[GRASS-SVN] r52480 - grass-addons/grass7/imagery/i.segment
svn_grass at osgeo.org
Mon Jul 30 20:56:38 PDT 2012
Author: momsen
Date: 2012-07-30 20:56:38 -0700 (Mon, 30 Jul 2012)
New Revision: 52480
grass-addons/grass7/imagery/i.segment/create_isegs.c
grass-addons/grass7/imagery/i.segment/iseg.h
grass-addons/grass7/imagery/i.segment/open_files.c
grass-addons/grass7/imagery/i.segment/parse_args.c
grass-addons/grass7/imagery/i.segment/write_output.c
iseg moved from RAM to SEG. Seeds have been implemented. Seeded segments will merge with each other.
Modified: grass-addons/grass7/imagery/i.segment/create_isegs.c
--- grass-addons/grass7/imagery/i.segment/create_isegs.c 2012-07-30 16:53:28 UTC (rev 52479)
+++ grass-addons/grass7/imagery/i.segment/create_isegs.c 2012-07-31 03:56:38 UTC (rev 52480)
@@ -12,8 +12,9 @@
#include <grass/rbtree.h> /* Red Black Tree library functions */
#include "iseg.h"
+#include <time.h> //todo polish...remove at end
#ifdef DEBUG
-#include <time.h>
#include <limits.h>
#endif
@@ -102,15 +103,21 @@
FLAG_SET(files->null_flag, row, col);
- G_debug(1, "minrow: %d, maxrow: %d, mincol: %d, maxcol: %d",
- files->minrow, files->maxrow, files->mincol,
- files->maxcol);
/* clear candidate flag, so only need to reset the processing area on each iteration. todo polish, can be removed after all loops only cover the processing area */
flag_clear_all(files->candidate_flag);
} /* end of else, set up for bounded segmentation */
+ /* consider maxrow/maxcol as nrow, ncol, loops will have: row < maxrow
+ * so need to increment by one */
+ files->maxrow++;
+ files->maxcol++;
+ G_debug(1,
+ "minrow: %d, maxrow: %d, nrows: %d, mincol: %d, maxcol: %d, ncols: %d",
+ files->minrow, files->maxrow, files->nrows, files->mincol,
+ files->maxcol, files->ncols);
/* run the segmentation algorithm */
if (functions->method == 1) {
@@ -174,10 +181,12 @@
/* idea is for large maps, if the width of SEG tiles in RAM is less than the width of the map, this should avoid a lot of I/O */
/* this is probably closer to a z-order curve then peano order. */
+ s = -1;
/*blank slate */
for (row = 0; row < files->nrows; row++) {
for (col = 0; col < files->ncols; col++) {
- files->iseg[row][col] = -1;
+ //files->iseg[row][col] = -1;
+ segment_put(&files->iseg_seg, (void *)s, row, col);
s = 0;
@@ -203,7 +212,8 @@
j--;
col = col | (1 & (i >> j));
G_message("Done: i: %li, row: %d, col: %d", i, row, col);
- files->iseg[row][col] = s;
+ //~ files->iseg[row][col] = s;
s++;
@@ -375,7 +385,9 @@
/*files->out_val[0] = files->out_val[0]; *//*segment number *//* just copying the map for testing. */
- files->iseg[row][col] = col + row;
+ //~ files->iseg[row][col] = col + row;
+ //todo need variable..
+ //segment_put(&files->iseg_seg, (void *)s, row, col);
G_percent(row, files->nrows, 1);
@@ -456,7 +468,8 @@
start = clock();
for (i = 0; i < max; i++) {
- temp = files->iseg[12][12];
+ //~ temp = files->iseg[12][12];
+ //todo
end = clock();
cpu_time_used = ((double)(end - start)) / CLOCKS_PER_SEC;
@@ -730,13 +743,13 @@
int get_segID_RAM(struct files *files, int row, int col)
- return files->iseg[row][col];
+ return 0; //todo... segment_put(&files->iseg_seg, (void *)s, row, col); files->iseg[row][col];
#endif
int region_growing(struct files *files, struct functions *functions)
- int row, col, t;
+ int row, col, t, testing; //todo remove testing
double threshold, Ri_similarity, Rk_similarity, tempsim;
int endflag; /* =TRUE if there were no merges on that processing iteration */
int pathflag; /* =TRUE if we didn't find mutual neighbors, and should continue with Rk */
@@ -744,6 +757,16 @@
*Rc_head, *Rc_tail, *Rcn_head, *current, *newpixel, *Ri_bestn;
int Ri_count, Rk_count, Rc_count; /* number of pixels/cells in Ri and Rk */
+ //todo polish, remove or comment when done?
+ clock_t start, end;
+ clock_t merge_start, merge_end;
+ double merge_accum, merge_lap;
+ clock_t fn_start, fn_end;
+ double fn_accum, fn_lap;
+ merge_accum = fn_accum = 0;
+ start = clock();
/* files->token has the "link_head" for linkm: linked list memory allocation.
* 4 linked lists of pixels:
@@ -760,7 +783,7 @@
t = 1;
files->candidate_count = 0;
- /*set next pointers to null. */
+ /*set linked list head pointers to null. */
Ri_head = NULL;
Rk_head = NULL;
Rin_head = NULL;
@@ -775,6 +798,7 @@
G_debug(3, "####### Starting outer do loop! t = %d #######", t);
/* todo, delete this? G_verbose_message("Pass %d: ", t); */
+ fprintf(stdout, "pass %d\n", t);
G_percent(t, functions->end_t, 1);
threshold = functions->threshold; /* TODO, consider making this a function of t. */
@@ -792,7 +816,7 @@
/*check each pixel, start the processing only if it is a candidate pixel */
+ //if (col == 3) return TRUE;
G_debug(4, "Starting pixel from next row/col, not from Rk");
if (FLAG_GET(files->candidate_flag, row, col)) {
@@ -820,14 +844,23 @@
G_debug(4, "Next starting pixel: row, %d, col, %d",
Ri_head->row, Ri_head->col);
+ pathflag = FALSE;
/* find segment neighbors, if we don't already have them */
if (Rin_head == NULL) {
+ fn_start = clock();
if (find_segment_neighbors
(&Ri_head, &Rin_head, &Ri_count, files,
functions) != TRUE) {
G_fatal_error
("find_segment_neighbors() failed");
+ fn_end = clock();
+ fn_lap =
+ ((double)(fn_end - fn_start)) /
+ CLOCKS_PER_SEC;
+ fn_accum += fn_lap;
+ fprintf(stdout, "fsn(Ri): %g\t", fn_lap);
if (Rin_head != NULL) { /*found neighbors, find best neighbor then see if is mutually best neighbor */
@@ -921,23 +954,31 @@
"Lowest Ri_similarity = %g, for neighbor pixel row: %d col: %d",
Ri_similarity, Ri_bestn->row,
Ri_bestn->col);
-//if bounds map, can't check if it is a candidate. TODO better way to include this check after decide on using the candidate flag here.
-if(files->seeds_map == NULL){
- //todo this "limited" flag will probably be removed? Then this entire if section could be removed if we always allow multiple merges per pass?
- if ((functions->limited == TRUE) && !
- (FLAG_GET
- (files->candidate_flag, Ri_bestn->row,
- Ri_bestn->col))) {
- /* this check is important:
- * best neighbor is not a valid candidate, was already merged earlier in this time step */
- Ri_bestn = NULL;
- pathflag = FALSE;
+ //if seeds map, can't check if it is a candidate. TODO better way to include this check after decide on using the candidate flag here.
+ if (files->seeds_map == NULL) {
+ //todo this "limited" flag will probably be removed? Then this entire if section could be removed if we always allow multiple merges per pass?
+ if ((functions->limited == TRUE) && !
+ (FLAG_GET
+ (files->candidate_flag,
+ Ri_bestn->row, Ri_bestn->col))) {
+ /* this check is important:
+ * best neighbor is not a valid candidate, was already merged earlier in this time step */
+ Ri_bestn = NULL;
+ //pathflag = FALSE;
if (Ri_bestn != NULL && Ri_similarity < threshold) { /* small TODO: should this be < or <= for threshold? */
/* Rk starts from Ri's best neighbor */
+ if (Rk_head) {
+ G_warning("Rk_head is not NULL!");
+ my_dispose_list(files->token, &Rk_head);
+ if (Rkn_head) {
+ G_warning("Rkn_head is not NULL!");
+ my_dispose_list(files->token, &Rkn_head);
Rk_count = 1;
newpixel =
(struct pixels *)link_new(files->token);
@@ -983,10 +1024,22 @@
} /* have checked all of Rk's neighbors */
if (Rk_similarity == Ri_similarity) { /* mutually most similar neighbors */
+ segment_get(&files->iseg_seg, &testing,
+ Ri_head->row, Ri_head->col);
+ //~ G_message("\t\tbefore call merge()... testing: %d, Ri_head->row: %d, Ri_head->col: %d", testing, Ri_head->row, Ri_head->col);
+ merge_start = clock();
merge_values(Ri_head, Rk_head, Ri_count,
Rk_count, files);
+ merge_end = clock();
+ merge_lap =
+ ((double)(merge_end - merge_start)) /
+ CLOCKS_PER_SEC;
+ merge_accum += merge_lap;
+ fprintf(stdout, "merge time: %g\n",
+ merge_lap);
endflag = FALSE; /* we've made at least one merge, so want another t iteration */
- pathflag = FALSE; /* go to next row,column pixel - end of Rk -> Ri chain since we found mutual best neighbors */
+ //pathflag = FALSE; /* go to next row,column pixel - end of Rk -> Ri chain since we found mutual best neighbors */
else { /* they weren't mutually best neighbors */
G_debug(4,
@@ -997,6 +1050,11 @@
set_candidate_flag(Ri_head, FALSE, files);
G_debug(4, "line 247, \t\t\t\tcc = %d",
files->candidate_count);
+ if (!(FLAG_GET
+ Rk_head->row, Rk_head->col)))
+ pathflag = TRUE;
} /* end if (Ri_bestn != NULL && Ri_similarity < threshold) */
else {
@@ -1008,13 +1066,13 @@
G_debug(4,
"3b Ri's best neighbor was not valid candidate, or their similarity was > threshold");
- pathflag = FALSE;
} /* end if(Rin_head != NULL) */
else { /* Ri didn't have a neighbor */
G_debug(4, "Segment had no neighbors");
- pathflag = FALSE;
G_debug(4, "line 176, \t\t\t\tcc = %d",
@@ -1188,6 +1246,11 @@
if (t > 2)
G_verbose_message("temporary(?) message, number of passes: %d",
t - 1);
+ end = clock();
+ fprintf(stdout, "time spent merging: %g\n", merge_accum);
+ fprintf(stdout, "time spent finding neighbors: %g\n", fn_accum);
+ fprintf(stdout, "total time: %g\n",
+ ((double)(end - start) / CLOCKS_PER_SEC));
return TRUE;
@@ -1196,7 +1259,7 @@
struct pixels **neighbors_head, int *seg_count,
- int n, current_seg_ID, Ri_seg_ID = -1;
+ int n, current_seg_ID, R_iseg = -1;
struct pixels *newpixel, *current, *to_check, tree_pix; /* need to check the pixel neighbors of to_check */
int pixel_neighbors[8][2];
struct RB_TREE *no_check_tree; /* pixels that should no longer be checked on this current find_neighbors() run */
@@ -1225,7 +1288,13 @@
/* *** initialize data *** */
- Ri_seg_ID = files->iseg[(*R_head)->row][(*R_head)->col];
+ //Ri_seg_ID = files->iseg[(*R_head)->row][(*R_head)->col];
+ segment_get(&files->iseg_seg, &R_iseg, (*R_head)->row, (*R_head)->col);
+ if (R_iseg == 0)
+ R_iseg = -1; /* with seeds, all non-seed pixels are assigned to segment 0. But we don't want to consider the others as part of the same segment. */
+ //~ G_message("fpn() for iseg: %d", R_iseg);
no_check_tree = rbtree_create(compare_pixels, sizeof(struct pixels));
known_iseg = rbtree_create(compare_ids, sizeof(int));
to_check = NULL;
@@ -1299,17 +1368,18 @@
rbtree_find(no_check_tree, &tree_pix));
if (rbtree_find(no_check_tree, &tree_pix) == FALSE) { /* want to check this neighbor */
- current_seg_ID =
- files->iseg[pixel_neighbors[n][0]][pixel_neighbors[n][1]];
+ segment_get(&files->iseg_seg, ¤t_seg_ID,
+ pixel_neighbors[n][0], pixel_neighbors[n][1]);
+ //current_seg_ID = files->iseg[pixel_neighbors[n][0]][pixel_neighbors[n][1]];
rbtree_insert(no_check_tree, &tree_pix); /* don't check it again */
- G_debug(5, "\tfiles->iseg[][] = %d Ri_seg_ID = %d",
- [pixel_neighbors[n]
- [1]], Ri_seg_ID);
+ //~ G_debug(5, "\tfiles->iseg[][] = %d Ri_seg_ID = %d",
+ //~ files->iseg[pixel_neighbors[n][0]]
+ //~ [pixel_neighbors[n]
+ //~ [1]], Ri_seg_ID);
- if (current_seg_ID == Ri_seg_ID) { /* pixel is member of current segment, add to R */
+ if (current_seg_ID == R_iseg) { /* pixel is member of current segment, add to R */
G_debug(5, "\tputing pixel_neighbor in Ri");
/* put pixel_neighbor[n] in Ri */
newpixel = (struct pixels *)link_new(files->token);
@@ -1330,9 +1400,10 @@
else { /* segment id's were different */
if (!rbtree_find(known_iseg, ¤t_seg_ID)) { /* we don't have any neighbors yet from this segment */
- /* add to known neighbors list */
- rbtree_insert(known_iseg, ¤t_seg_ID); /* todo: could I just try to insert it, if it fails I know it is already there?
+ if (current_seg_ID != 0)
+ /* with seeds, non seed pixels are defaulted to zero. Should we use null instead?? then could skip this check? Or we couldn't insert it??? */
+ /* add to known neighbors list */
+ rbtree_insert(known_iseg, ¤t_seg_ID); /* todo: could I just try to insert it, if it fails I know it is already there?
* I guess it would depend on how much faster the find() is, and what fraction of the
* neighbors are in a duplicate segment... */
@@ -1448,10 +1519,29 @@
+ In the eCognition literature, we find that the key factor in the
+ multi-scale segmentation algorithm used by Definiens is the scale
+ factor f:
+ f = W.Hcolor + (1 - W).Hshape
+ Hcolor = sum(b = 1:nbands)(Wb.SigmaB)
+ Hshape = Ws.Hcompact + (1 - Ws).Hsmooth
+ Hcompact = PL/sqrt(Npx)
+ Hsmooth = PL/Pbbox
+ Where W is a user-defined weight of importance of object radiometry vs
+ shape (usually .9 vs .1), Wb is the weigh given to band B, SigmaB is
+ the std dev of the object for band b, Ws is a user-defined weight
+ giving the importance of compactedness vs smoothness, PL is the
+ perimeter lenght of the object, Npx the number of pixels within the
+ object, and Pbbox the perimeter of the bounding box of the object.
int merge_values(struct pixels *Ri_head, struct pixels *Rk_head,
int Ri_count, int Rk_count, struct files *files)
- int n;
+ int n, Ri_iseg = 42, Rk_iseg = 43;
struct pixels *current;
/*get input values *//*TODO polish, confirm if we can assume we already have bands_val for Ri, so don't need to segment_get() again? note...current very_close implementation requires getting this value again... */
@@ -1460,6 +1550,15 @@
segment_get(&files->bands_seg, (void *)files->second_val,
Rk_head->row, Rk_head->col);
+ segment_get(&files->iseg_seg, &Rk_iseg, Rk_head->row, Rk_head->col);
+ segment_get(&files->iseg_seg, &Ri_iseg, Ri_head->row, Ri_head->col);
+ /* todo polish, maybe we have some of these values already? Or they should be stored in files structure? */
+ // G_message("Ri_iseg get(): %d", segment_get(&files->iseg_seg, &Ri_iseg, Ri_head->row, Ri_head->col));
+ //~ G_message("Rk_iseg get(): %d", segment_get(&files->iseg_seg, &Rk_iseg, Rk_head->row, Rk_head->col));
+ //~ G_message("Ri_iseg get(): %d", segment_get(&files->iseg_seg, &Ri_iseg, Ri_head->row, Ri_head->col));
+ //~ G_message("here is what I have: Ri_iseg: %d, Ri_head->row: %d, Ri_head->col: %d", Ri_iseg, Ri_head->row, Ri_head->col);
+ //~ G_message("here is what I have: Rk_iseg: %d, Rk_head->row: %d, Rk_head->col: %d", Rk_iseg, Rk_head->row, Rk_head->col);
for (n = 0; n < files->nbands; n++) {
files->bands_val[n] =
(files->bands_val[n] * Ri_count +
@@ -1468,9 +1567,14 @@
/* update segment number and candidate flag ==0 */
- G_debug(4, "\t\tMerging, segment number: %d, including pixels:",
- files->iseg[Ri_head->row][Ri_head->col]);
+ //~ G_debug(4, "\t\tMerging, segment number: %d, including pixels:",
+ //~ files->iseg[Ri_head->row][Ri_head->col]);
+ fprintf(stdout,
+ "merging Ri (pixel count): %d (%d) with Rk (count): %d (%d).\t",
+ Ri_iseg, Ri_count, Rk_iseg, Rk_count);
+ //~ G_message("Ri_head->row: %d, Ri_head->col: %d", Ri_head->row, Ri_head->col);
/* for each member of Ri and Rk, write new average bands values and segment values */
for (current = Ri_head; current != NULL; current = current->next) {
segment_put(&files->bands_seg, (void *)files->bands_val,
@@ -1483,8 +1587,9 @@
for (current = Rk_head; current != NULL; current = current->next) {
current->row, current->col);
- files->iseg[current->row][current->col] =
- files->iseg[Ri_head->row][Ri_head->col];
+ //~ files->iseg[current->row][current->col] =
+ //~ files->iseg[Ri_head->row][Ri_head->col];
+ segment_put(&files->iseg_seg, &Ri_iseg, current->row, current->col);
FLAG_UNSET(files->candidate_flag, current->row, current->col);
files->candidate_count--;
G_debug(4, "line 516, \t\t\t\tcc = %d", files->candidate_count);
@@ -1492,9 +1597,14 @@
- /* merged two segments, decrement count */
- files->nsegs--;
- /* todo seeds: need if statement here, if merging "unseeded" pixel, don't want to decrement. */
+ /* merged two segments, decrement count
+ * if seeds were provided, need to adjust the candidate_count*/
+ files->nsegs--;
+ else {
+ files->candidate_count += Ri_count + Rk_count - 1;
+ /* todo if allow seeded segments to merge, need to decrement nsegs if Rk_count = 1 and it isn't a seed */
return TRUE;
@@ -1580,57 +1690,58 @@
/* Set candidate flag to true/1 or false/0 for all pixels in current processing area
- * checks for NULL flag and if it is in current "polygon" if a bounds map is given */
+ * checks for NULL flag and if it is in current "polygon" if a bounds map is given
+ * checks if seeds were given */
int set_all_candidate_flags(struct files *files)
int row, col;
- if(files->seeds_map == NULL) { /* entire map is considered as candidates */
- //~ if (files->bounds_map == NULL) { /* process entire raster */
- for (row = files->minrow; row < files->maxrow; row++) {
- for (col = files->mincol; col < files->maxcol; col++) {
- /* TODO: if we are starting from seeds...and only allow merges between unassigned pixels
- * and seeds/existing segments, then this needs an if (and will be very inefficient)
- * maybe consider the sorted array, btree, map... but the number of seeds could still be high for a large map */
- /* MM: could be solved/not necessary if all pixels of an existing segment have the same ID */
- if (!(FLAG_GET(files->null_flag, row, col))) {
- FLAG_SET(files->candidate_flag, row, col);
- files->candidate_count++;
+ if (files->seeds_map == NULL) { /* entire map is considered as candidates */
+ //G_message("No seeds map, setting all pixels to be candidates");
+ //~ if (files->bounds_map == NULL) { /* process entire raster */
+ for (row = files->minrow; row < files->maxrow; row++) {
+ for (col = files->mincol; col < files->maxcol; col++) {
+ /* TODO: if we are starting from seeds...and only allow merges between unassigned pixels
+ * and seeds/existing segments, then this needs an if (and will be very inefficient)
+ * maybe consider the sorted array, btree, map... but the number of seeds could still be high for a large map */
+ /* MM: could be solved/not necessary if all pixels of an existing segment have the same ID */
+ if (!(FLAG_GET(files->null_flag, row, col))) {
+ FLAG_SET(files->candidate_flag, row, col);
+ files->candidate_count++;
+ else
+ FLAG_UNSET(files->candidate_flag, row, col);
- else
- FLAG_UNSET(files->candidate_flag, row, col);
+ //~ else { /* process part of the raster, polygon constraints/boundaries */
+ //~ for (row = files->minrow; row < files->maxrow; row++) {
+ //~ for (col = files->mincol; col < files->maxcol; col++) {
+ //~ if (!(FLAG_GET(files->in_bounds_flag, row, col))) {
+ //~ FLAG_SET(files->candidate_flag, row, col);
+ //~ files->candidate_count++;
+ //~ else
+ //~ FLAG_UNSET(files->candidate_flag, row, col);
- //~ else { /* process part of the raster, polygon constraints/boundaries */
- //~ for (row = files->minrow; row < files->maxrow; row++) {
- //~ for (col = files->mincol; col < files->maxcol; col++) {
- //~ if (!(FLAG_GET(files->in_bounds_flag, row, col))) {
- //~ FLAG_SET(files->candidate_flag, row, col);
- //~ files->candidate_count++;
- //~ else
- //~ FLAG_UNSET(files->candidate_flag, row, col);
- else { /* seeds were provided */
+ else { /* seeds were provided */
+ //G_message("seeds provided, just setting those pixels as candidates");
- if ((FLAG_GET(files->seeds_flag, row, col))) {
- files->candidate_count++; //TODO, how deal with this...
+ if ((FLAG_GET(files->seeds_flag, row, col))) {
+ files->candidate_count++; //TODO, how deal with this...
+ else
+ FLAG_UNSET(files->candidate_flag, row, col); //todo maybe can skip this...
- else
- FLAG_UNSET(files->candidate_flag, row, col); //todo maybe can skip this...
return TRUE;
Modified: grass-addons/grass7/imagery/i.segment/iseg.h
--- grass-addons/grass7/imagery/i.segment/iseg.h 2012-07-30 16:53:28 UTC (rev 52479)
+++ grass-addons/grass7/imagery/i.segment/iseg.h 2012-07-31 03:56:38 UTC (rev 52480)
@@ -20,6 +20,9 @@
* it also add some while loops that just have G_debug statements in them. */
/* #define DEBUG */
+/* PROFILE will add some rough time checks for finding neighbors and merging. */
+/* #define PROFILE */
/* pixel stack */
struct pixels
@@ -40,7 +43,7 @@
/* files */
char *out_name; /* name of output raster map */
- const char *seeds_map, *seeds_mapset, *bounds_map, *bounds_mapset; /* optional segment seeds and polygon constraints/boundaries */
+ const char *seeds_map, *seeds_mapset, *bounds_map, *bounds_mapset; /* optional segment seeds and polygon constraints/boundaries */
char *out_band; /* for debug */
/* file processing */
@@ -53,7 +56,9 @@
int minrow, maxrow, mincol, maxcol;
/* results */
- int **iseg; /* segment ID assignment */
+ SEGMENT iseg_seg; /* segment ID assignment */
+ // int iseg_val;
+ // int **iseg; /* segment ID assignment */
int nsegs; /* number of segments */
/* processing flags */
Modified: grass-addons/grass7/imagery/i.segment/open_files.c
--- grass-addons/grass7/imagery/i.segment/open_files.c 2012-07-30 16:53:28 UTC (rev 52479)
+++ grass-addons/grass7/imagery/i.segment/open_files.c 2012-07-31 03:56:38 UTC (rev 52480)
@@ -14,7 +14,8 @@
int i, n, s, row, col, srows, scols, inlen, nseg;
DCELL **inbuf; /* buffer array, to store lines from each of the imagery group rasters */
CELL *boundsbuf;
- void *seedsbuf; /* todo. correct data type when allowing any data type? */
+ void *seedsbuf, *ptr; /* todo. correct data type when allowing any data type? */
+ size_t ptrsize;
RASTER_MAP_TYPE data_type;
struct FPRange *fp_range; /* for getting min/max values on each input raster */
DCELL *min, *max;
@@ -39,7 +40,7 @@
files->candidate_flag = flag_create(files->nrows, files->ncols);
if (files->bounds_map != NULL)
files->orig_null_flag = flag_create(files->nrows, files->ncols);
- if (files->seeds_map != NULL)
+ if (files->seeds_map != NULL)
files->seeds_flag = flag_create(files->nrows, files->ncols);
/* references for segmentation library: i.cost r.watershed/seg and http://grass.osgeo.org/programming7/segmentlib.html */
@@ -73,6 +74,14 @@
Ref.file[n].mapset);
+ /* open seeds raster */
+ if (files->seeds_map != NULL) {
+ seeds_fd = Rast_open_old(files->seeds_map, "");
+ data_type = Rast_get_map_type(seeds_fd);
+ seedsbuf = Rast_allocate_buf(data_type);
+ ptrsize = Rast_cell_size(data_type);
/* Get min/max values of each input raster for scaling */
if (files->weighted == FALSE) { /*default, we will scale */
@@ -100,7 +109,7 @@
scols = 64;
/* TODO: make calculations for this, check i.cost and i.watershed */
- nseg = 16;
+ nseg = 1000; //16;
/* ******* create temporary segmentation files ********* */
@@ -123,24 +132,34 @@
files->bands_val = (double *)G_malloc(inlen);
files->second_val = (double *)G_malloc(inlen);
- files->iseg = G_malloc(files->nrows * sizeof(int *));
- for (i = 0; i < files->nrows; i++)
- files->iseg[i] = G_malloc(files->ncols * sizeof(int));
+ //~ files->iseg = G_malloc(files->nrows * sizeof(int *));
+ //~ for (i = 0; i < files->nrows; i++)
+ //~ files->iseg[i] = G_malloc(files->ncols * sizeof(int));
+ //~ /*check the last one to make sure there was enough memory */
+ //~ if (files->iseg[i - 1] != NULL) { /* everything is OK, and assume all previous memory allocations are OK too. */
+ //~ else
+ //~ G_fatal_error(_("Unable to allocate memory for initial segment ID's"));
- /*check the last one to make sure there was enough memory */
- if (files->iseg[i - 1] != NULL) { /* everything is OK, and assume all previous memory allocations are OK too. */
- else
+ if (segment_open
+ (&files->iseg_seg, G_tempfile(), files->nrows, files->ncols, srows,
+ scols, inlen, nseg) != TRUE)
+ /* NOTE: SEGMENT file should be initialized to zeros for all data. TODO double check this. */
/* ******** load input bands to segment structure and fill iseg array ******** */
G_debug(1, "Reading input rasters into segmentation data files...");
- s = 1; /* initial segment ID */
+ s = 0; /* initial segment ID will be 1 */
for (n = 0; n < Ref.nfiles; n++) {
Rast_get_d_row(in_fd[n], inbuf[n], row);
+ Rast_get_row(seeds_fd, seedsbuf, row, data_type);
+ ptr = seedsbuf;
null_check = 1; /*Assume there is data */
@@ -154,44 +173,44 @@
segment_put(&files->bands_seg, (void *)files->bands_val, row, col); /* store input bands */
if (null_check != -1) { /*good pixel */
- files->iseg[row][col] = s; /*starting segment number TODO: for seeds this will be different */
FLAG_UNSET(files->null_flag, row, col); /*flag */
- s++; /* sequentially number all pixels with their own segment ID */
+ //G_message("Rast_is_null_value(&seedsbuf[col], data_type) = %d", Rast_is_null_value(&seedsbuf[col], data_type));
+ // if (Rast_is_null_value(&seedsbuf[col], data_type) == TRUE) //switched to ptr navigation... maybe I could have done &(seedsbuf[col]) ??
+ if (Rast_is_null_value(ptr, data_type) == TRUE) { /* TODO, compiler warnings:
+ * open_files.c:182:37: warning: dereferencing ‘void *’ pointer [enabled by default]
+ * open_files.c:182:27: warning: taking address of expression of type ‘void’ [enabled by default] */
+ // not needed, initialized to zero. files->iseg[row][col] = 0; /* place holder... todo, OK? */
+ FLAG_UNSET(files->seeds_flag, row, col); //todo shouldn't need to this, flag is initialized to zero?
+ else {
+ s++; /* sequentially number each seed pixel with its own segment ID */
+ FLAG_SET(files->seeds_flag, row, col); //todo might not need this... just use the zero as seg ID? If go this route, need to enforce constraints are positive integers.
+ //files->iseg[row][col] = s; /*starting segment number TODO: for seeds this will be different */
+ segment_put(&files->iseg_seg, &s, row, col);
+ G_message("set seed for row: %d, col: %d", row, col);
+ ptr = G_incr_void_ptr(ptr, ptrsize);
+ else { /* no seeds provided */
+ s++; /* sequentially number all pixels with their own segment ID */
+ segment_put(&files->iseg_seg, &s, row, col); /*starting segment number */
else { /*don't use this pixel */
- files->iseg[row][col] = -1; /* place holder...TODO this could be a conflict if constraints included a -1 */
+ //files->iseg[row][col] = -1; /* place holder...TODO this could be a conflict if constraints included a -1 ??? wrote that awhile ago...still true???*/
+ //TODO, do we need a -1 here? Or just leave as the zero it was initialized with? Need a -1 if we don't use the NULL_FLAG...
FLAG_SET(files->null_flag, row, col); /*flag */
/* number of initial segments, will decrement when merge */
- files->nsegs = s - 1;
+ files->nsegs = s;
- /* starting seeds */
- /* save as flag, will reset candidate flags to match seed flags on each iteration */
- if (files->seeds_map != NULL) {
- seeds_fd = Rast_open_old(files->seeds_map, "");
- data_type = Rast_get_map_type(seeds_fd);
- seedsbuf = Rast_allocate_buf(data_type);
- for (row = 0; row < files->nrows; row++) {
- Rast_get_row(seeds_fd, seedsbuf, row, data_type);
- for (col = 0; col < files->ncols; col++) {
- if (Rast_is_null_value(&seedsbuf[col], data_type) == TRUE) { /* TODO, compiler warnings:
- * open_files.c:182:37: warning: dereferencing ‘void *’ pointer [enabled by default]
- * open_files.c:182:27: warning: taking address of expression of type ‘void’ [enabled by default]
- FLAG_SET(files->seeds_flag, row, col);
- Rast_close(seeds_fd);
- G_free(seedsbuf);
/* bounds/constraints */
if (files->bounds_map != NULL) {
if (segment_open
@@ -229,11 +248,17 @@
G_debug(1, "no boundary constraint supplied.");
+ //~ for (row = 0; row < files->nrows; row++) {
+ //~ for (col = 0; col < files->ncols; col++) {
+ //~ segment_get(&files->iseg_seg, &s, row, col);
+ //~ G_message("row: %d, col: %d, iseg: %d", row, col, s);
/* other info */
files->candidate_count = 0; /* counter for remaining candidate pixels */
/* translate seeds to unique segments TODO MM mentioned it here... */
+ /* todo decide if we need to take the seeds value, and use it to start the segments... or if each pixel starts a unique segment. */
/* linked list memory management linkm */
link_set_chunk_size(100); /* TODO polish: fine tune this number */
@@ -247,6 +272,11 @@
Rast_close(in_fd[n]);
+ Rast_close(seeds_fd);
+ G_free(seedsbuf);
G_free(inbuf);
G_free(in_fd);
G_free(fp_range);
Modified: grass-addons/grass7/imagery/i.segment/parse_args.c
--- grass-addons/grass7/imagery/i.segment/parse_args.c 2012-07-30 16:53:28 UTC (rev 52479)
+++ grass-addons/grass7/imagery/i.segment/parse_args.c 2012-07-31 03:56:38 UTC (rev 52480)
@@ -182,8 +182,8 @@
G_fatal_error(_("Starting seeds map not found."));
//~ if (Rast_map_type(files->seeds_map, files->seeds_mapset) !=
- //~ CELL_TYPE) {
- //~ G_fatal_error(_("Starting seeds map must be CELL type (integers)"));
+ //~ CELL_TYPE) {
+ //~ G_fatal_error(_("Starting seeds map must be CELL type (integers)"));
//~ } //todo: don't need this check, want it for polygon constraints, but for seeds we are just looking for null vs. not null
Modified: grass-addons/grass7/imagery/i.segment/write_output.c
--- grass-addons/grass7/imagery/i.segment/write_output.c 2012-07-30 16:53:28 UTC (rev 52479)
+++ grass-addons/grass7/imagery/i.segment/write_output.c 2012-07-31 03:56:38 UTC (rev 52480)
@@ -24,6 +24,7 @@
/* force all data to disk */
segment_flush(&files->bands_seg);
+ segment_flush(&files->iseg_seg);
/* open output raster map */
G_debug(1, "preparing output raster");
@@ -39,7 +40,8 @@
segment_get(&files->bands_seg, (void *)files->bands_val, row,
col);
- outbuf[col] = files->iseg[row][col];
+ // outbuf[col] = files->iseg[row][col];
+ segment_get(&files->iseg_seg, &(outbuf[col]), row, col);
meanbuf[col] = files->bands_val[0];
@@ -91,9 +93,10 @@
G_free(files->second_val);
G_debug(1, "freeing iseg");
- G_free(files->iseg[i]);
- G_free(files->iseg);
+ //~ G_free(files->iseg[i]);
+ //~ G_free(files->iseg);
+ segment_close(&files->iseg_seg);
G_debug(1, "destroying flags");
flag_destroy(files->null_flag);
