[GRASS-SVN] r52271 - grass/trunk/raster/r.external
Sun Jul 1 10:05:46 PDT 2012
Author: mmetz
Date: 2012-07-01 10:05:46 -0700 (Sun, 01 Jul 2012)
New Revision: 52271
   grass/trunk/raster/r.external/link.c
   grass/trunk/raster/r.external/main.c
   grass/trunk/raster/r.external/proto.h
r.external: close GDALDataset; remove r flag: approximate range is not ok
Modified: grass/trunk/raster/r.external/link.c
--- grass/trunk/raster/r.external/link.c	2012-07-01 17:03:53 UTC (rev 52270)
+++ grass/trunk/raster/r.external/link.c	2012-07-01 17:05:46 UTC (rev 52271)
@@ -5,7 +5,7 @@
 #include "proto.h"
-void query_band(GDALRasterBandH hBand, const char *output, int exact_range,
+void query_band(GDALRasterBandH hBand, const char *output,
 		struct Cell_head *cellhd, struct band_info *info)
     int bGotMin, bGotMax;
@@ -52,7 +52,7 @@
     info->range[0] = GDALGetRasterMinimum(hBand, &bGotMin);
     info->range[1] = GDALGetRasterMaximum(hBand, &bGotMax);
     if(!(bGotMin && bGotMax))
-	GDALComputeRasterMinMax(hBand, !exact_range, info->range);
+	GDALComputeRasterMinMax(hBand, 0, info->range);
     Rast_init_colors(&info->colors);
Modified: grass/trunk/raster/r.external/main.c
--- grass/trunk/raster/r.external/main.c	2012-07-01 17:03:53 UTC (rev 52270)
+++ grass/trunk/raster/r.external/main.c	2012-07-01 17:05:46 UTC (rev 52271)
@@ -42,7 +42,7 @@
 	struct Option *input, *source, *output, *band, *title;
     } parm;
     struct {
-	struct Flag *o, *f, *e, *r, *h, *v;
+	struct Flag *o, *f, *e, *h, *v;
     } flag;
     int min_band, max_band, band;
     struct band_info info;
@@ -105,10 +105,6 @@
     flag.e->label = _("Extend region extents based on new dataset");
     flag.e->description = _("Also updates the default region if in the PERMANENT mapset");
-    flag.r = G_define_flag();
-    flag.r->key = 'r';
-    flag.r->description = _("Require exact range");
     flag.h = G_define_flag();
     flag.h->key = 'h';
     flag.h->description = _("Flip horizontally");
@@ -209,13 +205,16 @@
 		title2 = G_store(title);
-	query_band(hBand, output2, flag.r->answer, &cellhd, &info);
+	query_band(hBand, output2, &cellhd, &info);
 	create_map(input, band, output2, &cellhd, &info, title, flip);
 	G_free(output2);
 	G_free(title2);
+    /* close the GDALDataset to avoid segfault in libgdal */
+    GDALClose(hDS);
     if (flag.e->answer)
 	update_default_window(&cellhd);
Modified: grass/trunk/raster/r.external/proto.h
--- grass/trunk/raster/r.external/proto.h	2012-07-01 17:03:53 UTC (rev 52270)
+++ grass/trunk/raster/r.external/proto.h	2012-07-01 17:05:46 UTC (rev 52271)
@@ -21,7 +21,7 @@
 /* link.c */
-void query_band(GDALRasterBandH, const char *, int,
+void query_band(GDALRasterBandH, const char *,
 		struct Cell_head *, struct band_info *);
 void make_cell(const char *, const struct band_info *);
 void make_link(const char *, const char *, int,
