[GRASS-SVN] r52454 - grass-addons/grass7/gui/wxpython/wx.vnet/vnet
svn_grass at osgeo.org
Thu Jul 26 16:39:43 PDT 2012
Author: turek
Date: 2012-07-26 16:39:43 -0700 (Thu, 26 Jul 2012)
New Revision: 52454
grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py
grass-addons/grass7/gui/wxpython/wx.vnet/vnet/toolbars.py
vnet: Snapping implemented
Modified: grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py
--- grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py 2012-07-26 12:36:38 UTC (rev 52453)
+++ grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py 2012-07-26 23:39:43 UTC (rev 52454)
@@ -20,12 +20,19 @@
import os
import sys
+import Queue
try:
+ import grass.lib.vector as vectlib
+ from ctypes import pointer, byref, c_char_p, c_int, c_double
+ haveCtypes = True
+except ImportError:
+ haveCtypes = False
+try:
from hashlib import md5
- hasHashlib = True
+ haveHashlib = True
except:
import md5 #Python 2.4
- hasHashlib = False
+ haveHashlib = False
from copy import copy
from grass.script import core as grass
@@ -39,13 +46,14 @@
from core.gcmd import RunCommand, GMessage
from gui_core.widgets import GNotebook
-from gui_core.goutput import GMConsole
+from gui_core.goutput import GMConsole, CmdThread, EVT_CMD_DONE
from gui_core.gselect import Select, LayerSelect, ColumnSelect
from vnet.widgets import PointsList
from vnet.toolbars import MainToolbar, PointListToolbar
#TODOs
+# snaping - react on change of map/layer
# when layer tree is lmgr is changed, tmp layer is removed from render list
# check if has layertree (lmgr)?
@@ -61,14 +69,12 @@
self.mapWin = parent.MapWindow
self.inputData = {}
self.cmdParams = {}
+ self.snapData = {}
+ self.snaping = False
- self.tmp_result = None
- self.vnetFlowTmpCut = None
self.tmpMaps = VnetTmpVectMaps(parent = self)
- self.firstAnalysis = True
self.hiddenTypeCol = None
self._initSettings()
# registration graphics for drawing
@@ -87,7 +93,7 @@
# toobars
self.toolbars = {}
self.toolbars['mainToolbar'] = MainToolbar(parent = self)
# Fancy gui
@@ -276,10 +282,12 @@
val = event.IsChecked()
if val:
self.tmp_result.DeleteRenderLayer()
- self.vnetFlowTmpCut.AddRenderLayer()
+ cmd = self.GetLayerStyle()
+ self.vnetFlowTmpCut.AddRenderLayer(cmd)
else:
self.vnetFlowTmpCut.DeleteRenderLayer()
- self.tmp_result.AddRenderLayer()
+ self.tmp_result.AddRenderLayer(cmd)
self.mapWin.UpdateMap(render = True, renderVector = True)
@@ -513,7 +521,6 @@
return
self.notebook.SetSelectionByName("points")
if not self.list.itemDataMap:
self.list.AddItem(None)
@@ -522,6 +529,12 @@
index = self.list.selected
key = self.list.GetItemData(index)
+ if self.snaping:
+ coords = [e, n]
+ self._snapPoint(coords)
+ e = coords[0]
+ n = coords[1]
self.pointsToDraw.GetItem(key).SetCoords([e, n])
if self.list.selected == self.list.GetItemCount() - 1:
@@ -532,6 +545,58 @@
self.mapWin.UpdateMap(render=False, renderVector=False)
+ def _snapPoint(self, coords):
+ e = coords[0]
+ n = coords[1]
+ snapTreshPix = int(UserSettings.Get(group ='vnet',
+ key = 'other',
+ subkey = 'snap_tresh'))
+ res = max(self.mapWin.Map.region['nsres'], self.mapWin.Map.region['ewres'])
+ snapTreshDist = snapTreshPix * res
+ inpMapExists = grass.find_file(name = self.inputData['input'].GetValue(),
+ element = 'vector',
+ mapset = grass.gisenv()['MAPSET'])
+ if not inpMapExists['name']: # TODO without check falls on Vect_open_old2
+ return False
+ openedMap = pointer(vectlib.Map_info())
+ ret = vectlib.Vect_open_old2(openedMap,
+ c_char_p(self.inputData['input'].GetValue()),
+ c_char_p(grass.gisenv()['MAPSET']),
+ c_char_p(self.inputData['alayer'].GetValue()))
+ if ret == 1:
+ vectlib.Vect_close(openedMap)
+ if ret != 2: #TODO also 1?
+ return False
+ nodeNum = vectlib.Vect_find_node(openedMap,
+ c_double(e),
+ c_double(n),
+ c_double(0),
+ c_double(snapTreshDist),
+ vectlib.WITHOUT_Z)
+ if nodeNum > 0:
+ e = c_double(0)
+ n = c_double(0)
+ vectlib.Vect_get_node_coor(openedMap,
+ nodeNum,
+ byref(e),
+ byref(n),
+ None); # z
+ e = e.value
+ n = n.value
+ else:
+ return False
+ coords[0] = e
+ coords[1] = n
+ return True
def OnAnalyze(self, event):
"""!Called when network analysis is started"""
# Check of parameters for analysis
@@ -589,13 +654,11 @@
message = msg)
return
- if self.firstAnalysis:
+ if not self.tmpMaps.HasTmpVectMap("vnet_tmp_result"):
self.tmp_result = self.tmpMaps.AddTmpVectMap("vnet_tmp_result")
if not self.tmp_result:
return
- self.firstAnalysis = False
- else:
- if not self.tmp_result.VectLayerState(layer = 1):
+ elif not self.tmp_result.VectLayerState(layer = 1):
return
# Creates part of cmd fro analysis
@@ -605,8 +668,6 @@
catPts = self._getPtByCat()
- self.tmpMaps.RemoveTmpMap(self.tmp_result)
if self.currAnModule == "v.net.path":
self._vnetPathRunAn(cmdParams, catPts)
else:
@@ -660,7 +721,8 @@
grass.try_remove(self.coordsTmpFile)
self.tmp_result.SaveVectLayerState(layer = 1)
self.mapWin.UpdateMap(render=True, renderVector=True)
def _runAn(self, cmdParams, catPts):
@@ -761,7 +823,8 @@
grass.try_remove(self.tmpPtsAsciiFile)
def _getInputParams(self):
@@ -833,8 +896,7 @@
resStyle = self.vnetParams[self.currAnModule]["resultStyle"]
width = UserSettings.Get(group='vnet', key='res_style', subkey= "line_width")
- layerStyleCmd = ['d.vect',
- "layer=1",'width=' + str(width)]
+ layerStyleCmd = ["layer=1",'width=' + str(width)]
if "catColor" in resStyle:
layerStyleCmd.append('flags=c')
@@ -863,9 +925,11 @@
toggleState = mainToolbar.GetToolState(id)
if toggleState:
else:
- self.tmp_result.DeleteRenderLayer()
+ self.tmp_result.DeleteRenderLayer(cmd)
@@ -925,14 +989,15 @@
vect = [self.tmp_result.GetVectMapName(), addedMap])
+ cmd.insert(0, 'd.vect')
cmd.append('map=%s' % addedMap)
if self.mapWin.tree.FindItemByData(key = 'name', value = addedMap) is None:
self.mapWin.tree.AddLayer(ltype = "vector",
- lname =addedMap,
+ lname = addedMap,
lcmd = cmd,
lchecked = True)
- self.mapWin.UpdateMap(render=True, renderVector=True)
+ #self.mapWin.UpdateMap(render=True, renderVector=True)
def OnSettings(self, event):
@@ -1010,7 +1075,81 @@
self.list.DeleteColumn(1)
self.list.ResizeColumns()
+ def OnSnapping(self, event):
+ if not haveCtypes:
+ ptListToolbar = self.toolbars['pointsList']
+ ptListToolbar.ToggleTool(vars(ptListToolbar)["snapping"], False) #TODO better way?
+ GMessage(parent = self,
+ message = _("Unable to find Vector library. \n") + \
+ _("Snapping mode can not be activated."))
+ return
+ if not event.IsChecked():
+ self.snapPts.DeleteRenderLayer()
+ self.mapWin.UpdateMap(render = False, renderVector = False)
+ return
+ self.snaping = True
+ if not self.tmpMaps.HasTmpVectMap("vnet_snap_points"):
+ self.tmpMaps.HasTmpVectMap("vnet_snap_points")
+ self.snapPts = self.tmpMaps.AddTmpVectMap("vnet_snap_points")
+ if not self.snapPts:
+ return #TODO
+ elif not self.snapPts.VectLayerState(layer = 1):
+ return #TODO
+ info = RunCommand("v.info",
+ map = self.inputData["input"].GetValue(),
+ layer = self.inputData["alayer"].GetValue(),
+ read = True)
+ if haveHashlib:
+ m = md5()
+ else:
+ m = md5.new()
+ m.update(info)
+ inputHash = m.digest()
+ computeNodes = True
+ if not self.snapData:
+ pass
+ elif self.snapData["inputMap"] == self.inputData["input"].GetValue() and \
+ self.snapData["inputMapAlayer"] == self.inputData["alayer"].GetValue():
+ if self.snapData["inputHash"] == inputHash:
+ computeNodes = False
+ if computeNodes:
+ self.requestQ = Queue.Queue()
+ self.resultQ = Queue.Queue()
+ self.cmdThread = CmdThread(self, self.requestQ, self.resultQ)
+ cmd = ["v.to.points", "input=" + self.inputData["input"].GetValue(),
+ "output=" + self.snapPts.GetVectMapName(),
+ "llayer=" + self.inputData["alayer"].GetValue(),
+ "-n", "--overwrite"]
+ # process GRASS command with argument
+ self.Bind(EVT_CMD_DONE, self._onToPointsDone)
+ self.cmdThread.RunCmd(cmd)
+ self.snapData["inputMap"] = self.inputData["input"].GetValue()
+ self.snapData["inputMapAlayer"] = self.inputData["alayer"].GetValue()
+ self.snapData["inputHash"] = inputHash
+ else:
+ self.snapPts.AddRenderLayer()
+ self.mapWin.UpdateMap(render = True, renderVector = True)
+ def _onToPointsDone(self, event):
+ self.snapPts.SaveVectLayerState(layer = 1)
def _initVnetParams(self):
"""!Initializes parameters for different v.net.* modules """
@@ -1141,8 +1280,8 @@
def _initSettings(self):
"""!Initialization of settings (if not already defined)"""
- if 'vnet' in UserSettings.userSettings:
- return
+ #if 'vnet' in UserSettings.userSettings:
+ # return
# initializes default settings
initSettings = [
@@ -1153,10 +1292,11 @@
['point_colors', "unused", (131,139,139)],
['point_colors', "used1cat", (192,0,0)],
['point_colors', "used2cat", (0,0,255)],
- ['point_colors', "selected", (9,249,17)]
+ ['point_colors', "selected", (9,249,17)],
+ ['other', "snap_tresh", 10]
- for init in initSettings:
+ for init in initSettings: #TODO initialization warnings, all types are strs
try:
val = UserSettings.Get(group ='vnet',
key = init[0],
@@ -1164,7 +1304,8 @@
if type(val) != type(init[2]):
raise ValueError()
- except (KeyError, ValueError):
+ except (KeyError, ValueError):
UserSettings.Append(dict = UserSettings.userSettings,
group ='vnet',
key = init[0],
@@ -1321,7 +1462,8 @@
self.sizeSetts = {
"line_width" : ["res_style", _("Line width:")],
"point_size" : ["point_symbol", _("Point size:")],
- "point_width" : ["point_symbol", _("Point width:")]
+ "point_width" : ["point_symbol", _("Point width:")],
+ "snap_tresh" : ["other", _("Snapping treshold in pixels:")]
for settKey, sett in self.sizeSetts.iteritems():
@@ -1392,6 +1534,20 @@
ptsStyleBoxSizer.Add(item = gridSizer, flag = wx.EXPAND)
+ otherBox = wx.StaticBox(parent = self, id = wx.ID_ANY,
+ label =" %s " % _("Other:"))
+ otherBoxSizer = wx.StaticBoxSizer(otherBox, wx.VERTICAL)
+ gridSizer = wx.GridBagSizer(vgap = 1, hgap = 1)
+ gridSizer.AddGrowableCol(1)
+ row = 0
+ gridSizer.Add(item = settsLabels["snap_tresh"], flag=wx.ALIGN_CENTER_VERTICAL, pos=(row, 0))
+ gridSizer.Add(item = self.settings["snap_tresh"],
+ flag = wx.ALIGN_RIGHT | wx.ALL, border = 5,
+ pos = (row, 1))
+ otherBoxSizer.Add(item = gridSizer, flag = wx.EXPAND)
btnSizer = wx.BoxSizer(wx.HORIZONTAL)
btnSizer.Add(self.btnApply, flag = wx.LEFT | wx.RIGHT, border = 5)
btnSizer.Add(self.btnSave, flag=wx.LEFT | wx.RIGHT, border=5)
@@ -1399,12 +1555,12 @@
sizer.Add(item = styleBoxSizer, flag = wx.EXPAND | wx.ALL, border = 5)
sizer.Add(item = ptsStyleBoxSizer, flag = wx.EXPAND | wx.ALL, border = 5)
+ sizer.Add(item = otherBoxSizer, flag = wx.EXPAND | wx.ALL, border = 5)
sizer.Add(item = btnSizer, flag = wx.EXPAND | wx.ALL, border = 5, proportion = 0)
self.SetSizer(sizer)
sizer.Fit(self)
def OnSave(self, event):
"""!Button 'Save' pressed"""
self.UpdateSettings()
@@ -1437,7 +1593,8 @@
if not hasattr(self.parent.tmp_result, "GetRenderLayer"):
self.parent.mapWin.UpdateMap(render=False, renderVector=False)
elif self.parent.tmp_result.GetRenderLayer():
- self.parent.tmp_result.AddRenderLayer()
+ cmd = self.parent.GetLayerStyle()
+ self.parent.tmp_result.AddRenderLayer(cmd)
self.parent.mapWin.UpdateMap(render=True, renderVector=True)#TODO optimization
else:
@@ -1462,7 +1619,7 @@
# text fields and it's captions
self.vectSel = Select(parent = self.panel, type = 'vector', size = (-1, -1))
self.vectSellabel = wx.StaticText(parent = self.panel, id = wx.ID_ANY,
- label = _("Layer name:"))
+ label = _("Map name:"))
# buttons
self.btnCancel = wx.Button(self.panel, wx.ID_CANCEL)
@@ -1477,7 +1634,7 @@
sizer = wx.BoxSizer(wx.VERTICAL)
box = wx.StaticBox (parent = self.panel, id = wx.ID_ANY,
- label = "Added layer")
+ label = "Added vector map")
boxSizer = wx.StaticBoxSizer(box, wx.HORIZONTAL)
@@ -1539,6 +1696,14 @@
return newVectMap
+ def HasTmpVectMap(self, vectMap):
+ fullName = vectMap + "@" + grass.gisenv()['MAPSET']
+ for vectTmpMap in self.tmpMaps:
+ if vectTmpMap.GetVectMapName() == fullName:
+ return True
+ return False
def RemoveTmpMap(self, vectMap):
RunCommand('g.remove',
@@ -1566,12 +1731,13 @@
self.parent = parent
self.renderLayer = None
self.layersHash = {}
+ self.new = True
def __del__(self):
self.DeleteRenderLayer()
- def AddRenderLayer(self):
+ def AddRenderLayer(self, cmd = None):
existsMap = grass.find_file(name = self.fullName,
element = 'vector',
@@ -1581,7 +1747,9 @@
return False
- cmd = self.parent.parent.GetLayerStyle()
+ if not cmd:
+ cmd = []
cmd.append('map=%s' % self.fullName)
if self.renderLayer:
@@ -1608,11 +1776,11 @@
def SaveVectLayerState(self, layer):
- self.layersHash[layer] = self._getLayerHash(layer = layer)
+ self.layersHash[layer] = self.GetLayerHash(layer = layer)
def VectLayerState(self, layer):
- if self.layersHash[layer] != self._getLayerHash(layer = layer):
+ if self.layersHash[layer] != self.GetLayerHash(layer = layer):
dlg = wx.MessageDialog(parent = self.parent.parent,
message = _("Layer %d in map %s was changed outside " +
"of vector network analysis tool. " +
@@ -1630,13 +1798,13 @@
return True
- def _getLayerHash(self, layer):
+ def GetLayerHash(self, layer):
map = self.fullName,
layer = layer,
read = True)
- if hasHashlib:
+ if haveHashlib:
m = md5()
else:
m = md5.new()
Modified: grass-addons/grass7/gui/wxpython/wx.vnet/vnet/toolbars.py
--- grass-addons/grass7/gui/wxpython/wx.vnet/vnet/toolbars.py 2012-07-26 12:36:38 UTC (rev 52453)
+++ grass-addons/grass7/gui/wxpython/wx.vnet/vnet/toolbars.py 2012-07-26 23:39:43 UTC (rev 52454)
@@ -39,6 +39,8 @@
icons = {
'insertPoint' : MetaIcon(img = 'pointer',
label = _('Insert point with mouse')),
+ 'snapping' : MetaIcon(img = 'move',
+ label = _('Snap to nodes')),
'pointAdd' : MetaIcon(img = 'point-create',
label = _('Add new point')),
'pointDelete' : MetaIcon(img = 'gcp-delete',
@@ -48,6 +50,10 @@
return self._getToolbarData((('insertPoint', icons['insertPoint'],
self.list.dialog.OnInsertPoint,#TODO self.list.dialog
wx.ITEM_CHECK),
+ ('snapping', icons['snapping'],
+ self.list.dialog.OnSnapping,
+ wx.ITEM_CHECK),
+ (None, ),
('pointAdd', icons["pointAdd"],
self.list.AddItem),
('pointDelete', icons["pointDelete"],
