[GRASS-SVN] r52446 - grass-addons/grass7/vector/v.unpack
svn_grass at osgeo.org
Wed Jul 25 01:45:51 PDT 2012
Author: lucadelu
Date: 2012-07-25 01:45:51 -0700 (Wed, 25 Jul 2012)
New Revision: 52446
grass-addons/grass7/vector/v.unpack/v.unpack.py
fix some problems with overwrite existing vector
Modified: grass-addons/grass7/vector/v.unpack/v.unpack.py
--- grass-addons/grass7/vector/v.unpack/v.unpack.py 2012-07-24 19:44:19 UTC (rev 52445)
+++ grass-addons/grass7/vector/v.unpack/v.unpack.py 2012-07-25 08:45:51 UTC (rev 52446)
@@ -81,7 +81,7 @@
gisenv['LOCATION_NAME'],
gisenv['MAPSET'])
- new_dir = os.path.join(mset_dir,'vector',data_name)
+ new_dir = os.path.join(mset_dir,'vector',map_name)
gfile = grass.find_file(name = map_name, element = 'vector',
mapset = '.')
@@ -121,26 +121,27 @@
list_fromtable = grass.read_command('db.tables',driver='sqlite',database=fromdb)
list_fromtable = list_fromtable.split('\n')
#return the list of old connection for extract layer number and key
- dbln = open(os.path.join(data_name,'dbln'),'r')
+ dbln = open(os.path.join(new_dir,'dbln'),'r')
dbnlist = dbln.readlines()
dbln.close()
- #for each old connection
- for t in dbnlist:
- #it split the line of each connection, to found layer number and key
- if len(t.split('|')) != 1:
- values = t.split('|')
- else:
- values = t.split(' ')
- #copy the table in the default database
- cptable = grass.run_command('db.copy', to_driver = dbconn['driver'],
- to_database = todb, to_table = values[1],
+ #for each old connection
+ for t in dbnlist:
+ #it split the line of each connection, to found layer number and key
+ if len(t.split('|')) != 1:
+ values = t.split('|')
+ else:
+ values = t.split(' ')
+ #copy the table in the default database
+ print "prima di db.copy"
+ grass.run_command('db.copy', to_driver = dbconn['driver'],
+ to_database = todb, to_table = map_name,
from_driver = 'sqlite', from_database = fromdb,
from_table = values[1])
- #and connect the new tables with the rigth layer
- contable = grass.run_command('v.db.connect', flags = "o",
+ #and connect the new tables with the rigth layer
+ grass.run_command('v.db.connect', flags = "o",
driver = dbconn['driver'], database = todb,
map = map_name, key = values[2],
- layer = values[0].split('/')[0], table = values[1])
+ layer = values[0].split('/')[0], table = map_name)
#remove
os.remove(os.path.join(new_dir,'PROJ_INFO'))
