[GRASS-SVN] r52356 - grass/trunk/vector/v.generalize
svn_grass at osgeo.org
Mon Jul 9 09:37:28 PDT 2012
Author: martinl
Date: 2012-07-09 09:37:27 -0700 (Mon, 09 Jul 2012)
New Revision: 52356
grass/trunk/vector/v.generalize/main.c
v.generalize: module description cosmetics (more guisections)
simplify localization of option->descriptions
Modified: grass/trunk/vector/v.generalize/main.c
--- grass/trunk/vector/v.generalize/main.c 2012-07-09 15:45:11 UTC (rev 52355)
+++ grass/trunk/vector/v.generalize/main.c 2012-07-09 16:37:27 UTC (rev 52356)
@@ -9,7 +9,7 @@
* PURPOSE: Module for line simplification and smoothing
- * COPYRIGHT: (C) 2007-2010 by the GRASS Development Team
+ * COPYRIGHT: (C) 2007-2010, 2012 by the GRASS Development Team
* This program is free software under the GNU General
* Public License (>=v2). Read the file COPYING that
@@ -66,7 +66,7 @@
int n_lines;
int simplification, mask_type;
struct varray *varray;
- char *s;
+ char *s, *descriptions;
/* initialize GIS environment */
G_gisinit(argv[0]); /* reads grass env, stores program name to G_program_name() */
@@ -79,7 +79,7 @@
G_add_keyword(_("smoothing"));
G_add_keyword(_("displacement"));
G_add_keyword(_("network generalization"));
- module->description = _("Tool for vector based generalization.");
+ module->description = _("Performs vector based generalization.");
/* Define the different options as defined in gis.h */
map_in = G_define_standard_option(G_OPT_V_INPUT);
@@ -89,7 +89,8 @@
type_opt = G_define_standard_option(G_OPT_V_TYPE);
type_opt->options = "line,boundary,area";
type_opt->answer = "line,boundary,area";
+ type_opt->guisection = _("Selection");
map_out = G_define_standard_option(G_OPT_V_OUTPUT);
@@ -100,20 +101,36 @@
method_opt->multiple = NO;
method_opt->options =
"douglas,douglas_reduction,lang,reduction,reumann,boyle,sliding_averaging,distance_weighting,chaiken,hermite,snakes,network,displacement";
- method_opt->descriptions = _("douglas;Douglas-Peucker Algorithm;"
- "douglas_reduction;Douglas-Peucker Algorithm with reduction parameter;"
- "lang;Lang Simplification Algorithm;"
- "reduction;Vertex Reduction Algorithm eliminates points close to each other;"
- "reumann;Reumann-Witkam Algorithm;"
- "boyle;Boyle's Forward-Looking Algorithm;"
- "sliding_averaging;McMaster's Sliding Averaging Algorithm;"
- "distance_weighting;McMaster's Distance-Weighting Algorithm;"
- "chaiken;Chaiken's Algorithm;"
- "hermite;Interpolation by Cubic Hermite Splines;"
- "snakes;Snakes method for line smoothing;"
- "network;Network generalization;"
- "displacement;Displacement of lines close to each other;");
+ descriptions = NULL;
+ G_asprintf(&descriptions,
+ "douglas;%s;"
+ "douglas_reduction;%s;"
+ "lang;%s;"
+ "reduction;%s;"
+ "reumann;%s;"
+ "boyle;%s;"
+ "sliding_averaging;%s;"
+ "distance_weighting;%s;"
+ "chaiken;%s;"
+ "hermite;%s;"
+ "snakes;%s;"
+ "network;%s;"
+ "displacement;%s;",
+ _("Douglas-Peucker Algorithm"),
+ _("Douglas-Peucker Algorithm with reduction parameter"),
+ _("Lang Simplification Algorithm"),
+ _("Vertex Reduction Algorithm eliminates points close to each other"),
+ _("Reumann-Witkam Algorithm"),
+ _("Boyle's Forward-Looking Algorithm"),
+ _("McMaster's Sliding Averaging Algorithm"),
+ _("McMaster's Distance-Weighting Algorithm"),
+ _("Chaiken's Algorithm"),
+ _("Interpolation by Cubic Hermite Splines"),
+ _("Snakes method for line smoothing"),
+ _("Network generalization"),
+ _("Displacement of lines close to each other"));
+ method_opt->descriptions = G_store(descriptions);
method_opt->description = _("Generalization algorithm");
thresh_opt = G_define_option();
@@ -138,7 +155,7 @@
reduction_opt->options = "0-100";
reduction_opt->description =
_("Percentage of the points in the output of 'douglas_reduction' algorithm");
slide_opt = G_define_option();
slide_opt->key = "slide";
slide_opt->type = TYPE_DOUBLE;
@@ -204,12 +221,16 @@
iterations_opt->description = _("Number of iterations");
cat_opt = G_define_standard_option(G_OPT_V_CATS);
+ cat_opt->guisection = _("Selection");
where_opt = G_define_standard_option(G_OPT_DB_WHERE);
+ where_opt->guisection = _("Selection");
ca_flag = G_define_flag();
ca_flag->key = 'c';
ca_flag->description = _("Copy attributes");
+ ca_flag->guisection = _("Attributes");
/* options and flags parser */
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
