[GRASS-SVN] r51932 - grass/branches/develbranch_6/lib/python
svn_grass at osgeo.org
Sat Jun 2 03:46:44 PDT 2012
Author: martinl
Date: 2012-06-02 03:46:43 -0700 (Sat, 02 Jun 2012)
New Revision: 51932
grass/branches/develbranch_6/lib/python/db.py
pythonlib: sync db_select() with trunk - argument 'table' should be optional
Modified: grass/branches/develbranch_6/lib/python/db.py
--- grass/branches/develbranch_6/lib/python/db.py 2012-06-02 10:35:22 UTC (rev 51931)
+++ grass/branches/develbranch_6/lib/python/db.py 2012-06-02 10:46:43 UTC (rev 51932)
@@ -84,36 +84,64 @@
s = read_command('db.connect', flags = 'p')
return parse_key_val(s, sep = ':')
-def db_select(table, sql, file = False, **args):
+def db_select(sql = None, filename = None, table = None, **args):
"""!Perform SQL select statement
- @param table table name
- @param sql SQL select statement (string or file)
- @param file True if sql is filename
+ Note: one of <em>sql</em>, <em>filename</em>, or <em>table</em>
+ must be provided.
+ Examples:
+ \code
+ grass.db_select(sql = 'SELECT cat,CAMPUS FROM busstopsall WHERE cat < 4')
+ (('1', 'Vet School'), ('2', 'West'), ('3', 'North'))
+ \endcode
+ \code
+ grass.db_select(filename = '/path/to/sql/file')
+ \endcode
+ Simplyfied usage
+ \code
+ grass.db_select(table = 'busstopsall')
+ \endcode
+ performs <tt>SELECT cat,CAMPUS FROM busstopsall</tt>.
+ @param sql SQL statement to perform (or None)
+ @param filename name of file with SQL statements (or None)
+ @param table name of table to query (or None)
@param args see db.select arguments
fname = tempfile()
- if not file:
- ret = run_command('db.select', quiet = True,
- flags = 'c',
- table = table,
- sql = sql,
- output = fname,
- **args)
- else: # -> sql is file
- flags = 'c',
- table = table,
- input = sql,
- output = fname,
- **args)
+ if sql:
+ args['sql'] = sql
+ elif filename:
+ args['input'] = filename
+ elif table:
+ args['table'] = table
+ else:
+ fatal(_("Programmer error: '%s', '%s', or '%s' must be provided") %
+ 'sql', 'filename', 'table')
+ if 'fs' not in args:
+ args['fs'] = '|'
+ ret = run_command('db.select', quiet = True,
+ flags = 'c',
+ output = fname,
+ **args)
if ret != 0:
- fatal(_("Fetching data from table <%s> failed") % table)
+ fatal(_("Fetching data failed"))
ofile = open(fname)
- result = map(lambda x: x.rstrip(os.linesep), ofile.readlines())
+ result = map(lambda x: tuple(x.rstrip(os.linesep).split(args['fs'])),
+ ofile.readlines())
ofile.close()
try_remove(fname)
- return result
+ return tuple(result)
