[GRASS-SVN] r52466 - in grass/trunk: include lib/gis lib/raster
svn_grass at osgeo.org
Fri Jul 27 13:06:50 PDT 2012
Author: martinl
Date: 2012-07-27 13:06:49 -0700 (Fri, 27 Jul 2012)
New Revision: 52466
grass/trunk/include/gis.h
grass/trunk/lib/gis/gislib.dox
grass/trunk/lib/raster/rasterlib.dox
better doxygen documentation of Cell_head structure
Modified: grass/trunk/include/gis.h
--- grass/trunk/include/gis.h 2012-07-27 20:05:47 UTC (rev 52465)
+++ grass/trunk/include/gis.h 2012-07-27 20:06:49 UTC (rev 52466)
@@ -82,10 +82,15 @@
#define U_MINUTES DATETIME_MINUTE
#define U_SECONDS DATETIME_SECOND
+/*! \brief Projection code - XY coordinate system */
#define PROJECTION_XY 0
+/*! \brief Projection code - UTM */
#define PROJECTION_UTM 1
+/*! \brief Projection code - plane */
#define PROJECTION_SP 2
+/*! \brief Projection code - LatLong */
#define PROJECTION_LL 3
+/*! \brief Projection code - other coordinate system (other then noted above) */
#define PROJECTION_OTHER 99
#define PROJECTION_FILE "PROJ_INFO"
@@ -311,27 +316,62 @@
/*=========================== Typedefs/Structures ==========================*/
+ \brief 2D/3D raster map header (used also for region)
struct Cell_head
- int format; /* max number of bytes per cell minus 1 */
- int compressed; /* 0 = uncompressed, 1 = compressed, -1 pre 3.0 */
- int rows; /* number of rows in the data 2D */
- int rows3; /* number of rows in the data 3D */
- int cols; /* number of columns in the data 2D */
- int cols3; /* number of columns in the data 3D */
- int depths; /* number of depths in data */
- int proj; /* projection (see #defines above) */
- int zone; /* projection zone */
- double ew_res; /* east to west cell size 2D */
- double ew_res3; /* east to west cell size 3D */
- double ns_res; /* north to south cell size 2D */
- double ns_res3; /* north to south cell size 3D */
- double tb_res; /* top to bottom cell size */
- double north; /* coordinates of map layer */
+ /*! \brief Max number of bytes per raster data value minus 1 (raster header only) */
+ int format;
+ /*! \brief Compression mode (raster header only)
+ - 0: uncompressed
+ - 1: compressed
+ - -1: pre GRASS 3.0
+ int compressed;
+ /*! \brief Number of rows for 2D data */
+ int rows;
+ /*! \brief Number of rows for 3D data */
+ int rows3;
+ /*! \brief Number of columns for 2D data */
+ int cols;
+ /*! \brief Number of columns for 3D data */
+ int cols3;
+ /*! \brief number of depths for 3D data */
+ int depths;
+ /*! \brief Projection code
+ - PROJECTION_XY
+ - PROJECTION_UTM
+ - PROJECTION_SP
+ - PROJECTION_LL
+ - PROJECTION_OTHER
+ int proj;
+ /*! \brief Projection zone (UTM) */
+ int zone;
+ /*! \brief Resolution - east to west cell size for 2D data */
+ double ew_res;
+ /*! \brief Resolution - east to west cell size for 3D data */
+ double ew_res3;
+ /*! \brief Resolution - north to south cell size for 2D data */
+ double ns_res;
+ /*! \brief Resolution - north to south cell size for 3D data */
+ double ns_res3;
+ /*! \brief Resolution - top to bottom cell size for 3D data */
+ double tb_res;
+ /*! \brief Extent coordinates (north) */
+ double north;
+ /*! \brief Extent coordinates (south) */
double south;
+ /*! \brief Extent coordinates (east) */
double east;
+ /*! \brief Extent coordinates (west) */
double west;
+ /*! \brief Extent coordinates (top) - 3D data*/
double top;
+ /*! \brief Extent coordinates (bottom) - 3D data */
double bottom;
Modified: grass/trunk/lib/gis/gislib.dox
--- grass/trunk/lib/gis/gislib.dox 2012-07-27 20:05:47 UTC (rev 52465)
+++ grass/trunk/lib/gis/gislib.dox 2012-07-27 20:06:49 UTC (rev 52466)
@@ -2117,49 +2117,25 @@
The raster header data structure is used for two purposes. It is used
-for raster header information for map layers. It also used to hold
-region values. The structure is:
+for raster header information for raster map. It also used to hold
+region values.
-\code
-struct Cell_head
- double south;
- double east;
- double west;
- double top;
- double bottom;
-\endcode
+See documentation of Cell_head structure for details.
+The <tt>format</tt> and <tt>compressed</tt> fields apply only to
+raster headers. The <tt>format</tt> field describes the number of
+bytes per raster data value and the <tt>compressed</tt> field
+indicates if the raster file is compressed or not. The other fields
+apply both to raster headers and regions. The geographic boundaries
+are described by <tt>north, south, east</tt> and <tt>west</tt>. The
+grid resolution is described by <tt>ew_res</tt> and
+<tt>ns_res</tt>. The cartographic projection is described by
+<tt>proj</tt> and the related zone for the projection by
+<tt>zone</tt>. The <tt>rows</tt> and <tt>cols</tt> indicate the number
+of rows and columns in the raster map, or in the region. See \ref
+Raster_Header_File for more information about raster headers, and \ref
+Region for more information about regions.
-The <i>format</i> and <i>compressed</i> fields apply only to raster
-headers. The <i>format</i> field describes the number of bytes per
-raster data value and the <i>compressed</i> field indicates if the
-raster file is compressed or not. The other fields apply both to
-raster headers and regions. The geographic boundaries are described by
-<i>north, south, east</i> and <i>west</i>. The grid resolution is
-described by <i>ew_res</i> and <i>ns_res</i>. The cartographic
-projection is described by <i>proj</i> and the related zone for the
-projection by <i>zone</i>. The <i>rows</i> and <i>cols</i> indicate
-the number of rows and columns in the raster file, or in the
-region. See \ref Raster_Header_File for more information about
-raster headers, and \ref Region for more information about regions.
The routines described in \ref Raster_Header_File use this structure.
\subsection struct_Categories struct Categories
Modified: grass/trunk/lib/raster/rasterlib.dox
--- grass/trunk/lib/raster/rasterlib.dox 2012-07-27 20:05:47 UTC (rev 52465)
+++ grass/trunk/lib/raster/rasterlib.dox 2012-07-27 20:06:49 UTC (rev 52466)
@@ -284,11 +284,11 @@
\section Raster_Header_File Raster Header File
-The raster header file contains information describing the geographic
-extent of the map layer, the grid cell resolution, and the format used
-to store the data in the raster file. The format of this file is
-described in \ref Raster_Header_Format. The routines described below
-use the <i>Cell_head</i> structure which is shown in detail in \ref
+The raster header file (<tt>cellhd</tt>) contains information
+describing the geographic extent of the raster map, the grid cell
+resolution, the format used to store the data in the raster file, see
+Cell_head structure for details. The routines described below use the
+Cell_head structure which is shown in detail in \ref
GIS_Library_Data_Structures.
- Rast_get_cellhd()
