[GRASS-SVN] r52261 - in grass/trunk/temporal: t.vect.db.select t.vect.observe.strds
Sun Jul 1 04:41:16 PDT 2012
Author: neteler
Date: 2012-07-01 04:41:15 -0700 (Sun, 01 Jul 2012)
New Revision: 52261
   grass/trunk/temporal/t.vect.db.select/t.vect.db.select.html
   grass/trunk/temporal/t.vect.db.select/t.vect.db.select.py
   grass/trunk/temporal/t.vect.db.select/test.t.vect.db.select.sh
   grass/trunk/temporal/t.vect.observe.strds/test.t.vect.observe.strds.relative.sh
svn propset
Property changes on: grass/trunk/temporal/t.vect.db.select/t.vect.db.select.html
___________________________________________________________________
Added: svn:mime-type
   + text/html
Added: svn:keywords
   + Author Date Id
Added: svn:eol-style
   + native
Property changes on: grass/trunk/temporal/t.vect.db.select/t.vect.db.select.py
   + text/x-python
   + native
Modified: grass/trunk/temporal/t.vect.db.select/test.t.vect.db.select.sh
--- grass/trunk/temporal/t.vect.db.select/test.t.vect.db.select.sh	2012-07-01 10:46:55 UTC (rev 52260)
+++ grass/trunk/temporal/t.vect.db.select/test.t.vect.db.select.sh	2012-07-01 11:41:15 UTC (rev 52261)
@@ -41,3 +41,4 @@
 g.remove vect=prec_observer,test_extract
 g.remove rast=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
Property changes on: grass/trunk/temporal/t.vect.db.select/test.t.vect.db.select.sh
   + text/x-sh
   + native
Property changes on: grass/trunk/temporal/t.vect.observe.strds/test.t.vect.observe.strds.relative.sh
   + text/x-sh
   + native
