[GRASS-SVN] r52461 - grass/trunk/lib/gis
Fri Jul 27 01:04:47 PDT 2012
Author: lucadelu
Date: 2012-07-27 01:04:47 -0700 (Fri, 27 Jul 2012)
New Revision: 52461
   grass/trunk/lib/gis/parser_rest.c
fix comment change // to /*
Modified: grass/trunk/lib/gis/parser_rest.c
--- grass/trunk/lib/gis/parser_rest.c	2012-07-27 06:37:16 UTC (rev 52460)
+++ grass/trunk/lib/gis/parser_rest.c	2012-07-27 08:04:47 UTC (rev 52461)
@@ -5,10 +5,13 @@
 #include "parser_local_proto.h"
 #include "string.h"
-// static void print_escaped_for_html(FILE * f, const char *str);
-// static void print_escaped_for_html_options(FILE * f, const char *str);
+static void print_escaped_for_html(FILE * f, const char *str);
+static void print_escaped_for_html_options(FILE * f, const char *str);
   \brief Print module usage description in HTML format.
 void G__usage_rest(void)
@@ -43,7 +46,7 @@
     fprintf(stdout,"   :alt: GRASS logo\n\n");
     fprintf(stdout,"%s\n----\n", _("NAME"));
-    fprintf(stdout, "**%s**", st->pgm_name); //TODO fix bold + emphase now only bold
+    fprintf(stdout, "**%s**", st->pgm_name); /*! TODO fix bold + emphase now only bold */
     if (st->module_info.label || st->module_info.description)
 	fprintf(stdout, " - ");
@@ -200,14 +203,14 @@
 	    if (opt->options) {
 		fprintf(stdout, "    %s: *", _("Options"));
-// 		print_escaped_for_html_options(stdout, opt->options);
+		/*! print_escaped_for_html_options(stdout, opt->options); */
 		fprintf(stdout, "%s", opt->options);
 		fprintf(stdout, "*\n");
 	    if (opt->def) {
 		fprintf(stdout, "    %s: *", _("Default"));
-// 		print_escaped_for_html(stdout, opt->def);
+		/*! print_escaped_for_html(stdout, opt->def); */
 		fprintf(stdout,"%s", opt->def);
@@ -218,10 +221,10 @@
 		while (opt->opts[i]) {
 		    if (opt->descs[i]) {
 			fprintf(stdout, "    **");
-// 			print_escaped_for_html(stdout, opt->opts[i]);
+			/*! print_escaped_for_html(stdout, opt->opts[i]); */
 			fprintf(stdout,"%s", opt->opts[i]);
 			fprintf(stdout, "**: ");
-// 			print_escaped_for_html(stdout, opt->descs[i]);
+			/*! print_escaped_for_html(stdout, opt->descs[i]); */
 			fprintf(stdout, "%s\n", opt->descs[i]);
 		    i++;
@@ -239,40 +242,41 @@
  * \brief Format text for HTML output
 #define do_escape(c,escaped) case c: fputs(escaped,f);break
-// void print_escaped_for_html(FILE * f, const char *str)
-//     const char *s;
-//     for (s = str; *s; s++) {
-// 	switch (*s) {
-// 	    do_escape('&', "&");
-// 	    do_escape('<', "<");
-// 	    do_escape('>', ">");
-// 	    do_escape('\n', "<br>");
-// 	    do_escape('\t', "    ");
-// 	default:
-// 	    fputc(*s, f);
-// void print_escaped_for_html_options(FILE * f, const char *str)
-//     const char *s;
-// 	switch (*s) {
-// 	    do_escape(',',  ", ");
-// 	default:
-// 	    fputc(*s, f);
+ void print_escaped_for_html(FILE * f, const char *str)
+     const char *s;
+     for (s = str; *s; s++) {
+ 	switch (*s) {
+ 	    do_escape('&', "&");
+ 	    do_escape('<', "<");
+ 	    do_escape('>', ">");
+ 	    do_escape('\n', "<br>");
+ 	    do_escape('\t', "    ");
+ 	default:
+ 	    fputc(*s, f);
+ void print_escaped_for_html_options(FILE * f, const char *str)
+     const char *s;
+ 	switch (*s) {
+ 	    do_escape(',',  ", ");
+ 	default:
+ 	    fputc(*s, f);
 #undef do_escape
