[GRASS-SVN] r52459 - grass/trunk/lib/gis
svn_grass at osgeo.org
Thu Jul 26 23:17:26 PDT 2012
Author: lucadelu
Date: 2012-07-26 23:17:25 -0700 (Thu, 26 Jul 2012)
New Revision: 52459
Added:
grass/trunk/lib/gis/parser_rst.c
grass/trunk/lib/gis/parser.c
grass/trunk/lib/gis/parser_local_proto.h
add parse to return as output rest format
Modified: grass/trunk/lib/gis/parser.c
--- grass/trunk/lib/gis/parser.c 2012-07-27 05:05:40 UTC (rev 52458)
+++ grass/trunk/lib/gis/parser.c 2012-07-27 06:17:25 UTC (rev 52459)
@@ -441,6 +441,13 @@
G__usage_html();
exit(EXIT_SUCCESS);
+ /* If first arg is "--rest-description" then print out
+ * a rest description of the task */
+ if (strcmp(argv[1], "--rest-description") == 0) {
+ G__usage_rest();
+ exit(EXIT_SUCCESS);
/* If first arg is "--wps-process-description" then print out
* the wps process description of the task */
Modified: grass/trunk/lib/gis/parser_local_proto.h
--- grass/trunk/lib/gis/parser_local_proto.h 2012-07-27 05:05:40 UTC (rev 52458)
+++ grass/trunk/lib/gis/parser_local_proto.h 2012-07-27 06:17:25 UTC (rev 52459)
@@ -47,6 +47,7 @@
void G__usage_xml(void);
void G__usage_html(void);
+void G__usage_rest(void);
void G__usage_text(void);
void G__script(void);
void G__wps_print_process_description(void);
Added: grass/trunk/lib/gis/parser_rst.c
--- grass/trunk/lib/gis/parser_rst.c (rev 0)
+++ grass/trunk/lib/gis/parser_rst.c 2012-07-27 06:17:25 UTC (rev 52459)
@@ -0,0 +1,278 @@
+#include <stdio.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+#include "parser_local_proto.h"
+#include "string.h"
+// static void print_escaped_for_html(FILE * f, const char *str);
+// static void print_escaped_for_html_options(FILE * f, const char *str);
+ \brief Print module usage description in HTML format.
+ struct Option *opt;
+ struct Flag *flag;
+ const char *type;
+ int new_prompt = 0;
+ int s;
+ new_prompt = G__uses_new_gisprompt();
+ if (!st->pgm_name) /* v.dave && r.michael */
+ st->pgm_name = G_program_name();
+ st->pgm_name = "??";
+ fprintf(stdout, "=================");
+ for (s = 0; s <= strlen(st->pgm_name); s++) {
+ fprintf(stdout, "=");
+ fprintf(stdout, "\n");
+ fprintf(stdout, "GRASS GIS manual: %s\n", st->pgm_name);
+ fprintf(stdout, "\n\n");
+ fprintf(stdout,".. figure:: grass_logo.png\n");
+ fprintf(stdout," :align: center\n");
+ fprintf(stdout," :alt: GRASS logo\n\n");
+ fprintf(stdout,"%s\n----\n", _("NAME"));
+ fprintf(stdout, "**%s**", st->pgm_name); //TODO fix bold + emphase now only bold
+ if (st->module_info.label || st->module_info.description)
+ fprintf(stdout, " - ");
+ if (st->module_info.label)
+ fprintf(stdout, "%s\n", st->module_info.label);
+ if (st->module_info.description)
+ fprintf(stdout, "%s\n", st->module_info.description);
+ fprintf(stdout, "%s\n--------\n", _("KEYWORDS"));
+ if (st->module_info.keywords) {
+ G__print_keywords(stdout, NULL);
+ fprintf(stdout, "%s\n--------\n", _("SYNOPSIS"));
+ fprintf(stdout, "**%s**\n\n", st->pgm_name);
+ fprintf(stdout, "**%s** help\n\n", st->pgm_name);
+ /* print short version first */
+ if (st->n_flags) {
+ flag = &st->first_flag;
+ fprintf(stdout, " [**-");
+ while (flag != NULL) {
+ fprintf(stdout, "%c", flag->key);
+ flag = flag->next_flag;
+ fprintf(stdout, "**] ");
+ else
+ fprintf(stdout, " ");
+ if (st->n_opts) {
+ opt = &st->first_option;
+ while (opt != NULL) {
+ if (opt->key_desc != NULL)
+ type = opt->key_desc;
+ else
+ switch (opt->type) {
+ case TYPE_INTEGER:
+ type = "integer";
+ break;
+ case TYPE_DOUBLE:
+ type = "float";
+ break;
+ case TYPE_STRING:
+ type = "string";
+ break;
+ default:
+ type = "string";
+ break;
+ if (!opt->required)
+ fprintf(stdout, " [");
+ fprintf(stdout, "**%s**=*%s*", opt->key, type);
+ if (opt->multiple) {
+ fprintf(stdout, "[,*%s*,...]", type);
+ fprintf(stdout, "] ");
+ opt = opt->next_opt;
+ if (new_prompt)
+ fprintf(stdout, " [--**overwrite**] ");
+ fprintf(stdout, " [--**verbose**] ");
+ fprintf(stdout, " [--**quiet**] ");
+ /* now long version */
+ if (st->n_flags || new_prompt) {
+ fprintf(stdout, "%s:\n~~~~~~\n", _("Flags"));
+ while (st->n_flags && flag != NULL) {
+ fprintf(stdout, "**-%c**\n", flag->key);
+ if (flag->label) {
+ fprintf(stdout, " %s", flag->label);
+ if (flag->description) {
+ fprintf(stdout, " %s", flag->description);
+ if (new_prompt) {
+ fprintf(stdout, "**--overwrite**\n");
+ fprintf(stdout, " %s\n",
+ _("Allow output files to overwrite existing files"));
+ fprintf(stdout, "**--verbose**\n");
+ fprintf(stdout, " %s\n", _("Verbose module output"));
+ fprintf(stdout, "**--quiet**\n");
+ fprintf(stdout, " %s\n", _("Quiet module output"));
+ if (st->n_opts) {
+ fprintf(stdout, "%s:\n~~~~~~~~~~~\n", _("Parameters"));
+ /* TODO: make this a enumeration type? */
+ else
+ type = "integer";
+ break;
+ case TYPE_DOUBLE:
+ type = "float";
+ break;
+ case TYPE_STRING:
+ type = "string";
+ break;
+ default:
+ type = "string";
+ break;
+ fprintf(stdout, "**%s** = *%s", opt->key, type);
+ fprintf(stdout, "*");
+ if (opt->required) {
+ fprintf(stdout, " ;**[required]**");
+ if (opt->label) {
+ fprintf(stdout, " %s\n", opt->label);
+ if (opt->description) {
+ fprintf(stdout, " %s\n", opt->description);
+ if (opt->options) {
+ fprintf(stdout, " %s: *", _("Options"));
+// print_escaped_for_html_options(stdout, opt->options);
+ fprintf(stdout, "%s", opt->options);
+ fprintf(stdout, "*\n");
+ if (opt->def) {
+ fprintf(stdout, " %s: *", _("Default"));
+// print_escaped_for_html(stdout, opt->def);
+ fprintf(stdout,"%s", opt->def);
+ if (opt->descs) {
+ int i = 0;
+ while (opt->opts[i]) {
+ if (opt->descs[i]) {
+ fprintf(stdout, " **");
+// print_escaped_for_html(stdout, opt->opts[i]);
+ fprintf(stdout,"%s", opt->opts[i]);
+ fprintf(stdout, "**: ");
+// print_escaped_for_html(stdout, opt->descs[i]);
+ fprintf(stdout, "%s\n", opt->descs[i]);
+ i++;
+ * \brief Format text for HTML output
+#define do_escape(c,escaped) case c: fputs(escaped,f);break
+// void print_escaped_for_html(FILE * f, const char *str)
+// const char *s;
+// for (s = str; *s; s++) {
+// switch (*s) {
+// do_escape('&', "&");
+// do_escape('<', "<");
+// do_escape('>', ">");
+// do_escape('\n', "<br>");
+// do_escape('\t', " ");
+// default:
+// fputc(*s, f);
+// void print_escaped_for_html_options(FILE * f, const char *str)
+// const char *s;
+// switch (*s) {
+// do_escape(',', ", ");
+// default:
+// fputc(*s, f);
+#undef do_escape
