[GRASS-SVN] r52361 - grass-addons/grass7/gui/wxpython/wx.vnet/vnet
svn_grass at osgeo.org
Tue Jul 10 09:17:37 PDT 2012
Author: turek
Date: 2012-07-10 09:17:36 -0700 (Tue, 10 Jul 2012)
New Revision: 52361
grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py
grass-addons/grass7/gui/wxpython/wx.vnet/vnet/toolbars.py
grass-addons/grass7/gui/wxpython/wx.vnet/vnet/widgets.py
Integrated v.net.salesman and v.net.alloc. Changes for easier integration of other v.net.* modules.
Modified: grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py
--- grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py 2012-07-10 16:09:34 UTC (rev 52360)
+++ grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py 2012-07-10 16:17:36 UTC (rev 52361)
@@ -28,23 +28,26 @@
from gui_core.widgets import GNotebook
from core.settings import UserSettings
from grass.script import core as grass
+from core import utils
from core.gcmd import RunCommand, GMessage
+import unicodedata
import wx
import wx.aui
import wx.lib.flatnotebook as FN
from copy import copy
class VNETDialog(wx.Dialog):
def __init__(self, parent,
id=wx.ID_ANY, title = "Vector network analysis",
style=wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER):
- """!Dialolog for vector network analasis"""
+ """!Dialolog for vector network analysis"""
wx.Dialog.__init__(self, parent, id, style=style, title = title)
self.parent = parent #mapdisp.frame MapFrame
self.mapWin = parent.MapWindow
self.inputData = {}
+ self.cmdParams = {}
# registration graphics for drawing
self.pointsToDraw = self.mapWin.RegisterGraphicsToDraw(graphicsType = "point",
@@ -56,6 +59,9 @@
self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass_map.ico'), wx.BITMAP_TYPE_ICO))
+ # initialozation of v.net.* analysis parameters
+ self._initvnetParams()
# toolbars
self.toolbars = {}
self.toolbars['mainToolbar'] = MainToolbar(parent = self)
@@ -67,7 +73,7 @@
# Columns in points list
self.cols = [
- ['type', ["", "Start point", "End point"], ""]
+ ['type', ["", _("Start point"), _("End point")], ""] #TODO init dynamically
self.mainPanel = wx.Panel(parent=self)
@@ -101,8 +107,8 @@
initSettings = [
['resStyle', 'width', 5],
['resStyle', 'color', (192,0,0)],
- ['analasisSettings', 'maxDist', 10000],
- ['analasisSettings', 'resultId', 1]
+ ['analysisSettings', 'maxDist', 10000],
+ ['analysisSettings', 'resultId', 1]
for init in initSettings:
@@ -121,17 +127,17 @@
# adds 2 points into list
for i in range(2):
self.list.AddItem(None)
- self.list.EditCell(i, 1, self.cols[1][1][1 + i])
+ self.list.EditCellIndex(i, 1, self.cols[1][1][1 + i])
self.list.CheckItem(i, True)
self.Bind(wx.EVT_CLOSE, self.OnCloseDialog)
- dlgSize = (300,450)
+ dlgSize = (300, 500)
self.SetMinSize(dlgSize)
self.SetInitialSize(dlgSize)
def __del__(self):
- """!Removes temp layer with analasis result, unregisters handlers and graphics"""
+ """!Removes temp layer with analysis result, unregisters handlers and graphics"""
self.mapWin.UnregisterGraphicsToDraw(self.pointsToDraw)
@@ -210,10 +216,14 @@
abcolumnSelTitle = wx.StaticText(parent = self.settingsPanel)
abcolumnSelTitle.SetLabel("Arc backward direction cost column:")
- self.inputData['input'].Bind(wx.EVT_TEXT, self.OnVectSel)
- self.inputData['alayer'].Bind(wx.EVT_TEXT, self.OnVectSel)
- self.inputData['nlayer'].Bind(wx.EVT_TEXT, self.OnVectSel)
+ self.inputData['ncolumn'] = ColumnSelect(parent = self.settingsPanel, size = (-1, -1))
+ ncolumnSelTitle = wx.StaticText(parent = self.settingsPanel)
+ ncolumnSelTitle.SetLabel("Node direction cost column:")
+ self.inputData['input'].Bind(wx.EVT_TEXT, self.OnVectSel) # TODO optimalization
+ self.inputData['alayer'].Bind(wx.EVT_TEXT, self.OnALayerSel)
+ self.inputData['nlayer'].Bind(wx.EVT_TEXT, self.OnNLayerSel)
mainSizer = wx.BoxSizer(wx.VERTICAL)
box = wx.StaticBox(self.settingsPanel, -1, "Layer for analysis")
@@ -243,6 +253,8 @@
bsizer.Add(item = self._doSelLayout(title = abcolumnSelTitle, sel = self.inputData['abcolumn']), proportion = 0,
flag = wx.EXPAND)
+ bsizer.Add(item = self._doSelLayout(title = ncolumnSelTitle, sel = self.inputData['ncolumn']), proportion = 0,
+ flag = wx.EXPAND)
self.settingsPanel.SetSizer(mainSizer)
@@ -264,9 +276,15 @@
def OnVectSel(self, event):
- self.inputData['alayer'].InsertLayers(vector = self.inputData['input'].GetValue())#TODO split
+ self.inputData['alayer'].InsertLayers(vector = self.inputData['input'].GetValue())
self.inputData['nlayer'].InsertLayers(vector = self.inputData['input'].GetValue())
+ self.OnALayerSel(event)
+ self.OnNLayerSel(event)
+ def OnALayerSel(self, event):
self.inputData['afcolumn'].InsertColumns(vector = self.inputData['input'].GetValue(),
layer = self.inputData['alayer'].GetValue(),
type = self.columnTypes)
@@ -274,6 +292,13 @@
+ def OnNLayerSel(self, event):
+ self.inputData['ncolumn'].InsertColumns(vector = self.inputData['input'].GetValue(),
+ layer = self.inputData['nlayer'].GetValue(),
+ type = self.columnTypes)
def OnCloseDialog(self, event):
"""!Cancel dialog"""
@@ -281,7 +306,7 @@
self.Destroy()
def SetNodeStatus(self, item, itemIndex):
- """!Before point is drawed, decides properties of drawing style"""
+ """!Before point is drawn, decides properties of drawing style"""
key = self.list.GetItemData(itemIndex)
gcp = self.list.itemDataMap[key]
@@ -323,63 +348,210 @@
def OnAnalyze(self, event):
"""!Takes coordinates from map window."""
+ inType = self.vnetParams[self.currAnModule]["inputType"]
+ cmdParams = [self.currAnModule]
+ cmdParams.extend(self._getInputParams())
+ cmdParams.append("output=" + self.tmp_result)
+ catPts = self._getPtByCat()
+ if inType == "cats":
+ self._catsInType(cmdParams, catPts)
+ elif inType == "stdin":
+ self._stdinInType(cmdParams, catPts)
+ def _stdinInType(self, cmdParams, catPts):
if len(self.pointsToDraw.GetAllItems()) < 1:
return
- startPtLabel = self.cols[1][1][1]
- endPtLabel = self.cols[1][1][2]
+ cats = self.vnetParams[self.currAnModule]["cmdParams"]["cats"]
- inputCoords = { startPtLabel : None,
- endPtLabel : None}
+ cmdPts = []
+ for cat in cats:
+ if len(catPts[cat[0]]) < 1:
+ GMessage(parent = self,
+ message=_("Pleas choose 'to' and 'from' point."))
+ return
+ cmdPts.append(catPts[cat[0]][0])
+ resId = int(UserSettings.Get(group ='vnet',
+ key = 'analysisSettings',
+ subkey = 'resultId'))
+ inpPoints = str(resId) + " " + str(cmdPts[0][0]) + " " + str(cmdPts[0][1]) + \
+ " " + str(cmdPts[1][0]) + " " + str(cmdPts[1][1])
+ cmdParams.append("stdin=" + inpPoints)
+ dmax = int(UserSettings.Get(group = 'vnet',
+ key ='analysisSettings',
+ subkey ='maxDist'))
+ cmdParams.append("dmax=" + str(dmax))
+ cmdParams.append("input=" + self.inputData['input'].GetValue())
+ self._executeCommand(cmdParams)
+ self._addTempLayer()
+ def _catsInType(self, cmdParams, catPts):
+ tmp_pts_connect = "pts_connect"
+ tmp_input_connected = "tmp_input_map_connected"
+ cats = RunCommand("v.category",
+ input = self.inputData['input'].GetValue(),
+ option = "report",
+ flags = "g",
+ read = True)
+ cats = cats.splitlines()
+ for cat in cats:#TODO
+ cat = cat.split()
+ if "all" in cat:
+ maxCat = int(cat[4])
+ break
+ layerNum = self.inputData["nlayer"].GetValue().strip()
+ if not layerNum:
+ layerNum = 1 #TODO
+ pt_ascii, catsNums = self._getAsciiPts (catPts = catPts,
+ maxCat = maxCat,
+ layerNum = layerNum)
+ ret, msg = RunCommand("v.edit",
+ map = tmp_pts_connect,
+ stdin = pt_ascii,
+ input = "-",
+ tool = 'create',
+ flags = "n",
+ overwrite = True,
+ getErrorMsg = True)
+ print msg
+ ret, msg = RunCommand("v.to.db",
+ option = "cat",
+ overwrite = True,
+ print msg
+ ret, msg = RunCommand("v.net",
+ points = tmp_pts_connect,
+ stdin = pt_ascii,
+ output = tmp_input_connected,
+ input = self.inputData["input"].GetValue(),
+ operation = 'connect',
+ thresh = dmax,
+ alayer = self.inputData["alayer"].GetValue(),
+ nlayer= self.inputData["nlayer"].GetValue(),
+ overwrite = True,
+ getErrorMsg = True,
+ quiet = True)
+ print msg
+ cmdParams.append("input=" + tmp_input_connected)
+ for catName, catNum in catsNums.iteritems():
+ if catNum[0] == catNum[1]:
+ cmdParams.append(catName + "=" + str(catNum[0]))
+ else:
+ cmdParams.append(catName + "=" + str(catNum[0]) + "-" + str(catNum[1]))
+ if self.currAnModule == "v.net.alloc": #TODO ugly hack
+ self.UpdateCmdList(self.tmp_result, True)
+ else: #TODO
+ self.UpdateCmdList(self.tmp_result, False)
+ def _getInputParams(self):
+ inParams = []
+ for col in self.vnetParams[self.currAnModule]["cmdParams"]["cols"]:
+ if "inputField" in self.attrCols[col]:
+ colInptF = self.attrCols[col]["inputField"]
+ else:
+ colInptF = col
+ inParams.append(col + '=' + self.inputData[colInptF].GetValue())
+ for layer in ['alayer', 'nlayer']: #TODO input
+ inParams.append(layer + "=" + self.inputData[layer].GetValue())
+ return inParams
+ def _getPtByCat(self):
+ ptByCats = {}
+ for cat in self.vnetParams[self.currAnModule]["cmdParams"]["cats"]:
+ ptByCats[cat[0]] = []
for i in range(len(self.list.itemDataMap)):
key = self.list.GetItemData(i)
if self.list.IsChecked(key):
- for k, v in inputCoords.iteritems():
- if k == self.list.itemDataMap[key][1]:
- inputCoords[k] = self.pointsToDraw.GetItem(key).GetCoords ()
+ for cat in cats:
+ if cat[1] == self.list.itemDataMap[key][1] or len(ptByCats) == 1:
+ ptByCats[cat[0]].append(self.pointsToDraw.GetItem(key).GetCoords())
+ continue
- if None in inputCoords.values():
- GMessage(parent = self,
- message=_("Pleas choose 'to' and 'from' point."))
- return
+ return ptByCats
- resId = int(UserSettings.Get(group='vnet',
- key='analasisSettings',
- subkey='resultId'))
+ def _getAsciiPts (self, catPts, maxCat, layerNum):
- s = str(resId) + " " + str(inputCoords[startPtLabel][0]) + " " + str(inputCoords[startPtLabel][1]) + \
- " " + str(inputCoords[endPtLabel][0]) + " " + str(inputCoords[endPtLabel][1])
+ catsNums = {}
+ pt_ascii = ""
+ catNum = maxCat
- coordsTempFile = grass.tempfile()#TODO stdin
- coordsTempFileOpened = open(coordsTempFile, 'w')
- coordsTempFileOpened.write(s)
- coordsTempFileOpened.close()
+ if layerNum:
+ nlayer = layerNum
+ else:
+ nlayer = 1 #TODO ugly hack
- params = {}
- for k, v in self.inputData.iteritems():
- if not v.GetValue():
- params[k] = None
- else:
- params[k] = v.GetValue()
- ret, std, msg = RunCommand('v.net.path',
- input = params['input'],
- output = self.tmp_result,
- overwrite = True,
- alayer = params['alayer'],
- nlayer = params['nlayer'],
- afcolumn = params['afcolumn'],
- abcolumn = params['abcolumn'],
- file = coordsTempFile,
- dmax = int(UserSettings.Get(group='vnet',
- subkey='maxDist')),
- read = True,
- getErrorMsg = True)
+ for catName, pts in catPts.iteritems():
- grass.try_remove(coordsTempFile)
+ catsNums[catName] = [catNum + 1]
+ for pt in pts:
+ catNum += 1
+ pt_ascii += "P 1 1\n"
+ pt_ascii += str(pt[0]) + " " + str(pt[1]) + "\n"
+ pt_ascii += str(nlayer) + " " + str(catNum) + "\n"
+ catsNums[catName].append(catNum)
+ return pt_ascii, catsNums
+ def _executeCommand(self, cmd):
+ cmd = utils.CmdToTuple(cmd)
+ for c, v in cmd[1].items():
+ if not v.strip():
+ cmd[1].pop(c)
+ ret, msg = RunCommand(cmd[0],
+ quiet = True,
+ overwrite = True, #TODO init test
+ **cmd[1])
+ def _addTempLayer(self):
if self.tmpResultLayer:
self.mapWin.Map.DeleteLayer(layer = self.tmpResultLayer)
@@ -390,6 +562,42 @@
self.mapWin.UpdateMap(render=True, renderVector=True)
+ def _adaptPointsList(self):
+ prevParamsCats = self.vnetParams[self.prevAnModule]["cmdParams"]["cats"]
+ currParamsCats = self.vnetParams[self.currAnModule]["cmdParams"]["cats"]
+ for key in range(len(self.list.itemDataMap)):
+ iCat = 0
+ for ptCat in prevParamsCats:
+ if self.list.itemDataMap[key][1] == ptCat[1]:
+ self.list.EditCellKey(key, 1, currParamsCats[iCat][1])
+ iCat += 1
+ colValues = [""]
+ for ptCat in currParamsCats:
+ colValues.append(ptCat[1])
+ self.list.ChangeColType(1, colValues)
+ self.prevAnModule = self.currAnModule
+ def UpdateCmdList(self, layerName, colorsByCats = False):
+ """!Displays vnet settings dialog"""
+ col = UserSettings.Get(group='vnet', key='resStyle', subkey= "color")
+ width = UserSettings.Get(group='vnet', key='resStyle', subkey= "width")
+ self.cmdlist = ['d.vect', 'map=%s' % layerName,
+ "layer=1",'width=' + str(width)]
+ if colorsByCats:
+ self.cmdlist.append('flags=c')
+ else:
+ self.cmdlist.append('color=' + str(col[0]) + ':' + str(col[1]) + ':' + str(col[2]))
def OnInsertPoint(self, event):
if self.handlerRegistered == False:
self.mapWin.RegisterMouseEventHandler(wx.EVT_LEFT_DOWN,
@@ -408,7 +616,7 @@
if dlg.ShowModal() == wx.ID_OK:
- ret, std, msg = RunCommand("g.copy",
+ ret, std, msg = RunCommand("g.rename",
overwrite = dlg.overwrite.GetValue(),
vect = [self.tmp_result, dlg.vectSel.GetValue()],
read = True,
@@ -431,19 +639,113 @@
dlg.Destroy()
- def UpdateCmdList(self, layerName):
- """!Displays vnet settings dialog"""
+ def OnAnalysisChanged(self, event):
- col = UserSettings.Get(group='vnet', key='resStyle', subkey= "color")
- width = UserSettings.Get(group='vnet', key='resStyle', subkey= "width")
+ # finds module name according to value in anChoice
+ for module, params in self.vnetParams.iteritems():
+ chLabel = self.toolbars['mainToolbar'].anChoice.GetValue()
+ if params["label"] == chLabel:
+ self.currAnModule = module
+ break
- self.cmdlist = ['d.vect', 'map=%s' % layerName, \
- 'color=' + str(col[0]) + ':' + str(col[1]) + ':' + str(col[2]), \
- 'width=' + str(width)]# TODO settings
+ if len(self.vnetParams[self.currAnModule]["cmdParams"]["cats"]) > 1:
+ self._adaptPointsList()
+ def _initvnetParams(self):
+ """!Initializes parameters for different v.net.* analysis """
+ self.attrCols = {
+ 'afcolumn' : {"label" : "Arc forward/both direction(s) cost column:"}, #TODO add dynamic generation of data tab
+ 'abcolumn' : {"label" : "Arc backward direction cost column:"},
+ 'acolumn' : {
+ "label" : "Arcs' cost column (for both directions:",
+ "inputField" : 'afcolumn'
+ 'ncolumn' : {"label" : "Node cost column:"}
+ self.vnetParams = {
+ "v.net.path" : {
+ "label" : _("Shortest path %s") % "(v.net.path)",
+ "cmdParams" : {
+ "cats" : [
+ ["st_pt", _("Start point")],
+ ["end_pt", _("End point")]
+ "cols" : [
+ 'afcolumn',
+ 'abcolumn',
+ 'ncolumn'
+ "other" : {
+ "dmax" : int,
+ "id" : int
+ "inputType" : "stdin",
+ "v.net.salesman" : {
+ "label" : _("Salesman %s") % "(v.net.salesman)",
+ "cmdParams" : {
+ "cats" : [["ccats", None]],
+ "cols" : [
+ 'afcolumn',
+ 'abcolumn'
+ "inputType" : "cats"
+ "v.net.flow" : {
+ "label" : _("Flow %s") % "(v.net.flow)",
+ "cmdParams" : {
+ "cats" : [
+ ["source_cats", _("Source point")],
+ ["sink_cats", _("Sink point")]
+ "cols" : [
+ 'afcolumn',
+ 'abcolumn',
+ 'ncolumn'
+ "v.net.alloc" : {
+ "label" : _("Allocate subnets for nearest centres %s") % "(v.net.alloc)",
+ "cmdParams" : {
+ "cols" : [
+ 'afcolumn',
+ 'abcolumn',
+ 'ncolumn'
+ "v.net.steiner" : {
+ "label" : _("Create Steiner tree for the network and given terminals %s") % "(v.net.steiner)",
+ "cmdParams" : {
+ "cats" : [["tcats", None]],
+ "cols" : [
+ 'acolumn',
+ self.vnetModulesOrder = ["v.net.path",
+ "v.net.salesman",
+ #"v.net.flow",
+ "v.net.alloc",
+ #"v.net.steiner"
+ ] # order in the choice of analysis
+ self.currAnModule = self.vnetModulesOrder[0]
+ self.prevAnModule = self.vnetModulesOrder[0]
class NodesList(PointsList):
def __init__(self, parent, dialog, cols, id=wx.ID_ANY):
- """! List with points for analasis
+ """! List with points for analysis
self.dialog = dialog # VNETDialog class
@@ -481,7 +783,7 @@
PointsList.OnItemSelected(self, event)
self.dialog.mapWin.UpdateMap(render=False, renderVector=False)
+ self.dialog._getPtByCat()
event.Skip()
def OnCheckItem(self, index, flag):
@@ -490,10 +792,19 @@
key = self.GetItemData(index)
checkedVal = self.itemDataMap[key][1]
+ currModule = self.dialog.currAnModule
+ cats = self.dialog.vnetParams[currModule]["cmdParams"]["cats"]
+ if len(cats) <= 1:
+ return
if checkedVal == "":
self.CheckItem(key, False)
return
+ if currModule != "v.net.path":
+ return
iItem = 0
for item in self.itemDataMap:
if item[1] == checkedVal and key != iItem and flag:
@@ -501,10 +812,11 @@
self.CheckItem(checkedKey, False)
iItem += 1
class SettingsDialog(wx.Dialog):
def __init__(self, parent, id, title, pos=wx.DefaultPosition, size=wx.DefaultSize,
style=wx.DEFAULT_DIALOG_STYLE):
- """!Settings for v.net analasis dialog"""
+ """!Settings for v.net analysis dialog"""
wx.Dialog.__init__(self, parent, id, title, pos, size, style)
maxValue = 1e8
@@ -527,12 +839,12 @@
self.idLabel = wx.StaticText(parent = self.panel, id = wx.ID_ANY, label =_("Id of line:"))
self.resIdFiled = wx.SpinCtrl(parent = self.panel, id = wx.ID_ANY, min = 1, max = maxValue)
- resId = int(UserSettings.Get(group ='vnet', key ='analasisSettings', subkey = 'resultId'))
+ resId = int(UserSettings.Get(group ='vnet', key ='analysisSettings', subkey = 'resultId'))
self.resIdFiled.SetValue(resId)
self.maxDistlabel = wx.StaticText(parent = self.panel, id = wx.ID_ANY, label = _("Maximum distance \n to the network:"))
self.maxDistField = wx.SpinCtrl(parent = self.panel, id = wx.ID_ANY, min = 0, max = maxValue) #TODO
- maxDist = int(UserSettings.Get(group = 'vnet', key = 'analasisSettings', subkey ='maxDist'))
+ maxDist = int(UserSettings.Get(group = 'vnet', key = 'analysisSettings', subkey ='maxDist'))
self.maxDistField.SetValue(maxDist)
# buttons
@@ -556,7 +868,7 @@
sizer = wx.BoxSizer(wx.VERTICAL)
styleBox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
- label =" %s " % _("Analasis outcome line style:"))
+ label =" %s " % _("Analysis outcome line style:"))
styleBoxSizer = wx.StaticBoxSizer(styleBox, wx.VERTICAL)
gridSizer = wx.GridBagSizer(vgap = 1, hgap = 1)
@@ -576,9 +888,9 @@
styleBoxSizer.Add(item = gridSizer, flag = wx.EXPAND)
- analasisBox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
- label = " %s " % _("Analasis settings:"))
- analasisBoxSizer = wx.StaticBoxSizer(analasisBox, wx.VERTICAL)
+ analysisBox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
+ label = " %s " % _("Analysis settings:"))
+ analysisBoxSizer = wx.StaticBoxSizer(analysisBox, wx.VERTICAL)
row = 0
@@ -593,7 +905,7 @@
flag = wx.ALIGN_RIGHT | wx.ALL, border = 5,
pos = (row, 1))
- analasisBoxSizer.Add(item = gridSizer, flag = wx.EXPAND)
+ analysisBoxSizer.Add(item = gridSizer, flag = wx.EXPAND)
# sizers
btnSizer = wx.BoxSizer(wx.HORIZONTAL)
@@ -602,7 +914,7 @@
btnSizer.Add(self.btnClose, flag = wx.LEFT | wx.RIGHT, border = 5)
sizer.Add(item = styleBoxSizer, flag = wx.EXPAND | wx.ALL, border = 5, proportion = 1)
- sizer.Add(item = analasisBoxSizer, flag = wx.EXPAND | wx.ALL, border = 5, proportion = 1)
+ sizer.Add(item = analysisBoxSizer, flag = wx.EXPAND | wx.ALL, border = 5, proportion = 1)
sizer.Add(item = btnSizer, flag = wx.EXPAND | wx.ALL, border = 5, proportion = 0)
self.panel.SetSizer(sizer)
@@ -616,10 +928,10 @@
UserSettings.Set(group = 'vnet', key ='resStyle', subkey ='color',
value = self.colorField.GetColour())
- UserSettings.Set(group = 'vnet', key ='analasisSettings', subkey ='resultId',
+ UserSettings.Set(group = 'vnet', key ='analysisSettings', subkey ='resultId',
value = self.resIdFiled.GetValue())
- UserSettings.Set(group ='vnet', key ='analasisSettings', subkey ='maxDist',
+ UserSettings.Set(group ='vnet', key ='analysisSettings', subkey ='maxDist',
value = self.maxDistField.GetValue())
if self.parent.tmpResultLayer:
@@ -627,7 +939,7 @@
self.parent.UpdateCmdList(self.parent.tmp_result)
self.parent.tmpResultLayer.SetCmd(self.parent.cmdlist)
- self.parent.mapWin.UpdateMap(render=True, renderVector=True)#TODO necessary
+ self.parent.mapWin.UpdateMap(render=True, renderVector=True)#TODO optimalization
#def OnSave(self, event): TODO
@@ -653,7 +965,7 @@
"""!Adds layer with analysis result into layer tree"""
def __init__(self, parent,id=wx.ID_ANY,
- title =_("Add analasis result into layer tree"), style=wx.DEFAULT_DIALOG_STYLE):
+ title =_("Add analysis result into layer tree"), style=wx.DEFAULT_DIALOG_STYLE):
"""!Dialog for editing item cells in list"""
wx.Dialog.__init__(self, parent, id, title = _(title), style = style)
Modified: grass-addons/grass7/gui/wxpython/wx.vnet/vnet/toolbars.py
--- grass-addons/grass7/gui/wxpython/wx.vnet/vnet/toolbars.py 2012-07-10 16:09:34 UTC (rev 52360)
+++ grass-addons/grass7/gui/wxpython/wx.vnet/vnet/toolbars.py 2012-07-10 16:17:36 UTC (rev 52361)
@@ -62,18 +62,22 @@
self.InitToolbar(self._toolbarData())
- choices = [ _('Shortest path'), ]
- self.combo = wx.ComboBox(parent = self, id = wx.ID_ANY,
+ choices = []
+ for moduleName in self.parent.vnetModulesOrder:
+ choices.append(self.parent.vnetParams[moduleName]['label'])
+ self.anChoice = wx.ComboBox(parent = self, id = wx.ID_ANY,
choices = choices,
style = wx.CB_READONLY, size = (110, -1))
- self.combo.SetSelection(0)
- self.comboid = self.AddControl(self.combo)
- #self.parent.Bind(wx.EVT_COMBOBOX, self.OnSelectTool, self.comboid)
+ self.anChoice.SetSelection(0)
+ self.anChoiceId = self.AddControl(self.anChoice)
+ self.parent.Bind(wx.EVT_COMBOBOX, self.parent.OnAnalysisChanged, self.anChoiceId)
# workaround for Mac bug. May be fixed by 2.8.8, but not before then.
- self.combo.Hide()
- self.combo.Show()
+ self.anChoice.Hide()
+ self.anChoice.Show()
# realize the toolbar
self.Realize()
@@ -84,16 +88,16 @@
icons = {
'run' : MetaIcon(img = 'execute',
label = _('Execute analysis')),
- 'saveTempLayer' : MetaIcon(img = 'map-export',
- label = _('Add temporary result of analasis into layer tree')),
- 'settings' : BaseIcons['settings'].SetLabel( _('Vector network analasis settings'))
+ 'saveTempLayer' : MetaIcon(img = 'map-export',
+ label = _('Add temporary result of analysis into layer tree')),
+ 'settings' : BaseIcons['settings'].SetLabel( _('Vector network analysis settings'))
return self._getToolbarData((
("run", icons['run'],
self.parent.OnAnalyze),
- ("saveTempLayer", icons['saveTempLayer'],
- self.parent.OnSaveTmpLayer),
+ #("saveTempLayer", icons['saveTempLayer'],
+ # self.parent.OnSaveTmpLayer),
('settings', icons["settings"],
self.parent.OnSettings),
("quit", BaseIcons['quit'],
Modified: grass-addons/grass7/gui/wxpython/wx.vnet/vnet/widgets.py
--- grass-addons/grass7/gui/wxpython/wx.vnet/vnet/widgets.py 2012-07-10 16:09:34 UTC (rev 52360)
+++ grass-addons/grass7/gui/wxpython/wx.vnet/vnet/widgets.py 2012-07-10 16:17:36 UTC (rev 52361)
@@ -54,7 +54,7 @@
column name, convert function, default val
@code
cols = [
- wx.ListCtrl, float, 0.0],
+ ['source E', float, 0.0],
['source N', float, 0.0],
['target E', float, 0.0],
['target N', float, 0.0],
@@ -170,13 +170,24 @@
return self.selected
- def EditCell(self, item, col, cellData):
- """! Changes value in list"""
+ def EditCellIndex(self, index, col, cellData):
+ """! Changes value in list using key (same regardless sorting)"""
- self.itemDataMap[self.GetItemData(item)][col] = cellData
- self.SetStringItem(item, col, str(cellData))
+ self.itemDataMap[self.GetItemData(index)][col] = cellData
+ self.SetStringItem(index, col, str(cellData))
+ def EditCellKey(self, key, col, cellData):
+ """! Changes value in list using index (changes during sorting)"""
+ index = self.FindItemData(-1, key)
+ self.itemDataMap[key][col] = cellData
+ def ChangeColType(self, col, colType):
+ print colType
+ self.cols_data["colsEditable"][col] = colType
def DeleteItem(self, event = None):
"""! Deletes selected item in list"""
if self.selected == wx.NOT_FOUND:
