[GRASS-SVN] r52431 - grass-addons/grass7/imagery/i.segment
svn_grass at osgeo.org
Fri Jul 20 15:20:28 PDT 2012
Author: momsen
Date: 2012-07-20 15:20:28 -0700 (Fri, 20 Jul 2012)
New Revision: 52431
grass-addons/grass7/imagery/i.segment/create_isegs.c
grass-addons/grass7/imagery/i.segment/iseg.h
grass-addons/grass7/imagery/i.segment/main.c
grass-addons/grass7/imagery/i.segment/open_files.c
grass-addons/grass7/imagery/i.segment/parse_args.c
grass-addons/grass7/imagery/i.segment/write_output.c
option for processing in boundary constraints is fixed, other small changes.
Modified: grass-addons/grass7/imagery/i.segment/create_isegs.c
--- grass-addons/grass7/imagery/i.segment/create_isegs.c 2012-07-20 17:53:52 UTC (rev 52430)
+++ grass-addons/grass7/imagery/i.segment/create_isegs.c 2012-07-20 22:20:28 UTC (rev 52431)
@@ -45,82 +45,67 @@
for (files->current_bound = lower_bound;
files->current_bound <= upper_bound; files->current_bound++) {
- /* check the processing window */
+ if (files->bounds_map == NULL)
+ G_message(_("Running region growing algorithm, the percent completed is based the range of values in the boundary constraints map"));
+ G_percent(files->current_bound - lower_bound,
+ upper_bound - lower_bound, 1);
+ /* *** check the processing window *** */
+ /* set boundaries at "opposite" end, change until reach lowest/highest */
+ files->minrow = files->nrows;
+ files->mincol = files->ncols;
+ files->maxrow = files->maxcol = 0;
if (files->bounds_map == NULL) {
- files->minrow = files->mincol = 0;
- files->maxrow = files->nrows;
- files->maxcol = files->ncols;
- /* todo polish: could actually check the NULL flag to see where the first/last row/col of real data are, and reduce the processing window.
- * This could help (a little?) if a MASK is used that removes a large part of the map. */
- else {
- /* todo, Markus, should there be a faster way to find this? Something already in GRASS that I can call? */
- /* find first row that matches the current bound value */
+ /* check the NULL flag to see where the first/last row/col of real data are, and reduce the processing window.
+ * This could help (a little?) if a MASK is used that removes a large border portion of the map. */
for (row = 0; row < files->nrows; row++) {
for (col = 0; col < files->ncols; col++) {
- segment_get(&files->bounds_seg, &files->bounds_val, row,
- col);
- if (files->bounds_val == files->current_bound) {
- files->minrow = row;
- /* break a nested loop... hmm, could change this to a function call, use a flag, or use peano iteration. */
- goto done1; /* or is this one of the few places where a goto loop is OK? */
- done1:
- for (col = 0; col < files->ncols; col++) {
- for (row = 0; row < files->nrows; row++) {
- col);
- files->mincol = col;
- goto done2;
+ if (!(FLAG_GET(files->null_flag, row, col))) {
+ if (files->minrow > row)
+ files->minrow = row;
+ if (files->maxrow < row)
+ files->maxrow = row;
+ if (files->mincol > col)
+ files->mincol = col;
+ if (files->maxcol < col)
+ files->maxcol = col;
- done2:
+ else {
+ for (row = 0; row < files->nrows; row++) {
+ for (col = 0; col < files->ncols; col++) {
- for (row = files->nrows - 1; row >= 0; row--) {
- for (col = files->ncols - 1; col >= 0; col--) {
col);
- files->maxrow = row;
- goto done3;
- done3:
+ if (files->bounds_val == files->current_bound &&
+ !(FLAG_GET(files->orig_null_flag, row, col))) {
+ FLAG_UNSET(files->null_flag, row, col);
- col);
- files->maxcol = col;
- goto done4;
+ else /* pixel is outside the current boundary or was null in the input bands */
+ FLAG_SET(files->null_flag, row, col);
- done4:
- G_message("minrow: %d, maxrow: %d, mincol: %d, maxcol: %d", files->minrow, files->maxrow, files->mincol, files->maxcol); //TODO change to debug.
+ G_debug(1, "minrow: %d, maxrow: %d, mincol: %d, maxcol: %d",
+ files->minrow, files->maxrow, files->mincol,
+ files->maxcol);
- /* set the in_bound_flag */
- if (!(FLAG_GET(files->null_flag, row, col))) {
- row, col);
- FLAG_SET(files->in_bounds_flag, row, col);
- else
- FLAG_UNSET(files->in_bounds_flag, row, col);
- /* clear candidate flag, so only need to reset the processing area on each iteration. */
+ /* clear candidate flag, so only need to reset the processing area on each iteration. todo polish, can be removed after all loops only cover the processing area */
flag_clear_all(files->candidate_flag);
} /* end of else, set up for bounded segmentation */
@@ -140,7 +125,20 @@
#endif
} /* end outer loop for processing polygons */
- return successflag;
+ /* reset null flag to the original if we have boundary constraints */
+ if (files->bounds_map != NULL) {
+ if (FLAG_GET(files->orig_null_flag, row, col))
+ else
+ return successflag; /* todo, successflag was assuming one pass... don't have anything to pick up a failure if there is a bounds constraint */
#ifdef DEBUG
@@ -438,49 +436,49 @@
start = clock();
for (i = 0; i < max; i++) {
no_check_tree = rbtree_create(compare_ids, sizeof(struct pixels));
/*build */
for (j = 0; j < n; j++) {
+ tree_pix = (struct pixels *)link_new(files->token);
tree_pix->row = tree_pix->col = j;
rbtree_insert(no_check_tree, &tree_pix);
/*access */
- rbtree_init_trav(&trav, no_check_tree);
- /*not sure how to do this...
- while ((data = rbtree_traverse(&trav)) != NULL) {
- if (my_compare_fn(data, threshold_data) == 0) break;
- G_message("%d", data);
+ for (j = 0; j < n; j++) {
+ if (rbtree_find(no_check_tree, &tree_pix))
+ continue; /* always looking for the same pixel...is this an easy or hard one to find? */
/*free memory */
rbtree_destroy(no_check_tree);
end = clock();
cpu_time_used = ((double)(end - start)) / CLOCKS_PER_SEC;
G_message
- ("Using rbtree of pixels (just build/destroy), %d elements, time: %g",
+ ("Using rbtree of pixels ( build/find/destroy), %d elements, time: %g",
n, cpu_time_used);
start = clock();
known_iseg_tree = rbtree_create(compare_ids, sizeof(int));
/*build */
rbtree_insert(known_iseg_tree, &j);
/*access */
- rbtree_init_trav(&trav, known_iseg_tree);
+ if (rbtree_find(known_iseg_tree, &j))
+ continue;
/*free memory */
rbtree_destroy(known_iseg_tree);
end = clock();
G_message
- ("Using rbtree ints (just build/destroy), %d elements, time: %g",
+ ("Using rbtree ints ( build/find/destroy), %d elements, time: %g",
n, cpu_time_used);
@@ -517,17 +515,18 @@
start = clock();
/*build */
/*access */
- /* while ((data = rbtree_traverse(&trav)) != NULL) {
+ continue;
/*free memory */
@@ -603,31 +602,60 @@
/* iff bounding constraints have been given, need to confirm neighbors are in the same area.
* Faster to check if the bounds map is null, or if no bounds just set all the bounds flags to 1 and directly check the bounds flag? */
+ max = INT_MAX;
+ j = 0;
+ G_message("compare if statement to FLAG_GET, repeating %d times",
+ max);
+ G_message("Flag = %d", FLAG_GET(files->candidate_flag, 1, 1));
+ start = clock();
+ for (i = 0; i < max; i++) {
+ if ((FLAG_GET(files->candidate_flag, 1, 1)) != 0) {
+ j++;
+ end = clock();
+ cpu_time_used = ((double)(end - start)) / CLOCKS_PER_SEC;
+ G_message("FLAG_GET: %g, temp: %d", cpu_time_used, j);
+ j = 0;
+ start = clock();
+ j++;
+ end = clock();
+ G_message("check for NULL: %g, temp: %d", cpu_time_used, j); /* was faster by about 20% */
+ /* is accessing a variable different then a value? */
max = INT_MAX;
- j = 0;
- G_message("compare if statement to FLAG_GET, repeating %d times", max);
- G_message("Flag = %d", FLAG_GET(files->candidate_flag, 1, 1));
+ j = k = 0;
+ G_message("compare variable to number, repeating %d times", max);
start = clock();
- if ((FLAG_GET(files->candidate_flag, 1, 1)) != 0) {
+ if (i > 0) {
j++;
end = clock();
- G_message("FLAG_GET: %g, temp: %d", cpu_time_used, j);
+ G_message("compare to zero: %g, temp: %d", cpu_time_used, j);
j = 0;
start = clock();
- if (files->bounds_map != NULL) {
+ if (i > k) {
j++;
end = clock();
- G_message("check for NULL: %g, temp: %d", cpu_time_used, j); /* was faster by about 20% */
+ G_message("compare to k: %g, temp: %d", cpu_time_used, j); /* was faster by about 20% */
return TRUE;
@@ -662,7 +690,9 @@
* Rin = Ri's neigbors
- G_message("Running region growing algorithm, the percent completed is based on %d max iterations, but the process will end earlier if no further merges can be made.", functions->end_t); /*TODO polish: can _() be combined with %d ? */
+ G_message(_("Running region growing algorithm, the percent completed is based on %d max iterations, but the process will end earlier if no further merges can be made."),
+ functions->end_t);
t = 1;
files->candidate_count = 0;
@@ -674,13 +704,11 @@
Rkn_head = NULL;
Ri_bestn = NULL;
- /* TODO, want to get a min/max row/col to narrow the processing window ??? certainly if polygon constraints. */
/* do while loop until no merges are made, or until t reaches maximum number of iterations */
do {
G_debug(3, "####### Starting outer do loop! t = %d #######", t);
- G_verbose_message("Pass %d: ", t);
+ /* todo, delete this? G_verbose_message("Pass %d: ", t); */
G_percent(t, functions->end_t, 1);
threshold = functions->threshold; /* TODO, consider making this a function of t. */
@@ -759,8 +787,7 @@
/* for each of Ri's neighbors */
for (current = Rin_head; current != NULL;
current = current->next) {
- tempsim =
- (*functions->calculate_similarity)
+ tempsim = (*functions->calculate_similarity)
(Ri_head, current, files, functions);
G_debug(4,
"simularity = %g for neighbor : row: %d, col %d.",
@@ -880,24 +907,24 @@
/* So for the next iteration, lets start with Rk as the focus segment */
/* Seems this should be a bit faster, since we already have segment membership pixels */
/* TODO: this shortened each iteration time by about 10% but increased the number of iterations by 20% ?!?!?!? */
- if(functions->path == TRUE){
- Ri_count = Rk_count;
- Rk_count = 0;
- my_dispose_list(files->token, &Ri_head);
- Ri_head = Rk_head;
- Rk_head = NULL;
- if (Rkn_head != NULL) {
- my_dispose_list(files->token, &Rin_head);
- Rin_head = Rkn_head;
- Rkn_head = NULL;
+ if (functions->path == TRUE) {
+ Ri_count = Rk_count;
+ Rk_count = 0;
+ my_dispose_list(files->token, &Ri_head);
+ Ri_head = Rk_head;
+ Rk_head = NULL;
+ if (Rkn_head != NULL) {
+ my_dispose_list(files->token, &Rin_head);
+ Rin_head = Rkn_head;
+ Rkn_head = NULL;
+ else
else
+ pathflag = FALSE;
- else
- pathflag = FALSE;
} /*end pathflag do loop */
} /*end if pixel is candidate pixel */
@@ -923,7 +950,7 @@
- if (functions->min_segment_size > 1) {
+ if (functions->min_segment_size > 1 && t > 2) { /* NOTE: added t > 2, it doesn't make sense to force merges if no merges were made on the original pass. Something should be adjusted first */
G_verbose_message
(_("Final iteration, forcing merges for small segments, percent complete based on rows."));
@@ -1036,11 +1063,14 @@
} /* end if pixel is candidate pixel */
} /* next column */
} /* next row */
+ t++; /* to count one more "iteration" */
} /* end if for force merge */
else
- G_verbose_message(_("Input for minimum pixels in a segment was 1, will not force a merge for small segments."));
+ /* todo delete? G_verbose_message(_("Input for minimum pixels in a segment was 1, will not force a merge for small segments.")); */
- G_message("temporary(?) message, number of passes: %d", t - 1);
+ if (t > 2)
+ G_verbose_message("temporary(?) message, number of passes: %d",
+ t - 1);
return TRUE;
@@ -1136,23 +1166,15 @@
for (n = 0; n < functions->num_pn; n++) {
/* skip pixel if out of computational area or null */
- if (pixel_neighbors[n][0] < 0 ||
- pixel_neighbors[n][0] >= files->nrows ||
- pixel_neighbors[n][1] < 0 ||
- pixel_neighbors[n][1] >= files->ncols ||
+ if (pixel_neighbors[n][0] < files->minrow ||
+ pixel_neighbors[n][0] >= files->maxrow ||
+ pixel_neighbors[n][1] < files->mincol ||
+ pixel_neighbors[n][1] >= files->maxcol ||
FLAG_GET(files->null_flag, pixel_neighbors[n][0],
pixel_neighbors[n][1])
continue;
- /* skip pixel if not in same boundary area */
- //~ if(files->bounds_map != NULL){
- //~ segment_get(&files->bounds_seg, &files->bounds_val, pixel_neighbors[n][0], pixel_neighbors[n][1]);
- //~ if (files->bounds_val != files->current_bound) {
- //~ continue;
tree_pix.row = pixel_neighbors[n][0];
tree_pix.col = pixel_neighbors[n][1];
G_debug(5,
@@ -1349,6 +1371,10 @@
+ /* merged two segments, decrement count */
+ files->nsegs--;
+ /* todo seeds: need if statement here, if merging "unseeded" pixel, don't want to decrement. */
return TRUE;
@@ -1438,34 +1464,34 @@
int row, col;
- if (files->bounds_map == NULL) { /* process entire raster */
- for (row = files->minrow; row < files->maxrow; row++) {
- for (col = files->mincol; col < files->maxcol; col++) {
- /* TODO: if we are starting from seeds...and only allow merges between unassigned pixels
- * and seeds/existing segments, then this needs an if (and will be very inefficient)
- * maybe consider the sorted array, btree, map... but the number of seeds could still be high for a large map */
- /* MM: could be solved/not necessary if all pixels of an existing segment have the same ID */
- FLAG_SET(files->candidate_flag, row, col);
- files->candidate_count++;
- else
- FLAG_UNSET(files->candidate_flag, row, col);
+ //~ if (files->bounds_map == NULL) { /* process entire raster */
+ for (row = files->minrow; row < files->maxrow; row++) {
+ for (col = files->mincol; col < files->maxcol; col++) {
+ /* TODO: if we are starting from seeds...and only allow merges between unassigned pixels
+ * and seeds/existing segments, then this needs an if (and will be very inefficient)
+ * maybe consider the sorted array, btree, map... but the number of seeds could still be high for a large map */
+ /* MM: could be solved/not necessary if all pixels of an existing segment have the same ID */
+ FLAG_SET(files->candidate_flag, row, col);
+ files->candidate_count++;
+ else
+ FLAG_UNSET(files->candidate_flag, row, col);
- else { /* process part of the raster, polygon constraints/boundaries */
- if (!(FLAG_GET(files->in_bounds_flag, row, col))) {
- else
+ //~ else { /* process part of the raster, polygon constraints/boundaries */
+ //~ for (row = files->minrow; row < files->maxrow; row++) {
+ //~ for (col = files->mincol; col < files->maxcol; col++) {
+ //~ if (!(FLAG_GET(files->in_bounds_flag, row, col))) {
+ //~ FLAG_SET(files->candidate_flag, row, col);
+ //~ files->candidate_count++;
+ //~ else
+ //~ FLAG_UNSET(files->candidate_flag, row, col);
return TRUE;
Modified: grass-addons/grass7/imagery/i.segment/iseg.h
--- grass-addons/grass7/imagery/i.segment/iseg.h 2012-07-20 17:53:52 UTC (rev 52430)
+++ grass-addons/grass7/imagery/i.segment/iseg.h 2012-07-20 22:20:28 UTC (rev 52431)
@@ -54,10 +54,11 @@
int minrow, maxrow, mincol, maxcol;
/* results */
- int **iseg; /*segment ID assignment. */
+ int **iseg; /* segment ID assignment */
+ int nsegs; /* number of segments */
/* processing flags */
- FLAG *candidate_flag, *null_flag, *in_bounds_flag;
+ FLAG *candidate_flag, *null_flag, *orig_null_flag;
/* memory management, linked lists */
struct link_head *token; /* for linkm.h linked list memory management. */
@@ -80,8 +81,8 @@
/* max number of iterations/passes */
int end_t;
- /* todo remove when decide on pathflag*/
+ /* todo remove when decide on pathflag */
int path;
Modified: grass-addons/grass7/imagery/i.segment/main.c
--- grass-addons/grass7/imagery/i.segment/main.c 2012-07-20 17:53:52 UTC (rev 52430)
+++ grass-addons/grass7/imagery/i.segment/main.c 2012-07-20 22:20:28 UTC (rev 52431)
@@ -55,7 +55,7 @@
G_debug(1, "Main: starting close_files()");
close_files(&files);
- G_done_msg("Number of segments created: TODO");
+ G_done_msg("Number of segments created: %d", files.nsegs);
exit(EXIT_SUCCESS);
Modified: grass-addons/grass7/imagery/i.segment/open_files.c
--- grass-addons/grass7/imagery/i.segment/open_files.c 2012-07-20 17:53:52 UTC (rev 52430)
+++ grass-addons/grass7/imagery/i.segment/open_files.c 2012-07-20 22:20:28 UTC (rev 52431)
@@ -36,13 +36,13 @@
files->null_flag = flag_create(files->nrows, files->ncols);
files->candidate_flag = flag_create(files->nrows, files->ncols);
- files->in_bounds_flag = flag_create(files->nrows, files->ncols);
+ files->orig_null_flag = flag_create(files->nrows, files->ncols);
/* references for segmentation library: i.cost r.watershed/seg and http://grass.osgeo.org/programming7/segmentlib.html */
/* ****** open the input rasters ******* */
- /* TODO: I confirmed, the API does not check this. Markus, should this be checked in parse_args / validation ? Or best to do here where I want to use the REF data? */
+ /* Note: I confirmed, the API does not check this. */
G_debug(1, "Checking image group...");
if (!I_get_group_ref(files->image_group, &Ref))
G_fatal_error(_("Unable to read REF file for group <%s>"),
@@ -161,6 +161,21 @@
+ /* keep original copy of null flag if we have boundary constraints */
+ if (FLAG_GET(files->null_flag, row, col))
+ FLAG_SET(files->orig_null_flag, row, col);
+ else /* todo polish, flags are initialized to zero... could just skip this else? */
+ FLAG_UNSET(files->orig_null_flag, row, col);
+ /* number of initial segments, will decrement when merge */
+ files->nsegs = s - 1;
/* bounds/constraints */
/* TODO: You should also handle NULL cells in the bounds
* raster map, I would suggest to replace NULL with min(bounds) - 1 or
@@ -191,6 +206,8 @@
/* other info */
files->candidate_count = 0; /* counter for remaining candidate pixels */
+ /* translate seeds to unique segments TODO MM mentioned it here... */
/* linked list memory management linkm */
link_set_chunk_size(100); /* TODO polish: fine tune this number */
Modified: grass-addons/grass7/imagery/i.segment/parse_args.c
--- grass-addons/grass7/imagery/i.segment/parse_args.c 2012-07-20 17:53:52 UTC (rev 52430)
+++ grass-addons/grass7/imagery/i.segment/parse_args.c 2012-07-20 22:20:28 UTC (rev 52431)
@@ -41,13 +41,14 @@
method->description = _("Segmentation method.");
min_segment_size = G_define_option();
- min_segment_size->key = "min"; /*TODO Markus, is there a preference for long or short key names? min is pretty generic...but short... */
+ min_segment_size->key = "minsize";
min_segment_size->type = TYPE_INTEGER;
min_segment_size->required = YES;
min_segment_size->answer = "1"; /* default: no merges, a minimum of 1 pixel is allowed in a segment. */
min_segment_size->options = "1-100000";
+ min_segment_size->label = _("Minimum number of cells in a segment.");
min_segment_size->description =
- _("Minimum number of pixels (cells) in a segment. The final merge step will ignore the threshold for any segments with fewer pixels.");
+ _("The final iteration will ignore the threshold for any segments with fewer pixels.");
/* optional parameters */
@@ -182,8 +183,8 @@
/* debug help */
- functions->path = path->answer; /* default/0 for no pathflag, but selected/1 to use Rk as next Ri if not mutually best neighbors. */
+ functions->path = path->answer; /* default/0 for no pathflag, but selected/1 to use Rk as next Ri if not mutually best neighbors. */
if (outband->answer == NULL)
files->out_band = NULL;
else {
Modified: grass-addons/grass7/imagery/i.segment/write_output.c
--- grass-addons/grass7/imagery/i.segment/write_output.c 2012-07-20 17:53:52 UTC (rev 52430)
+++ grass-addons/grass7/imagery/i.segment/write_output.c 2012-07-20 22:20:28 UTC (rev 52431)
@@ -54,6 +54,7 @@
* current: | Data Description: |
* | generated by i.segment |
* It would be nice to save the segmentation settings (just the CL? Or something more human readable?)
+ * * MM: see e.g. i.pca for an example of setting custom info
/* close and save file */
@@ -64,7 +65,7 @@
/* set colors */
Rast_init_colors(&colors);
Rast_make_random_colors(&colors, 1, files->nrows * files->ncols); /* TODO polish - number segments from 1 - max ? and then can use that max here. */
- Rast_write_colors(files->out_name, G_mapset(), &colors); /* TODO, OK to just use G_mapset() here, seems I don't use it anywhere else, and that is where the output has to be written. (Markus, should the library allow changing colors to other mapsets? I was suprised it was needed as a parameter.) */
+ Rast_write_colors(files->out_name, G_mapset(), &colors);
/* free memory */
G_free(outbuf);
