[GRASS-SVN] r52350 - grass/branches/develbranch_6/display/d.vect
svn_grass at osgeo.org
Sun Jul 8 03:17:03 PDT 2012
Author: martinl
Date: 2012-07-08 03:17:03 -0700 (Sun, 08 Jul 2012)
New Revision: 52350
grass/branches/develbranch_6/display/d.vect/dir.c
grass/branches/develbranch_6/display/d.vect/local_proto.h
grass/branches/develbranch_6/display/d.vect/main.c
d.vect: dir arrows sizeable (backport from trunk)
Modified: grass/branches/develbranch_6/display/d.vect/dir.c
--- grass/branches/develbranch_6/display/d.vect/dir.c 2012-07-08 10:13:35 UTC (rev 52349)
+++ grass/branches/develbranch_6/display/d.vect/dir.c 2012-07-08 10:17:03 UTC (rev 52350)
@@ -8,15 +8,15 @@
/* arrow heads will be drawn at 25,50,75% of the line length */
#define PERC_OF_LINE 25
-int dir(struct Map_info *Map, int type, struct cat_list *Clist, int chcat)
+int dir(struct Map_info *Map, int type, struct cat_list *Clist,
+ int chcat, int dsize)
- int ltype, dsize;
+ int ltype;
double len, x, y, angle, msize, dist;
struct line_pnts *Points;
struct line_cats *Cats;
G_debug(1, "display direction:");
- dsize = 5;
msize = dsize * (D_d_to_u_col(2.0) - D_d_to_u_col(1.0)); /* do it better */
Points = Vect_new_line_struct();
Modified: grass/branches/develbranch_6/display/d.vect/local_proto.h
--- grass/branches/develbranch_6/display/d.vect/local_proto.h 2012-07-08 10:13:35 UTC (rev 52349)
+++ grass/branches/develbranch_6/display/d.vect/local_proto.h 2012-07-08 10:17:03 UTC (rev 52350)
@@ -8,7 +8,7 @@
int, char *);
int label(struct Map_info *, int, struct cat_list *, LATTR *, int);
int topo(struct Map_info *, int, LATTR *);
-int dir(struct Map_info *, int, struct cat_list *, int);
+int dir(struct Map_info *, int, struct cat_list *, int, int);
int darea(struct Map_info *, struct cat_list *, const struct color_rgb *,
const struct color_rgb *, int, int, int, int, struct Cell_head *,
char *, int, char *, double, int, char *);
Modified: grass/branches/develbranch_6/display/d.vect/main.c
--- grass/branches/develbranch_6/display/d.vect/main.c 2012-07-08 10:13:35 UTC (rev 52349)
+++ grass/branches/develbranch_6/display/d.vect/main.c 2012-07-08 10:17:03 UTC (rev 52350)
@@ -646,7 +646,7 @@
if (has_color) {
R_RGB_color(color.r, color.g, color.b);
if (display & DISP_DIR)
- stat = dir(&Map, type, Clist, chcat);
+ stat = dir(&Map, type, Clist, chcat, size);
/* reset line width: Do we need to get line width from display
