[GRASS-SVN] r52315 - grass-addons/grass7/raster/r.regression.series
svn_grass at osgeo.org
Thu Jul 5 12:39:53 PDT 2012
Author: mmetz
Date: 2012-07-05 12:39:53 -0700 (Thu, 05 Jul 2012)
New Revision: 52315
grass-addons/grass7/raster/r.regression.series/main.c
grass-addons/grass7/raster/r.regression.series/r.regression.series.html
r.regression.series update: speed, more methods
Modified: grass-addons/grass7/raster/r.regression.series/main.c
--- grass-addons/grass7/raster/r.regression.series/main.c 2012-07-05 16:19:01 UTC (rev 52314)
+++ grass-addons/grass7/raster/r.regression.series/main.c 2012-07-05 19:39:53 UTC (rev 52315)
@@ -27,73 +27,49 @@
#include <grass/raster.h>
#include <grass/glocale.h>
-#define REGRESSION_SLOPE 0
-#define REGRESSION_OFFSET 1
-#define REGRESSION_COEFF_DET 2
-#define REGRESSION_COEFF_DET_ADJ 3
-#define REGRESSION_F_VALUE 4
-#define REGRESSION_T_VALUE 5
+/* TODO: use more stable two pass algorithm */
-static void reg(DCELL *result, DCELL (*values)[2], int n, int which)
+#define SLOPE 0
+#define OFFSET 1
+#define CORCOEFF 2
+#define RSQUARE 3
+#define RSQUARE_ADJ 4
+#define F_VALUE 5
+#define T_VALUE 6
+struct reg_stats
DCELL sumX, sumY, sumsqX, sumsqY, sumXY;
DCELL meanX, meanY;
- DCELL A, B, R, F, T;
+ DCELL A, B, R, R2;
int count;
- int i;
- sumX = sumY = sumsqX = sumsqY = sumXY = 0.0;
- meanX = meanY = 0.0;
- count = 0;
- for (i = 0; i < n; i++) {
- if (Rast_is_d_null_value(&values[i][0]) ||
- Rast_is_d_null_value(&values[i][1]))
- continue;
- sumX += values[i][0];
- sumY += values[i][1];
- sumsqX += values[i][0] * values[i][0];
- sumsqY += values[i][1] * values[i][1];
- sumXY += values[i][0] * values[i][1];
- count++;
- if (count < 2) {
- Rast_set_d_null_value(result, 1);
- return;
- B = (sumXY - sumX * sumY / count) / (sumsqX - sumX * sumX / count);
- R = (sumXY - sumX * sumY / count) /
- sqrt((sumsqX - sumX * sumX / count) * (sumsqY - sumY * sumY / count));
- meanX = sumX / count;
- meanY = sumY / count;
+static void reg(DCELL *result, struct reg_stats rs, int which)
switch (which) {
- case REGRESSION_SLOPE:
- *result = B;
+ case SLOPE:
+ *result = rs.B;
break;
- case REGRESSION_OFFSET:
- A = meanY - B * meanX;
- *result = A;
+ case OFFSET:
+ *result = rs.meanY - rs.B * rs.meanX;
break;
- case REGRESSION_COEFF_DET:
- *result = R;
+ case CORCOEFF:
+ *result = rs.R;
break;
- case REGRESSION_COEFF_DET_ADJ:
- *result = 1 - (1 - R) * ((count - 1) / (count - 2 - 1));
+ case RSQUARE:
+ *result = rs.R2;
break;
- case REGRESSION_F_VALUE:
- F = R * R / ((1 - R * R) / (count - 2));
- *result = F;
+ case RSQUARE_ADJ:
+ *result = 1 - (1 - rs.R2) * ((rs.count - 1) / (rs.count - 2));
break;
- case REGRESSION_T_VALUE:
- T = sqrt(R) * sqrt((count - 2) / (1 - R));
- *result = T;
+ case F_VALUE:
+ /* *result = rs.R2 / ((1 - rs.R2) / (rs.count - 2)); */
+ *result = rs.R2 * (rs.count - 2) / (1 - rs.R2);
break;
+ case T_VALUE:
+ *result = fabs(rs.R) * sqrt((rs.count - 2) / (1 - rs.R2));
+ break;
default:
break;
@@ -104,51 +80,20 @@
-void reg_m(DCELL * result, DCELL (*values)[2], int n)
- reg(result, values, n, REGRESSION_SLOPE);
-void reg_c(DCELL * result, DCELL (*values)[2], int n)
- reg(result, values, n, REGRESSION_OFFSET);
-void reg_r2(DCELL * result, DCELL (*values)[2], int n)
- reg(result, values, n, REGRESSION_COEFF_DET);
-void reg_r2_adj(DCELL * result, DCELL (*values)[2], int n)
-void reg_f(DCELL * result, DCELL (*values)[2], int n)
- reg(result, values, n, REGRESSION_F_VALUE);
-void reg_t(DCELL * result, DCELL (*values)[2], int n)
- reg(result, values, n, REGRESSION_T_VALUE);
-typedef void stat_func(DCELL *, DCELL (*)[2], int);
struct menu
- stat_func *method; /* routine to compute new value */
+ int method; /* routine to compute new value */
char *name; /* method name */
char *text; /* menu display - full description */
} menu[] = {
- {reg_m, "slope", "linear regression slope"},
- {reg_c, "offset", "linear regression offset"},
- {reg_r2, "detcoeff", "linear regression coefficient of determination"},
- {reg_r2_adj, "adjdetcoeff", "adjusted coefficient of determination"},
- {reg_f, "f", "F statistic"},
- {reg_t, "t", "T statistic"},
- {NULL, NULL, NULL}
+ {SLOPE, "slope", "Linear regression slope"},
+ {OFFSET, "offset", "Linear regression offset"},
+ {CORCOEFF, "corcoef", "Correlation coefficient R"},
+ {RSQUARE, "rsq", "R squared (coefficient of determination)"},
+ {RSQUARE_ADJ, "adjrsq", "Adjusted R squared"},
+ {F_VALUE, "f", "F statistic"},
+ {T_VALUE, "t", "T statistic"},
+ {-1, NULL, NULL}
struct input
@@ -163,7 +108,7 @@
const char *name;
int fd;
DCELL *buf;
- stat_func *method_fn;
+ int method;
static char *build_method_list(void)
@@ -214,8 +159,8 @@
struct input *xinputs, *yinputs;
int num_outputs;
struct output *outputs;
+ struct reg_stats rs;
struct History history;
- DCELL (*values)[2], (*values_tmp)[2];
int nrows, ncols;
int row, col;
@@ -307,14 +252,12 @@
int method = find_method(method_name);
out->name = output_name;
- out->method_fn = menu[method].method;
+ out->method = menu[method].method;
out->buf = Rast_allocate_d_buf();
out->fd = Rast_open_new(output_name, DCELL_TYPE);
/* initialise variables */
- values = (DCELL(*)[2]) G_malloc(num_inputs * 2 * sizeof(DCELL));
- values_tmp = (DCELL(*)[2]) G_malloc(num_inputs * 2 * sizeof(DCELL));
nrows = Rast_window_rows();
ncols = Rast_window_cols();
@@ -333,25 +276,51 @@
for (col = 0; col < ncols; col++) {
int null = 0;
+ rs.sumX = rs.sumY = rs.sumsqX = rs.sumsqY = rs.sumXY = 0.0;
+ rs.meanX = rs.meanY = 0.0;
+ rs.count = 0;
for (i = 0; i < num_inputs; i++) {
DCELL x = xinputs[i].buf[col];
DCELL y = yinputs[i].buf[col];
if (Rast_is_d_null_value(&x) || Rast_is_d_null_value(&y))
null = 1;
+ else {
+ rs.sumX += x;
+ rs.sumY += y;
+ rs.sumsqX += x * x;
+ rs.sumsqY += y * y;
+ rs.sumXY += x * y;
+ rs.count++;
+ if (rs.count > 1) {
+ DCELL tmp1 = rs.count * rs.sumXY - rs.sumX * rs.sumY;
+ DCELL tmp2 = rs.count * rs.sumsqX - rs.sumX * rs.sumX;
- values[i][0] = x;
- values[i][1] = y;
+ /* slope */
+ rs.B = tmp1 / tmp2;
+ /* correlation coefficient */
+ rs.R = tmp1 / sqrt((tmp2) * (rs.count * rs.sumsqY - rs.sumY * rs.sumY));
+ /* coefficient of determination aka R squared */
+ rs.R2 = rs.R * rs.R;
+ rs.meanX = rs.sumX / rs.count;
+ rs.meanY = rs.sumY / rs.count;
+ else {
+ rs.R = rs.R2 = rs.B = 0;
for (i = 0; i < num_outputs; i++) {
struct output *out = &outputs[i];
- if (null && flag.nulls->answer)
+ if (rs.count < 2 || (null && flag.nulls->answer))
Rast_set_d_null_value(&out->buf[col], 1);
else {
- memcpy(values_tmp, values, num_inputs * 2 * sizeof(DCELL));
- (*out->method_fn)(&out->buf[col], values_tmp, num_inputs);
+ reg(&out->buf[col], rs, out->method);
Modified: grass-addons/grass7/raster/r.regression.series/r.regression.series.html
--- grass-addons/grass7/raster/r.regression.series/r.regression.series.html 2012-07-05 16:19:01 UTC (rev 52314)
+++ grass-addons/grass7/raster/r.regression.series/r.regression.series.html 2012-07-05 19:39:53 UTC (rev 52315)
@@ -9,10 +9,11 @@
Following methods are available:
<ul>
- <li>offset: linear regression offset
- <li>slope: linear regression slope
- <li>detcoeff: linear regression coefficient of determination
- <li>adjdetcoeff: adjusted coefficient of determination
+ <li>offset: Linear regression offset
+ <li>slope: Linear regression slope
+ <li>corcoef: Correlation Coefficent R
+ <li>rsq: Coefficient of determination = R squared
+ <li>adjrsq: Adjusted coefficient of determination
<li>f: F statistic
<li>t: T statistic
</ul>
@@ -29,10 +30,13 @@
<p>
<em>slope</em> is equivalent to <em>b</em> in the above equation.
<p>
-<em>detcoff</em> is the coefficient of determination, equivalent to
+<em>corcoef</em> is the correlation coefficient R with a theoretical
+range of -1,1.
+<p>
+<em>rsq</em> is the coefficient of determination, equivalent to
the squared correlation coefficient R<sup>2</sup>.
<p>
-<em>adjdetcoff</em> is the coefficient of determination adjusted for the
+<em>adjrsq</em> is the coefficient of determination adjusted for the
number of samples, i.e. number of input maps per series.
<p>
<em>f</em> is the value of the F statistic.
@@ -79,8 +83,9 @@
Using <em>r.regression.series</em> with wildcards:
<br>
<div class="code"><pre>
-r.regression.series input="`g.mlist pattern='insitu_data.*' sep=,`" \
- output=insitu_data.det method=detcoeff
+r.regression.series xseries="`g.mlist pattern='insitu_data.*' sep=,`" \
+ yseries="`g.mlist pattern='invivo_data.*' sep=,`" \
+ output=insitu_data.rsquared method=rsq
</pre></div>
<p>
Note the <em>g.mlist</em> module also supports regular expressions for
@@ -91,7 +96,7 @@
parameters from 8 input maps, 4 maps per time series):
r.regression.series x=xone,xtwo,xthree,xfour y=yone,ytwo,ythree,yfour \
- out=res_offset,res_slope,res_det meth=offset,slope,adjdetcoeff
+ out=res_offset,res_slope,res_adjrsq meth=offset,slope,adjrsq
</pre></div>
<h2>SEE ALSO</h2>
