[GRASS-SVN] r52489 - grass/trunk/lib/vector/rtree
Tue Jul 31 11:09:03 PDT 2012
Author: mmetz
Date: 2012-07-31 11:09:02 -0700 (Tue, 31 Jul 2012)
New Revision: 52489
   grass/trunk/lib/vector/rtree/index.c
   grass/trunk/lib/vector/rtree/index.h
   grass/trunk/lib/vector/rtree/indexf.c
   grass/trunk/lib/vector/rtree/indexm.c
   grass/trunk/lib/vector/rtree/node.c
   grass/trunk/lib/vector/rtree/rect.c
   grass/trunk/lib/vector/rtree/rtree.h
   grass/trunk/lib/vector/rtree/split.c
rtree optimizations
Modified: grass/trunk/lib/vector/rtree/index.c
--- grass/trunk/lib/vector/rtree/index.c	2012-07-31 18:06:18 UTC (rev 52488)
+++ grass/trunk/lib/vector/rtree/index.c	2012-07-31 18:09:02 UTC (rev 52489)
@@ -56,13 +56,13 @@
     new_rtree->free_nodes.alloc = 0;
     new_rtree->free_nodes.pos = NULL;
+    new_rtree->rectsize = new_rtree->nsides_alloc * sizeof(RectReal);
     new_rtree->nodesize = sizeof(struct RTree_Node) -
                           MAXCARD * sizeof(RectReal *) +
-			  MAXCARD * new_rtree->nsides_alloc * sizeof(RectReal);
+			  MAXCARD * new_rtree->rectsize;
     new_rtree->branchsize = sizeof(struct RTree_Branch) -
-                            sizeof(RectReal *) +
-			    new_rtree->nsides_alloc * sizeof(RectReal);
+                            sizeof(RectReal *) + new_rtree->rectsize;
     /* create empty root node */
     n = RTreeNewNode(new_rtree, 0);
Modified: grass/trunk/lib/vector/rtree/index.h
--- grass/trunk/lib/vector/rtree/index.h	2012-07-31 18:06:18 UTC (rev 52488)
+++ grass/trunk/lib/vector/rtree/index.h	2012-07-31 18:09:02 UTC (rev 52489)
@@ -75,7 +75,7 @@
 /* node.c */
 void RTreeNodeCover(struct RTree_Node *, struct RTree_Rect *, struct RTree *);
 int RTreeAddBranch(struct RTree_Branch *, struct RTree_Node *, struct RTree_Node **,
-            struct RTree_ListBranch **, struct RTree_Rect *, int *, struct RTree *);
+            struct RTree_ListBranch **, struct RTree_Rect *, char *, struct RTree *);
 int RTreePickBranch(struct RTree_Rect *, struct RTree_Node *, struct RTree *);
 void RTreeDisconnectBranch(struct RTree_Node *, int, struct RTree *);
 void RTreePrintNode(struct RTree_Node *, int, struct RTree *);
@@ -97,7 +97,7 @@
 | Copy second rectangle to first rectangle.
-#define RTreeCopyRect(r1, r2, t) memcpy((r1)->boundary, (r2)->boundary, (t)->nsides_alloc * sizeof(RectReal))
+#define RTreeCopyRect(r1, r2, t) memcpy((r1)->boundary, (r2)->boundary, (t)->rectsize)
 /* split.c */
Modified: grass/trunk/lib/vector/rtree/indexf.c
--- grass/trunk/lib/vector/rtree/indexf.c	2012-07-31 18:06:18 UTC (rev 52488)
+++ grass/trunk/lib/vector/rtree/indexf.c	2012-07-31 18:09:02 UTC (rev 52489)
@@ -40,7 +40,7 @@
 		 SearchHitCallback *shcb, void *cbarg)
     struct RTree_Node *n;
-    int hitCount = 0, found, currlevel;
+    int hitCount = 0, notfound, currlevel;
     int i;
     int top = 0;
     struct fstack *s = t->fs;
@@ -57,7 +57,7 @@
     while (top >= 0) {
 	if (s[top].sn.level > 0) {		/* this is an internal node in the tree */
 	    n = &(s[top].sn);
-	    found = 1;
+	    notfound = 1;
 	    currlevel = s[top].sn.level - 1;
 	    for (i = s[top].branch_id; i < t->nodecard; i++) {
 		if (s[top].sn.branch[i].child.pos > -1 &&
@@ -67,11 +67,11 @@
 		    s[top].pos = n->branch[i].child.pos;
 		    RTreeGetNode(&(s[top].sn), s[top].pos, currlevel, t);
 		    s[top].branch_id = 0;
-		    found = 0;
+		    notfound = 0;
 		    break;
-	    if (found) {
+	    if (notfound) {
 		/* nothing else found, go back up */
 		s[top].branch_id = t->nodecard;
 		top--;
@@ -110,7 +110,7 @@
 static int RTreeInsertRect2F(struct RTree_Rect *r, union RTree_Child child, int level,
 			     struct RTree_Node *newnode, off_t *newnode_pos,
 			     struct RTree *t,
-			     struct RTree_ListBranch **ee, int *overflow)
+			     struct RTree_ListBranch **ee, char *overflow)
     int i, currlevel;
     struct RTree_Rect *cover;
@@ -152,30 +152,22 @@
     /* Have reached level for insertion. Add rect, split if necessary */
-    if (s[top].sn.level == level) {
-	RTreeCopyRect(&(b->rect), r, t);
-	/* child field of leaves contains tid of data record */
-	b->child = child;
-	/* add branch, may split node or remove branches */
-	if (top)
-	    cover = &(s[top - 1].sn.branch[s[top - 1].branch_id].rect);
-	else
-	    cover = NULL;
-	result = RTreeAddBranch(b, &(s[top].sn), &n2, ee, cover, overflow, t);
-	/* write out new node if node was split */
-	if (result == 1) {
-	    *newnode_pos = RTreeGetNodePos(t);
-	    RTreeWriteNode(n2, t);
-	    t->n_nodes++;
-	/* update node */
-	RTreePutNode(&(s[top].sn), s[top].pos, t);
+    RTreeCopyRect(&(b->rect), r, t);
+    /* child field of leaves contains tid of data record */
+    b->child = child;
+    /* add branch, may split node or remove branches */
+    cover = NULL;
+    if (top)
+	cover = &(s[top - 1].sn.branch[s[top - 1].branch_id].rect);
+    result = RTreeAddBranch(b, &(s[top].sn), &n2, ee, cover, overflow, t);
+    /* write out new node if node was split */
+    if (result == 1) {
+	*newnode_pos = RTreeGetNodePos(t);
+	RTreeWriteNode(n2, t);
+	t->n_nodes++;
-    else {
-	/* Not supposed to happen */
-	assert(s[top].sn.level == level);
-	return 0;
+    /* update node */
+    RTreePutNode(&(s[top].sn), s[top].pos, t);
     /* go back up */
     while (top) {
@@ -204,10 +196,9 @@
 	    RTreeNodeCover(n2, &(b->rect), t);
+	    cover = NULL;
 	    if (top)
-	    else
-		cover = NULL;
@@ -239,8 +230,8 @@
                      struct RTree *t)
     struct RTree_ListBranch *e, *reInsertList = NULL;
-    int result;
-    int i, overflow[MAXLEVEL];
+    int i, result;
+    char overflow[MAXLEVEL];
     off_t newnode_pos = -1;
     static struct RTree_Node oldroot, newroot, newnode;
@@ -257,8 +248,7 @@
     /* R*-tree forced reinsertion: for each level only once */
-    for (i = 0; i < MAXLEVEL; i++)
-	overflow[i] = 1;
+    memset(overflow, 1, MAXLEVEL);
     result =
 	RTreeInsertRect2F(r, child, level, &newnode, &newnode_pos, t,
@@ -282,8 +272,11 @@
 	t->rootpos = RTreeGetNodePos(t);
 	RTreeWriteNode(&newroot, t);
 	t->n_nodes++;
-    else if (result == 2) {	/* branches were removed */
+	return result;
+    if (result == 2) {	/* branches were removed */
 	while (reInsertList) {
 	    /* get next branch in list */
 	    RTreeCopyBranch(b, &(reInsertList->b), t);
@@ -353,7 +346,7 @@
-    while (notfound) {
+    while (notfound && top >= 0) {
 	/* go down to level 0, remember path */
 	    n = &(s[top].sn);
@@ -497,8 +490,7 @@
 	return 0;
-    else {
-	return 1;
+    return 1;
Modified: grass/trunk/lib/vector/rtree/indexm.c
--- grass/trunk/lib/vector/rtree/indexm.c	2012-07-31 18:06:18 UTC (rev 52488)
+++ grass/trunk/lib/vector/rtree/indexm.c	2012-07-31 18:09:02 UTC (rev 52489)
@@ -36,7 +36,7 @@
-    int hitCount = 0, found;
+    int hitCount = 0, notfound;
     int i;
     int top = 0;
     struct mstack *s = t->ms;
@@ -52,7 +52,7 @@
     while (top >= 0) {
 	n = s[top].sn;
 	if (s[top].sn->level > 0) {	/* this is an internal node in the tree */
-	    found = 1;
+	    notfound = 1;
 		if (s[top].sn->branch[i].child.ptr &&
 		    RTreeOverlap(r, &(s[top].sn->branch[i].rect), t)) {
@@ -60,11 +60,11 @@
 		    /* add next node to stack */
 		    s[top].sn = n->branch[i].child.ptr;
-		    found = 0;
+		    notfound = 0;
 		    break;
-	    if (found) {
+	    if (notfound) {
 		top--;
@@ -103,7 +103,7 @@
 static int RTreeInsertRect2M(struct RTree_Rect *r, union RTree_Child child, int level,
 			     struct RTree_Node **newnode,
 			     struct RTree *t,
     int i;
     struct RTree_Node *n, *n2;
@@ -126,26 +126,18 @@
     /* Have reached level for insertion. Remove p rectangles or split */
-    if (s[top].sn->level == level) {
-	b->child = child;
-	if (top)
-	    cover = &(s[top - 1].sn->branch[s[top - 1].branch_id].rect);
-	else
-	    cover = NULL;
-	result = RTreeAddBranch(b, s[top].sn, &n2, ee, cover, overflow, t);
-	/* update node count */
-	    t->n_nodes++;
+    b->child = child;
+    cover = NULL;
+    if (top)
+	cover = &(s[top - 1].sn->branch[s[top - 1].branch_id].rect);
+    result = RTreeAddBranch(b, s[top].sn, &n2, ee, cover, overflow, t);
+    /* update node count */
+	t->n_nodes++;
-    else {
-	assert(0);
-	return 0;
     /* go back up */
     while (top) {
@@ -166,10 +158,9 @@
 	    RTreeNodeCover(b->child.ptr, &(b->rect), t);
+	    cover = NULL;
 	    if (top)
-	    else
-		cover = NULL;
 	    result =
@@ -200,12 +191,11 @@
     struct RTree_ListBranch *reInsertList = NULL;
     struct RTree_ListBranch *e;
     int result;
     struct RTree_Branch *b = &(t->tmpb1);
-	overflow[i] = 1;
     result =
 	RTreeInsertRect2M(r, child, level, &newnode, t, &reInsertList,
@@ -227,8 +217,11 @@
 	/* set new root node */
 	t->root = newroot;
 	t->n_nodes++;
+	return result;
@@ -287,7 +280,7 @@
     n = s[top].sn;
 	    n = s[top].sn;
@@ -308,7 +301,7 @@
 		top--;
-	    else		/* found a way down but not yet the item */
+	    else       /* found a way down but not yet the item */
 		notfound = 1;
 	else {
@@ -410,7 +403,6 @@
 	return 0;
-    else {
-	return 1;
+    return 1;
Modified: grass/trunk/lib/vector/rtree/node.c
--- grass/trunk/lib/vector/rtree/node.c	2012-07-31 18:06:18 UTC (rev 52488)
+++ grass/trunk/lib/vector/rtree/node.c	2012-07-31 18:09:02 UTC (rev 52489)
@@ -338,7 +338,7 @@
 static int RTreePartitionDist(struct dist *d, int first, int last)
-    int pivot, mid = (first + last) / 2;
+    int pivot, mid = ((first + last) >> 1);
     int larger, smaller;
     if (last - first == 1) {	/* only two items in list */
@@ -349,23 +349,19 @@
     /* Larger of two */
+    larger = pivot = mid;
+    smaller = first;
     if (d[first].distance > d[mid].distance) {
 	larger = pivot = first;
 	smaller = mid;
-    else {
-	larger = pivot = mid;
-	smaller = first;
     if (d[larger].distance > d[last].distance) {
 	/* larger is largest, get the larger of smaller and last */
+	pivot = last;
 	if (d[smaller].distance > d[last].distance) {
 	    pivot = smaller;
-	else {
-	    pivot = last;
     if (pivot != last) {
@@ -539,7 +535,7 @@
 int RTreeAddBranch(struct RTree_Branch *b, struct RTree_Node *n,
 		   struct RTree_Node **newnode, struct RTree_ListBranch **ee,
-		   struct RTree_Rect *cover, int *overflow, struct RTree *t)
+		   struct RTree_Rect *cover, char *overflow, struct RTree *t)
     int i, maxkids;
Modified: grass/trunk/lib/vector/rtree/rect.c
--- grass/trunk/lib/vector/rtree/rect.c	2012-07-31 18:06:18 UTC (rev 52488)
+++ grass/trunk/lib/vector/rtree/rect.c	2012-07-31 18:09:02 UTC (rev 52489)
@@ -37,7 +37,7 @@
 void RTreeNewRect(struct RTree_Rect *r, struct RTree *t)
-    r->boundary = (RectReal *)malloc((size_t) t->nsides_alloc * sizeof(RectReal));
+    r->boundary = (RectReal *)malloc(t->rectsize);
     assert(r->boundary);
@@ -48,8 +48,8 @@
     register int i;
-    for (i = 0; i < t->nsides_alloc; i++)
-	r->boundary[i] = (RectReal) 0;
+    for (i = 0; i < t->ndims; i++)
+	r->boundary[i] = r->boundary[i + t->ndims_alloc] = (RectReal) 0;
@@ -60,7 +60,7 @@
     register int i;
-    assert(r);
+    /* assert(r); */
     r->boundary[0] = (RectReal) 1;
     r->boundary[t->nsides - 1] = (RectReal) - 1;
@@ -160,7 +160,8 @@
     register int i;
     register RectReal volume = (RectReal) 1;
-    assert(r);
+    /* assert(r); */
     if (Undefined(r, t))
 	return (RectReal) 0;
@@ -245,9 +246,11 @@
     register int i;
     RectReal maxsize = (RectReal) 0, c_size;
-    assert(r);
+    /* assert(r); */
     for (i = 0; i < t->ndims; i++) {
 	c_size = r->boundary[i + NUMDIMS] - r->boundary[i];
 	if (c_size > maxsize)
@@ -264,18 +267,21 @@
 RectReal RTreeRectSphericalVolume(struct RTree_Rect *r, struct RTree *t)
     int i;
-    double sum_of_squares = 0, radius, half_extent;
+    double sum_of_squares = 0, extent;
-    assert(r);
+    /* assert(r); */
-	half_extent = (r->boundary[i + t->ndims_alloc] - r->boundary[i]) / 2;
+	extent = (r->boundary[i + t->ndims_alloc] - r->boundary[i]);
-	sum_of_squares += half_extent * half_extent;
+	/* extent should be half extent : /4 */
+	sum_of_squares += extent * extent / 4.;
-    radius = sqrt(sum_of_squares);
-    return (RectReal) (pow(radius, t->ndims) * UnitSphereVolumes[t->ndims]);
+    return (RectReal) (pow(sqrt(sum_of_squares), t->ndims) * UnitSphereVolumes[t->ndims]);
@@ -285,21 +291,20 @@
 RectReal RTreeRectSurfaceArea(struct RTree_Rect *r, struct RTree *t)
     int i, j;
-    RectReal j_extent, sum = (RectReal) 0;
+    RectReal face_area, sum = (RectReal) 0;
-    assert(r);
+    /*assert(r); */
-	RectReal face_area = (RectReal) 1;
+	face_area = (RectReal) 1;
 	for (j = 0; j < t->ndims; j++)
 	    /* exclude i extent from product in this dimension */
 	    if (i != j) {
-		j_extent = r->boundary[j + t->ndims_alloc] - r->boundary[j];
-		face_area *= j_extent;
+		face_area *= (r->boundary[j + t->ndims_alloc] - r->boundary[j]);
 	sum += face_area;
@@ -316,7 +321,7 @@
     int i;
     RectReal margin = 0.0;
-    assert(r);
+    /* assert(r); */
 	margin += r->boundary[i + t->ndims_alloc] - r->boundary[i];
@@ -334,19 +339,19 @@
     int i, j;
-    assert(r1 && r2 && r3);
+    /* assert(r1 && r2 && r3); */
     if (Undefined(r1, t)) {
 	for (i = 0; i < t->nsides; i++)
 	    r3->boundary[i] = r2->boundary[i];
 	return;
     if (Undefined(r2, t)) {
 	    r3->boundary[i] = r1->boundary[i];
 	return;
@@ -371,7 +376,7 @@
     int i, j;
-    assert(r1 && r2);
+    /* assert(r1 && r2); */
 	return;
@@ -397,7 +402,7 @@
     register int i, j;
-    assert(r && s);
+    /* assert(r && s); */
 	j = i + t->ndims_alloc;	/* index for high sides */
@@ -417,7 +422,7 @@
     register int i, j;
-    assert(r && s);
@@ -437,7 +442,7 @@
     register int i, j, result;
-    assert(r && s);
     /* undefined rect is contained in any other */
Modified: grass/trunk/lib/vector/rtree/rtree.h
--- grass/trunk/lib/vector/rtree/rtree.h	2012-07-31 18:06:18 UTC (rev 52488)
+++ grass/trunk/lib/vector/rtree/rtree.h	2012-07-31 18:09:02 UTC (rev 52489)
@@ -18,6 +18,7 @@
 #ifndef _R_TREE_H_
 #define _R_TREE_H_
+#include <stdlib.h>
 #include <stdio.h>
 #include <string.h>
 #include <sys/types.h>
@@ -123,13 +124,14 @@
 struct RTree
     /* RTree setup info */
-    int fd;                 	  /* file descriptor */
-    unsigned char ndims;    	  /* number of dimensions */
-    unsigned char nsides;   	  /* number of sides = 2 * ndims */
-    unsigned char ndims_alloc;    	  /* number of dimensions allocated */
+    int fd;                       /* file descriptor */
+    unsigned char ndims;          /* number of dimensions */
+    unsigned char nsides;         /* number of sides = 2 * ndims */
+    unsigned char ndims_alloc;    /* number of dimensions allocated */
     unsigned char nsides_alloc;   /* number of sides allocated = 2 * ndims allocated */
-    int nodesize;           	  /* node size in bytes */
-    int branchsize;         	  /* branch size in bytes */
+    int nodesize;                 /* node size in bytes */
+    int branchsize;               /* branch size in bytes */
+    int rectsize;                 /* rectangle size in bytes */
     /* RTree info, useful to calculate space requirements */
     int n_nodes;            /* number of nodes */
Modified: grass/trunk/lib/vector/rtree/split.c
--- grass/trunk/lib/vector/rtree/split.c	2012-07-31 18:06:18 UTC (rev 52488)
+++ grass/trunk/lib/vector/rtree/split.c	2012-07-31 18:09:02 UTC (rev 52489)
@@ -312,13 +312,10 @@
 static int RTreeCompareBranches(struct RTree_Branch *a, struct RTree_Branch *b, int side)
-    if (a->rect.boundary[side] > b->rect.boundary[side])
-	return 1;
-    else if (a->rect.boundary[side] < b->rect.boundary[side])
+    if (a->rect.boundary[side] < b->rect.boundary[side])
 	return -1;
-    /* boundaries are equal */
-    return 0;
+    return (a->rect.boundary[side] > b->rect.boundary[side]);
@@ -342,7 +339,7 @@
 static int RTreePartitionBranchBuf(int first, int last, int side, struct RTree *t)
@@ -354,26 +351,22 @@
     /* larger of two */
+    smaller = first;
     if (RTreeCompareBranches(&(t->BranchBuf[first]), &(t->BranchBuf[mid]), side)
 	== 1) {
 	smaller = mid;
-    else {
-	smaller = first;
     if (RTreeCompareBranches(&(t->BranchBuf[larger]), &(t->BranchBuf[last]), side)
 	== 1) {
+	pivot = last;
 	    (&(t->BranchBuf[smaller]), &(t->BranchBuf[last]), side) == 1) {
 	    pivot = smaller;
-	else {
-	    pivot = last;
@@ -488,8 +481,9 @@
 	smallest_overlap = DBL_MAX;
 	smallest_vol = DBL_MAX;
-	/* first lower then upper bounds for each axis */
-	for (s = 0; s < 2; s++) {
+	/* first upper then lower bounds for each axis */
+	s = 1;
+	do {
 	    RTreeQuicksortBranchBuf(i + s * t->ndims_alloc, t);
 	    side = s;
@@ -578,7 +572,7 @@
 	    }    /* end of distribution check */
-	}    /* end of side check */
+	} while (s--);   /* end of side check */
     }    /* end of axis check */
     /* Use best distribution to classify branches */
