[GRASS-SVN] r51926 - grass-addons/grass7/imagery/i.segment
Fri Jun 1 22:01:01 PDT 2012
Author: momsen
Date: 2012-06-01 22:01:01 -0700 (Fri, 01 Jun 2012)
New Revision: 51926
Added:
   grass-addons/grass7/imagery/i.segment/parse_args.c
Removed:
   grass-addons/grass7/imagery/i.segment/get_input.c
   grass-addons/grass7/imagery/i.segment/iseg.h
renamed get_input to parse_args.  (still bugs, per previous commit note)
Deleted: grass-addons/grass7/imagery/i.segment/get_input.c
--- grass-addons/grass7/imagery/i.segment/get_input.c	2012-06-02 04:58:33 UTC (rev 51925)
+++ grass-addons/grass7/imagery/i.segment/get_input.c	2012-06-02 05:01:01 UTC (rev 51926)
@@ -1,273 +0,0 @@
-/* PURPOSE:      Parse and validate the input, including opening input rasters and creating segmentation files */
-#include <stdlib.h>
-#include <string.h>
-#include <fcntl.h>		/* needed for creat and open for the segmentation files.
-				   used those functions per the programmer's manual, correct usage? */
-#include <grass/gis.h>
-#include <grass/glocale.h>
-#include <grass/imagery.h>
-#include <grass/segment.h>	/* segmentation library */
-#include "iseg.h"
-int parse_args(int argc, char *argv[], struct files *files,
-	       struct functions *functions)
-    /* reference: http://grass.osgeo.org/programming7/gislib.html#Command_Line_Parsing */
-    struct Option *group, *subgroup, *seeds, *output, *method, *threshold;	/* Establish an Option pointer for each option */
-    struct Flag *diagonal;	/* Establish a Flag pointer for each option */
-    group = G_define_standard_option(G_OPT_I_GROUP);
-    subgroup = G_define_standard_option(G_OPT_I_SUBGROUP);
-    /* OK to require the user to create a group?  Otherwise later add an either/or option to give just a single raster map... */
-    //~ input = G_define_standard_option(G_OPT_R_INPUT);   /* Request a pointer to memory for each option */
-    //~ input->key = "input"; /* TODO: update to allow groups.  Maybe this needs a group/subgroup variables, or we can check if the input is group/subgroup/raster */
-    //~ input->type = TYPE_STRING;
-    //~ input->required = YES;
-    //~ input->description = _("Raster map to be segmented.");
-    /* Using raster for seeds, maybe consider allowing vector points/centroids later. */
-    seeds = G_define_standard_option(G_OPT_R_INPUT);
-    seeds->key = "seeds";
-    seeds->type = TYPE_STRING;
-    seeds->required = NO;
-    seeds->description = _("Optional raster map with starting seeds.");
-    output = G_define_standard_option(G_OPT_R_OUTPUT);
-    //seems API handles this part ?
-    //~ output->key = "output";
-    //~ output->type = TYPE_STRING;
-    //~ output->required = YES;
-    //~ output->description = _("Name of output raster map.");
-    //TODO: when put in a new raster map, error message:
-    //~ Command 'd.rast map=testing at samples' failed
-    //~ Details: Raster map <testing at samples> not found
-    //Also, that error seems to be accumulated, putting in a new output map names results in:
-    //~ Command 'd.rast map=test2 at samples' failed
-    //~ Details: Raster map <test2 at samples> not found
-    method = G_define_option();
-    method->key = "method";
-    method->type = TYPE_STRING;
-    method->required = NO;
-    method->answer = _("region_growing");
-    method->options = "region_growing, mean_shift";
-    method->description = _("Segmentation method.");
-    threshold = G_define_option();
-    threshold->key = "threshold";
-    threshold->type = TYPE_DOUBLE;
-    threshold->required = YES;
-    threshold->description = _("Similarity threshold.");
-    diagonal = G_define_flag();
-    diagonal->key = 'd';
-    diagonal->description =
-	_
-	("Use 8 neighbors (3x3 neighborhood) instead of the default 4 neighbors for each pixel.");
-    //~ G_debug(1, "testing debug!");
-    //~ When put this in, get an error (only when DEBUG is set, if not set, it runs fine)
-    //~ Error box:
-    //~ Unable to fetch interface description for command 'i.segment'.
-    //~ Details: D1/1: testing debug!
-    //~ G_debug(1, "For the option <%s> you chose: <%s>",
-    //~ input->description, input->answer);
-    //~ seeds->description, seeds->answer);
-    //~ output->description, output->answer);
-    //~ method->description, method->answer);
-    //~ threshold->description, threshold->answer);
-    //~ G_debug(1, "The value of the diagonal flag is: %d", diagonal->answer);
-    if (G_parser(argc, argv))
-	exit(EXIT_FAILURE);
-    /* Validation */
-    /* use checker for any of the data validation steps!? */
-    /* ToDo The most important things to check are if the
-       input and output raster maps can be opened (non-negative file
-       descriptor). */
-    /* Check and save parameters */
-    sscanf(threshold->answer, "%f", &functions->threshold);
-    /* I'm assuming it is already validated as a number.  Is this OK, or is there a better way to cast the input? */
-    /* r.cost line 313
-       if (sscanf(opt5->answer, "%d", &maxcost) != 1 || maxcost < 0)
-       G_fatal_error(_("Inappropriate maximum cost: %d"), maxcost); */
-    /* TODO: The following routines create a new raster map in the current mapset and open it for writing. G_legal_filename() should be called first to make sure that raster map name is a valid name. */
-    files->out_name = output->answer;	/* name of output raster map */
-    /* Open Files (file segmentation) */
-    G_verbose_message("Checking image (sub)group...");
-    /* references: i.cost and http://grass.osgeo.org/programming7/segmentlib.html */
-    struct Ref Ref;		/* subgroup reference list */
-    int *in_fd, *seg_in_fd, seg_out_fd;
-    RASTER_MAP_TYPE data_type;
-    int n, row, nrows, ncols, srows, scols, seg_in_mem;
-    void *inbuf;
-    const char *in_file[10], *out_file;	/* max 10 rasters in imagery group, until figure out how to do this dynamically */
-    /* int buf[NCOLS]; */
-    /* c question... will using void data type be the right way, until I know what the data type is? */
-    /* that was in the developer's manual... but would void *buf also work? */
-    /* void *buf; *//* for copying from raster into segmentation file */
-    /* ****** open the input rasters ******* */
-    /* i.smap/openfiles.c  lines 17-23 checked if subgroup had maps, does API handles the checks?
-       can no subgroup be entered, just a group? */
-    if (!I_get_subgroup_ref(group->answer, subgroup->answer, &Ref))
-	G_fatal_error(_
-		      ("Unable to read REF file for subgroup <%s> in group <%s>"),
-		      subgroup->answer, group->answer);
-    if (Ref.nfiles <= 0)
-	G_fatal_error(_
-		      ("Subgroup <%s> in group <%s> contains no raster maps"),
-    /* open input group maps for reading */
-    in_fd = G_malloc(Ref.nfiles * sizeof(seg_out_fd));	/* need sizeof( integer ) */
-    G_verbose_message("Opening input rasters...");
-    for (n = 0; n < Ref.nfiles; n++) {
-	in_fd[n] = Rast_open_old(Ref.file[n].name, Ref.file[n].mapset);
-    /* ********** find out file segmentation size ************ */
-    G_verbose_message("Calculate temp file sizes...");
-    /*loop again... need to get largest option
-       //for today assume all are the same
-       //data_type = Rast_get_map_type(in_fd[n]); */
-    files->nbands = Ref.nfiles;
-    data_type = Rast_get_map_type(in_fd[0]);
-    files->data_type = data_type;
-    nrows = Rast_window_rows();
-    ncols = Rast_window_cols();
-    /*TODO: i.cost and i.watershed take different approaches...
-       //hardcode for now */
-    srows = nrows / 8;
-    scols = ncols / 8;
-    /* TODO: make calculations for this */
-    seg_in_mem = 4;
-    /*    G_debug(1, "  %d rows, %d cols", nrows, ncols); ... never tried this, just copied from other module */
-    /* ******* create temporary segmentation files ********* */
-    G_verbose_message("Getting temp file names...");
-    /* Initalize access to database and create temporary files */
-	in_file[n] = G_tempfile();
-    out_file = G_tempfile();
-    /* Format segmented files */
-    seg_in_fd = G_malloc(Ref.nfiles * sizeof(seg_out_fd));	/* need sizeof( integer ) */
-    G_verbose_message("Creating temporary data files...");
-	seg_in_fd[n] = creat(&in_file[n], 0666);
-	if (segment_format(seg_in_fd[n], nrows, ncols, srows, scols, sizeof(data_type)) != 1)	/* TODO: this data_type should be from each map */
-	    G_fatal_error("can not create temporary file");
-	close(seg_in_fd[n]);	/* why close when we just reopen again?  Different access mode between creat and open ? */
-    seg_out_fd = creat(out_file, 0666);
-	(seg_out_fd, nrows, ncols, srows, scols, sizeof(data_type)) != 1)
-    close(seg_out_fd);
-    /* Open and initialize all segment files */
-    G_debug(1, "Initializing temporary data files...");	/* program dies sometime after this point, and before line 234 */
-	seg_in_fd[n] = open(&in_file[n], 2);	/* TODO: second parameter here is different in many places... */
-	if (segment_init(&files->bands_seg[n], seg_in_fd[n], seg_in_mem) != 1)
-	    G_fatal_error("can not initialize temporary file");
-    seg_out_fd = open(out_file, 2);
-    if (segment_init(&files->out_seg, seg_out_fd, seg_in_mem) != 1)
-    /* convert flat files to segmented files */
-    G_verbose_message("Read input rasters into temporary data files...");
-    inbuf = Rast_allocate_buf(data_type);	/* buffer from the raster file */
-    /* buf = new data_type [ncols] *//* buffer to read data into, cell by cell.  But can I just write inbuf directly to the segmentation file??? */
-	for (row = 0; row < nrows; row++) {
-	    Rast_get_row(in_fd[n], inbuf, row, data_type);
-	    //~ for (col = 0; col < ncols; col++)
-	    //~ /*fill buf */
-	    //~ // G_incr_void_ptr
-	    segment_put_row(&files->bands_seg[n], inbuf, row);
-    /* Don't need to do anything else for the output segmentation file?  It is initialized to zeros and will be written to later... */
-    /* Free memory */
-	Rast_close(in_fd[n]);
-    G_free(inbuf);
-    G_free(in_fd);
-    G_free(seg_in_fd);
-    /* Need to clean up anything else?  Need to close segmentation files?  Or they should be open still since they will be used later?  Close after all processing is done? */
-       from r.cost
-       unlink(in_file); *//* remove submatrix files  */
-    return 0;
Modified: grass-addons/grass7/imagery/i.segment/iseg.h
--- grass-addons/grass7/imagery/i.segment/iseg.h	2012-06-02 04:58:33 UTC (rev 51925)
+++ grass-addons/grass7/imagery/i.segment/iseg.h	2012-06-02 05:01:01 UTC (rev 51926)
@@ -56,7 +56,7 @@
-/* get_input.c */
+/* parse_args.c */
 /* gets input from user, validates, opens files, and sets up functions */
 int parse_args(int, char *[], struct files *, struct functions *);
Copied: grass-addons/grass7/imagery/i.segment/parse_args.c (from rev 51925, grass-addons/grass7/imagery/i.segment/get_input.c)
--- grass-addons/grass7/imagery/i.segment/parse_args.c	                        (rev 0)
+++ grass-addons/grass7/imagery/i.segment/parse_args.c	2012-06-02 05:01:01 UTC (rev 51926)
@@ -0,0 +1,273 @@
+/* PURPOSE:      Parse and validate the input, including opening input rasters and creating segmentation files */
+#include <stdlib.h>
+#include <string.h>
+#include <fcntl.h>		/* needed for creat and open for the segmentation files.
+				   used those functions per the programmer's manual, correct usage? */
+#include <grass/gis.h>
+#include <grass/glocale.h>
+#include <grass/imagery.h>
+#include <grass/segment.h>	/* segmentation library */
+#include "iseg.h"
+int parse_args(int argc, char *argv[], struct files *files,
+	       struct functions *functions)
+    /* reference: http://grass.osgeo.org/programming7/gislib.html#Command_Line_Parsing */
+    struct Option *group, *subgroup, *seeds, *output, *method, *threshold;	/* Establish an Option pointer for each option */
+    struct Flag *diagonal;	/* Establish a Flag pointer for each option */
+    group = G_define_standard_option(G_OPT_I_GROUP);
+    subgroup = G_define_standard_option(G_OPT_I_SUBGROUP);
+    /* OK to require the user to create a group?  Otherwise later add an either/or option to give just a single raster map... */
+    //~ input = G_define_standard_option(G_OPT_R_INPUT);   /* Request a pointer to memory for each option */
+    //~ input->key = "input"; /* TODO: update to allow groups.  Maybe this needs a group/subgroup variables, or we can check if the input is group/subgroup/raster */
+    //~ input->type = TYPE_STRING;
+    //~ input->required = YES;
+    //~ input->description = _("Raster map to be segmented.");
+    /* Using raster for seeds, maybe consider allowing vector points/centroids later. */
+    seeds = G_define_standard_option(G_OPT_R_INPUT);
+    seeds->key = "seeds";
+    seeds->type = TYPE_STRING;
+    seeds->required = NO;
+    seeds->description = _("Optional raster map with starting seeds.");
+    output = G_define_standard_option(G_OPT_R_OUTPUT);
+    //seems API handles this part ?
+    //~ output->key = "output";
+    //~ output->type = TYPE_STRING;
+    //~ output->required = YES;
+    //~ output->description = _("Name of output raster map.");
+    //TODO: when put in a new raster map, error message:
+    //~ Command 'd.rast map=testing at samples' failed
+    //~ Details: Raster map <testing at samples> not found
+    //Also, that error seems to be accumulated, putting in a new output map names results in:
+    //~ Command 'd.rast map=test2 at samples' failed
+    //~ Details: Raster map <test2 at samples> not found
+    method = G_define_option();
+    method->key = "method";
+    method->type = TYPE_STRING;
+    method->required = NO;
+    method->answer = _("region_growing");
+    method->options = "region_growing, mean_shift";
+    method->description = _("Segmentation method.");
+    threshold = G_define_option();
+    threshold->key = "threshold";
+    threshold->type = TYPE_DOUBLE;
+    threshold->required = YES;
+    threshold->description = _("Similarity threshold.");
+    diagonal = G_define_flag();
+    diagonal->key = 'd';
+    diagonal->description =
+	_
+	("Use 8 neighbors (3x3 neighborhood) instead of the default 4 neighbors for each pixel.");
+    //~ G_debug(1, "testing debug!");
+    //~ When put this in, get an error (only when DEBUG is set, if not set, it runs fine)
+    //~ Error box:
+    //~ Unable to fetch interface description for command 'i.segment'.
+    //~ Details: D1/1: testing debug!
+    //~ G_debug(1, "For the option <%s> you chose: <%s>",
+    //~ input->description, input->answer);
+    //~ seeds->description, seeds->answer);
+    //~ output->description, output->answer);
+    //~ method->description, method->answer);
+    //~ threshold->description, threshold->answer);
+    //~ G_debug(1, "The value of the diagonal flag is: %d", diagonal->answer);
+    if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
+    /* Validation */
+    /* use checker for any of the data validation steps!? */
+    /* ToDo The most important things to check are if the
+       input and output raster maps can be opened (non-negative file
+       descriptor). */
+    /* Check and save parameters */
+    sscanf(threshold->answer, "%f", &functions->threshold);
+    /* I'm assuming it is already validated as a number.  Is this OK, or is there a better way to cast the input? */
+    /* r.cost line 313
+       if (sscanf(opt5->answer, "%d", &maxcost) != 1 || maxcost < 0)
+       G_fatal_error(_("Inappropriate maximum cost: %d"), maxcost); */
+    /* TODO: The following routines create a new raster map in the current mapset and open it for writing. G_legal_filename() should be called first to make sure that raster map name is a valid name. */
+    files->out_name = output->answer;	/* name of output raster map */
+    /* Open Files (file segmentation) */
+    G_verbose_message("Checking image (sub)group...");
+    /* references: i.cost and http://grass.osgeo.org/programming7/segmentlib.html */
+    struct Ref Ref;		/* subgroup reference list */
+    int *in_fd, *seg_in_fd, seg_out_fd;
+    RASTER_MAP_TYPE data_type;
+    int n, row, nrows, ncols, srows, scols, seg_in_mem;
+    void *inbuf;
+    const char *in_file[10], *out_file;	/* max 10 rasters in imagery group, until figure out how to do this dynamically */
+    /* int buf[NCOLS]; */
+    /* c question... will using void data type be the right way, until I know what the data type is? */
+    /* that was in the developer's manual... but would void *buf also work? */
+    /* void *buf; *//* for copying from raster into segmentation file */
+    /* ****** open the input rasters ******* */
+    /* i.smap/openfiles.c  lines 17-23 checked if subgroup had maps, does API handles the checks?
+       can no subgroup be entered, just a group? */
+    if (!I_get_subgroup_ref(group->answer, subgroup->answer, &Ref))
+	G_fatal_error(_
+		      ("Unable to read REF file for subgroup <%s> in group <%s>"),
+		      subgroup->answer, group->answer);
+    if (Ref.nfiles <= 0)
+	G_fatal_error(_
+		      ("Subgroup <%s> in group <%s> contains no raster maps"),
+    /* open input group maps for reading */
+    in_fd = G_malloc(Ref.nfiles * sizeof(seg_out_fd));	/* need sizeof( integer ) */
+    G_verbose_message("Opening input rasters...");
+    for (n = 0; n < Ref.nfiles; n++) {
+	in_fd[n] = Rast_open_old(Ref.file[n].name, Ref.file[n].mapset);
+    /* ********** find out file segmentation size ************ */
+    G_verbose_message("Calculate temp file sizes...");
+    /*loop again... need to get largest option
+       //for today assume all are the same
+       //data_type = Rast_get_map_type(in_fd[n]); */
+    files->nbands = Ref.nfiles;
+    data_type = Rast_get_map_type(in_fd[0]);
+    files->data_type = data_type;
+    nrows = Rast_window_rows();
+    ncols = Rast_window_cols();
+    /*TODO: i.cost and i.watershed take different approaches...
+       //hardcode for now */
+    srows = nrows / 8;
+    scols = ncols / 8;
+    /* TODO: make calculations for this */
+    seg_in_mem = 4;
+    /*    G_debug(1, "  %d rows, %d cols", nrows, ncols); ... never tried this, just copied from other module */
+    /* ******* create temporary segmentation files ********* */
+    G_verbose_message("Getting temp file names...");
+    /* Initalize access to database and create temporary files */
+	in_file[n] = G_tempfile();
+    out_file = G_tempfile();
+    /* Format segmented files */
+    seg_in_fd = G_malloc(Ref.nfiles * sizeof(seg_out_fd));	/* need sizeof( integer ) */
+    G_verbose_message("Creating temporary data files...");
+	seg_in_fd[n] = creat(&in_file[n], 0666);
+	if (segment_format(seg_in_fd[n], nrows, ncols, srows, scols, sizeof(data_type)) != 1)	/* TODO: this data_type should be from each map */
+	    G_fatal_error("can not create temporary file");
+	close(seg_in_fd[n]);	/* why close when we just reopen again?  Different access mode between creat and open ? */
+    seg_out_fd = creat(out_file, 0666);
+	(seg_out_fd, nrows, ncols, srows, scols, sizeof(data_type)) != 1)
+    close(seg_out_fd);
+    /* Open and initialize all segment files */
+    G_debug(1, "Initializing temporary data files...");	/* program dies sometime after this point, and before line 234 */
+	seg_in_fd[n] = open(&in_file[n], 2);	/* TODO: second parameter here is different in many places... */
+	if (segment_init(&files->bands_seg[n], seg_in_fd[n], seg_in_mem) != 1)
+	    G_fatal_error("can not initialize temporary file");
+    seg_out_fd = open(out_file, 2);
+    if (segment_init(&files->out_seg, seg_out_fd, seg_in_mem) != 1)
+    /* convert flat files to segmented files */
+    G_verbose_message("Read input rasters into temporary data files...");
+    inbuf = Rast_allocate_buf(data_type);	/* buffer from the raster file */
+    /* buf = new data_type [ncols] *//* buffer to read data into, cell by cell.  But can I just write inbuf directly to the segmentation file??? */
+	for (row = 0; row < nrows; row++) {
+	    Rast_get_row(in_fd[n], inbuf, row, data_type);
+	    //~ for (col = 0; col < ncols; col++)
+	    //~ /*fill buf */
+	    //~ // G_incr_void_ptr
+	    segment_put_row(&files->bands_seg[n], inbuf, row);
+    /* Don't need to do anything else for the output segmentation file?  It is initialized to zeros and will be written to later... */
+    /* Free memory */
+	Rast_close(in_fd[n]);
+    G_free(inbuf);
+    G_free(in_fd);
+    G_free(seg_in_fd);
+    /* Need to clean up anything else?  Need to close segmentation files?  Or they should be open still since they will be used later?  Close after all processing is done? */
+       from r.cost
+       unlink(in_file); *//* remove submatrix files  */
+    return 0;
