[GRASS-SVN] r52302 - grass/branches/releasebranch_6_4/scripts/v.db.addcol
svn_grass at osgeo.org
Wed Jul 4 05:12:04 PDT 2012
Author: neteler
Date: 2012-07-04 05:12:04 -0700 (Wed, 04 Jul 2012)
New Revision: 52302
grass/branches/releasebranch_6_4/scripts/v.db.addcol/v.db.addcol
backport of r52299
Modified: grass/branches/releasebranch_6_4/scripts/v.db.addcol/v.db.addcol
--- grass/branches/releasebranch_6_4/scripts/v.db.addcol/v.db.addcol 2012-07-04 10:52:22 UTC (rev 52301)
+++ grass/branches/releasebranch_6_4/scripts/v.db.addcol/v.db.addcol 2012-07-04 12:12:04 UTC (rev 52302)
@@ -77,8 +77,7 @@
export LC_NUMERIC
### setup enviro vars ###
-eval `g.gisenv`
-: ${GISBASE?} ${GISDBASE?} ${LOCATION_NAME?} ${MAPSET?}
+eval `g.gisenv get=MAPSET`
# does map exist in CURRENT mapset?
eval `g.findfile element=vector file="$GIS_OPT_MAP" mapset="$MAPSET"`
@@ -108,7 +107,7 @@
exit 1
fi
- echo "ALTER TABLE $table ADD COLUMN $col" | db.execute database="${database}" driver="${driver}"
+ echo "ALTER TABLE $table ADD COLUMN $col" | db.execute database="$database" driver="$driver"
if [ $? -eq 1 ] ; then
g.message -e "Cannot continue (problem adding column)."
exit 1
@@ -118,7 +117,7 @@
# write cmd history:
-v.support "${GIS_OPT_MAP}" cmdhist="${CMDLINE}"
+v.support "$GIS_OPT_MAP" cmdhist="${CMDLINE}"
exit 0
