[GRASS-SVN] r52309 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Thu Jul 5 07:36:21 PDT 2012
Author: wenzeslaus
Date: 2012-07-05 07:36:20 -0700 (Thu, 05 Jul 2012)
New Revision: 52309
grass/trunk/lib/vector/Vlib/constraint.c
Vlib: dox: updating documentation according to V2_read_next_line_nat etc. where Vect_box_overlap is used
Modified: grass/trunk/lib/vector/Vlib/constraint.c
--- grass/trunk/lib/vector/Vlib/constraint.c 2012-07-05 13:19:49 UTC (rev 52308)
+++ grass/trunk/lib/vector/Vlib/constraint.c 2012-07-05 14:36:20 UTC (rev 52309)
@@ -34,8 +34,10 @@
\brief Set constraint region
Vect_read_next_line() will read only features inside of given
- region. Constraint is ignored for random access - Vect_read_line().
+ region or features with overlapping bounding box.
+ \note Constraint is ignored for random access - Vect_read_line().
\param Map pointer to Map_info struct
\param n,s,e,w,t,b bbox definition (north, south, east, west, top, and bottom coordinates)
