[GRASS-SVN] r52474 - grass-addons/grass7/gui/wxpython/wx.vnet/vnet
svn_grass at osgeo.org
Sat Jul 28 03:45:00 PDT 2012
Author: turek
Date: 2012-07-28 03:45:00 -0700 (Sat, 28 Jul 2012)
New Revision: 52474
grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py
grass-addons/grass7/gui/wxpython/wx.vnet/vnet/toolbars.py
grass-addons/grass7/gui/wxpython/wx.vnet/vnet/widgets.py
vnet: Undo/redo features added
Modified: grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py
--- grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py 2012-07-28 09:49:57 UTC (rev 52473)
+++ grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py 2012-07-28 10:45:00 UTC (rev 52474)
@@ -8,7 +8,7 @@
- dialogs::PtsList
- dialogs::SettingsDialog
- dialogs::VnetTmpVectMaps
- - dialogs::VnetTmpVectMap
+ - dialogs::TmpVectMap
(C) 2012 by the GRASS Development Team
@@ -20,6 +20,7 @@
import os
import sys
+import types
import Queue
try:
import grass.lib.vector as vectlib
@@ -52,11 +53,13 @@
from vnet.widgets import PointsList
from vnet.toolbars import MainToolbar, PointListToolbar
-#TODOs
-# snaping - react on change of map/layer
+#Main TODOs
+# snapping - react on change of map/layer
# when layer tree is lmgr is changed, tmp layer is removed from render list
# check if has layertree (lmgr)?
+# optimization of map drawing
class VNETDialog(wx.Dialog):
def __init__(self, parent,
id = wx.ID_ANY, title = _("Vector network analysis"),
@@ -71,7 +74,12 @@
self.cmdParams = {}
self.snapData = {}
self.snaping = False
+ self.tmp_result = None #TODO
+ self.history = History(self)
+ self.histTmpVectMapNum = 0
+ self.tmpVectMapsToHist = []
self.tmpMaps = VnetTmpVectMaps(parent = self)
self.hiddenTypeCol = None
@@ -93,7 +101,7 @@
# toobars
self.toolbars = {}
self.toolbars['mainToolbar'] = MainToolbar(parent = self)
# Fancy gui
@@ -124,7 +132,7 @@
# adds 2 points into list
for i in range(2):
- self.list.AddItem(None)
+ self.list.AddItem()
self.list.EditCellIndex(i, 1, self.cols[1][1][1 + i])
self.list.CheckItem(i, True)
@@ -134,7 +142,7 @@
self.Bind(wx.EVT_CLOSE, self.OnCloseDialog)
- dlgSize = (400, 520)
+ dlgSize = (410, 520)
self.SetMinSize(dlgSize)
self.SetInitialSize(dlgSize)
@@ -326,7 +334,7 @@
['nlayer', "Node layer number or name:", LayerSelect],
['afcolumn', self.attrCols['afcolumn']['label'], ColumnSelect],
['abcolumn', self.attrCols['abcolumn']['label'], ColumnSelect],
- ['ncolumn', self.attrCols['ncolumn']['label'], ColumnSelect]
+ ['ncolumn', self.attrCols['ncolumn']['label'], ColumnSelect],
selPanels = {}
@@ -654,10 +662,13 @@
message = msg)
return
- if not self.tmpMaps.HasTmpVectMap("vnet_tmp_result"):
- self.tmp_result = self.tmpMaps.AddTmpVectMap("vnet_tmp_result")
- if not self.tmp_result:
- return
+ self.SaveAnInputToHist()
+ if self.tmp_result:
+ self.tmp_result.DeleteRenderLayer()
+ self.tmp_result = self.NewTmpVectMapToHist('vnet_tmp_result')
+ if not self.tmp_result:
+ return
elif not self.tmp_result.VectLayerState(layer = 1):
return
@@ -719,6 +730,9 @@
def _vnetPathRunAnDone(self, cmd, returncode):
"""!Called when v.net.path analysis is done"""
grass.try_remove(self.coordsTmpFile)
+ self._saveHistStep()
self.tmp_result.SaveVectLayerState(layer = 1)
cmd = self.GetLayerStyle()
@@ -775,7 +789,7 @@
cmdParams.append("from_layer=1")
cmdParams.append("to_layer=1")
elif self.currAnModule == "v.net.flow":#TODO
- self.vnetFlowTmpCut = self.tmpMaps.AddTmpVectMap("vnet_tmp_flow_cut")
+ self.vnetFlowTmpCut = self.NewTmpVectMapToHist("vnet_tmp_flow_cut")
if not self.vnetFlowTmpCut:
return
cmdParams.append("cut=" + self.vnetFlowTmpCut.GetVectMapName())
@@ -822,6 +836,8 @@
self.tmpMaps.RemoveTmpMap(self.tmpInPtsConnected)
grass.try_remove(self.tmpPtsAsciiFile)
self.tmp_result.AddRenderLayer(cmd)
@@ -988,7 +1004,7 @@
overwrite = True,
vect = [self.tmp_result.GetVectMapName(), addedMap])
- cmd = self.GetLayerStyle()
+ cmd = self.GetLayerStyle()#TOFO get rid of insert
cmd.insert(0, 'd.vect')
cmd.append('map=%s' % addedMap)
if self.mapWin.tree.FindItemByData(key = 'name', value = addedMap) is None:
@@ -997,9 +1013,8 @@
lcmd = cmd,
lchecked = True)
- #self.mapWin.UpdateMap(render=True, renderVector=True)
+ #self.mapWin.UpdateMap(render=True, renderVector=True)
def OnSettings(self, event):
"""!Displays vnet settings dialog"""
dlg = SettingsDialog(parent=self, id=wx.ID_ANY, title=_('Settings'))
@@ -1150,6 +1165,80 @@
self.snapPts.AddRenderLayer()
self.mapWin.UpdateMap(render = True, renderVector = True)
+ def OnUndo(self, event):
+ histStepData = self.history.GetPrev()
+ self.toolbars['mainToolbar'].UpdateUndoRedo()
+ if histStepData:
+ self._updateHistStepData(histStepData)
+ def OnRedo(self, event):
+ histStepData = self.history.GetNext()
+ if histStepData:
+ def _saveHistStep(self):
+ self.history.SaveHistStep()
+ def _updateHistStepData(self, histStepData):#TODO need optimization
+ #TODO ischecked?
+ self.currAnModule = histStepData["vnet_modules"]["curr_module"]
+ anChoice = self.toolbars['mainToolbar'].anChoice
+ anChoice.SetStringSelection(self.vnetParams[self.currAnModule]["label"]) #TODO
+ while self.list.GetSelected() != wx.NOT_FOUND:
+ self.list.DeleteItem()
+ i = 0
+ for pt, ptData in histStepData["points"].iteritems():
+ coords = ptData["coords"]
+ item = self.pointsToDraw.GetItem(i)
+ item.SetCoords(coords)
+ i += 1
+ mapsNames = histStepData["tmp_data"]["maps"]
+ for vectMapName in mapsNames:
+ if "vnet_tmp_result" in vectMapName:
+ self.tmp_result = self.tmpMaps.GetTmpVectMap(vectMapName)
+ self.tmp_result.AddRenderLayer(cmd)
+ self.mapWin.UpdateMap(render=True, renderVector=True)
+ def NewTmpVectMapToHist(self, prefMapName):
+ mapName = prefMapName + str(self.histTmpVectMapNum)
+ self.histTmpVectMapNum += 1
+ tmpMap = self.tmpMaps.AddTmpVectMap(mapName)
+ if not tmpMap:
+ return tmpMap
+ self.tmpVectMapsToHist.append(tmpMap.GetVectMapName())
+ self.history.Add(key = "tmp_data", subkey = "maps", value = self.tmpVectMapsToHist)
+ return tmpMap
+ def SaveAnInputToHist(self):
+ pts = self.pointsToDraw.GetAllItems()
+ for iPt, pt in enumerate(pts):
+ coords = pt.GetCoords()
+ ptName = "pt" + str(iPt)
+ self.history.Add(key = "points", subkey = [ptName, "coords"], value = coords)
+ self.history.Add(key = "vnet_modules", subkey = "curr_module", value = self.currAnModule)
def _initVnetParams(self):
"""!Initializes parameters for different v.net.* modules """
@@ -1287,7 +1376,7 @@
initSettings = [
['res_style', 'line_width', 5],
['res_style', 'line_color', (192,0,0)],
- ['point_symbol', 'point_size', 10],
+ ['point_symbol', 'point_size', 10],
['point_symbol', 'point_width', 2],
['point_colors', "unused", (131,139,139)],
['point_colors', "used1cat", (192,0,0)],
@@ -1342,7 +1431,7 @@
PointsList.__init__(self, parent = parent, cols = cols, id = id)
- def AddItem(self, event):
+ def AddItem(self, event = None):
Appends an point to list
@@ -1354,18 +1443,17 @@
self.dialog.mapWin.UpdateMap(render=False, renderVector=False)
- def DeleteItem(self, event):
+ def DeleteItem(self, event = None):
Deletes selected point in list
key = self.GetItemData(self.selected)
- PointsList.DeleteItem(self, event)
if self.selected != wx.NOT_FOUND:
item = self.dialog.pointsToDraw.GetItem(key)
self.dialog.pointsToDraw.DeleteItem(item)
+ PointsList.DeleteItem(self, event)
def OnItemSelected(self, event):
Item selected
@@ -1590,7 +1678,7 @@
self.parent.SetPointDrawSettings()
- if not hasattr(self.parent.tmp_result, "GetRenderLayer"):
+ if not self.parent.tmpMaps.HasTmpVectMap("vnet_tmp_result"):
self.parent.mapWin.UpdateMap(render=False, renderVector=False)
elif self.parent.tmp_result.GetRenderLayer():
cmd = self.parent.GetLayerStyle()
@@ -1691,7 +1779,7 @@
else:
fullName = mapName + "@" + currMapSet
- newVectMap = VnetTmpVectMap(self, fullName)
+ newVectMap = TmpVectMap(self, fullName)
self.tmpMaps.append(newVectMap)
return newVectMap
@@ -1704,6 +1792,13 @@
return True
return False
+ def GetTmpVectMap(self, vectMapName):
+ for vectMap in self.tmpMaps:
+ if vectMap.GetVectMapName() == vectMapName.strip():
+ return vectMap
+ return None
def RemoveTmpMap(self, vectMap):
RunCommand('g.remove',
@@ -1724,7 +1819,7 @@
update = True
return update
-class VnetTmpVectMap:
+class TmpVectMap:
def __init__(self, parent, fullName):
"""!Represents one temporary map"""
self.fullName = fullName
@@ -1776,11 +1871,14 @@
def SaveVectLayerState(self, layer):
- self.layersHash[layer] = self.GetLayerHash(layer = layer)
+ self.layersHash[layer] = self._getLayerHash(layer = layer)
def VectLayerState(self, layer):
- if self.layersHash[layer] != self.GetLayerHash(layer = layer):
+ if not self.layersHash:#TODO
+ return True
+ if self.layersHash[layer] != self._getLayerHash(layer = layer):
dlg = wx.MessageDialog(parent = self.parent.parent,
message = _("Layer %d in map %s was changed outside " +
"of vector network analysis tool. " +
@@ -1798,7 +1896,7 @@
return True
- def GetLayerHash(self, layer):
+ def _getLayerHash(self, layer):
info = RunCommand("v.info",
map = self.fullName,
layer = layer,
@@ -1812,6 +1910,228 @@
return m.digest()
+class History:
+ def __init__(self, parent):
+ self.maxHistSteps = 10
+ self.currHistStep = 0
+ self.histStepsNum = 0
+ self.currHistStepData = {}
+ self.newHistStepData = {}
+ self.histFile = grass.tempfile()
+ # key/value separator
+ self.sep = ';'
+ def __del__(self):
+ grass.try_remove(self.histFile)
+ def GetNext(self):
+ self.currHistStepData.clear()
+ self.currHistStep -= 1
+ return self._getHistStepData(self.currHistStep)
+ def GetPrev(self):
+ self.currHistStep += 1
+ def GetCurrHistStep(self):
+ return self.currHistStep
+ def GetStepsNum(self):
+ return self.histStepsNum
+ def Add(self, key, subkey, value):#TODO
+ if key not in self.newHistStepData:
+ self.newHistStepData[key] = {}
+ if type(subkey) == types.ListType:
+ if subkey[0] not in self.newHistStepData[key]:
+ self.newHistStepData[key][subkey[0]] = {}
+ self.newHistStepData[key][subkey[0]][subkey[1]] = value
+ else:
+ self.newHistStepData[key][subkey] = value
+ def SaveHistStep(self):
+ self.currHistStep = 0 #TODO
+ newHistFile = grass.tempfile()
+ newHist = open(newHistFile, "w")
+ self._saveNewHistStep(newHist)
+ oldHist = open(self.histFile)
+ self._savePreviusHist(newHist, oldHist)
+ oldHist.close()
+ newHist.close()
+ self.histFile = newHistFile
+ self.newHistStepData.clear()
+ def _savePreviusHist(self, newHist, oldHist):
+ newHistStep = False
+ histStepNum = 1
+ for line in oldHist.readlines():
+ if not line.strip():
+ newHistStep = True
+ continue
+ if newHistStep:
+ line = line.split("=")
+ line[1] = str(histStepNum)
+ line = "=".join(line)
+ if histStepNum >= self.maxHistSteps:
+ self.histStepsNum = histStepNum + 1
+ return
+ histStepNum += 1
+ newHist.write('%s%s%s' % (os.linesep, line, os.linesep))
+ else:
+ newHist.write('%s' % line)
+ def _saveNewHistStep(self, newHist):
+ newHist.write('%s%s%s' % (os.linesep, "history step=0", os.linesep))
+ for key in self.newHistStepData.keys():
+ subkeys = self.newHistStepData[key].keys()
+ newHist.write('%s%s' % (key, self.sep))
+ for idx in range(len(subkeys)):
+ value = self.newHistStepData[key][subkeys[idx]]
+ if type(value) == types.DictType:
+ if idx > 0:
+ newHist.write('%s%s%s' % (os.linesep, key, self.sep))
+ newHist.write('%s%s' % (subkeys[idx], self.sep))
+ kvalues = self.newHistStepData[key][subkeys[idx]].keys()
+ srange = range(len(kvalues))
+ for sidx in srange:
+ svalue = self._parseValue(self.newHistStepData[key][subkeys[idx]][kvalues[sidx]])
+ newHist.write('%s%s%s' % (kvalues[sidx], self.sep, svalue))
+ if sidx < len(kvalues) - 1:
+ newHist.write('%s' % self.sep)
+ else:
+ if idx > 0 and \
+ type( self.newHistStepData[key][subkeys[idx - 1]]) == types.DictType:
+ value = self._parseValue(self.newHistStepData[key][subkeys[idx]])
+ newHist.write('%s%s%s' % (subkeys[idx], self.sep, value))
+ if idx < len(subkeys) - 1 and \
+ type(self.newHistStepData[key][subkeys[idx + 1]]) != types.DictType:
+ newHist.write(os.linesep)
+ self.histStepsNum = 1
+ def _parseValue(self, value, read = False):
+ if read: # -> read data (cast values)
+ if value:
+ if value[0] == '[' and value[-1] == ']':# TODO
+ value = value[1:-1].split(',')
+ value = map(self._castValue, value)
+ return value
+ if value == 'True':
+ value = True
+ elif value == 'False':
+ value = False
+ elif value == 'None':
+ value = None
+ elif ':' in value: # -> color
+ try:
+ value = tuple(map(int, value.split(':')))
+ except ValueError: # -> string
+ pass
+ else:
+ try:
+ value = int(value)
+ try:
+ value = float(value)
+ pass
+ else: # -> write data
+ if type(value) == type(()): # -> color
+ value = str(value[0]) + ':' +\
+ str(value[1]) + ':' + \
+ str(value[2])
+ return value
+ def _castValue(self, value):
+ try:
+ try:
+ return value
+ def _getHistStepData(self, histStep):
+ hist = open(self.histFile)
+ isSearchedHistStep = False
+ for line in hist.readlines():
+ if not line.strip() and isSearchedHistStep:
+ break
+ elif not line.strip():
+ continue
+ elif isSearchedHistStep:
+ self._parseLine(line)
+ if newHistStep:
+ if int(line[1]) == histStep:
+ isSearchedHistStep = True
+ hist.close()
+ return self.currHistStepData
+ def _parseLine(self, line):
+ line = line.rstrip('%s' % os.linesep).split(self.sep)
+ key = line[0]
+ kv = line[1:]
+ idx = 0
+ subkeyMaster = None
+ if len(kv) % 2 != 0: # multiple (e.g. nviz)
+ subkeyMaster = kv[0]
+ del kv[0]
+ idx = 0
+ while idx < len(kv):
+ if subkeyMaster:
+ subkey = [subkeyMaster, kv[idx]]
+ else:
+ subkey = kv[idx]
+ value = kv[idx+1]
+ value = self._parseValue(value, read = True)
+ if key not in self.currHistStepData:
+ self.currHistStepData[key] = {}
+ if subkey[0] not in self.currHistStepData[key]:
+ self.currHistStepData[key][subkey[0]] = {}
+ self.currHistStepData[key][subkey[0]][subkey[1]] = value
+ else:
+ self.currHistStepData[key][subkey] = value
+ idx += 2
#TODO ugly hack - just for GMConsole to be satisfied
class CmdPanelHack:
def createCmd(self, ignoreErrors = False, ignoreRequired = False):
Modified: grass-addons/grass7/gui/wxpython/wx.vnet/vnet/toolbars.py
--- grass-addons/grass7/gui/wxpython/wx.vnet/vnet/toolbars.py 2012-07-28 09:49:57 UTC (rev 52473)
+++ grass-addons/grass7/gui/wxpython/wx.vnet/vnet/toolbars.py 2012-07-28 10:45:00 UTC (rev 52474)
@@ -74,8 +74,8 @@
choices.append(self.parent.vnetParams[moduleName]['label'])
self.anChoice = wx.ComboBox(parent = self, id = wx.ID_ANY,
- choices = choices,
- style = wx.CB_READONLY, size = (200, -1))
+ choices = choices,
+ style = wx.CB_READONLY, size = (180, -1))
self.anChoice.SetSelection(0)
self.anChoiceId = self.AddControl(self.anChoice)
@@ -85,6 +85,7 @@
self.anChoice.Hide()
self.anChoice.Show()
+ self.UpdateUndoRedo()
# realize the toolbar
self.Realize()
@@ -94,6 +95,10 @@
icons = {
'run' : MetaIcon(img = 'execute',
label = _('Execute analysis')),
+ 'undo' : MetaIcon(img = 'undo',
+ label = _('Go to previous analysis result')),
+ 'redo' : MetaIcon(img = 'redo',
+ label = _('Go to next analysis result')),
'showResult' : MetaIcon(img = 'layer-add',
label = _("Show analysis result")),
'saveTempLayer' : MetaIcon(img = 'map-export',
@@ -105,7 +110,11 @@
("run", icons['run'],
self.parent.OnAnalyze),
#("showResult", icons['showResult'], TODO
- #self.parent.OnShowResult, wx.ITEM_CHECK),
+ #self.parent.OnShowResult, wx.ITEM_CHECK),
+ ("undo", icons['undo'],
+ self.parent.OnUndo),
+ ("redo", icons['redo'],
+ self.parent.OnRedo),
("saveTempLayer", icons['saveTempLayer'],
self.parent.OnSaveTmpLayer),
('settings', icons["settings"],
@@ -113,3 +122,15 @@
("quit", BaseIcons['quit'],
self.parent.OnCloseDialog)
+ def UpdateUndoRedo(self):
+ if self.parent.history.GetCurrHistStep() >= self.parent.history.GetStepsNum() - 2:
+ self.Enable("undo", False)
+ else:
+ self.Enable("undo", True)
+ if self.parent.history.GetCurrHistStep() <= 0:
+ self.Enable("redo", False)
+ else:
+ self.Enable("redo", True)
\ No newline at end of file
Modified: grass-addons/grass7/gui/wxpython/wx.vnet/vnet/widgets.py
--- grass-addons/grass7/gui/wxpython/wx.vnet/vnet/widgets.py 2012-07-28 09:49:57 UTC (rev 52473)
+++ grass-addons/grass7/gui/wxpython/wx.vnet/vnet/widgets.py 2012-07-28 10:45:00 UTC (rev 52474)
@@ -223,7 +223,7 @@
def ClearItem(self, event):
""""! Clears all values in selected item of points list and unchecks it."""
- if self.selected == wx.NOT_FOUN:
+ if self.selected == wx.NOT_FOUND:
return
index = self.selected
i = 0
