[GRASS-SVN] r51944 - grass/trunk/db/db.select
svn_grass at osgeo.org
Sun Jun 3 02:58:40 PDT 2012
Author: martinl
Date: 2012-06-03 02:58:40 -0700 (Sun, 03 Jun 2012)
New Revision: 51944
grass/trunk/db/db.select/db.select.html
grass/trunk/db/db.select/main.c
db.select: add support for multiple statements in the file
fix r51929 (input=-)
Modified: grass/trunk/db/db.select/db.select.html
--- grass/trunk/db/db.select/db.select.html 2012-06-03 09:57:13 UTC (rev 51943)
+++ grass/trunk/db/db.select/db.select.html 2012-06-03 09:58:40 UTC (rev 51944)
@@ -1,15 +1,16 @@
<h2>DESCRIPTION</h2>
-<em>db.select</em> prints result of selection from database
-based on SQL statement read from input file or from standard input
-to standard output.
+<em>db.select</em> prints result of selection from database based on
+SQL statement read from input file or from standard input to standard
+output.
<h2>NOTE</h2>
If parameters for database connection are already set with
<em><a href="db.connect.html">db.connect</a></em>, they are taken as
default values and do not need to be specified each time. Output will
-be displayed to standard output or can be directed to a file (option <b>output</b>).
+be displayed to standard output or can be directed to a file
+(option <b>output</b>).
<h2>EXAMPLES</h2>
@@ -19,21 +20,21 @@
</pre></div>
or
<div class="code"><pre>
-echo "select * from roads" | db.select
+echo "select * from roads" | db.select input=-
</pre></div>
or
-cat file.sql | db.select
+db.select input=file.sql
</pre></div>
or
-db.select input=file.sql
+cat file.sql | db.select input=-
</pre></div>
<p>
Select all from table roads:
-db.select -c driver=odbc database=g51test table=roads input=file.sql > result.csv
+db.select -c driver=odbc database=g51test table=roads input=file.sql output=result.csv
</pre></div>
<p>
@@ -54,6 +55,16 @@
db.select sql="SELECT x(geo),y(geo) FROM localizzazione"
</pre></div>
+<p>Execute multiple SQL statements:
+<div class="code"><pre>
+cat file.sql
+SELECT * FROM busstopsall WHERE cat = 1
+SELECT cat FROM busstopsall WHERE cat > 4 AND cat < 8
+</pre></div>
<h2>SEE ALSO</h2>
<em>
@@ -73,8 +84,9 @@
<h2>AUTHOR</h2>
-Original author unknown<br>
-Modifications: Radim Blazek, ITC-Irst, Trento, Italy
+Original author unknown (probably CERL)<br>
+Modifications by Radim Blazek, ITC-Irst, Trento, Italy<br>
+Support for multiple statements by Martin Landa, Czech Technical University in Prague
<p>
<i>Last changed: $Date$</i>
Modified: grass/trunk/db/db.select/main.c
--- grass/trunk/db/db.select/main.c 2012-06-03 09:57:13 UTC (rev 51943)
+++ grass/trunk/db/db.select/main.c 2012-06-03 09:58:40 UTC (rev 51944)
@@ -26,8 +26,7 @@
#include <grass/glocale.h>
#include "local_proto.h"
-struct
+struct {
char *driver, *database, *table, *sql, *fs, *vs, *nv, *input, *output;
int c, d, h, test_only;
} parms;
@@ -39,7 +38,6 @@
static int get_stmt(FILE *, dbString *);
static int stmt_is_empty(dbString *);
int main(int argc, char **argv)
dbString stmt;
@@ -50,8 +48,8 @@
parse_command_line(argc, argv);
- errno = 0;
- if (parms.input) {
+ /* read from file or stdin ? */
+ if (parms.input && strcmp(parms.input, "-") != 0) {
fd = fopen(parms.input, "r");
if (fd == NULL) {
G_fatal_error(_("Unable to open file <%s>: %s"),
@@ -61,6 +59,7 @@
else
fd = stdin;
+ /* open DB connection */
db_init_string(&stmt);
driver = db_start_driver(parms.driver);
@@ -73,25 +72,25 @@
if (db_open_database(driver, &handle) != DB_OK)
G_fatal_error(_("Unable to open database <%s>"), parms.database);
+ /* check for sql, table, and input */
if (parms.sql) {
- if (strcmp(parms.sql, "-") == 0) {
- /* read stdin */
- stat = OK;
- while (stat == OK && get_stmt(fd, &stmt)) {
- if (!stmt_is_empty(&stmt))
- stat = sel(driver, &stmt);
- else {
- db_set_string(&stmt, parms.sql);
+ /* parms.sql */
+ db_set_string(&stmt, parms.sql);
+ stat = sel(driver, &stmt);
else if (parms.table) {
- db_set_string(&stmt, "select * from ");
+ /* parms.table */
+ db_set_string(&stmt, "SELECT * FROM ");
db_append_string(&stmt, parms.table);
+ else { /* -> parms.input */
+ stat = OK;
+ while (stat == OK && get_stmt(fd, &stmt)) {
+ if (!stmt_is_empty(&stmt))
if(parms.test_only)
G_verbose_message(_("Test %s."), stat ? _("failed") : _("succeeded"));
@@ -99,11 +98,11 @@
db_close_database(driver);
db_shutdown_driver(driver);
- exit(stat);
+ exit(stat == OK ? EXIT_SUCCESS : EXIT_FAILURE);
-static int sel(dbDriver * driver, dbString * stmt)
+int sel(dbDriver * driver, dbString * stmt)
dbCursor cursor;
dbTable *table;
@@ -149,7 +148,7 @@
/* fetch the data */
- while (1) {
+ while (TRUE) {
if (db_fetch(&cursor, DB_NEXT, &more) != DB_OK)
return ERROR;
if (!more)
@@ -180,7 +179,7 @@
-static void parse_command_line(int argc, char **argv)
+void parse_command_line(int argc, char **argv)
struct Option *driver, *database, *table, *sql,
@@ -197,7 +196,7 @@
input = G_define_standard_option(G_OPT_F_INPUT);
input->required = NO;
input->label = _("Name of file containing SQL select statement(s)");
- input->description = _("One SQL statement per line");
+ input->description = _("'-' for standard input");
input->guisection = _("Query");
table = G_define_standard_option(G_OPT_DB_TABLE);
@@ -262,10 +261,11 @@
G_add_keyword(_("database"));
G_add_keyword(_("attribute table"));
G_add_keyword(_("SQL"));
- module->description = _("Selects data from attribute table (performs SQL query statement(s)).");
+ module->label = _("Selects data from attribute table.");
+ module->description = _("Performs SQL query statement(s).");
if (G_parser(argc, argv))
- exit(EXIT_SUCCESS);
+ exit(EXIT_FAILURE);
parms.driver = driver->answer;
parms.database = database->answer;
@@ -278,14 +278,14 @@
parms.output = output->answer;
if (!c->answer)
- parms.c = 1;
+ parms.c = TRUE;
else
- parms.c = 0;
+ parms.c = FALSE;
parms.d = d->answer;
if (!v->answer)
- parms.h = 1;
+ parms.h = TRUE;
else
- parms.h = 0;
+ parms.h = FALSE;
parms.test_only = flag_test->answer;
@@ -302,30 +302,22 @@
sql->key, input->key, table->key);
-static int get_stmt(FILE * fd, dbString * stmt)
+int get_stmt(FILE * fd, dbString * stmt)
- char buf[1024];
- int n;
- static int first = 1;
+ char buf[DB_SQL_MAX];
db_zero_string(stmt);
- /* this is until get_stmt is smart enough to handle multiple stmts */
- if (!first)
- return 0;
- first = 0;
- while ((n = fread(buf, 1, sizeof(buf) - 1, fd)) > 0) {
- buf[n] = 0;
- db_append_string(stmt, buf);
+ if (G_getl2(buf, sizeof(buf), fd) == 0)
+ return 0;
+ db_set_string(stmt, buf);
return 1;
-static int stmt_is_empty(dbString * stmt)
+int stmt_is_empty(dbString * stmt)
char dummy[2];
