[GRASS-SVN] r52405 - grass-addons/grass7/gui/wxpython/wx.vnet/vnet
svn_grass at osgeo.org
Wed Jul 18 17:13:49 PDT 2012
Author: turek
Date: 2012-07-18 17:13:48 -0700 (Wed, 18 Jul 2012)
New Revision: 52405
grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py
vnet: Improved settings structure, added new settings options, improved interaction of select fields in parameters tab
Modified: grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py
--- grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py 2012-07-18 15:48:42 UTC (rev 52404)
+++ grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py 2012-07-19 00:13:48 UTC (rev 52405)
@@ -55,41 +55,13 @@
self.hiddenTypeCol = None
- #TODO if 'vnet' not in UserSettings.userSettings:
- # initializes default settings
- initSettings = [
- ['symbol', 'width', 5],
- ['symbol', 'line_color', (192,0,0)],
- ['symbol', "unused", (131,139,139)],
- ['symbol', "used1cat", (192,0,0)],
- ['symbol', "used2cat", (0,0,255)],
- ['symbol', "selected", (9,249,17)],
- ['analysisSettings', 'maxDist', 10000],
- ['analysisSettings', 'resultId', 1]
- for init in initSettings:
- UserSettings.Append(dict = UserSettings.userSettings,
- group ='vnet',
- key = init[0],
- subkey =init[1],
- value = init[2])
+ self._initSettings()
# registration graphics for drawing
self.pointsToDraw = self.mapWin.RegisterGraphicsToDraw(graphicsType = "point",
- setStatusFunc = self.SetNodeStatus)
+ setStatusFunc = self.SetPointStatus)
+ self.SetPointDrawSettings()
- self.pointsToDraw.SetPropertyVal("size", 10) # TODO settings
- for penName in ["used1cat", "used2cat", "unused", "selected"]:
- col = UserSettings.Get(group='vnet', key='symbol', subkey= penName)
- pen = self.pointsToDraw.GetPen(penName)
- if pen:
- pen.SetColour(wx.Colour(col[0], col[1], col[2], 255))
- else:
- self.pointsToDraw.AddPen(penName, wx.Pen(colour = wx.Colour(col[0], col[1], col[2], 255), width = 2))
# getting attribute table columns only with numbers (costs)
self.columnTypes = ['integer', 'double precision']
@@ -137,6 +109,9 @@
self.list.EditCellIndex(i, 1, self.cols[1][1][1 + i])
self.list.CheckItem(i, True)
+ self.list.selected = 0
+ self.list.Select(self.list.selected)
self.Bind(wx.EVT_CLOSE, self.OnCloseDialog)
dlgSize = (400, 520)
@@ -189,8 +164,7 @@
self.mainPanel.SetSizer(sizer)
- sizer.Fit(self)
+ sizer.Fit(self)
self.Layout()
def _createAnalysisPage(self):
@@ -206,7 +180,7 @@
text=_('Points'),
name = 'points')
- self.list = NodesList(parent = analysisPanel, dialog = self, cols = self.cols)
+ self.list = PtsList(parent = analysisPanel, dialog = self, cols = self.cols)
self.toolbars['pointsList'] = PointListToolbar(parent = analysisPanel, list = self.list)
anSettingsPanel = wx.Panel(parent = analysisPanel)
@@ -217,14 +191,14 @@
#lineIdPanel = wx.Panel(parent = anSettingsPanel)
#lineIdLabel = wx.StaticText(parent = lineIdPanel, id = wx.ID_ANY, label =_("Id of line:"))
#elf.anSettings["line_id"] = wx.SpinCtrl(parent = lineIdPanel, id = wx.ID_ANY, min = 1, max = maxValue)
- #resId = int(UserSettings.Get(group ='vnet', key ='analysisSettings', subkey = 'resultId'))
+ #resId = int(UserSettings.Get(group ='vnet', key ='analysis_settings', subkey = 'resultId'))
#self.anSettings["line_id"].SetValue(resId)
maxDistPanel = wx.Panel(parent = anSettingsPanel)
maxDistLabel = wx.StaticText(parent = maxDistPanel, id = wx.ID_ANY, label = _("Maximum distance of point to the network:"))
self.anSettings["max_dist"] = wx.SpinCtrl(parent = maxDistPanel, id = wx.ID_ANY, min = 0, max = maxValue) #TODO
- maxDist = int(UserSettings.Get(group = 'vnet', key = 'analysisSettings', subkey ='maxDist'))
- self.anSettings["max_dist"].SetValue(maxDist)
+ #maxDist = int(UserSettings.Get(group = 'vnet', key = 'analysis_settings', subkey ='maxDist'))
+ self.anSettings["max_dist"].SetValue(100000) #TODO init val
isoLinesPanel = wx.Panel(parent = anSettingsPanel)
isoLineslabel = wx.StaticText(parent = isoLinesPanel, id = wx.ID_ANY, label = _("Iso lines:"))
@@ -299,7 +273,7 @@
dataSelects = [
['input', "Choose vector map for analysis:", Select],
['alayer', "Arc layer number or name:", LayerSelect],
- ['nlayer', "Node direction cost column:", LayerSelect],
+ ['nlayer', "Node layer number or name:", LayerSelect],
['afcolumn', self.attrCols['afcolumn']['label'], ColumnSelect],
['abcolumn', self.attrCols['abcolumn']['label'], ColumnSelect],
['ncolumn', self.attrCols['ncolumn']['label'], ColumnSelect]
@@ -364,14 +338,35 @@
return selSizer
def OnVectSel(self, event):
+ self.inputData['alayer'].Clear()
+ self.inputData['nlayer'].Clear()
self.inputData['alayer'].InsertLayers(vector = self.inputData['input'].GetValue())
self.inputData['nlayer'].InsertLayers(vector = self.inputData['input'].GetValue())
+ items = self.inputData['alayer'].GetItems()
+ itemsLen = len(items)
+ if itemsLen < 1:
+ self.inputData['alayer'].SetValue("")
+ self.inputData['nlayer'].SetValue("")
+ for sel in ['afcolumn', 'abcolumn', 'ncolumn']:
+ self.inputData[sel].Clear()
+ self.inputData[sel].SetValue("")
+ return
+ elif itemsLen == 1:
+ self.inputData['alayer'].SetSelection(0)
+ self.inputData['nlayer'].SetSelection(0)
+ elif itemsLen >= 1:
+ if unicode("1") in items:
+ iItem = items.index(unicode("1"))
+ self.inputData['alayer'].SetSelection(iItem)
+ if unicode("2") in items:
+ iItem = items.index(unicode("2"))
+ self.inputData['nlayer'].SetSelection(iItem)
self.OnALayerSel(event)
self.OnNLayerSel(event)
def OnALayerSel(self, event):
self.inputData['afcolumn'].InsertColumns(vector = self.inputData['input'].GetValue(),
@@ -394,7 +389,7 @@
self.parent.dialogs['vnet'] = None
self.Destroy()
- def SetNodeStatus(self, item, itemIndex):
+ def SetPointStatus(self, item, itemIndex):
"""!Before point is drawn, decides properties of drawing style"""
key = self.list.GetItemData(itemIndex)
point = self.list.itemDataMap[key]
@@ -446,7 +441,7 @@
self.mapWin.UpdateMap(render=False, renderVector=False)
def OnAnalyze(self, event):
- """!Takes coordinates from map window."""
+ """!Called when network analysis is started"""
if not self.inputData["input"].GetValue().strip():
GMessage(parent = self,
@@ -482,7 +477,7 @@
- key = 'analysisSettings',
+ key = 'analysis_settings',
inpPoints = str(resId) + " " + str(cmdPts[0][0]) + " " + str(cmdPts[0][1]) + \
@@ -496,7 +491,7 @@
cmdParams.append("file=" + self.coordsTmpFile)
#dmax = int(UserSettings.Get(group = 'vnet',
- # key ='analysisSettings',
+ # key ='analysis_settings',
# subkey ='maxDist'))
cmdParams.append("dmax=" + str(self.anSettings["max_dist"].GetValue()))
@@ -505,9 +500,9 @@
cmdParams.append("--overwrite")
self._prepareCmd(cmd = cmdParams)
- self.goutput.RunCmd(command = cmdParams, onDone = self._stdinInTypeDone)
+ self.goutput.RunCmd(command = cmdParams, onDone = self._vnetPathRunAnDone)
- def _stdinInTypeDone(self, cmd, returncode):
+ def _vnetPathRunAnDone(self, cmd, returncode):
grass.try_remove(self.coordsTmpFile)
self._addTempLayer()
@@ -543,10 +538,7 @@
break
layerNum = self.inputData["nlayer"].GetValue().strip()
- if not layerNum:
- layerNum = 1 #TODO
pt_ascii, catsNums = self._getAsciiPts (catPts = catPts,
maxCat = maxCat,
layerNum = layerNum)
@@ -563,7 +555,7 @@
self.tmpMaps.append(self.tmpInPtsConnected)
cmdParams.append("input=" + self.tmpInPtsConnected)
@@ -598,21 +590,13 @@
self._prepareCmd(cmdVEdit)
self.goutput.RunCmd(command = cmdVEdit)
- alayer = self.inputData["alayer"].GetValue().strip()
- if not alayer: #TODO just temporary
- alayer = "1"
- nlayer = self.inputData["nlayer"].GetValue().strip()
- if not nlayer:
- nlayer = "1"
cmdVNet = [
"v.net",
"points=" + self.tmpInPts,
"input=" + self.inputData["input"].GetValue(),
"output=" + self.tmpInPtsConnected,
- "alayer=" + alayer,
- "nlayer=" + nlayer,
+ "alayer=" + self.inputData["alayer"].GetValue().strip(),
+ "nlayer=" + self.inputData["nlayer"].GetValue().strip(),
"operation=connect",
"thresh=" + str(self.anSettings["max_dist"].GetValue()),
"--overwrite" #TODO warning
@@ -621,9 +605,9 @@
self.goutput.RunCmd(command = cmdVNet)
self._prepareCmd(cmdParams)
- self.goutput.RunCmd(command = cmdParams, onDone = self._catsInTypeDone)
+ self.goutput.RunCmd(command = cmdParams, onDone = self.__runAnDone)
- def _catsInTypeDone(self, cmd, returncode):
+ def __runAnDone(self, cmd, returncode):
self.RemoveTmpMap(self.tmpInPts) # remove earlier (ondone lambda?)
self.RemoveTmpMap(self.tmpInPtsConnected)
@@ -647,10 +631,7 @@
inParams.append(col + '=' + self.inputData[colInptF].GetValue())
for layer in ['alayer', 'nlayer']: #TODO input
- val = self.inputData[layer].GetValue().strip()
- if not val:
- val = "1"
- inParams.append(layer + "=" + val)
+ inParams.append(layer + "=" + self.inputData[layer].GetValue().strip())
return inParams
@@ -678,11 +659,6 @@
pt_ascii = ""
catNum = maxCat
- if layerNum:
- nlayer = layerNum
- else:
- nlayer = 1 #TODO ugly hack
for catName, pts in catPts.iteritems():
catsNums[catName] = [catNum + 1]
@@ -690,7 +666,7 @@
catNum += 1
pt_ascii += "P 1 1\n"
pt_ascii += str(pt[0]) + " " + str(pt[1]) + "\n"
- pt_ascii += str(nlayer) + " " + str(catNum) + "\n"
+ pt_ascii += str(layerNum) + " " + str(catNum) + "\n"
catsNums[catName].append(catNum)
@@ -698,7 +674,6 @@
def _prepareCmd(self, cmd):
for c in cmd[:]:#TODO
if c.find("=") == -1:
continue
@@ -710,7 +685,7 @@
def _addTempLayer(self):
- cmd = self._getLayerStyle()
+ cmd = self.GetLayerStyle()
cmd.append('map=%s' % self.tmp_result)
if self.tmpResultLayer:
@@ -723,18 +698,18 @@
self.mapWin.UpdateMap(render=True, renderVector=True)
- def _getLayerStyle(self):
+ def GetLayerStyle(self):
resStyle = self.vnetParams[self.currAnModule]["resultStyle"]
- width = UserSettings.Get(group='vnet', key='symbol', subkey= "width")
+ width = UserSettings.Get(group='vnet', key='res_style', subkey= "width")
layerStyleCmd = ['d.vect',
"layer=1",'width=' + str(width)]
if "catColor" in resStyle:
layerStyleCmd.append('flags=c')
elif "singleColor" in resStyle:
- col = UserSettings.Get(group='vnet', key='symbol', subkey= "line_color")
+ col = UserSettings.Get(group='vnet', key='res_style', subkey= "line_color")
layerStyleCmd.append('color=' + str(col[0]) + ':' + str(col[1]) + ':' + str(col[2]))
if "attrColColor" in resStyle:
@@ -979,7 +954,62 @@
] # order in the choice of analysis
self.currAnModule = self.vnetModulesOrder[0]
self.prevAnModule = self.vnetModulesOrder[0]
-class NodesList(PointsList):
+ def _initSettings(self):
+ if 'vnet' in UserSettings.userSettings:
+ return
+ # initializes default settings
+ initSettings = [
+ ['res_style', 'line_width', 5],
+ ['res_style', 'line_color', (192,0,0)],
+ ['point_symbol', 'point_size', 10],
+ ['point_symbol', 'point_width', 2],
+ ['point_colors', "unused", (131,139,139)],
+ ['point_colors', "used1cat", (192,0,0)],
+ ['point_colors', "used2cat", (0,0,255)],
+ ['point_colors', "selected", (9,249,17)]
+ for init in initSettings:
+ try:
+ val = UserSettings.Get(dict = UserSettings.userSettings,
+ group ='vnet',
+ key = init[0],
+ subkey =init[1])
+ if type(val) != type(init[2]):
+ raise ValueError
+ except KeyError, ValueError:
+ UserSettings.Append(dict = UserSettings.userSettings,
+ group ='vnet',
+ key = init[0],
+ subkey =init[1],
+ value = init[2])
+ def SetPointDrawSettings(self):
+ """!Sets settings for drawing of points.
+ ptSize = int(UserSettings.Get(group='vnet', key='point_symbol', subkey = 'point_size'))
+ self.pointsToDraw.SetPropertyVal("size", ptSize)
+ colors = UserSettings.Get(group='vnet', key='point_colors')
+ ptWidth = int(UserSettings.Get(group='vnet', key='point_symbol', subkey = 'point_width'))
+ textProp = self.pointsToDraw.GetPropertyVal("text")
+ textProp["font"].SetPointSize(ptSize + 2)
+ for colKey, col in colors.iteritems():
+ pen = self.pointsToDraw.GetPen(colKey)
+ if pen:
+ pen.SetColour(wx.Colour(col[0], col[1], col[2], 255))
+ pen.SetWidth(ptWidth)
+ else:
+ self.pointsToDraw.AddPen(colKey, wx.Pen(colour = wx.Colour(col[0], col[1], col[2], 255), width = ptWidth))
+class PtsList(PointsList):
def __init__(self, parent, dialog, cols, id=wx.ID_ANY):
"""! List with points for analysis
@@ -1035,8 +1065,8 @@
return
if checkedVal == "":
- self.CheckItem(key, False)
- return
+ self.CheckItem(key, False)
+ return
if currModule == "v.net.path" and flag:
self._updateCheckedItems(index)
@@ -1069,33 +1099,39 @@
maxValue = 1e8
self.parent = parent
- #self.panel = wx.Panel(parent = self, id = wx.ID_ANY)
self.colorsSetts = {
- "line_color" : _("Line color:"),
- "unused" : _("Color for unused point:"),
- "used1cat" : _("Color for Start/From/Source/Used point:"),
- "used2cat" : _("Color for End/To/Sink point:"),
- "selected" : _("Color for selected point:")
- settsColorLabels = {}
+ "line_color" : ["res_style", _("Line color:")],
+ "unused" : ["point_colors", _("Color for unused point:")],
+ "used1cat" : ["point_colors", _("Color for Start/From/Source/Used point:")],
+ "used2cat" : ["point_colors", _("Color for End/To/Sink point:")],
+ "selected" : ["point_colors", _("Color for selected point:")]
+ settsLabels = {}
- for settKey, label in self.colorsSetts.iteritems():
- settsColorLabels[settKey] = wx.StaticText(parent = self, id = wx.ID_ANY, label = label)
- col = UserSettings.Get(group ='vnet', key = 'symbol', subkey = settKey)
+ for settKey, sett in self.colorsSetts.iteritems():
+ settsLabels[settKey] = wx.StaticText(parent = self, id = wx.ID_ANY, label = sett[1])
+ col = UserSettings.Get(group ='vnet', key = sett[0], subkey = settKey)
self.settings[settKey] = csel.ColourSelect(parent = self, id = wx.ID_ANY,
col[1],
col[2],
255))
- lineWidthLabel = wx.StaticText(parent = self, id = wx.ID_ANY, label =_("Line width:"))
- self.settings["line_width"] = wx.SpinCtrl(parent = self, id = wx.ID_ANY, min = 1, max = 10)
- width = int(UserSettings.Get(group = 'vnet', key = 'symbol', subkey = 'width'))
- self.settings["line_width"].SetValue(width)
+ self.sizeSetts = {
+ "line_width" : ["res_style", _("Line width:")],
+ "point_size" : ["point_symbol", _("Point size:")],
+ "point_width" : ["point_symbol", _("Point width:")]
+ for settKey, sett in self.sizeSetts.iteritems():
+ self.settings[settKey] = wx.SpinCtrl(parent = self, id = wx.ID_ANY, min = 1, max = 50)
+ size = int(UserSettings.Get(group = 'vnet', key = sett[0], subkey = settKey))
+ self.settings[settKey].SetValue(size)
# buttons
- #btnSave = wx.Button(self.panel, wx.ID_SAVE)
+ self.btnSave = wx.Button(self, wx.ID_SAVE)
self.btnApply = wx.Button(self, wx.ID_APPLY)
self.btnClose = wx.Button(self, wx.ID_CLOSE)
self.btnApply.SetDefault()
@@ -1103,11 +1139,13 @@
# bindings
self.btnApply.Bind(wx.EVT_BUTTON, self.OnApply)
self.btnApply.SetToolTipString(_("Apply changes for the current session"))
- #btnSave.Bind(wx.EVT_BUTTON, self.OnSave)
- #btnSave.SetToolTipString(_("Apply and save changes to user settings file (default for next sessions)"))
+ self.btnSave.Bind(wx.EVT_BUTTON, self.OnSave)
+ self.btnSave.SetToolTipString(_("Apply and save changes to user settings file (default for next sessions)"))
self.btnClose.Bind(wx.EVT_BUTTON, self.OnClose)
self.btnClose.SetToolTipString(_("Close dialog"))
+ #Layout
self.SetMinSize(self.GetBestSize())
sizer = wx.BoxSizer(wx.VERTICAL)
@@ -1117,38 +1155,45 @@
styleBoxSizer = wx.StaticBoxSizer(styleBox, wx.VERTICAL)
gridSizer = wx.GridBagSizer(vgap = 1, hgap = 1)
+ gridSizer.AddGrowableCol(1)
row = 0
- gridSizer.Add(item = settsColorLabels["line_color"], flag = wx.ALIGN_CENTER_VERTICAL, pos =(row, 0))
+ gridSizer.Add(item = settsLabels["line_color"], flag = wx.ALIGN_CENTER_VERTICAL, pos =(row, 0))
gridSizer.Add(item = self.settings["line_color"],
flag = wx.ALIGN_RIGHT | wx.ALL, border = 5,
pos =(row, 1))
row += 1
- gridSizer.Add(item = lineWidthLabel, flag=wx.ALIGN_CENTER_VERTICAL, pos=(row, 0))
+ gridSizer.Add(item = settsLabels["line_width"], flag=wx.ALIGN_CENTER_VERTICAL, pos=(row, 0))
gridSizer.Add(item = self.settings["line_width"],
pos = (row, 1))
styleBoxSizer.Add(item = gridSizer, flag = wx.EXPAND)
ptsStyleBox = wx.StaticBox(parent = self, id = wx.ID_ANY,
- label =" %s " % _("Points style:"))
+ label =" %s " % _("Point style:"))
ptsStyleBoxSizer = wx.StaticBoxSizer(ptsStyleBox, wx.VERTICAL)
- for settKey in ["used1cat", "used2cat", "selected", "unused"]:
- gridSizer.Add(item = settsColorLabels[settKey], flag = wx.ALIGN_CENTER_VERTICAL, pos =(row, 0))
+ row = 0
+ setts = dict(self.colorsSetts.items() + self.sizeSetts.items())
+ settsOrder = ["selected", "used1cat", "used2cat", "unused", "point_size", "point_width"]
+ for settKey in settsOrder:
+ sett = setts[settKey]
+ gridSizer.Add(item = settsLabels[settKey], flag = wx.ALIGN_CENTER_VERTICAL, pos =(row, 0))
gridSizer.Add(item = self.settings[settKey],
- flag = wx.ALIGN_RIGHT | wx.ALL, border = 5,
- pos =(row, 1))
- row += 1
+ flag = wx.ALIGN_RIGHT | wx.ALL, border = 5,
+ pos =(row, 1))
+ row += 1
ptsStyleBoxSizer.Add(item = gridSizer, flag = wx.EXPAND)
- # sizers
btnSizer = wx.BoxSizer(wx.HORIZONTAL)
btnSizer.Add(self.btnApply, flag = wx.LEFT | wx.RIGHT, border = 5)
- #btnSizer.Add(btnSave, flag=wx.LEFT | wx.RIGHT, border=5)
+ btnSizer.Add(self.btnSave, flag=wx.LEFT | wx.RIGHT, border=5)
btnSizer.Add(self.btnClose, flag = wx.LEFT | wx.RIGHT, border = 5)
sizer.Add(item = styleBoxSizer, flag = wx.EXPAND | wx.ALL, border = 5)
@@ -1159,39 +1204,43 @@
sizer.Fit(self)
- #def OnSave(self, event): TODO
- # """!Button 'Save' pressed"""
- # self.UpdateSettings()
- # fileSettings = {}
- # UserSettings.ReadSettingsFile(settings=fileSettings)
- # fileSettings['vnet'] = UserSettings.Get(group='vnet')
- # file = UserSettings.SaveToFile(fileSettings)
- # self.parent.parent.goutput.WriteLog(_('Vnet fron end settings saved to file \'%s\'.') % file) TODO
- # self.Close()
+ def OnSave(self, event):
+ """!Button 'Save' pressed"""
+ self.UpdateSettings()
+ fileSettings = {}
+ UserSettings.ReadSettingsFile(settings=fileSettings)
+ fileSettings['vnet'] = UserSettings.Get(group='vnet')
+ UserSettings.SaveToFile(fileSettings)
+ self.Close()
def UpdateSettings(self):
- UserSettings.Set(group ='vnet', key ='symbol', subkey ='width',
+ UserSettings.Set(group ='vnet', key = "res_style", subkey ='line_width',
value = self.settings["line_width"].GetValue())
- for settKey in self.colorsSetts.iterkeys():
- col = self.settings[settKey].GetColour()
- UserSettings.Set(group = 'vnet', key ='symbol', subkey ='color',
+ col = tuple(self.settings[settKey].GetColour())
+ UserSettings.Set(group = 'vnet',
+ key = sett[0],
+ subkey = settKey,
value = col)
- if settKey != "line_color":
- #TODO set width
- self.parent.pointsToDraw.GetPen(settKey).SetColour(colour = wx.Colour(col[0],
- col[1],
- col[2],
- 255))
+ UserSettings.Set(group = 'vnet', key = sett[0], subkey = settKey,
+ value = self.settings[settKey].GetValue())
+ self.parent.SetPointDrawSettings()
if self.parent.tmpResultLayer:
- cmd = self.parent._getLayerStyle()
+ cmd = self.parent.GetLayerStyle()
cmd.append('map=%s' % self.parent.tmp_result)
self.parent.tmpResultLayer.SetCmd(cmd)
self.parent.mapWin.UpdateMap(render=True, renderVector=True)#TODO optimization
+ else:
+ self.parent.mapWin.UpdateMap(render=False, renderVector=False)
def OnApply(self, event):
"""!Button 'Apply' pressed"""
