[GRASS-SVN] r52437 - grass-addons/grass7/gui/wxpython/wx.vnet/vnet
svn_grass at osgeo.org
Mon Jul 23 14:34:22 PDT 2012
Author: turek
Date: 2012-07-23 14:34:21 -0700 (Mon, 23 Jul 2012)
New Revision: 52437
grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py
grass-addons/grass7/gui/wxpython/wx.vnet/vnet/widgets.py
vnet: Bugs fixing, few comments added, button for adding vector map into layer tree
Modified: grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py
--- grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py 2012-07-23 11:56:06 UTC (rev 52436)
+++ grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py 2012-07-23 21:34:21 UTC (rev 52437)
@@ -45,8 +45,9 @@
from vnet.widgets import PointsList
from vnet.toolbars import MainToolbar, PointListToolbar
-#TODOs:
-# itemdada mam - not direct access
+#TODOs
+# when layer tree is lmgr is changed, tmp layer is removed from render list
+# check if has layertree (lmgr)?
class VNETDialog(wx.Dialog):
def __init__(self, parent,
@@ -61,7 +62,8 @@
self.inputData = {}
self.cmdParams = {}
- self.tmp_result = "vnet_tmp_result"
+ self.tmp_result = None
+ self.vnetFlowTmpCut = None
self.tmpMaps = VnetTmpVectMaps(parent = self)
self.firstAnalysis = True
@@ -80,7 +82,7 @@
self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass_map.ico'), wx.BITMAP_TYPE_ICO))
# initialization of v.net.* analysis parameters
- self._initvnetParams()
+ self._initVnetParams()
# toobars
self.toolbars = {}
@@ -101,9 +103,9 @@
style = FN.FNB_FANCY_TABS | FN.FNB_BOTTOM |
FN.FNB_NO_NAV_BUTTONS | FN.FNB_NO_X_BUTTON)
- self._createAnalysisPage()
- self._createDataPage()
+ # Creates tabs
+ self._createPointsPage()
+ self._createParametersPage()
self._createOutputPage()
self._addPanes()
@@ -114,13 +116,13 @@
self.handlerRegistered = False
self.tmpResultLayer = None
# adds 2 points into list
for i in range(2):
self.list.AddItem(None)
self.list.EditCellIndex(i, 1, self.cols[1][1][1 + i])
self.list.CheckItem(i, True)
+ # selects first point
self.list.selected = 0
self.list.Select(self.list.selected)
@@ -135,9 +137,10 @@
self.goutput.SetSashPosition(int(self.GetSize()[1] * .75))
self.OnAnalysisChanged(None)
+ self.notebook.SetSelectionByName("parameters")
def __del__(self):
- """!Removes temp layer with analysis result, unregisters handlers and graphics"""
+ """!Removes temp layers, unregisters handlers and graphics"""
update = self.tmpMaps.RemoveAllTmpMaps()
@@ -153,6 +156,7 @@
def _addPanes(self):
+ """!Adds toolbar pane and pane with tabs"""
self._mgr.AddPane(self.toolbars['mainToolbar'],
wx.aui.AuiPaneInfo().
@@ -180,23 +184,24 @@
sizer.Fit(self)
self.Layout()
- def _createAnalysisPage(self):
+ def _createPointsPage(self):
+ """!Tab with points list and analysis settings"""
- analysisPanel = wx.Panel(parent = self)
+ pointsPanel = wx.Panel(parent = self)
self.anSettings = {} #TODO
maxValue = 1e8
- listBox = wx.StaticBox(parent = analysisPanel, id = wx.ID_ANY,
+ listBox = wx.StaticBox(parent = pointsPanel, id = wx.ID_ANY,
label =" %s " % _("Points for analysis:"))
- self.notebook.AddPage(page = analysisPanel,
+ self.notebook.AddPage(page = pointsPanel,
text=_('Points'),
name = 'points')
- self.list = PtsList(parent = analysisPanel, dialog = self, cols = self.cols)
- self.toolbars['pointsList'] = PointListToolbar(parent = analysisPanel, list = self.list)
+ self.list = PtsList(parent = pointsPanel, dialog = self, cols = self.cols)
+ self.toolbars['pointsList'] = PointListToolbar(parent = pointsPanel, list = self.list)
- anSettingsPanel = wx.Panel(parent = analysisPanel)
+ anSettingsPanel = wx.Panel(parent = pointsPanel)
anSettingsBox = wx.StaticBox(parent = anSettingsPanel, id = wx.ID_ANY,
label =" %s " % _("Analysis settings:"))
@@ -213,11 +218,17 @@
#maxDist = int(UserSettings.Get(group = 'vnet', key = 'analysis_settings', subkey ='maxDist'))
self.anSettings["max_dist"].SetValue(100000) #TODO init val
+ #showCutPanel = wx.Panel(parent = anSettingsPanel)
+ #self.anSettings["show_cut"] = wx.CheckBox(parent = showCutPanel, id=wx.ID_ANY,
+ # label = _("Show minimal cut"))
+ #self.anSettings["show_cut"].Bind(wx.EVT_CHECKBOX, self.OnShowCut)
isoLinesPanel = wx.Panel(parent = anSettingsPanel)
isoLineslabel = wx.StaticText(parent = isoLinesPanel, id = wx.ID_ANY, label = _("Iso lines:"))
self.anSettings["iso_lines"] = wx.TextCtrl(parent = isoLinesPanel, id = wx.ID_ANY) #TODO
self.anSettings["iso_lines"].SetValue("1000,2000,3000")
+ # Layout
AnalysisSizer = wx.BoxSizer(wx.VERTICAL)
listSizer = wx.StaticBoxSizer(listBox, wx.VERTICAL)
@@ -241,8 +252,14 @@
maxDistPanel.SetSizer(maxDistSizer)
anSettingsSizer.Add(item = maxDistPanel, proportion = 1, flag = wx.EXPAND)
+ #showCutSizer = wx.BoxSizer(wx.HORIZONTAL)
+ #showCutPanel.SetSizer(showCutSizer)
+ #showCutSizer.Add(item = self.anSettings["show_cut"],
+ # flag = wx.EXPAND | wx.ALL, border = 5, proportion = 0)
+ #anSettingsSizer.Add(item = showCutPanel, proportion = 1, flag = wx.EXPAND)
isoLinesSizer = wx.BoxSizer(wx.HORIZONTAL)
- isoLinesSizer.Add(item = isoLineslabel, flag = wx.EXPAND, proportion = 0)
+ isoLinesSizer.Add(item = isoLineslabel, flag = wx.ALIGN_CENTER_VERTICAL, proportion = 1)
isoLinesSizer.Add(item = self.anSettings["iso_lines"],
flag = wx.EXPAND | wx.ALL, border = 5, proportion = 1)
isoLinesPanel.SetSizer(isoLinesSizer)
@@ -252,10 +269,22 @@
AnalysisSizer.Add(item = anSettingsPanel, proportion = 0, flag = wx.EXPAND | wx.RIGHT | wx.LEFT | wx.BOTTOM, border = 5)
anSettingsPanel.SetSizer(anSettingsSizer)
- analysisPanel.SetSizer(AnalysisSizer)
+ pointsPanel.SetSizer(AnalysisSizer)
+ def OnShowCut(self, event):
+ """!Shows vector map with minimal cut (v.net.flow) - not yet implemented"""
+ val = event.IsChecked()
+ if val:
+ self.tmp_result.DeleteRenderLayer()
+ self.vnetFlowTmpCut.AddRenderLayer()
+ else:
+ self.vnetFlowTmpCut.DeleteRenderLayer()
+ self.tmp_result.AddRenderLayer()
+ self.mapWin.UpdateMap(render = True, renderVector = True)
def _createOutputPage(self):
+ """!Tab with output console"""
outputPanel = wx.Panel(parent = self)
self.notebook.AddPage(page = outputPanel,
text = _("Output"),
@@ -276,8 +305,8 @@
outputPanel.SetSizer(self.outputSizer)
- def _createDataPage(self):
+ def _createParametersPage(self):
dataPanel = wx.Panel(parent=self)
self.notebook.AddPage(page = dataPanel,
text=_('Parameters'),
@@ -299,6 +328,15 @@
self.inputData[dataSel[0]] = dataSel[2](parent = selPanels[dataSel[0]],
size = (-1, -1),
type = 'vector')
+ icon = wx.Image(os.path.join(globalvar.ETCICONDIR, "grass", "layer-vector-add.png"))
+ icon.Rescale(18, 18)
+ icon = wx.BitmapFromImage(icon)
+ self.addToTreeBtn = wx.BitmapButton(parent = selPanels[dataSel[0]],
+ bitmap = icon,
+ size = globalvar.DIALOG_COLOR_SIZE)
+ self.addToTreeBtn.SetToolTipString(_("Add vector map into layer tree"))
+ self.addToTreeBtn.Disable()
else:
size = (-1, -1))
@@ -309,17 +347,23 @@
self.inputData['input'].Bind(wx.EVT_TEXT, self.OnVectSel) # TODO optimization
self.inputData['alayer'].Bind(wx.EVT_TEXT, self.OnALayerSel)
self.inputData['nlayer'].Bind(wx.EVT_TEXT, self.OnNLayerSel)
+ self.addToTreeBtn .Bind(wx.EVT_BUTTON, self.OnToTreeBtn)
+ # Layout
mainSizer = wx.BoxSizer(wx.VERTICAL)
- box = wx.StaticBox(dataPanel, -1, "Layer for analysis")
+ box = wx.StaticBox(dataPanel, -1, "Vector map and layers for analysis")
bsizer = wx.StaticBoxSizer(box, wx.VERTICAL)
mainSizer.Add(item = bsizer, proportion = 0,
- flag = wx.EXPAND | wx.TOP | wx.LEFT | wx.RIGHT, border = 5)
+ flag = wx.EXPAND | wx.TOP | wx.LEFT | wx.RIGHT, border = 5)
for sel in ['input', 'alayer', 'nlayer']:
- selPanels[sel].SetSizer(self._doSelLayout(title = label[sel], sel = self.inputData[sel]))
- bsizer.Add(item = selPanels[sel], proportion = 0,
+ if sel== 'input':
+ btn = self.addToTreeBtn
+ selPanels[sel].SetSizer(self._doSelLayout(title = label[sel],
+ sel = self.inputData[sel],
+ btn = btn))
+ bsizer.Add(item = selPanels[sel], proportion = 1,
flag = wx.EXPAND)
box = wx.StaticBox(dataPanel, -1, "Costs")
@@ -335,7 +379,7 @@
dataPanel.SetSizer(mainSizer)
- def _doSelLayout(self, title, sel):
+ def _doSelLayout(self, title, sel, btn = None):
selSizer = wx.BoxSizer(orient = wx.VERTICAL)
@@ -345,12 +389,44 @@
selSizer.Add(item = selTitleSizer, proportion = 0,
flag = wx.EXPAND)
- selSizer.Add(item = sel, proportion = 0,
- flag = wx.EXPAND | wx.ALL| wx.ALIGN_CENTER_VERTICAL,
- border = 5)
+ if btn:
+ selFiledSizer = wx.BoxSizer(orient = wx.HORIZONTAL)
+ selFiledSizer.Add(item = sel, proportion = 1,
+ flag = wx.EXPAND | wx.ALL)
+ selFiledSizer.Add(item = btn, proportion = 0,
+ selSizer.Add(item = selFiledSizer, proportion = 0,
+ flag = wx.EXPAND | wx.ALL| wx.ALIGN_CENTER_VERTICAL,
+ border = 5)
+ else:
+ selSizer.Add(item = sel, proportion = 1,
+ border = 5)
return selSizer
+ def OnToTreeBtn(self, event):
+ """!Adds vector map into layer tree (button next to map select)"""
+ vectorMap = self.inputData['input'].GetValue()
+ existsMap = grass.find_file(name = vectorMap,
+ element = 'vector',
+ mapset = grass.gisenv()['MAPSET'])
+ if not existsMap["name"]:
+ return
+ cmd = ['d.vect',
+ 'map=' + vectorMap]
+ if self.mapWin.tree.FindItemByData(key = 'name', value = vectorMap) is None:
+ self.mapWin.tree.AddLayer(ltype = "vector",
+ lcmd = cmd,
+ lname =vectorMap,
+ lchecked = True)
def OnVectSel(self, event):
+ """!When vector map is selected populates other selects (layer selects, columns selects)"""
self.inputData['alayer'].Clear()
self.inputData['nlayer'].Clear()
@@ -360,6 +436,7 @@
items = self.inputData['alayer'].GetItems()
itemsLen = len(items)
if itemsLen < 1:
self.inputData['alayer'].SetValue("")
self.inputData['nlayer'].SetValue("")
for sel in ['afcolumn', 'abcolumn', 'ncolumn']:
@@ -377,11 +454,13 @@
iItem = items.index(unicode("2"))
self.inputData['nlayer'].SetSelection(iItem)
+ self.addToTreeBtn.Enable()
self.OnALayerSel(event)
self.OnNLayerSel(event)
def OnALayerSel(self, event):
+ """!When arc layer from vector map is selected, populates corespondent columns selects"""
self.inputData['afcolumn'].InsertColumns(vector = self.inputData['input'].GetValue(),
layer = self.inputData['alayer'].GetValue(),
type = self.columnTypes)
@@ -391,14 +470,13 @@
def OnNLayerSel(self, event):
+ """!When node layer from vector map is selected, populates corespondent column select"""
self.inputData['ncolumn'].InsertColumns(vector = self.inputData['input'].GetValue(),
layer = self.inputData['nlayer'].GetValue(),
def OnCloseDialog(self, event):
"""!Cancel dialog"""
self.parent.dialogs['vnet'] = None
self.Destroy()
@@ -427,7 +505,6 @@
def OnMapClickHandler(self, event):
"""!Takes coordinates from map window."""
if event == 'unregistered':
ptListToolbar = self.toolbars['pointsList']
if ptListToolbar:
@@ -457,7 +534,6 @@
def OnAnalyze(self, event):
"""!Called when network analysis is started"""
# Check of parameters for analysis
curr_mapset = grass.gisenv()['MAPSET']
vectMaps = grass.list_grouped('vect')[curr_mapset]
@@ -514,7 +590,7 @@
return
if self.firstAnalysis:
- self.tmp_result = self.tmpMaps.AddTmpVectMap(self.tmp_result)
+ self.tmp_result = self.tmpMaps.AddTmpVectMap("vnet_tmp_result")
if not self.tmp_result:
return
self.firstAnalysis = False
@@ -529,13 +605,15 @@
catPts = self._getPtByCat()
+ self.tmpMaps.RemoveTmpMap(self.tmp_result)
if self.currAnModule == "v.net.path":
self._vnetPathRunAn(cmdParams, catPts)
else:
self._runAn(cmdParams, catPts)
def _vnetPathRunAn(self, cmdParams, catPts):
+ """!Called when analysis is run for v.net.path module"""
if len(self.pointsToDraw.GetAllItems()) < 1:
return
@@ -578,8 +656,7 @@
self.goutput.RunCmd(command = cmdParams, onDone = self._vnetPathRunAnDone)
def _vnetPathRunAnDone(self, cmd, returncode):
+ """!Called when v.net.path analysis is done"""
grass.try_remove(self.coordsTmpFile)
self.tmp_result.SaveVectLayerState(layer = 1)
@@ -587,7 +664,7 @@
self.mapWin.UpdateMap(render=True, renderVector=True)
def _runAn(self, cmdParams, catPts):
+ """!Called for all v.net.* analysis (except v.net.path)"""
# TODO how to get output in ondone function
#cmdCategory = [ "v.category",
# "input=" + self.inputData['input'].GetValue(),
@@ -678,13 +755,9 @@
self.goutput.RunCmd(command = cmdParams, onDone = self._runAnDone)
def _runAnDone(self, cmd, returncode):
+ """!Called when analysis is done"""
self.tmpMaps.RemoveTmpMap(self.tmpInPts) # remove earlier (ondone lambda?)
self.tmpMaps.RemoveTmpMap(self.tmpInPtsConnected)
- try:
- self.tmpMaps.RemoveTmpMap(self.vnetFlowTmpCut)
- except AttributeError:
- pass
grass.try_remove(self.tmpPtsAsciiFile)
@@ -692,7 +765,6 @@
def _getInputParams(self):
inParams = []
for col in self.vnetParams[self.currAnModule]["cmdParams"]["cols"]:
@@ -709,7 +781,7 @@
return inParams
def _getPtByCat(self):
+ """!Returns points separated by theirs categories"""
cats = self.vnetParams[self.currAnModule]["cmdParams"]["cats"]
ptByCats = {}
@@ -727,7 +799,7 @@
return ptByCats
def _getAsciiPts (self, catPts, maxCat, layerNum):
+ """!Returns points separated by categories in GRASS ASCII vector representation"""
catsNums = {}
pt_ascii = ""
catNum = maxCat
@@ -746,7 +818,7 @@
return pt_ascii, catsNums
def _prepareCmd(self, cmd):
+ """!Helper function for preparation of cmd in list into form for RunCmd method"""
for c in cmd[:]:
if c.find("=") == -1:
continue
@@ -757,7 +829,7 @@
cmd.remove(c)
def GetLayerStyle(self):
+ """!Returns cmd for d.vect, with set style for analysis result"""
resStyle = self.vnetParams[self.currAnModule]["resultStyle"]
width = UserSettings.Get(group='vnet', key='res_style', subkey= "line_width")
@@ -785,6 +857,7 @@
return layerStyleCmd
def OnShowResult(self, event):
+ """!Shows, hides analysis result - not yet implemented"""
mainToolbar = self.toolbars['mainToolbar']
id = vars(mainToolbar)['showResult']
toggleState = mainToolbar.GetToolState(id)
@@ -797,6 +870,7 @@
def OnInsertPoint(self, event):
+ """!Registers/unregisters mouse handler into map window"""
if self.handlerRegistered == False:
self.mapWin.RegisterMouseEventHandler(wx.EVT_LEFT_DOWN,
self.OnMapClickHandler,
@@ -808,28 +882,51 @@
def OnSaveTmpLayer(self, event):
+ """!Permanently saves temporary map of analysis result"""
dlg = AddLayerDialog(parent = self)#TODO impot location check?
+ msg = _("Vector map with analysis result does not exist.")
if dlg.ShowModal() == wx.ID_OK:
- addedMap = dlg.vectSel.GetValue()
- existsMap = grass.find_file(name = addedMap,
+ if not hasattr(self.tmp_result, "GetVectMapName"):
+ GMessage(parent = self,
+ message = msg)
+ return
+ mapToAdd = self.tmp_result.GetVectMapName()
+ mapToAddEx = grass.find_file(name = mapToAdd,
element = 'vector',
- if existsMap["name"] and not dlg.overwrite.GetValue():
+ if not mapToAddEx["name"]:
- message = _("Map already exists. Result will not be added."))
+ message = msg)
return
+ addedMap = dlg.vectSel.GetValue()
+ existsMap = grass.find_file(name = addedMap,
+ if existsMap["name"]:
+ dlg = wx.MessageDialog(parent = self.parent.parent,
+ message = _("Vector map %s already exists. " +
+ "Do you want to overwrite it?") %
+ (existsMap["fullname"]),
+ caption = _("Overwrite map layer"),
+ style = wx.YES_NO | wx.NO_DEFAULT |
+ wx.ICON_QUESTION | wx.CENTRE)
+ ret = dlg.ShowModal()
+ if ret == wx.ID_NO:
+ return
RunCommand("g.copy",
overwrite = True,
vect = [self.tmp_result.GetVectMapName(), addedMap])
cmd = self.GetLayerStyle()
cmd.append('map=%s' % addedMap)
- if self.mapWin.tree.FindItemByData(key = 'name', value = addedMap) is None: #TODO check if has tree
+ if self.mapWin.tree.FindItemByData(key = 'name', value = addedMap) is None:
lname =addedMap,
lcmd = cmd,
@@ -848,7 +945,7 @@
dlg.Destroy()
def OnAnalysisChanged(self, event):
+ """!Updates dialog when analysis is changed"""
# finds module name according to value in anChoice
for module, params in self.vnetParams.iteritems():
chLabel = self.toolbars['mainToolbar'].anChoice.GetValue()
@@ -867,6 +964,12 @@
else:
self.anSettings['iso_lines'].GetParent().Hide()
+ #if self.currAnModule == "v.net.flow":
+ # self.anSettings['show_cut'].GetParent().Show()
+ #else:
+ # self.anSettings['show_cut'].GetParent().Hide()
+ # Show only corresponding selects for chosen v.net module
skip = []
for col in self.attrCols.iterkeys():
if "inputField" in self.attrCols[col]:
@@ -888,6 +991,7 @@
self.inputData[colInptF].GetParent().Hide()
self.Layout()
+ # If module has only one category -> hide type column in points list otherwise show it
if len(self.vnetParams[self.currAnModule]["cmdParams"]["cats"]) > 1:
if self.hiddenTypeCol:
self.list.InsertColumnItem(1, self.hiddenTypeCol)
@@ -907,8 +1011,8 @@
self.list.ResizeColumns()
- def _initvnetParams(self):
- """!Initializes parameters for different v.net.* analysis """
+ def _initVnetParams(self):
+ """!Initializes parameters for different v.net.* modules """
self.attrCols = {
'afcolumn' : {
@@ -1036,7 +1140,7 @@
self.prev2catsAnModule = self.vnetModulesOrder[0]
def _initSettings(self):
+ """!Initialization of settings (if not already defined)"""
if 'vnet' in UserSettings.userSettings:
return
@@ -1107,7 +1211,7 @@
self.dialog.pointsToDraw.AddItem(coords = [0,0],
label = str(self.selectedkey + 1))
- self.dialog.mapWin.UpdateMap(render=True, renderVector=True)
+ self.dialog.mapWin.UpdateMap(render=False, renderVector=False)
def DeleteItem(self, event):
@@ -1132,7 +1236,7 @@
event.Skip()
def _adaptPointsList(self, currParamsCats, prevParamsCats):
+ """Rename category values fwhen module is changed. Expample: Start point -> Sink point"""
for item in enumerate(self.itemDataMap):
iCat = 0
for ptCat in prevParamsCats:
@@ -1157,6 +1261,8 @@
currModule = self.dialog.currAnModule #TODO public func
cats = self.dialog.vnetParams[currModule]["cmdParams"]["cats"]
if len(cats) <= 1:
return
@@ -1168,7 +1274,7 @@
self._updateCheckedItems(index)
def _updateCheckedItems(self, index):
- """!for v.net.path - max. just one checked start point and end point """
+ """!For v.net.path - max. just one checked start point and end point """
alreadyChecked = []
if index:
checkedKey = self.GetItemData(index)
@@ -1302,7 +1408,6 @@
def OnSave(self, event):
"""!Button 'Save' pressed"""
self.UpdateSettings()
fileSettings = {}
@@ -1330,8 +1435,9 @@
self.parent.SetPointDrawSettings()
- renderLayer = self.parent.tmp_result.GetRenderLayer()
- if renderLayer:
+ if not hasattr(self.parent.tmp_result, "GetRenderLayer"):
+ self.parent.mapWin.UpdateMap(render=False, renderVector=False)
+ elif self.parent.tmp_result.GetRenderLayer():
self.parent.tmp_result.AddRenderLayer()
self.parent.mapWin.UpdateMap(render=True, renderVector=True)#TODO optimization
else:
@@ -1347,12 +1453,9 @@
self.Close()
class AddLayerDialog(wx.Dialog):
- """!Adds layer with analysis result into layer tree"""
def __init__(self, parent,id=wx.ID_ANY,
title =_("Add analysis result into layer tree"), style=wx.DEFAULT_DIALOG_STYLE):
- """!Dialog for editing item cells in list"""
+ """!Adds vector map with analysis result into layer tree"""
wx.Dialog.__init__(self, parent, id, title = _(title), style = style)
self.panel = wx.Panel(parent = self)
@@ -1362,14 +1465,12 @@
self.vectSellabel = wx.StaticText(parent = self.panel, id = wx.ID_ANY,
label = _("Layer name:"))
- self.overwrite = wx.CheckBox(parent = self.panel, id=wx.ID_ANY,
- label = _("Overwrite existing layer"))
# buttons
self.btnCancel = wx.Button(self.panel, wx.ID_CANCEL)
self.btnOk = wx.Button(self.panel, wx.ID_OK)
self.btnOk.SetDefault()
+ self.SetInitialSize((400, -1))
self._layout()
def _layout(self):
@@ -1379,28 +1480,18 @@
box = wx.StaticBox (parent = self.panel, id = wx.ID_ANY,
label = "Added layer")
- boxSizer = wx.StaticBoxSizer(box, wx.VERTICAL)
+ boxSizer = wx.StaticBoxSizer(box, wx.HORIZONTAL)
- # source coordinates
- gridSizer = wx.GridBagSizer(vgap = 5, hgap = 5)
+ boxSizer.Add(item = self.vectSellabel,
+ flag = wx.ALIGN_CENTER_VERTICAL,
+ proportion = 0)
- row = 0
- gridSizer.Add(item = self.vectSellabel,
- flag = wx.ALIGN_CENTER_VERTICAL,
- pos = (row, 0))
- gridSizer.Add(item = self.vectSel,
- pos = (row, 1))
- boxSizer.Add(item = gridSizer, proportion = 1,
+ boxSizer.Add(item = self.vectSel, proportion = 1,
flag = wx.EXPAND | wx.ALL, border = 5)
sizer.Add(item = boxSizer, proportion = 1,
- row +=1
- gridSizer.Add(item = self.overwrite, pos =(row, 0))
btnSizer = wx.StdDialogButtonSizer()
btnSizer.AddButton(self.btnCancel)
btnSizer.AddButton(self.btnOk)
@@ -1414,7 +1505,7 @@
class VnetTmpVectMaps:
def __init__(self, parent):
+ """!Class which creates, stores and destroys all tmp maps created during analysis"""
self.tmpMaps = []
self.parent = parent
self.mapWin = self.parent.mapWin
@@ -1470,9 +1561,8 @@
return update
class VnetTmpVectMap:
def __init__(self, parent, fullName):
+ """!Represents one temporary map"""
self.fullName = fullName
self.renderLayer = None
@@ -1501,7 +1591,7 @@
self.renderLayer = self.parent.mapWin.Map.AddLayer(type = "vector", command = cmd,
l_active=True, name = self.fullName,
l_hidden = True, l_opacity = 1.0,
- l_render = True, pos = -1)
+ l_render = False, pos = -1)
return True
def DeleteRenderLayer(self):
Modified: grass-addons/grass7/gui/wxpython/wx.vnet/vnet/widgets.py
--- grass-addons/grass7/gui/wxpython/wx.vnet/vnet/widgets.py 2012-07-23 11:56:06 UTC (rev 52436)
+++ grass-addons/grass7/gui/wxpython/wx.vnet/vnet/widgets.py 2012-07-23 21:34:21 UTC (rev 52437)
@@ -36,7 +36,8 @@
wx.LC_SINGLE_SEL):
"""!Creates list for points.
- PointsList class was extracted from GCPList class in GCP manager.
+ PointsList class was extracted from GCPList class in GCP manager. It is possible
+ to be shared by GCP and VNET front end.
Important parameters:
@param cols is list containing list items. which represents columns.
