[GRASS-SVN] r51923 - in grass/trunk: lib/python/temporal temporal temporal/t.rast.series temporal/t.vect.db.select temporal/t.vect.observe.strds
svn_grass at osgeo.org
Fri Jun 1 15:39:20 PDT 2012
Author: huhabla
Date: 2012-06-01 15:39:20 -0700 (Fri, 01 Jun 2012)
New Revision: 51923
Added:
grass/trunk/temporal/t.vect.db.select/
grass/trunk/temporal/t.vect.db.select/Makefile
grass/trunk/temporal/t.vect.db.select/t.vect.db.select.html
grass/trunk/temporal/t.vect.db.select/t.vect.db.select.py
grass/trunk/temporal/t.vect.db.select/test.t.vect.db.select.sh
grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
grass/trunk/lib/python/temporal/space_time_datasets_tools.py
grass/trunk/temporal/t.rast.series/t.rast.series.py
grass/trunk/temporal/t.rast.series/test.t.rast.series.sh
grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.py
New module to print selected database columns from space time vector
datasets. Small bugfixes.
Modified: grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
--- grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2012-06-01 22:09:42 UTC (rev 51922)
+++ grass/trunk/lib/python/temporal/abstract_space_time_dataset.py 2012-06-01 22:39:20 UTC (rev 51923)
@@ -799,9 +799,9 @@
if not map.check_valid_time():
if map.get_layer():
- core.fatal(_("Map <%s> with layer %s has invalid time") % map.get_map_id(), map.get_layer())
+ core.fatal(_("Map <%s> with layer %s has invalid time") % (map.get_map_id(), map.get_layer()))
else:
- core.fatal(_("Map <%s> has invalid time") % map.get_map_id())
+ core.fatal(_("Map <%s> has invalid time") % (map.get_map_id()))
map_id = map.base.get_id()
map_name = map.base.get_name()
Modified: grass/trunk/lib/python/temporal/space_time_datasets_tools.py
--- grass/trunk/lib/python/temporal/space_time_datasets_tools.py 2012-06-01 22:09:42 UTC (rev 51922)
+++ grass/trunk/lib/python/temporal/space_time_datasets_tools.py 2012-06-01 22:39:20 UTC (rev 51923)
@@ -197,6 +197,8 @@
else:
is_in_db = True
+ if core.overwrite == False:
+ continue
map.select(dbif)
if name and map.get_temporal_type() != sp.get_temporal_type():
dbif.close()
Modified: grass/trunk/temporal/t.rast.series/t.rast.series.py
--- grass/trunk/temporal/t.rast.series/t.rast.series.py 2012-06-01 22:09:42 UTC (rev 51922)
+++ grass/trunk/temporal/t.rast.series/t.rast.series.py 2012-06-01 22:39:20 UTC (rev 51923)
@@ -51,7 +51,7 @@
#%flag
#% key: t
-#% description: Assign the space time raster dataset start and end time to the output map
+#% description: Do not assign the space time raster dataset start and end time to the output map
#%end
import grass.script as grass
@@ -100,7 +100,7 @@
ret = grass.run_command("r.series", flags="z", file=filename, output=output, overwrite=grass.overwrite(), method=method)
- if ret == 0 and add_time:
+ if ret == 0 and not add_time:
if sp.is_time_absolute():
start_time, end_time, tz = sp.get_absolute_time()
else:
@@ -123,7 +123,7 @@
# Register the map in the temporal database
if map.is_in_db():
- map.update()
+ map.update_all()
else:
map.insert()
Modified: grass/trunk/temporal/t.rast.series/test.t.rast.series.sh
--- grass/trunk/temporal/t.rast.series/test.t.rast.series.sh 2012-06-01 22:09:42 UTC (rev 51922)
+++ grass/trunk/temporal/t.rast.series/test.t.rast.series.sh 2012-06-01 22:39:20 UTC (rev 51923)
@@ -13,17 +13,23 @@
r.mapcalc --o expr="prec_6 = 600"
# @test
-t.create --v --o type=strds temporaltype=absolute output=precip_abs title="A test" descr="A test"
+t.create --o type=strds temporaltype=absolute output=precip_abs title="A test" descr="A test"
-t.register --v type=rast input=precip_abs maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="1 months"
+t.register type=rast input=precip_abs maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="1 months"
+t.rast.list precip_abs
-t.rast.series --o input=precip_abs method=average output=prec_average where="start_time > '2001-03-01'"
-t.rast.series --o -t input=precip_abs method=maximum output=prec_max order=start_time
-t.rast.series --o -t input=precip_abs method=sum output=prec_sum
+t.rast.series --o -t input=precip_abs method=average output=prec_average where="start_time > '2001-03-01'"
+t.rast.series --o input=precip_abs method=maximum output=prec_max order=start_time
+t.rast.series input=precip_abs method=sum output=prec_sum
+t.rast.series --o input=precip_abs method=sum output=prec_sum
+# This test should raise an error
-t.unregister --v type=rast maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
-t.remove --v type=strds input=precip_abs
+r.info prec_average
+r.info prec_max
+r.info prec_sum
-r.info prec_average
-t.info type=rast input=prec_max
-t.info type=rast input=prec_sum
+t.unregister type=rast maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6,prec_sum,prec_max
+t.remove type=strds input=precip_abs
+g.remove rast=prec_sum,prec_max,prec_average
Added: grass/trunk/temporal/t.vect.db.select/Makefile
--- grass/trunk/temporal/t.vect.db.select/Makefile (rev 0)
+++ grass/trunk/temporal/t.vect.db.select/Makefile 2012-06-01 22:39:20 UTC (rev 51923)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../../
+PGM = t.vect.db.select
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script $(TEST_DST)
Added: grass/trunk/temporal/t.vect.db.select/t.vect.db.select.html
Added: grass/trunk/temporal/t.vect.db.select/t.vect.db.select.py
--- grass/trunk/temporal/t.vect.db.select/t.vect.db.select.py (rev 0)
+++ grass/trunk/temporal/t.vect.db.select/t.vect.db.select.py 2012-06-01 22:39:20 UTC (rev 51923)
@@ -0,0 +1,130 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE: t.vect.db.select
+# AUTHOR(S): Soeren Gebbert
+# PURPOSE: Prints attributes of vector maps registered in a space time vector dataset.
+# COPYRIGHT: (C) 2011 by the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (version 2). Read the file COPYING that comes with GRASS
+# for details.
+#%module
+#% description: Prints attributes of vector maps registered in a space time vector dataset.
+#% keywords: temporal
+#% keywords: vector
+#% keywords: database
+#% keywords: select
+#%end
+#%option G_OPT_STVDS_INPUT
+#%end
+#%option G_OPT_DB_COLUMNS
+#%end
+#%option
+#% key: fs
+#% type: string
+#% description: Field separator character between the output columns
+#% required: no
+#% answer: |
+#%end
+#%option G_OPT_V_FIELD
+#%end
+#%option G_OPT_DB_WHERE
+#%end
+#%option G_OPT_T_WHERE
+#% key: t_where
+#%end
+import grass.script as grass
+import grass.temporal as tgis
+import grass.script.raster as raster
+def main():
+ # Get the options
+ input = options["input"]
+ where = options["where"]
+ columns = options["columns"]
+ tempwhere = options["t_where"]
+ layer = options["layer"]
+ fs = options["fs"]
+ if where == "" or where == " " or where == "\n":
+ where = None
+ if columns == "" or columns == " " or columns == "\n":
+ columns = None
+ # Make sure the temporal database exists
+ tgis.create_temporal_database()
+ # We need a database interface
+ dbif = tgis.sql_database_interface_connection()
+ dbif.connect()
+ mapset = grass.gisenv()["MAPSET"]
+ if input.find("@") >= 0:
+ id = input
+ else:
+ id = input + "@" + mapset
+ sp = tgis.space_time_vector_dataset(id)
+ if sp.is_in_db() == False:
+ dbif.close()
+ grass.fatal(_("Space time %s dataset <%s> not found") % (sp.get_new_map_instance(None).get_type(), id))
+ sp.select(dbif)
+ rows = sp.get_registered_maps("name,layer,mapset,start_time,end_time", tempwhere, "start_time", dbif)
+ col_names = ""
+ if rows:
+ for row in rows:
+ vector_name = "%s@%s"%(row["name"], row["mapset"])
+ # In case a layer is defined in the vector dataset, we override the option layer
+ if row["layer"]:
+ layer = row["layer"]
+ select = grass.read_command("v.db.select", map=vector_name, layer=layer, columns=columns, fs="%s"%(fs), where=where)
+ if not select:
+ dbif.close()
+ grass.fatal(_("Unable to run v.db.select for vector map <%s> with layer %s")%(vector_name, layer))
+ # The first line are the column names
+ list = select.split("\n")
+ count = 0
+ for entry in list:
+ if entry.strip() != "":
+ # print the column names in case they change
+ if count == 0:
+ col_names_new = "start_time%send_time%s%s"%(fs, fs, entry)
+ if col_names != col_names_new:
+ col_names = col_names_new
+ print col_names
+ else:
+ if row["end_time"]:
+ print "%s%s%s%s%s"%(row["start_time"],fs, row["end_time"], fs, entry)
+ else:
+ print "%s%s%s%s"%(row["start_time"], fs, fs, entry)
+ count += 1
+ dbif.close()
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ main()
Property changes on: grass/trunk/temporal/t.vect.db.select/t.vect.db.select.py
___________________________________________________________________
Added: svn:executable
Added: grass/trunk/temporal/t.vect.db.select/test.t.vect.db.select.sh
--- grass/trunk/temporal/t.vect.db.select/test.t.vect.db.select.sh (rev 0)
+++ grass/trunk/temporal/t.vect.db.select/test.t.vect.db.select.sh 2012-06-01 22:39:20 UTC (rev 51923)
@@ -0,0 +1,43 @@
+#!/bin/sh
+# Test the database output of vector maps in a space time vector dataset
+# We need to set a specific region in the
+# @preprocess step of this test.
+# The region setting should work for UTM and LL test locations
+g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
+r.mapcalc --o expr="prec_1 = 100.0"
+r.mapcalc --o expr="prec_2 = 200.0"
+r.mapcalc --o expr="prec_3 = 300"
+r.mapcalc --o expr="prec_4 = 400"
+r.mapcalc --o expr="prec_5 = 500.0"
+r.mapcalc --o expr="prec_6 = 600.0"
+v.random --o -z output=prec n=5 seed=1
+t.create --o type=strds temporaltype=absolute output=precip_abs1 title="A test" descr="A test"
+t.register -i input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-03-01 00:00:00" increment="1 months"
+# The @test
+# We need to create a nice space time vector dataset with layers for testing
+t.vect.observe.strds input=prec strds=precip_abs1 output=prec_observer column=observation
+t.vect.list input=prec_observer
+t.vect.db.select input=prec_observer
+t.vect.db.select input=prec_observer where="cat = 1" fs=" | "
+t.vect.db.select input=prec_observer where="cat = 1" fs=" | " columns=observation
+# Time instances
+t.register --o input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2004-01-01 00:00:00" increment="3 months"
+t.vect.observe.strds --o input=prec strds=precip_abs1 output=prec_observer
+# @postprocess
+t.remove type=strds input=precip_abs1
+t.remove type=stvds input=prec_observer
+t.unregister type=vect maps=prec_observer:1,prec_observer:2,prec_observer:3,prec_observer:4,prec_observer:5,prec_observer:6
+g.remove vect=prec_observer,test_extract
+g.remove rast=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
Property changes on: grass/trunk/temporal/t.vect.db.select/test.t.vect.db.select.sh
Modified: grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.py
--- grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.py 2012-06-01 22:09:42 UTC (rev 51922)
+++ grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.py 2012-06-01 22:39:20 UTC (rev 51923)
@@ -189,7 +189,7 @@
vect.set_relative_time(start, end, strds_ds.get_relative_time_unit())
if vect.is_in_db(dbif):
- vect.update(dbif)
+ vect.update_all(dbif)
else:
vect.insert(dbif)
