[GRASS-SVN] r52335 - grass-addons/grass7/gui/wxpython/wx.vnet/vnet
svn_grass at osgeo.org
Sat Jul 7 02:19:39 PDT 2012
Author: martinl
Date: 2012-07-07 02:19:39 -0700 (Sat, 07 Jul 2012)
New Revision: 52335
Added:
grass-addons/grass7/gui/wxpython/wx.vnet/vnet/__init__.py
grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py
Removed:
grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialog.py
wx.vnet: rename dialog.py to dialogs.py
add __init__.py
Added: grass-addons/grass7/gui/wxpython/wx.vnet/vnet/__init__.py
--- grass-addons/grass7/gui/wxpython/wx.vnet/vnet/__init__.py (rev 0)
+++ grass-addons/grass7/gui/wxpython/wx.vnet/vnet/__init__.py 2012-07-07 09:19:39 UTC (rev 52335)
@@ -0,0 +1,5 @@
+all = [
+ 'dialogs',
+ 'toolbars',
+ 'widgets',
Property changes on: grass-addons/grass7/gui/wxpython/wx.vnet/vnet/__init__.py
___________________________________________________________________
Added: svn:mime-type
+ text/x-python
Added: svn:eol-style
+ native
Deleted: grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialog.py
--- grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialog.py 2012-07-07 00:30:21 UTC (rev 52334)
+++ grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialog.py 2012-07-07 09:19:39 UTC (rev 52335)
@@ -1,716 +0,0 @@
- at package vnet.dialog
- at brief Dialog for vector network analysis front-end
-Classes:
- - dialog::VNETDialog
- - dialog::SettingsDialog
- - dialog::AddLayerDialog
-(C) 2012 by the GRASS Development Team
-This program is free software under the GNU General Public License
-(>=v2). Read the file COPYING that comes with GRASS for details.
- at author Stepan Turek <stepan.turek seznam.cz> (GSoC 2012, mentor: Martin Landa)
-import os
-import wx
-import sys
-import wx.lib.colourselect as csel
-from core import globalvar
-from vnet.toolbars import MainToolbar, PointListToolbar
-from vnet.widgets import PointsList
-from gui_core.gselect import Select, LayerSelect, ColumnSelect
-from gui_core.widgets import GNotebook
-from core.settings import UserSettings
-from grass.script import core as grass
-from core.gcmd import RunCommand, GMessage
-import wx
-import wx.aui
-import wx.lib.flatnotebook as FN
-from copy import copy
-class VNETDialog(wx.Dialog):
- def __init__(self, parent,
- id=wx.ID_ANY, title = "Vector network analysis",
- style=wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER):
- """!Dialolog for vector network analasis"""
- wx.Dialog.__init__(self, parent, id, style=style, title = title)
- self.parent = parent #mapdisp.frame MapFrame
- self.mapWin = parent.MapWindow
- self.inputData = {}
- # registration graphics for drawing
- self.pointsToDraw = self.mapWin.RegisterGraphicsToDraw(graphicsType = "point",
- setStatusFunc = self.SetNodeStatus)
- self.pointsToDraw.SetPropertyVal("size", 10) # TODO settings
- # getting attribute table columns only whith numbers (costs)
- self.columnTypes = ['integer', 'double precision']
- self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass_map.ico'), wx.BITMAP_TYPE_ICO))
- # toolbars
- self.toolbars = {}
- self.toolbars['mainToolbar'] = MainToolbar(parent = self)
- # Fancy gui
- self._mgr = wx.aui.AuiManager(self)
- # Columns in points list
- self.cols = [
- ['type', ["", "Start point", "End point"], ""]
- self.mainPanel = wx.Panel(parent=self)
- self.notebook = GNotebook(parent = self.mainPanel,
- style = FN.FNB_FANCY_TABS | FN.FNB_BOTTOM |
- FN.FNB_NO_NAV_BUTTONS | FN.FNB_NO_X_BUTTON)
- self._createListPanel()
- self.notebook.AddPage(page = self.listPanel,
- text=_('Points list'),
- name = 'list')
- self._createSelectsPanel()
- self.notebook.AddPage(page = self.settingsPanel,
- text=_('Data'),
- name = 'data')
- self._addPanes()
- self._doDialogLayout()
- self._mgr.Update()
- self.handlerRegistered = False
- self.tmpResultLayer = None
- #TODO if 'vnet' not in UserSettings.userSettings:
- # initializes default settings
- initSettings = [
- ['resStyle', 'width', 5],
- ['resStyle', 'color', (192,0,0)],
- ['analasisSettings', 'maxDist', 10000],
- ['analasisSettings', 'resultId', 1]
- for init in initSettings:
- UserSettings.Append(dict = UserSettings.userSettings,
- group ='vnet',
- key = init[0],
- subkey =init[1],
- value = init[2])
- # name of temporary map
- self.tmp_result = "tmp_map"
- # set options for drawing the map
- self.UpdateCmdList(self.tmp_result)
- # adds 2 points into list
- for i in range(2):
- self.list.AddItem(None)
- self.list.EditCell(i, 1, self.cols[1][1][1 + i])
- self.list.CheckItem(i, True)
- self.Bind(wx.EVT_CLOSE, self.OnCloseDialog)
- dlgSize = (300,450)
- self.SetMinSize(dlgSize)
- self.SetInitialSize(dlgSize)
- def __del__(self):
- """!Removes temp layer with analasis result, unregisters handlers and graphics"""
- self.mapWin.UnregisterGraphicsToDraw(self.pointsToDraw)
- RunCommand('g.remove', vect = self.tmp_result)
- if self.tmpResultLayer:
- self.mapWin.UpdateMap(render=True, renderVector=True)
- if self.handlerRegistered:
- self.mapWin.UnregisterMouseEventHandler(wx.EVT_LEFT_DOWN,
- self.OnMapClickHandler)
- def _addPanes(self):
- self._mgr.AddPane(self.toolbars['mainToolbar'],
- wx.aui.AuiPaneInfo().
- Name("pointlisttools").Caption(_("Point list toolbar")).
- ToolbarPane().Top().
- Dockable(False).
- CloseButton(False).Layer(0))
- self._mgr.AddPane(self.mainPanel,
- Name("tabs").CaptionVisible(visible = False).
- Center().
- Dockable(False).
- def _doDialogLayout(self):
- sizer = wx.BoxSizer(wx.VERTICAL)
- sizer.Add(item = self.notebook, proportion = 1,
- flag = wx.EXPAND)
- self.mainPanel.SetSizer(sizer)
- sizer.Fit(self)
- self.Layout()
- def _createListPanel(self):
- self.listPanel = wx.Panel(parent=self)
- self.list = NodesList(parent = self.listPanel, dialog = self, cols = self.cols)
- self.toolbars['pointsList'] = PointListToolbar(parent = self.listPanel, list = self.list)
- listsizer = wx.BoxSizer(wx.VERTICAL)
- listsizer.Add(item = self.toolbars['pointsList'], proportion = 0)
- listsizer.Add(item = self.list, proportion = 1, flag = wx.EXPAND)
- self.listPanel.SetSizer(listsizer)
- def _createSelectsPanel(self):
- self.settingsPanel = wx.Panel(parent=self)
- self.inputData['input'] = Select(parent = self.settingsPanel, type = 'vector', size = (-1, -1))
- vectSelTitle = wx.StaticText(parent = self.settingsPanel)
- vectSelTitle.SetLabel("Choose vector layers for analysis:")
- self.inputData['alayer'] = LayerSelect(parent = self.settingsPanel, size = (-1, -1))
- aLayerSelTitle = wx.StaticText(parent = self.settingsPanel)
- aLayerSelTitle.SetLabel("Arc layer number or name:")
- self.inputData['nlayer'] = LayerSelect(parent = self.settingsPanel, size = (-1, -1))
- nLayerSelTitle = wx.StaticText(parent = self.settingsPanel)
- nLayerSelTitle.SetLabel("Node layer number or name:")
- self.inputData['afcolumn'] = ColumnSelect(parent = self.settingsPanel, size = (-1, -1))
- afcolumnSelTitle = wx.StaticText(parent = self.settingsPanel)
- afcolumnSelTitle.SetLabel("Arc forward/both direction(s) cost column:")
- self.inputData['abcolumn'] = ColumnSelect(parent = self.settingsPanel, size = (-1, -1))
- abcolumnSelTitle = wx.StaticText(parent = self.settingsPanel)
- abcolumnSelTitle.SetLabel("Arc backward direction cost column:")
- self.inputData['input'].Bind(wx.EVT_TEXT, self.OnVectSel)
- self.inputData['alayer'].Bind(wx.EVT_TEXT, self.OnVectSel)
- self.inputData['nlayer'].Bind(wx.EVT_TEXT, self.OnVectSel)
- mainSizer = wx.BoxSizer(wx.VERTICAL)
- box = wx.StaticBox(self.settingsPanel, -1, "Layer for analysis")
- bsizer = wx.StaticBoxSizer(box, wx.VERTICAL)
- mainSizer.Add(item = bsizer, proportion = 0,
- flag = wx.EXPAND | wx.TOP | wx.LEFT | wx.RIGHT, border = 5)
- bsizer.Add(item = self._doSelLayout(title = vectSelTitle, sel = self.inputData['input']), proportion = 0,
- flag = wx.EXPAND)
- bsizer.Add(item = self._doSelLayout(title = aLayerSelTitle, sel = self.inputData['alayer']), proportion = 0,
- flag = wx.EXPAND)
- bsizer.Add(item = self._doSelLayout(title = nLayerSelTitle, sel = self.inputData['nlayer']), proportion = 0,
- flag = wx.EXPAND)
- box = wx.StaticBox(self.settingsPanel, -1, "Costs")
- bsizer.Add(item = self._doSelLayout(title = afcolumnSelTitle, sel = self.inputData['afcolumn']), proportion = 0,
- flag = wx.EXPAND)
- bsizer.Add(item = self._doSelLayout(title = abcolumnSelTitle, sel = self.inputData['abcolumn']), proportion = 0,
- flag = wx.EXPAND)
- self.settingsPanel.SetSizer(mainSizer)
- def _doSelLayout(self, title, sel):
- selSizer = wx.BoxSizer(orient = wx.VERTICAL)
- selTitleSizer = wx.BoxSizer(wx.HORIZONTAL)
- selTitleSizer.Add(item = title, proportion = 1,
- flag = wx.LEFT | wx.TOP | wx.EXPAND, border = 5)
- selSizer.Add(item = selTitleSizer, proportion = 0,
- flag = wx.EXPAND)
- selSizer.Add(item = sel, proportion = 0,
- flag = wx.EXPAND | wx.BOTTOM | wx.LEFT | wx.RIGHT | wx.TOP | wx.ALIGN_CENTER_VERTICAL,
- border = 5)
- return selSizer
- def OnVectSel(self, event):
- self.inputData['alayer'].InsertLayers(vector = self.inputData['input'].GetValue())#TODO split
- self.inputData['nlayer'].InsertLayers(vector = self.inputData['input'].GetValue())
- self.inputData['afcolumn'].InsertColumns(vector = self.inputData['input'].GetValue(),
- layer = self.inputData['alayer'].GetValue(),
- type = self.columnTypes)
- self.inputData['abcolumn'].InsertColumns(vector = self.inputData['input'].GetValue(),
- def OnCloseDialog(self, event):
- """!Cancel dialog"""
- self.parent.dialogs['vnet'] = None
- self.Destroy()
- def SetNodeStatus(self, item, itemIndex):
- """!Before point is drawed, decides properties of drawing style"""
- key = self.list.GetItemData(itemIndex)
- gcp = self.list.itemDataMap[key]
- if not self.list.IsChecked(key):
- wxPen = "unused"
- item.hide = False
- else:
- wxPen = "default"
- if key == self.list.selected:
- wxPen = "selected"
- item.SetPropertyVal('label', str(itemIndex + 1))
- item.SetPropertyVal('penName', wxPen)
- def OnMapClickHandler(self, event):
- """!Takes coordinates from map window."""
- if event == 'unregistered':
- ptListToolbar = self.toolbars['pointsList']
- if ptListToolbar:
- ptListToolbar.ToggleTool(vars(ptListToolbar)["insertPoint"], False) # TODO
- return
- if not self.list.itemDataMap:
- e, n = self.mapWin.GetLastEN()
- index = self.list.selected
- key = self.list.GetItemData(index)
- self.pointsToDraw.GetItem(key).SetCoords([e, n])
- self.mapWin.UpdateMap(render=False, renderVector=False)
- def OnAnalyze(self, event):
- if len(self.pointsToDraw.GetAllItems()) < 1:
- return
- startPtLabel = self.cols[1][1][1]
- endPtLabel = self.cols[1][1][2]
- inputCoords = { startPtLabel : None,
- endPtLabel : None}
- for i in range(len(self.list.itemDataMap)):
- key = self.list.GetItemData(i)
- if self.list.IsChecked(key):
- for k, v in inputCoords.iteritems():
- if k == self.list.itemDataMap[key][1]:
- inputCoords[k] = self.pointsToDraw.GetItem(key).GetCoords ()
- if None in inputCoords.values():
- GMessage(parent = self,
- message=_("Pleas choose 'to' and 'from' point."))
- return
- resId = int(UserSettings.Get(group='vnet',
- key='analasisSettings',
- subkey='resultId'))
- s = str(resId) + " " + str(inputCoords[startPtLabel][0]) + " " + str(inputCoords[startPtLabel][1]) + \
- " " + str(inputCoords[endPtLabel][0]) + " " + str(inputCoords[endPtLabel][1])
- coordsTempFile = grass.tempfile()#TODO stdin
- coordsTempFileOpened = open(coordsTempFile, 'w')
- coordsTempFileOpened.write(s)
- coordsTempFileOpened.close()
- params = {}
- for k, v in self.inputData.iteritems():
- if not v.GetValue():
- params[k] = None
- else:
- params[k] = v.GetValue()
- ret, std, msg = RunCommand('v.net.path',
- input = params['input'],
- output = self.tmp_result,
- overwrite = True,
- alayer = params['alayer'],
- nlayer = params['nlayer'],
- afcolumn = params['afcolumn'],
- abcolumn = params['abcolumn'],
- file = coordsTempFile,
- dmax = int(UserSettings.Get(group='vnet',
- subkey='maxDist')),
- read = True,
- getErrorMsg = True)
- grass.try_remove(coordsTempFile)
- self.mapWin.Map.DeleteLayer(layer = self.tmpResultLayer)
- self.tmpResultLayer = self.mapWin.Map.AddLayer(type = "vector", command = self.cmdlist,
- l_active=True, name = self.tmp_result,
- l_hidden = False, l_opacity = 1.0,
- l_render = True, pos = 1)
- def OnInsertPoint(self, event):
- if self.handlerRegistered == False:
- self.mapWin.RegisterMouseEventHandler(wx.EVT_LEFT_DOWN,
- self.OnMapClickHandler,
- wx.StockCursor(wx.CURSOR_CROSS))
- self.handlerRegistered = True
- else:
- def OnSaveTmpLayer(self, event):
- dlg = AddLayerDialog(parent = self)
- if dlg.ShowModal() == wx.ID_OK:
- ret, std, msg = RunCommand("g.copy",
- overwrite = dlg.overwrite.GetValue(),
- vect = [self.tmp_result, dlg.vectSel.GetValue()],
- read = True,
- self.UpdateCmdList(dlg.vectSel.GetValue())
- if self.mapWin.tree.FindItemByData(key = 'name', value = dlg.vectSel.GetValue()) is None:
- self.mapWin.tree.AddLayer(ltype = "vector",
- lname = dlg.vectSel.GetValue(),
- lcmd = self.cmdlist,
- lchecked = True)
- def OnSettings(self, event):
- """!Displays vnet settings dialog"""
- dlg = SettingsDialog(parent=self, id=wx.ID_ANY, title=_('Settings'))
- pass
- dlg.Destroy()
- def UpdateCmdList(self, layerName):
- col = UserSettings.Get(group='vnet', key='resStyle', subkey= "color")
- width = UserSettings.Get(group='vnet', key='resStyle', subkey= "width")
- self.cmdlist = ['d.vect', 'map=%s' % layerName, \
- 'color=' + str(col[0]) + ':' + str(col[1]) + ':' + str(col[2]), \
- 'width=' + str(width)]# TODO settings
-class NodesList(PointsList):
- def __init__(self, parent, dialog, cols, id=wx.ID_ANY):
- """! List with points for analasis
- self.dialog = dialog # VNETDialog class
- PointsList.__init__(self, parent = parent, cols = cols, id = id)
- def AddItem(self, event):
- Appends an point to list
- PointsList.AddItem(self, event)
- self.dialog.pointsToDraw.AddItem(coords = [0,0],
- label = str(self.selectedkey + 1))
- self.dialog.mapWin.UpdateMap(render=True, renderVector=True)
- def DeleteItem(self, event):
- Deletes selected point in list
- key = self.GetItemData(self.selected)
- PointsList.DeleteItem(self, event)
- if self.selected != wx.NOT_FOUND:
- item = self.dialog.pointsToDraw.GetItem(key)
- self.dialog.pointsToDraw.DeleteItem(item)
- def OnItemSelected(self, event):
- Item selected
- PointsList.OnItemSelected(self, event)
- self.dialog.mapWin.UpdateMap(render=False, renderVector=False)
- event.Skip()
- def OnCheckItem(self, index, flag):
- """!Item is checked/unchecked"""
- key = self.GetItemData(index)
- checkedVal = self.itemDataMap[key][1]
- if checkedVal == "":
- self.CheckItem(key, False)
- return
- iItem = 0
- for item in self.itemDataMap:
- if item[1] == checkedVal and key != iItem and flag:
- checkedKey = self.GetItemData(iItem)
- self.CheckItem(checkedKey, False)
- iItem += 1
-class SettingsDialog(wx.Dialog):
- def __init__(self, parent, id, title, pos=wx.DefaultPosition, size=wx.DefaultSize,
- style=wx.DEFAULT_DIALOG_STYLE):
- """!Settings for v.net analasis dialog"""
- wx.Dialog.__init__(self, parent, id, title, pos, size, style)
- maxValue = 1e8
- self.panel = wx.Panel(parent = self, id = wx.ID_ANY)
- self.colorLabel = wx.StaticText(parent = self.panel, id = wx.ID_ANY, label = _("Line color:"))
- col = UserSettings.Get(group ='vnet', key ='resStyle', subkey = "color")
- self.colorField = csel.ColourSelect(parent = self.panel, id = wx.ID_ANY,
- colour = wx.Colour(col[0],
- col[1],
- col[2],
- 255))
- self.widthLabel = wx.StaticText(parent = self.panel, id = wx.ID_ANY, label =_("Line width:"))
- self.widthField = wx.SpinCtrl(parent = self.panel, id = wx.ID_ANY, min = 1, max = 10)
- width = int(UserSettings.Get(group = 'vnet', key = 'resStyle', subkey = 'width'))
- self.widthField.SetValue(width)
- self.idLabel = wx.StaticText(parent = self.panel, id = wx.ID_ANY, label =_("Id of line:"))
- self.resIdFiled = wx.SpinCtrl(parent = self.panel, id = wx.ID_ANY, min = 1, max = maxValue)
- resId = int(UserSettings.Get(group ='vnet', key ='analasisSettings', subkey = 'resultId'))
- self.resIdFiled.SetValue(resId)
- self.maxDistlabel = wx.StaticText(parent = self.panel, id = wx.ID_ANY, label = _("Maximum distance \n to the network:"))
- self.maxDistField = wx.SpinCtrl(parent = self.panel, id = wx.ID_ANY, min = 0, max = maxValue) #TODO
- maxDist = int(UserSettings.Get(group = 'vnet', key = 'analasisSettings', subkey ='maxDist'))
- self.maxDistField.SetValue(maxDist)
- # buttons
- #btnSave = wx.Button(self.panel, wx.ID_SAVE)
- self.btnApply = wx.Button(self.panel, wx.ID_APPLY)
- self.btnClose = wx.Button(self.panel, wx.ID_CLOSE)
- self.btnApply.SetDefault()
- # bindings
- self.btnApply.Bind(wx.EVT_BUTTON, self.OnApply)
- self.btnApply.SetToolTipString(_("Apply changes for the current session"))
- #btnSave.Bind(wx.EVT_BUTTON, self.OnSave)
- #btnSave.SetToolTipString(_("Apply and save changes to user settings file (default for next sessions)"))
- self.btnClose.Bind(wx.EVT_BUTTON, self.OnClose)
- self.btnClose.SetToolTipString(_("Close dialog"))
- self._layout()
- self.SetMinSize(self.GetBestSize())
- def _layout(self):
- styleBox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
- label =" %s " % _("Analasis outcome line style:"))
- styleBoxSizer = wx.StaticBoxSizer(styleBox, wx.VERTICAL)
- gridSizer = wx.GridBagSizer(vgap = 1, hgap = 1)
- row = 0
- gridSizer.Add(item = self.colorLabel, flag = wx.ALIGN_CENTER_VERTICAL, pos =(row, 0))
- gridSizer.Add(item = self.colorField,
- flag = wx.ALIGN_RIGHT | wx.ALL, border = 5,
- pos =(row, 1))
- row += 1
- gridSizer.Add(item = self.widthLabel, flag=wx.ALIGN_CENTER_VERTICAL, pos=(row, 0))
- gridSizer.Add(item = self.widthField,
- pos = (row, 1))
- styleBoxSizer.Add(item = gridSizer, flag = wx.EXPAND)
- analasisBox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
- label = " %s " % _("Analasis settings:"))
- analasisBoxSizer = wx.StaticBoxSizer(analasisBox, wx.VERTICAL)
- row = 0
- gridSizer.Add(item = self.idLabel, flag = wx.ALIGN_CENTER_VERTICAL, pos = (row, 0))
- gridSizer.Add(item = self.resIdFiled,
- pos = (row, 1))
- row += 1
- gridSizer.Add(item = self.maxDistlabel, flag = wx.ALIGN_CENTER_VERTICAL, pos = (row, 0))
- gridSizer.Add(item = self.maxDistField,
- pos = (row, 1))
- analasisBoxSizer.Add(item = gridSizer, flag = wx.EXPAND)
- # sizers
- btnSizer = wx.BoxSizer(wx.HORIZONTAL)
- btnSizer.Add(self.btnApply, flag = wx.LEFT | wx.RIGHT, border = 5)
- #btnSizer.Add(btnSave, flag=wx.LEFT | wx.RIGHT, border=5)
- btnSizer.Add(self.btnClose, flag = wx.LEFT | wx.RIGHT, border = 5)
- sizer.Add(item = styleBoxSizer, flag = wx.EXPAND | wx.ALL, border = 5, proportion = 1)
- sizer.Add(item = analasisBoxSizer, flag = wx.EXPAND | wx.ALL, border = 5, proportion = 1)
- sizer.Add(item = btnSizer, flag = wx.EXPAND | wx.ALL, border = 5, proportion = 0)
- self.panel.SetSizer(sizer)
- sizer.Fit(self)
- def UpdateSettings(self):
- UserSettings.Set(group ='vnet', key ='resStyle', subkey ='width',
- value = self.widthField.GetValue())
- UserSettings.Set(group = 'vnet', key ='resStyle', subkey ='color',
- value = self.colorField.GetColour())
- UserSettings.Set(group = 'vnet', key ='analasisSettings', subkey ='resultId',
- value = self.resIdFiled.GetValue())
- UserSettings.Set(group ='vnet', key ='analasisSettings', subkey ='maxDist',
- value = self.maxDistField.GetValue())
- if self.parent.tmpResultLayer:
- self.parent.UpdateCmdList(self.parent.tmp_result)
- self.parent.tmpResultLayer.SetCmd(self.parent.cmdlist)
- self.parent.mapWin.UpdateMap(render=True, renderVector=True)#TODO necessary
- #def OnSave(self, event): TODO
- # """!Button 'Save' pressed"""
- # self.UpdateSettings()
- # fileSettings = {}
- # UserSettings.ReadSettingsFile(settings=fileSettings)
- # fileSettings['vnet'] = UserSettings.Get(group='vnet')
- # file = UserSettings.SaveToFile(fileSettings)
- # self.parent.parent.goutput.WriteLog(_('Vnet fron end settings saved to file \'%s\'.') % file) TODO
- # self.Close()
- def OnApply(self, event):
- """!Button 'Apply' pressed"""
- self.UpdateSettings()
- #self.Close()
- def OnClose(self, event):
- """!Button 'Cancel' pressed"""
- self.Close()
-class AddLayerDialog(wx.Dialog):
- """!Adds layer with analysis result into layer tree"""
- def __init__(self, parent,id=wx.ID_ANY,
- title =_("Add analasis result into layer tree"), style=wx.DEFAULT_DIALOG_STYLE):
- """!Dialog for editing item cells in list"""
- wx.Dialog.__init__(self, parent, id, title = _(title), style = style)
- self.panel = wx.Panel(parent = self)
- # text fields and it's captions
- self.vectSel = Select(parent = self.panel, type = 'vector', size = (-1, -1))
- self.vectSellabel = wx.StaticText(parent = self.panel, id = wx.ID_ANY,
- label = _("Layer name:"))
- self.overwrite = wx.CheckBox(parent = self.panel, id=wx.ID_ANY,
- label = _("Overwrite existing layer"))
- # buttons
- self.btnCancel = wx.Button(self.panel, wx.ID_CANCEL)
- self.btnOk = wx.Button(self.panel, wx.ID_OK)
- self.btnOk.SetDefault()
- self._layout()
- box = wx.StaticBox (parent = self.panel, id = wx.ID_ANY,
- label = "Added layer")
- boxSizer = wx.StaticBoxSizer(box, wx.VERTICAL)
- # source coordinates
- gridSizer = wx.GridBagSizer(vgap = 5, hgap = 5)
- row = 0
- gridSizer.Add(item = self.vectSellabel,
- flag = wx.ALIGN_CENTER_VERTICAL,
- pos = (row, 0))
- gridSizer.Add(item = self.vectSel,
- pos = (row, 1))
- boxSizer.Add(item = gridSizer, proportion = 1,
- flag = wx.EXPAND | wx.ALL, border = 5)
- sizer.Add(item = boxSizer, proportion = 1,
- row +=1
- gridSizer.Add(item = self.overwrite, pos =(row, 0))
- btnSizer = wx.StdDialogButtonSizer()
- btnSizer.AddButton(self.btnCancel)
- btnSizer.AddButton(self.btnOk)
- btnSizer.Realize()
- sizer.Add(item = btnSizer, proportion = 0,
- flag = wx.ALIGN_RIGHT | wx.ALL, border = 5)
- sizer.Fit(self)
Copied: grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py (from rev 52334, grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialog.py)
--- grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py (rev 0)
+++ grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py 2012-07-07 09:19:39 UTC (rev 52335)
@@ -0,0 +1,716 @@
+ at package vnet.dialog
+ at brief Dialog for vector network analysis front-end
+Classes:
+ - dialog::VNETDialog
+ - dialog::SettingsDialog
+ - dialog::AddLayerDialog
+(C) 2012 by the GRASS Development Team
+This program is free software under the GNU General Public License
+(>=v2). Read the file COPYING that comes with GRASS for details.
+ at author Stepan Turek <stepan.turek seznam.cz> (GSoC 2012, mentor: Martin Landa)
+import os
+import wx
+import sys
+import wx.lib.colourselect as csel
+from core import globalvar
+from vnet.toolbars import MainToolbar, PointListToolbar
+from vnet.widgets import PointsList
+from gui_core.gselect import Select, LayerSelect, ColumnSelect
+from gui_core.widgets import GNotebook
+from core.settings import UserSettings
+from grass.script import core as grass
+from core.gcmd import RunCommand, GMessage
+import wx
+import wx.aui
+import wx.lib.flatnotebook as FN
+from copy import copy
+class VNETDialog(wx.Dialog):
+ def __init__(self, parent,
+ id=wx.ID_ANY, title = "Vector network analysis",
+ style=wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER):
+ """!Dialolog for vector network analasis"""
+ wx.Dialog.__init__(self, parent, id, style=style, title = title)
+ self.parent = parent #mapdisp.frame MapFrame
+ self.mapWin = parent.MapWindow
+ self.inputData = {}
+ # registration graphics for drawing
+ self.pointsToDraw = self.mapWin.RegisterGraphicsToDraw(graphicsType = "point",
+ setStatusFunc = self.SetNodeStatus)
+ self.pointsToDraw.SetPropertyVal("size", 10) # TODO settings
+ # getting attribute table columns only whith numbers (costs)
+ self.columnTypes = ['integer', 'double precision']
+ self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass_map.ico'), wx.BITMAP_TYPE_ICO))
+ # toolbars
+ self.toolbars = {}
+ self.toolbars['mainToolbar'] = MainToolbar(parent = self)
+ # Fancy gui
+ self._mgr = wx.aui.AuiManager(self)
+ # Columns in points list
+ self.cols = [
+ ['type', ["", "Start point", "End point"], ""]
+ self.mainPanel = wx.Panel(parent=self)
+ self.notebook = GNotebook(parent = self.mainPanel,
+ style = FN.FNB_FANCY_TABS | FN.FNB_BOTTOM |
+ FN.FNB_NO_NAV_BUTTONS | FN.FNB_NO_X_BUTTON)
+ self._createListPanel()
+ self.notebook.AddPage(page = self.listPanel,
+ text=_('Points list'),
+ name = 'list')
+ self._createSelectsPanel()
+ self.notebook.AddPage(page = self.settingsPanel,
+ text=_('Data'),
+ name = 'data')
+ self._addPanes()
+ self._doDialogLayout()
+ self._mgr.Update()
+ self.handlerRegistered = False
+ self.tmpResultLayer = None
+ #TODO if 'vnet' not in UserSettings.userSettings:
+ # initializes default settings
+ initSettings = [
+ ['resStyle', 'width', 5],
+ ['resStyle', 'color', (192,0,0)],
+ ['analasisSettings', 'maxDist', 10000],
+ ['analasisSettings', 'resultId', 1]
+ for init in initSettings:
+ UserSettings.Append(dict = UserSettings.userSettings,
+ group ='vnet',
+ key = init[0],
+ subkey =init[1],
+ value = init[2])
+ # name of temporary map
+ self.tmp_result = "tmp_map"
+ # set options for drawing the map
+ self.UpdateCmdList(self.tmp_result)
+ # adds 2 points into list
+ for i in range(2):
+ self.list.AddItem(None)
+ self.list.EditCell(i, 1, self.cols[1][1][1 + i])
+ self.list.CheckItem(i, True)
+ self.Bind(wx.EVT_CLOSE, self.OnCloseDialog)
+ dlgSize = (300,450)
+ self.SetMinSize(dlgSize)
+ self.SetInitialSize(dlgSize)
+ def __del__(self):
+ """!Removes temp layer with analasis result, unregisters handlers and graphics"""
+ self.mapWin.UnregisterGraphicsToDraw(self.pointsToDraw)
+ RunCommand('g.remove', vect = self.tmp_result)
+ if self.tmpResultLayer:
+ self.mapWin.UpdateMap(render=True, renderVector=True)
+ if self.handlerRegistered:
+ self.mapWin.UnregisterMouseEventHandler(wx.EVT_LEFT_DOWN,
+ self.OnMapClickHandler)
+ def _addPanes(self):
+ self._mgr.AddPane(self.toolbars['mainToolbar'],
+ wx.aui.AuiPaneInfo().
+ Name("pointlisttools").Caption(_("Point list toolbar")).
+ ToolbarPane().Top().
+ Dockable(False).
+ CloseButton(False).Layer(0))
+ self._mgr.AddPane(self.mainPanel,
+ Name("tabs").CaptionVisible(visible = False).
+ Center().
+ Dockable(False).
+ def _doDialogLayout(self):
+ sizer = wx.BoxSizer(wx.VERTICAL)
+ sizer.Add(item = self.notebook, proportion = 1,
+ flag = wx.EXPAND)
+ self.mainPanel.SetSizer(sizer)
+ sizer.Fit(self)
+ self.Layout()
+ def _createListPanel(self):
+ self.listPanel = wx.Panel(parent=self)
+ self.list = NodesList(parent = self.listPanel, dialog = self, cols = self.cols)
+ self.toolbars['pointsList'] = PointListToolbar(parent = self.listPanel, list = self.list)
+ listsizer = wx.BoxSizer(wx.VERTICAL)
+ listsizer.Add(item = self.toolbars['pointsList'], proportion = 0)
+ listsizer.Add(item = self.list, proportion = 1, flag = wx.EXPAND)
+ self.listPanel.SetSizer(listsizer)
+ def _createSelectsPanel(self):
+ self.settingsPanel = wx.Panel(parent=self)
+ self.inputData['input'] = Select(parent = self.settingsPanel, type = 'vector', size = (-1, -1))
+ vectSelTitle = wx.StaticText(parent = self.settingsPanel)
+ vectSelTitle.SetLabel("Choose vector layers for analysis:")
+ self.inputData['alayer'] = LayerSelect(parent = self.settingsPanel, size = (-1, -1))
+ aLayerSelTitle = wx.StaticText(parent = self.settingsPanel)
+ aLayerSelTitle.SetLabel("Arc layer number or name:")
+ self.inputData['nlayer'] = LayerSelect(parent = self.settingsPanel, size = (-1, -1))
+ nLayerSelTitle = wx.StaticText(parent = self.settingsPanel)
+ nLayerSelTitle.SetLabel("Node layer number or name:")
+ self.inputData['afcolumn'] = ColumnSelect(parent = self.settingsPanel, size = (-1, -1))
+ afcolumnSelTitle = wx.StaticText(parent = self.settingsPanel)
+ afcolumnSelTitle.SetLabel("Arc forward/both direction(s) cost column:")
+ self.inputData['abcolumn'] = ColumnSelect(parent = self.settingsPanel, size = (-1, -1))
+ abcolumnSelTitle = wx.StaticText(parent = self.settingsPanel)
+ abcolumnSelTitle.SetLabel("Arc backward direction cost column:")
+ self.inputData['input'].Bind(wx.EVT_TEXT, self.OnVectSel)
+ self.inputData['alayer'].Bind(wx.EVT_TEXT, self.OnVectSel)
+ self.inputData['nlayer'].Bind(wx.EVT_TEXT, self.OnVectSel)
+ mainSizer = wx.BoxSizer(wx.VERTICAL)
+ box = wx.StaticBox(self.settingsPanel, -1, "Layer for analysis")
+ bsizer = wx.StaticBoxSizer(box, wx.VERTICAL)
+ mainSizer.Add(item = bsizer, proportion = 0,
+ flag = wx.EXPAND | wx.TOP | wx.LEFT | wx.RIGHT, border = 5)
+ bsizer.Add(item = self._doSelLayout(title = vectSelTitle, sel = self.inputData['input']), proportion = 0,
+ flag = wx.EXPAND)
+ bsizer.Add(item = self._doSelLayout(title = aLayerSelTitle, sel = self.inputData['alayer']), proportion = 0,
+ flag = wx.EXPAND)
+ bsizer.Add(item = self._doSelLayout(title = nLayerSelTitle, sel = self.inputData['nlayer']), proportion = 0,
+ flag = wx.EXPAND)
+ box = wx.StaticBox(self.settingsPanel, -1, "Costs")
+ bsizer.Add(item = self._doSelLayout(title = afcolumnSelTitle, sel = self.inputData['afcolumn']), proportion = 0,
+ flag = wx.EXPAND)
+ bsizer.Add(item = self._doSelLayout(title = abcolumnSelTitle, sel = self.inputData['abcolumn']), proportion = 0,
+ flag = wx.EXPAND)
+ self.settingsPanel.SetSizer(mainSizer)
+ def _doSelLayout(self, title, sel):
+ selSizer = wx.BoxSizer(orient = wx.VERTICAL)
+ selTitleSizer = wx.BoxSizer(wx.HORIZONTAL)
+ selTitleSizer.Add(item = title, proportion = 1,
+ flag = wx.LEFT | wx.TOP | wx.EXPAND, border = 5)
+ selSizer.Add(item = selTitleSizer, proportion = 0,
+ flag = wx.EXPAND)
+ selSizer.Add(item = sel, proportion = 0,
+ flag = wx.EXPAND | wx.BOTTOM | wx.LEFT | wx.RIGHT | wx.TOP | wx.ALIGN_CENTER_VERTICAL,
+ border = 5)
+ return selSizer
+ def OnVectSel(self, event):
+ self.inputData['alayer'].InsertLayers(vector = self.inputData['input'].GetValue())#TODO split
+ self.inputData['nlayer'].InsertLayers(vector = self.inputData['input'].GetValue())
+ self.inputData['afcolumn'].InsertColumns(vector = self.inputData['input'].GetValue(),
+ layer = self.inputData['alayer'].GetValue(),
+ type = self.columnTypes)
+ self.inputData['abcolumn'].InsertColumns(vector = self.inputData['input'].GetValue(),
+ def OnCloseDialog(self, event):
+ """!Cancel dialog"""
+ self.parent.dialogs['vnet'] = None
+ self.Destroy()
+ def SetNodeStatus(self, item, itemIndex):
+ """!Before point is drawed, decides properties of drawing style"""
+ key = self.list.GetItemData(itemIndex)
+ gcp = self.list.itemDataMap[key]
+ if not self.list.IsChecked(key):
+ wxPen = "unused"
+ item.hide = False
+ else:
+ wxPen = "default"
+ if key == self.list.selected:
+ wxPen = "selected"
+ item.SetPropertyVal('label', str(itemIndex + 1))
+ item.SetPropertyVal('penName', wxPen)
+ def OnMapClickHandler(self, event):
+ """!Takes coordinates from map window."""
+ if event == 'unregistered':
+ ptListToolbar = self.toolbars['pointsList']
+ if ptListToolbar:
+ ptListToolbar.ToggleTool(vars(ptListToolbar)["insertPoint"], False) # TODO
+ return
+ if not self.list.itemDataMap:
+ e, n = self.mapWin.GetLastEN()
+ index = self.list.selected
+ key = self.list.GetItemData(index)
+ self.pointsToDraw.GetItem(key).SetCoords([e, n])
+ self.mapWin.UpdateMap(render=False, renderVector=False)
+ def OnAnalyze(self, event):
+ if len(self.pointsToDraw.GetAllItems()) < 1:
+ return
+ startPtLabel = self.cols[1][1][1]
+ endPtLabel = self.cols[1][1][2]
+ inputCoords = { startPtLabel : None,
+ endPtLabel : None}
+ for i in range(len(self.list.itemDataMap)):
+ key = self.list.GetItemData(i)
+ if self.list.IsChecked(key):
+ for k, v in inputCoords.iteritems():
+ if k == self.list.itemDataMap[key][1]:
+ inputCoords[k] = self.pointsToDraw.GetItem(key).GetCoords ()
+ if None in inputCoords.values():
+ GMessage(parent = self,
+ message=_("Pleas choose 'to' and 'from' point."))
+ return
+ resId = int(UserSettings.Get(group='vnet',
+ key='analasisSettings',
+ subkey='resultId'))
+ s = str(resId) + " " + str(inputCoords[startPtLabel][0]) + " " + str(inputCoords[startPtLabel][1]) + \
+ " " + str(inputCoords[endPtLabel][0]) + " " + str(inputCoords[endPtLabel][1])
+ coordsTempFile = grass.tempfile()#TODO stdin
+ coordsTempFileOpened = open(coordsTempFile, 'w')
+ coordsTempFileOpened.write(s)
+ coordsTempFileOpened.close()
+ params = {}
+ for k, v in self.inputData.iteritems():
+ if not v.GetValue():
+ params[k] = None
+ else:
+ params[k] = v.GetValue()
+ ret, std, msg = RunCommand('v.net.path',
+ input = params['input'],
+ output = self.tmp_result,
+ overwrite = True,
+ alayer = params['alayer'],
+ nlayer = params['nlayer'],
+ afcolumn = params['afcolumn'],
+ abcolumn = params['abcolumn'],
+ file = coordsTempFile,
+ dmax = int(UserSettings.Get(group='vnet',
+ subkey='maxDist')),
+ read = True,
+ getErrorMsg = True)
+ grass.try_remove(coordsTempFile)
+ self.mapWin.Map.DeleteLayer(layer = self.tmpResultLayer)
+ self.tmpResultLayer = self.mapWin.Map.AddLayer(type = "vector", command = self.cmdlist,
+ l_active=True, name = self.tmp_result,
+ l_hidden = False, l_opacity = 1.0,
+ l_render = True, pos = 1)
+ def OnInsertPoint(self, event):
+ if self.handlerRegistered == False:
+ self.mapWin.RegisterMouseEventHandler(wx.EVT_LEFT_DOWN,
+ self.OnMapClickHandler,
+ wx.StockCursor(wx.CURSOR_CROSS))
+ self.handlerRegistered = True
+ else:
+ def OnSaveTmpLayer(self, event):
+ dlg = AddLayerDialog(parent = self)
+ if dlg.ShowModal() == wx.ID_OK:
+ ret, std, msg = RunCommand("g.copy",
+ overwrite = dlg.overwrite.GetValue(),
+ vect = [self.tmp_result, dlg.vectSel.GetValue()],
+ read = True,
+ self.UpdateCmdList(dlg.vectSel.GetValue())
+ if self.mapWin.tree.FindItemByData(key = 'name', value = dlg.vectSel.GetValue()) is None:
+ self.mapWin.tree.AddLayer(ltype = "vector",
+ lname = dlg.vectSel.GetValue(),
+ lcmd = self.cmdlist,
+ lchecked = True)
+ def OnSettings(self, event):
+ """!Displays vnet settings dialog"""
+ dlg = SettingsDialog(parent=self, id=wx.ID_ANY, title=_('Settings'))
+ pass
+ dlg.Destroy()
+ def UpdateCmdList(self, layerName):
+ col = UserSettings.Get(group='vnet', key='resStyle', subkey= "color")
+ width = UserSettings.Get(group='vnet', key='resStyle', subkey= "width")
+ self.cmdlist = ['d.vect', 'map=%s' % layerName, \
+ 'color=' + str(col[0]) + ':' + str(col[1]) + ':' + str(col[2]), \
+ 'width=' + str(width)]# TODO settings
+class NodesList(PointsList):
+ def __init__(self, parent, dialog, cols, id=wx.ID_ANY):
+ """! List with points for analasis
+ self.dialog = dialog # VNETDialog class
+ PointsList.__init__(self, parent = parent, cols = cols, id = id)
+ def AddItem(self, event):
+ Appends an point to list
+ PointsList.AddItem(self, event)
+ self.dialog.pointsToDraw.AddItem(coords = [0,0],
+ label = str(self.selectedkey + 1))
+ self.dialog.mapWin.UpdateMap(render=True, renderVector=True)
+ def DeleteItem(self, event):
+ Deletes selected point in list
+ key = self.GetItemData(self.selected)
+ PointsList.DeleteItem(self, event)
+ if self.selected != wx.NOT_FOUND:
+ item = self.dialog.pointsToDraw.GetItem(key)
+ self.dialog.pointsToDraw.DeleteItem(item)
+ def OnItemSelected(self, event):
+ Item selected
+ PointsList.OnItemSelected(self, event)
+ self.dialog.mapWin.UpdateMap(render=False, renderVector=False)
+ event.Skip()
+ def OnCheckItem(self, index, flag):
+ """!Item is checked/unchecked"""
+ key = self.GetItemData(index)
+ checkedVal = self.itemDataMap[key][1]
+ if checkedVal == "":
+ self.CheckItem(key, False)
+ return
+ iItem = 0
+ for item in self.itemDataMap:
+ if item[1] == checkedVal and key != iItem and flag:
+ checkedKey = self.GetItemData(iItem)
+ self.CheckItem(checkedKey, False)
+ iItem += 1
+class SettingsDialog(wx.Dialog):
+ def __init__(self, parent, id, title, pos=wx.DefaultPosition, size=wx.DefaultSize,
+ style=wx.DEFAULT_DIALOG_STYLE):
+ """!Settings for v.net analasis dialog"""
+ wx.Dialog.__init__(self, parent, id, title, pos, size, style)
+ maxValue = 1e8
+ self.panel = wx.Panel(parent = self, id = wx.ID_ANY)
+ self.colorLabel = wx.StaticText(parent = self.panel, id = wx.ID_ANY, label = _("Line color:"))
+ col = UserSettings.Get(group ='vnet', key ='resStyle', subkey = "color")
+ self.colorField = csel.ColourSelect(parent = self.panel, id = wx.ID_ANY,
+ colour = wx.Colour(col[0],
+ col[1],
+ col[2],
+ 255))
+ self.widthLabel = wx.StaticText(parent = self.panel, id = wx.ID_ANY, label =_("Line width:"))
+ self.widthField = wx.SpinCtrl(parent = self.panel, id = wx.ID_ANY, min = 1, max = 10)
+ width = int(UserSettings.Get(group = 'vnet', key = 'resStyle', subkey = 'width'))
+ self.widthField.SetValue(width)
+ self.idLabel = wx.StaticText(parent = self.panel, id = wx.ID_ANY, label =_("Id of line:"))
+ self.resIdFiled = wx.SpinCtrl(parent = self.panel, id = wx.ID_ANY, min = 1, max = maxValue)
+ resId = int(UserSettings.Get(group ='vnet', key ='analasisSettings', subkey = 'resultId'))
+ self.resIdFiled.SetValue(resId)
+ self.maxDistlabel = wx.StaticText(parent = self.panel, id = wx.ID_ANY, label = _("Maximum distance \n to the network:"))
+ self.maxDistField = wx.SpinCtrl(parent = self.panel, id = wx.ID_ANY, min = 0, max = maxValue) #TODO
+ maxDist = int(UserSettings.Get(group = 'vnet', key = 'analasisSettings', subkey ='maxDist'))
+ self.maxDistField.SetValue(maxDist)
+ # buttons
+ #btnSave = wx.Button(self.panel, wx.ID_SAVE)
+ self.btnApply = wx.Button(self.panel, wx.ID_APPLY)
+ self.btnClose = wx.Button(self.panel, wx.ID_CLOSE)
+ self.btnApply.SetDefault()
+ # bindings
+ self.btnApply.Bind(wx.EVT_BUTTON, self.OnApply)
+ self.btnApply.SetToolTipString(_("Apply changes for the current session"))
+ #btnSave.Bind(wx.EVT_BUTTON, self.OnSave)
+ #btnSave.SetToolTipString(_("Apply and save changes to user settings file (default for next sessions)"))
+ self.btnClose.Bind(wx.EVT_BUTTON, self.OnClose)
+ self.btnClose.SetToolTipString(_("Close dialog"))
+ self._layout()
+ self.SetMinSize(self.GetBestSize())
+ def _layout(self):
+ styleBox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
+ label =" %s " % _("Analasis outcome line style:"))
+ styleBoxSizer = wx.StaticBoxSizer(styleBox, wx.VERTICAL)
+ gridSizer = wx.GridBagSizer(vgap = 1, hgap = 1)
+ row = 0
+ gridSizer.Add(item = self.colorLabel, flag = wx.ALIGN_CENTER_VERTICAL, pos =(row, 0))
+ gridSizer.Add(item = self.colorField,
+ flag = wx.ALIGN_RIGHT | wx.ALL, border = 5,
+ pos =(row, 1))
+ row += 1
+ gridSizer.Add(item = self.widthLabel, flag=wx.ALIGN_CENTER_VERTICAL, pos=(row, 0))
+ gridSizer.Add(item = self.widthField,
+ pos = (row, 1))
+ styleBoxSizer.Add(item = gridSizer, flag = wx.EXPAND)
+ analasisBox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
+ label = " %s " % _("Analasis settings:"))
+ analasisBoxSizer = wx.StaticBoxSizer(analasisBox, wx.VERTICAL)
+ row = 0
+ gridSizer.Add(item = self.idLabel, flag = wx.ALIGN_CENTER_VERTICAL, pos = (row, 0))
+ gridSizer.Add(item = self.resIdFiled,
+ pos = (row, 1))
+ row += 1
+ gridSizer.Add(item = self.maxDistlabel, flag = wx.ALIGN_CENTER_VERTICAL, pos = (row, 0))
+ gridSizer.Add(item = self.maxDistField,
+ pos = (row, 1))
+ analasisBoxSizer.Add(item = gridSizer, flag = wx.EXPAND)
+ # sizers
+ btnSizer = wx.BoxSizer(wx.HORIZONTAL)
+ btnSizer.Add(self.btnApply, flag = wx.LEFT | wx.RIGHT, border = 5)
+ #btnSizer.Add(btnSave, flag=wx.LEFT | wx.RIGHT, border=5)
+ btnSizer.Add(self.btnClose, flag = wx.LEFT | wx.RIGHT, border = 5)
+ sizer.Add(item = styleBoxSizer, flag = wx.EXPAND | wx.ALL, border = 5, proportion = 1)
+ sizer.Add(item = analasisBoxSizer, flag = wx.EXPAND | wx.ALL, border = 5, proportion = 1)
+ sizer.Add(item = btnSizer, flag = wx.EXPAND | wx.ALL, border = 5, proportion = 0)
+ self.panel.SetSizer(sizer)
+ sizer.Fit(self)
+ def UpdateSettings(self):
+ UserSettings.Set(group ='vnet', key ='resStyle', subkey ='width',
+ value = self.widthField.GetValue())
+ UserSettings.Set(group = 'vnet', key ='resStyle', subkey ='color',
+ value = self.colorField.GetColour())
+ UserSettings.Set(group = 'vnet', key ='analasisSettings', subkey ='resultId',
+ value = self.resIdFiled.GetValue())
+ UserSettings.Set(group ='vnet', key ='analasisSettings', subkey ='maxDist',
+ value = self.maxDistField.GetValue())
+ if self.parent.tmpResultLayer:
+ self.parent.UpdateCmdList(self.parent.tmp_result)
+ self.parent.tmpResultLayer.SetCmd(self.parent.cmdlist)
+ self.parent.mapWin.UpdateMap(render=True, renderVector=True)#TODO necessary
+ #def OnSave(self, event): TODO
+ # """!Button 'Save' pressed"""
+ # self.UpdateSettings()
+ # fileSettings = {}
+ # UserSettings.ReadSettingsFile(settings=fileSettings)
+ # fileSettings['vnet'] = UserSettings.Get(group='vnet')
+ # file = UserSettings.SaveToFile(fileSettings)
+ # self.parent.parent.goutput.WriteLog(_('Vnet fron end settings saved to file \'%s\'.') % file) TODO
+ # self.Close()
+ def OnApply(self, event):
+ """!Button 'Apply' pressed"""
+ self.UpdateSettings()
+ #self.Close()
+ def OnClose(self, event):
+ """!Button 'Cancel' pressed"""
+ self.Close()
+class AddLayerDialog(wx.Dialog):
+ """!Adds layer with analysis result into layer tree"""
+ def __init__(self, parent,id=wx.ID_ANY,
+ title =_("Add analasis result into layer tree"), style=wx.DEFAULT_DIALOG_STYLE):
+ """!Dialog for editing item cells in list"""
+ wx.Dialog.__init__(self, parent, id, title = _(title), style = style)
+ self.panel = wx.Panel(parent = self)
+ # text fields and it's captions
+ self.vectSel = Select(parent = self.panel, type = 'vector', size = (-1, -1))
+ self.vectSellabel = wx.StaticText(parent = self.panel, id = wx.ID_ANY,
+ label = _("Layer name:"))
+ self.overwrite = wx.CheckBox(parent = self.panel, id=wx.ID_ANY,
+ label = _("Overwrite existing layer"))
+ # buttons
+ self.btnCancel = wx.Button(self.panel, wx.ID_CANCEL)
+ self.btnOk = wx.Button(self.panel, wx.ID_OK)
+ self.btnOk.SetDefault()
+ self._layout()
+ box = wx.StaticBox (parent = self.panel, id = wx.ID_ANY,
+ label = "Added layer")
+ boxSizer = wx.StaticBoxSizer(box, wx.VERTICAL)
+ # source coordinates
+ gridSizer = wx.GridBagSizer(vgap = 5, hgap = 5)
+ row = 0
+ gridSizer.Add(item = self.vectSellabel,
+ flag = wx.ALIGN_CENTER_VERTICAL,
+ pos = (row, 0))
+ gridSizer.Add(item = self.vectSel,
+ pos = (row, 1))
+ boxSizer.Add(item = gridSizer, proportion = 1,
+ flag = wx.EXPAND | wx.ALL, border = 5)
+ sizer.Add(item = boxSizer, proportion = 1,
+ row +=1
+ gridSizer.Add(item = self.overwrite, pos =(row, 0))
+ btnSizer = wx.StdDialogButtonSizer()
+ btnSizer.AddButton(self.btnCancel)
+ btnSizer.AddButton(self.btnOk)
+ btnSizer.Realize()
+ sizer.Add(item = btnSizer, proportion = 0,
+ flag = wx.ALIGN_RIGHT | wx.ALL, border = 5)
+ sizer.Fit(self)
