[GRASS-SVN] r52374 - grass/trunk/lib/ogsf
svn_grass at osgeo.org
Sun Jul 15 08:04:26 PDT 2012
Author: annakrat
Date: 2012-07-15 08:04:25 -0700 (Sun, 15 Jul 2012)
New Revision: 52374
grass/trunk/lib/ogsf/gsd_fringe.c
improved fringe rendering (GL_QUAD_STRIP instead of GL_POLYGON which can't draw concave polygons)
Modified: grass/trunk/lib/ogsf/gsd_fringe.c
--- grass/trunk/lib/ogsf/gsd_fringe.c 2012-07-13 20:57:40 UTC (rev 52373)
+++ grass/trunk/lib/ogsf/gsd_fringe.c 2012-07-15 15:04:25 UTC (rev 52374)
@@ -131,21 +131,23 @@
- \brief ADD
+ \brief Draw fringe polygon in x direction
- \param bot
+ \param bot coordinate of fringe bottom
\param surf surface (geosurf)
- \param row
+ \param row row along which is fringe drawn
\param side
void gsd_fringe_horiz_poly(float bot, geosurf * surf, int row, int side)
int col;
- int cnt;
float pt[4];
typbuff *buff;
long offset;
int xcnt;
+ int row_shift, max_row_shift;
+ max_row_shift = 20;
GS_set_draw(GSD_FRONT);
gsd_pushmatrix();
@@ -155,7 +157,7 @@
buff = gs_get_att_typbuff(surf, ATT_TOPO, 0);
xcnt = VCOLS(surf);
- gsd_bgnpolygon();
+ gsd_bgnqstrip();
col = 0;
/* floor left */
@@ -167,34 +169,44 @@
gsd_vert_func(pt);
offset = (row * surf->y_mod * surf->cols) + (col * surf->x_mod);
- GET_MAPATT(buff, offset, pt[Z]);
+ /* find nearest row with defined z coordinate */
+ row_shift = 0;
+ while (!GET_MAPATT(buff, offset, pt[Z]) && row_shift < max_row_shift) {
+ row_shift++;
+ if (side)
+ offset = ((row - row_shift) * surf->y_mod * surf->cols) + (col * surf->x_mod);
+ else
+ offset = ((row + row_shift) * surf->y_mod * surf->cols) + (col * surf->x_mod);
pt[Z] = pt[Z] * surf->z_exag;
gsd_vert_func(pt);
- cnt = 1;
for (col = 0; col < xcnt - 1; col++) {
- /* bottom right */
+ /* bottom vertex */
pt[X] = col * (surf->x_mod * surf->xres);
pt[Y] =
((surf->rows - 1) * surf->yres) -
((row + side) * (surf->y_mod * surf->yres));
+ pt[Z] = bot;
+ gsd_vert_func(pt);
+ /* map vertex */
+ row_shift = 0;
+ row_shift++;
+ if (side)
+ else
gsd_vert_func(pt);
- cnt++;
- col--;
- pt[X] = col * (surf->x_mod * surf->xres);
- pt[Y] =
- ((surf->rows - 1) * surf->yres) -
- ((row + side) * (surf->y_mod * surf->yres));
- pt[Z] = bot;
- gsd_vert_func(pt);
+ gsd_endqstrip();
- gsd_endpolygon();
GS_done_draw();
gsd_popmatrix();
gsd_flush();
@@ -203,21 +215,23 @@
- \brief ADD
+ \brief Draw fringe outline in x direction
- \param bot
- \param row
\param side
void gsd_fringe_horiz_line(float bot, geosurf * surf, int row, int side)
int col;
- int cnt;
float pt[4];
typbuff *buff;
long offset;
int xcnt;
gsd_pushmatrix();
@@ -239,12 +253,19 @@
pt[Z] = bot;
gsd_vert_func(pt);
+ row_shift = 0;
+ row_shift++;
+ if (side)
+ else
gsd_vert_func(pt);
- cnt = 1;
/* bottom right */
@@ -252,10 +273,16 @@
+ row_shift = 0;
+ row_shift++;
+ if (side)
+ else
gsd_vert_func(pt);
- cnt++;
col--;
@@ -284,29 +311,31 @@
- \brief ADD
+ \brief Draw fringe outline in y direction
- \param bot
- \param col
- \param side [unused]
+ \param col column along which is fringe drawn
+ \param side
void gsd_fringe_vert_poly(float bot, geosurf * surf, int col, int side)
int row;
- int cnt;
float pt[4];
typbuff *buff;
long offset;
int ycnt;
+ int col_shift, max_col_shift;
+ max_col_shift = 20;
gsd_pushmatrix();
gsd_do_scale(1);
gsd_translate(surf->x_trans, surf->y_trans, surf->z_trans);
- gsd_bgnpolygon();
+ gsd_bgnqstrip();
ycnt = VROWS(surf);
@@ -319,34 +348,43 @@
pt[Z] = bot;
gsd_vert_func(pt);
+ col_shift = 0;
+ while (!GET_MAPATT(buff, offset, pt[Z]) && col_shift < max_col_shift) {
+ col_shift++;
+ if (side)
+ offset = (row * surf->y_mod * surf->cols) + ((col - col_shift) * surf->x_mod);
+ else
+ offset = (row * surf->y_mod * surf->cols) + ((col + col_shift) * surf->x_mod);
gsd_vert_func(pt);
- cnt = 1;
for (row = 0; row < ycnt - 1; row++) {
+ /* floor */
pt[Y] =
(row * (surf->y_mod * surf->yres));
+ pt[Z] = bot;
+ /* map elevation */
+ col_shift = 0;
+ col_shift++;
+ if (side)
+ else
gsd_vert_func(pt);
- cnt++;
- row--;
- pt[Y] =
- ((surf->rows - 1) * surf->yres) - (row * (surf->y_mod * surf->yres));
- pt[Z] = bot;
+ gsd_endqstrip();
- gsd_endpolygon();
GS_done_draw();
gsd_popmatrix();
gsd_flush();
@@ -355,21 +393,23 @@
- \brief ADD
- \param bot
- \param col
+ \param side
void gsd_fringe_vert_line(float bot, geosurf * surf, int col, int side)
int row;
- int cnt;
float pt[4];
typbuff *buff;
long offset;
int ycnt;
gsd_pushmatrix();
@@ -389,12 +429,19 @@
pt[Z] = bot;
gsd_vert_func(pt);
+ col_shift = 0;
+ col_shift++;
+ if (side)
+ else
gsd_vert_func(pt);
- cnt = 1;
/* bottom right */
@@ -402,10 +449,16 @@
+ col_shift = 0;
+ col_shift++;
+ if (side)
+ else
gsd_vert_func(pt);
- cnt++;
row--;
