = setStatusFunc
+        if drawFunc:
+            self.drawFunc = drawFunc
+        elif self.graphicsType == "point":
+            self.properties["size"] = 5
+            self.properties["text"] = {}
+            self.properties["text"]['font'] = wx.Font(pointSize = self.properties["size"],
+                                                      family = wx.FONTFAMILY_DEFAULT,
+                                                      style = wx.FONTSTYLE_NORMAL,
+                                                      weight = wx.FONTWEIGHT_NORMAL)
+            self.properties["text"]['active'] = True
+            self.drawFunc = self.parentMapWin.DrawCross
+        elif self.graphicsType == "line":
+            self.drawFunc = self.parentMapWin.DrawLines
+    def Draw(self, pdc):
+        """!Draws all containing items.
+        @param pdc - device context, where items are drawn
+        itemOrderNum = 0
+        for item in self.itemsList:
+            if self.setStatusFunc is not None:
+                self.setStatusFunc(item, itemOrderNum)
+            if item.GetPropertyVal("hide") == True:
+                itemOrderNum += 1
+                continue
+            if self.graphicsType  == "point":
+                if item.GetPropertyVal("penName"):
+                    self.parentMapWin.pen = self.pens[item.GetPropertyVal("penName")]
+                else:
+                    self.parentMapWin.pen = self.pens["default"]
+                coords = self.parentMapWin.Cell2Pixel(item.GetCoords())
+                size = self.properties["size"]
+                self.properties["text"]['coords'] = [coords[0] + size, coords[1] + size, size, size]
+                self.properties["text"]['color'] = self.parentMapWin.pen.GetColour()
+                self.properties["text"]['text'] = item.GetPropertyVal("label")
+                self.drawFunc(pdc = pdc,
+                              coords = coords,
+                              text = self.properties["text"],
+                              size = self.properties["size"])
+                if item.GetPropertyVal("pen"):
+                    self.parentMapWin.polypen = self.pens[item.GetPropertyVal("pen")]
+                else:
+                    self.parentMapWin.polypen = self.pens["default"]
+                              polycoords = coords)
+            itemOrderNum += 1
+    def AddItem(self, coords, penName = None, label = None, hide = False):
+        """!Append item to the list.
+        Added item is put to the last place in drawing order.
+        Could be 'point' or 'line' according to graphicsType.
+        @param coords - list of east, north coordinates (double) of item
+                        Example: point: [1023, 122]
+                                 line: [[10, 12],[20,40],[23, 2334]]
+        @param penName (string) - the 'default' pen is used if is not defined
+        @param label (string) - label, which will be drawn with point. It is relavant just for 'point' type.
+        @param hide (bool) -  If it is True, the item is not drawn, when self.Draw is called.
+        @return (GraphicsSetItem) - added item reference
+        item = GraphicsSetItem(coords = coords, penName = None, label = None, hide = False)
+        self.itemsList.append(item)
+        return item
+    def DeleteItem(self, item):
+        """!Deletes item
+        @param item (GraphicsSetItem) - item to remove
+        @return True if item was removed
+        @return False if item was not found
+        try:
+            self.itemsList.remove(item)
+        except:
+            return False
+        return True
+    def GetAllItems(self):
+        """!Returns list of all containing instances of GraphicsSetItem, in order
+        as they are drawn. If you want to change order of drawing use: SetItemDrawOrder method.
+        # user can edit objects but not order in list, that is reason,
+        # why is returned shallow copy of data list it should be used
+        # SetItemDrawOrder for changing order
+        return copy(self.itemsList)
+    def GetItem(self, drawNum):
+        """!Get given item from the list.
+        @param drawNum (int) - drawing order (index) number of item
+        @return instance of GraphicsSetItem which is drawn in drawNum order
+        @return False if drawNum was out of range
+        if drawNum < len(self.itemsList) and drawNum >= 0:
+            return self.itemsList[drawNum]
+        else:
+            return False
+    def SetPropertyVal(self, propName, propVal):
+        """!Set property value
+        @param propName (string) - property name: "size", "text"
+                                 - both properties are relevant for "point" type
+        @param propVal - property value to be set
+        @return True - if value was set
+        @return False - if propName is not "size" or "text" or type is "line"
+        if self.properties.has_key(propName):
+            self.properties[propName] = propVal
+            return True
+        return False
+    def GetPropertyVal(self, propName):
+        """!Get property value
+        Raises KeyError if propName is not "size" or "text" or type is
+        "line"
+        @return value of property
+            return self.properties[propName]
+        raise KeyError(_("Property does not exist: %s") % (propName))
+    def AddPen(self, penName, pen):
+        """!Add pen
+        @param penName (string) - name of added pen
+        @param pen (wx.Pen) - added pen
+        @return True - if pen was added
+        @return False - if pen already exists
+        if self.pens.has_key(penName):
+            return False
+        self.pens[penName] = pen
+        return True
+    def GetPen(self, penName):
+        """!Get existing pen
+        @param penName (string) - name of pen
+        @return wx.Pen reference if is found
+        @return None if penName was not found
+            return self.pens[penName]
+        return None
+    def SetItemDrawOrder(self, item, drawNum):
+        """!Set draw order for item
+        @param drawNum (int) - drawing order of item to be set
+        @return True - if order was changed
+        @return False - if drawNum is out of range or item was not found
+        if drawNum < len(self.itemsList) and drawNum >= 0 and \
+            item in self.itemsList:
+            self.itemsList.insert(drawNum, self.itemsList.pop(self.itemsList.index(item)))
+            return True
+        return False
+    def GetItemDrawOrder(self, item):
+        """!Get draw order for given item
+        @return (int) - drawing order of item
+        @return None - if item was not found
+        try:
+            return self.itemsList.index(item)
+        except:
+            return None
+class GraphicsSetItem:
+    def __init__(self, coords, penName = None, label = None, hide = False):
+        """!Could be point or line according to graphicsType in
+        GraphicsSet class
+        @param coords - list of coordinates (double) of item
+        @param penName (string) - if it is not defined 'default' pen is used
+        @param label (string) - label, which will be drawn with point. It is relevant just for 'point' type
+        @param hide (bool) - if it is True, item is not drawn
+                             Hidden items are also counted in drawing order in GraphicsSet class.
+        self.coords = coords
+        self.properties = { "penName" : penName,
+                            "hide"    : hide,
+                            "label"   : label }
+        @param propName (string) - property name: "penName", "hide" or "label"
+                                 - property "label" is relevant just for 'point' type
+        @return False - if propName is not "penName", "hide" or "label"
+            return True
+        return False
+        Raises KeyError if propName is not "penName", "hide" or
+        "label".
+    def SetCoords(self, coords):
+        """!Set coordinates of item
+    def GetCoords(self):
+        """!Get item coordinates
+        @returns coordinates
+        return self.coords
