[GRASS-SVN] r52418 - grass-addons/grass7/gui/wxpython/wx.vnet/vnet
svn_grass at osgeo.org
Thu Jul 19 16:17:09 PDT 2012
Author: turek
Date: 2012-07-19 16:17:08 -0700 (Thu, 19 Jul 2012)
New Revision: 52418
grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py
vnet:Checks if temp layers already exists/were changed, usability improvements(parameters tab).
Modified: grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py
--- grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py 2012-07-19 16:59:36 UTC (rev 52417)
+++ grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py 2012-07-19 23:17:08 UTC (rev 52418)
@@ -1,12 +1,13 @@
- at package vnet.dialog
+ at package vnet.dialogs
@brief Dialog for vector network analysis front-end
Classes:
- - dialog::VNETDialog
- - dialog::SettingsDialog
- - dialog::AddLayerDialog
+ - dialogs::VNETDialog
+ - dialogs::PtsList
+ - dialogs::SettingsDialog
+ - dialogs::AddLayerDialog
(C) 2012 by the GRASS Development Team
@@ -18,6 +19,12 @@
import os
import sys
+try:
+ from hashlib import md5
+ hasHashlib = True
+except:
+ import md5 #Python 2.4
+ hasHashlib = False
from copy import copy
from grass.script import core as grass
@@ -51,8 +58,9 @@
self.cmdParams = {}
self.tmp_result = "vnet_tmp_result"
- self.tmpMaps = [self.tmp_result]
+ self.tmpMaps = {}
+ self.firstAnalysis = True
self.hiddenTypeCol = None
self._initSettings()
@@ -129,7 +137,7 @@
self.mapWin.UnregisterGraphicsToDraw(self.pointsToDraw)
- for tmpMap in self.tmpMaps:
+ for tmpMap in self.tmpMaps.iterkeys():
RunCommand('g.remove', vect = tmpMap)
if self.tmpResultLayer:
@@ -341,8 +349,8 @@
self.inputData['alayer'].Clear()
self.inputData['nlayer'].Clear()
- self.inputData['alayer'].InsertLayers(vector = self.inputData['input'].GetValue())
- self.inputData['nlayer'].InsertLayers(vector = self.inputData['input'].GetValue())
+ self.inputData['alayer'].InsertLayers(vector = self.inputData['input'].GetValue().strip())
+ self.inputData['nlayer'].InsertLayers(vector = self.inputData['input'].GetValue().strip())
items = self.inputData['alayer'].GetItems()
itemsLen = len(items)
@@ -443,11 +451,71 @@
def OnAnalyze(self, event):
"""!Called when network analysis is started"""
- if not self.inputData["input"].GetValue().strip():
+ # Check of parameters for analysis
+ curr_mapset = grass.gisenv()['MAPSET']
+ vectMaps = grass.list_grouped('vect')[curr_mapset]
+ selMap = self.inputData['input'].GetValue()
+ if selMap not in vectMaps:
+ self.notebook.SetSelectionByName("parameters")
+ GMessage(parent = self,
+ message = _("Please select existing vector map."))
+ return
+ errLayerLabels = []
+ for layer, layerLabel in {'alayer' : _("arc layer"),
+ 'nlayer' : _("node layer")}.iteritems():
+ layerItem = self.inputData[layer].GetItems()
+ if self.inputData[layer].GetValue().strip() not in layerItem:
+ errLayerLabels.append(layerLabel)
+ if errLayerLabels:
- message = _("Please select vector map in Data tab"))
+ message = _("Please select existing ") + _("and ").join(errLayerLabels))
return
+ errColumnLabels = []
+ for col, colData in self.attrCols.iteritems():
+ if "inputField" in self.attrCols[col]:
+ colInptF = self.attrCols[col]["inputField"]
+ else:
+ colInptF = col
+ if not self.inputData[colInptF].IsShown():
+ continue
+ colVal = self.inputData[colInptF].GetValue().strip()
+ if not colVal:
+ continue
+ if colVal not in self.inputData[colInptF].GetItems():
+ errColumnLabels.append(colData["name"])
+ if errColumnLabels:
+ errColumnLabels = map(lambda s : s + _(" column"), errColumnLabels)
+ msg = _("Please select existing or set empty: ")
+ errColsLen = len(errColumnLabels)
+ if errColsLen > 3:
+ msg += ", ".join(errColumnLabels[:(errColsLen - 2)]) + \
+ _(" and ") + errColumnLabels[errColsLen - 1]
+ else:
+ msg += _(" and ").join(errColumnLabels)
+ message = msg)
+ return
+ if self.firstAnalysis:
+ self.tmp_result = self.TmpMap(self.tmp_result)
+ if not self.tmp_result:
+ return
+ self.firstAnalysis = False
+ else:
+ if not self.VectLayerState(mapName = self.tmp_result, layer = 1):
+ return
+ # Creates part of cmd fro analysis
cmdParams = [self.currAnModule]
cmdParams.extend(self._getInputParams())
cmdParams.append("output=" + self.tmp_result)
@@ -458,7 +526,7 @@
self._vnetPathRunAn(cmdParams, catPts)
else:
self._runAn(cmdParams, catPts)
def _vnetPathRunAn(self, cmdParams, catPts):
if len(self.pointsToDraw.GetAllItems()) < 1:
@@ -505,16 +573,9 @@
def _vnetPathRunAnDone(self, cmd, returncode):
grass.try_remove(self.coordsTmpFile)
+ self.SaveVectLayerState(mapName = self.tmp_result, layer = 1)
self._addTempLayer()
- def RemoveTmpMap(self, map):
- RunCommand('g.remove', vect = map)
- try:
- self.tmpMaps.remove(map)
- except ValueError:
- pass
def _runAn(self, cmdParams, catPts):
# TODO how to get output in ondone function
@@ -529,7 +590,6 @@
flags = "g",
read = True)
cats = cats.splitlines()
for cat in cats:#TODO
cat = cat.split()
@@ -548,12 +608,13 @@
tmpPtsAsciiFileOpened.write(pt_ascii)
tmpPtsAsciiFileOpened.close()
- self.tmpInPts = "vnet_in_pts"
- self.tmpMaps.append(self.tmpInPts)
+ self.tmpInPts = self.TmpMap("vnet_tmp_in_pts")
+ if not self.tmpInPts:
+ return
- self.tmpInPtsConnected = "vnet_in_pts_connected"
- self.tmpMaps.append(self.tmpInPtsConnected)
+ self.tmpInPtsConnected = self.TmpMap("vnet_tmp_in_pts_connected")
+ if not self.tmpInPtsConnected:
+ return
#dmax = int(UserSettings.Get(group = 'vnet',
# key ='analysis_settings',
# subkey ='maxDist'))
@@ -561,12 +622,13 @@
cmdParams.append("input=" + self.tmpInPtsConnected)
cmdParams.append("--overwrite")
- self.vnetFlowTmpCut = "vnet_flow_tmp_cut"
if self.currAnModule == "v.net.distance": #TODO ugly hack
cmdParams.append("from_layer=1")
cmdParams.append("to_layer=1")
elif self.currAnModule == "v.net.flow":#TODO
- self.tmpMaps.append(self.vnetFlowTmpCut)
+ self.vnetFlowTmpCut = self.TmpMap("vnet_tmp_flow_cut")
+ if not self.vnetFlowTmpCut:
+ return
cmdParams.append("cut=" + self.vnetFlowTmpCut)
elif self.currAnModule == "v.net.iso":
@@ -612,10 +674,14 @@
self.RemoveTmpMap(self.tmpInPts) # remove earlier (ondone lambda?)
self.RemoveTmpMap(self.tmpInPtsConnected)
- self.RemoveTmpMap(self.vnetFlowTmpCut)
+ try:
+ self.RemoveTmpMap(self.vnetFlowTmpCut)
+ except AttributeError:
+ pass
grass.try_remove(self.tmpPtsAsciiFile)
def _getInputParams(self):
@@ -702,7 +768,7 @@
resStyle = self.vnetParams[self.currAnModule]["resultStyle"]
- width = UserSettings.Get(group='vnet', key='res_style', subkey= "width")
+ width = UserSettings.Get(group='vnet', key='res_style', subkey= "line_width")
layerStyleCmd = ['d.vect',
"layer=1",'width=' + str(width)]
@@ -726,6 +792,80 @@
return layerStyleCmd
+ def SaveVectLayerState(self, mapName, layer):
+ self.tmpMaps[mapName] = {"stateHash" : self.GetLayerHash(mapName = mapName,
+ layer = layer)}
+ def VectLayerState(self, mapName, layer):
+ if self.tmpMaps[mapName]["stateHash"] != self.GetLayerHash(mapName = mapName,
+ layer = layer):
+ dlg = wx.MessageDialog(parent = self,
+ message = _("Layer %d in map %s was changed outside " +
+ "of vector network analysis tool. " +
+ "Do you want to continue in analysis and " +
+ "overwrite it?") % (layer, mapName),
+ caption = _("Overwrite map layer"),
+ style = wx.YES_NO | wx.NO_DEFAULT |
+ wx.ICON_QUESTION | wx.CENTRE)
+ ret = dlg.ShowModal()
+ dlg.Destroy()
+ if ret == wx.ID_NO:
+ return False
+ return True
+ def GetLayerHash(self, mapName, layer):
+ info = RunCommand("v.info",
+ map = mapName,
+ layer = layer,
+ read = True)
+ if hasHashlib:
+ m = md5()
+ else:
+ m = md5.new()
+ m.update(info)
+ return m.digest()
+ def TmpMap(self, mapName):
+ currMapSet = grass.gisenv()['MAPSET']
+ tmpMap = grass.find_file(name = mapName, element = 'vector',
+ mapset = currMapSet)
+ fullMapName = tmpMap["fullname"]
+ if fullMapName:
+ message = _("Temporary map %s already exists." +
+ "overwrite it?") % fullMapName,
+ dlg.Destroy()
+ return None
+ else:
+ fullMapName = mapName + "@" + currMapSet
+ self.tmpMaps[fullMapName] = {"stateHash" : None}
+ return fullMapName
+ def RemoveTmpMap(self, mapName):
+ RunCommand('g.remove', vect = mapName)
+ try:
+ del self.tmpMaps[mapName]
+ except KeyError:
+ pass
def _adaptPointsList(self):
prevParamsCats = self.vnetParams[self.prevAnModule]["cmdParams"]["cats"]
@@ -841,13 +981,23 @@
"""!Initializes parameters for different v.net.* analysis """
self.attrCols = {
- 'afcolumn' : {"label" : "Arc forward/both direction(s) cost column:"},
- 'abcolumn' : {"label" : "Arc backward direction cost column:"},
+ 'afcolumn' : {
+ "label" : _("Arc forward/both direction(s) cost column:"),
+ "name" : _("arc forward/both")
+ 'abcolumn' : {
+ "label" : _("Arc backward direction cost column:"),
+ "name" : _("arc backward")
'acolumn' : {
- "label" : "Arcs' cost column (for both directions):",
- "inputField" : 'afcolumn'
+ "label" : _("Arcs' cost column (for both directions):"),
+ "name" : _("arc"),
+ "inputField" : 'afcolumn',
- 'ncolumn' : {"label" : "Node cost column:"}
+ 'ncolumn' : {
+ "label" : _("Node cost column:"),
+ "name" : _("node")
self.vnetParams = {
